[U-Boot] [PATCH 1/2] ext4fs ls load support
Signed-off-by: Uma Shankar uma.shankar@samsung.com Signed-off-by: Manjunatha C Achar a.manjunatha@samsung.com Signed-off-by: Iqbal Shareef iqbal.ams@samsung.com Signed-off-by: Hakgoo Lee goodguy.lee@samsung.com --- Makefile | 2 +- common/Makefile | 1 + common/cmd_ext2.c | 1 + common/cmd_ext4.c | 253 ++++++++++++++++++++++ fs/Makefile | 1 + fs/ext2/dev.c | 1 + fs/ext2/ext2fs.c | 340 +++--------------------------- fs/ext4/Makefile | 51 +++++ fs/ext4/ext4_common.c | 573 +++++++++++++++++++++++++++++++++++++++++++++++++ fs/ext4/ext4_common.h | 44 ++++ fs/ext4/ext4fs.c | 215 ++++++++++++++++++ include/ext2fs.h | 16 +- include/ext4fs.h | 116 ++++++++++ include/ext_common.h | 199 +++++++++++++++++ 14 files changed, 1489 insertions(+), 324 deletions(-) create mode 100644 common/cmd_ext4.c create mode 100644 fs/ext4/Makefile create mode 100644 fs/ext4/ext4_common.c create mode 100644 fs/ext4/ext4_common.h create mode 100644 fs/ext4/ext4fs.c create mode 100644 include/ext4fs.h create mode 100644 include/ext_common.h
diff --git a/Makefile b/Makefile index 5de7915..20cb941 100644 --- a/Makefile +++ b/Makefile @@ -235,7 +235,7 @@ LIBS += dts/libdts.o endif LIBS += arch/$(ARCH)/lib/lib$(ARCH).o LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o \ - fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/yaffs2/libyaffs2.o \ + fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/ext4/libext4fs.o fs/yaffs2/libyaffs2.o \ fs/ubifs/libubifs.o LIBS += net/libnet.o LIBS += disk/libdisk.o diff --git a/common/Makefile b/common/Makefile index 2d9ae8c..d99cc31 100644 --- a/common/Makefile +++ b/common/Makefile @@ -87,6 +87,7 @@ COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o +COBJS-$(CONFIG_CMD_EXT4) += cmd_ext4.o COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o COBJS-$(CONFIG_OF_LIBFDT) += cmd_fdt.o fdt_support.o diff --git a/common/cmd_ext2.c b/common/cmd_ext2.c index 35fb361..3ccc47e 100644 --- a/common/cmd_ext2.c +++ b/common/cmd_ext2.c @@ -40,6 +40,7 @@ #include <linux/ctype.h> #include <asm/byteorder.h> #include <ext2fs.h> +#include <ext_common.h> #if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) #include <usb.h> #endif diff --git a/common/cmd_ext4.c b/common/cmd_ext4.c new file mode 100644 index 0000000..7c2d541 --- /dev/null +++ b/common/cmd_ext4.c @@ -0,0 +1,253 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* + * Ext4fs support + * made from existing cmd_ext2.c file of Uboot + */ +#include <common.h> +#include <part.h> +#include <config.h> +#include <command.h> +#include <image.h> +#include <linux/ctype.h> +#include <asm/byteorder.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <linux/stat.h> +#include <malloc.h> + +#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) +#include <usb.h> +#endif + +#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) +#error DOS or EFI partition support must be selected +#endif + +uint64_t total_sector; +uint64_t part_offset; + +#define DOS_PART_MAGIC_OFFSET 0x1fe +#define DOS_FS_TYPE_OFFSET 0x36 +#define DOS_FS32_TYPE_OFFSET 0x52 + +int do_ext4_load(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + char *filename = NULL; + char *ep; + int dev; + unsigned long part = 1; + ulong addr = 0, part_length; + int filelen; + disk_partition_t info; + struct ext_filesystem *fs; + char buf[12]; + unsigned long count; + const char *addr_str; + + switch (argc) { + case 3: + addr_str = getenv("loadaddr"); + if (addr_str != NULL) + strict_strtoul(addr_str, 16, &addr); + else + addr = CONFIG_SYS_LOAD_ADDR; + + filename = getenv("bootfile"); + count = 0; + break; + case 4: + strict_strtoul(argv[3], 16, &addr); + filename = getenv("bootfile"); + count = 0; + break; + case 5: + strict_strtoul(argv[3], 16, &addr); + filename = argv[4]; + count = 0; + break; + case 6: + strict_strtoul(argv[3], 16, &addr); + filename = argv[4]; + strict_strtoul(argv[5], 16, &count); + break; + + default: + return cmd_usage(cmdtp); + } + + if (!filename) { + puts("** No boot file defined **\n"); + return 1; + } + + dev = (int)simple_strtoul(argv[2], &ep, 16); + ext4_dev_desc = get_dev(argv[1], dev); + if (ext4_dev_desc == NULL) { + printf("** Block device %s %d not supported\n", argv[1], dev); + return 1; + } + if (init_fs(ext4_dev_desc)) + return 1; + + fs = get_fs(); + if (*ep) { + if (*ep != ':') { + puts("** Invalid boot device, use `dev[:part]' **\n"); + return 1; + } + (int)strict_strtoul(++ep, 16, &part); + } + + if (part != 0) { + if (get_partition_info(fs->dev_desc, part, &info)) { + printf("** Bad partition %lu **\n", part); + return 1; + } + + if (strncmp((char *)info.type, BOOT_PART_TYPE, + sizeof(info.type)) != 0) { + printf("** Invalid partition type "%.32s"" + " (expect "" BOOT_PART_TYPE "")\n", info.type); + return 1; + } + printf("Loading file "%s" " + "from %s device %d:%lu (%.32s)\n", + filename, argv[1], dev, part, info.name); + } else { + printf("Loading file "%s" from %s device %d\n", + filename, argv[1], dev); + } + + part_length = ext2fs_set_blk_dev(fs->dev_desc, part); + if (part_length == 0) { + printf("**Bad partition - %s %d:%lu **\n", argv[1], dev, part); + ext4fs_close(); + return 1; + } + + if (!ext4fs_mount(part_length)) { + printf("** Bad ext2 partition or disk - %s %d:%lu **\n", + argv[1], dev, part); + ext4fs_close(); + return 1; + } + + filelen = ext4fs_open(filename); + if (filelen < 0) { + printf("** File not found %s\n", filename); + ext4fs_close(); + return 1; + } + if ((count < filelen) && (count != 0)) + filelen = count; + + if (ext4fs_read((char *)addr, filelen) != filelen) { + printf("** Unable to read "%s" from %s %d:%lu **\n", + filename, argv[1], dev, part); + ext4fs_close(); + return 1; + } + + ext4fs_close(); + deinit_fs(fs->dev_desc); + /* Loading ok, update default load address */ + load_addr = addr; + + printf("%d bytes read\n", filelen); + sprintf(buf, "%X", filelen); + setenv("filesize", buf); + + return 0; +} + +int do_ext4_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + char *filename = "/"; + int dev = 0; + unsigned long part = 1; + char *ep; + struct ext_filesystem *fs; + int part_length; + + if (argc < 3) + return cmd_usage(cmdtp); + + dev = (int)simple_strtoul(argv[2], &ep, 16); + ext4_dev_desc = get_dev(argv[1], dev); + + if (ext4_dev_desc == NULL) { + printf("\n** Block device %s %d not supported\n", argv[1], dev); + return 1; + } + + if (init_fs(ext4_dev_desc)) + return 1; + + fs = get_fs(); + if (*ep) { + if (*ep != ':') { + puts("\n** Invalid boot device, use `dev[:part]' **\n"); + return 1; + } + (int)strict_strtoul(++ep, 16, &part); + } + + if (argc == 4) + filename = argv[3]; + + part_length = ext2fs_set_blk_dev(fs->dev_desc, part); + if (part_length == 0) { + printf("** Bad partition - %s %d:%lu **\n", argv[1], dev, part); + ext4fs_close(); + return 1; + } + + if (!ext4fs_mount(part_length)) { + printf("** Bad ext2 partition or disk - %s %d:%lu **\n", + argv[1], dev, part); + ext4fs_close(); + return 1; + } + if (ext4fs_ls(filename)) { + printf("** Error ext2fs_ls() **\n"); + ext4fs_close(); + return 1; + }; + + ext4fs_close(); + deinit_fs(fs->dev_desc); + return 0; +} + +U_BOOT_CMD(ext4ls, 4, 1, do_ext4_ls, + "list files in a directory (default /)", + "<interface> <dev[:part]> [directory]\n" + " - list files from 'dev' on 'interface' in a 'directory'"); + +U_BOOT_CMD(ext4load, 6, 0, do_ext4_load, + "load binary file from a Ext2 filesystem", + "<interface> <dev[:part]> [addr] [filename] [bytes]\n" + " - load binary file 'filename' from 'dev' on 'interface'\n" + " to address 'addr' from ext2 filesystem"); diff --git a/fs/Makefile b/fs/Makefile index 22aad12..27330d4 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -24,6 +24,7 @@
subdirs-$(CONFIG_CMD_CRAMFS) := cramfs subdirs-$(CONFIG_CMD_EXT2) += ext2 +subdirs-$(CONFIG_CMD_EXT4) += ext4 subdirs-$(CONFIG_CMD_FAT) += fat subdirs-$(CONFIG_CMD_FDOS) += fdos subdirs-$(CONFIG_CMD_JFFS2) += jffs2 diff --git a/fs/ext2/dev.c b/fs/ext2/dev.c index 874e211..315ff53 100644 --- a/fs/ext2/dev.c +++ b/fs/ext2/dev.c @@ -27,6 +27,7 @@ #include <common.h> #include <config.h> #include <ext2fs.h> +#include <ext_common.h>
static block_dev_desc_t *ext2fs_block_dev_desc; static disk_partition_t part_info; diff --git a/fs/ext2/ext2fs.c b/fs/ext2/ext2fs.c index e119e13..df336b9 100644 --- a/fs/ext2/ext2fs.c +++ b/fs/ext2/ext2fs.c @@ -25,152 +25,12 @@
#include <common.h> #include <ext2fs.h> +#include <ext_common.h> #include <malloc.h> #include <asm/byteorder.h>
-extern int ext2fs_devread (int sector, int byte_offset, int byte_len, - char *buf); - -/* Magic value used to identify an ext2 filesystem. */ -#define EXT2_MAGIC 0xEF53 -/* Amount of indirect blocks in an inode. */ -#define INDIRECT_BLOCKS 12 -/* Maximum lenght of a pathname. */ -#define EXT2_PATH_MAX 4096 -/* Maximum nesting of symlinks, used to prevent a loop. */ -#define EXT2_MAX_SYMLINKCNT 8 - -/* Filetype used in directory entry. */ -#define FILETYPE_UNKNOWN 0 -#define FILETYPE_REG 1 -#define FILETYPE_DIRECTORY 2 -#define FILETYPE_SYMLINK 7 - -/* Filetype information as used in inodes. */ -#define FILETYPE_INO_MASK 0170000 -#define FILETYPE_INO_REG 0100000 -#define FILETYPE_INO_DIRECTORY 0040000 -#define FILETYPE_INO_SYMLINK 0120000 - -/* Bits used as offset in sector */ -#define DISK_SECTOR_BITS 9 - -/* Log2 size of ext2 block in 512 blocks. */ -#define LOG2_EXT2_BLOCK_SIZE(data) (__le32_to_cpu (data->sblock.log2_block_size) + 1) - -/* Log2 size of ext2 block in bytes. */ -#define LOG2_BLOCK_SIZE(data) (__le32_to_cpu (data->sblock.log2_block_size) + 10) - -/* The size of an ext2 block in bytes. */ -#define EXT2_BLOCK_SIZE(data) (1 << LOG2_BLOCK_SIZE(data)) - -/* The ext2 superblock. */ -struct ext2_sblock { - uint32_t total_inodes; - uint32_t total_blocks; - uint32_t reserved_blocks; - uint32_t free_blocks; - uint32_t free_inodes; - uint32_t first_data_block; - uint32_t log2_block_size; - uint32_t log2_fragment_size; - uint32_t blocks_per_group; - uint32_t fragments_per_group; - uint32_t inodes_per_group; - uint32_t mtime; - uint32_t utime; - uint16_t mnt_count; - uint16_t max_mnt_count; - uint16_t magic; - uint16_t fs_state; - uint16_t error_handling; - uint16_t minor_revision_level; - uint32_t lastcheck; - uint32_t checkinterval; - uint32_t creator_os; - uint32_t revision_level; - uint16_t uid_reserved; - uint16_t gid_reserved; - uint32_t first_inode; - uint16_t inode_size; - uint16_t block_group_number; - uint32_t feature_compatibility; - uint32_t feature_incompat; - uint32_t feature_ro_compat; - uint32_t unique_id[4]; - char volume_name[16]; - char last_mounted_on[64]; - uint32_t compression_info; -}; - -/* The ext2 blockgroup. */ -struct ext2_block_group { - uint32_t block_id; - uint32_t inode_id; - uint32_t inode_table_id; - uint16_t free_blocks; - uint16_t free_inodes; - uint16_t used_dir_cnt; - uint32_t reserved[3]; -}; - -/* The ext2 inode. */ -struct ext2_inode { - uint16_t mode; - uint16_t uid; - uint32_t size; - uint32_t atime; - uint32_t ctime; - uint32_t mtime; - uint32_t dtime; - uint16_t gid; - uint16_t nlinks; - uint32_t blockcnt; /* Blocks of 512 bytes!! */ - uint32_t flags; - uint32_t osd1; - union { - struct datablocks { - uint32_t dir_blocks[INDIRECT_BLOCKS]; - uint32_t indir_block; - uint32_t double_indir_block; - uint32_t tripple_indir_block; - } blocks; - char symlink[60]; - } b; - uint32_t version; - uint32_t acl; - uint32_t dir_acl; - uint32_t fragment_addr; - uint32_t osd2[3]; -}; - -/* The header of an ext2 directory entry. */ -struct ext2_dirent { - uint32_t inode; - uint16_t direntlen; - uint8_t namelen; - uint8_t filetype; -}; - -struct ext2fs_node { - struct ext2_data *data; - struct ext2_inode inode; - int ino; - int inode_read; -}; - -/* Information about a "mounted" ext2 filesystem. */ -struct ext2_data { - struct ext2_sblock sblock; - struct ext2_inode *inode; - struct ext2fs_node diropen; -}; - - -typedef struct ext2fs_node *ext2fs_node_t; - -struct ext2_data *ext2fs_root = NULL; -ext2fs_node_t ext2fs_file = NULL; +struct ext2_data *ext2fs_root; +struct ext2fs_node *ext2fs_file; int symlinknest = 0; uint32_t *indir1_block = NULL; int indir1_size = 0; @@ -178,8 +38,7 @@ int indir1_blkno = -1; uint32_t *indir2_block = NULL; int indir2_size = 0; int indir2_blkno = -1; -static unsigned int inode_size; - +unsigned int inode_size;
static int ext2fs_blockgroup (struct ext2_data *data, int group, struct ext2_block_group *blkgrp) { @@ -198,10 +57,8 @@ static int ext2fs_blockgroup #endif return (ext2fs_devread (blkno << LOG2_EXT2_BLOCK_SIZE(data), blkoff, sizeof(struct ext2_block_group), (char *)blkgrp)); - }
- static int ext2fs_read_inode (struct ext2_data *data, int ino, struct ext2_inode *inode) { struct ext2_block_group blkgrp; @@ -242,155 +99,16 @@ static int ext2fs_read_inode return (1); }
- -void ext2fs_free_node (ext2fs_node_t node, ext2fs_node_t currroot) { +void ext2fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot) +{ if ((node != &ext2fs_root->diropen) && (node != currroot)) { free (node); } }
- -static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { - struct ext2_data *data = node->data; - struct ext2_inode *inode = &node->inode; - int blknr; - int blksz = EXT2_BLOCK_SIZE (data); - int log2_blksz = LOG2_EXT2_BLOCK_SIZE (data); - int status; - - /* Direct blocks. */ - if (fileblock < INDIRECT_BLOCKS) { - blknr = __le32_to_cpu (inode->b.blocks.dir_blocks[fileblock]); - } - /* Indirect. */ - else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4))) { - if (indir1_block == NULL) { - indir1_block = (uint32_t *) malloc (blksz); - if (indir1_block == NULL) { - printf ("** ext2fs read block (indir 1) malloc failed. **\n"); - return (-1); - } - indir1_size = blksz; - indir1_blkno = -1; - } - if (blksz != indir1_size) { - free (indir1_block); - indir1_block = NULL; - indir1_size = 0; - indir1_blkno = -1; - indir1_block = (uint32_t *) malloc (blksz); - if (indir1_block == NULL) { - printf ("** ext2fs read block (indir 1) malloc failed. **\n"); - return (-1); - } - indir1_size = blksz; - } - if ((__le32_to_cpu (inode->b.blocks.indir_block) << - log2_blksz) != indir1_blkno) { - status = ext2fs_devread (__le32_to_cpu(inode->b.blocks.indir_block) << log2_blksz, - 0, blksz, - (char *) indir1_block); - if (status == 0) { - printf ("** ext2fs read block (indir 1) failed. **\n"); - return (0); - } - indir1_blkno = - __le32_to_cpu (inode->b.blocks. - indir_block) << log2_blksz; - } - blknr = __le32_to_cpu (indir1_block - [fileblock - INDIRECT_BLOCKS]); - } - /* Double indirect. */ - else if (fileblock < - (INDIRECT_BLOCKS + (blksz / 4 * (blksz / 4 + 1)))) { - unsigned int perblock = blksz / 4; - unsigned int rblock = fileblock - (INDIRECT_BLOCKS - + blksz / 4); - - if (indir1_block == NULL) { - indir1_block = (uint32_t *) malloc (blksz); - if (indir1_block == NULL) { - printf ("** ext2fs read block (indir 2 1) malloc failed. **\n"); - return (-1); - } - indir1_size = blksz; - indir1_blkno = -1; - } - if (blksz != indir1_size) { - free (indir1_block); - indir1_block = NULL; - indir1_size = 0; - indir1_blkno = -1; - indir1_block = (uint32_t *) malloc (blksz); - if (indir1_block == NULL) { - printf ("** ext2fs read block (indir 2 1) malloc failed. **\n"); - return (-1); - } - indir1_size = blksz; - } - if ((__le32_to_cpu (inode->b.blocks.double_indir_block) << - log2_blksz) != indir1_blkno) { - status = ext2fs_devread (__le32_to_cpu(inode->b.blocks.double_indir_block) << log2_blksz, - 0, blksz, - (char *) indir1_block); - if (status == 0) { - printf ("** ext2fs read block (indir 2 1) failed. **\n"); - return (-1); - } - indir1_blkno = - __le32_to_cpu (inode->b.blocks.double_indir_block) << log2_blksz; - } - - if (indir2_block == NULL) { - indir2_block = (uint32_t *) malloc (blksz); - if (indir2_block == NULL) { - printf ("** ext2fs read block (indir 2 2) malloc failed. **\n"); - return (-1); - } - indir2_size = blksz; - indir2_blkno = -1; - } - if (blksz != indir2_size) { - free (indir2_block); - indir2_block = NULL; - indir2_size = 0; - indir2_blkno = -1; - indir2_block = (uint32_t *) malloc (blksz); - if (indir2_block == NULL) { - printf ("** ext2fs read block (indir 2 2) malloc failed. **\n"); - return (-1); - } - indir2_size = blksz; - } - if ((__le32_to_cpu (indir1_block[rblock / perblock]) << - log2_blksz) != indir2_blkno) { - status = ext2fs_devread (__le32_to_cpu(indir1_block[rblock / perblock]) << log2_blksz, - 0, blksz, - (char *) indir2_block); - if (status == 0) { - printf ("** ext2fs read block (indir 2 2) failed. **\n"); - return (-1); - } - indir2_blkno = - __le32_to_cpu (indir1_block[rblock / perblock]) << log2_blksz; - } - blknr = __le32_to_cpu (indir2_block[rblock % perblock]); - } - /* Tripple indirect. */ - else { - printf ("** ext2fs doesn't support tripple indirect blocks. **\n"); - return (-1); - } -#ifdef DEBUG - printf ("ext2fs_read_block %08x\n", blknr); -#endif - return (blknr); -} - - int ext2fs_read_file - (ext2fs_node_t node, int pos, unsigned int len, char *buf) { + (struct ext2fs_node *node, int pos, unsigned int len, char *buf) +{ int i; int blockcnt; int log2blocksize = LOG2_EXT2_BLOCK_SIZE (node->data); @@ -409,8 +127,7 @@ int ext2fs_read_file int blockend = blocksize;
int skipfirst = 0; - - blknr = ext2fs_read_block (node, i); + blknr = read_allocated_block(&(node->inode), i); if (blknr < 0) { return (-1); } @@ -449,8 +166,8 @@ int ext2fs_read_file return (len); }
- -static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fnode, int *ftype) +int ext2fs_iterate_dir(struct ext2fs_node *dir, char *name, + struct ext2fs_node **fnode, int *ftype) { unsigned int fpos = 0; int status; @@ -479,7 +196,7 @@ static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fn } if (dirent.namelen != 0) { char filename[dirent.namelen + 1]; - ext2fs_node_t fdiro; + struct ext2fs_node *fdiro; int type = FILETYPE_UNKNOWN;
status = ext2fs_read_file (diro, @@ -581,8 +298,8 @@ static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fn return (0); }
- -static char *ext2fs_read_symlink (ext2fs_node_t node) { +static char *ext2fs_read_symlink(struct ext2fs_node *node) +{ char *symlink; struct ext2fs_node *diro = node; int status; @@ -617,17 +334,17 @@ static char *ext2fs_read_symlink (ext2fs_node_t node) { return (symlink); }
- int ext2fs_find_file1 - (const char *currpath, - ext2fs_node_t currroot, ext2fs_node_t * currfound, int *foundtype) { + (const char *currpath, struct ext2fs_node *currroot, + struct ext2fs_node **currfound, int *foundtype) +{ char fpath[strlen (currpath) + 1]; char *name = fpath; char *next; int status; int type = FILETYPE_DIRECTORY; - ext2fs_node_t currnode = currroot; - ext2fs_node_t oldnode = currroot; + struct ext2fs_node *currnode = currroot; + struct ext2fs_node *oldnode = currroot;
strncpy (fpath, currpath, strlen (currpath) + 1);
@@ -721,14 +438,13 @@ int ext2fs_find_file1 return (-1); }
- int ext2fs_find_file - (const char *path, - ext2fs_node_t rootnode, ext2fs_node_t * foundnode, int expecttype) { + (const char *path, struct ext2fs_node *rootnode, + struct ext2fs_node **foundnode, int expecttype) +{ int status; int foundtype = FILETYPE_DIRECTORY;
- symlinknest = 0; if (!path) { return (0); @@ -748,9 +464,8 @@ int ext2fs_find_file return (1); }
- int ext2fs_ls (const char *dirname) { - ext2fs_node_t dirnode; + struct ext2fs_node *dirnode; int status;
if (ext2fs_root == NULL) { @@ -768,9 +483,8 @@ int ext2fs_ls (const char *dirname) { return (0); }
- int ext2fs_open (const char *filename) { - ext2fs_node_t fdiro = NULL; + struct ext2fs_node *fdiro = NULL; int status; int len;
@@ -799,7 +513,6 @@ fail: return (-1); }
- int ext2fs_close (void ) { if ((ext2fs_file != NULL) && (ext2fs_root != NULL)) { @@ -825,7 +538,6 @@ int ext2fs_close (void return (0); }
- int ext2fs_read (char *buf, unsigned len) { int status;
@@ -836,12 +548,10 @@ int ext2fs_read (char *buf, unsigned len) { if (ext2fs_file == NULL) { return (0); } - status = ext2fs_read_file (ext2fs_file, 0, len, buf); return (status); }
- int ext2fs_mount (unsigned part_length) { struct ext2_data *data; int status; @@ -880,7 +590,7 @@ int ext2fs_mount (unsigned part_length) { }
ext2fs_root = data; - + ext4fs_root = data; return (1);
fail: diff --git a/fs/ext4/Makefile b/fs/ext4/Makefile new file mode 100644 index 0000000..850f821 --- /dev/null +++ b/fs/ext4/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2003 +# Pavel Bartusek, Sysgo Real-Time Solutions AG, pba@sysgo.de +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libext4fs.o + +AOBJS = +COBJS-$(CONFIG_CMD_EXT4) := ext4fs.o ext4_common.o + +SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) + + +all: $(LIB) $(AOBJS) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c new file mode 100644 index 0000000..6f9351c --- /dev/null +++ b/fs/ext4/ext4_common.c @@ -0,0 +1,573 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * ext4load - based on code from GRUB2 fs/ext2.c +*/ +#include <common.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <malloc.h> +#include <asm/byteorder.h> +#include <linux/stat.h> +#include <linux/time.h> +#include "ext4_common.h" + +struct ext2_data *ext4fs_root; +struct ext2fs_node *ext4fs_file; +uint32_t *ext4fs_indir1_block; +int ext4fs_indir1_size; +int ext4fs_indir1_blkno = -1; +uint32_t *ext4fs_indir2_block; +int ext4fs_indir2_size; +int ext4fs_indir2_blkno = -1; + +uint32_t *ext4fs_indir3_block; +int ext4fs_indir3_size; +int ext4fs_indir3_blkno = -1; +struct ext2_inode *g_parent_inode; + +#ifndef offsetof +#define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER) +#endif + +void *xmalloc(size_t size) +{ + void *ptr = malloc(size); + if (ptr == NULL && size != 0) + printf("bb_msg_memory_exhausted\n"); + return ptr; +} + +void *xzalloc(size_t size) +{ + void *ptr = xmalloc(size); + memset(ptr, 0, size); + return ptr; +} + +static struct ext4_extent_header *ext4fs_find_leaf(struct ext2_data *data, + char *buf, struct ext4_extent_header *ext_block, uint32_t fileblock) +{ + struct ext4_extent_idx *index; + unsigned long long block; + int i; + + while (1) { + index = (struct ext4_extent_idx *)(ext_block + 1); + + if (le32_to_cpu(ext_block->magic) != EXT4_EXT_MAGIC) + return 0; + + if (ext_block->depth == 0) + return ext_block; + + for (i = 0; i < le32_to_cpu(ext_block->entries); i++) { + if (fileblock < le32_to_cpu(index[i].block)) + break; + } + + if (--i < 0) + return 0; + + block = le32_to_cpu(index[i].leaf_hi); + block = (block << 32) + le32_to_cpu(index[i].leaf); + + if (ext2fs_devread(block << LOG2_EXT2_BLOCK_SIZE(data), + 0, EXT2_BLOCK_SIZE(data), buf)) { + ext_block = (struct ext4_extent_header *)buf; + return ext_block; + } else + return 0; + } +} + +static int ext4fs_blockgroup + (struct ext2_data *data, int group, struct ext2_block_group *blkgrp) +{ + long int blkno; + unsigned int blkoff, desc_per_blk; + + desc_per_blk = EXT2_BLOCK_SIZE(data) / sizeof(struct ext2_block_group); + + blkno = __le32_to_cpu(data->sblock.first_data_block) + 1 + + group / desc_per_blk; + blkoff = (group % desc_per_blk) * sizeof(struct ext2_block_group); + + debug("ext4fs read %d group descriptor (blkno %ld blkoff %u)\n", + group, blkno, blkoff); + + return ext2fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data), + blkoff, sizeof(struct ext2_block_group), (char *)blkgrp); +} + +int ext4fs_read_inode(struct ext2_data *data, int ino, struct ext2_inode *inode) +{ + struct ext2_block_group blkgrp; + struct ext2_sblock *sblock = &data->sblock; + struct ext_filesystem *fs = get_fs(); + int inodes_per_block, status; + long int blkno; + unsigned int blkoff; + + /* It is easier to calculate if the first inode is 0. */ + ino--; + status = ext4fs_blockgroup(data, ino / __le32_to_cpu + (sblock->inodes_per_group), &blkgrp); + + if (status == 0) + return 0; + + inodes_per_block = EXT2_BLOCK_SIZE(data) / fs->inodesz; + + blkno = __le32_to_cpu(blkgrp.inode_table_id) + + (ino % __le32_to_cpu(sblock->inodes_per_group)) + / inodes_per_block; + blkoff = (ino % inodes_per_block) * fs->inodesz; + /* Read the inode. */ + status = ext2fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data), blkoff, + sizeof(struct ext2_inode), (char *)inode); + if (status == 0) + return 0; + + return 1; +} + +long int read_allocated_block(struct ext2_inode *inode, int fileblock) +{ + long int blknr; + int blksz; + int log2_blksz; + int status; + long int rblock; + long int perblock_parent; + long int perblock_child; + unsigned long long start; + /*get the blocksize of the filesystem */ + blksz = EXT2_BLOCK_SIZE(ext4fs_root); + log2_blksz = LOG2_EXT2_BLOCK_SIZE(ext4fs_root); + + if (le32_to_cpu(inode->flags) & EXT4_EXTENTS_FLAG) { + char buf[EXT2_BLOCK_SIZE(ext4fs_root)]; + struct ext4_extent_header *leaf; + struct ext4_extent *ext; + int i; + + leaf = ext4fs_find_leaf(ext4fs_root, buf, + (struct ext4_extent_header *)inode-> + b.blocks.dir_blocks, fileblock); + if (!leaf) { + printf("invalid extent\n"); + return -1; + } + + ext = (struct ext4_extent *)(leaf + 1); + + for (i = 0; i < le32_to_cpu(leaf->entries); i++) { + if (fileblock < le32_to_cpu(ext[i].block)) + break; + } + + if (--i >= 0) { + fileblock -= le32_to_cpu(ext[i].block); + if (fileblock >= le32_to_cpu(ext[i].len)) { + return 0; + } else { + start = le32_to_cpu(ext[i].start_hi); + start = (start << 32) + + le32_to_cpu(ext[i].start); + return fileblock + start; + } + } else { + printf("something wrong with extent\n"); + return -1; + } + } + + /* Direct blocks. */ + if (fileblock < INDIRECT_BLOCKS) + blknr = __le32_to_cpu(inode->b.blocks.dir_blocks[fileblock]); + + /* Indirect. */ + else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4))) { + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** SI ext2fs read block (indir 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** SI ext2fs read block (indir 1):" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = ext2fs_devread(__le32_to_cpu(inode->b.blocks. + indir_block) << log2_blksz, 0, blksz, + (char *) ext4fs_indir1_block); + if (status == 0) { + printf("** SI ext2fs read block (indir 1)" + "failed. **\n"); + return 0; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks. + indir_block) << log2_blksz; + } + blknr = __le32_to_cpu(ext4fs_indir1_block + [fileblock - INDIRECT_BLOCKS]); + } + /* Double indirect. */ + else if (fileblock < + (INDIRECT_BLOCKS + (blksz / 4 * (blksz / 4 + 1)))) { + + long int perblock = blksz / 4; + long int rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4); + + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** DI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** DI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.double_indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = ext2fs_devread(__le32_to_cpu(inode->b.blocks. + double_indir_block) << log2_blksz, 0, blksz, + (char *) ext4fs_indir1_block); + if (status == 0) { + printf("** DI ext2fs read block (indir 2 1)" + "failed. **\n"); + return -1; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks. + double_indir_block) << log2_blksz; + } + + if (ext4fs_indir2_block == NULL) { + ext4fs_indir2_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** DI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + ext4fs_indir2_blkno = -1; + } + if (blksz != ext4fs_indir2_size) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + ext4fs_indir2_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** DI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir1_block[rblock / perblock]) << + log2_blksz) != ext4fs_indir2_blkno) { + status = ext2fs_devread(__le32_to_cpu + (ext4fs_indir1_block + [rblock / perblock]) << log2_blksz, + 0, blksz, (char *) ext4fs_indir2_block); + if (status == 0) { + printf("** DI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir2_blkno = + __le32_to_cpu(ext4fs_indir1_block[rblock + / perblock]) << log2_blksz; + } + blknr = __le32_to_cpu(ext4fs_indir2_block[rblock % perblock]); + } + /* Tripple indirect. */ + else { + rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4 + + (blksz / 4 * blksz / 4)); + perblock_child = blksz / 4; + perblock_parent = ((blksz / 4) * (blksz / 4)); + + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** TI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** TI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.tripple_indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = ext2fs_devread + (__le32_to_cpu(inode->b.blocks. + tripple_indir_block) << log2_blksz, + 0, blksz, (char *) ext4fs_indir1_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 1)" + "failed. **\n"); + return -1; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks. + tripple_indir_block) << log2_blksz; + } + + if (ext4fs_indir2_block == NULL) { + ext4fs_indir2_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + ext4fs_indir2_blkno = -1; + } + if (blksz != ext4fs_indir2_size) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + ext4fs_indir2_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir1_block[rblock / + perblock_parent]) << log2_blksz) + != ext4fs_indir2_blkno) { + status = ext2fs_devread(__le32_to_cpu + (ext4fs_indir1_block + [rblock / perblock_parent]) << log2_blksz, + 0, blksz, (char *) ext4fs_indir2_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir2_blkno = + __le32_to_cpu(ext4fs_indir1_block[rblock / + perblock_parent]) << log2_blksz; + } + + if (ext4fs_indir3_block == NULL) { + ext4fs_indir3_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir3_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir3_size = blksz; + ext4fs_indir3_blkno = -1; + } + if (blksz != ext4fs_indir3_size) { + free(ext4fs_indir3_block); + ext4fs_indir3_block = NULL; + ext4fs_indir3_size = 0; + ext4fs_indir3_blkno = -1; + ext4fs_indir3_block = (uint32_t *) malloc(blksz); + if (ext4fs_indir3_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir3_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir2_block[rblock + / perblock_child]) << log2_blksz) != ext4fs_indir3_blkno){ + status = ext2fs_devread(__le32_to_cpu + (ext4fs_indir2_block[(rblock / perblock_child) + % (blksz / 4)]) << log2_blksz, + 0, blksz, (char *) ext4fs_indir3_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir3_blkno = + __le32_to_cpu(ext4fs_indir2_block[(rblock / + perblock_child) % (blksz / 4)]) << log2_blksz; + } + + blknr = __le32_to_cpu(ext4fs_indir3_block + [rblock % perblock_child]); + } + debug("ext4fs_read_block %ld\n", blknr); + return blknr; +} + +int ext4fs_close(void) +{ + if ((ext4fs_file != NULL) && (ext4fs_root != NULL)) { + ext4fs_free_node(ext4fs_file, &ext4fs_root->diropen); + ext4fs_file = NULL; + } + if (ext4fs_root != NULL) { + free(ext4fs_root); + ext4fs_root = NULL; + } + if (ext4fs_indir1_block != NULL) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + } + if (ext4fs_indir2_block != NULL) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + } + return 0; +} + +int ext4fs_open(const char *filename) +{ + struct ext2fs_node *fdiro = NULL; + int status; + int len; + + if (ext4fs_root == NULL) + return -1; + + ext4fs_file = NULL; + status = ext2fs_find_file(filename, &ext4fs_root->diropen, &fdiro, + FILETYPE_REG); + if (status == 0) + goto fail; + + if (!fdiro->inode_read) { + status = ext4fs_read_inode(fdiro->data, fdiro->ino, + &fdiro->inode); + if (status == 0) + goto fail; + } + len = __le32_to_cpu(fdiro->inode.size); + ext4fs_file = fdiro; + return len; + +fail: + ext4fs_free_node(fdiro, &ext4fs_root->diropen); + return -1; +} + +int ext4fs_mount(unsigned part_length) +{ + struct ext2_data *data; + int status; + struct ext_filesystem *fs = get_fs(); + data = malloc(sizeof(struct ext2_data)); + if (!data) + return 0; + + /* Read the superblock. */ + status = ext2fs_devread(1 * 2, 0, sizeof(struct ext2_sblock), + (char *)&data->sblock); + + if (status == 0) + goto fail; + + /* Make sure this is an ext2 filesystem. */ + if (__le16_to_cpu(data->sblock.magic) != EXT2_MAGIC) + goto fail; + + if (__le32_to_cpu(data->sblock.revision_level == 0)) + fs->inodesz = 128; + else + fs->inodesz = __le16_to_cpu(data->sblock.inode_size); + +#ifdef DEBUG + printf("EXT2 rev %d, inode_size %d\n", + __le32_to_cpu(data->sblock.revision_level), fs->inodesz); +#endif + data->diropen.data = data; + data->diropen.ino = 2; + data->diropen.inode_read = 1; + data->inode = &data->diropen.inode; + + status = ext4fs_read_inode(data, 2, data->inode); + if (status == 0) + goto fail; + + inode_size = fs->inodesz; + ext4fs_root = data; + ext2fs_root = data; + return 1; + +fail: + printf("Failed to mount ext2 filesystem...\n"); + free(data); + + ext4fs_root = NULL; + return 0; +} diff --git a/fs/ext4/ext4_common.h b/fs/ext4/ext4_common.h new file mode 100644 index 0000000..73f218d --- /dev/null +++ b/fs/ext4/ext4_common.h @@ -0,0 +1,44 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __EXT4_COMMON__ +#define __EXT4_COMMON__ +#include <ext_common.h> +#include <ext4fs.h> + +#define YES 1 +#define NO 0 +#define TRUE 1 +#define FALSE 0 +#define RECOVER 1 +#define SCAN 0 + +#define S_IFLNK 0120000 /* symbolic link */ +#define BLOCK_NO_ONE 1 +#define SUPERBLOCK_SECTOR 2 +#define SUPERBLOCK_SIZE 1024 +#define F_FILE 1 + +extern unsigned long part_offset; +int ext4fs_read_inode(struct ext2_data *data, int ino, + struct ext2_inode *inode); +#endif diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c new file mode 100644 index 0000000..d4faa16 --- /dev/null +++ b/fs/ext4/ext4fs.c @@ -0,0 +1,215 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* + * ext4load - based on code from GRUB2 fs/ext2.c +*/ +#include <common.h> +#include <malloc.h> +#include <asm/byteorder.h> +#include <linux/stat.h> +#include <linux/time.h> +#include <ext_common.h> +#include <ext4fs.h> +#include "ext4_common.h" + +int ext4fs_symlinknest; +block_dev_desc_t *ext4_dev_desc; + +struct ext_filesystem *get_fs(void) +{ + if (ext4_dev_desc == NULL || ext4_dev_desc->priv == NULL) + printf("Invalid Input Arguments %s\n", __func__); + return (struct ext_filesystem *)ext4_dev_desc->priv; +} + +int init_fs(block_dev_desc_t *dev_desc) +{ + struct ext_filesystem *fs; + if (dev_desc == NULL) { + printf("Invalid Input Arguments %s\n", __func__); + return -1; + } + + fs = (struct ext_filesystem *)xzalloc(sizeof(struct ext_filesystem)); + if (fs == NULL) { + printf("malloc failed: %s\n", __func__); + return -1; + } + + fs->dev_desc = dev_desc; + dev_desc->priv = fs; + return 0; +} + +void deinit_fs(block_dev_desc_t *dev_desc) +{ + if (dev_desc == NULL) { + printf("Invalid Input Arguments %s\n", __func__); + return; + } + if (dev_desc->priv) + free(dev_desc->priv); + return; +} + +void ext4fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot) +{ + if ((node != &ext4fs_root->diropen) && (node != currroot)) + free(node); +} + +/* Taken from openmoko-kernel mailing list: By Andy green +* Optimized read file API : collects and defers contiguous sector +* reads into one potentially more efficient larger sequential read action +*/ +int ext4fs_read_file(struct ext2fs_node *node, int pos, + unsigned int len, char *buf) +{ + int i; + int blockcnt; + int log2blocksize = LOG2_EXT2_BLOCK_SIZE(node->data); + int blocksize = 1 << (log2blocksize + DISK_SECTOR_BITS); + unsigned int filesize = __le32_to_cpu(node->inode.size); + int previous_block_number = -1; + int delayed_start = 0; + int delayed_extent = 0; + int delayed_skipfirst = 0; + int delayed_next = 0; + char *delayed_buf = NULL; + short status; + + /* Adjust len so it we can't read past the end of the file. */ + if (len > filesize) + len = filesize; + + blockcnt = ((len + pos) + blocksize - 1) / blocksize; + + for (i = pos / blocksize; i < blockcnt; i++) { + int blknr; + int blockoff = pos % blocksize; + int blockend = blocksize; + int skipfirst = 0; + blknr = read_allocated_block(&(node->inode), i); + if (blknr < 0) + return -1; + + blknr = blknr << log2blocksize; + + /* Last block. */ + if (i == blockcnt - 1) { + blockend = (len + pos) % blocksize; + + /* The last portion is exactly blocksize. */ + if (!blockend) + blockend = blocksize; + } + + /* First block. */ + if (i == pos / blocksize) { + skipfirst = blockoff; + blockend -= skipfirst; + } + if (blknr) { + int status; + + if (previous_block_number != -1) { + if (delayed_next == blknr) { + delayed_extent += blockend; + delayed_next += blockend >> SECTOR_BITS; + } else { /* spill */ + status = ext2fs_devread(delayed_start, + delayed_skipfirst, + delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = blknr; + delayed_start = blknr; + delayed_extent = blockend; + delayed_skipfirst = skipfirst; + delayed_buf = buf; + delayed_next = blknr + + (blockend >> SECTOR_BITS); + } + } else { + previous_block_number = blknr; + delayed_start = blknr; + delayed_extent = blockend; + delayed_skipfirst = skipfirst; + delayed_buf = buf; + delayed_next = blknr + + (blockend >> SECTOR_BITS); + } + } else { + if (previous_block_number != -1) { + /* spill */ + status = ext2fs_devread(delayed_start, + delayed_skipfirst, + delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = -1; + } + memset(buf, 0, blocksize - skipfirst); + } + buf += blocksize - skipfirst; + } + if (previous_block_number != -1) { + /* spill */ + status = ext2fs_devread(delayed_start, + delayed_skipfirst, delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = -1; + } + return len; +} + +int ext4fs_ls(const char *dirname) +{ + struct ext2fs_node *dirnode; + int status; + + if (dirname == NULL) + return 0; + + status = ext2fs_find_file(dirname, &ext4fs_root->diropen, &dirnode, + FILETYPE_DIRECTORY); + if (status != 1) { + printf("** Can not find directory. **\n"); + return 1; + } + + ext2fs_iterate_dir(dirnode, NULL, NULL, NULL); + ext4fs_free_node(dirnode, &ext4fs_root->diropen); + return 0; +} + +int ext4fs_read(char *buf, unsigned len) +{ + if (ext4fs_root == NULL || ext4fs_file == NULL) + return 0; + return ext4fs_read_file(ext4fs_file, 0, len, buf); +} diff --git a/include/ext2fs.h b/include/ext2fs.h index 163a9bb..7d4834c 100644 --- a/include/ext2fs.h +++ b/include/ext2fs.h @@ -25,6 +25,8 @@ * from the original ext2 fs code, as found in the linux kernel. */
+#ifndef __EXT2__ +#define __EXT2__
#define SECTOR_SIZE 0x200 #define SECTOR_BITS 9 @@ -68,14 +70,12 @@ typedef enum ERR_DEV_NEED_INIT, ERR_NO_DISK_SPACE, ERR_NUMBER_OVERFLOW, - MAX_ERR_NUM } ext2fs_error_t;
- -extern int ext2fs_set_blk_dev(block_dev_desc_t *rbdd, int part); -extern int ext2fs_ls (const char *dirname); -extern int ext2fs_open (const char *filename); -extern int ext2fs_read (char *buf, unsigned len); -extern int ext2fs_mount (unsigned part_length); -extern int ext2fs_close(void); +int ext2fs_ls(const char *dirname); +int ext2fs_open(const char *filename); +int ext2fs_read(char *buf, unsigned len); +int ext2fs_close(void); +int ext2_register_device(block_dev_desc_t *dev_desc, int part_no); +#endif diff --git a/include/ext4fs.h b/include/ext4fs.h new file mode 100644 index 0000000..fd7bd47 --- /dev/null +++ b/include/ext4fs.h @@ -0,0 +1,116 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * + * Some parts of this code (mainly the structures and defines) are + * from the original ext4 fs code, as found in the linux kernel. + * Reference for ext4load and ls features have ben taken from GRUB + */ + +#ifndef __EXT4__ +#define __EXT4__ +#include <ext_common.h> + +#define EXT4_EXTENTS_FLAG 0x80000 +#define EXT4_EXT_MAGIC 0xf30a +#define EXT4_FEATURE_RO_COMPAT_GDT_CSUM 0x0010 +#define EXT4_FEATURE_INCOMPAT_EXTENTS 0x0040 +#define EXT4_INDIRECT_BLOCKS 12 + +#define EXT4_BG_INODE_UNINIT 0x0001 +#define EXT4_BG_BLOCK_UNINIT 0x0002 +#define EXT4_BG_INODE_ZEROED 0x0004 + +struct ext4_extent_header { + uint16_t magic; + uint16_t entries; + uint16_t max; + uint16_t depth; + uint32_t generation; +}; + +struct ext4_extent { + uint32_t block; + uint16_t len; + uint16_t start_hi; + uint32_t start; +}; + +struct ext4_extent_idx { + uint32_t block; + uint32_t leaf; + uint16_t leaf_hi; + uint16_t unused; +}; + +struct ext_filesystem { + /*Total Sector of partition */ + uint64_t total_sect; + /*Block size of partition */ + uint32_t blksz; + /*Inode size of partition */ + uint32_t inodesz; + /*Sectors per Block */ + uint32_t sect_perblk; + /*Group Descriptor Block Number */ + uint32_t gdtable_blkno; + /*Total block groups of partition */ + uint32_t no_blkgrp; + /*No of blocks required for bgdtable */ + uint32_t no_blk_pergdt; + /*superblock */ + struct ext2_sblock *sb; + /*block group descritpor table */ + struct ext2_block_group *gd; + char *gdtable; + + /*Block Bitmap Related */ + unsigned char **blk_bmaps; + long int curr_blkno; + uint16_t first_pass_bbmap; + + /*Inode Bitmap Related */ + unsigned char **inode_bmaps; + int curr_inode_no; + uint16_t first_pass_ibmap; + + /*Journal Related */ + + /*Block Device Descriptor */ + block_dev_desc_t *dev_desc; +}; + +/*############################*/ +extern block_dev_desc_t *ext4_dev_desc; +/*#########################*/ + +extern struct ext2_data *ext4fs_root; +extern struct ext2fs_node *ext4fs_file; +struct ext_filesystem *get_fs(void); +int init_fs(block_dev_desc_t *); +void deinit_fs(block_dev_desc_t *); +int ext4fs_open(const char *filename); +int ext4fs_read(char *buf, unsigned len); +int ext4fs_mount(unsigned part_length); +int ext4fs_close(void); +int ext4fs_ls(const char *dirname); +void ext4fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot); +extern int ext2fs_devread(int sector, int byte_offset, int byte_len, char *buf); +extern void *xzalloc(size_t size); +#endif diff --git a/include/ext_common.h b/include/ext_common.h new file mode 100644 index 0000000..8b0474c --- /dev/null +++ b/include/ext_common.h @@ -0,0 +1,199 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + + +/* Some parts of this code (mainly the structures and defines) are + * from the original ext2 fs code, as found in the linux kernel. + */ + +#ifndef __EXT_COMMON__ +#define __EXT_COMMON__ + +#define SECTOR_SIZE 0x200 +#define SECTOR_BITS 9 + +/* Magic value used to identify an ext2 filesystem. */ +#define EXT2_MAGIC 0xEF53 +/* Amount of indirect blocks in an inode. */ +#define INDIRECT_BLOCKS 12 +/* Maximum lenght of a pathname. */ +#define EXT2_PATH_MAX 4096 +/* Maximum nesting of symlinks, used to prevent a loop. */ +#define EXT2_MAX_SYMLINKCNT 8 + +/* Filetype used in directory entry. */ +#define FILETYPE_UNKNOWN 0 +#define FILETYPE_REG 1 +#define FILETYPE_DIRECTORY 2 +#define FILETYPE_SYMLINK 7 + +/* Filetype information as used in inodes. */ +#define FILETYPE_INO_MASK 0170000 +#define FILETYPE_INO_REG 0100000 +#define FILETYPE_INO_DIRECTORY 0040000 +#define FILETYPE_INO_SYMLINK 0120000 +#define EXT2_ROOT_INO 2 /* Root inode */ + +/* Bits used as offset in sector */ +#define DISK_SECTOR_BITS 9 +/* The size of an ext2 block in bytes. */ +#define EXT2_BLOCK_SIZE(data) (1 << LOG2_BLOCK_SIZE(data)) + +/* Log2 size of ext2 block in 512 blocks. */ +#define LOG2_EXT2_BLOCK_SIZE(data) (__le32_to_cpu \ + (data->sblock.log2_block_size) + 1) + +/* Log2 size of ext2 block in bytes. */ +#define LOG2_BLOCK_SIZE(data) (__le32_to_cpu \ + (data->sblock.log2_block_size) + 10) +#define INODE_SIZE_FILESYSTEM(data) (__le32_to_cpu \ + (data->sblock.inode_size)) + +#define EXT2_FT_DIR 2 +#define SUCCESS 1 +/* + * Macro-instructions used to manage several block sizes + */ +#define EXT2_MIN_BLOCK_LOG_SIZE 10 /* 1024 */ +#define EXT2_MAX_BLOCK_LOG_SIZE 16 /* 65536 */ +#define EXT2_MIN_BLOCK_SIZE (1 << EXT2_MIN_BLOCK_LOG_SIZE) +#define EXT2_MAX_BLOCK_SIZE (1 << EXT2_MAX_BLOCK_LOG_SIZE) + +/* The ext2 superblock. */ +struct ext2_sblock { + uint32_t total_inodes; + uint32_t total_blocks; + uint32_t reserved_blocks; + uint32_t free_blocks; + uint32_t free_inodes; + uint32_t first_data_block; + uint32_t log2_block_size; + uint32_t log2_fragment_size; + uint32_t blocks_per_group; + uint32_t fragments_per_group; + uint32_t inodes_per_group; + uint32_t mtime; + uint32_t utime; + uint16_t mnt_count; + uint16_t max_mnt_count; + uint16_t magic; + uint16_t fs_state; + uint16_t error_handling; + uint16_t minor_revision_level; + uint32_t lastcheck; + uint32_t checkinterval; + uint32_t creator_os; + uint32_t revision_level; + uint16_t uid_reserved; + uint16_t gid_reserved; + uint32_t first_inode; + uint16_t inode_size; + uint16_t block_group_number; + uint32_t feature_compatibility; + uint32_t feature_incompat; + uint32_t feature_ro_compat; + uint32_t unique_id[4]; + char volume_name[16]; + char last_mounted_on[64]; + uint32_t compression_info; +}; + +struct ext2_block_group { + __u32 block_id; /* Blocks bitmap block */ + __u32 inode_id; /* Inodes bitmap block */ + __u32 inode_table_id; /* Inodes table block */ + __u16 free_blocks; /* Free blocks count */ + __u16 free_inodes; /* Free inodes count */ + __u16 used_dir_cnt; /* Directories count */ + __u16 bg_flags; + __u32 bg_reserved[2]; + __u16 bg_itable_unused; /* Unused inodes count */ + __u16 bg_checksum; /* crc16(s_uuid+grouo_num+group_desc)*/ +}; + +/* The ext2 inode. */ +struct ext2_inode { + uint16_t mode; + uint16_t uid; + uint32_t size; + uint32_t atime; + uint32_t ctime; + uint32_t mtime; + uint32_t dtime; + uint16_t gid; + uint16_t nlinks; + uint32_t blockcnt; /* Blocks of 512 bytes!! */ + uint32_t flags; + uint32_t osd1; + union { + struct datablocks { + uint32_t dir_blocks[INDIRECT_BLOCKS]; + uint32_t indir_block; + uint32_t double_indir_block; + uint32_t tripple_indir_block; + } blocks; + char symlink[60]; + } b; + uint32_t version; + uint32_t acl; + uint32_t dir_acl; + uint32_t fragment_addr; + uint32_t osd2[3]; +}; + +/* The header of an ext2 directory entry. */ +struct ext2_dirent { + uint32_t inode; + uint16_t direntlen; + uint8_t namelen; + uint8_t filetype; +}; + +struct ext2fs_node { + struct ext2_data *data; + struct ext2_inode inode; + int ino; + int inode_read; +}; + +/* Information about a "mounted" ext2 filesystem. */ +struct ext2_data { + struct ext2_sblock sblock; + struct ext2_inode *inode; + struct ext2fs_node diropen; +}; + +extern unsigned int inode_size; +extern struct ext2_data *ext2fs_root; +extern struct ext2_data *ext4fs_root; +extern int ext2fs_iterate_dir(struct ext2fs_node *dir, char *name, + struct ext2fs_node **fnode, int *ftype); +extern int ext2fs_find_file(const char *path, struct ext2fs_node *rootnode, + struct ext2fs_node **foundnode, int expecttype); +extern int ext2fs_devread(int sector, int byte_offset, int byte_len, char *buf); +int ext2fs_set_blk_dev(block_dev_desc_t *rbdd, int part); +uint32_t div_roundup(uint32_t size, uint32_t n); +long int read_allocated_block(struct ext2_inode *inode, int fileblock); +int ext2fs_mount(unsigned part_length); +void *xmalloc(size_t size); +void *xzalloc(size_t size); +#endif
Hi Uma,
Please include revision information in the patch title ([PATCH v2 ...]), change summary below the signed-of-by line (after a line with only ---) and set the in-reply-to: email header to the previous version of the patch.
Please read:
http://www.denx.de/wiki/U-Boot/Patches
Regards,
Graeme
On Thursday 15 December 2011 12:39:28 uma.shankar@samsung.com wrote:
NAK: please add some sort of description here. you must document all the places you're copying code from for example, and retain all the appropriate copyrights. as it stands, this patch is a mess from that perspective.
Makefile | 2 +- common/Makefile | 1 + common/cmd_ext2.c | 1 + common/cmd_ext4.c | 253 ++++++++++++++++++++++ fs/Makefile | 1 + fs/ext2/dev.c | 1 + fs/ext2/ext2fs.c | 340 +++--------------------------- fs/ext4/Makefile | 51 +++++ fs/ext4/ext4_common.c | 573 fs/ext4/ext4_common.h | 44 ++++ fs/ext4/ext4fs.c | 215 ++++++++++++++++++ include/ext2fs.h | 16 +- include/ext4fs.h | 116 ++++++++++ include/ext_common.h | 199 +++++++++++++++++
when moving code around, you should use the -M/-C flags so git can better describe what you did
static
- char *filename = NULL;
const
- switch (argc) {
- case 3:
else
count = 0;
break;
- case 4:
count = 0;
break;
- case 5:
filename = argv[4];
count = 0;
break;
- case 6:
filename = argv[4];
break;
- default:
there's duplicated code here. simpler to write it as: count = 0; filename = getenv("bootfile"); addr_str = getenv("loadaddr"); switch (argc) { case 6: strict_strtoul(argv[5], 16, &count); case 5: filename = argv[4]; case 4: addr_str = argv[3]; case 3: break; default: return cmd_usage(cmdtp); } if (addr_str) strict_strtoul(addr_str, 16, &addr); else addr = CONFIG_SYS_LOAD_ADDR;
that cast doesn't make sense
i don't see how this could possibly work. info.type is "unsigned char", so casting that single byte into an address and then reading a single byte !?
printf("** Invalid partition type \"%.32s\""
" (expect \"" BOOT_PART_TYPE "\")\n", info.type);
use %s instead of embeddeding a constant string
static
- char *filename = "/";
const
useless cast
drop the dead $(AOBJS) logic
NAK: the linux/ headers already provide this
- void *ptr = malloc(size);
- if (ptr == NULL && size != 0)
- return ptr;
NAK: this is useless, and clearly you're copying code from busybox. you *must* document that.
- void *ptr = xmalloc(size);
- memset(ptr, 0, size);
- return ptr;
NAK: this doesn't fail (so the "x" doesn't make sense), and the zalloc() aspect should be in a common header written as: #define zalloc(size) calloc(1, size)
+int ext4fs_mount(unsigned part_length) +{ ... +#ifdef DEBUG
- printf("EXT2 rev %d, inode_size %d\n",
use debug()
- ext4load - based on code from GRUB2 fs/ext2.c
you must retain copyright from the source files in the new files
+int init_fs(block_dev_desc_t *dev_desc) +{ ...
- fs = (struct ext_filesystem *)xzalloc(sizeof(struct ext_filesystem));
useless cast -mike
Signed-off-by: Uma Shankar uma.shankar@samsung.com Signed-off-by: Manjunatha C Achar a.manjunatha@samsung.com Signed-off-by: Iqbal Shareef iqbal.ams@samsung.com Signed-off-by: Hakgoo Lee goodguy.lee@samsung.com --- Changes for v2: - Code cleanup, changed comment style - camel case removed, resolved code alignment issues - memory allocation logic changed, removed busybox logic - Modified ext4 load to remove grub dependency (GPLv3)
Changes for v1: - Removed checkpatch warnings and errors - Moved common API's of ext2 and ext4 to one generic header file
Makefile | 2 +- common/Makefile | 1 + common/cmd_ext2.c | 1 + common/cmd_ext4.c | 249 ++++++++++++++++++++++ fs/Makefile | 1 + fs/ext2/dev.c | 1 + fs/ext2/ext2fs.c | 340 +++--------------------------- fs/ext4/Makefile | 51 +++++ fs/ext4/ext4_common.c | 565 +++++++++++++++++++++++++++++++++++++++++++++++++ fs/ext4/ext4_common.h | 48 +++++ fs/ext4/ext4fs.c | 219 +++++++++++++++++++ include/ext2fs.h | 16 +- include/ext4fs.h | 133 ++++++++++++ include/ext_common.h | 198 +++++++++++++++++ 14 files changed, 1501 insertions(+), 324 deletions(-) create mode 100644 common/cmd_ext4.c create mode 100644 fs/ext4/Makefile create mode 100644 fs/ext4/ext4_common.c create mode 100644 fs/ext4/ext4_common.h create mode 100644 fs/ext4/ext4fs.c create mode 100644 include/ext4fs.h create mode 100644 include/ext_common.h
diff --git a/Makefile b/Makefile index 5de7915..20cb941 100644 --- a/Makefile +++ b/Makefile @@ -235,7 +235,7 @@ LIBS += dts/libdts.o endif LIBS += arch/$(ARCH)/lib/lib$(ARCH).o LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o \ - fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/yaffs2/libyaffs2.o \ + fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/ext4/libext4fs.o fs/yaffs2/libyaffs2.o \ fs/ubifs/libubifs.o LIBS += net/libnet.o LIBS += disk/libdisk.o diff --git a/common/Makefile b/common/Makefile index 2d9ae8c..d99cc31 100644 --- a/common/Makefile +++ b/common/Makefile @@ -87,6 +87,7 @@ COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o +COBJS-$(CONFIG_CMD_EXT4) += cmd_ext4.o COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o COBJS-$(CONFIG_OF_LIBFDT) += cmd_fdt.o fdt_support.o diff --git a/common/cmd_ext2.c b/common/cmd_ext2.c index 35fb361..3ccc47e 100644 --- a/common/cmd_ext2.c +++ b/common/cmd_ext2.c @@ -40,6 +40,7 @@ #include <linux/ctype.h> #include <asm/byteorder.h> #include <ext2fs.h> +#include <ext_common.h> #if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) #include <usb.h> #endif diff --git a/common/cmd_ext4.c b/common/cmd_ext4.c new file mode 100644 index 0000000..85343db --- /dev/null +++ b/common/cmd_ext4.c @@ -0,0 +1,249 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* + * Ext4fs support + * made from existing cmd_ext2.c file of Uboot + */ +#include <common.h> +#include <part.h> +#include <config.h> +#include <command.h> +#include <image.h> +#include <linux/ctype.h> +#include <asm/byteorder.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <linux/stat.h> +#include <malloc.h> + +#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) +#include <usb.h> +#endif + +#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) +#error DOS or EFI partition support must be selected +#endif + +uint64_t total_sector; +uint64_t part_offset; + +#define DOS_PART_MAGIC_OFFSET 0x1fe +#define DOS_FS_TYPE_OFFSET 0x36 +#define DOS_FS32_TYPE_OFFSET 0x52 + +static int do_ext4_load(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + char *filename = NULL; + char *ep; + int dev; + unsigned long part = 1; + ulong addr = 0, part_length; + int filelen; + disk_partition_t info; + struct ext_filesystem *fs; + char buf[12]; + unsigned long count; + const char *addr_str; + + count = 0; + strict_strtoul(argv[3], 16, &addr); + filename = getenv("bootfile"); + switch (argc) { + case 3: + addr_str = getenv("loadaddr"); + if (addr_str != NULL) + strict_strtoul(addr_str, 16, &addr); + else + addr = CONFIG_SYS_LOAD_ADDR; + + break; + case 4: + break; + case 5: + filename = argv[4]; + break; + case 6: + filename = argv[4]; + strict_strtoul(argv[5], 16, &count); + break; + + default: + return cmd_usage(cmdtp); + } + + if (!filename) { + puts("** No boot file defined **\n"); + return 1; + } + + dev = (int)simple_strtoul(argv[2], &ep, 16); + ext4_dev_desc = get_dev(argv[1], dev); + if (ext4_dev_desc == NULL) { + printf("** Block device %s %d not supported\n", argv[1], dev); + return 1; + } + if (init_fs(ext4_dev_desc)) + return 1; + + fs = get_fs(); + if (*ep) { + if (*ep != ':') { + puts("** Invalid boot device, use `dev[:part]' **\n"); + return 1; + } + strict_strtoul(++ep, 16, &part); + } + + if (part != 0) { + if (get_partition_info(fs->dev_desc, part, &info)) { + printf("** Bad partition %lu **\n", part); + return 1; + } + + if (strncmp((char *)info.type, BOOT_PART_TYPE, + sizeof(info.type)) != 0) { + printf("** Invalid partition type "%.32s"" + " (expect "" BOOT_PART_TYPE "")\n", info.type); + return 1; + } + printf("Loading file "%s" " + "from %s device %d:%lu (%.32s)\n", + filename, argv[1], dev, part, info.name); + } else { + printf("Loading file "%s" from %s device %d\n", + filename, argv[1], dev); + } + + part_length = ext2fs_set_blk_dev(fs->dev_desc, part); + if (part_length == 0) { + printf("**Bad partition - %s %d:%lu **\n", argv[1], dev, part); + ext4fs_close(); + return 1; + } + + if (!ext4fs_mount(part_length)) { + printf("** Bad ext2 partition or disk - %s %d:%lu **\n", + argv[1], dev, part); + ext4fs_close(); + return 1; + } + + filelen = ext4fs_open(filename); + if (filelen < 0) { + printf("** File not found %s\n", filename); + ext4fs_close(); + return 1; + } + if ((count < filelen) && (count != 0)) + filelen = count; + + if (ext4fs_read((char *)addr, filelen) != filelen) { + printf("** Unable to read "%s" from %s %d:%lu **\n", + filename, argv[1], dev, part); + ext4fs_close(); + return 1; + } + + ext4fs_close(); + deinit_fs(fs->dev_desc); + /* Loading ok, update default load address */ + load_addr = addr; + + printf("%d bytes read\n", filelen); + sprintf(buf, "%X", filelen); + setenv("filesize", buf); + + return 0; +} + +static int do_ext4_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + char *filename = "/"; + int dev = 0; + unsigned long part = 1; + char *ep; + struct ext_filesystem *fs; + int part_length; + + if (argc < 3) + return cmd_usage(cmdtp); + + dev = (int)simple_strtoul(argv[2], &ep, 16); + ext4_dev_desc = get_dev(argv[1], dev); + + if (ext4_dev_desc == NULL) { + printf("\n** Block device %s %d not supported\n", argv[1], dev); + return 1; + } + + if (init_fs(ext4_dev_desc)) + return 1; + + fs = get_fs(); + if (*ep) { + if (*ep != ':') { + puts("\n** Invalid boot device, use `dev[:part]' **\n"); + return 1; + } + strict_strtoul(++ep, 16, &part); + } + + if (argc == 4) + filename = argv[3]; + + part_length = ext2fs_set_blk_dev(fs->dev_desc, part); + if (part_length == 0) { + printf("** Bad partition - %s %d:%lu **\n", argv[1], dev, part); + ext4fs_close(); + return 1; + } + + if (!ext4fs_mount(part_length)) { + printf("** Bad ext2 partition or disk - %s %d:%lu **\n", + argv[1], dev, part); + ext4fs_close(); + return 1; + } + if (ext4fs_ls(filename)) { + printf("** Error ext2fs_ls() **\n"); + ext4fs_close(); + return 1; + }; + + ext4fs_close(); + deinit_fs(fs->dev_desc); + return 0; +} + +U_BOOT_CMD(ext4ls, 4, 1, do_ext4_ls, + "list files in a directory (default /)", + "<interface> <dev[:part]> [directory]\n" + " - list files from 'dev' on 'interface' in a 'directory'"); + +U_BOOT_CMD(ext4load, 6, 0, do_ext4_load, + "load binary file from a Ext2 filesystem", + "<interface> <dev[:part]> [addr] [filename] [bytes]\n" + " - load binary file 'filename' from 'dev' on 'interface'\n" + " to address 'addr' from ext2 filesystem"); diff --git a/fs/Makefile b/fs/Makefile index 22aad12..27330d4 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -24,6 +24,7 @@
fail: diff --git a/fs/ext4/Makefile b/fs/ext4/Makefile new file mode 100644 index 0000000..850f821 --- /dev/null +++ b/fs/ext4/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2003 +# Pavel Bartusek, Sysgo Real-Time Solutions AG, pba@sysgo.de +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libext4fs.o + +AOBJS = +COBJS-$(CONFIG_CMD_EXT4) := ext4fs.o ext4_common.o + +SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) + + +all: $(LIB) $(AOBJS) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c new file mode 100644 index 0000000..d014360 --- /dev/null +++ b/fs/ext4/ext4_common.c @@ -0,0 +1,565 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <malloc.h> +#include <asm/byteorder.h> +#include <linux/stat.h> +#include <linux/time.h> +#include "ext4_common.h" +#include <stddef.h> + +struct ext2_data *ext4fs_root; +struct ext2fs_node *ext4fs_file; +uint32_t *ext4fs_indir1_block; +int ext4fs_indir1_size; +int ext4fs_indir1_blkno = -1; +uint32_t *ext4fs_indir2_block; +int ext4fs_indir2_size; +int ext4fs_indir2_blkno = -1; + +uint32_t *ext4fs_indir3_block; +int ext4fs_indir3_size; +int ext4fs_indir3_blkno = -1; +struct ext2_inode *g_parent_inode; + +static struct ext4_extent_header *ext4fs_get_extent_block(struct ext2_data * + data, char *buf, struct ext4_extent_header *ext_block, + uint32_t fileblock, int log2_blksz) +{ + struct ext4_extent_idx *index; + unsigned long long block; + struct ext_filesystem *fs = get_fs(); + int i; + + while (1) { + index = (struct ext4_extent_idx *)(ext_block + 1); + + if (le32_to_cpu(ext_block->eh_magic) != EXT4_EXT_MAGIC) + return 0; + + if (ext_block->eh_depth == 0) + return ext_block; + i = -1; + do { + i++; + if (i >= le32_to_cpu(ext_block->eh_entries)) + break; + } while (fileblock > le32_to_cpu(index[i].ei_block)); + + if (--i < 0) + return 0; + + block = le32_to_cpu(index[i].ei_leaf_hi); + block = (block << 32) + le32_to_cpu(index[i].ei_leaf_lo); + + if (ext2fs_devread(block << log2_blksz, 0, fs->blksz, buf)) + ext_block = (struct ext4_extent_header *)buf; + else + return 0; + } +} + +static int ext4fs_blockgroup + (struct ext2_data *data, int group, struct ext2_block_group *blkgrp) +{ + long int blkno; + unsigned int blkoff, desc_per_blk; + + desc_per_blk = EXT2_BLOCK_SIZE(data) / sizeof(struct ext2_block_group); + + blkno = __le32_to_cpu(data->sblock.first_data_block) + 1 + + group / desc_per_blk; + blkoff = (group % desc_per_blk) * sizeof(struct ext2_block_group); + + debug("ext4fs read %d group descriptor (blkno %ld blkoff %u)\n", + group, blkno, blkoff); + + return ext2fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data), + blkoff, sizeof(struct ext2_block_group), (char *)blkgrp); +} + +int ext4fs_read_inode(struct ext2_data *data, int ino, struct ext2_inode *inode) +{ + struct ext2_block_group blkgrp; + struct ext2_sblock *sblock = &data->sblock; + struct ext_filesystem *fs = get_fs(); + int inodes_per_block, status; + long int blkno; + unsigned int blkoff; + + /* It is easier to calculate if the first inode is 0. */ + ino--; + status = ext4fs_blockgroup(data, ino / __le32_to_cpu + (sblock->inodes_per_group), &blkgrp); + + if (status == 0) + return 0; + + inodes_per_block = EXT2_BLOCK_SIZE(data) / fs->inodesz; + blkno = __le32_to_cpu(blkgrp.inode_table_id) + + (ino % __le32_to_cpu(sblock->inodes_per_group)) / + inodes_per_block; + blkoff = (ino % inodes_per_block) * fs->inodesz; + /* Read the inode. */ + status = ext2fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data), blkoff, + sizeof(struct ext2_inode), (char *)inode); + if (status == 0) + return 0; + + return 1; +} + +long int read_allocated_block(struct ext2_inode *inode, int fileblock) +{ + long int blknr; + int blksz; + int log2_blksz; + int status; + long int rblock; + long int perblock_parent; + long int perblock_child; + unsigned long long start; + /*get the blocksize of the filesystem */ + blksz = EXT2_BLOCK_SIZE(ext4fs_root); + log2_blksz = LOG2_EXT2_BLOCK_SIZE(ext4fs_root); + + if (le32_to_cpu(inode->flags) & EXT4_EXTENTS_FL) { + char *buf = (char *)zalloc(blksz); + if (!buf) + return -ENOMEM; + struct ext4_extent_header *ext_block; + struct ext4_extent *extent; + int i = -1; + ext_block = ext4fs_get_extent_block(ext4fs_root, buf, + (struct ext4_extent_header *)inode-> + b.blocks.dir_blocks, fileblock, log2_blksz); + if (!ext_block) { + printf("invalid extent block\n"); + free(buf); + return -EINVAL; + } + + extent = (struct ext4_extent *)(ext_block + 1); + + do { + i++; + if (i >= le32_to_cpu(ext_block->eh_entries)) + break; + } while (fileblock >= le32_to_cpu(extent[i].ee_block)); + if (--i >= 0) { + fileblock -= le32_to_cpu(extent[i].ee_block); + if (fileblock >= le32_to_cpu(extent[i].ee_len)) { + free(buf); + return 0; + } + + start = le32_to_cpu(extent[i].ee_start_hi); + start = (start << 32) + + le32_to_cpu(extent[i].ee_start_lo); + free(buf); + return fileblock + start; + } + + printf("Extent Error\n"); + free(buf); + return -1; + } + + /* Direct blocks. */ + if (fileblock < INDIRECT_BLOCKS) + blknr = __le32_to_cpu(inode->b.blocks.dir_blocks[fileblock]); + + /* Indirect. */ + else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4))) { + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** SI ext2fs read block (indir 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** SI ext2fs read block (indir 1):" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = ext2fs_devread(__le32_to_cpu(inode->b.blocks. + indir_block) << log2_blksz, 0, blksz, + (char *) ext4fs_indir1_block); + if (status == 0) { + printf("** SI ext2fs read block (indir 1)" + "failed. **\n"); + return 0; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks. + indir_block) << log2_blksz; + } + blknr = __le32_to_cpu(ext4fs_indir1_block + [fileblock - INDIRECT_BLOCKS]); + } + /* Double indirect. */ + else if (fileblock < + (INDIRECT_BLOCKS + (blksz / 4 * (blksz / 4 + 1)))) { + + long int perblock = blksz / 4; + long int rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4); + + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** DI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** DI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.double_indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = ext2fs_devread(__le32_to_cpu(inode->b.blocks. + double_indir_block) << log2_blksz, 0, blksz, + (char *) ext4fs_indir1_block); + if (status == 0) { + printf("** DI ext2fs read block (indir 2 1)" + "failed. **\n"); + return -1; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks. + double_indir_block) << log2_blksz; + } + + if (ext4fs_indir2_block == NULL) { + ext4fs_indir2_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** DI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + ext4fs_indir2_blkno = -1; + } + if (blksz != ext4fs_indir2_size) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + ext4fs_indir2_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** DI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir1_block[rblock / perblock]) << + log2_blksz) != ext4fs_indir2_blkno) { + status = ext2fs_devread(__le32_to_cpu + (ext4fs_indir1_block + [rblock / perblock]) << log2_blksz, + 0, blksz, (char *) ext4fs_indir2_block); + if (status == 0) { + printf("** DI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir2_blkno = + __le32_to_cpu(ext4fs_indir1_block[rblock + / perblock]) << log2_blksz; + } + blknr = __le32_to_cpu(ext4fs_indir2_block[rblock % perblock]); + } + /* Tripple indirect. */ + else { + rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4 + + (blksz / 4 * blksz / 4)); + perblock_child = blksz / 4; + perblock_parent = ((blksz / 4) * (blksz / 4)); + + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** TI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** TI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.triple_indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = ext2fs_devread + (__le32_to_cpu(inode->b.blocks. + triple_indir_block) << log2_blksz, + 0, blksz, (char *) ext4fs_indir1_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 1)" + "failed. **\n"); + return -1; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks. + triple_indir_block) << log2_blksz; + } + + if (ext4fs_indir2_block == NULL) { + ext4fs_indir2_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + ext4fs_indir2_blkno = -1; + } + if (blksz != ext4fs_indir2_size) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + ext4fs_indir2_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir1_block[rblock / + perblock_parent]) << log2_blksz) + != ext4fs_indir2_blkno) { + status = ext2fs_devread(__le32_to_cpu + (ext4fs_indir1_block + [rblock / perblock_parent]) << log2_blksz, + 0, blksz, (char *) ext4fs_indir2_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir2_blkno = + __le32_to_cpu(ext4fs_indir1_block[rblock / + perblock_parent]) << log2_blksz; + } + + if (ext4fs_indir3_block == NULL) { + ext4fs_indir3_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir3_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir3_size = blksz; + ext4fs_indir3_blkno = -1; + } + if (blksz != ext4fs_indir3_size) { + free(ext4fs_indir3_block); + ext4fs_indir3_block = NULL; + ext4fs_indir3_size = 0; + ext4fs_indir3_blkno = -1; + ext4fs_indir3_block = (uint32_t *) zalloc(blksz); + if (ext4fs_indir3_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir3_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir2_block[rblock + / perblock_child]) << log2_blksz) != ext4fs_indir3_blkno){ + status = ext2fs_devread(__le32_to_cpu + (ext4fs_indir2_block[(rblock / perblock_child) + % (blksz / 4)]) << log2_blksz, + 0, blksz, (char *) ext4fs_indir3_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir3_blkno = + __le32_to_cpu(ext4fs_indir2_block[(rblock / + perblock_child) % (blksz / 4)]) << log2_blksz; + } + + blknr = __le32_to_cpu(ext4fs_indir3_block + [rblock % perblock_child]); + } + debug("ext4fs_read_block %ld\n", blknr); + + return blknr; +} + +int ext4fs_close(void) +{ + if ((ext4fs_file != NULL) && (ext4fs_root != NULL)) { + ext4fs_free_node(ext4fs_file, &ext4fs_root->diropen); + ext4fs_file = NULL; + } + if (ext4fs_root != NULL) { + free(ext4fs_root); + ext4fs_root = NULL; + } + if (ext4fs_indir1_block != NULL) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + } + if (ext4fs_indir2_block != NULL) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + } + if (ext4fs_indir3_block != NULL) { + free(ext4fs_indir3_block); + ext4fs_indir3_block = NULL; + ext4fs_indir3_size = 0; + ext4fs_indir3_blkno = -1; + } + + return 0; +} + +int ext4fs_open(const char *filename) +{ + struct ext2fs_node *fdiro = NULL; + int status; + int len; + + if (ext4fs_root == NULL) + return -1; + + ext4fs_file = NULL; + status = ext2fs_find_file(filename, &ext4fs_root->diropen, &fdiro, + FILETYPE_REG); + if (status == 0) + goto fail; + + if (!fdiro->inode_read) { + status = ext4fs_read_inode(fdiro->data, fdiro->ino, + &fdiro->inode); + if (status == 0) + goto fail; + } + len = __le32_to_cpu(fdiro->inode.size); + ext4fs_file = fdiro; + + return len; +fail: + ext4fs_free_node(fdiro, &ext4fs_root->diropen); + + return -1; +} + +int ext4fs_mount(unsigned part_length) +{ + struct ext2_data *data; + int status; + struct ext_filesystem *fs = get_fs(); + data = zalloc(sizeof(struct ext2_data)); + if (!data) + return 0; + + /* Read the superblock. */ + status = ext2fs_devread(1 * 2, 0, sizeof(struct ext2_sblock), + (char *)&data->sblock); + + if (status == 0) + goto fail; + + /* Make sure this is an ext2 filesystem. */ + if (__le16_to_cpu(data->sblock.magic) != EXT2_MAGIC) + goto fail; + + if (__le32_to_cpu(data->sblock.revision_level == 0)) + fs->inodesz = 128; + else + fs->inodesz = __le16_to_cpu(data->sblock.inode_size); + + debug("EXT2 rev %d, inode_size %d\n", + __le32_to_cpu(data->sblock.revision_level), fs->inodesz); + + data->diropen.data = data; + data->diropen.ino = 2; + data->diropen.inode_read = 1; + data->inode = &data->diropen.inode; + + status = ext4fs_read_inode(data, 2, data->inode); + if (status == 0) + goto fail; + + inode_size = fs->inodesz; + ext4fs_root = data; + ext2fs_root = data; + + return 1; +fail: + printf("Failed to mount ext2 filesystem...\n"); + free(data); + ext4fs_root = NULL; + + return 0; +} diff --git a/fs/ext4/ext4_common.h b/fs/ext4/ext4_common.h new file mode 100644 index 0000000..a0e04e0 --- /dev/null +++ b/fs/ext4/ext4_common.h @@ -0,0 +1,48 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __EXT4_COMMON__ +#define __EXT4_COMMON__ +#include <ext_common.h> +#include <ext4fs.h> +#include <malloc.h> +#include <asm/errno.h> + +#define YES 1 +#define NO 0 +#define TRUE 1 +#define FALSE 0 +#define RECOVER 1 +#define SCAN 0 + +#define S_IFLNK 0120000 /* symbolic link */ +#define BLOCK_NO_ONE 1 +#define SUPERBLOCK_SECTOR 2 +#define SUPERBLOCK_SIZE 1024 +#define F_FILE 1 + +#define zalloc(size) calloc(1, size) + +extern unsigned long part_offset; +int ext4fs_read_inode(struct ext2_data *data, int ino, + struct ext2_inode *inode); +#endif diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c new file mode 100644 index 0000000..2db044d --- /dev/null +++ b/fs/ext4/ext4fs.c @@ -0,0 +1,219 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <malloc.h> +#include <asm/byteorder.h> +#include <linux/stat.h> +#include <linux/time.h> +#include <ext_common.h> +#include <ext4fs.h> +#include "ext4_common.h" + +int ext4fs_symlinknest; +block_dev_desc_t *ext4_dev_desc; + +struct ext_filesystem *get_fs(void) +{ + if (ext4_dev_desc == NULL || ext4_dev_desc->priv == NULL) + printf("Invalid Input Arguments %s\n", __func__); + + return ext4_dev_desc->priv; +} + +int init_fs(block_dev_desc_t *dev_desc) +{ + struct ext_filesystem *fs; + if (dev_desc == NULL) { + printf("Invalid Input Arguments %s\n", __func__); + return -EINVAL; + } + + fs = (struct ext_filesystem *)zalloc(sizeof(struct ext_filesystem)); + if (fs == NULL) { + printf("malloc failed: %s\n", __func__); + return -ENOMEM; + } + + fs->dev_desc = dev_desc; + dev_desc->priv = fs; + + return 0; +} + +void deinit_fs(block_dev_desc_t *dev_desc) +{ + if (dev_desc == NULL) { + printf("Invalid Input Arguments %s\n", __func__); + return; + } + free(dev_desc->priv); + dev_desc->priv = NULL; + + return; +} + +void ext4fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot) +{ + if ((node != &ext4fs_root->diropen) && (node != currroot)) + free(node); +} + +/* + * Taken from openmoko-kernel mailing list: By Andy green + * Optimized read file API : collects and defers contiguous sector + * reads into one potentially more efficient larger sequential read action + */ +int ext4fs_read_file(struct ext2fs_node *node, int pos, + unsigned int len, char *buf) +{ + int i; + int blockcnt; + int log2blocksize = LOG2_EXT2_BLOCK_SIZE(node->data); + int blocksize = 1 << (log2blocksize + DISK_SECTOR_BITS); + unsigned int filesize = __le32_to_cpu(node->inode.size); + int previous_block_number = -1; + int delayed_start = 0; + int delayed_extent = 0; + int delayed_skipfirst = 0; + int delayed_next = 0; + char *delayed_buf = NULL; + short status; + + /* Adjust len so it we can't read past the end of the file. */ + if (len > filesize) + len = filesize; + + blockcnt = ((len + pos) + blocksize - 1) / blocksize; + + for (i = pos / blocksize; i < blockcnt; i++) { + int blknr; + int blockoff = pos % blocksize; + int blockend = blocksize; + int skipfirst = 0; + blknr = read_allocated_block(&(node->inode), i); + if (blknr < 0) + return -1; + + blknr = blknr << log2blocksize; + + /* Last block. */ + if (i == blockcnt - 1) { + blockend = (len + pos) % blocksize; + + /* The last portion is exactly blocksize. */ + if (!blockend) + blockend = blocksize; + } + + /* First block. */ + if (i == pos / blocksize) { + skipfirst = blockoff; + blockend -= skipfirst; + } + if (blknr) { + int status; + + if (previous_block_number != -1) { + if (delayed_next == blknr) { + delayed_extent += blockend; + delayed_next += blockend >> SECTOR_BITS; + } else { /* spill */ + status = ext2fs_devread(delayed_start, + delayed_skipfirst, + delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = blknr; + delayed_start = blknr; + delayed_extent = blockend; + delayed_skipfirst = skipfirst; + delayed_buf = buf; + delayed_next = blknr + + (blockend >> SECTOR_BITS); + } + } else { + previous_block_number = blknr; + delayed_start = blknr; + delayed_extent = blockend; + delayed_skipfirst = skipfirst; + delayed_buf = buf; + delayed_next = blknr + + (blockend >> SECTOR_BITS); + } + } else { + if (previous_block_number != -1) { + /* spill */ + status = ext2fs_devread(delayed_start, + delayed_skipfirst, + delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = -1; + } + memset(buf, 0, blocksize - skipfirst); + } + buf += blocksize - skipfirst; + } + if (previous_block_number != -1) { + /* spill */ + status = ext2fs_devread(delayed_start, + delayed_skipfirst, delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = -1; + } + + return len; +} + +int ext4fs_ls(const char *dirname) +{ + struct ext2fs_node *dirnode; + int status; + + if (dirname == NULL) + return 0; + + status = ext2fs_find_file(dirname, &ext4fs_root->diropen, &dirnode, + FILETYPE_DIRECTORY); + if (status != 1) { + printf("** Can not find directory. **\n"); + return 1; + } + + ext2fs_iterate_dir(dirnode, NULL, NULL, NULL); + ext4fs_free_node(dirnode, &ext4fs_root->diropen); + + return 0; +} + +int ext4fs_read(char *buf, unsigned len) +{ + if (ext4fs_root == NULL || ext4fs_file == NULL) + return 0; + + return ext4fs_read_file(ext4fs_file, 0, len, buf); +} diff --git a/include/ext2fs.h b/include/ext2fs.h index 163a9bb..7d4834c 100644 --- a/include/ext2fs.h +++ b/include/ext2fs.h @@ -25,6 +25,8 @@ * from the original ext2 fs code, as found in the linux kernel. */
- -extern int ext2fs_set_blk_dev(block_dev_desc_t *rbdd, int part); -extern int ext2fs_ls (const char *dirname); -extern int ext2fs_open (const char *filename); -extern int ext2fs_read (char *buf, unsigned len); -extern int ext2fs_mount (unsigned part_length); -extern int ext2fs_close(void); +int ext2fs_ls(const char *dirname); +int ext2fs_open(const char *filename); +int ext2fs_read(char *buf, unsigned len); +int ext2fs_close(void); +int ext2_register_device(block_dev_desc_t *dev_desc, int part_no); +#endif diff --git a/include/ext4fs.h b/include/ext4fs.h new file mode 100644 index 0000000..e1eb17f --- /dev/null +++ b/include/ext4fs.h @@ -0,0 +1,133 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * + * Some parts of this code (mainly the structures and defines) are + * from the original ext4 fs code, as found in the linux kernel. + */ + +#ifndef __EXT4__ +#define __EXT4__ +#include <ext_common.h> + +#define EXT4_EXTENTS_FL 0x00080000 +#define EXT4_EXT_MAGIC 0xf30a +#define EXT4_FEATURE_RO_COMPAT_GDT_CSUM 0x0010 +#define EXT4_FEATURE_INCOMPAT_EXTENTS 0x0040 +#define EXT4_INDIRECT_BLOCKS 12 + +#define EXT4_BG_INODE_UNINIT 0x0001 +#define EXT4_BG_BLOCK_UNINIT 0x0002 +#define EXT4_BG_INODE_ZEROED 0x0004 + +/* + * ext4_inode has i_block array (60 bytes total). + * The first 12 bytes store ext4_extent_header; + * the remainder stores an array of ext4_extent. + */ + +/* + * This is the extent on-disk structure. + * It's used at the bottom of the tree. + */ +struct ext4_extent { + __le32 ee_block; /* first logical block extent covers */ + __le16 ee_len; /* number of blocks covered by extent */ + __le16 ee_start_hi; /* high 16 bits of physical block */ + __le32 ee_start_lo; /* low 32 bits of physical block */ +}; + +/* + * This is index on-disk structure. + * It's used at all the levels except the bottom. + */ +struct ext4_extent_idx { + __le32 ei_block; /* index covers logical blocks from 'block' */ + __le32 ei_leaf_lo; /* pointer to the physical block of the next * + * level. leaf or next index could be there */ + __le16 ei_leaf_hi; /* high 16 bits of physical block */ + __u16 ei_unused; +}; + +/* + * Each block (leaves and indexes), even inode-stored has header. + */ +struct ext4_extent_header { + __le16 eh_magic; /* probably will support different formats */ + __le16 eh_entries; /* number of valid entries */ + __le16 eh_max; /* capacity of store in entries */ + __le16 eh_depth; /* has tree real underlying blocks? */ + __le32 eh_generation; /* generation of the tree */ +}; + +struct ext_filesystem { + /*Total Sector of partition */ + uint64_t total_sect; + /*Block size of partition */ + uint32_t blksz; + /*Inode size of partition */ + uint32_t inodesz; + /*Sectors per Block */ + uint32_t sect_perblk; + /*Group Descriptor Block Number */ + uint32_t gdtable_blkno; + /*Total block groups of partition */ + uint32_t no_blkgrp; + /*No of blocks required for bgdtable */ + uint32_t no_blk_pergdt; + /*superblock */ + struct ext2_sblock *sb; + /*block group descritpor table */ + struct ext2_block_group *gd; + char *gdtable; + + /*Block Bitmap Related */ + unsigned char **blk_bmaps; + long int curr_blkno; + uint16_t first_pass_bbmap; + + /*Inode Bitmap Related */ + unsigned char **inode_bmaps; + int curr_inode_no; + uint16_t first_pass_ibmap; + + /*Journal Related */ + + /*Block Device Descriptor */ + block_dev_desc_t *dev_desc; +}; + +/*############################*/ +extern block_dev_desc_t *ext4_dev_desc; +/*#########################*/ + +extern struct ext2_data *ext4fs_root; +extern struct ext2fs_node *ext4fs_file; +struct ext_filesystem *get_fs(void); +int init_fs(block_dev_desc_t *); +void deinit_fs(block_dev_desc_t *); +int ext4fs_open(const char *filename); +int ext4fs_read(char *buf, unsigned len); +int ext4fs_mount(unsigned part_length); +int ext4fs_close(void); +int ext4fs_ls(const char *dirname); +void ext4fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot); +extern int ext2fs_devread(int sector, int byte_offset, int byte_len, char *buf); +extern void *xzalloc(size_t size); +#endif diff --git a/include/ext_common.h b/include/ext_common.h new file mode 100644 index 0000000..7a4d422 --- /dev/null +++ b/include/ext_common.h @@ -0,0 +1,198 @@ +/* + * (C) Copyright 2011 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + + +/* + * Some parts of this code (mainly the structures and defines) are + * from the original ext2 fs code, as found in the linux kernel. + */ + +#ifndef __EXT_COMMON__ +#define __EXT_COMMON__ + +#define SECTOR_SIZE 0x200 +#define SECTOR_BITS 9 + +/* Magic value used to identify an ext2 filesystem. */ +#define EXT2_MAGIC 0xEF53 +/* Amount of indirect blocks in an inode. */ +#define INDIRECT_BLOCKS 12 +/* Maximum lenght of a pathname. */ +#define EXT2_PATH_MAX 4096 +/* Maximum nesting of symlinks, used to prevent a loop. */ +#define EXT2_MAX_SYMLINKCNT 8 + +/* Filetype used in directory entry. */ +#define FILETYPE_UNKNOWN 0 +#define FILETYPE_REG 1 +#define FILETYPE_DIRECTORY 2 +#define FILETYPE_SYMLINK 7 + +/* Filetype information as used in inodes. */ +#define FILETYPE_INO_MASK 0170000 +#define FILETYPE_INO_REG 0100000 +#define FILETYPE_INO_DIRECTORY 0040000 +#define FILETYPE_INO_SYMLINK 0120000 +#define EXT2_ROOT_INO 2 /* Root inode */ + +/* Bits used as offset in sector */ +#define DISK_SECTOR_BITS 9 +/* The size of an ext2 block in bytes. */ +#define EXT2_BLOCK_SIZE(data) (1 << LOG2_BLOCK_SIZE(data)) + +/* Log2 size of ext2 block in 512 blocks. */ +#define LOG2_EXT2_BLOCK_SIZE(data) (__le32_to_cpu \ + (data->sblock.log2_block_size) + 1) + +/* Log2 size of ext2 block in bytes. */ +#define LOG2_BLOCK_SIZE(data) (__le32_to_cpu \ + (data->sblock.log2_block_size) + 10) +#define INODE_SIZE_FILESYSTEM(data) (__le32_to_cpu \ + (data->sblock.inode_size)) + +#define EXT2_FT_DIR 2 +#define SUCCESS 1 +/* + * Macro-instructions used to manage several block sizes + */ +#define EXT2_MIN_BLOCK_LOG_SIZE 10 /* 1024 */ +#define EXT2_MAX_BLOCK_LOG_SIZE 16 /* 65536 */ +#define EXT2_MIN_BLOCK_SIZE (1 << EXT2_MIN_BLOCK_LOG_SIZE) +#define EXT2_MAX_BLOCK_SIZE (1 << EXT2_MAX_BLOCK_LOG_SIZE) + +/* The ext2 superblock. */ +struct ext2_sblock { + uint32_t total_inodes; + uint32_t total_blocks; + uint32_t reserved_blocks; + uint32_t free_blocks; + uint32_t free_inodes; + uint32_t first_data_block; + uint32_t log2_block_size; + uint32_t log2_fragment_size; + uint32_t blocks_per_group; + uint32_t fragments_per_group; + uint32_t inodes_per_group; + uint32_t mtime; + uint32_t utime; + uint16_t mnt_count; + uint16_t max_mnt_count; + uint16_t magic; + uint16_t fs_state; + uint16_t error_handling; + uint16_t minor_revision_level; + uint32_t lastcheck; + uint32_t checkinterval; + uint32_t creator_os; + uint32_t revision_level; + uint16_t uid_reserved; + uint16_t gid_reserved; + uint32_t first_inode; + uint16_t inode_size; + uint16_t block_group_number; + uint32_t feature_compatibility; + uint32_t feature_incompat; + uint32_t feature_ro_compat; + uint32_t unique_id[4]; + char volume_name[16]; + char last_mounted_on[64]; + uint32_t compression_info; +}; + +struct ext2_block_group { + __u32 block_id; /* Blocks bitmap block */ + __u32 inode_id; /* Inodes bitmap block */ + __u32 inode_table_id; /* Inodes table block */ + __u16 free_blocks; /* Free blocks count */ + __u16 free_inodes; /* Free inodes count */ + __u16 used_dir_cnt; /* Directories count */ + __u16 bg_flags; + __u32 bg_reserved[2]; + __u16 bg_itable_unused; /* Unused inodes count */ + __u16 bg_checksum; /* crc16(s_uuid+grouo_num+group_desc)*/ +}; + +/* The ext2 inode. */ +struct ext2_inode { + uint16_t mode; + uint16_t uid; + uint32_t size; + uint32_t atime; + uint32_t ctime; + uint32_t mtime; + uint32_t dtime; + uint16_t gid; + uint16_t nlinks; + uint32_t blockcnt; /* Blocks of 512 bytes!! */ + uint32_t flags; + uint32_t osd1; + union { + struct datablocks { + uint32_t dir_blocks[INDIRECT_BLOCKS]; + uint32_t indir_block; + uint32_t double_indir_block; + uint32_t triple_indir_block; + } blocks; + char symlink[60]; + } b; + uint32_t version; + uint32_t acl; + uint32_t dir_acl; + uint32_t fragment_addr; + uint32_t osd2[3]; +}; + +/* The header of an ext2 directory entry. */ +struct ext2_dirent { + uint32_t inode; + uint16_t direntlen; + uint8_t namelen; + uint8_t filetype; +}; + +struct ext2fs_node { + struct ext2_data *data; + struct ext2_inode inode; + int ino; + int inode_read; +}; + +/* Information about a "mounted" ext2 filesystem. */ +struct ext2_data { + struct ext2_sblock sblock; + struct ext2_inode *inode; + struct ext2fs_node diropen; +}; + +extern unsigned int inode_size; +extern struct ext2_data *ext2fs_root; +extern struct ext2_data *ext4fs_root; +extern int ext2fs_iterate_dir(struct ext2fs_node *dir, char *name, + struct ext2fs_node **fnode, int *ftype); +extern int ext2fs_find_file(const char *path, struct ext2fs_node *rootnode, + struct ext2fs_node **foundnode, int expecttype); +extern int ext2fs_devread(int sector, int byte_offset, int byte_len, char *buf); +int ext2fs_set_blk_dev(block_dev_desc_t *rbdd, int part); +uint32_t div_roundup(uint32_t size, uint32_t n); +long int read_allocated_block(struct ext2_inode *inode, int fileblock); +int ext2fs_mount(unsigned part_length); +#endif
Dear uma.shankar@samsung.com,
In message 1325038933-10587-1-git-send-email-uma.shankar@samsung.com you wrote:
Changes for v2:
Changes for v1:
Applied, thanks.
Changes for v2:
Changes for v1:
Oops. No, I cannot apply this. When I enable CONFIG_CMD_EXT4 in a board config file, I get this:
+ ./MAKEALL TQM860L Configuring for TQM860L board... common/libcommon.o: In function `do_ext4_load': /home/wd/git/u-boot/work/common/cmd_ext4.c:143: undefined reference to `ext2fs_set_blk_dev' common/libcommon.o: In function `do_ext4_ls': /home/wd/git/u-boot/work/common/cmd_ext4.c:220: undefined reference to `ext2fs_set_blk_dev' fs/ext4/libext4fs.o: In function `ext4fs_read_file': /home/wd/git/u-boot/work/fs/ext4/ext4fs.c:152: undefined reference to `ext2fs_devread' /home/wd/git/u-boot/work/fs/ext4/ext4fs.c:178: undefined reference to `ext2fs_devread' /home/wd/git/u-boot/work/fs/ext4/ext4fs.c:192: undefined reference to `ext2fs_devread' fs/ext4/libext4fs.o: In function `ext4fs_ls': /home/wd/git/u-boot/work/fs/ext4/ext4fs.c:211: undefined reference to `ext2fs_find_file' /home/wd/git/u-boot/work/fs/ext4/ext4fs.c:218: undefined reference to `ext2fs_iterate_dir' fs/ext4/libext4fs.o: In function `ext4fs_blockgroup': /home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1479: undefined reference to `ext2fs_devread' fs/ext4/libext4fs.o: In function `ext4fs_read_inode': /home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1506: undefined reference to `ext2fs_devread' fs/ext4/libext4fs.o: In function `ext4fs_get_extent_block': /home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1457: undefined reference to `ext2fs_devread' fs/ext4/libext4fs.o: In function `read_allocated_block': /home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1601: undefined reference to `ext2fs_devread' /home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1648: undefined reference to `ext2fs_devread' fs/ext4/libext4fs.o:/home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1686: more undefined references to `ext2fs_devread' follow fs/ext4/libext4fs.o: In function `ext4fs_open': /home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1876: undefined reference to `ext2fs_find_file' fs/ext4/libext4fs.o: In function `ext4fs_mount': /home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1907: undefined reference to `ext2fs_devread' /home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1934: undefined reference to `inode_size' /home/wd/git/u-boot/work/fs/ext4/ext4_common.c:1936: undefined reference to `ext2fs_root' make: *** [/work/wd/tmp-ppc/u-boot] Error 1
It seems this happens when you only enable CONFIG_CMD_EXT4, without explicitly enabling CONFIG_CMD_EXT2 as well. Please fix this - if the ext4 code needs ext2, then it should automatically enable this option.
Hm... How much code duplication (for ext2 and ext4 commands) does this cause?
NAK: you missed a bunch of my previous feedback -mike
Signed-off-by: Uma Shankar uma.shankar@samsung.com Signed-off-by: Manjunatha C Achar a.manjunatha@samsung.com Signed-off-by: Iqbal Shareef iqbal.ams@samsung.com Signed-off-by: Hakgoo Lee goodguy.lee@samsung.com --- Changes for v3: - Copyright has been updated in respective files - ext4fs has been made independant of ext2fs.c - Fixed API namespace - Removed endianness conversion API, used uboot defined API for the same - Fixed coding style issues - Moved README.ext4 file into doc folder
Changes for v2: - Code cleanup, changed comment style - camel case removed, resolved code alignment issues - memory allocation logic changed, removed busybox logic - Modified ext4 load to remove grub dependency (GPLv3) - Introduced new Config for ext4 write
Makefile | 2 +- common/Makefile | 1 + common/cmd_ext4.c | 266 +++++++++++++++ fs/Makefile | 1 + fs/ext2/dev.c | 1 + fs/ext2/ext2fs.c | 181 ++--------- fs/ext4/Makefile | 51 +++ fs/ext4/dev.c | 145 ++++++++ fs/ext4/ext4_common.c | 875 +++++++++++++++++++++++++++++++++++++++++++++++++ fs/ext4/ext4_common.h | 63 ++++ fs/ext4/ext4fs.c | 228 +++++++++++++ include/ext4fs.h | 132 ++++++++ include/ext_common.h | 188 +++++++++++ 13 files changed, 1977 insertions(+), 157 deletions(-) create mode 100644 common/cmd_ext4.c create mode 100644 fs/ext4/Makefile create mode 100644 fs/ext4/dev.c create mode 100644 fs/ext4/ext4_common.c create mode 100644 fs/ext4/ext4_common.h create mode 100644 fs/ext4/ext4fs.c create mode 100644 include/ext4fs.h create mode 100644 include/ext_common.h
diff --git a/Makefile b/Makefile index 7e9491d..e77f6be 100644 --- a/Makefile +++ b/Makefile @@ -235,7 +235,7 @@ LIBS += dts/libdts.o endif LIBS += arch/$(ARCH)/lib/lib$(ARCH).o LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o \ - fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/yaffs2/libyaffs2.o \ + fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/ext4/libext4fs.o fs/yaffs2/libyaffs2.o \ fs/ubifs/libubifs.o LIBS += net/libnet.o LIBS += disk/libdisk.o diff --git a/common/Makefile b/common/Makefile index 2d9ae8c..f5243f6 100644 --- a/common/Makefile +++ b/common/Makefile @@ -86,6 +86,7 @@ COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o +COBJS-$(CONFIG_CMD_EXT4) += cmd_ext4.o COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o diff --git a/common/cmd_ext4.c b/common/cmd_ext4.c new file mode 100644 index 0000000..2c53d2c --- /dev/null +++ b/common/cmd_ext4.c @@ -0,0 +1,266 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Ext4fs support + * made from existing cmd_ext2.c file of Uboot + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * made from cmd_reiserfs by + * + * (C) Copyright 2003 - 2004 + * Sysgo Real-Time Solutions, AG <www.elinos.com> + * Pavel Bartusek pba@sysgo.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* + * Changelog: + * 0.1 - Newly created file for ext4fs support. Taken from cmd_ext2.c + * file in uboot. Added ext4fs ls and load support. + */ + +#include <common.h> +#include <part.h> +#include <config.h> +#include <command.h> +#include <image.h> +#include <linux/ctype.h> +#include <asm/byteorder.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <linux/stat.h> +#include <malloc.h> + +#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) +#include <usb.h> +#endif + +#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) +#error DOS or EFI partition support must be selected +#endif + +uint64_t total_sector; +uint64_t part_offset; + +#define DOS_PART_MAGIC_OFFSET 0x1fe +#define DOS_FS_TYPE_OFFSET 0x36 +#define DOS_FS32_TYPE_OFFSET 0x52 + +static int do_ext4_load(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + char *filename = NULL; + char *ep; + int dev; + unsigned long part = 1; + ulong addr = 0; + ulong part_length; + int filelen; + disk_partition_t info; + struct ext_filesystem *fs; + char buf[12]; + unsigned long count; + const char *addr_str; + + count = 0; + addr = simple_strtoul(argv[3], NULL, 16); + filename = getenv("bootfile"); + switch (argc) { + case 3: + addr_str = getenv("loadaddr"); + if (addr_str != NULL) + addr = simple_strtoul(addr_str, NULL, 16); + else + addr = CONFIG_SYS_LOAD_ADDR; + + break; + case 4: + break; + case 5: + filename = argv[4]; + break; + case 6: + filename = argv[4]; + count = simple_strtoul(argv[5], NULL, 16); + break; + + default: + return cmd_usage(cmdtp); + } + + if (!filename) { + puts("** No boot file defined **\n"); + return 1; + } + + dev = (int)simple_strtoul(argv[2], &ep, 16); + ext4_dev_desc = get_dev(argv[1], dev); + if (ext4_dev_desc == NULL) { + printf("** Block device %s %d not supported\n", argv[1], dev); + return 1; + } + if (init_fs(ext4_dev_desc)) + return 1; + + fs = get_fs(); + if (*ep) { + if (*ep != ':') { + puts("** Invalid boot device, use `dev[:part]' **\n"); + return 1; + } + part = simple_strtoul(++ep, NULL, 16); + } + + if (part != 0) { + if (get_partition_info(fs->dev_desc, part, &info)) { + printf("** Bad partition %lu **\n", part); + return 1; + } + + if (strncmp((char *)info.type, BOOT_PART_TYPE, + strlen(BOOT_PART_TYPE)) != 0) { + printf("** Invalid partition type "%s"" + " (expect "" BOOT_PART_TYPE "")\n", info.type); + return 1; + } + printf("Loading file "%s" " + "from %s device %d:%lu %s\n", + filename, argv[1], dev, part, info.name); + } else { + printf("Loading file "%s" from %s device %d\n", + filename, argv[1], dev); + } + + part_length = ext4fs_set_blk_dev(fs->dev_desc, part); + if (part_length == 0) { + printf("**Bad partition - %s %d:%lu **\n", argv[1], dev, part); + ext4fs_close(); + return 1; + } + + if (!ext4fs_mount(part_length)) { + printf("** Bad ext2 partition or disk - %s %d:%lu **\n", + argv[1], dev, part); + ext4fs_close(); + return 1; + } + + filelen = ext4fs_open(filename); + if (filelen < 0) { + printf("** File not found %s\n", filename); + ext4fs_close(); + return 1; + } + if ((count < filelen) && (count != 0)) + filelen = count; + + if (ext4fs_read((char *)addr, filelen) != filelen) { + printf("** Unable to read "%s" from %s %d:%lu **\n", + filename, argv[1], dev, part); + ext4fs_close(); + return 1; + } + + ext4fs_close(); + deinit_fs(fs->dev_desc); + /* Loading ok, update default load address */ + load_addr = addr; + + printf("%d bytes read\n", filelen); + sprintf(buf, "%X", filelen); + setenv("filesize", buf); + + return 0; +} + +static int do_ext4_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + const char *filename = "/"; + int dev; + unsigned long part = 1; + char *ep; + struct ext_filesystem *fs; + int part_length; + + if (argc < 3) + return cmd_usage(cmdtp); + + dev = (int)simple_strtoul(argv[2], &ep, 16); + ext4_dev_desc = get_dev(argv[1], dev); + + if (ext4_dev_desc == NULL) { + printf("\n** Block device %s %d not supported\n", argv[1], dev); + return 1; + } + + if (init_fs(ext4_dev_desc)) + return 1; + + fs = get_fs(); + if (*ep) { + if (*ep != ':') { + puts("\n** Invalid boot device, use `dev[:part]' **\n"); + return 1; + } + part = simple_strtoul(++ep, NULL, 16); + } + + if (argc == 4) + filename = argv[3]; + + part_length = ext4fs_set_blk_dev(fs->dev_desc, part); + if (part_length == 0) { + printf("** Bad partition - %s %d:%lu **\n", argv[1], dev, part); + ext4fs_close(); + return 1; + } + + if (!ext4fs_mount(part_length)) { + printf("** Bad ext2 partition or disk - %s %d:%lu **\n", + argv[1], dev, part); + ext4fs_close(); + return 1; + } + if (ext4fs_ls(filename)) { + printf("** Error ext2fs_ls() **\n"); + ext4fs_close(); + return 1; + }; + + ext4fs_close(); + deinit_fs(fs->dev_desc); + + return 0; +} + +U_BOOT_CMD(ext4ls, 4, 1, do_ext4_ls, + "list files in a directory (default /)", + "<interface> <dev[:part]> [directory]\n" + " - list files from 'dev' on 'interface' in a 'directory'"); + +U_BOOT_CMD(ext4load, 6, 0, do_ext4_load, + "load binary file from a Ext2 filesystem", + "<interface> <dev[:part]> [addr] [filename] [bytes]\n" + " - load binary file 'filename' from 'dev' on 'interface'\n" + " to address 'addr' from ext2 filesystem"); diff --git a/fs/Makefile b/fs/Makefile index 22aad12..00a8f37 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -23,6 +23,7 @@ #
subdirs-$(CONFIG_CMD_CRAMFS) := cramfs +subdirs-$(CONFIG_CMD_EXT4) += ext4 subdirs-$(CONFIG_CMD_EXT2) += ext2 subdirs-$(CONFIG_CMD_FAT) += fat subdirs-$(CONFIG_CMD_FDOS) += fdos diff --git a/fs/ext2/dev.c b/fs/ext2/dev.c index 874e211..315ff53 100644 --- a/fs/ext2/dev.c +++ b/fs/ext2/dev.c @@ -27,6 +27,7 @@ #include <common.h> #include <config.h> #include <ext2fs.h> +#include <ext_common.h>
static block_dev_desc_t *ext2fs_block_dev_desc; static disk_partition_t part_info; diff --git a/fs/ext2/ext2fs.c b/fs/ext2/ext2fs.c index f621741..a4f3094 100644 --- a/fs/ext2/ext2fs.c +++ b/fs/ext2/ext2fs.c @@ -25,152 +25,16 @@
#include <common.h> #include <ext2fs.h> +#include <ext_common.h> #include <malloc.h> #include <asm/byteorder.h>
extern int ext2fs_devread (int sector, int byte_offset, int byte_len, char *buf);
-/* Magic value used to identify an ext2 filesystem. */ -#define EXT2_MAGIC 0xEF53 -/* Amount of indirect blocks in an inode. */ -#define INDIRECT_BLOCKS 12 -/* Maximum lenght of a pathname. */ -#define EXT2_PATH_MAX 4096 -/* Maximum nesting of symlinks, used to prevent a loop. */ -#define EXT2_MAX_SYMLINKCNT 8 - -/* Filetype used in directory entry. */ -#define FILETYPE_UNKNOWN 0 -#define FILETYPE_REG 1 -#define FILETYPE_DIRECTORY 2 -#define FILETYPE_SYMLINK 7 - -/* Filetype information as used in inodes. */ -#define FILETYPE_INO_MASK 0170000 -#define FILETYPE_INO_REG 0100000 -#define FILETYPE_INO_DIRECTORY 0040000 -#define FILETYPE_INO_SYMLINK 0120000 - -/* Bits used as offset in sector */ -#define DISK_SECTOR_BITS 9 - -/* Log2 size of ext2 block in 512 blocks. */ -#define LOG2_EXT2_BLOCK_SIZE(data) (__le32_to_cpu (data->sblock.log2_block_size) + 1) - -/* Log2 size of ext2 block in bytes. */ -#define LOG2_BLOCK_SIZE(data) (__le32_to_cpu (data->sblock.log2_block_size) + 10) - -/* The size of an ext2 block in bytes. */ -#define EXT2_BLOCK_SIZE(data) (1 << LOG2_BLOCK_SIZE(data)) - -/* The ext2 superblock. */ -struct ext2_sblock { - uint32_t total_inodes; - uint32_t total_blocks; - uint32_t reserved_blocks; - uint32_t free_blocks; - uint32_t free_inodes; - uint32_t first_data_block; - uint32_t log2_block_size; - uint32_t log2_fragment_size; - uint32_t blocks_per_group; - uint32_t fragments_per_group; - uint32_t inodes_per_group; - uint32_t mtime; - uint32_t utime; - uint16_t mnt_count; - uint16_t max_mnt_count; - uint16_t magic; - uint16_t fs_state; - uint16_t error_handling; - uint16_t minor_revision_level; - uint32_t lastcheck; - uint32_t checkinterval; - uint32_t creator_os; - uint32_t revision_level; - uint16_t uid_reserved; - uint16_t gid_reserved; - uint32_t first_inode; - uint16_t inode_size; - uint16_t block_group_number; - uint32_t feature_compatibility; - uint32_t feature_incompat; - uint32_t feature_ro_compat; - uint32_t unique_id[4]; - char volume_name[16]; - char last_mounted_on[64]; - uint32_t compression_info; -}; - -/* The ext2 blockgroup. */ -struct ext2_block_group { - uint32_t block_id; - uint32_t inode_id; - uint32_t inode_table_id; - uint16_t free_blocks; - uint16_t free_inodes; - uint16_t used_dir_cnt; - uint32_t reserved[3]; -}; - -/* The ext2 inode. */ -struct ext2_inode { - uint16_t mode; - uint16_t uid; - uint32_t size; - uint32_t atime; - uint32_t ctime; - uint32_t mtime; - uint32_t dtime; - uint16_t gid; - uint16_t nlinks; - uint32_t blockcnt; /* Blocks of 512 bytes!! */ - uint32_t flags; - uint32_t osd1; - union { - struct datablocks { - uint32_t dir_blocks[INDIRECT_BLOCKS]; - uint32_t indir_block; - uint32_t double_indir_block; - uint32_t tripple_indir_block; - } blocks; - char symlink[60]; - } b; - uint32_t version; - uint32_t acl; - uint32_t dir_acl; - uint32_t fragment_addr; - uint32_t osd2[3]; -}; - -/* The header of an ext2 directory entry. */ -struct ext2_dirent { - uint32_t inode; - uint16_t direntlen; - uint8_t namelen; - uint8_t filetype; -}; - -struct ext2fs_node { - struct ext2_data *data; - struct ext2_inode inode; - int ino; - int inode_read; -}; - -/* Information about a "mounted" ext2 filesystem. */ -struct ext2_data { - struct ext2_sblock sblock; - struct ext2_inode *inode; - struct ext2fs_node diropen; -}; - - -typedef struct ext2fs_node *ext2fs_node_t;
struct ext2_data *ext2fs_root = NULL; -ext2fs_node_t ext2fs_file = NULL; +struct ext2fs_node *ext2fs_file; int symlinknest = 0; uint32_t *indir1_block = NULL; int indir1_size = 0; @@ -243,14 +107,16 @@ static int ext2fs_read_inode }
-void ext2fs_free_node (ext2fs_node_t node, ext2fs_node_t currroot) { +void ext2fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot) +{ if ((node != &ext2fs_root->diropen) && (node != currroot)) { free (node); } }
-static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { +static int ext2fs_read_block(struct ext2fs_node *node, int fileblock) +{ struct ext2_data *data = node->data; struct ext2_inode *inode = &node->inode; int blknr; @@ -396,7 +262,8 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) {
int ext2fs_read_file - (ext2fs_node_t node, int pos, unsigned int len, char *buf) { + (struct ext2fs_node *node, int pos, unsigned int len, char *buf) +{ int i; int blockcnt; int log2blocksize = LOG2_EXT2_BLOCK_SIZE (node->data); @@ -455,8 +322,8 @@ int ext2fs_read_file return (len); }
- -static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fnode, int *ftype) +int ext2fs_iterate_dir(struct ext2fs_node *dir, char *name, + struct ext2fs_node **fnode, int *ftype) { unsigned int fpos = 0; int status; @@ -485,7 +352,7 @@ static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fn } if (dirent.namelen != 0) { char filename[dirent.namelen + 1]; - ext2fs_node_t fdiro; + struct ext2fs_node *fdiro; int type = FILETYPE_UNKNOWN;
status = ext2fs_read_file (diro, @@ -587,8 +454,8 @@ static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fn return (0); }
- -static char *ext2fs_read_symlink (ext2fs_node_t node) { +static char *ext2fs_read_symlink(struct ext2fs_node *node) +{ char *symlink; struct ext2fs_node *diro = node; int status; @@ -625,15 +492,16 @@ static char *ext2fs_read_symlink (ext2fs_node_t node) {
int ext2fs_find_file1 - (const char *currpath, - ext2fs_node_t currroot, ext2fs_node_t * currfound, int *foundtype) { + (const char *currpath, struct ext2fs_node *currroot, + struct ext2fs_node **currfound, int *foundtype) +{ char fpath[strlen (currpath) + 1]; char *name = fpath; char *next; int status; int type = FILETYPE_DIRECTORY; - ext2fs_node_t currnode = currroot; - ext2fs_node_t oldnode = currroot; + struct ext2fs_node *currnode = currroot; + struct ext2fs_node *oldnode = currroot;
strncpy (fpath, currpath, strlen (currpath) + 1);
@@ -729,8 +597,9 @@ int ext2fs_find_file1
int ext2fs_find_file - (const char *path, - ext2fs_node_t rootnode, ext2fs_node_t * foundnode, int expecttype) { + (const char *path, struct ext2fs_node *rootnode, + struct ext2fs_node **foundnode, int expecttype) +{ int status; int foundtype = FILETYPE_DIRECTORY;
@@ -756,7 +625,7 @@ int ext2fs_find_file
int ext2fs_ls (const char *dirname) { - ext2fs_node_t dirnode; + struct ext2fs_node *dirnode; int status;
if (ext2fs_root == NULL) { @@ -776,7 +645,7 @@ int ext2fs_ls (const char *dirname) {
int ext2fs_open (const char *filename) { - ext2fs_node_t fdiro = NULL; + struct ext2fs_node *fdiro = NULL; int status; int len;
@@ -806,8 +675,8 @@ fail: }
-int ext2fs_close (void - ) { +int ext2fs_close(void) +{ if ((ext2fs_file != NULL) && (ext2fs_root != NULL)) { ext2fs_free_node (ext2fs_file, &ext2fs_root->diropen); ext2fs_file = NULL; diff --git a/fs/ext4/Makefile b/fs/ext4/Makefile new file mode 100644 index 0000000..7add4ab --- /dev/null +++ b/fs/ext4/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2003 +# Pavel Bartusek, Sysgo Real-Time Solutions AG, pba@sysgo.de +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)libext4fs.o + +AOBJS = +COBJS-$(CONFIG_CMD_EXT4) := ext4fs.o ext4_common.o dev.o + +SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) + + +all: $(LIB) $(AOBJS) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/fs/ext4/dev.c b/fs/ext4/dev.c new file mode 100644 index 0000000..2054be3 --- /dev/null +++ b/fs/ext4/dev.c @@ -0,0 +1,145 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * made from existing ext2/dev.c file of Uboot + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code of fs/reiserfs/dev.c by + * + * (C) Copyright 2003 - 2004 + * Sysgo AG, <www.elinos.com>, Pavel Bartusek pba@sysgo.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * + */ + +/* + * Changelog: + * 0.1 - Newly created file for ext4fs support. Taken from + * fs/ext2/dev.c file in uboot. + */ + +#include <common.h> +#include <config.h> +#include <ext_common.h> + +static block_dev_desc_t *ext4fs_block_dev_desc; +static disk_partition_t part_info; + +int ext4fs_set_blk_dev(block_dev_desc_t *rbdd, int part) +{ + ext4fs_block_dev_desc = rbdd; + + if (part == 0) { + /* disk doesn't use partition table */ + part_info.start = 0; + part_info.size = rbdd->lba; + part_info.blksz = rbdd->blksz; + } else { + if (get_partition_info(ext4fs_block_dev_desc, + part, &part_info)) + return 0; + } + return part_info.size; +} + +int ext4fs_devread(int sector, int byte_offset, int byte_len, char *buf) +{ + char sec_buf[SECTOR_SIZE]; + unsigned block_len; + + /* Check partition boundaries */ + if ((sector < 0) + || ((sector + ((byte_offset + byte_len - 1) >> SECTOR_BITS)) >= + part_info.size)) { + printf("%s read outside partition %d\n", __func__, sector); + return 0; + } + + /* Get the read to the beginning of a partition */ + sector += byte_offset >> SECTOR_BITS; + byte_offset &= SECTOR_SIZE - 1; + + debug(" <%d, %d, %d>\n", sector, byte_offset, byte_len); + + if (ext4fs_block_dev_desc == NULL) { + printf("** Invalid Block Device Descriptor (NULL)\n"); + return 0; + } + + if (byte_offset != 0) { + /* read first part which isn't aligned with start of sector */ + if (ext4fs_block_dev_desc-> + block_read(ext4fs_block_dev_desc->dev, + part_info.start + sector, 1, + (unsigned long *) sec_buf) != 1) { + printf(" ** ext2fs_devread() read error **\n"); + return 0; + } + memcpy(buf, sec_buf + byte_offset, + min(SECTOR_SIZE - byte_offset, byte_len)); + buf += min(SECTOR_SIZE - byte_offset, byte_len); + byte_len -= min(SECTOR_SIZE - byte_offset, byte_len); + sector++; + } + + if (byte_len == 0) + return 1; + + /* read sector aligned part */ + block_len = byte_len & ~(SECTOR_SIZE - 1); + + if (block_len == 0) { + u8 p[SECTOR_SIZE]; + + block_len = SECTOR_SIZE; + ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc->dev, + part_info.start + sector, + 1, (unsigned long *)p); + memcpy(buf, p, byte_len); + return 1; + } + + if (ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc->dev, + part_info.start + sector, + block_len / SECTOR_SIZE, + (unsigned long *) buf) != + block_len / SECTOR_SIZE) { + printf(" ** %s read error - block\n", __func__); + return 0; + } + block_len = byte_len & ~(SECTOR_SIZE - 1); + buf += block_len; + byte_len -= block_len; + sector += block_len / SECTOR_SIZE; + + if (byte_len != 0) { + /* read rest of data which are not in whole sector */ + if (ext4fs_block_dev_desc-> + block_read(ext4fs_block_dev_desc->dev, + part_info.start + sector, 1, + (unsigned long *) sec_buf) != 1) { + printf("* %s read error - last part\n", __func__); + return 0; + } + memcpy(buf, sec_buf, byte_len); + } + return 1; +} diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c new file mode 100644 index 0000000..d9deefe --- /dev/null +++ b/fs/ext4/ext4_common.c @@ -0,0 +1,875 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * ext4ls and ext4load : Based on ext2 ls load support in Uboot. + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code from grub2 fs/ext2.c and fs/fshelp.c by + * GRUB -- GRand Unified Bootloader + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <malloc.h> +#include <stddef.h> +#include <linux/stat.h> +#include <linux/time.h> +#include <asm/byteorder.h> +#include "ext4_common.h" + +struct ext2_data *ext4fs_root; +struct ext2fs_node *ext4fs_file; +uint32_t *ext4fs_indir1_block; +int ext4fs_indir1_size; +int ext4fs_indir1_blkno = -1; +uint32_t *ext4fs_indir2_block; +int ext4fs_indir2_size; +int ext4fs_indir2_blkno = -1; + +uint32_t *ext4fs_indir3_block; +int ext4fs_indir3_size; +int ext4fs_indir3_blkno = -1; +struct ext2_inode *g_parent_inode; +static int symlinknest; + +static struct ext4_extent_header *ext4fs_get_extent_block + (struct ext2_data *data, char *buf, + struct ext4_extent_header *ext_block, + uint32_t fileblock, int log2_blksz) +{ + struct ext4_extent_idx *index; + unsigned long long block; + struct ext_filesystem *fs = get_fs(); + int i; + + while (1) { + index = (struct ext4_extent_idx *)(ext_block + 1); + + if (le32_to_cpu(ext_block->eh_magic) != EXT4_EXT_MAGIC) + return 0; + + if (ext_block->eh_depth == 0) + return ext_block; + i = -1; + do { + i++; + if (i >= le32_to_cpu(ext_block->eh_entries)) + break; + } while (fileblock > le32_to_cpu(index[i].ei_block)); + + if (--i < 0) + return 0; + + block = le32_to_cpu(index[i].ei_leaf_hi); + block = (block << 32) + le32_to_cpu(index[i].ei_leaf_lo); + + if (ext4fs_devread(block << log2_blksz, 0, fs->blksz, buf)) + ext_block = (struct ext4_extent_header *)buf; + else + return 0; + } +} + +static int ext4fs_blockgroup + (struct ext2_data *data, int group, struct ext2_block_group *blkgrp) +{ + long int blkno; + unsigned int blkoff, desc_per_blk; + + desc_per_blk = EXT2_BLOCK_SIZE(data) / sizeof(struct ext2_block_group); + + blkno = __le32_to_cpu(data->sblock.first_data_block) + 1 + + group / desc_per_blk; + blkoff = (group % desc_per_blk) * sizeof(struct ext2_block_group); + + debug("ext4fs read %d group descriptor (blkno %ld blkoff %u)\n", + group, blkno, blkoff); + + return ext4fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data), + blkoff, sizeof(struct ext2_block_group), + (char *)blkgrp); +} + +int ext4fs_read_inode(struct ext2_data *data, int ino, struct ext2_inode *inode) +{ + struct ext2_block_group blkgrp; + struct ext2_sblock *sblock = &data->sblock; + struct ext_filesystem *fs = get_fs(); + int inodes_per_block, status; + long int blkno; + unsigned int blkoff; + + /* It is easier to calculate if the first inode is 0. */ + ino--; + status = ext4fs_blockgroup(data, ino / __le32_to_cpu + (sblock->inodes_per_group), &blkgrp); + if (status == 0) + return 0; + + inodes_per_block = EXT2_BLOCK_SIZE(data) / fs->inodesz; + blkno = __le32_to_cpu(blkgrp.inode_table_id) + + (ino % __le32_to_cpu(sblock->inodes_per_group)) / inodes_per_block; + blkoff = (ino % inodes_per_block) * fs->inodesz; + /* Read the inode. */ + status = ext4fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data), blkoff, + sizeof(struct ext2_inode), (char *)inode); + if (status == 0) + return 0; + + return 1; +} + +long int read_allocated_block(struct ext2_inode *inode, int fileblock) +{ + long int blknr; + int blksz; + int log2_blksz; + int status; + long int rblock; + long int perblock_parent; + long int perblock_child; + unsigned long long start; + /* get the blocksize of the filesystem */ + blksz = EXT2_BLOCK_SIZE(ext4fs_root); + log2_blksz = LOG2_EXT2_BLOCK_SIZE(ext4fs_root); + if (le32_to_cpu(inode->flags) & EXT4_EXTENTS_FL) { + char *buf = zalloc(blksz); + if (!buf) + return -ENOMEM; + struct ext4_extent_header *ext_block; + struct ext4_extent *extent; + int i = -1; + ext_block = ext4fs_get_extent_block(ext4fs_root, buf, + (struct ext4_extent_header + *)inode->b. + blocks.dir_blocks, + fileblock, log2_blksz); + if (!ext_block) { + printf("invalid extent block\n"); + free(buf); + return -EINVAL; + } + + extent = (struct ext4_extent *)(ext_block + 1); + + do { + i++; + if (i >= le32_to_cpu(ext_block->eh_entries)) + break; + } while (fileblock >= le32_to_cpu(extent[i].ee_block)); + if (--i >= 0) { + fileblock -= le32_to_cpu(extent[i].ee_block); + if (fileblock >= le32_to_cpu(extent[i].ee_len)) { + free(buf); + return 0; + } + + start = le32_to_cpu(extent[i].ee_start_hi); + start = (start << 32) + + le32_to_cpu(extent[i].ee_start_lo); + free(buf); + return fileblock + start; + } + + printf("Extent Error\n"); + free(buf); + return -1; + } + + /* Direct blocks. */ + if (fileblock < INDIRECT_BLOCKS) + blknr = __le32_to_cpu(inode->b.blocks.dir_blocks[fileblock]); + + /* Indirect. */ + else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4))) { + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** SI ext2fs read block (indir 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** SI ext2fs read block (indir 1):" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = + ext4fs_devread(__le32_to_cpu + (inode->b.blocks. + indir_block) << log2_blksz, 0, + blksz, (char *)ext4fs_indir1_block); + if (status == 0) { + printf("** SI ext2fs read block (indir 1)" + "failed. **\n"); + return 0; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks. + indir_block) << log2_blksz; + } + blknr = __le32_to_cpu(ext4fs_indir1_block + [fileblock - INDIRECT_BLOCKS]); + } + /* Double indirect. */ + else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4 * + (blksz / 4 + 1)))) { + + long int perblock = blksz / 4; + long int rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4); + + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** DI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** DI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.double_indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = + ext4fs_devread(__le32_to_cpu + (inode->b.blocks. + double_indir_block) << log2_blksz, + 0, blksz, + (char *)ext4fs_indir1_block); + if (status == 0) { + printf("** DI ext2fs read block (indir 2 1)" + "failed. **\n"); + return -1; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks.double_indir_block) << + log2_blksz; + } + + if (ext4fs_indir2_block == NULL) { + ext4fs_indir2_block = zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** DI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + ext4fs_indir2_blkno = -1; + } + if (blksz != ext4fs_indir2_size) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + ext4fs_indir2_block = zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** DI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir1_block[rblock / perblock]) << + log2_blksz) != ext4fs_indir2_blkno) { + status = ext4fs_devread(__le32_to_cpu + (ext4fs_indir1_block + [rblock / + perblock]) << log2_blksz, 0, + blksz, + (char *)ext4fs_indir2_block); + if (status == 0) { + printf("** DI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir2_blkno = + __le32_to_cpu(ext4fs_indir1_block[rblock + / + perblock]) << + log2_blksz; + } + blknr = __le32_to_cpu(ext4fs_indir2_block[rblock % perblock]); + } + /* Tripple indirect. */ + else { + rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4 + + (blksz / 4 * blksz / 4)); + perblock_child = blksz / 4; + perblock_parent = ((blksz / 4) * (blksz / 4)); + + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** TI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** TI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.triple_indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = ext4fs_devread + (__le32_to_cpu(inode->b.blocks.triple_indir_block) + << log2_blksz, 0, blksz, + (char *)ext4fs_indir1_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 1)" + "failed. **\n"); + return -1; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks.triple_indir_block) << + log2_blksz; + } + + if (ext4fs_indir2_block == NULL) { + ext4fs_indir2_block = zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + ext4fs_indir2_blkno = -1; + } + if (blksz != ext4fs_indir2_size) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + ext4fs_indir2_block = zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir1_block[rblock / + perblock_parent]) << + log2_blksz) + != ext4fs_indir2_blkno) { + status = ext4fs_devread(__le32_to_cpu + (ext4fs_indir1_block + [rblock / + perblock_parent]) << + log2_blksz, 0, blksz, + (char *)ext4fs_indir2_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir2_blkno = + __le32_to_cpu(ext4fs_indir1_block[rblock / + perblock_parent]) + << log2_blksz; + } + + if (ext4fs_indir3_block == NULL) { + ext4fs_indir3_block = zalloc(blksz); + if (ext4fs_indir3_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir3_size = blksz; + ext4fs_indir3_blkno = -1; + } + if (blksz != ext4fs_indir3_size) { + free(ext4fs_indir3_block); + ext4fs_indir3_block = NULL; + ext4fs_indir3_size = 0; + ext4fs_indir3_blkno = -1; + ext4fs_indir3_block = zalloc(blksz); + if (ext4fs_indir3_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir3_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir2_block[rblock + / + perblock_child]) << + log2_blksz) != ext4fs_indir3_blkno) { + status = + ext4fs_devread(__le32_to_cpu + (ext4fs_indir2_block + [(rblock / perblock_child) + % (blksz / 4)]) << log2_blksz, 0, + blksz, (char *)ext4fs_indir3_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir3_blkno = + __le32_to_cpu(ext4fs_indir2_block[(rblock / + perblock_child) % + (blksz / + 4)]) << + log2_blksz; + } + + blknr = __le32_to_cpu(ext4fs_indir3_block + [rblock % perblock_child]); + } + debug("ext4fs_read_block %ld\n", blknr); + + return blknr; +} + +void ext4fs_close(void) +{ + if ((ext4fs_file != NULL) && (ext4fs_root != NULL)) { + ext4fs_free_node(ext4fs_file, &ext4fs_root->diropen); + ext4fs_file = NULL; + } + if (ext4fs_root != NULL) { + free(ext4fs_root); + ext4fs_root = NULL; + } + if (ext4fs_indir1_block != NULL) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + } + if (ext4fs_indir2_block != NULL) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + } + if (ext4fs_indir3_block != NULL) { + free(ext4fs_indir3_block); + ext4fs_indir3_block = NULL; + ext4fs_indir3_size = 0; + ext4fs_indir3_blkno = -1; + } +} + +int ext4fs_iterate_dir(struct ext2fs_node *dir, char *name, + struct ext2fs_node **fnode, int *ftype) +{ + unsigned int fpos = 0; + int status; + struct ext2fs_node *diro = (struct ext2fs_node *)dir; + +#ifdef DEBUG + if (name != NULL) + printf("Iterate dir %s\n", name); +#endif /* of DEBUG */ + if (!diro->inode_read) { + status = ext4fs_read_inode(diro->data, diro->ino, &diro->inode); + if (status == 0) + return 0; + } + /* Search the file. */ + while (fpos < __le32_to_cpu(diro->inode.size)) { + struct ext2_dirent dirent; + + status = ext4fs_read_file(diro, fpos, + sizeof(struct ext2_dirent), + (char *)&dirent); + if (status < 1) + return 0; + + if (dirent.namelen != 0) { + char filename[dirent.namelen + 1]; + struct ext2fs_node *fdiro; + int type = FILETYPE_UNKNOWN; + + status = ext4fs_read_file(diro, + fpos + + sizeof(struct ext2_dirent), + dirent.namelen, filename); + if (status < 1) + return 0; + + fdiro = zalloc(sizeof(struct ext2fs_node)); + if (!fdiro) + return 0; + + fdiro->data = diro->data; + fdiro->ino = __le32_to_cpu(dirent.inode); + + filename[dirent.namelen] = '\0'; + + if (dirent.filetype != FILETYPE_UNKNOWN) { + fdiro->inode_read = 0; + + if (dirent.filetype == FILETYPE_DIRECTORY) + type = FILETYPE_DIRECTORY; + else if (dirent.filetype == FILETYPE_SYMLINK) + type = FILETYPE_SYMLINK; + else if (dirent.filetype == FILETYPE_REG) + type = FILETYPE_REG; + } else { + status = ext4fs_read_inode(diro->data, + __le32_to_cpu + (dirent.inode), + &fdiro->inode); + if (status == 0) { + free(fdiro); + return 0; + } + fdiro->inode_read = 1; + + if ((__le16_to_cpu(fdiro->inode.mode) & + FILETYPE_INO_MASK) == + FILETYPE_INO_DIRECTORY) { + type = FILETYPE_DIRECTORY; + } else if ((__le16_to_cpu(fdiro->inode.mode) + & FILETYPE_INO_MASK) == + FILETYPE_INO_SYMLINK) { + type = FILETYPE_SYMLINK; + } else if ((__le16_to_cpu(fdiro->inode.mode) + & FILETYPE_INO_MASK) == + FILETYPE_INO_REG) { + type = FILETYPE_REG; + } + } +#ifdef DEBUG + printf("iterate >%s<\n", filename); +#endif /* of DEBUG */ + if ((name != NULL) && (fnode != NULL) + && (ftype != NULL)) { + if (strcmp(filename, name) == 0) { + *ftype = type; + *fnode = fdiro; + return 1; + } + } else { + if (fdiro->inode_read == 0) { + status = ext4fs_read_inode(diro->data, + __le32_to_cpu( + dirent.inode), + &fdiro->inode); + if (status == 0) { + free(fdiro); + return 0; + } + fdiro->inode_read = 1; + } + switch (type) { + case FILETYPE_DIRECTORY: + printf("<DIR> "); + break; + case FILETYPE_SYMLINK: + printf("<SYM> "); + break; + case FILETYPE_REG: + printf(" "); + break; + default: + printf("< ? > "); + break; + } + printf("%10d %s\n", + __le32_to_cpu(fdiro->inode.size), + filename); + } + free(fdiro); + } + fpos += __le16_to_cpu(dirent.direntlen); + } + return 0; +} + +static char *ext4fs_read_symlink(struct ext2fs_node *node) +{ + char *symlink; + struct ext2fs_node *diro = node; + int status; + + if (!diro->inode_read) { + status = ext4fs_read_inode(diro->data, diro->ino, &diro->inode); + if (status == 0) + return 0; + } + symlink = zalloc(__le32_to_cpu(diro->inode.size) + 1); + if (!symlink) + return 0; + + if (__le32_to_cpu(diro->inode.size) <= 60) { + strncpy(symlink, diro->inode.b.symlink, + __le32_to_cpu(diro->inode.size)); + } else { + status = ext4fs_read_file(diro, 0, + __le32_to_cpu(diro->inode.size), + symlink); + if (status == 0) { + free(symlink); + return 0; + } + } + symlink[__le32_to_cpu(diro->inode.size)] = '\0'; + return symlink; +} + +static int ext4fs_find_file1(const char *currpath, + struct ext2fs_node *currroot, + struct ext2fs_node **currfound, int *foundtype) +{ + char fpath[strlen(currpath) + 1]; + char *name = fpath; + char *next; + int status; + int type = FILETYPE_DIRECTORY; + struct ext2fs_node *currnode = currroot; + struct ext2fs_node *oldnode = currroot; + + strncpy(fpath, currpath, strlen(currpath) + 1); + + /* Remove all leading slashes. */ + while (*name == '/') + name++; + + if (!*name) { + *currfound = currnode; + return 1; + } + + for (;;) { + int found; + + /* Extract the actual part from the pathname. */ + next = strchr(name, '/'); + if (next) { + /* Remove all leading slashes. */ + while (*next == '/') + *(next++) = '\0'; + } + + if (type != FILETYPE_DIRECTORY) { + ext4fs_free_node(currnode, currroot); + return 0; + } + + oldnode = currnode; + + /* Iterate over the directory. */ + found = ext4fs_iterate_dir(currnode, name, &currnode, &type); + if (found == 0) + return 0; + + if (found == -1) + break; + + /* Read in the symlink and follow it. */ + if (type == FILETYPE_SYMLINK) { + char *symlink; + + /* Test if the symlink does not loop. */ + if (++symlinknest == 8) { + ext4fs_free_node(currnode, currroot); + ext4fs_free_node(oldnode, currroot); + return 0; + } + + symlink = ext4fs_read_symlink(currnode); + ext4fs_free_node(currnode, currroot); + + if (!symlink) { + ext4fs_free_node(oldnode, currroot); + return 0; + } + + debug("Got symlink >%s<\n", symlink); + + if (symlink[0] == '/') { + ext4fs_free_node(oldnode, currroot); + oldnode = &ext4fs_root->diropen; + } + + /* Lookup the node the symlink points to. */ + status = ext4fs_find_file1(symlink, oldnode, + &currnode, &type); + + free(symlink); + + if (status == 0) { + ext4fs_free_node(oldnode, currroot); + return 0; + } + } + + ext4fs_free_node(oldnode, currroot); + + /* Found the node! */ + if (!next || *next == '\0') { + *currfound = currnode; + *foundtype = type; + return 1; + } + name = next; + } + return -1; +} + +int ext4fs_find_file(const char *path, struct ext2fs_node *rootnode, + struct ext2fs_node **foundnode, int expecttype) +{ + int status; + int foundtype = FILETYPE_DIRECTORY; + + symlinknest = 0; + if (!path) + return 0; + + status = ext4fs_find_file1(path, rootnode, foundnode, &foundtype); + if (status == 0) + return 0; + + /* Check if the node that was found was of the expected type. */ + if ((expecttype == FILETYPE_REG) && (foundtype != expecttype)) + return 0; + else if ((expecttype == FILETYPE_DIRECTORY) + && (foundtype != expecttype)) + return 0; + + return 1; +} + +int ext4fs_open(const char *filename) +{ + struct ext2fs_node *fdiro = NULL; + int status; + int len; + + if (ext4fs_root == NULL) + return -1; + + ext4fs_file = NULL; + status = ext4fs_find_file(filename, &ext4fs_root->diropen, &fdiro, + FILETYPE_REG); + if (status == 0) + goto fail; + + if (!fdiro->inode_read) { + status = ext4fs_read_inode(fdiro->data, fdiro->ino, + &fdiro->inode); + if (status == 0) + goto fail; + } + len = __le32_to_cpu(fdiro->inode.size); + ext4fs_file = fdiro; + + return len; + fail: + ext4fs_free_node(fdiro, &ext4fs_root->diropen); + + return -1; +} + +int ext4fs_mount(unsigned part_length) +{ + struct ext2_data *data; + int status; + struct ext_filesystem *fs = get_fs(); + data = zalloc(sizeof(struct ext2_data)); + if (!data) + return 0; + + /* Read the superblock. */ + status = ext4fs_devread(1 * 2, 0, sizeof(struct ext2_sblock), + (char *)&data->sblock); + + if (status == 0) + goto fail; + + /* Make sure this is an ext2 filesystem. */ + if (__le16_to_cpu(data->sblock.magic) != EXT2_MAGIC) + goto fail; + + if (__le32_to_cpu(data->sblock.revision_level == 0)) + fs->inodesz = 128; + else + fs->inodesz = __le16_to_cpu(data->sblock.inode_size); + + debug("EXT2 rev %d, inode_size %d\n", + __le32_to_cpu(data->sblock.revision_level), fs->inodesz); + + data->diropen.data = data; + data->diropen.ino = 2; + data->diropen.inode_read = 1; + data->inode = &data->diropen.inode; + + status = ext4fs_read_inode(data, 2, data->inode); + if (status == 0) + goto fail; + + ext4fs_root = data; + + return 1; + fail: + printf("Failed to mount ext2 filesystem...\n"); + free(data); + ext4fs_root = NULL; + + return 0; +} diff --git a/fs/ext4/ext4_common.h b/fs/ext4/ext4_common.h new file mode 100644 index 0000000..182049d --- /dev/null +++ b/fs/ext4/ext4_common.h @@ -0,0 +1,63 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * ext4ls and ext4load : based on ext2 ls load support in Uboot. + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code from grub2 fs/ext2.c and fs/fshelp.c by + * GRUB -- GRand Unified Bootloader + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __EXT4_COMMON__ +#define __EXT4_COMMON__ +#include <ext_common.h> +#include <ext4fs.h> +#include <malloc.h> +#include <asm/errno.h> + +#define YES 1 +#define NO 0 +#define TRUE 1 +#define FALSE 0 +#define RECOVER 1 +#define SCAN 0 + +#define S_IFLNK 0120000 /* symbolic link */ +#define BLOCK_NO_ONE 1 +#define SUPERBLOCK_SECTOR 2 +#define SUPERBLOCK_SIZE 1024 +#define F_FILE 1 + +#define zalloc(size) calloc(1, size) + +extern unsigned long part_offset; +int ext4fs_read_inode(struct ext2_data *data, int ino, + struct ext2_inode *inode); +int ext4fs_read_file(struct ext2fs_node *node, int pos, + unsigned int len, char *buf); +int ext4fs_find_file(const char *path, struct ext2fs_node *rootnode, + struct ext2fs_node **foundnode, int expecttype); +int ext4fs_iterate_dir(struct ext2fs_node *dir, char *name, + struct ext2fs_node **fnode, int *ftype); +#endif diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c new file mode 100644 index 0000000..7933769 --- /dev/null +++ b/fs/ext4/ext4fs.c @@ -0,0 +1,228 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * ext4ls and ext4load : Based on ext2 ls and load support in Uboot. + * Ext4 read optimization taken from Open-Moko + * Qi bootloader + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code from grub2 fs/ext2.c and fs/fshelp.c by + * GRUB -- GRand Unified Bootloader + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <malloc.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <linux/stat.h> +#include <linux/time.h> +#include <asm/byteorder.h> +#include "ext4_common.h" + +int ext4fs_symlinknest; +block_dev_desc_t *ext4_dev_desc; + +struct ext_filesystem *get_fs(void) +{ + if (ext4_dev_desc == NULL || ext4_dev_desc->priv == NULL) + printf("Invalid Input Arguments %s\n", __func__); + + return ext4_dev_desc->priv; +} + +int init_fs(block_dev_desc_t *dev_desc) +{ + struct ext_filesystem *fs; + if (dev_desc == NULL) { + printf("Invalid Input Arguments %s\n", __func__); + return -EINVAL; + } + + fs = zalloc(sizeof(struct ext_filesystem)); + if (fs == NULL) { + printf("malloc failed: %s\n", __func__); + return -ENOMEM; + } + + fs->dev_desc = dev_desc; + dev_desc->priv = fs; + + return 0; +} + +void deinit_fs(block_dev_desc_t *dev_desc) +{ + if (dev_desc == NULL) { + printf("Invalid Input Arguments %s\n", __func__); + return; + } + free(dev_desc->priv); + dev_desc->priv = NULL; +} + +void ext4fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot) +{ + if ((node != &ext4fs_root->diropen) && (node != currroot)) + free(node); +} + +/* + * Taken from openmoko-kernel mailing list: By Andy green + * Optimized read file API : collects and defers contiguous sector + * reads into one potentially more efficient larger sequential read action + */ +int ext4fs_read_file(struct ext2fs_node *node, int pos, + unsigned int len, char *buf) +{ + int i; + int blockcnt; + int log2blocksize = LOG2_EXT2_BLOCK_SIZE(node->data); + int blocksize = 1 << (log2blocksize + DISK_SECTOR_BITS); + unsigned int filesize = __le32_to_cpu(node->inode.size); + int previous_block_number = -1; + int delayed_start = 0; + int delayed_extent = 0; + int delayed_skipfirst = 0; + int delayed_next = 0; + char *delayed_buf = NULL; + short status; + + /* Adjust len so it we can't read past the end of the file. */ + if (len > filesize) + len = filesize; + + blockcnt = ((len + pos) + blocksize - 1) / blocksize; + + for (i = pos / blocksize; i < blockcnt; i++) { + int blknr; + int blockoff = pos % blocksize; + int blockend = blocksize; + int skipfirst = 0; + blknr = read_allocated_block(&(node->inode), i); + if (blknr < 0) + return -1; + + blknr = blknr << log2blocksize; + + /* Last block. */ + if (i == blockcnt - 1) { + blockend = (len + pos) % blocksize; + + /* The last portion is exactly blocksize. */ + if (!blockend) + blockend = blocksize; + } + + /* First block. */ + if (i == pos / blocksize) { + skipfirst = blockoff; + blockend -= skipfirst; + } + if (blknr) { + int status; + + if (previous_block_number != -1) { + if (delayed_next == blknr) { + delayed_extent += blockend; + delayed_next += blockend >> SECTOR_BITS; + } else { /* spill */ + status = ext4fs_devread(delayed_start, + delayed_skipfirst, + delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = blknr; + delayed_start = blknr; + delayed_extent = blockend; + delayed_skipfirst = skipfirst; + delayed_buf = buf; + delayed_next = blknr + + (blockend >> SECTOR_BITS); + } + } else { + previous_block_number = blknr; + delayed_start = blknr; + delayed_extent = blockend; + delayed_skipfirst = skipfirst; + delayed_buf = buf; + delayed_next = blknr + + (blockend >> SECTOR_BITS); + } + } else { + if (previous_block_number != -1) { + /* spill */ + status = ext4fs_devread(delayed_start, + delayed_skipfirst, + delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = -1; + } + memset(buf, 0, blocksize - skipfirst); + } + buf += blocksize - skipfirst; + } + if (previous_block_number != -1) { + /* spill */ + status = ext4fs_devread(delayed_start, + delayed_skipfirst, delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = -1; + } + + return len; +} + +int ext4fs_ls(const char *dirname) +{ + struct ext2fs_node *dirnode; + int status; + + if (dirname == NULL) + return 0; + + status = ext4fs_find_file(dirname, &ext4fs_root->diropen, &dirnode, + FILETYPE_DIRECTORY); + if (status != 1) { + printf("** Can not find directory. **\n"); + return 1; + } + + ext4fs_iterate_dir(dirnode, NULL, NULL, NULL); + ext4fs_free_node(dirnode, &ext4fs_root->diropen); + + return 0; +} + +int ext4fs_read(char *buf, unsigned len) +{ + if (ext4fs_root == NULL || ext4fs_file == NULL) + return 0; + + return ext4fs_read_file(ext4fs_file, 0, len, buf); +} diff --git a/include/ext4fs.h b/include/ext4fs.h new file mode 100644 index 0000000..55f9ccc --- /dev/null +++ b/include/ext4fs.h @@ -0,0 +1,132 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Ext4 Extent data structures are taken from original ext4 fs code + * as found in the linux kernel. + * + * Copyright (c) 2003-2006, Cluster File Systems, Inc, info@clusterfs.com + * Written by Alex Tomas alex@clusterfs.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __EXT4__ +#define __EXT4__ +#include <ext_common.h> + +#define EXT4_EXTENTS_FL 0x00080000 /* Inode uses extents */ +#define EXT4_EXT_MAGIC 0xf30a +#define EXT4_FEATURE_RO_COMPAT_GDT_CSUM 0x0010 +#define EXT4_FEATURE_INCOMPAT_EXTENTS 0x0040 +#define EXT4_INDIRECT_BLOCKS 12 + +#define EXT4_BG_INODE_UNINIT 0x0001 +#define EXT4_BG_BLOCK_UNINIT 0x0002 +#define EXT4_BG_INODE_ZEROED 0x0004 + +/* + * ext4_inode has i_block array (60 bytes total). + * The first 12 bytes store ext4_extent_header; + * the remainder stores an array of ext4_extent. + */ + +/* + * This is the extent on-disk structure. + * It's used at the bottom of the tree. + */ +struct ext4_extent { + __le32 ee_block; /* first logical block extent covers */ + __le16 ee_len; /* number of blocks covered by extent */ + __le16 ee_start_hi; /* high 16 bits of physical block */ + __le32 ee_start_lo; /* low 32 bits of physical block */ +}; + +/* + * This is index on-disk structure. + * It's used at all the levels except the bottom. + */ +struct ext4_extent_idx { + __le32 ei_block; /* index covers logical blocks from 'block' */ + __le32 ei_leaf_lo; /* pointer to the physical block of the next * + * level. leaf or next index could be there */ + __le16 ei_leaf_hi; /* high 16 bits of physical block */ + __u16 ei_unused; +}; + +/* Each block (leaves and indexes), even inode-stored has header. */ +struct ext4_extent_header { + __le16 eh_magic; /* probably will support different formats */ + __le16 eh_entries; /* number of valid entries */ + __le16 eh_max; /* capacity of store in entries */ + __le16 eh_depth; /* has tree real underlying blocks? */ + __le32 eh_generation; /* generation of the tree */ +}; + +struct ext_filesystem { + /* Total Sector of partition */ + uint64_t total_sect; + /* Block size of partition */ + uint32_t blksz; + /* Inode size of partition */ + uint32_t inodesz; + /* Sectors per Block */ + uint32_t sect_perblk; + /* Group Descriptor Block Number */ + uint32_t gdtable_blkno; + /* Total block groups of partition */ + uint32_t no_blkgrp; + /* No of blocks required for bgdtable */ + uint32_t no_blk_pergdt; + /* Superblock */ + struct ext2_sblock *sb; + /* Block group descritpor table */ + struct ext2_block_group *gd; + char *gdtable; + + /* Block Bitmap Related */ + unsigned char **blk_bmaps; + long int curr_blkno; + uint16_t first_pass_bbmap; + + /* Inode Bitmap Related */ + unsigned char **inode_bmaps; + int curr_inode_no; + uint16_t first_pass_ibmap; + + /* Journal Related */ + + /* Block Device Descriptor */ + block_dev_desc_t *dev_desc; +}; + +extern block_dev_desc_t *ext4_dev_desc; +extern struct ext2_data *ext4fs_root; +extern struct ext2fs_node *ext4fs_file; + +struct ext_filesystem *get_fs(void); +int init_fs(block_dev_desc_t *dev_desc); +void deinit_fs(block_dev_desc_t *dev_desc); +int ext4fs_open(const char *filename); +int ext4fs_read(char *buf, unsigned len); +int ext4fs_mount(unsigned part_length); +void ext4fs_close(void); +int ext4fs_ls(const char *dirname); +void ext4fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot); +int ext4fs_devread(int sector, int byte_offset, int byte_len, char *buf); +int ext4fs_set_blk_dev(block_dev_desc_t *rbdd, int part); +long int read_allocated_block(struct ext2_inode *inode, int fileblock); +#endif diff --git a/include/ext_common.h b/include/ext_common.h new file mode 100644 index 0000000..e532570 --- /dev/null +++ b/include/ext_common.h @@ -0,0 +1,188 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Data structures and headers for ext4 support have been taken from + * ext2 ls load support in Uboot + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code from grub2 fs/ext2.c and fs/fshelp.c by + * GRUB -- GRand Unified Bootloader + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __EXT_COMMON__ +#define __EXT_COMMON__ + +#define SECTOR_SIZE 0x200 +#define SECTOR_BITS 9 + +/* Magic value used to identify an ext2 filesystem. */ +#define EXT2_MAGIC 0xEF53 +/* Amount of indirect blocks in an inode. */ +#define INDIRECT_BLOCKS 12 +/* Maximum lenght of a pathname. */ +#define EXT2_PATH_MAX 4096 +/* Maximum nesting of symlinks, used to prevent a loop. */ +#define EXT2_MAX_SYMLINKCNT 8 + +/* Filetype used in directory entry. */ +#define FILETYPE_UNKNOWN 0 +#define FILETYPE_REG 1 +#define FILETYPE_DIRECTORY 2 +#define FILETYPE_SYMLINK 7 + +/* Filetype information as used in inodes. */ +#define FILETYPE_INO_MASK 0170000 +#define FILETYPE_INO_REG 0100000 +#define FILETYPE_INO_DIRECTORY 0040000 +#define FILETYPE_INO_SYMLINK 0120000 +#define EXT2_ROOT_INO 2 /* Root inode */ + +/* Bits used as offset in sector */ +#define DISK_SECTOR_BITS 9 +/* The size of an ext2 block in bytes. */ +#define EXT2_BLOCK_SIZE(data) (1 << LOG2_BLOCK_SIZE(data)) + +/* Log2 size of ext2 block in 512 blocks. */ +#define LOG2_EXT2_BLOCK_SIZE(data) (__le32_to_cpu \ + (data->sblock.log2_block_size) + 1) + +/* Log2 size of ext2 block in bytes. */ +#define LOG2_BLOCK_SIZE(data) (__le32_to_cpu \ + (data->sblock.log2_block_size) + 10) +#define INODE_SIZE_FILESYSTEM(data) (__le32_to_cpu \ + (data->sblock.inode_size)) + +#define EXT2_FT_DIR 2 +#define SUCCESS 1 + +/* Macro-instructions used to manage several block sizes */ +#define EXT2_MIN_BLOCK_LOG_SIZE 10 /* 1024 */ +#define EXT2_MAX_BLOCK_LOG_SIZE 16 /* 65536 */ +#define EXT2_MIN_BLOCK_SIZE (1 << EXT2_MIN_BLOCK_LOG_SIZE) +#define EXT2_MAX_BLOCK_SIZE (1 << EXT2_MAX_BLOCK_LOG_SIZE) + +/* The ext2 superblock. */ +struct ext2_sblock { + uint32_t total_inodes; + uint32_t total_blocks; + uint32_t reserved_blocks; + uint32_t free_blocks; + uint32_t free_inodes; + uint32_t first_data_block; + uint32_t log2_block_size; + uint32_t log2_fragment_size; + uint32_t blocks_per_group; + uint32_t fragments_per_group; + uint32_t inodes_per_group; + uint32_t mtime; + uint32_t utime; + uint16_t mnt_count; + uint16_t max_mnt_count; + uint16_t magic; + uint16_t fs_state; + uint16_t error_handling; + uint16_t minor_revision_level; + uint32_t lastcheck; + uint32_t checkinterval; + uint32_t creator_os; + uint32_t revision_level; + uint16_t uid_reserved; + uint16_t gid_reserved; + uint32_t first_inode; + uint16_t inode_size; + uint16_t block_group_number; + uint32_t feature_compatibility; + uint32_t feature_incompat; + uint32_t feature_ro_compat; + uint32_t unique_id[4]; + char volume_name[16]; + char last_mounted_on[64]; + uint32_t compression_info; +}; + +struct ext2_block_group { + __u32 block_id; /* Blocks bitmap block */ + __u32 inode_id; /* Inodes bitmap block */ + __u32 inode_table_id; /* Inodes table block */ + __u16 free_blocks; /* Free blocks count */ + __u16 free_inodes; /* Free inodes count */ + __u16 used_dir_cnt; /* Directories count */ + __u16 bg_flags; + __u32 bg_reserved[2]; + __u16 bg_itable_unused; /* Unused inodes count */ + __u16 bg_checksum; /* crc16(s_uuid+grouo_num+group_desc)*/ +}; + +/* The ext2 inode. */ +struct ext2_inode { + uint16_t mode; + uint16_t uid; + uint32_t size; + uint32_t atime; + uint32_t ctime; + uint32_t mtime; + uint32_t dtime; + uint16_t gid; + uint16_t nlinks; + uint32_t blockcnt; /* Blocks of 512 bytes!! */ + uint32_t flags; + uint32_t osd1; + union { + struct datablocks { + uint32_t dir_blocks[INDIRECT_BLOCKS]; + uint32_t indir_block; + uint32_t double_indir_block; + uint32_t triple_indir_block; + } blocks; + char symlink[60]; + } b; + uint32_t version; + uint32_t acl; + uint32_t dir_acl; + uint32_t fragment_addr; + uint32_t osd2[3]; +}; + +/* The header of an ext2 directory entry. */ +struct ext2_dirent { + uint32_t inode; + uint16_t direntlen; + uint8_t namelen; + uint8_t filetype; +}; + +struct ext2fs_node { + struct ext2_data *data; + struct ext2_inode inode; + int ino; + int inode_read; +}; + +/* Information about a "mounted" ext2 filesystem. */ +struct ext2_data { + struct ext2_sblock sblock; + struct ext2_inode *inode; + struct ext2fs_node diropen; +}; +#endif
On 01/09/2012 11:54 AM, uma.shankar@samsung.com wrote:
Signed-off-by: Uma Shankar uma.shankar@samsung.com Signed-off-by: Manjunatha C Achar a.manjunatha@samsung.com Signed-off-by: Iqbal Shareef iqbal.ams@samsung.com Signed-off-by: Hakgoo Lee goodguy.lee@samsung.com
Changes for v3: - Copyright has been updated in respective files - ext4fs has been made independant of ext2fs.c - Fixed API namespace - Removed endianness conversion API, used uboot defined API for the same - Fixed coding style issues - Moved README.ext4 file into doc folder
Changes for v2: - Code cleanup, changed comment style - camel case removed, resolved code alignment issues - memory allocation logic changed, removed busybox logic - Modified ext4 load to remove grub dependency (GPLv3) - Introduced new Config for ext4 write
Changes for v1: - Removed checkpatch warnings and errors - Moved common API's of ext2 and ext4 to one generic header file
Makefile | 2 +- common/Makefile | 1 + common/cmd_ext4.c | 266 +++++++++++++++
I don't think we need yet another version of filesystem commands that just duplicates the same code.
I tested this patch and can read ext2 partitions with the ext4ls/load commands. Using ext2 commands on an ext4 partition will hang now. You should merge your ext4 command changes into the existing ext2 commands so that commands work on either ext2/3 or ext4 partitions.
Really, I would like to see all the block based device and file commands collapsed down into just fsls and fsload commands and then detect (or specify if necessary) the fs type. But that's a bigger problem.
Rob
fs/Makefile | 1 + fs/ext2/dev.c | 1 + fs/ext2/ext2fs.c | 181 ++--------- fs/ext4/Makefile | 51 +++ fs/ext4/dev.c | 145 ++++++++ fs/ext4/ext4_common.c | 875 +++++++++++++++++++++++++++++++++++++++++++++++++ fs/ext4/ext4_common.h | 63 ++++ fs/ext4/ext4fs.c | 228 +++++++++++++ include/ext4fs.h | 132 ++++++++ include/ext_common.h | 188 +++++++++++ 13 files changed, 1977 insertions(+), 157 deletions(-) create mode 100644 common/cmd_ext4.c create mode 100644 fs/ext4/Makefile create mode 100644 fs/ext4/dev.c create mode 100644 fs/ext4/ext4_common.c create mode 100644 fs/ext4/ext4_common.h create mode 100644 fs/ext4/ext4fs.c create mode 100644 include/ext4fs.h create mode 100644 include/ext_common.h
diff --git a/Makefile b/Makefile index 7e9491d..e77f6be 100644 --- a/Makefile +++ b/Makefile @@ -235,7 +235,7 @@ LIBS += dts/libdts.o endif LIBS += arch/$(ARCH)/lib/lib$(ARCH).o LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o \
- fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/yaffs2/libyaffs2.o \
- fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/ext4/libext4fs.o fs/yaffs2/libyaffs2.o \ fs/ubifs/libubifs.o
LIBS += net/libnet.o LIBS += disk/libdisk.o diff --git a/common/Makefile b/common/Makefile index 2d9ae8c..f5243f6 100644 --- a/common/Makefile +++ b/common/Makefile @@ -86,6 +86,7 @@ COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o +COBJS-$(CONFIG_CMD_EXT4) += cmd_ext4.o COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o diff --git a/common/cmd_ext4.c b/common/cmd_ext4.c new file mode 100644 index 0000000..2c53d2c --- /dev/null +++ b/common/cmd_ext4.c @@ -0,0 +1,266 @@ +/*
- (C) Copyright 2011 - 2012 Samsung Electronics
- EXT4 filesystem implementation in Uboot by
- Uma Shankar uma.shankar@samsung.com
- Manjunatha C Achar a.manjunatha@samsung.com
- Ext4fs support
- made from existing cmd_ext2.c file of Uboot
- (C) Copyright 2004
- esd gmbh <www.esd-electronics.com>
- Reinhard Arlt reinhard.arlt@esd-electronics.com
- made from cmd_reiserfs by
- (C) Copyright 2003 - 2004
- Sysgo Real-Time Solutions, AG <www.elinos.com>
- Pavel Bartusek pba@sysgo.com
- MA 02111-1307 USA
- Changelog:
- 0.1 - Newly created file for ext4fs support. Taken from cmd_ext2.c
file in uboot. Added ext4fs ls and load support.
+#include <common.h> +#include <part.h> +#include <config.h> +#include <command.h> +#include <image.h> +#include <linux/ctype.h> +#include <asm/byteorder.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <linux/stat.h> +#include <malloc.h>
+#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) +#include <usb.h> +#endif
+#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) +#error DOS or EFI partition support must be selected +#endif
+uint64_t total_sector; +uint64_t part_offset;
+#define DOS_PART_MAGIC_OFFSET 0x1fe +#define DOS_FS_TYPE_OFFSET 0x36 +#define DOS_FS32_TYPE_OFFSET 0x52
+static int do_ext4_load(cmd_tbl_t *cmdtp, int flag, int argc,
char *const argv[])
- char *filename = NULL;
- char *ep;
- int dev;
- unsigned long part = 1;
- ulong addr = 0;
- ulong part_length;
- int filelen;
- disk_partition_t info;
- struct ext_filesystem *fs;
- char buf[12];
- unsigned long count;
- const char *addr_str;
- count = 0;
- addr = simple_strtoul(argv[3], NULL, 16);
- filename = getenv("bootfile");
- switch (argc) {
- case 3:
addr_str = getenv("loadaddr");
if (addr_str != NULL)
addr = simple_strtoul(addr_str, NULL, 16);
else
addr = CONFIG_SYS_LOAD_ADDR;
break;
- case 4:
break;
- case 5:
filename = argv[4];
break;
- case 6:
filename = argv[4];
count = simple_strtoul(argv[5], NULL, 16);
break;
- default:
return cmd_usage(cmdtp);
- if (!filename) {
puts("** No boot file defined **\n");
return 1;
- dev = (int)simple_strtoul(argv[2], &ep, 16);
- ext4_dev_desc = get_dev(argv[1], dev);
- if (ext4_dev_desc == NULL) {
printf("** Block device %s %d not supported\n", argv[1], dev);
return 1;
- if (init_fs(ext4_dev_desc))
return 1;
- fs = get_fs();
- if (*ep) {
if (*ep != ':') {
puts("** Invalid boot device, use `dev[:part]' **\n");
return 1;
part = simple_strtoul(++ep, NULL, 16);
- if (part != 0) {
if (get_partition_info(fs->dev_desc, part, &info)) {
printf("** Bad partition %lu **\n", part);
return 1;
if (strncmp((char *)info.type, BOOT_PART_TYPE,
strlen(BOOT_PART_TYPE)) != 0) {
printf("** Invalid partition type \"%s\""
" (expect \"" BOOT_PART_TYPE "\")\n", info.type);
return 1;
printf("Loading file \"%s\" "
"from %s device %d:%lu %s\n",
filename, argv[1], dev, part, info.name);
- } else {
printf("Loading file \"%s\" from %s device %d\n",
filename, argv[1], dev);
- part_length = ext4fs_set_blk_dev(fs->dev_desc, part);
- if (part_length == 0) {
printf("**Bad partition - %s %d:%lu **\n", argv[1], dev, part);
ext4fs_close();
return 1;
- if (!ext4fs_mount(part_length)) {
printf("** Bad ext2 partition or disk - %s %d:%lu **\n",
ext4fs_close();
return 1;
- filelen = ext4fs_open(filename);
- if (filelen < 0) {
printf("** File not found %s\n", filename);
ext4fs_close();
return 1;
- if ((count < filelen) && (count != 0))
filelen = count;
- if (ext4fs_read((char *)addr, filelen) != filelen) {
printf("** Unable to read \"%s\" from %s %d:%lu **\n",
filename, argv[1], dev, part);
ext4fs_close();
return 1;
- ext4fs_close();
- deinit_fs(fs->dev_desc);
- /* Loading ok, update default load address */
- load_addr = addr;
- printf("%d bytes read\n", filelen);
- sprintf(buf, "%X", filelen);
- setenv("filesize", buf);
+static int do_ext4_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{
- const char *filename = "/";
- int dev;
- char *ep;
- int part_length;
- if (argc < 3)
printf("\n** Block device %s %d not supported\n", argv[1], dev);
return 1;
return 1;
- fs = get_fs();
- if (*ep) {
if (*ep != ':') {
puts("\n** Invalid boot device, use `dev[:part]' **\n");
return 1;
- if (argc == 4)
filename = argv[3];
printf("** Bad partition - %s %d:%lu **\n", argv[1], dev, part);
ext4fs_close();
return 1;
ext4fs_close();
return 1;
- if (ext4fs_ls(filename)) {
printf("** Error ext2fs_ls() **\n");
ext4fs_close();
return 1;
- ext4fs_close();
+U_BOOT_CMD(ext4ls, 4, 1, do_ext4_ls,
"list files in a directory (default /)",
"<interface> <dev[:part]> [directory]\n"
" - list files from 'dev' on 'interface' in a 'directory'");
+U_BOOT_CMD(ext4load, 6, 0, do_ext4_load,
"load binary file from a Ext2 filesystem",
"<interface> <dev[:part]> [addr] [filename] [bytes]\n"
" - load binary file 'filename' from 'dev' on 'interface'\n"
" to address 'addr' from ext2 filesystem");
diff --git a/fs/Makefile b/fs/Makefile index 22aad12..00a8f37 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -23,6 +23,7 @@ #
subdirs-$(CONFIG_CMD_CRAMFS) := cramfs +subdirs-$(CONFIG_CMD_EXT4) += ext4 subdirs-$(CONFIG_CMD_EXT2) += ext2 subdirs-$(CONFIG_CMD_FAT) += fat subdirs-$(CONFIG_CMD_FDOS) += fdos diff --git a/fs/ext2/dev.c b/fs/ext2/dev.c index 874e211..315ff53 100644 --- a/fs/ext2/dev.c +++ b/fs/ext2/dev.c @@ -27,6 +27,7 @@ #include <common.h> #include <config.h> #include <ext2fs.h> +#include <ext_common.h>
static block_dev_desc_t *ext2fs_block_dev_desc; static disk_partition_t part_info; diff --git a/fs/ext2/ext2fs.c b/fs/ext2/ext2fs.c index f621741..a4f3094 100644 --- a/fs/ext2/ext2fs.c +++ b/fs/ext2/ext2fs.c @@ -25,152 +25,16 @@
#include <common.h> #include <ext2fs.h> +#include <ext_common.h> #include <malloc.h> #include <asm/byteorder.h>
extern int ext2fs_devread (int sector, int byte_offset, int byte_len, char *buf);
-/* Magic value used to identify an ext2 filesystem. */ -#define EXT2_MAGIC 0xEF53 -/* Amount of indirect blocks in an inode. */ -#define INDIRECT_BLOCKS 12 -/* Maximum lenght of a pathname. */ -#define EXT2_PATH_MAX 4096 -/* Maximum nesting of symlinks, used to prevent a loop. */ -#define EXT2_MAX_SYMLINKCNT 8
-/* Filetype used in directory entry. */ -#define FILETYPE_UNKNOWN 0 -#define FILETYPE_REG 1 -#define FILETYPE_DIRECTORY 2 -#define FILETYPE_SYMLINK 7
-/* Filetype information as used in inodes. */ -#define FILETYPE_INO_MASK 0170000 -#define FILETYPE_INO_REG 0100000 -#define FILETYPE_INO_DIRECTORY 0040000 -#define FILETYPE_INO_SYMLINK 0120000
-/* Bits used as offset in sector */ -#define DISK_SECTOR_BITS 9
-/* Log2 size of ext2 block in 512 blocks. */ -#define LOG2_EXT2_BLOCK_SIZE(data) (__le32_to_cpu (data->sblock.log2_block_size) + 1)
-/* Log2 size of ext2 block in bytes. */ -#define LOG2_BLOCK_SIZE(data) (__le32_to_cpu (data->sblock.log2_block_size) + 10)
-/* The size of an ext2 block in bytes. */ -#define EXT2_BLOCK_SIZE(data) (1 << LOG2_BLOCK_SIZE(data))
-/* The ext2 superblock. */ -struct ext2_sblock {
- uint32_t total_inodes;
- uint32_t total_blocks;
- uint32_t reserved_blocks;
- uint32_t free_blocks;
- uint32_t free_inodes;
- uint32_t first_data_block;
- uint32_t log2_block_size;
- uint32_t log2_fragment_size;
- uint32_t blocks_per_group;
- uint32_t fragments_per_group;
- uint32_t inodes_per_group;
- uint32_t mtime;
- uint32_t utime;
- uint16_t mnt_count;
- uint16_t max_mnt_count;
- uint16_t magic;
- uint16_t fs_state;
- uint16_t error_handling;
- uint16_t minor_revision_level;
- uint32_t lastcheck;
- uint32_t checkinterval;
- uint32_t creator_os;
- uint32_t revision_level;
- uint16_t uid_reserved;
- uint16_t gid_reserved;
- uint32_t first_inode;
- uint16_t inode_size;
- uint16_t block_group_number;
- uint32_t feature_compatibility;
- uint32_t feature_incompat;
- uint32_t feature_ro_compat;
- uint32_t unique_id[4];
- char volume_name[16];
- char last_mounted_on[64];
- uint32_t compression_info;
-/* The ext2 blockgroup. */ -struct ext2_block_group {
- uint32_t block_id;
- uint32_t inode_id;
- uint32_t inode_table_id;
- uint16_t free_blocks;
- uint16_t free_inodes;
- uint16_t used_dir_cnt;
- uint32_t reserved[3];
-/* The ext2 inode. */ -struct ext2_inode {
- uint16_t mode;
- uint16_t uid;
- uint32_t size;
- uint32_t atime;
- uint32_t ctime;
- uint32_t mtime;
- uint32_t dtime;
- uint16_t gid;
- uint16_t nlinks;
- uint32_t blockcnt; /* Blocks of 512 bytes!! */
- uint32_t flags;
- uint32_t osd1;
- union {
struct datablocks {
uint32_t tripple_indir_block;
} blocks;
char symlink[60];
- } b;
- uint32_t version;
- uint32_t acl;
- uint32_t dir_acl;
- uint32_t fragment_addr;
- uint32_t osd2[3];
-/* The header of an ext2 directory entry. */ -struct ext2_dirent {
- uint32_t inode;
- uint16_t direntlen;
- uint8_t namelen;
- uint8_t filetype;
-struct ext2fs_node {
- struct ext2_data *data;
- struct ext2_inode inode;
- int ino;
- int inode_read;
-/* Information about a "mounted" ext2 filesystem. */ -struct ext2_data {
- struct ext2_sblock sblock;
- struct ext2_inode *inode;
- struct ext2fs_node diropen;
-typedef struct ext2fs_node *ext2fs_node_t;
struct ext2_data *ext2fs_root = NULL; -ext2fs_node_t ext2fs_file = NULL; +struct ext2fs_node *ext2fs_file; int symlinknest = 0; uint32_t *indir1_block = NULL; int indir1_size = 0; @@ -243,14 +107,16 @@ static int ext2fs_read_inode }
-void ext2fs_free_node (ext2fs_node_t node, ext2fs_node_t currroot) { +void ext2fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot) +{ if ((node != &ext2fs_root->diropen) && (node != currroot)) { free (node); } }
-static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { +static int ext2fs_read_block(struct ext2fs_node *node, int fileblock) +{ struct ext2_data *data = node->data; struct ext2_inode *inode = &node->inode; int blknr; @@ -396,7 +262,8 @@ static int ext2fs_read_block (ext2fs_node_t node, int fileblock) {
int ext2fs_read_file
- (ext2fs_node_t node, int pos, unsigned int len, char *buf) {
- (struct ext2fs_node *node, int pos, unsigned int len, char *buf)
+{ int i; int blockcnt; int log2blocksize = LOG2_EXT2_BLOCK_SIZE (node->data); @@ -455,8 +322,8 @@ int ext2fs_read_file return (len); }
-static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fnode, int *ftype) +int ext2fs_iterate_dir(struct ext2fs_node *dir, char *name,
{ unsigned int fpos = 0; int status; @@ -485,7 +352,7 @@ static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fn } if (dirent.namelen != 0) { char filename[dirent.namelen + 1];
ext2fs_node_t fdiro;
struct ext2fs_node *fdiro; int type = FILETYPE_UNKNOWN; status = ext2fs_read_file (diro,
@@ -587,8 +454,8 @@ static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fn return (0); }
-static char *ext2fs_read_symlink (ext2fs_node_t node) { +static char *ext2fs_read_symlink(struct ext2fs_node *node) +{ char *symlink; struct ext2fs_node *diro = node; int status; @@ -625,15 +492,16 @@ static char *ext2fs_read_symlink (ext2fs_node_t node) {
int ext2fs_find_file1
- (const char *currpath,
ext2fs_node_t currroot, ext2fs_node_t * currfound, int *foundtype) {
- (const char *currpath, struct ext2fs_node *currroot,
+{ char fpath[strlen (currpath) + 1]; char *name = fpath; char *next; int status; int type = FILETYPE_DIRECTORY;
- ext2fs_node_t currnode = currroot;
- ext2fs_node_t oldnode = currroot;
strncpy (fpath, currpath, strlen (currpath) + 1);
@@ -729,8 +597,9 @@ int ext2fs_find_file1
- (const char *path,
ext2fs_node_t rootnode, ext2fs_node_t * foundnode, int expecttype) {
- (const char *path, struct ext2fs_node *rootnode,
- struct ext2fs_node **foundnode, int expecttype)
+{ int status; int foundtype = FILETYPE_DIRECTORY;
@@ -756,7 +625,7 @@ int ext2fs_find_file
int ext2fs_ls (const char *dirname) {
- ext2fs_node_t dirnode;
struct ext2fs_node *dirnode; int status;
if (ext2fs_root == NULL) {
@@ -776,7 +645,7 @@ int ext2fs_ls (const char *dirname) {
int ext2fs_open (const char *filename) {
- ext2fs_node_t fdiro = NULL;
- struct ext2fs_node *fdiro = NULL; int status; int len;
@@ -806,8 +675,8 @@ fail: }
-int ext2fs_close (void
+int ext2fs_close(void) +{ if ((ext2fs_file != NULL) && (ext2fs_root != NULL)) { ext2fs_free_node (ext2fs_file, &ext2fs_root->diropen); ext2fs_file = NULL; diff --git a/fs/ext4/Makefile b/fs/ext4/Makefile new file mode 100644 index 0000000..7add4ab --- /dev/null +++ b/fs/ext4/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2003 +# Pavel Bartusek, Sysgo Real-Time Solutions AG, pba@sysgo.de +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +#
+include $(TOPDIR)/config.mk
+LIB = $(obj)libext4fs.o
+AOBJS = +COBJS-$(CONFIG_CMD_EXT4) := ext4fs.o ext4_common.o dev.o
+SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y))
+all: $(LIB) $(AOBJS)
+$(LIB): $(obj).depend $(OBJS)
- $(call cmd_link_o_target, $(OBJS))
+# defines $(obj).depend target +include $(SRCTREE)/rules.mk
+sinclude $(obj).depend
+######################################################################### diff --git a/fs/ext4/dev.c b/fs/ext4/dev.c new file mode 100644 index 0000000..2054be3 --- /dev/null +++ b/fs/ext4/dev.c @@ -0,0 +1,145 @@ +/*
- made from existing ext2/dev.c file of Uboot
- based on code of fs/reiserfs/dev.c by
- Sysgo AG, <www.elinos.com>, Pavel Bartusek pba@sysgo.com
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
- Changelog:
fs/ext2/dev.c file in uboot.
+#include <common.h> +#include <config.h> +#include <ext_common.h>
+static block_dev_desc_t *ext4fs_block_dev_desc; +static disk_partition_t part_info;
+int ext4fs_set_blk_dev(block_dev_desc_t *rbdd, int part) +{
- ext4fs_block_dev_desc = rbdd;
- if (part == 0) {
/* disk doesn't use partition table */
part_info.start = 0;
part_info.size = rbdd->lba;
part_info.blksz = rbdd->blksz;
- } else {
if (get_partition_info(ext4fs_block_dev_desc,
part, &part_info))
- return part_info.size;
+int ext4fs_devread(int sector, int byte_offset, int byte_len, char *buf) +{
- char sec_buf[SECTOR_SIZE];
- unsigned block_len;
- /* Check partition boundaries */
- if ((sector < 0)
|| ((sector + ((byte_offset + byte_len - 1) >> SECTOR_BITS)) >=
part_info.size)) {
printf("%s read outside partition %d\n", __func__, sector);
- /* Get the read to the beginning of a partition */
- sector += byte_offset >> SECTOR_BITS;
- byte_offset &= SECTOR_SIZE - 1;
- debug(" <%d, %d, %d>\n", sector, byte_offset, byte_len);
- if (ext4fs_block_dev_desc == NULL) {
printf("** Invalid Block Device Descriptor (NULL)\n");
- if (byte_offset != 0) {
/* read first part which isn't aligned with start of sector */
printf(" ** ext2fs_devread() read error **\n");
memcpy(buf, sec_buf + byte_offset,
min(SECTOR_SIZE - byte_offset, byte_len));
buf += min(SECTOR_SIZE - byte_offset, byte_len);
byte_len -= min(SECTOR_SIZE - byte_offset, byte_len);
sector++;
- if (byte_len == 0)
return 1;
- /* read sector aligned part */
- block_len = byte_len & ~(SECTOR_SIZE - 1);
- if (block_len == 0) {
u8 p[SECTOR_SIZE];
block_len = SECTOR_SIZE;
ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc->dev,
part_info.start + sector,
1, (unsigned long *)p);
memcpy(buf, p, byte_len);
return 1;
- if (ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc->dev,
block_len / SECTOR_SIZE,
(unsigned long *) buf) !=
block_len / SECTOR_SIZE) {
printf(" ** %s read error - block\n", __func__);
- buf += block_len;
- byte_len -= block_len;
- sector += block_len / SECTOR_SIZE;
- if (byte_len != 0) {
/* read rest of data which are not in whole sector */
part_info.start + sector, 1,
(unsigned long *) sec_buf) != 1) {
printf("* %s read error - last part\n", __func__);
memcpy(buf, sec_buf, byte_len);
- return 1;
+} diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c new file mode 100644 index 0000000..d9deefe --- /dev/null +++ b/fs/ext4/ext4_common.c @@ -0,0 +1,875 @@ +/*
- ext4ls and ext4load : Based on ext2 ls load support in Uboot.
- based on code from grub2 fs/ext2.c and fs/fshelp.c by
- GRUB -- GRand Unified Bootloader
- Copyright (C) 2003, 2004 Free Software Foundation, Inc.
- (struct ext2_data *data, char *buf,
- struct ext4_extent_idx *index;
- unsigned long long block;
- struct ext_filesystem *fs = get_fs();
- int i;
- while (1) {
return ext_block;
i = -1;
do {
i++;
break;
if (--i < 0)
else
- (struct ext2_data *data, int group, struct ext2_block_group *blkgrp)
- long int blkno;
- unsigned int blkoff, desc_per_blk;
- desc_per_blk = EXT2_BLOCK_SIZE(data) / sizeof(struct ext2_block_group);
- blkno = __le32_to_cpu(data->sblock.first_data_block) + 1 +
- blkoff = (group % desc_per_blk) * sizeof(struct ext2_block_group);
- debug("ext4fs read %d group descriptor (blkno %ld blkoff %u)\n",
- return ext4fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data),
(char *)blkgrp);
- struct ext2_block_group blkgrp;
- struct ext2_sblock *sblock = &data->sblock;
- int inodes_per_block, status;
- long int blkno;
- unsigned int blkoff;
- /* It is easier to calculate if the first inode is 0. */
- ino--;
- status = ext4fs_blockgroup(data, ino / __le32_to_cpu
- if (status == 0)
- inodes_per_block = EXT2_BLOCK_SIZE(data) / fs->inodesz;
- blkno = __le32_to_cpu(blkgrp.inode_table_id) +
- blkoff = (ino % inodes_per_block) * fs->inodesz;
- /* Read the inode. */
- status = ext4fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data), blkoff,
- if (status == 0)
- return 1;
- long int blknr;
- int blksz;
- int log2_blksz;
- int status;
- long int rblock;
- long int perblock_parent;
- long int perblock_child;
- unsigned long long start;
- /* get the blocksize of the filesystem */
- blksz = EXT2_BLOCK_SIZE(ext4fs_root);
- log2_blksz = LOG2_EXT2_BLOCK_SIZE(ext4fs_root);
- if (le32_to_cpu(inode->flags) & EXT4_EXTENTS_FL) {
if (!buf)
return -ENOMEM;
int i = -1;
*)inode->b.
blocks.dir_blocks,
if (!ext_block) {
free(buf);
return -EINVAL;
do {
i++;
break;
if (--i >= 0) {
free(buf);
free(buf);
free(buf);
return -1;
- /* Direct blocks. */
- if (fileblock < INDIRECT_BLOCKS)
- /* Indirect. */
- else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4))) {
return -1;
return -1;
status =
(inode->b.blocks.
if (status == 0) {
"failed. **\n");
- /* Double indirect. */
- else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4 *
return -1;
return -1;
status =
(inode->b.blocks.
0, blksz,
if (status == 0) {
"failed. **\n");
return -1;
log2_blksz;
return -1;
return -1;
[rblock /
blksz,
if (status == 0) {
"failed. **\n");
return -1;
perblock]) <<
log2_blksz;
- /* Tripple indirect. */
- else {
return -1;
return -1;
if (status == 0) {
"failed. **\n");
return -1;
log2_blksz;
return -1;
return -1;
log2_blksz)
[rblock /
if (status == 0) {
"failed. **\n");
return -1;
perblock_parent])
<< log2_blksz;
return -1;
return -1;
perblock_child]) <<
status =
if (status == 0) {
"failed. **\n");
return -1;
perblock_child) %
(blksz /
4)]) <<
log2_blksz;
- debug("ext4fs_read_block %ld\n", blknr);
- return blknr;
- if ((ext4fs_file != NULL) && (ext4fs_root != NULL)) {
ext4fs_file = NULL;
- if (ext4fs_root != NULL) {
free(ext4fs_root);
ext4fs_root = NULL;
- if (ext4fs_indir1_block != NULL) {
- if (ext4fs_indir2_block != NULL) {
- if (ext4fs_indir3_block != NULL) {
- unsigned int fpos = 0;
- int status;
- struct ext2fs_node *diro = (struct ext2fs_node *)dir;
+#ifdef DEBUG
- if (name != NULL)
- if (!diro->inode_read) {
if (status == 0)
- /* Search the file. */
- while (fpos < __le32_to_cpu(diro->inode.size)) {
(char *)&dirent);
if (status < 1)
fpos +
if (status < 1)
if (!fdiro)
} else {
__le32_to_cpu
(dirent.inode),
&fdiro->inode);
if (status == 0) {
free(fdiro);
FILETYPE_INO_REG) {
+#ifdef DEBUG
*ftype = type;
*fnode = fdiro;
return 1;
} else {
__le32_to_cpu(
dirent.inode),
&fdiro->inode);
if (status == 0) {
free(fdiro);
switch (type) {
printf("<DIR> ");
break;
printf("<SYM> ");
break;
case FILETYPE_REG:
printf(" ");
break;
default:
printf("< ? > ");
break;
printf("%10d %s\n",
filename);
free(fdiro);
- char *symlink;
- struct ext2fs_node *diro = node;
- int status;
if (status == 0)
- symlink = zalloc(__le32_to_cpu(diro->inode.size) + 1);
- if (!symlink)
- if (__le32_to_cpu(diro->inode.size) <= 60) {
- } else {
symlink);
if (status == 0) {
free(symlink);
- symlink[__le32_to_cpu(diro->inode.size)] = '\0';
- return symlink;
- char fpath[strlen(currpath) + 1];
- char *name = fpath;
- char *next;
- int status;
- int type = FILETYPE_DIRECTORY;
- struct ext2fs_node *currnode = currroot;
- struct ext2fs_node *oldnode = currroot;
- strncpy(fpath, currpath, strlen(currpath) + 1);
- /* Remove all leading slashes. */
- while (*name == '/')
name++;
- if (!*name) {
return 1;
- for (;;) {
int found;
if (next) {
*(next++) = '\0';
oldnode = currnode;
if (found == 0)
if (found == -1)
break;
char *symlink;
if (!symlink) {
&currnode, &type);
free(symlink);
if (status == 0) {
*foundtype = type;
return 1;
name = next;
- return -1;
- int status;
- int foundtype = FILETYPE_DIRECTORY;
- symlinknest = 0;
- if (!path)
- status = ext4fs_find_file1(path, rootnode, foundnode, &foundtype);
- if (status == 0)
- /* Check if the node that was found was of the expected type. */
- if ((expecttype == FILETYPE_REG) && (foundtype != expecttype))
- else if ((expecttype == FILETYPE_DIRECTORY)
- return 1;
- int status;
- int len;
- if (ext4fs_root == NULL)
return -1;
- ext4fs_file = NULL;
- status = ext4fs_find_file(filename, &ext4fs_root->diropen, &fdiro,
FILETYPE_REG);
- if (status == 0)
goto fail;
- if (!fdiro->inode_read) {
&fdiro->inode);
if (status == 0)
goto fail;
- len = __le32_to_cpu(fdiro->inode.size);
- ext4fs_file = fdiro;
- return len;
- fail:
- ext4fs_free_node(fdiro, &ext4fs_root->diropen);
- return -1;
- int status;
- data = zalloc(sizeof(struct ext2_data));
- if (!data)
- /* Read the superblock. */
- status = ext4fs_devread(1 * 2, 0, sizeof(struct ext2_sblock),
- if (status == 0)
goto fail;
- /* Make sure this is an ext2 filesystem. */
- if (__le16_to_cpu(data->sblock.magic) != EXT2_MAGIC)
goto fail;
- if (__le32_to_cpu(data->sblock.revision_level == 0))
fs->inodesz = 128;
- else
- debug("EXT2 rev %d, inode_size %d\n",
- data->diropen.data = data;
- data->diropen.ino = 2;
- data->diropen.inode_read = 1;
- data->inode = &data->diropen.inode;
- status = ext4fs_read_inode(data, 2, data->inode);
- if (status == 0)
goto fail;
- ext4fs_root = data;
- return 1;
- fail:
- printf("Failed to mount ext2 filesystem...\n");
- free(data);
- ext4fs_root = NULL;
- ext4ls and ext4load : based on ext2 ls load support in Uboot.
- ext4ls and ext4load : Based on ext2 ls and load support in Uboot.
Qi bootloader
- if (ext4_dev_desc == NULL || ext4_dev_desc->priv == NULL)
- return ext4_dev_desc->priv;
- if (dev_desc == NULL) {
return -EINVAL;
- fs = zalloc(sizeof(struct ext_filesystem));
- if (fs == NULL) {
return -ENOMEM;
- fs->dev_desc = dev_desc;
- dev_desc->priv = fs;
return;
- free(dev_desc->priv);
- dev_desc->priv = NULL;
- if ((node != &ext4fs_root->diropen) && (node != currroot))
free(node);
- Taken from openmoko-kernel mailing list: By Andy green
- Optimized read file API : collects and defers contiguous sector
- reads into one potentially more efficient larger sequential read action
- int i;
- int blockcnt;
- int log2blocksize = LOG2_EXT2_BLOCK_SIZE(node->data);
- int blocksize = 1 << (log2blocksize + DISK_SECTOR_BITS);
- unsigned int filesize = __le32_to_cpu(node->inode.size);
- int previous_block_number = -1;
- int delayed_start = 0;
- int delayed_extent = 0;
- int delayed_skipfirst = 0;
- int delayed_next = 0;
- char *delayed_buf = NULL;
- short status;
- /* Adjust len so it we can't read past the end of the file. */
- if (len > filesize)
len = filesize;
- blockcnt = ((len + pos) + blocksize - 1) / blocksize;
- for (i = pos / blocksize; i < blockcnt; i++) {
int blknr;
int skipfirst = 0;
if (blknr < 0)
return -1;
/* Last block. */
if (!blockend)
/* First block. */
if (blknr) {
int status;
delayed_skipfirst,
delayed_extent,
delayed_buf);
if (status == 0)
return -1;
delayed_buf = buf;
} else {
delayed_buf = buf;
} else {
/* spill */
delayed_skipfirst,
delayed_extent,
delayed_buf);
if (status == 0)
return -1;
- if (previous_block_number != -1) {
/* spill */
delayed_buf);
if (status == 0)
return -1;
- return len;
- struct ext2fs_node *dirnode;
- int status;
- if (dirname == NULL)
- status = ext4fs_find_file(dirname, &ext4fs_root->diropen, &dirnode,
- if (status != 1) {
return 1;
- ext4fs_iterate_dir(dirnode, NULL, NULL, NULL);
- ext4fs_free_node(dirnode, &ext4fs_root->diropen);
- if (ext4fs_root == NULL || ext4fs_file == NULL)
- return ext4fs_read_file(ext4fs_file, 0, len, buf);
- Ext4 Extent data structures are taken from original ext4 fs code
- as found in the linux kernel.
- Copyright (c) 2003-2006, Cluster File Systems, Inc, info@clusterfs.com
- Written by Alex Tomas alex@clusterfs.com
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
- ext4_inode has i_block array (60 bytes total).
- The first 12 bytes store ext4_extent_header;
- the remainder stores an array of ext4_extent.
- This is the extent on-disk structure.
- It's used at the bottom of the tree.
- __le32 ee_block; /* first logical block extent covers */
- __le16 ee_len; /* number of blocks covered by extent */
- __le16 ee_start_hi; /* high 16 bits of physical block */
- __le32 ee_start_lo; /* low 32 bits of physical block */
- This is index on-disk structure.
- It's used at all the levels except the bottom.
- __le32 ei_block; /* index covers logical blocks from 'block' */
- __le32 ei_leaf_lo; /* pointer to the physical block of the next *
- __le16 ei_leaf_hi; /* high 16 bits of physical block */
- __u16 ei_unused;
- __le16 eh_magic; /* probably will support different formats */
- __le16 eh_entries; /* number of valid entries */
- __le16 eh_max; /* capacity of store in entries */
- __le16 eh_depth; /* has tree real underlying blocks? */
- __le32 eh_generation; /* generation of the tree */
- /* Total Sector of partition */
- uint64_t total_sect;
- /* Block size of partition */
- uint32_t blksz;
- /* Inode size of partition */
- uint32_t inodesz;
- /* Sectors per Block */
- uint32_t sect_perblk;
- /* Group Descriptor Block Number */
- uint32_t gdtable_blkno;
- /* Total block groups of partition */
- uint32_t no_blkgrp;
- /* No of blocks required for bgdtable */
- uint32_t no_blk_pergdt;
- /* Superblock */
- struct ext2_sblock *sb;
- /* Block group descritpor table */
- struct ext2_block_group *gd;
- char *gdtable;
- /* Block Bitmap Related */
- unsigned char **blk_bmaps;
- long int curr_blkno;
- uint16_t first_pass_bbmap;
- /* Inode Bitmap Related */
- unsigned char **inode_bmaps;
- int curr_inode_no;
- uint16_t first_pass_ibmap;
- /* Journal Related */
- /* Block Device Descriptor */
- block_dev_desc_t *dev_desc;
- Data structures and headers for ext4 support have been taken from
- ext2 ls load support in Uboot
- uint32_t mtime;
- uint32_t utime;
- uint16_t magic;
- __u32 block_id; /* Blocks bitmap block */
- __u32 inode_id; /* Inodes bitmap block */
- __u32 inode_table_id; /* Inodes table block */
- __u16 free_blocks; /* Free blocks count */
- __u16 free_inodes; /* Free inodes count */
- __u16 used_dir_cnt; /* Directories count */
- __u16 bg_flags;
- __u32 bg_reserved[2];
- __u16 bg_itable_unused; /* Unused inodes count */
- __u16 bg_checksum; /* crc16(s_uuid+grouo_num+group_desc)*/
- uint16_t mode;
- uint16_t uid;
- uint32_t size;
- uint32_t atime;
- uint32_t ctime;
- uint32_t mtime;
- uint32_t dtime;
- uint16_t gid;
- uint16_t nlinks;
- uint32_t flags;
- uint32_t osd1;
- union {
struct datablocks {
} blocks;
char symlink[60];
- } b;
- uint32_t version;
- uint32_t acl;
- uint32_t dir_acl;
- uint32_t osd2[3];
- uint32_t inode;
- uint8_t namelen;
- uint8_t filetype;
- int ino;
- int inode_read;
+}; +#endif
snip
char *const argv[])
- char *ep;
- int dev;
- ulong addr = 0;
- int filelen;
- char buf[12];
- count = 0;
- switch (argc) {
- case 3:
else
break;
- case 4:
break;
- case 5:
filename = argv[4];
break;
- case 6:
filename = argv[4];
break;
- default:
- if (!filename) {
return 1;
return 1;
return 1;
- fs = get_fs();
These functions pollute the name space and could be combined.
Or can't these 2 calls be rolled into...
- if (*ep) {
if (*ep != ':') {
return 1;
- if (part != 0) {
return 1;
return 1;
- } else {
...this function?
ext4fs_close();
You are leaking memory allocated in init_fs here.
return 1;
ext4fs_close();
and here...
return 1;
ext4fs_close();
and here...
return 1;
filelen = count;
ext4fs_close();
and here...
Same comments apply in do_ext4_ls.
Rob
Signed-off-by: Uma Shankar uma.shankar@samsung.com Signed-off-by: Manjunatha C Achar a.manjunatha@samsung.com Signed-off-by: Iqbal Shareef iqbal.ams@samsung.com Signed-off-by: Hakgoo Lee goodguy.lee@samsung.com --- Changes for v4: - Redesigned ext2, ext4 command interface - Removed ext2 folder from fs/ - Memory Leak issue handled
--- Makefile | 2 +- common/Makefile | 6 + common/cmd_ext2.c | 219 +---------- common/cmd_ext4.c | 96 +++++ common/cmd_ext_common.c | 259 +++++++++++++ fs/Makefile | 5 +- fs/ext2/dev.c | 131 ------- fs/ext2/ext2fs.c | 897 -------------------------------------------- fs/{ext2 => ext4}/Makefile | 8 +- fs/ext4/dev.c | 145 +++++++ fs/ext4/ext4_common.c | 875 ++++++++++++++++++++++++++++++++++++++++++ fs/ext4/ext4_common.h | 63 +++ fs/ext4/ext4fs.c | 228 +++++++++++ include/ext2fs.h | 81 ---- include/ext4fs.h | 132 +++++++ include/ext_common.h | 197 ++++++++++ 16 files changed, 2028 insertions(+), 1316 deletions(-) create mode 100644 common/cmd_ext4.c create mode 100644 common/cmd_ext_common.c delete mode 100644 fs/ext2/dev.c delete mode 100644 fs/ext2/ext2fs.c rename fs/{ext2 => ext4}/Makefile (89%) create mode 100644 fs/ext4/dev.c create mode 100644 fs/ext4/ext4_common.c create mode 100644 fs/ext4/ext4_common.h create mode 100644 fs/ext4/ext4fs.c delete mode 100644 include/ext2fs.h create mode 100644 include/ext4fs.h create mode 100644 include/ext_common.h
diff --git a/Makefile b/Makefile index 351a8f0..dd306ac 100644 --- a/Makefile +++ b/Makefile @@ -243,7 +243,7 @@ LIBS += dts/libdts.o endif LIBS += arch/$(ARCH)/lib/lib$(ARCH).o LIBS += fs/cramfs/libcramfs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o \ - fs/reiserfs/libreiserfs.o fs/ext2/libext2fs.o fs/yaffs2/libyaffs2.o \ + fs/reiserfs/libreiserfs.o fs/ext4/libext4fs.o fs/yaffs2/libyaffs2.o \ fs/ubifs/libubifs.o LIBS += net/libnet.o LIBS += disk/libdisk.o diff --git a/common/Makefile b/common/Makefile index 6e23baa..feb3731 100644 --- a/common/Makefile +++ b/common/Makefile @@ -88,7 +88,13 @@ COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o +COBJS-$(CONFIG_CMD_EXT4) += cmd_ext4.o COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o +ifdef CONFIG_CMD_EXT4 +COBJS-y += cmd_ext_common.o +else +COBJS-$(CONFIG_CMD_EXT2) += cmd_ext_common.o +endif COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o COBJS-$(CONFIG_OF_LIBFDT) += cmd_fdt.o fdt_support.o diff --git a/common/cmd_ext2.c b/common/cmd_ext2.c index 79b1e2f..c27d9c7 100644 --- a/common/cmd_ext2.c +++ b/common/cmd_ext2.c @@ -1,4 +1,9 @@ /* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * (C) Copyright 2004 * esd gmbh <www.esd-electronics.com> * Reinhard Arlt reinhard.arlt@esd-electronics.com @@ -33,225 +38,35 @@ * Ext2fs support */ #include <common.h> -#include <part.h> -#include <config.h> -#include <command.h> -#include <image.h> -#include <linux/ctype.h> -#include <asm/byteorder.h> -#include <ext2fs.h> -#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) -#include <usb.h> -#endif - -#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) -#error DOS or EFI partition support must be selected -#endif - -/* #define EXT2_DEBUG */ - -#ifdef EXT2_DEBUG -#define PRINTF(fmt,args...) printf (fmt ,##args) -#else -#define PRINTF(fmt,args...) -#endif +#include <ext_common.h>
int do_ext2ls (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - char *filename = "/"; - int dev=0; - int part=1; - char *ep; - block_dev_desc_t *dev_desc=NULL; - int part_length; - - if (argc < 3) - return CMD_RET_USAGE; - - dev = (int)simple_strtoul (argv[2], &ep, 16); - dev_desc = get_dev(argv[1],dev); - - if (dev_desc == NULL) { - printf ("\n** Block device %s %d not supported\n", argv[1], dev); - return 1; - } - - if (*ep) { - if (*ep != ':') { - puts ("\n** Invalid boot device, use `dev[:part]' **\n"); - return 1; - } - part = (int)simple_strtoul(++ep, NULL, 16); - } - - if (argc == 4) - filename = argv[3]; - - PRINTF("Using device %s %d:%d, directory: %s\n", argv[1], dev, part, filename); - - if ((part_length = ext2fs_set_blk_dev(dev_desc, part)) == 0) { - printf ("** Bad partition - %s %d:%d **\n", argv[1], dev, part); - ext2fs_close(); - return 1; - } - - if (!ext2fs_mount(part_length)) { - printf ("** Bad ext2 partition or disk - %s %d:%d **\n", argv[1], dev, part); - ext2fs_close(); - return 1; - } - - if (ext2fs_ls (filename)) { - printf ("** Error ext2fs_ls() **\n"); - ext2fs_close(); - return 1; - }; - - ext2fs_close(); + if (do_ext_ls(cmdtp, flag, argc, argv)) + return -1;
return 0; }
-U_BOOT_CMD( - ext2ls, 4, 1, do_ext2ls, - "list files in a directory (default /)", - "<interface> <dev[:part]> [directory]\n" - " - list files from 'dev' on 'interface' in a 'directory'" -); - /****************************************************************************** * Ext2fs boot command intepreter. Derived from diskboot */ int do_ext2load (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - char *filename = NULL; - char *ep; - int dev, part = 1; - ulong addr = 0, part_length; - int filelen; - disk_partition_t info; - block_dev_desc_t *dev_desc = NULL; - char buf [12]; - unsigned long count; - char *addr_str; - - switch (argc) { - case 3: - addr_str = getenv("loadaddr"); - if (addr_str != NULL) - addr = simple_strtoul (addr_str, NULL, 16); - else - addr = CONFIG_SYS_LOAD_ADDR; - - filename = getenv ("bootfile"); - count = 0; - break; - case 4: - addr = simple_strtoul (argv[3], NULL, 16); - filename = getenv ("bootfile"); - count = 0; - break; - case 5: - addr = simple_strtoul (argv[3], NULL, 16); - filename = argv[4]; - count = 0; - break; - case 6: - addr = simple_strtoul (argv[3], NULL, 16); - filename = argv[4]; - count = simple_strtoul (argv[5], NULL, 16); - break; - - default: - return CMD_RET_USAGE; - } - - if (!filename) { - puts ("** No boot file defined **\n"); - return 1; - } - - dev = (int)simple_strtoul (argv[2], &ep, 16); - dev_desc = get_dev(argv[1],dev); - if (dev_desc==NULL) { - printf ("** Block device %s %d not supported\n", argv[1], dev); - return 1; - } - if (*ep) { - if (*ep != ':') { - puts ("** Invalid boot device, use `dev[:part]' **\n"); - return 1; - } - part = (int)simple_strtoul(++ep, NULL, 16); - } - - PRINTF("Using device %s%d, partition %d\n", argv[1], dev, part); - - if (part != 0) { - if (get_partition_info (dev_desc, part, &info)) { - printf ("** Bad partition %d **\n", part); - return 1; - } - - if (strncmp((char *)info.type, BOOT_PART_TYPE, sizeof(info.type)) != 0) { - printf ("** Invalid partition type "%.32s"" - " (expect "" BOOT_PART_TYPE "")\n", - info.type); - return 1; - } - printf ("Loading file "%s" " - "from %s device %d:%d (%.32s)\n", - filename, - argv[1], dev, part, info.name); - } else { - printf ("Loading file "%s" from %s device %d\n", - filename, argv[1], dev); - } - - - if ((part_length = ext2fs_set_blk_dev(dev_desc, part)) == 0) { - printf ("** Bad partition - %s %d:%d **\n", argv[1], dev, part); - ext2fs_close(); - return 1; - } - - if (!ext2fs_mount(part_length)) { - printf ("** Bad ext2 partition or disk - %s %d:%d **\n", - argv[1], dev, part); - ext2fs_close(); - return 1; - } - - filelen = ext2fs_open(filename); - if (filelen < 0) { - printf("** File not found %s\n", filename); - ext2fs_close(); - return 1; - } - if ((count < filelen) && (count != 0)) { - filelen = count; - } - - if (ext2fs_read((char *)addr, filelen) != filelen) { - printf("** Unable to read "%s" from %s %d:%d **\n", - filename, argv[1], dev, part); - ext2fs_close(); - return 1; - } - - ext2fs_close(); - - /* Loading ok, update default load address */ - load_addr = addr; - - printf ("%d bytes read\n", filelen); - sprintf(buf, "%X", filelen); - setenv("filesize", buf); + if (do_ext_load(cmdtp, flag, argc, argv)) + return -1;
return 0; }
U_BOOT_CMD( + ext2ls, 4, 1, do_ext2ls, + "list files in a directory (default /)", + "<interface> <dev[:part]> [directory]\n" + " - list files from 'dev' on 'interface' in a 'directory'" +); + +U_BOOT_CMD( ext2load, 6, 0, do_ext2load, "load binary file from a Ext2 filesystem", "<interface> <dev[:part]> [addr] [filename] [bytes]\n" diff --git a/common/cmd_ext4.c b/common/cmd_ext4.c new file mode 100644 index 0000000..3298fee --- /dev/null +++ b/common/cmd_ext4.c @@ -0,0 +1,96 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Ext4fs support + * made from existing cmd_ext2.c file of Uboot + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * made from cmd_reiserfs by + * + * (C) Copyright 2003 - 2004 + * Sysgo Real-Time Solutions, AG <www.elinos.com> + * Pavel Bartusek pba@sysgo.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* + * Changelog: + * 0.1 - Newly created file for ext4fs support. Taken from cmd_ext2.c + * file in uboot. Added ext4fs ls load and write support. + */ + +#include <common.h> +#include <part.h> +#include <config.h> +#include <command.h> +#include <image.h> +#include <linux/ctype.h> +#include <asm/byteorder.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <linux/stat.h> +#include <malloc.h> + +#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) +#include <usb.h> +#endif + +#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) +#error DOS or EFI partition support must be selected +#endif + +uint64_t total_sector; +uint64_t part_offset; + +#define DOS_PART_MAGIC_OFFSET 0x1fe +#define DOS_FS_TYPE_OFFSET 0x36 +#define DOS_FS32_TYPE_OFFSET 0x52 + +int do_ext4_load(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + if (do_ext_load(cmdtp, flag, argc, argv)) + return -1; + + return 0; +} + +int do_ext4_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + if (do_ext_ls(cmdtp, flag, argc, argv)) + return -1; + + return 0; +} + +U_BOOT_CMD(ext4ls, 4, 1, do_ext4_ls, + "list files in a directory (default /)", + "<interface> <dev[:part]> [directory]\n" + " - list files from 'dev' on 'interface' in a 'directory'"); + +U_BOOT_CMD(ext4load, 6, 0, do_ext4_load, + "load binary file from a Ext4 filesystem", + "<interface> <dev[:part]> [addr] [filename] [bytes]\n" + " - load binary file 'filename' from 'dev' on 'interface'\n" + " to address 'addr' from ext4 filesystem"); diff --git a/common/cmd_ext_common.c b/common/cmd_ext_common.c new file mode 100644 index 0000000..fa2d3b7 --- /dev/null +++ b/common/cmd_ext_common.c @@ -0,0 +1,259 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT2/4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Ext4fs support + * made from existing cmd_ext2.c file of Uboot + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * made from cmd_reiserfs by + * + * (C) Copyright 2003 - 2004 + * Sysgo Real-Time Solutions, AG <www.elinos.com> + * Pavel Bartusek pba@sysgo.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +/* + * Changelog: + * 0.1 - Newly created file for ext4fs support. Taken from cmd_ext2.c + * file in uboot. Added ext4fs ls load and write support. + */ + +#include <common.h> +#include <part.h> +#include <config.h> +#include <command.h> +#include <image.h> +#include <linux/ctype.h> +#include <asm/byteorder.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <linux/stat.h> +#include <malloc.h> + +#if defined(CONFIG_CMD_USB) && defined(CONFIG_USB_STORAGE) +#include <usb.h> +#endif + +#if !defined(CONFIG_DOS_PARTITION) && !defined(CONFIG_EFI_PARTITION) +#error DOS or EFI partition support must be selected +#endif + +#define DOS_PART_MAGIC_OFFSET 0x1fe +#define DOS_FS_TYPE_OFFSET 0x36 +#define DOS_FS32_TYPE_OFFSET 0x52 + +int do_ext_load(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + char *filename = NULL; + char *ep; + int dev; + unsigned long part = 1; + ulong addr = 0; + ulong part_length; + int filelen; + disk_partition_t info; + struct ext_filesystem *fs; + char buf[12]; + unsigned long count; + const char *addr_str; + + count = 0; + addr = simple_strtoul(argv[3], NULL, 16); + filename = getenv("bootfile"); + switch (argc) { + case 3: + addr_str = getenv("loadaddr"); + if (addr_str != NULL) + addr = simple_strtoul(addr_str, NULL, 16); + else + addr = CONFIG_SYS_LOAD_ADDR; + + break; + case 4: + break; + case 5: + filename = argv[4]; + break; + case 6: + filename = argv[4]; + count = simple_strtoul(argv[5], NULL, 16); + break; + + default: + return cmd_usage(cmdtp); + } + + if (!filename) { + puts("** No boot file defined **\n"); + return 1; + } + + dev = (int)simple_strtoul(argv[2], &ep, 16); + ext4_dev_desc = get_dev(argv[1], dev); + if (ext4_dev_desc == NULL) { + printf("** Block device %s %d not supported\n", argv[1], dev); + return 1; + } + if (init_fs(ext4_dev_desc)) + return 1; + + fs = get_fs(); + if (*ep) { + if (*ep != ':') { + puts("** Invalid boot device, use `dev[:part]' **\n"); + goto fail; + } + part = simple_strtoul(++ep, NULL, 16); + } + + if (part != 0) { + if (get_partition_info(fs->dev_desc, part, &info)) { + printf("** Bad partition %lu **\n", part); + goto fail; + } + + if (strncmp((char *)info.type, BOOT_PART_TYPE, + strlen(BOOT_PART_TYPE)) != 0) { + printf("** Invalid partition type "%s"" + " (expect "" BOOT_PART_TYPE "")\n", info.type); + goto fail; + } + printf("Loading file "%s" " + "from %s device %d:%lu %s\n", + filename, argv[1], dev, part, info.name); + } else { + printf("Loading file "%s" from %s device %d\n", + filename, argv[1], dev); + } + + part_length = ext4fs_set_blk_dev(fs->dev_desc, part); + if (part_length == 0) { + printf("**Bad partition - %s %d:%lu **\n", argv[1], dev, part); + ext4fs_close(); + goto fail; + } + + if (!ext4fs_mount(part_length)) { + printf("** Bad ext2 partition or disk - %s %d:%lu **\n", + argv[1], dev, part); + ext4fs_close(); + goto fail; + } + + filelen = ext4fs_open(filename); + if (filelen < 0) { + printf("** File not found %s\n", filename); + ext4fs_close(); + goto fail; + } + if ((count < filelen) && (count != 0)) + filelen = count; + + if (ext4fs_read((char *)addr, filelen) != filelen) { + printf("** Unable to read "%s" from %s %d:%lu **\n", + filename, argv[1], dev, part); + ext4fs_close(); + goto fail; + } + + ext4fs_close(); + deinit_fs(fs->dev_desc); + /* Loading ok, update default load address */ + load_addr = addr; + + printf("%d bytes read\n", filelen); + sprintf(buf, "%X", filelen); + setenv("filesize", buf); + + return 0; +fail: + deinit_fs(fs->dev_desc); + return 1; +} + +int do_ext_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + const char *filename = "/"; + int dev; + unsigned long part = 1; + char *ep; + struct ext_filesystem *fs; + int part_length; + if (argc < 3) + return cmd_usage(cmdtp); + + dev = (int)simple_strtoul(argv[2], &ep, 16); + + ext4_dev_desc = get_dev(argv[1], dev); + + if (ext4_dev_desc == NULL) { + printf("\n** Block device %s %d not supported\n", argv[1], dev); + return 1; + } + + if (init_fs(ext4_dev_desc)) + return 1; + + fs = get_fs(); + if (*ep) { + if (*ep != ':') { + puts("\n** Invalid boot device, use `dev[:part]' **\n"); + goto fail; + } + part = simple_strtoul(++ep, NULL, 16); + } + + if (argc == 4) + filename = argv[3]; + + part_length = ext4fs_set_blk_dev(fs->dev_desc, part); + if (part_length == 0) { + printf("** Bad partition - %s %d:%lu **\n", argv[1], dev, part); + ext4fs_close(); + goto fail; + } + + if (!ext4fs_mount(part_length)) { + printf("** Bad ext2 partition or disk - %s %d:%lu **\n", + argv[1], dev, part); + ext4fs_close(); + goto fail; + } + + if (ext4fs_ls(filename)) { + printf("** Error extfs_ls() **\n"); + ext4fs_close(); + goto fail; + }; + + ext4fs_close(); + deinit_fs(fs->dev_desc); + return 0; + +fail: + deinit_fs(fs->dev_desc); + return 1; +} diff --git a/fs/Makefile b/fs/Makefile index 22aad12..bb53e6b 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -23,7 +23,10 @@ #
subdirs-$(CONFIG_CMD_CRAMFS) := cramfs -subdirs-$(CONFIG_CMD_EXT2) += ext2 +subdirs-$(CONFIG_CMD_EXT4) += ext4 +ifndef CONFIG_CMD_EXT4 +subdirs-$(CONFIG_CMD_EXT2) += ext4 +endif subdirs-$(CONFIG_CMD_FAT) += fat subdirs-$(CONFIG_CMD_FDOS) += fdos subdirs-$(CONFIG_CMD_JFFS2) += jffs2 diff --git a/fs/ext2/dev.c b/fs/ext2/dev.c deleted file mode 100644 index 874e211..0000000 --- a/fs/ext2/dev.c +++ /dev/null @@ -1,131 +0,0 @@ -/* - * (C) Copyright 2004 - * esd gmbh <www.esd-electronics.com> - * Reinhard Arlt reinhard.arlt@esd-electronics.com - * - * based on code of fs/reiserfs/dev.c by - * - * (C) Copyright 2003 - 2004 - * Sysgo AG, <www.elinos.com>, Pavel Bartusek pba@sysgo.com - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. - */ - - -#include <common.h> -#include <config.h> -#include <ext2fs.h> - -static block_dev_desc_t *ext2fs_block_dev_desc; -static disk_partition_t part_info; - -int ext2fs_set_blk_dev(block_dev_desc_t *rbdd, int part) -{ - ext2fs_block_dev_desc = rbdd; - - if (part == 0) { - /* disk doesn't use partition table */ - part_info.start = 0; - part_info.size = rbdd->lba; - part_info.blksz = rbdd->blksz; - } else { - if (get_partition_info - (ext2fs_block_dev_desc, part, &part_info)) { - return 0; - } - } - return part_info.size; -} - - -int ext2fs_devread(int sector, int byte_offset, int byte_len, char *buf) -{ - ALLOC_CACHE_ALIGN_BUFFER(char, sec_buf, SECTOR_SIZE); - unsigned sectors; - - /* - * Check partition boundaries - */ - if ((sector < 0) || - ((sector + ((byte_offset + byte_len - 1) >> SECTOR_BITS)) >= - part_info.size)) { - /* errnum = ERR_OUTSIDE_PART; */ - printf(" ** %s read outside partition sector %d\n", - __func__, - sector); - return 0; - } - - /* - * Get the read to the beginning of a partition. - */ - sector += byte_offset >> SECTOR_BITS; - byte_offset &= SECTOR_SIZE - 1; - - debug(" <%d, %d, %d>\n", sector, byte_offset, byte_len); - - if (ext2fs_block_dev_desc == NULL) { - printf(" ** %s Invalid Block Device Descriptor (NULL)\n", - __func__); - return 0; - } - - if (byte_offset != 0) { - /* read first part which isn't aligned with start of sector */ - if (ext2fs_block_dev_desc-> - block_read(ext2fs_block_dev_desc->dev, - part_info.start + sector, 1, - (unsigned long *) sec_buf) != 1) { - printf(" ** %s read error **\n", __func__); - return 0; - } - memcpy(buf, sec_buf + byte_offset, - min(SECTOR_SIZE - byte_offset, byte_len)); - buf += min(SECTOR_SIZE - byte_offset, byte_len); - byte_len -= min(SECTOR_SIZE - byte_offset, byte_len); - sector++; - } - - /* read sector aligned part */ - sectors = byte_len / SECTOR_SIZE; - - if (sectors > 0) { - if (ext2fs_block_dev_desc->block_read( - ext2fs_block_dev_desc->dev, - part_info.start + sector, - sectors, - (unsigned long *) buf) != sectors) { - printf(" ** %s read error - block\n", __func__); - return 0; - } - - buf += sectors * SECTOR_SIZE; - byte_len -= sectors * SECTOR_SIZE; - sector += sectors; - } - - if (byte_len != 0) { - /* read rest of data which are not in whole sector */ - if (ext2fs_block_dev_desc-> - block_read(ext2fs_block_dev_desc->dev, - part_info.start + sector, 1, - (unsigned long *) sec_buf) != 1) { - printf(" ** %s read error - last part\n", __func__); - return 0; - } - memcpy(buf, sec_buf, byte_len); - } - return 1; -} diff --git a/fs/ext2/ext2fs.c b/fs/ext2/ext2fs.c deleted file mode 100644 index f621741..0000000 --- a/fs/ext2/ext2fs.c +++ /dev/null @@ -1,897 +0,0 @@ -/* - * (C) Copyright 2004 - * esd gmbh <www.esd-electronics.com> - * Reinhard Arlt reinhard.arlt@esd-electronics.com - * - * based on code from grub2 fs/ext2.c and fs/fshelp.c by - * - * GRUB -- GRand Unified Bootloader - * Copyright (C) 2003, 2004 Free Software Foundation, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. - */ - -#include <common.h> -#include <ext2fs.h> -#include <malloc.h> -#include <asm/byteorder.h> - -extern int ext2fs_devread (int sector, int byte_offset, int byte_len, - char *buf); - -/* Magic value used to identify an ext2 filesystem. */ -#define EXT2_MAGIC 0xEF53 -/* Amount of indirect blocks in an inode. */ -#define INDIRECT_BLOCKS 12 -/* Maximum lenght of a pathname. */ -#define EXT2_PATH_MAX 4096 -/* Maximum nesting of symlinks, used to prevent a loop. */ -#define EXT2_MAX_SYMLINKCNT 8 - -/* Filetype used in directory entry. */ -#define FILETYPE_UNKNOWN 0 -#define FILETYPE_REG 1 -#define FILETYPE_DIRECTORY 2 -#define FILETYPE_SYMLINK 7 - -/* Filetype information as used in inodes. */ -#define FILETYPE_INO_MASK 0170000 -#define FILETYPE_INO_REG 0100000 -#define FILETYPE_INO_DIRECTORY 0040000 -#define FILETYPE_INO_SYMLINK 0120000 - -/* Bits used as offset in sector */ -#define DISK_SECTOR_BITS 9 - -/* Log2 size of ext2 block in 512 blocks. */ -#define LOG2_EXT2_BLOCK_SIZE(data) (__le32_to_cpu (data->sblock.log2_block_size) + 1) - -/* Log2 size of ext2 block in bytes. */ -#define LOG2_BLOCK_SIZE(data) (__le32_to_cpu (data->sblock.log2_block_size) + 10) - -/* The size of an ext2 block in bytes. */ -#define EXT2_BLOCK_SIZE(data) (1 << LOG2_BLOCK_SIZE(data)) - -/* The ext2 superblock. */ -struct ext2_sblock { - uint32_t total_inodes; - uint32_t total_blocks; - uint32_t reserved_blocks; - uint32_t free_blocks; - uint32_t free_inodes; - uint32_t first_data_block; - uint32_t log2_block_size; - uint32_t log2_fragment_size; - uint32_t blocks_per_group; - uint32_t fragments_per_group; - uint32_t inodes_per_group; - uint32_t mtime; - uint32_t utime; - uint16_t mnt_count; - uint16_t max_mnt_count; - uint16_t magic; - uint16_t fs_state; - uint16_t error_handling; - uint16_t minor_revision_level; - uint32_t lastcheck; - uint32_t checkinterval; - uint32_t creator_os; - uint32_t revision_level; - uint16_t uid_reserved; - uint16_t gid_reserved; - uint32_t first_inode; - uint16_t inode_size; - uint16_t block_group_number; - uint32_t feature_compatibility; - uint32_t feature_incompat; - uint32_t feature_ro_compat; - uint32_t unique_id[4]; - char volume_name[16]; - char last_mounted_on[64]; - uint32_t compression_info; -}; - -/* The ext2 blockgroup. */ -struct ext2_block_group { - uint32_t block_id; - uint32_t inode_id; - uint32_t inode_table_id; - uint16_t free_blocks; - uint16_t free_inodes; - uint16_t used_dir_cnt; - uint32_t reserved[3]; -}; - -/* The ext2 inode. */ -struct ext2_inode { - uint16_t mode; - uint16_t uid; - uint32_t size; - uint32_t atime; - uint32_t ctime; - uint32_t mtime; - uint32_t dtime; - uint16_t gid; - uint16_t nlinks; - uint32_t blockcnt; /* Blocks of 512 bytes!! */ - uint32_t flags; - uint32_t osd1; - union { - struct datablocks { - uint32_t dir_blocks[INDIRECT_BLOCKS]; - uint32_t indir_block; - uint32_t double_indir_block; - uint32_t tripple_indir_block; - } blocks; - char symlink[60]; - } b; - uint32_t version; - uint32_t acl; - uint32_t dir_acl; - uint32_t fragment_addr; - uint32_t osd2[3]; -}; - -/* The header of an ext2 directory entry. */ -struct ext2_dirent { - uint32_t inode; - uint16_t direntlen; - uint8_t namelen; - uint8_t filetype; -}; - -struct ext2fs_node { - struct ext2_data *data; - struct ext2_inode inode; - int ino; - int inode_read; -}; - -/* Information about a "mounted" ext2 filesystem. */ -struct ext2_data { - struct ext2_sblock sblock; - struct ext2_inode *inode; - struct ext2fs_node diropen; -}; - - -typedef struct ext2fs_node *ext2fs_node_t; - -struct ext2_data *ext2fs_root = NULL; -ext2fs_node_t ext2fs_file = NULL; -int symlinknest = 0; -uint32_t *indir1_block = NULL; -int indir1_size = 0; -int indir1_blkno = -1; -uint32_t *indir2_block = NULL; -int indir2_size = 0; -int indir2_blkno = -1; -static unsigned int inode_size; - - -static int ext2fs_blockgroup - (struct ext2_data *data, int group, struct ext2_block_group *blkgrp) { - unsigned int blkno; - unsigned int blkoff; - unsigned int desc_per_blk; - - desc_per_blk = EXT2_BLOCK_SIZE(data) / sizeof(struct ext2_block_group); - - blkno = __le32_to_cpu(data->sblock.first_data_block) + 1 + - group / desc_per_blk; - blkoff = (group % desc_per_blk) * sizeof(struct ext2_block_group); -#ifdef DEBUG - printf ("ext2fs read %d group descriptor (blkno %d blkoff %d)\n", - group, blkno, blkoff); -#endif - return (ext2fs_devread (blkno << LOG2_EXT2_BLOCK_SIZE(data), - blkoff, sizeof(struct ext2_block_group), (char *)blkgrp)); - -} - - -static int ext2fs_read_inode - (struct ext2_data *data, int ino, struct ext2_inode *inode) { - struct ext2_block_group blkgrp; - struct ext2_sblock *sblock = &data->sblock; - int inodes_per_block; - int status; - - unsigned int blkno; - unsigned int blkoff; - -#ifdef DEBUG - printf ("ext2fs read inode %d, inode_size %d\n", ino, inode_size); -#endif - /* It is easier to calculate if the first inode is 0. */ - ino--; - status = ext2fs_blockgroup (data, ino / __le32_to_cpu - (sblock->inodes_per_group), &blkgrp); - if (status == 0) { - return (0); - } - - inodes_per_block = EXT2_BLOCK_SIZE(data) / inode_size; - - blkno = __le32_to_cpu (blkgrp.inode_table_id) + - (ino % __le32_to_cpu (sblock->inodes_per_group)) - / inodes_per_block; - blkoff = (ino % inodes_per_block) * inode_size; -#ifdef DEBUG - printf ("ext2fs read inode blkno %d blkoff %d\n", blkno, blkoff); -#endif - /* Read the inode. */ - status = ext2fs_devread (blkno << LOG2_EXT2_BLOCK_SIZE (data), blkoff, - sizeof (struct ext2_inode), (char *) inode); - if (status == 0) { - return (0); - } - - return (1); -} - - -void ext2fs_free_node (ext2fs_node_t node, ext2fs_node_t currroot) { - if ((node != &ext2fs_root->diropen) && (node != currroot)) { - free (node); - } -} - - -static int ext2fs_read_block (ext2fs_node_t node, int fileblock) { - struct ext2_data *data = node->data; - struct ext2_inode *inode = &node->inode; - int blknr; - int blksz = EXT2_BLOCK_SIZE (data); - int log2_blksz = LOG2_EXT2_BLOCK_SIZE (data); - int status; - - /* Direct blocks. */ - if (fileblock < INDIRECT_BLOCKS) { - blknr = __le32_to_cpu (inode->b.blocks.dir_blocks[fileblock]); - } - /* Indirect. */ - else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4))) { - if (indir1_block == NULL) { - indir1_block = (uint32_t *) memalign(ARCH_DMA_MINALIGN, - blksz); - if (indir1_block == NULL) { - printf ("** ext2fs read block (indir 1) malloc failed. **\n"); - return (-1); - } - indir1_size = blksz; - indir1_blkno = -1; - } - if (blksz != indir1_size) { - free (indir1_block); - indir1_block = NULL; - indir1_size = 0; - indir1_blkno = -1; - indir1_block = (uint32_t *) memalign(ARCH_DMA_MINALIGN, - blksz); - if (indir1_block == NULL) { - printf ("** ext2fs read block (indir 1) malloc failed. **\n"); - return (-1); - } - indir1_size = blksz; - } - if ((__le32_to_cpu (inode->b.blocks.indir_block) << - log2_blksz) != indir1_blkno) { - status = ext2fs_devread (__le32_to_cpu(inode->b.blocks.indir_block) << log2_blksz, - 0, blksz, - (char *) indir1_block); - if (status == 0) { - printf ("** ext2fs read block (indir 1) failed. **\n"); - return (0); - } - indir1_blkno = - __le32_to_cpu (inode->b.blocks. - indir_block) << log2_blksz; - } - blknr = __le32_to_cpu (indir1_block - [fileblock - INDIRECT_BLOCKS]); - } - /* Double indirect. */ - else if (fileblock < - (INDIRECT_BLOCKS + (blksz / 4 * (blksz / 4 + 1)))) { - unsigned int perblock = blksz / 4; - unsigned int rblock = fileblock - (INDIRECT_BLOCKS - + blksz / 4); - - if (indir1_block == NULL) { - indir1_block = (uint32_t *) memalign(ARCH_DMA_MINALIGN, - blksz); - if (indir1_block == NULL) { - printf ("** ext2fs read block (indir 2 1) malloc failed. **\n"); - return (-1); - } - indir1_size = blksz; - indir1_blkno = -1; - } - if (blksz != indir1_size) { - free (indir1_block); - indir1_block = NULL; - indir1_size = 0; - indir1_blkno = -1; - indir1_block = (uint32_t *) memalign(ARCH_DMA_MINALIGN, - blksz); - if (indir1_block == NULL) { - printf ("** ext2fs read block (indir 2 1) malloc failed. **\n"); - return (-1); - } - indir1_size = blksz; - } - if ((__le32_to_cpu (inode->b.blocks.double_indir_block) << - log2_blksz) != indir1_blkno) { - status = ext2fs_devread (__le32_to_cpu(inode->b.blocks.double_indir_block) << log2_blksz, - 0, blksz, - (char *) indir1_block); - if (status == 0) { - printf ("** ext2fs read block (indir 2 1) failed. **\n"); - return (-1); - } - indir1_blkno = - __le32_to_cpu (inode->b.blocks.double_indir_block) << log2_blksz; - } - - if (indir2_block == NULL) { - indir2_block = (uint32_t *) memalign(ARCH_DMA_MINALIGN, - blksz); - if (indir2_block == NULL) { - printf ("** ext2fs read block (indir 2 2) malloc failed. **\n"); - return (-1); - } - indir2_size = blksz; - indir2_blkno = -1; - } - if (blksz != indir2_size) { - free (indir2_block); - indir2_block = NULL; - indir2_size = 0; - indir2_blkno = -1; - indir2_block = (uint32_t *) memalign(ARCH_DMA_MINALIGN, - blksz); - if (indir2_block == NULL) { - printf ("** ext2fs read block (indir 2 2) malloc failed. **\n"); - return (-1); - } - indir2_size = blksz; - } - if ((__le32_to_cpu (indir1_block[rblock / perblock]) << - log2_blksz) != indir2_blkno) { - status = ext2fs_devread (__le32_to_cpu(indir1_block[rblock / perblock]) << log2_blksz, - 0, blksz, - (char *) indir2_block); - if (status == 0) { - printf ("** ext2fs read block (indir 2 2) failed. **\n"); - return (-1); - } - indir2_blkno = - __le32_to_cpu (indir1_block[rblock / perblock]) << log2_blksz; - } - blknr = __le32_to_cpu (indir2_block[rblock % perblock]); - } - /* Tripple indirect. */ - else { - printf ("** ext2fs doesn't support tripple indirect blocks. **\n"); - return (-1); - } -#ifdef DEBUG - printf ("ext2fs_read_block %08x\n", blknr); -#endif - return (blknr); -} - - -int ext2fs_read_file - (ext2fs_node_t node, int pos, unsigned int len, char *buf) { - int i; - int blockcnt; - int log2blocksize = LOG2_EXT2_BLOCK_SIZE (node->data); - int blocksize = 1 << (log2blocksize + DISK_SECTOR_BITS); - unsigned int filesize = __le32_to_cpu(node->inode.size); - - /* Adjust len so it we can't read past the end of the file. */ - if (len > filesize) { - len = filesize; - } - blockcnt = ((len + pos) + blocksize - 1) / blocksize; - - for (i = pos / blocksize; i < blockcnt; i++) { - int blknr; - int blockoff = pos % blocksize; - int blockend = blocksize; - - int skipfirst = 0; - - blknr = ext2fs_read_block (node, i); - if (blknr < 0) { - return (-1); - } - blknr = blknr << log2blocksize; - - /* Last block. */ - if (i == blockcnt - 1) { - blockend = (len + pos) % blocksize; - - /* The last portion is exactly blocksize. */ - if (!blockend) { - blockend = blocksize; - } - } - - /* First block. */ - if (i == pos / blocksize) { - skipfirst = blockoff; - blockend -= skipfirst; - } - - /* If the block number is 0 this block is not stored on disk but - is zero filled instead. */ - if (blknr) { - int status; - - status = ext2fs_devread (blknr, skipfirst, blockend, buf); - if (status == 0) { - return (-1); - } - } else { - memset (buf, 0, blocksize - skipfirst); - } - buf += blocksize - skipfirst; - } - return (len); -} - - -static int ext2fs_iterate_dir (ext2fs_node_t dir, char *name, ext2fs_node_t * fnode, int *ftype) -{ - unsigned int fpos = 0; - int status; - struct ext2fs_node *diro = (struct ext2fs_node *) dir; - -#ifdef DEBUG - if (name != NULL) - printf ("Iterate dir %s\n", name); -#endif /* of DEBUG */ - if (!diro->inode_read) { - status = ext2fs_read_inode (diro->data, diro->ino, - &diro->inode); - if (status == 0) { - return (0); - } - } - /* Search the file. */ - while (fpos < __le32_to_cpu (diro->inode.size)) { - struct ext2_dirent dirent; - - status = ext2fs_read_file (diro, fpos, - sizeof (struct ext2_dirent), - (char *) &dirent); - if (status < 1) { - return (0); - } - if (dirent.namelen != 0) { - char filename[dirent.namelen + 1]; - ext2fs_node_t fdiro; - int type = FILETYPE_UNKNOWN; - - status = ext2fs_read_file (diro, - fpos + sizeof (struct ext2_dirent), - dirent.namelen, filename); - if (status < 1) { - return (0); - } - fdiro = malloc (sizeof (struct ext2fs_node)); - if (!fdiro) { - return (0); - } - - fdiro->data = diro->data; - fdiro->ino = __le32_to_cpu (dirent.inode); - - filename[dirent.namelen] = '\0'; - - if (dirent.filetype != FILETYPE_UNKNOWN) { - fdiro->inode_read = 0; - - if (dirent.filetype == FILETYPE_DIRECTORY) { - type = FILETYPE_DIRECTORY; - } else if (dirent.filetype == - FILETYPE_SYMLINK) { - type = FILETYPE_SYMLINK; - } else if (dirent.filetype == FILETYPE_REG) { - type = FILETYPE_REG; - } - } else { - /* The filetype can not be read from the dirent, get it from inode */ - - status = ext2fs_read_inode (diro->data, - __le32_to_cpu(dirent.inode), - &fdiro->inode); - if (status == 0) { - free (fdiro); - return (0); - } - fdiro->inode_read = 1; - - if ((__le16_to_cpu (fdiro->inode.mode) & - FILETYPE_INO_MASK) == - FILETYPE_INO_DIRECTORY) { - type = FILETYPE_DIRECTORY; - } else if ((__le16_to_cpu (fdiro->inode.mode) - & FILETYPE_INO_MASK) == - FILETYPE_INO_SYMLINK) { - type = FILETYPE_SYMLINK; - } else if ((__le16_to_cpu (fdiro->inode.mode) - & FILETYPE_INO_MASK) == - FILETYPE_INO_REG) { - type = FILETYPE_REG; - } - } -#ifdef DEBUG - printf ("iterate >%s<\n", filename); -#endif /* of DEBUG */ - if ((name != NULL) && (fnode != NULL) - && (ftype != NULL)) { - if (strcmp (filename, name) == 0) { - *ftype = type; - *fnode = fdiro; - return (1); - } - } else { - if (fdiro->inode_read == 0) { - status = ext2fs_read_inode (diro->data, - __le32_to_cpu (dirent.inode), - &fdiro->inode); - if (status == 0) { - free (fdiro); - return (0); - } - fdiro->inode_read = 1; - } - switch (type) { - case FILETYPE_DIRECTORY: - printf ("<DIR> "); - break; - case FILETYPE_SYMLINK: - printf ("<SYM> "); - break; - case FILETYPE_REG: - printf (" "); - break; - default: - printf ("< ? > "); - break; - } - printf ("%10d %s\n", - __le32_to_cpu (fdiro->inode.size), - filename); - } - free (fdiro); - } - fpos += __le16_to_cpu (dirent.direntlen); - } - return (0); -} - - -static char *ext2fs_read_symlink (ext2fs_node_t node) { - char *symlink; - struct ext2fs_node *diro = node; - int status; - - if (!diro->inode_read) { - status = ext2fs_read_inode (diro->data, diro->ino, - &diro->inode); - if (status == 0) { - return (0); - } - } - symlink = malloc (__le32_to_cpu (diro->inode.size) + 1); - if (!symlink) { - return (0); - } - /* If the filesize of the symlink is bigger than - 60 the symlink is stored in a separate block, - otherwise it is stored in the inode. */ - if (__le32_to_cpu (diro->inode.size) <= 60) { - strncpy (symlink, diro->inode.b.symlink, - __le32_to_cpu (diro->inode.size)); - } else { - status = ext2fs_read_file (diro, 0, - __le32_to_cpu (diro->inode.size), - symlink); - if (status == 0) { - free (symlink); - return (0); - } - } - symlink[__le32_to_cpu (diro->inode.size)] = '\0'; - return (symlink); -} - - -int ext2fs_find_file1 - (const char *currpath, - ext2fs_node_t currroot, ext2fs_node_t * currfound, int *foundtype) { - char fpath[strlen (currpath) + 1]; - char *name = fpath; - char *next; - int status; - int type = FILETYPE_DIRECTORY; - ext2fs_node_t currnode = currroot; - ext2fs_node_t oldnode = currroot; - - strncpy (fpath, currpath, strlen (currpath) + 1); - - /* Remove all leading slashes. */ - while (*name == '/') { - name++; - } - if (!*name) { - *currfound = currnode; - return (1); - } - - for (;;) { - int found; - - /* Extract the actual part from the pathname. */ - next = strchr (name, '/'); - if (next) { - /* Remove all leading slashes. */ - while (*next == '/') { - *(next++) = '\0'; - } - } - - /* At this point it is expected that the current node is a directory, check if this is true. */ - if (type != FILETYPE_DIRECTORY) { - ext2fs_free_node (currnode, currroot); - return (0); - } - - oldnode = currnode; - - /* Iterate over the directory. */ - found = ext2fs_iterate_dir (currnode, name, &currnode, &type); - if (found == 0) { - return (0); - } - if (found == -1) { - break; - } - - /* Read in the symlink and follow it. */ - if (type == FILETYPE_SYMLINK) { - char *symlink; - - /* Test if the symlink does not loop. */ - if (++symlinknest == 8) { - ext2fs_free_node (currnode, currroot); - ext2fs_free_node (oldnode, currroot); - return (0); - } - - symlink = ext2fs_read_symlink (currnode); - ext2fs_free_node (currnode, currroot); - - if (!symlink) { - ext2fs_free_node (oldnode, currroot); - return (0); - } -#ifdef DEBUG - printf ("Got symlink >%s<\n", symlink); -#endif /* of DEBUG */ - /* The symlink is an absolute path, go back to the root inode. */ - if (symlink[0] == '/') { - ext2fs_free_node (oldnode, currroot); - oldnode = &ext2fs_root->diropen; - } - - /* Lookup the node the symlink points to. */ - status = ext2fs_find_file1 (symlink, oldnode, - &currnode, &type); - - free (symlink); - - if (status == 0) { - ext2fs_free_node (oldnode, currroot); - return (0); - } - } - - ext2fs_free_node (oldnode, currroot); - - /* Found the node! */ - if (!next || *next == '\0') { - *currfound = currnode; - *foundtype = type; - return (1); - } - name = next; - } - return (-1); -} - - -int ext2fs_find_file - (const char *path, - ext2fs_node_t rootnode, ext2fs_node_t * foundnode, int expecttype) { - int status; - int foundtype = FILETYPE_DIRECTORY; - - - symlinknest = 0; - if (!path) { - return (0); - } - - status = ext2fs_find_file1 (path, rootnode, foundnode, &foundtype); - if (status == 0) { - return (0); - } - /* Check if the node that was found was of the expected type. */ - if ((expecttype == FILETYPE_REG) && (foundtype != expecttype)) { - return (0); - } else if ((expecttype == FILETYPE_DIRECTORY) - && (foundtype != expecttype)) { - return (0); - } - return (1); -} - - -int ext2fs_ls (const char *dirname) { - ext2fs_node_t dirnode; - int status; - - if (ext2fs_root == NULL) { - return (0); - } - - status = ext2fs_find_file (dirname, &ext2fs_root->diropen, &dirnode, - FILETYPE_DIRECTORY); - if (status != 1) { - printf ("** Can not find directory. **\n"); - return (1); - } - ext2fs_iterate_dir (dirnode, NULL, NULL, NULL); - ext2fs_free_node (dirnode, &ext2fs_root->diropen); - return (0); -} - - -int ext2fs_open (const char *filename) { - ext2fs_node_t fdiro = NULL; - int status; - int len; - - if (ext2fs_root == NULL) { - return (-1); - } - ext2fs_file = NULL; - status = ext2fs_find_file (filename, &ext2fs_root->diropen, &fdiro, - FILETYPE_REG); - if (status == 0) { - goto fail; - } - if (!fdiro->inode_read) { - status = ext2fs_read_inode (fdiro->data, fdiro->ino, - &fdiro->inode); - if (status == 0) { - goto fail; - } - } - len = __le32_to_cpu (fdiro->inode.size); - ext2fs_file = fdiro; - return (len); - -fail: - ext2fs_free_node (fdiro, &ext2fs_root->diropen); - return (-1); -} - - -int ext2fs_close (void - ) { - if ((ext2fs_file != NULL) && (ext2fs_root != NULL)) { - ext2fs_free_node (ext2fs_file, &ext2fs_root->diropen); - ext2fs_file = NULL; - } - if (ext2fs_root != NULL) { - free (ext2fs_root); - ext2fs_root = NULL; - } - if (indir1_block != NULL) { - free (indir1_block); - indir1_block = NULL; - indir1_size = 0; - indir1_blkno = -1; - } - if (indir2_block != NULL) { - free (indir2_block); - indir2_block = NULL; - indir2_size = 0; - indir2_blkno = -1; - } - return (0); -} - - -int ext2fs_read (char *buf, unsigned len) { - int status; - - if (ext2fs_root == NULL) { - return (0); - } - - if (ext2fs_file == NULL) { - return (0); - } - - status = ext2fs_read_file (ext2fs_file, 0, len, buf); - return (status); -} - - -int ext2fs_mount (unsigned part_length) { - struct ext2_data *data; - int status; - - data = malloc (sizeof (struct ext2_data)); - if (!data) { - return (0); - } - /* Read the superblock. */ - status = ext2fs_devread (1 * 2, 0, sizeof (struct ext2_sblock), - (char *) &data->sblock); - if (status == 0) { - goto fail; - } - /* Make sure this is an ext2 filesystem. */ - if (__le16_to_cpu (data->sblock.magic) != EXT2_MAGIC) { - goto fail; - } - if (__le32_to_cpu(data->sblock.revision_level == 0)) { - inode_size = 128; - } else { - inode_size = __le16_to_cpu(data->sblock.inode_size); - } -#ifdef DEBUG - printf("EXT2 rev %d, inode_size %d\n", - __le32_to_cpu(data->sblock.revision_level), inode_size); -#endif - data->diropen.data = data; - data->diropen.ino = 2; - data->diropen.inode_read = 1; - data->inode = &data->diropen.inode; - - status = ext2fs_read_inode (data, 2, data->inode); - if (status == 0) { - goto fail; - } - - ext2fs_root = data; - - return (1); - -fail: - printf ("Failed to mount ext2 filesystem...\n"); - free (data); - ext2fs_root = NULL; - return (0); -} diff --git a/fs/ext2/Makefile b/fs/ext4/Makefile similarity index 89% rename from fs/ext2/Makefile rename to fs/ext4/Makefile index 3c65d25..7b7fcbd 100644 --- a/fs/ext2/Makefile +++ b/fs/ext4/Makefile @@ -27,15 +27,17 @@
include $(TOPDIR)/config.mk
-LIB = $(obj)libext2fs.o +LIB = $(obj)libext4fs.o
AOBJS = -COBJS-$(CONFIG_CMD_EXT2) := ext2fs.o dev.o +COBJS-$(CONFIG_CMD_EXT4) := ext4fs.o ext4_common.o dev.o +ifndef CONFIG_CMD_EXT4 +COBJS-$(CONFIG_CMD_EXT2) := ext4fs.o ext4_common.o dev.o +endif
SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y))
-#CPPFLAGS +=
all: $(LIB) $(AOBJS)
diff --git a/fs/ext4/dev.c b/fs/ext4/dev.c new file mode 100644 index 0000000..fb62f24 --- /dev/null +++ b/fs/ext4/dev.c @@ -0,0 +1,145 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * made from existing ext2/dev.c file of Uboot + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code of fs/reiserfs/dev.c by + * + * (C) Copyright 2003 - 2004 + * Sysgo AG, <www.elinos.com>, Pavel Bartusek pba@sysgo.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * + */ + +/* + * Changelog: + * 0.1 - Newly created file for ext4fs support. Taken from + * fs/ext2/dev.c file in uboot. + */ + +#include <common.h> +#include <config.h> +#include <ext_common.h> + +static block_dev_desc_t *ext4fs_block_dev_desc; +static disk_partition_t part_info; + +int ext4fs_set_blk_dev(block_dev_desc_t *rbdd, int part) +{ + ext4fs_block_dev_desc = rbdd; + + if (part == 0) { + /* disk doesn't use partition table */ + part_info.start = 0; + part_info.size = rbdd->lba; + part_info.blksz = rbdd->blksz; + } else { + if (get_partition_info(ext4fs_block_dev_desc, + part, &part_info)) + return 0; + } + return part_info.size; +} + +int ext4fs_devread(int sector, int byte_offset, int byte_len, char *buf) +{ + char sec_buf[SECTOR_SIZE]; + unsigned block_len; + + /* Check partition boundaries */ + if ((sector < 0) + || ((sector + ((byte_offset + byte_len - 1) >> SECTOR_BITS)) >= + part_info.size)) { + printf("%s read outside partition %d\n", __func__, sector); + return 0; + } + + /* Get the read to the beginning of a partition */ + sector += byte_offset >> SECTOR_BITS; + byte_offset &= SECTOR_SIZE - 1; + + debug(" <%d, %d, %d>\n", sector, byte_offset, byte_len); + + if (ext4fs_block_dev_desc == NULL) { + printf("** Invalid Block Device Descriptor (NULL)\n"); + return 0; + } + + if (byte_offset != 0) { + /* read first part which isn't aligned with start of sector */ + if (ext4fs_block_dev_desc-> + block_read(ext4fs_block_dev_desc->dev, + part_info.start + sector, 1, + (unsigned long *) sec_buf) != 1) { + printf(" ** ext2fs_devread() read error **\n"); + return 0; + } + memcpy(buf, sec_buf + byte_offset, + min(SECTOR_SIZE - byte_offset, byte_len)); + buf += min(SECTOR_SIZE - byte_offset, byte_len); + byte_len -= min(SECTOR_SIZE - byte_offset, byte_len); + sector++; + } + + if (byte_len == 0) + return 1; + + /* read sector aligned part */ + block_len = byte_len & ~(SECTOR_SIZE - 1); + + if (block_len == 0) { + u8 p[SECTOR_SIZE]; + + block_len = SECTOR_SIZE; + ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc->dev, + part_info.start + sector, + 1, (unsigned long *)p); + memcpy(buf, p, byte_len); + return 1; + } + + if (ext4fs_block_dev_desc->block_read(ext4fs_block_dev_desc->dev, + part_info.start + sector, + block_len / SECTOR_SIZE, + (unsigned long *) buf) != + block_len / SECTOR_SIZE) { + printf(" ** %s read error - block\n", __func__); + return 0; + } + block_len = byte_len & ~(SECTOR_SIZE - 1); + buf += block_len; + byte_len -= block_len; + sector += block_len / SECTOR_SIZE; + + if (byte_len != 0) { + /* read rest of data which are not in whole sector */ + if (ext4fs_block_dev_desc-> + block_read(ext4fs_block_dev_desc->dev, + part_info.start + sector, 1, + (unsigned long *) sec_buf) != 1) { + printf("* %s read error - last part\n", __func__); + return 0; + } + memcpy(buf, sec_buf, byte_len); + } + return 1; +} diff --git a/fs/ext4/ext4_common.c b/fs/ext4/ext4_common.c new file mode 100644 index 0000000..2ddbb50 --- /dev/null +++ b/fs/ext4/ext4_common.c @@ -0,0 +1,875 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * ext4ls and ext4load : Based on ext2 ls load support in Uboot. + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code from grub2 fs/ext2.c and fs/fshelp.c by + * GRUB -- GRand Unified Bootloader + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <malloc.h> +#include <stddef.h> +#include <linux/stat.h> +#include <linux/time.h> +#include <asm/byteorder.h> +#include "ext4_common.h" + +struct ext2_data *ext4fs_root; +struct ext2fs_node *ext4fs_file; +uint32_t *ext4fs_indir1_block; +int ext4fs_indir1_size; +int ext4fs_indir1_blkno = -1; +uint32_t *ext4fs_indir2_block; +int ext4fs_indir2_size; +int ext4fs_indir2_blkno = -1; + +uint32_t *ext4fs_indir3_block; +int ext4fs_indir3_size; +int ext4fs_indir3_blkno = -1; +struct ext2_inode *g_parent_inode; +static int symlinknest; + +static struct ext4_extent_header *ext4fs_get_extent_block + (struct ext2_data *data, char *buf, + struct ext4_extent_header *ext_block, + uint32_t fileblock, int log2_blksz) +{ + struct ext4_extent_idx *index; + unsigned long long block; + struct ext_filesystem *fs = get_fs(); + int i; + + while (1) { + index = (struct ext4_extent_idx *)(ext_block + 1); + + if (le32_to_cpu(ext_block->eh_magic) != EXT4_EXT_MAGIC) + return 0; + + if (ext_block->eh_depth == 0) + return ext_block; + i = -1; + do { + i++; + if (i >= le32_to_cpu(ext_block->eh_entries)) + break; + } while (fileblock > le32_to_cpu(index[i].ei_block)); + + if (--i < 0) + return 0; + + block = le32_to_cpu(index[i].ei_leaf_hi); + block = (block << 32) + le32_to_cpu(index[i].ei_leaf_lo); + + if (ext4fs_devread(block << log2_blksz, 0, fs->blksz, buf)) + ext_block = (struct ext4_extent_header *)buf; + else + return 0; + } +} + +static int ext4fs_blockgroup + (struct ext2_data *data, int group, struct ext2_block_group *blkgrp) +{ + long int blkno; + unsigned int blkoff, desc_per_blk; + + desc_per_blk = EXT2_BLOCK_SIZE(data) / sizeof(struct ext2_block_group); + + blkno = __le32_to_cpu(data->sblock.first_data_block) + 1 + + group / desc_per_blk; + blkoff = (group % desc_per_blk) * sizeof(struct ext2_block_group); + + debug("ext4fs read %d group descriptor (blkno %ld blkoff %u)\n", + group, blkno, blkoff); + + return ext4fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data), + blkoff, sizeof(struct ext2_block_group), + (char *)blkgrp); +} + +int ext4fs_read_inode(struct ext2_data *data, int ino, struct ext2_inode *inode) +{ + struct ext2_block_group blkgrp; + struct ext2_sblock *sblock = &data->sblock; + struct ext_filesystem *fs = get_fs(); + int inodes_per_block, status; + long int blkno; + unsigned int blkoff; + + /* It is easier to calculate if the first inode is 0. */ + ino--; + status = ext4fs_blockgroup(data, ino / __le32_to_cpu + (sblock->inodes_per_group), &blkgrp); + if (status == 0) + return 0; + + inodes_per_block = EXT2_BLOCK_SIZE(data) / fs->inodesz; + blkno = __le32_to_cpu(blkgrp.inode_table_id) + + (ino % __le32_to_cpu(sblock->inodes_per_group)) / inodes_per_block; + blkoff = (ino % inodes_per_block) * fs->inodesz; + /* Read the inode. */ + status = ext4fs_devread(blkno << LOG2_EXT2_BLOCK_SIZE(data), blkoff, + sizeof(struct ext2_inode), (char *)inode); + if (status == 0) + return 0; + + return 1; +} + +long int read_allocated_block(struct ext2_inode *inode, int fileblock) +{ + long int blknr; + int blksz; + int log2_blksz; + int status; + long int rblock; + long int perblock_parent; + long int perblock_child; + unsigned long long start; + /* get the blocksize of the filesystem */ + blksz = EXT2_BLOCK_SIZE(ext4fs_root); + log2_blksz = LOG2_EXT2_BLOCK_SIZE(ext4fs_root); + if (le32_to_cpu(inode->flags) & EXT4_EXTENTS_FL) { + char *buf = zalloc(blksz); + if (!buf) + return -ENOMEM; + struct ext4_extent_header *ext_block; + struct ext4_extent *extent; + int i = -1; + ext_block = ext4fs_get_extent_block(ext4fs_root, buf, + (struct ext4_extent_header + *)inode->b. + blocks.dir_blocks, + fileblock, log2_blksz); + if (!ext_block) { + printf("invalid extent block\n"); + free(buf); + return -EINVAL; + } + + extent = (struct ext4_extent *)(ext_block + 1); + + do { + i++; + if (i >= le32_to_cpu(ext_block->eh_entries)) + break; + } while (fileblock >= le32_to_cpu(extent[i].ee_block)); + if (--i >= 0) { + fileblock -= le32_to_cpu(extent[i].ee_block); + if (fileblock >= le32_to_cpu(extent[i].ee_len)) { + free(buf); + return 0; + } + + start = le32_to_cpu(extent[i].ee_start_hi); + start = (start << 32) + + le32_to_cpu(extent[i].ee_start_lo); + free(buf); + return fileblock + start; + } + + printf("Extent Error\n"); + free(buf); + return -1; + } + + /* Direct blocks. */ + if (fileblock < INDIRECT_BLOCKS) + blknr = __le32_to_cpu(inode->b.blocks.dir_blocks[fileblock]); + + /* Indirect. */ + else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4))) { + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** SI ext2fs read block (indir 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** SI ext2fs read block (indir 1):" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = + ext4fs_devread(__le32_to_cpu + (inode->b.blocks. + indir_block) << log2_blksz, 0, + blksz, (char *)ext4fs_indir1_block); + if (status == 0) { + printf("** SI ext2fs read block (indir 1)" + "failed. **\n"); + return 0; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks. + indir_block) << log2_blksz; + } + blknr = __le32_to_cpu(ext4fs_indir1_block + [fileblock - INDIRECT_BLOCKS]); + } + /* Double indirect. */ + else if (fileblock < (INDIRECT_BLOCKS + (blksz / 4 * + (blksz / 4 + 1)))) { + + long int perblock = blksz / 4; + long int rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4); + + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** DI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** DI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.double_indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = + ext4fs_devread(__le32_to_cpu + (inode->b.blocks. + double_indir_block) << log2_blksz, + 0, blksz, + (char *)ext4fs_indir1_block); + if (status == 0) { + printf("** DI ext2fs read block (indir 2 1)" + "failed. **\n"); + return -1; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks.double_indir_block) << + log2_blksz; + } + + if (ext4fs_indir2_block == NULL) { + ext4fs_indir2_block = zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** DI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + ext4fs_indir2_blkno = -1; + } + if (blksz != ext4fs_indir2_size) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + ext4fs_indir2_block = zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** DI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir1_block[rblock / perblock]) << + log2_blksz) != ext4fs_indir2_blkno) { + status = ext4fs_devread(__le32_to_cpu + (ext4fs_indir1_block + [rblock / + perblock]) << log2_blksz, 0, + blksz, + (char *)ext4fs_indir2_block); + if (status == 0) { + printf("** DI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir2_blkno = + __le32_to_cpu(ext4fs_indir1_block[rblock + / + perblock]) << + log2_blksz; + } + blknr = __le32_to_cpu(ext4fs_indir2_block[rblock % perblock]); + } + /* Tripple indirect. */ + else { + rblock = fileblock - (INDIRECT_BLOCKS + blksz / 4 + + (blksz / 4 * blksz / 4)); + perblock_child = blksz / 4; + perblock_parent = ((blksz / 4) * (blksz / 4)); + + if (ext4fs_indir1_block == NULL) { + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** TI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + ext4fs_indir1_blkno = -1; + } + if (blksz != ext4fs_indir1_size) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + ext4fs_indir1_block = zalloc(blksz); + if (ext4fs_indir1_block == NULL) { + printf("** TI ext2fs read block (indir 2 1)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir1_size = blksz; + } + if ((__le32_to_cpu(inode->b.blocks.triple_indir_block) << + log2_blksz) != ext4fs_indir1_blkno) { + status = ext4fs_devread + (__le32_to_cpu(inode->b.blocks.triple_indir_block) + << log2_blksz, 0, blksz, + (char *)ext4fs_indir1_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 1)" + "failed. **\n"); + return -1; + } + ext4fs_indir1_blkno = + __le32_to_cpu(inode->b.blocks.triple_indir_block) << + log2_blksz; + } + + if (ext4fs_indir2_block == NULL) { + ext4fs_indir2_block = zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + ext4fs_indir2_blkno = -1; + } + if (blksz != ext4fs_indir2_size) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + ext4fs_indir2_block = zalloc(blksz); + if (ext4fs_indir2_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir2_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir1_block[rblock / + perblock_parent]) << + log2_blksz) + != ext4fs_indir2_blkno) { + status = ext4fs_devread(__le32_to_cpu + (ext4fs_indir1_block + [rblock / + perblock_parent]) << + log2_blksz, 0, blksz, + (char *)ext4fs_indir2_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir2_blkno = + __le32_to_cpu(ext4fs_indir1_block[rblock / + perblock_parent]) + << log2_blksz; + } + + if (ext4fs_indir3_block == NULL) { + ext4fs_indir3_block = zalloc(blksz); + if (ext4fs_indir3_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir3_size = blksz; + ext4fs_indir3_blkno = -1; + } + if (blksz != ext4fs_indir3_size) { + free(ext4fs_indir3_block); + ext4fs_indir3_block = NULL; + ext4fs_indir3_size = 0; + ext4fs_indir3_blkno = -1; + ext4fs_indir3_block = zalloc(blksz); + if (ext4fs_indir3_block == NULL) { + printf("** TI ext2fs read block (indir 2 2)" + "malloc failed. **\n"); + return -1; + } + ext4fs_indir3_size = blksz; + } + if ((__le32_to_cpu(ext4fs_indir2_block[rblock + / + perblock_child]) << + log2_blksz) != ext4fs_indir3_blkno) { + status = + ext4fs_devread(__le32_to_cpu + (ext4fs_indir2_block + [(rblock / perblock_child) + % (blksz / 4)]) << log2_blksz, 0, + blksz, (char *)ext4fs_indir3_block); + if (status == 0) { + printf("** TI ext2fs read block (indir 2 2)" + "failed. **\n"); + return -1; + } + ext4fs_indir3_blkno = + __le32_to_cpu(ext4fs_indir2_block[(rblock / + perblock_child) % + (blksz / + 4)]) << + log2_blksz; + } + + blknr = __le32_to_cpu(ext4fs_indir3_block + [rblock % perblock_child]); + } + debug("ext4fs_read_block %ld\n", blknr); + + return blknr; +} + +void ext4fs_close(void) +{ + if ((ext4fs_file != NULL) && (ext4fs_root != NULL)) { + ext4fs_free_node(ext4fs_file, &ext4fs_root->diropen); + ext4fs_file = NULL; + } + if (ext4fs_root != NULL) { + free(ext4fs_root); + ext4fs_root = NULL; + } + if (ext4fs_indir1_block != NULL) { + free(ext4fs_indir1_block); + ext4fs_indir1_block = NULL; + ext4fs_indir1_size = 0; + ext4fs_indir1_blkno = -1; + } + if (ext4fs_indir2_block != NULL) { + free(ext4fs_indir2_block); + ext4fs_indir2_block = NULL; + ext4fs_indir2_size = 0; + ext4fs_indir2_blkno = -1; + } + if (ext4fs_indir3_block != NULL) { + free(ext4fs_indir3_block); + ext4fs_indir3_block = NULL; + ext4fs_indir3_size = 0; + ext4fs_indir3_blkno = -1; + } +} + +int ext4fs_iterate_dir(struct ext2fs_node *dir, char *name, + struct ext2fs_node **fnode, int *ftype) +{ + unsigned int fpos = 0; + int status; + struct ext2fs_node *diro = (struct ext2fs_node *) dir; + +#ifdef DEBUG + if (name != NULL) + printf("Iterate dir %s\n", name); +#endif /* of DEBUG */ + if (!diro->inode_read) { + status = ext4fs_read_inode(diro->data, diro->ino, &diro->inode); + if (status == 0) + return 0; + } + /* Search the file. */ + while (fpos < __le32_to_cpu(diro->inode.size)) { + struct ext2_dirent dirent; + + status = ext4fs_read_file(diro, fpos, + sizeof(struct ext2_dirent), + (char *) &dirent); + if (status < 1) + return 0; + + if (dirent.namelen != 0) { + char filename[dirent.namelen + 1]; + struct ext2fs_node *fdiro; + int type = FILETYPE_UNKNOWN; + + status = ext4fs_read_file(diro, + fpos + + sizeof(struct ext2_dirent), + dirent.namelen, filename); + if (status < 1) + return 0; + + fdiro = zalloc(sizeof(struct ext2fs_node)); + if (!fdiro) + return 0; + + fdiro->data = diro->data; + fdiro->ino = __le32_to_cpu(dirent.inode); + + filename[dirent.namelen] = '\0'; + + if (dirent.filetype != FILETYPE_UNKNOWN) { + fdiro->inode_read = 0; + + if (dirent.filetype == FILETYPE_DIRECTORY) + type = FILETYPE_DIRECTORY; + else if (dirent.filetype == FILETYPE_SYMLINK) + type = FILETYPE_SYMLINK; + else if (dirent.filetype == FILETYPE_REG) + type = FILETYPE_REG; + } else { + status = ext4fs_read_inode(diro->data, + __le32_to_cpu + (dirent.inode), + &fdiro->inode); + if (status == 0) { + free(fdiro); + return 0; + } + fdiro->inode_read = 1; + + if ((__le16_to_cpu(fdiro->inode.mode) & + FILETYPE_INO_MASK) == + FILETYPE_INO_DIRECTORY) { + type = FILETYPE_DIRECTORY; + } else if ((__le16_to_cpu(fdiro->inode.mode) + & FILETYPE_INO_MASK) == + FILETYPE_INO_SYMLINK) { + type = FILETYPE_SYMLINK; + } else if ((__le16_to_cpu(fdiro->inode.mode) + & FILETYPE_INO_MASK) == + FILETYPE_INO_REG) { + type = FILETYPE_REG; + } + } +#ifdef DEBUG + printf("iterate >%s<\n", filename); +#endif /* of DEBUG */ + if ((name != NULL) && (fnode != NULL) + && (ftype != NULL)) { + if (strcmp(filename, name) == 0) { + *ftype = type; + *fnode = fdiro; + return 1; + } + } else { + if (fdiro->inode_read == 0) { + status = ext4fs_read_inode(diro->data, + __le32_to_cpu( + dirent.inode), + &fdiro->inode); + if (status == 0) { + free(fdiro); + return 0; + } + fdiro->inode_read = 1; + } + switch (type) { + case FILETYPE_DIRECTORY: + printf("<DIR> "); + break; + case FILETYPE_SYMLINK: + printf("<SYM> "); + break; + case FILETYPE_REG: + printf(" "); + break; + default: + printf("< ? > "); + break; + } + printf("%10d %s\n", + __le32_to_cpu(fdiro->inode.size), + filename); + } + free(fdiro); + } + fpos += __le16_to_cpu(dirent.direntlen); + } + return 0; +} + +static char *ext4fs_read_symlink(struct ext2fs_node *node) +{ + char *symlink; + struct ext2fs_node *diro = node; + int status; + + if (!diro->inode_read) { + status = ext4fs_read_inode(diro->data, diro->ino, &diro->inode); + if (status == 0) + return 0; + } + symlink = zalloc(__le32_to_cpu(diro->inode.size) + 1); + if (!symlink) + return 0; + + if (__le32_to_cpu(diro->inode.size) <= 60) { + strncpy(symlink, diro->inode.b.symlink, + __le32_to_cpu(diro->inode.size)); + } else { + status = ext4fs_read_file(diro, 0, + __le32_to_cpu(diro->inode.size), + symlink); + if (status == 0) { + free(symlink); + return 0; + } + } + symlink[__le32_to_cpu(diro->inode.size)] = '\0'; + return symlink; +} + +static int ext4fs_find_file1(const char *currpath, + struct ext2fs_node *currroot, + struct ext2fs_node **currfound, int *foundtype) +{ + char fpath[strlen(currpath) + 1]; + char *name = fpath; + char *next; + int status; + int type = FILETYPE_DIRECTORY; + struct ext2fs_node *currnode = currroot; + struct ext2fs_node *oldnode = currroot; + + strncpy(fpath, currpath, strlen(currpath) + 1); + + /* Remove all leading slashes. */ + while (*name == '/') + name++; + + if (!*name) { + *currfound = currnode; + return 1; + } + + for (;;) { + int found; + + /* Extract the actual part from the pathname. */ + next = strchr(name, '/'); + if (next) { + /* Remove all leading slashes. */ + while (*next == '/') + *(next++) = '\0'; + } + + if (type != FILETYPE_DIRECTORY) { + ext4fs_free_node(currnode, currroot); + return 0; + } + + oldnode = currnode; + + /* Iterate over the directory. */ + found = ext4fs_iterate_dir(currnode, name, &currnode, &type); + if (found == 0) + return 0; + + if (found == -1) + break; + + /* Read in the symlink and follow it. */ + if (type == FILETYPE_SYMLINK) { + char *symlink; + + /* Test if the symlink does not loop. */ + if (++symlinknest == 8) { + ext4fs_free_node(currnode, currroot); + ext4fs_free_node(oldnode, currroot); + return 0; + } + + symlink = ext4fs_read_symlink(currnode); + ext4fs_free_node(currnode, currroot); + + if (!symlink) { + ext4fs_free_node(oldnode, currroot); + return 0; + } + + debug("Got symlink >%s<\n", symlink); + + if (symlink[0] == '/') { + ext4fs_free_node(oldnode, currroot); + oldnode = &ext4fs_root->diropen; + } + + /* Lookup the node the symlink points to. */ + status = ext4fs_find_file1(symlink, oldnode, + &currnode, &type); + + free(symlink); + + if (status == 0) { + ext4fs_free_node(oldnode, currroot); + return 0; + } + } + + ext4fs_free_node(oldnode, currroot); + + /* Found the node! */ + if (!next || *next == '\0') { + *currfound = currnode; + *foundtype = type; + return 1; + } + name = next; + } + return -1; +} + +int ext4fs_find_file(const char *path, struct ext2fs_node *rootnode, + struct ext2fs_node **foundnode, int expecttype) +{ + int status; + int foundtype = FILETYPE_DIRECTORY; + + symlinknest = 0; + if (!path) + return 0; + + status = ext4fs_find_file1(path, rootnode, foundnode, &foundtype); + if (status == 0) + return 0; + + /* Check if the node that was found was of the expected type. */ + if ((expecttype == FILETYPE_REG) && (foundtype != expecttype)) + return 0; + else if ((expecttype == FILETYPE_DIRECTORY) + && (foundtype != expecttype)) + return 0; + + return 1; +} + +int ext4fs_open(const char *filename) +{ + struct ext2fs_node *fdiro = NULL; + int status; + int len; + + if (ext4fs_root == NULL) + return -1; + + ext4fs_file = NULL; + status = ext4fs_find_file(filename, &ext4fs_root->diropen, &fdiro, + FILETYPE_REG); + if (status == 0) + goto fail; + + if (!fdiro->inode_read) { + status = ext4fs_read_inode(fdiro->data, fdiro->ino, + &fdiro->inode); + if (status == 0) + goto fail; + } + len = __le32_to_cpu(fdiro->inode.size); + ext4fs_file = fdiro; + + return len; +fail: + ext4fs_free_node(fdiro, &ext4fs_root->diropen); + + return -1; +} + +int ext4fs_mount(unsigned part_length) +{ + struct ext2_data *data; + int status; + struct ext_filesystem *fs = get_fs(); + data = zalloc(sizeof(struct ext2_data)); + if (!data) + return 0; + + /* Read the superblock. */ + status = ext4fs_devread(1 * 2, 0, sizeof(struct ext2_sblock), + (char *)&data->sblock); + + if (status == 0) + goto fail; + + /* Make sure this is an ext2 filesystem. */ + if (__le16_to_cpu(data->sblock.magic) != EXT2_MAGIC) + goto fail; + + if (__le32_to_cpu(data->sblock.revision_level == 0)) + fs->inodesz = 128; + else + fs->inodesz = __le16_to_cpu(data->sblock.inode_size); + + debug("EXT2 rev %d, inode_size %d\n", + __le32_to_cpu(data->sblock.revision_level), fs->inodesz); + + data->diropen.data = data; + data->diropen.ino = 2; + data->diropen.inode_read = 1; + data->inode = &data->diropen.inode; + + status = ext4fs_read_inode(data, 2, data->inode); + if (status == 0) + goto fail; + + ext4fs_root = data; + + return 1; +fail: + printf("Failed to mount ext2 filesystem...\n"); + free(data); + ext4fs_root = NULL; + + return 0; +} diff --git a/fs/ext4/ext4_common.h b/fs/ext4/ext4_common.h new file mode 100644 index 0000000..182049d --- /dev/null +++ b/fs/ext4/ext4_common.h @@ -0,0 +1,63 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * ext4ls and ext4load : based on ext2 ls load support in Uboot. + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code from grub2 fs/ext2.c and fs/fshelp.c by + * GRUB -- GRand Unified Bootloader + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __EXT4_COMMON__ +#define __EXT4_COMMON__ +#include <ext_common.h> +#include <ext4fs.h> +#include <malloc.h> +#include <asm/errno.h> + +#define YES 1 +#define NO 0 +#define TRUE 1 +#define FALSE 0 +#define RECOVER 1 +#define SCAN 0 + +#define S_IFLNK 0120000 /* symbolic link */ +#define BLOCK_NO_ONE 1 +#define SUPERBLOCK_SECTOR 2 +#define SUPERBLOCK_SIZE 1024 +#define F_FILE 1 + +#define zalloc(size) calloc(1, size) + +extern unsigned long part_offset; +int ext4fs_read_inode(struct ext2_data *data, int ino, + struct ext2_inode *inode); +int ext4fs_read_file(struct ext2fs_node *node, int pos, + unsigned int len, char *buf); +int ext4fs_find_file(const char *path, struct ext2fs_node *rootnode, + struct ext2fs_node **foundnode, int expecttype); +int ext4fs_iterate_dir(struct ext2fs_node *dir, char *name, + struct ext2fs_node **fnode, int *ftype); +#endif diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c new file mode 100644 index 0000000..1287bf0 --- /dev/null +++ b/fs/ext4/ext4fs.c @@ -0,0 +1,228 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * ext4ls and ext4load : Based on ext2 ls and load support in Uboot. + * Ext4 read optimization taken from Open-Moko + * Qi bootloader + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code from grub2 fs/ext2.c and fs/fshelp.c by + * GRUB -- GRand Unified Bootloader + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <malloc.h> +#include <ext_common.h> +#include <ext4fs.h> +#include <linux/stat.h> +#include <linux/time.h> +#include <asm/byteorder.h> +#include "ext4_common.h" + +int ext4fs_symlinknest; +block_dev_desc_t *ext4_dev_desc; + +struct ext_filesystem *get_fs(void) +{ + if (ext4_dev_desc == NULL || ext4_dev_desc->priv == NULL) + printf("Invalid Input Arguments %s\n", __func__); + + return ext4_dev_desc->priv; +} + +int init_fs(block_dev_desc_t *dev_desc) +{ + struct ext_filesystem *fs; + if (dev_desc == NULL) { + printf("Invalid Input Arguments %s\n", __func__); + return -EINVAL; + } + + fs = zalloc(sizeof(struct ext_filesystem)); + if (fs == NULL) { + printf("malloc failed: %s\n", __func__); + return -ENOMEM; + } + + fs->dev_desc = dev_desc; + dev_desc->priv = fs; + + return 0; +} + +void deinit_fs(block_dev_desc_t *dev_desc) +{ + if (dev_desc == NULL) { + printf("Invalid Input Arguments %s\n", __func__); + return; + } + free(dev_desc->priv); + dev_desc->priv = NULL; +} + +void ext4fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot) +{ + if ((node != &ext4fs_root->diropen) && (node != currroot)) + free(node); +} + +/* + * Taken from openmoko-kernel mailing list: By Andy green + * Optimized read file API : collects and defers contiguous sector + * reads into one potentially more efficient larger sequential read action + */ +int ext4fs_read_file(struct ext2fs_node *node, int pos, + unsigned int len, char *buf) +{ + int i; + int blockcnt; + int log2blocksize = LOG2_EXT2_BLOCK_SIZE(node->data); + int blocksize = 1 << (log2blocksize + DISK_SECTOR_BITS); + unsigned int filesize = __le32_to_cpu(node->inode.size); + int previous_block_number = -1; + int delayed_start = 0; + int delayed_extent = 0; + int delayed_skipfirst = 0; + int delayed_next = 0; + char *delayed_buf = NULL; + short status; + + /* Adjust len so it we can't read past the end of the file. */ + if (len > filesize) + len = filesize; + + blockcnt = ((len + pos) + blocksize - 1) / blocksize; + + for (i = pos / blocksize; i < blockcnt; i++) { + int blknr; + int blockoff = pos % blocksize; + int blockend = blocksize; + int skipfirst = 0; + blknr = read_allocated_block(&(node->inode), i); + if (blknr < 0) + return -1; + + blknr = blknr << log2blocksize; + + /* Last block. */ + if (i == blockcnt - 1) { + blockend = (len + pos) % blocksize; + + /* The last portion is exactly blocksize. */ + if (!blockend) + blockend = blocksize; + } + + /* First block. */ + if (i == pos / blocksize) { + skipfirst = blockoff; + blockend -= skipfirst; + } + if (blknr) { + int status; + + if (previous_block_number != -1) { + if (delayed_next == blknr) { + delayed_extent += blockend; + delayed_next += blockend >> SECTOR_BITS; + } else { /* spill */ + status = ext4fs_devread(delayed_start, + delayed_skipfirst, + delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = blknr; + delayed_start = blknr; + delayed_extent = blockend; + delayed_skipfirst = skipfirst; + delayed_buf = buf; + delayed_next = blknr + + (blockend >> SECTOR_BITS); + } + } else { + previous_block_number = blknr; + delayed_start = blknr; + delayed_extent = blockend; + delayed_skipfirst = skipfirst; + delayed_buf = buf; + delayed_next = blknr + + (blockend >> SECTOR_BITS); + } + } else { + if (previous_block_number != -1) { + /* spill */ + status = ext4fs_devread(delayed_start, + delayed_skipfirst, + delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = -1; + } + memset(buf, 0, blocksize - skipfirst); + } + buf += blocksize - skipfirst; + } + if (previous_block_number != -1) { + /* spill */ + status = ext4fs_devread(delayed_start, + delayed_skipfirst, delayed_extent, + delayed_buf); + if (status == 0) + return -1; + previous_block_number = -1; + } + + return len; +} + +int ext4fs_ls(const char *dirname) +{ + struct ext2fs_node *dirnode; + int status; + + if (dirname == NULL) + return 0; + + status = ext4fs_find_file(dirname, &ext4fs_root->diropen, &dirnode, + FILETYPE_DIRECTORY); + if (status != 1) { + printf("** Can not find directory. **\n"); + return 1; + } + + ext4fs_iterate_dir(dirnode, NULL, NULL, NULL); + ext4fs_free_node(dirnode, &ext4fs_root->diropen); + + return 0; +} + +int ext4fs_read(char *buf, unsigned len) +{ + if (ext4fs_root == NULL || ext4fs_file == NULL) + return 0; + + return ext4fs_read_file(ext4fs_file, 0, len, buf); +} diff --git a/include/ext2fs.h b/include/ext2fs.h deleted file mode 100644 index 163a9bb..0000000 --- a/include/ext2fs.h +++ /dev/null @@ -1,81 +0,0 @@ -/* - * GRUB -- GRand Unified Bootloader - * Copyright (C) 2000, 2001 Free Software Foundation, Inc. - * - * (C) Copyright 2003 Sysgo Real-Time Solutions, AG <www.elinos.com> - * Pavel Bartusek pba@sysgo.de - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; either version 2 of the License, or - * (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. - */ - -/* An implementation for the Ext2FS filesystem ported from GRUB. - * Some parts of this code (mainly the structures and defines) are - * from the original ext2 fs code, as found in the linux kernel. - */ - - -#define SECTOR_SIZE 0x200 -#define SECTOR_BITS 9 - -/* Error codes */ -typedef enum -{ - ERR_NONE = 0, - ERR_BAD_FILENAME, - ERR_BAD_FILETYPE, - ERR_BAD_GZIP_DATA, - ERR_BAD_GZIP_HEADER, - ERR_BAD_PART_TABLE, - ERR_BAD_VERSION, - ERR_BELOW_1MB, - ERR_BOOT_COMMAND, - ERR_BOOT_FAILURE, - ERR_BOOT_FEATURES, - ERR_DEV_FORMAT, - ERR_DEV_VALUES, - ERR_EXEC_FORMAT, - ERR_FILELENGTH, - ERR_FILE_NOT_FOUND, - ERR_FSYS_CORRUPT, - ERR_FSYS_MOUNT, - ERR_GEOM, - ERR_NEED_LX_KERNEL, - ERR_NEED_MB_KERNEL, - ERR_NO_DISK, - ERR_NO_PART, - ERR_NUMBER_PARSING, - ERR_OUTSIDE_PART, - ERR_READ, - ERR_SYMLINK_LOOP, - ERR_UNRECOGNIZED, - ERR_WONT_FIT, - ERR_WRITE, - ERR_BAD_ARGUMENT, - ERR_UNALIGNED, - ERR_PRIVILEGED, - ERR_DEV_NEED_INIT, - ERR_NO_DISK_SPACE, - ERR_NUMBER_OVERFLOW, - - MAX_ERR_NUM -} ext2fs_error_t; - - -extern int ext2fs_set_blk_dev(block_dev_desc_t *rbdd, int part); -extern int ext2fs_ls (const char *dirname); -extern int ext2fs_open (const char *filename); -extern int ext2fs_read (char *buf, unsigned len); -extern int ext2fs_mount (unsigned part_length); -extern int ext2fs_close(void); diff --git a/include/ext4fs.h b/include/ext4fs.h new file mode 100644 index 0000000..55f9ccc --- /dev/null +++ b/include/ext4fs.h @@ -0,0 +1,132 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Ext4 Extent data structures are taken from original ext4 fs code + * as found in the linux kernel. + * + * Copyright (c) 2003-2006, Cluster File Systems, Inc, info@clusterfs.com + * Written by Alex Tomas alex@clusterfs.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __EXT4__ +#define __EXT4__ +#include <ext_common.h> + +#define EXT4_EXTENTS_FL 0x00080000 /* Inode uses extents */ +#define EXT4_EXT_MAGIC 0xf30a +#define EXT4_FEATURE_RO_COMPAT_GDT_CSUM 0x0010 +#define EXT4_FEATURE_INCOMPAT_EXTENTS 0x0040 +#define EXT4_INDIRECT_BLOCKS 12 + +#define EXT4_BG_INODE_UNINIT 0x0001 +#define EXT4_BG_BLOCK_UNINIT 0x0002 +#define EXT4_BG_INODE_ZEROED 0x0004 + +/* + * ext4_inode has i_block array (60 bytes total). + * The first 12 bytes store ext4_extent_header; + * the remainder stores an array of ext4_extent. + */ + +/* + * This is the extent on-disk structure. + * It's used at the bottom of the tree. + */ +struct ext4_extent { + __le32 ee_block; /* first logical block extent covers */ + __le16 ee_len; /* number of blocks covered by extent */ + __le16 ee_start_hi; /* high 16 bits of physical block */ + __le32 ee_start_lo; /* low 32 bits of physical block */ +}; + +/* + * This is index on-disk structure. + * It's used at all the levels except the bottom. + */ +struct ext4_extent_idx { + __le32 ei_block; /* index covers logical blocks from 'block' */ + __le32 ei_leaf_lo; /* pointer to the physical block of the next * + * level. leaf or next index could be there */ + __le16 ei_leaf_hi; /* high 16 bits of physical block */ + __u16 ei_unused; +}; + +/* Each block (leaves and indexes), even inode-stored has header. */ +struct ext4_extent_header { + __le16 eh_magic; /* probably will support different formats */ + __le16 eh_entries; /* number of valid entries */ + __le16 eh_max; /* capacity of store in entries */ + __le16 eh_depth; /* has tree real underlying blocks? */ + __le32 eh_generation; /* generation of the tree */ +}; + +struct ext_filesystem { + /* Total Sector of partition */ + uint64_t total_sect; + /* Block size of partition */ + uint32_t blksz; + /* Inode size of partition */ + uint32_t inodesz; + /* Sectors per Block */ + uint32_t sect_perblk; + /* Group Descriptor Block Number */ + uint32_t gdtable_blkno; + /* Total block groups of partition */ + uint32_t no_blkgrp; + /* No of blocks required for bgdtable */ + uint32_t no_blk_pergdt; + /* Superblock */ + struct ext2_sblock *sb; + /* Block group descritpor table */ + struct ext2_block_group *gd; + char *gdtable; + + /* Block Bitmap Related */ + unsigned char **blk_bmaps; + long int curr_blkno; + uint16_t first_pass_bbmap; + + /* Inode Bitmap Related */ + unsigned char **inode_bmaps; + int curr_inode_no; + uint16_t first_pass_ibmap; + + /* Journal Related */ + + /* Block Device Descriptor */ + block_dev_desc_t *dev_desc; +}; + +extern block_dev_desc_t *ext4_dev_desc; +extern struct ext2_data *ext4fs_root; +extern struct ext2fs_node *ext4fs_file; + +struct ext_filesystem *get_fs(void); +int init_fs(block_dev_desc_t *dev_desc); +void deinit_fs(block_dev_desc_t *dev_desc); +int ext4fs_open(const char *filename); +int ext4fs_read(char *buf, unsigned len); +int ext4fs_mount(unsigned part_length); +void ext4fs_close(void); +int ext4fs_ls(const char *dirname); +void ext4fs_free_node(struct ext2fs_node *node, struct ext2fs_node *currroot); +int ext4fs_devread(int sector, int byte_offset, int byte_len, char *buf); +int ext4fs_set_blk_dev(block_dev_desc_t *rbdd, int part); +long int read_allocated_block(struct ext2_inode *inode, int fileblock); +#endif diff --git a/include/ext_common.h b/include/ext_common.h new file mode 100644 index 0000000..ef71e1d --- /dev/null +++ b/include/ext_common.h @@ -0,0 +1,197 @@ +/* + * (C) Copyright 2011 - 2012 Samsung Electronics + * EXT4 filesystem implementation in Uboot by + * Uma Shankar uma.shankar@samsung.com + * Manjunatha C Achar a.manjunatha@samsung.com + * + * Data structures and headers for ext4 support have been taken from + * ext2 ls load support in Uboot + * + * (C) Copyright 2004 + * esd gmbh <www.esd-electronics.com> + * Reinhard Arlt reinhard.arlt@esd-electronics.com + * + * based on code from grub2 fs/ext2.c and fs/fshelp.c by + * GRUB -- GRand Unified Bootloader + * Copyright (C) 2003, 2004 Free Software Foundation, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#ifndef __EXT_COMMON__ +#define __EXT_COMMON__ +#include <command.h> +#define SECTOR_SIZE 0x200 +#define SECTOR_BITS 9 + +/* Magic value used to identify an ext2 filesystem. */ +#define EXT2_MAGIC 0xEF53 +/* Amount of indirect blocks in an inode. */ +#define INDIRECT_BLOCKS 12 +/* Maximum lenght of a pathname. */ +#define EXT2_PATH_MAX 4096 +/* Maximum nesting of symlinks, used to prevent a loop. */ +#define EXT2_MAX_SYMLINKCNT 8 + +/* Filetype used in directory entry. */ +#define FILETYPE_UNKNOWN 0 +#define FILETYPE_REG 1 +#define FILETYPE_DIRECTORY 2 +#define FILETYPE_SYMLINK 7 + +/* Filetype information as used in inodes. */ +#define FILETYPE_INO_MASK 0170000 +#define FILETYPE_INO_REG 0100000 +#define FILETYPE_INO_DIRECTORY 0040000 +#define FILETYPE_INO_SYMLINK 0120000 +#define EXT2_ROOT_INO 2 /* Root inode */ + +/* Bits used as offset in sector */ +#define DISK_SECTOR_BITS 9 +/* The size of an ext2 block in bytes. */ +#define EXT2_BLOCK_SIZE(data) (1 << LOG2_BLOCK_SIZE(data)) + +/* Log2 size of ext2 block in 512 blocks. */ +#define LOG2_EXT2_BLOCK_SIZE(data) (__le32_to_cpu \ + (data->sblock.log2_block_size) + 1) + +/* Log2 size of ext2 block in bytes. */ +#define LOG2_BLOCK_SIZE(data) (__le32_to_cpu \ + (data->sblock.log2_block_size) + 10) +#define INODE_SIZE_FILESYSTEM(data) (__le32_to_cpu \ + (data->sblock.inode_size)) + +#define EXT2_FT_DIR 2 +#define SUCCESS 1 + +/* Macro-instructions used to manage several block sizes */ +#define EXT2_MIN_BLOCK_LOG_SIZE 10 /* 1024 */ +#define EXT2_MAX_BLOCK_LOG_SIZE 16 /* 65536 */ +#define EXT2_MIN_BLOCK_SIZE (1 << EXT2_MIN_BLOCK_LOG_SIZE) +#define EXT2_MAX_BLOCK_SIZE (1 << EXT2_MAX_BLOCK_LOG_SIZE) + +/* The ext2 superblock. */ +struct ext2_sblock { + uint32_t total_inodes; + uint32_t total_blocks; + uint32_t reserved_blocks; + uint32_t free_blocks; + uint32_t free_inodes; + uint32_t first_data_block; + uint32_t log2_block_size; + uint32_t log2_fragment_size; + uint32_t blocks_per_group; + uint32_t fragments_per_group; + uint32_t inodes_per_group; + uint32_t mtime; + uint32_t utime; + uint16_t mnt_count; + uint16_t max_mnt_count; + uint16_t magic; + uint16_t fs_state; + uint16_t error_handling; + uint16_t minor_revision_level; + uint32_t lastcheck; + uint32_t checkinterval; + uint32_t creator_os; + uint32_t revision_level; + uint16_t uid_reserved; + uint16_t gid_reserved; + uint32_t first_inode; + uint16_t inode_size; + uint16_t block_group_number; + uint32_t feature_compatibility; + uint32_t feature_incompat; + uint32_t feature_ro_compat; + uint32_t unique_id[4]; + char volume_name[16]; + char last_mounted_on[64]; + uint32_t compression_info; +}; + +struct ext2_block_group { + __u32 block_id; /* Blocks bitmap block */ + __u32 inode_id; /* Inodes bitmap block */ + __u32 inode_table_id; /* Inodes table block */ + __u16 free_blocks; /* Free blocks count */ + __u16 free_inodes; /* Free inodes count */ + __u16 used_dir_cnt; /* Directories count */ + __u16 bg_flags; + __u32 bg_reserved[2]; + __u16 bg_itable_unused; /* Unused inodes count */ + __u16 bg_checksum; /* crc16(s_uuid+grouo_num+group_desc)*/ +}; + +/* The ext2 inode. */ +struct ext2_inode { + uint16_t mode; + uint16_t uid; + uint32_t size; + uint32_t atime; + uint32_t ctime; + uint32_t mtime; + uint32_t dtime; + uint16_t gid; + uint16_t nlinks; + uint32_t blockcnt; /* Blocks of 512 bytes!! */ + uint32_t flags; + uint32_t osd1; + union { + struct datablocks { + uint32_t dir_blocks[INDIRECT_BLOCKS]; + uint32_t indir_block; + uint32_t double_indir_block; + uint32_t triple_indir_block; + } blocks; + char symlink[60]; + } b; + uint32_t version; + uint32_t acl; + uint32_t dir_acl; + uint32_t fragment_addr; + uint32_t osd2[3]; +}; + +/* The header of an ext2 directory entry. */ +struct ext2_dirent { + uint32_t inode; + uint16_t direntlen; + uint8_t namelen; + uint8_t filetype; +}; + +struct ext2fs_node { + struct ext2_data *data; + struct ext2_inode inode; + int ino; + int inode_read; +}; + +/* Information about a "mounted" ext2 filesystem. */ +struct ext2_data { + struct ext2_sblock sblock; + struct ext2_inode *inode; + struct ext2fs_node diropen; +}; + +int do_ext2ls(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +int do_ext2load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]); +int do_ext4_load(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]); +int do_ext4_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]); +int do_ext_load(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]); +int do_ext_ls(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]); +#endif
Dear Uma Shankar,
In message 1337961104-21198-1-git-send-email-uma.shankar@samsung.com you wrote:
Signed-off-by: Uma Shankar uma.shankar@samsung.com Signed-off-by: Manjunatha C Achar a.manjunatha@samsung.com Signed-off-by: Iqbal Shareef iqbal.ams@samsung.com Signed-off-by: Hakgoo Lee goodguy.lee@samsung.com
Changes for v4: - Redesigned ext2, ext4 command interface - Removed ext2 folder from fs/ - Memory Leak issue handled
Changes for v3: - Copyright has been updated in respective files - ext4fs has been made independant of ext2fs.c - Fixed API namespace - Removed endianness conversion API, used uboot defined API for the same - Fixed coding style issues - Moved README.ext4 file into doc folder
Changes for v2: - Code cleanup, changed comment style - camel case removed, resolved code alignment issues - memory allocation logic changed, removed busybox logic - Modified ext4 load to remove grub dependency (GPLv3) - Introduced new Config for ext4 write
Changes for v1: - Removed checkpatch warnings and errors - Moved common API's of ext2 and ext4 to one generic header file
Makefile | 2 +- common/Makefile | 6 + common/cmd_ext2.c | 219 +---------- common/cmd_ext4.c | 96 +++++ common/cmd_ext_common.c | 259 +++++++++++++ fs/Makefile | 5 +- fs/ext2/dev.c | 131 ------- fs/ext2/ext2fs.c | 897 -------------------------------------------- fs/{ext2 => ext4}/Makefile | 8 +- fs/ext4/dev.c | 145 +++++++ fs/ext4/ext4_common.c | 875 ++++++++++++++++++++++++++++++++++++++++++ fs/ext4/ext4_common.h | 63 +++ fs/ext4/ext4fs.c | 228 +++++++++++ include/ext2fs.h | 81 ---- include/ext4fs.h | 132 +++++++ include/ext_common.h | 197 ++++++++++ 16 files changed, 2028 insertions(+), 1316 deletions(-) create mode 100644 common/cmd_ext4.c create mode 100644 common/cmd_ext_common.c delete mode 100644 fs/ext2/dev.c delete mode 100644 fs/ext2/ext2fs.c rename fs/{ext2 => ext4}/Makefile (89%) create mode 100644 fs/ext4/dev.c create mode 100644 fs/ext4/ext4_common.c create mode 100644 fs/ext4/ext4_common.h create mode 100644 fs/ext4/ext4fs.c delete mode 100644 include/ext2fs.h create mode 100644 include/ext4fs.h create mode 100644 include/ext_common.h
As this is all untested code which replaces ext2 which is in active use by a large number of boards I decided to put this into a separate branch "ext4" for now so people can easiy test it. If there are no problems, or the problems have been fixed in time, we can merge this branch around when -rc1 comes out.
Hope this is OK with you.
On 08/09/2012 04:50 PM, Wolfgang Denk wrote:
Dear Uma Shankar,
I reported already that the prior version that ext4 has issues with sub-directories. I don't think that has been addressed in V5. Some directories show up fine and some don't. So it's kind of random whether u-boot can read a /boot directory. This was after full ubuntu installs. I'd guess a simple test with a couple of files and directories will not show the problem.
Rob
Dear Rob Herring,
Dear Uma Shankar,
It was crashing on ext2 for me ... maybe further tests are in place. Anyone willing to debug this btw ?
Best regards, Marek Vasut
Dear Rob Herring,
Do you have a specific test case that shows this behaviuour? I. e. either some script to create a directory hierarchy that triggers this bug, and/or a (small!) file system image or tarball we could use for testing?
Dear Rob Herring,
We really need a test case here. In my (certainly not very extensive) tests I didn't see such a problem.
Can you please describe what failed for you?
On 08/13/2012 06:52 AM, Wolfgang Denk wrote:
Dear Rob Herring,
I do an ubuntu install to a single ext4 fs and then ext2ls gives this:
EXT2 rev 1, inode_size 256 ext4fs read 0 group descriptor (blkno 1 blkoff 0) iterate >.< ext4fs read 0 group descriptor (blkno 1 blkoff 0) <DIR> 4096 . iterate >..< ext4fs read 0 group descriptor (blkno 1 blkoff 0) <DIR> 4096 .. iterate >lost+found< ext4fs read 0 group descriptor (blkno 1 blkoff 0) <DIR> 16384 lost+found iterate >etc< ext4fs read 832 group descriptor (blkno 7 blkoff 2048) <DIR> 4096 etc iterate >media< ext4fs read 416 group descriptor (blkno 4 blkoff 1024) <DIR> 4096 media iterate >var< ext4fs read 848 group descriptor (blkno 7 blkoff 2560) <DIR> 4096 var iterate >usr< ext4fs read 1760 group descriptor (blkno 14 blkoff 3072) <DIR> 0 usr iterate >mnt< ext4fs read 80 group descriptor (blkno 1 blkoff 2560) <DIR> 4096 mnt iterate >dev< ext4fs read 1152 group descriptor (blkno 10 blkoff 0) <DIR> 0 dev iterate >home< ext4fs read 1472 group descriptor (blkno 12 blkoff 2048) <DIR> 0 home iterate >run< ext4fs read 864 group descriptor (blkno 7 blkoff 3072) <DIR> 4096 run iterate >boot< ext4fs read 224 group descriptor (blkno 2 blkoff 3072) <DIR> 4096 boot iterate >tmp< ext4fs read 1184 group descriptor (blkno 10 blkoff 1024) <DIR> 0 tmp iterate >sbin< ext4fs read 576 group descriptor (blkno 5 blkoff 2048) <DIR> 4096 sbin iterate >proc< ext4fs read 1632 group descriptor (blkno 13 blkoff 3072) <DIR> 0 proc iterate >bin< ext4fs read 1216 group descriptor (blkno 10 blkoff 2048) <DIR> 0 bin
The problem is in the directories with sizes of 0. It does seem to be directories with higher blkno's. Perhaps the lack of support for hash table directory entries is a problem. Just guessing here as I don't know much about ext4 structure.
I haven't been able to produce a simple example just creating a bunch of files and directories, so only the disk after an ubuntu install has the problem.
Rob
Dear Rob Herring,
What exactly is the problem? The listing appears pretty normal to me?
It seems you enabled some debug feature? Which exactly? And you get the same results without debug, don't you?
Can you upload the image somewhere? And indicate which exact problems we should look for?
On 08/13/2012 02:17 PM, Wolfgang Denk wrote:
Dear Rob Herring,
The size for the directories are 0 instead of 4096 and those directories have no contents. An ext2ls on /usr in this example:
EXT2 rev 1, inode_size 256 ext4fs read 0 group descriptor (blkno 1 blkoff 0) Iterate dir usr iterate >.< iterate >..< iterate >lost+found< iterate >etc< iterate >media< iterate >var< iterate >usr< ext4fs read 1760 group descriptor (blkno 14 blkoff 3072)
Note only debug messages are printed. Not even '.' or '..' entries.
It's only a problem when it is the /boot directory which seems to be random from install to install.
Just defined DEBUG on ext_common.c and ext4fs.c. It happens either way.
Yes, I'll have to recreate one with a reasonable size.
Rob
Dear Rob Herring,
Did you manage to find time to create an image that couldbe used for testing this issue?
Dear Wolfgang Denk,
Dear Rob Herring,
Pavel is implementing block device support for sandbox ... I hope we can eventually use that to test.
On 09/02/2012 06:36 AM, Wolfgang Denk wrote:
Dear Rob Herring,
I tried, but unfortunately with a smaller partition it all works fine. So a 1.2GB partition was fine and a ~250GB partition was not. I'm not sure where the breaking point is. Perhaps just taking a hard disk with an x86 install to ext4 fs would be enough to test this. Doing this using highbank qemu model and the disk image being my laptop's drive, I don't see 0 length directories, but I do see other issues reading some directories:
Highbank #ext2ls scsi 0:1 /usr/ <DIR> 4096 . <DIR> 4096 .. <DIR> 69632 bin <DIR> 4096 games <DIR> 20480 include <DIR> 36864 lib <DIR> 4096 local <DIR> 12288 sbin <DIR> 12288 share <DIR> 4096 src <DIR> 4096 x86_64-linux-gnu <DIR> 4096 arm-linux-gnueabihf <DIR> 4096 arm-linux-gnueabi Highbank #ext2ls scsi 0:1 /usr/bin invalid extent block
I would say go ahead and merge this. It's at least usable for smaller /boot type partitions and may not show up on SD and MMC cards.
Rob
Dear Rob Herring,
[snip]
I took an Ubuntu install I had (for x86) that was on a USB drive, had been pretty extensively used, and was is ext4. I couldn't find any size 0 directories. Are you able to reproduce this problem on other hardware? Is the image in question NOT remountable as ext3 (extents is set, generated) ? My biggest concern is breakage among ext2/3 filesystems. Thanks!
Dear Rob Herring,
[snip]
What size partition? It is also fine for me with a small 1.2GB partition. I only see the problem with larger partitions (most of a 250GB drive).
I was under the impression that ext4 is not mountable as ext3.
Rob
Dear Rob Herring,
[snip]
This is a 240G partition.
You can go ext3->"ext4"->ext3, it's only when you have fsck rebuild and make use of extents, iirc, that it's no longer mountable as ext3.
Dear Tom Rini,
Dear Rob Herring,
[snip]
Maybe you can pick that loop block driver from Pavel [1] and try it on sandbox target? That might ease testing etc.
[1] http://patchwork.ozlabs.org/patch/182160/
On 09/13/2012 02:20 AM, Marek Vasut wrote:
Dear Tom Rini,
Dear Rob Herring,
In message 50244D5A.3080304@gmail.com you wrote: > I reported already that the prior version that ext4 has issues with > sub-directories. I don't think that has been addressed in V5. Some > directories show up fine and some don't. So it's kind of random > whether u-boot can read a /boot directory. This was after full > ubuntu installs. I'd guess a simple test with a couple of files and > directories will not show the problem.
[snip]
Only if Rob's image (which iirc is hooked up to a qemu target) still fails once attached that way. Rob, am I (a) remembering right that you see this on a qemu target and (b) if so does compressing the crap out of it yield a small enough file to put on dropbox or some other free cloud storage? Thanks!
Dear Tom Rini,
On 08/13/2012 06:52 AM, Wolfgang Denk wrote: > Dear Rob Herring, > > In message 50244D5A.3080304@gmail.com you wrote: >> I reported already that the prior version that ext4 has issues with >> sub-directories. I don't think that has been addressed in V5. Some >> directories show up fine and some don't. So it's kind of random >> whether u-boot can read a /boot directory. This was after full >> ubuntu installs. I'd guess a simple test with a couple of files and >> directories will not show the problem. > > We really need a test case here. In my (certainly not very extensive) > tests I didn't see such a problem. > > Can you please describe what failed for you?
[snip]
Folks? Thanks!
participants (9)
Graeme Russ
Mike Frysinger
Rob Herring
Uma Shankar
