[PATCH v2 1/3] mtd: spi-nor-ids: Add support for ESMT/EON EN25Q80B
The datasheet can be found here: https://www.esmt.com.tw/upload/pdf/ESMT/datasheets/EN25Q80B_Ver.E.pdf
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de Reviewed-by: Fabio Estevam festevam@gmail.com --- Changes in v2: * Add R-b tag from Fabio (Thanks!) --- drivers/mtd/spi/spi-nor-ids.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 38a287487ed..4e83b8c94c9 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -80,6 +80,7 @@ const struct flash_info spi_nor_ids[] = { #endif #ifdef CONFIG_SPI_FLASH_EON /* EON */ /* EON -- en25xxx */ + { INFO("en25q80b", 0x1c3014, 0, 64 * 1024, 16, SECT_4K) }, { INFO("en25q32b", 0x1c3016, 0, 64 * 1024, 64, 0) }, { INFO("en25q64", 0x1c3017, 0, 64 * 1024, 128, SECT_4K) }, { INFO("en25q128b", 0x1c3018, 0, 64 * 1024, 256, 0) },
The Sielaff i.MX6 Solo board is a control and HMI board for vending machines. Add support for this board.
The devicetree files are taken from pending changes in the Linux kernel that are available from linux-next and will likely be part of Linux v6.9.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- Changes in v2: * Implement changes suggested by Fabio (Thanks!) * Fix system reset and remove unneeded cpu_reset() * Add 'static const' to nfc_pads[] * Remove hostname from env * Remove options to disable caches * Enable watchdog and wdt command * Enable LTO --- arch/arm/dts/Makefile | 1 + arch/arm/dts/imx6dl-sielaff-u-boot.dtsi | 38 ++ arch/arm/dts/imx6dl-sielaff.dts | 533 ++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 10 + board/sielaff/imx6dl-sielaff/Kconfig | 15 + board/sielaff/imx6dl-sielaff/Makefile | 8 + board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c | 111 ++++ .../sielaff/imx6dl-sielaff/imx6dl-sielaff.env | 114 ++++ board/sielaff/imx6dl-sielaff/spl.c | 273 +++++++++ configs/imx6dl_sielaff_defconfig | 120 ++++ include/configs/imx6dl-sielaff.h | 25 + 11 files changed, 1248 insertions(+) create mode 100644 arch/arm/dts/imx6dl-sielaff-u-boot.dtsi create mode 100644 arch/arm/dts/imx6dl-sielaff.dts create mode 100644 board/sielaff/imx6dl-sielaff/Kconfig create mode 100644 board/sielaff/imx6dl-sielaff/Makefile create mode 100644 board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c create mode 100644 board/sielaff/imx6dl-sielaff/imx6dl-sielaff.env create mode 100644 board/sielaff/imx6dl-sielaff/spl.c create mode 100644 configs/imx6dl_sielaff_defconfig create mode 100644 include/configs/imx6dl-sielaff.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0fcae77cefe..d60fa1179af 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -930,6 +930,7 @@ dtb-y += \ imx6dl-riotboard.dtb \ imx6dl-sabreauto.dtb \ imx6dl-sabresd.dtb \ + imx6dl-sielaff.dtb \ imx6dl-wandboard-revd1.dtb \ imx6s-dhcom-drc02.dtb
diff --git a/arch/arm/dts/imx6dl-sielaff-u-boot.dtsi b/arch/arm/dts/imx6dl-sielaff-u-boot.dtsi new file mode 100644 index 00000000000..8f5a70ccb85 --- /dev/null +++ b/arch/arm/dts/imx6dl-sielaff-u-boot.dtsi @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +#include "imx6qdl-u-boot.dtsi" + +/ { + binman: binman { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + offset = <0x0>; + filename = "SPL"; + }; + + uboot: blob-ext@2 { + offset = <0x11000>; + filename = "u-boot.img"; + }; + }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog1>; + }; +}; + +&fec { + phy-mode = "rmii"; + phy-reset-gpios = <&gpio5 2 GPIO_ACTIVE_LOW>; + phy-reset-duration = <100>; +}; + +&gpmi { + fsl,legacy-bch-geometry; +}; diff --git a/arch/arm/dts/imx6dl-sielaff.dts b/arch/arm/dts/imx6dl-sielaff.dts new file mode 100644 index 00000000000..7de8d5f2651 --- /dev/null +++ b/arch/arm/dts/imx6dl-sielaff.dts @@ -0,0 +1,533 @@ +// SPDX-License-Identifier: GPL-2.0+ OR MIT +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +/dts-v1/; + +#include "imx6dl.dtsi" +#include <dt-bindings/clock/imx6qdl-clock.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> + +/ { + model = "Sielaff i.MX6 Solo"; + compatible = "sielaff,imx6dl-board", "fsl,imx6dl"; + + chosen { + stdout-path = &uart2; + }; + + backlight: pwm-backlight { + compatible = "pwm-backlight"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_backlight>; + pwms = <&pwm3 0 50000 0>; + brightness-levels = <0 0 64 88 112 136 184 232 255>; + default-brightness-level = <4>; + enable-gpios = <&gpio6 16 GPIO_ACTIVE_HIGH>; + power-supply = <®_backlight>; + }; + + cec { + compatible = "cec-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hdmi_cec>; + cec-gpios = <&gpio2 7 GPIO_ACTIVE_HIGH>; + hdmi-phandle = <&hdmi>; + }; + + enet_ref: clock-enet-ref { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <50000000>; + clock-output-names = "enet-ref"; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_keys>; + + key-0 { + gpios = <&gpio2 16 0>; + debounce-interval = <10>; + linux,code = <1>; + }; + + key-1 { + gpios = <&gpio3 27 0>; + debounce-interval = <10>; + linux,code = <2>; + }; + + key-2 { + gpios = <&gpio5 4 0>; + debounce-interval = <10>; + linux,code = <3>; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpio_leds>; + + led-debug { + label = "debug-led"; + gpios = <&gpio5 21 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "heartbeat"; + }; + }; + + memory@80000000 { + reg = <0x80000000 0x20000000>; + device_type = "memory"; + }; + + osc_eth_phy: clock-osc-eth-phy { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + clock-output-names = "osc-eth-phy"; + }; + + panel { + compatible = "lg,lb070wv8"; + backlight = <&backlight>; + power-supply = <®_3v3>; + + port { + panel_in_lvds: endpoint { + remote-endpoint = <&lvds_out>; + }; + }; + }; + + reg_3v3: regulator-3v3 { + compatible = "regulator-fixed"; + regulator-name = "3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_backlight: regulator-backlight { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_backlight>; + enable-active-high; + gpio = <&gpio1 23 GPIO_ACTIVE_HIGH>; + regulator-name = "backlight"; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; + + reg_usb_otg_vbus: regulator-usb-otg-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usbotg_vbus>; + enable-active-high; + gpio = <&gpio4 15 GPIO_ACTIVE_HIGH>; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; +}; + +&ecspi2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi2>; + cs-gpios = <&gpio5 29 GPIO_ACTIVE_LOW>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + reg = <0>; + spi-max-frequency = <20000000>; + }; +}; + +&fec { + /* + * Set PTP clock to external instead of internal reference, as the + * REF_CLK from the PHY is fed back into the i.MX6 and the GPR + * register needs to be set accordingly (see mach-imx6q.c). + */ + clocks = <&clks IMX6QDL_CLK_ENET>, + <&clks IMX6QDL_CLK_ENET>, + <&enet_ref>, + <&clks IMX6QDL_CLK_ENET_REF>; + clock-names = "ipg", "ahb", "ptp", "enet_out"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + phy-connection-type = "rmii"; + phy-handle = <ðphy>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy: ethernet-phy@1 { + reg = <1>; + clocks = <&osc_eth_phy>; + clock-names = "rmii-ref"; + micrel,led-mode = <1>; + reset-assert-us = <500>; + reset-deassert-us = <100>; + reset-gpios = <&gpio5 2 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&gpio1 { + gpio-line-names = + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "key-out", "key-in", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpio2 { + gpio-line-names = + "", "", "", "", "", "", "", "", + "lan9500a-rst", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&gpmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpmi_nand>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c4>; + status = "okay"; +}; + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + clock-frequency = <100000>; + status = "okay"; + + rtc@51 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + }; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + clock-frequency = <100000>; + status = "okay"; + + touchscreen@55 { + compatible = "sitronix,st1633"; + reg = <0x55>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_touch>; + interrupts = <18 IRQ_TYPE_EDGE_FALLING>; + interrupt-parent = <&gpio5>; + gpios = <&gpio1 2 GPIO_ACTIVE_LOW>; + status = "disabled"; + }; + + touchscreen@5d { + compatible = "goodix,gt928"; + reg = <0x5d>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_touch>; + interrupts = <18 IRQ_TYPE_LEVEL_LOW>; + interrupt-parent = <&gpio5>; + irq-gpios = <&gpio5 18 GPIO_ACTIVE_HIGH>; + reset-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>; + status = "disabled"; + }; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c4>; + clock-frequency = <100000>; + status = "okay"; +}; + +&ldb { + status = "okay"; + + lvds: lvds-channel@0 { + fsl,data-mapping = "spwg"; + fsl,data-width = <24>; + status = "okay"; + + port@4 { + reg = <4>; + + lvds_out: endpoint { + remote-endpoint = <&panel_in_lvds>; + }; + }; + }; +}; + +&pwm3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm3>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + status = "okay"; +}; + +&usbh1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbh1>; + disable-over-current; + status = "okay"; + + #address-cells = <1>; + #size-cells = <0>; + + usb1@1 { + compatible = "usb4b4,6570"; + reg = <1>; + clocks = <&clks IMX6QDL_CLK_CKO>; + + assigned-clocks = <&clks IMX6QDL_CLK_CKO>, + <&clks IMX6QDL_CLK_CKO2_SEL>; + assigned-clock-parents = <&clks IMX6QDL_CLK_CKO2>, + <&clks IMX6QDL_CLK_OSC>; + assigned-clock-rates = <12000000 0>; + }; +}; + +&usbotg { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usbotg>; + dr_mode = "host"; + over-current-active-low; + vbus-supply = <®_usb_otg_vbus>; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + cd-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + vmmc-supply = <®_3v3>; + voltage-ranges = <3300 3300>; + no-1-8-v; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX6QDL_PAD_RGMII_RD0__GPIO6_IO25 0x1b0b0 /* PMIC_IRQ */ + MX6QDL_PAD_SD2_DAT3__GPIO1_IO12 0x1b0b0 + MX6QDL_PAD_SD2_DAT1__GPIO1_IO14 0x1b0b0 + MX6QDL_PAD_SD2_DAT0__GPIO1_IO15 0x1b0b0 + MX6QDL_PAD_SD4_DAT0__GPIO2_IO08 0x1b0b0 + MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x1b0b0 + >; + }; + + pinctrl_backlight: backlightgrp { + fsl,pins = < + MX6QDL_PAD_NANDF_CS3__GPIO6_IO16 0x100b1 + >; + }; + + pinctrl_ecspi2: ecspi2grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__ECSPI2_MISO 0x100b1 + MX6QDL_PAD_CSI0_DAT9__ECSPI2_MOSI 0x100b1 + MX6QDL_PAD_CSI0_DAT8__ECSPI2_SCLK 0x100b1 + MX6QDL_PAD_CSI0_DAT11__GPIO5_IO29 0x100b1 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1b0b0 + MX6QDL_PAD_ENET_RX_ER__ENET_RX_ER 0x1b0b0 + MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x1b0b0 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x4001b0a8 + MX6QDL_PAD_EIM_A25__GPIO5_IO02 0x100b1 + >; + }; + + pinctrl_gpio_keys: gpiokeysgrp { + fsl,pins = < + MX6QDL_PAD_EIM_A22__GPIO2_IO16 0x1b080 + MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x1b080 + MX6QDL_PAD_EIM_A24__GPIO5_IO04 0x1b080 + >; + }; + + pinctrl_gpio_leds: gpioledsgrp { + fsl,pins = < + MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x1b0b0 + >; + }; + + pinctrl_gpmi_nand: gpminandgrp { + fsl,pins = < + MX6QDL_PAD_NANDF_CLE__NAND_CLE 0xb0b1 + MX6QDL_PAD_NANDF_ALE__NAND_ALE 0xb0b1 + MX6QDL_PAD_NANDF_WP_B__NAND_WP_B 0xb0b1 + MX6QDL_PAD_NANDF_RB0__NAND_READY_B 0xb000 + MX6QDL_PAD_NANDF_CS0__NAND_CE0_B 0xb0b1 + MX6QDL_PAD_SD4_CMD__NAND_RE_B 0xb0b1 + MX6QDL_PAD_SD4_CLK__NAND_WE_B 0xb0b1 + MX6QDL_PAD_NANDF_D0__NAND_DATA00 0xb0b1 + MX6QDL_PAD_NANDF_D1__NAND_DATA01 0xb0b1 + MX6QDL_PAD_NANDF_D2__NAND_DATA02 0xb0b1 + MX6QDL_PAD_NANDF_D3__NAND_DATA03 0xb0b1 + MX6QDL_PAD_NANDF_D4__NAND_DATA04 0xb0b1 + MX6QDL_PAD_NANDF_D5__NAND_DATA05 0xb0b1 + MX6QDL_PAD_NANDF_D6__NAND_DATA06 0xb0b1 + MX6QDL_PAD_NANDF_D7__NAND_DATA07 0xb0b1 + >; + }; + + pinctrl_hdmi_cec: hdmicecgrp { + fsl,pins = < + MX6QDL_PAD_EIM_A21__GPIO2_IO17 0x1b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_GPIO_5__I2C3_SCL 0x4001f8b1 + MX6QDL_PAD_GPIO_6__I2C3_SDA 0x4001f8b1 + >; + }; + + pinctrl_i2c4: i2c4grp { + fsl,pins = < + MX6QDL_PAD_GPIO_7__I2C4_SCL 0x4001b8b1 + MX6QDL_PAD_GPIO_8__I2C4_SDA 0x4001b8b1 + >; + }; + + pinctrl_pwm3: pwm3grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1 + >; + }; + + pinctrl_reg_backlight: regbacklightgrp { + fsl,pins = < + MX6QDL_PAD_ENET_REF_CLK__GPIO1_IO23 0x1b0b1 + >; + }; + + pinctrl_reg_usbotg_vbus: regusbotgvbusgrp { + fsl,pins = < + MX6QDL_PAD_KEY_ROW4__GPIO4_IO15 0x1b0b1 + >; + }; + + pinctrl_touch: touchgrp { + fsl,pins = < + MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x1b0b0 + MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x1b0b0 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6QDL_PAD_SD3_DAT7__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_SD3_DAT6__UART1_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT7__UART2_TX_DATA 0x1b0b1 + MX6QDL_PAD_SD4_DAT4__UART2_RX_DATA 0x1b0b1 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX6QDL_PAD_EIM_D24__UART3_TX_DATA 0x1b0b0 + MX6QDL_PAD_EIM_D25__UART3_RX_DATA 0x1b0b0 + >; + }; + + pinctrl_usbh1: usbh1grp { + fsl,pins = < + MX6QDL_PAD_GPIO_3__USB_H1_OC 0x1b0b1 + MX6QDL_PAD_CSI0_MCLK__CCM_CLKO1 0x1b0b0 + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL4__USB_OTG_OC 0x1b0b1 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x100b1 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX6QDL_PAD_GPIO_9__WDOG1_B 0x1b0b0 + >; + }; +}; diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 114cce4d9b9..15ee2b933f6 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -356,6 +356,15 @@ config TARGET_MX6Q_ACC select DM_THERMAL select SUPPORT_SPL
+config TARGET_MX6S_SIELAFF + bool "Sielaff i.MX6 Solo Board" + depends on MX6S + select BINMAN + select DM + select DM_THERMAL + select SUPPORT_SPL + imply CMD_DM + config TARGET_MX6SABREAUTO bool "mx6sabreauto" depends on MX6QDL @@ -708,6 +717,7 @@ source "board/softing/vining_2000/Kconfig" source "board/liebherr/display5/Kconfig" source "board/liebherr/mccmon6/Kconfig" source "board/logicpd/imx6/Kconfig" +source "board/sielaff/imx6dl-sielaff/Kconfig" source "board/solidrun/mx6cuboxi/Kconfig" source "board/somlabs/visionsom-6ull/Kconfig" source "board/technexion/pico-imx6/Kconfig" diff --git a/board/sielaff/imx6dl-sielaff/Kconfig b/board/sielaff/imx6dl-sielaff/Kconfig new file mode 100644 index 00000000000..1b74a7d90ee --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/Kconfig @@ -0,0 +1,15 @@ +if TARGET_MX6S_SIELAFF + +config SYS_BOARD + string + default "imx6dl-sielaff" + +config SYS_VENDOR + string + default "sielaff" + +config SYS_CONFIG_NAME + string + default "imx6dl-sielaff" + +endif diff --git a/board/sielaff/imx6dl-sielaff/Makefile b/board/sielaff/imx6dl-sielaff/Makefile new file mode 100644 index 00000000000..65cecfe6f6c --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ +# (C) Copyright 2022 Kontron Electronics GmbH + +ifdef CONFIG_SPL_BUILD +obj-y := spl.o +else +obj-y := imx6dl-sielaff.o +endif diff --git a/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c b/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c new file mode 100644 index 00000000000..4da084ed91c --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.c @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +#include <compiler.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-pins.h> +#include <asm/io.h> +#include <init.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const iomux_v3_cfg_t nfc_pads[] = { + MX6_PAD_NANDF_CLE__NAND_CLE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_ALE__NAND_ALE | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_WP_B__NAND_WP_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_RB0__NAND_READY_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS0__NAND_CE0_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS1__NAND_CE1_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS2__NAND_CE2_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_CS3__NAND_CE3_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CMD__NAND_RE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_CLK__NAND_WE_B | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D0__NAND_DATA00 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D1__NAND_DATA01 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D2__NAND_DATA02 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D3__NAND_DATA03 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D4__NAND_DATA04 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D5__NAND_DATA05 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D6__NAND_DATA06 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_NANDF_D7__NAND_DATA07 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_SD4_DAT0__NAND_DQS | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + return 0; +} + +static void setup_gpmi_nand(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* config gpmi nand iomux */ + imx_iomux_v3_setup_multiple_pads(nfc_pads, + ARRAY_SIZE(nfc_pads)); + + /* gate ENFC_CLK_ROOT clock first,before clk source switch */ + clrbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK); + + /* config gpmi and bch clock to 100 MHz */ + clrsetbits_le32(&mxc_ccm->cs2cdr, + MXC_CCM_CS2CDR_ENFC_CLK_PODF_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_PRED_MASK | + MXC_CCM_CS2CDR_ENFC_CLK_SEL_MASK, + MXC_CCM_CS2CDR_ENFC_CLK_PODF(0) | + MXC_CCM_CS2CDR_ENFC_CLK_PRED(3) | + MXC_CCM_CS2CDR_ENFC_CLK_SEL(3)); + + /* enable ENFC_CLK_ROOT clock */ + setbits_le32(&mxc_ccm->CCGR2, MXC_CCM_CCGR2_IOMUX_IPT_CLK_IO_MASK); + + /* enable gpmi and bch clock gating */ + setbits_le32(&mxc_ccm->CCGR4, + MXC_CCM_CCGR4_RAWNAND_U_BCH_INPUT_APB_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_BCH_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_BCH_INPUT_GPMI_IO_MASK | + MXC_CCM_CCGR4_RAWNAND_U_GPMI_INPUT_APB_MASK | + MXC_CCM_CCGR4_PL301_MX6QPER1_BCH_OFFSET); + + /* enable apbh clock gating */ + setbits_le32(&mxc_ccm->CCGR0, MXC_CCM_CCGR0_APBHDMA_MASK); +} + +int board_init(void) +{ + struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + u32 reg; + + setup_gpmi_nand(); + + /* Enable SPI2 clock */ + enable_spi_clk(true, 1); + + /* + * Configure clock output for USB hub + * 1. Disabling CLK01 and CLK02 + */ + clrbits_le32(&mxc_ccm->ccosr, MXC_CCM_CCOSR_CKOL_EN); + clrbits_le32(&mxc_ccm->ccosr, MXC_CCM_CCOSR_CKO2_EN_OFFSET); + + /* + * 2. Setting ccm timer - osc_clk (24 MHz) divide by 2 -> 12 Mhz + * CLK02_DIV: 001b CLK02_SEL: 01110b -> 0010 1110b -> 0x2e + */ + reg = readl(&mxc_ccm->ccosr); + reg &= ~MXC_CCM_CCOSR_CKO2_SEL_MASK; + reg &= ~MXC_CCM_CCOSR_CKO2_DIV_MASK; + reg |= (0x2e << MXC_CCM_CCOSR_CKO2_SEL_OFFSET); + writel(reg, &mxc_ccm->ccosr); + + /* 3. Enabling CLK02 on output CCM_CLK01 */ + setbits_le32(&mxc_ccm->ccosr, MXC_CCM_CCOSR_CLK_OUT_SEL); + setbits_le32(&mxc_ccm->ccosr, MXC_CCM_CCOSR_CKO2_EN_OFFSET); + + return 0; +} diff --git a/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.env b/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.env new file mode 100644 index 00000000000..9aafa3c9984 --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/imx6dl-sielaff.env @@ -0,0 +1,114 @@ +blkloadfdt=fatload ${device} ${devnum}:${partnum} ${fdt_addr} ${load_fdt_file} +blkloadimage=fatload ${device} ${devnum}:${partnum} ${loadaddr} ${load_image} +boot_devices=usb mmc ubi +bootargs_base=vt.global_cursor_default=0 consoleblank=0 cma=200M fbcon=rotate:1 +bootdelay=3 +bootdir= +console=ttymxc1,115200 +ethact=FEC0 +fdt_addr=0x18000000 +fdt_file_legacy=imx6dl_sielaff.dtb +fdt_file=imx6dl-sielaff.dtb +fdt_high=0xffffffff +image_legacy=zImage +image=fitImage +initrd_high=0xffffffff +ip_dyn=no +loadaddr=0x12000000 +mmcargs=setenv bootargs ${bootargs_base} console=${console} root=${mmcroot} +mmcroot=/dev/mmcblk2p2 rootwait rw +ramdisk_addr=0x18C00000 +script=boot.scr +touch_rst_gpio=2 +touch_irq_gpio=146 +ubiargs=setenv bootargs ${bootargs_base} console=${console} rootfstype=ubifs ubi.mtd=0 root=ubi0_0 rw +ubiloadfdt=ubifsload ${fdt_addr} /boot/${load_fdt_file} +ubiloadimage=ubifsload ${loadaddr} /boot/${load_image} +usb_pgood_delay=2000 +usbargs=setenv bootargs ${bootargs_base} console=${console} root=${usbroot} +usbroot=/dev/sda2 rootwait rw + +bootcmd= + for b in ${boot_devices}; do + if test ${b} = mmc; then + run mmcboot; + fi; + if test ${b} = net; then + run netboot; + fi; + if test ${b} = ubi; then + run ubiboot; + fi; + if test ${b} = usb; then + run usbboot; + fi; + done; + +boot= + load_image=${image}; + run loadimagecmd; + if test $? = 0; then + imxtract ${loadaddr} fdt-${fdt_file} ${fdt_addr}; + run detect_touch; + bootm ${loadaddr} - ${fdt_addr}; + else + load_image=${image_legacy}; + load_fdt_file=${fdt_file_legacy}; + run loadimagecmd; + run loadfdtcmd; + if test $? = 0; then + run detect_touch; + bootz ${loadaddr} - ${fdt_addr}; + fi; + fi; + +detect_touch= + gpio clear ${touch_irq_gpio}; + gpio clear ${touch_rst_gpio}; + sleep 0.02; + gpio set ${touch_rst_gpio}; + sleep 0.1; + gpio input ${touch_irq_gpio}; + i2c dev 2; + fdt addr ${fdt_addr}; + if i2c probe 0x55; then + echo 'Detected Sitronix Touch'; + fdt set /soc/bus@2100000/i2c@21a8000/touchscreen@55 status okay; + else + if i2c probe 0x5d; then + echo 'Detected Goodix Touch'; + fdt set /soc/bus@2100000/i2c@21a8000/touchscreen@5d status okay; + fi; + fi; + gpio clear ${touch_rst_gpio}; + +mmcboot= + echo Booting from MMC ...; + run mmcargs; + device=mmc; + devnum=2; + partnum=1; + setenv loadimagecmd ${blkloadimage}; + setenv loadfdtcmd ${blkloadfdt}; + run boot; + +ubiboot= + echo Booting from NAND (UBI); + run ubiargs; + ubi part rootfs; + ubifsmount ubi0; + setenv loadimagecmd ${ubiloadimage}; + setenv loadfdtcmd ${ubiloadfdt}; + load_image=${image}; + run boot; + +usbboot= + echo Booting from USB Storage ...; + run usbargs; + usb start; + device=usb; + devnum=0; + partnum=1; + setenv loadimagecmd ${blkloadimage}; + setenv loadfdtcmd ${blkloadfdt}; + run boot; diff --git a/board/sielaff/imx6dl-sielaff/spl.c b/board/sielaff/imx6dl-sielaff/spl.c new file mode 100644 index 00000000000..64a84fd5122 --- /dev/null +++ b/board/sielaff/imx6dl-sielaff/spl.c @@ -0,0 +1,273 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +#include <asm/arch/clock.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/crm_regs.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/sections.h> +#include <init.h> +#include <spl.h> +#include <fsl_esdhc_imx.h> +#include <mmc.h> + +#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ + PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define GPIO_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ + PAD_CTL_PUS_100K_DOWN | PAD_CTL_SPEED_LOW | \ + PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static const iomux_v3_cfg_t ecspi2_pads[] = { + MX6_PAD_CSI0_DAT10__ECSPI2_MISO | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_CSI0_DAT9__ECSPI2_MOSI | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_CSI0_DAT8__ECSPI2_SCLK | MUX_PAD_CTRL(SPI_PAD_CTRL), + MX6_PAD_CSI0_DAT11__GPIO5_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static const iomux_v3_cfg_t uart2_pads[] = { + MX6_PAD_SD4_DAT7__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_SD4_DAT4__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static const iomux_v3_cfg_t usdhc3_pads[] = { + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + /* CD */ + MX6_PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(GPIO_PAD_CTRL), +}; + +#define USDHC3_CD_GPIO IMX_GPIO_NR(1, 4) +#define SPI2_CS_GPIO IMX_GPIO_NR(5, 29) + +static struct fsl_esdhc_cfg usdhc_cfg[1] = { + {USDHC3_BASE_ADDR, 0, 4}, +}; + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC3_BASE_ADDR: + ret = !gpio_get_value(USDHC3_CD_GPIO); + break; + } + + return ret; +} + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + for (i = 0; i < CFG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads(usdhc3_pads, + ARRAY_SIZE(usdhc3_pads)); + gpio_direction_input(USDHC3_CD_GPIO); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + break; + default: + printf("Warning: you configured more USDHC controllers \ + (%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) { + printf("Warning: failed to initialize mmc dev %d\n", i); + return ret; + } + } + return 0; +} + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static int mx6ssielaff_dcd_table[] = { + 0x020e0774, 0x000C0000, + 0x020e0754, 0x00000000, + 0x020e04ac, 0x00000030, + 0x020e04b0, 0x00000030, + 0x020e0464, 0x00000030, + 0x020e0490, 0x00000030, + 0x020e074c, 0x00000030, + 0x020e0494, 0x00000030, + 0x020e04a0, 0x00000000, + 0x020e04b4, 0x00000030, + 0x020e04b8, 0x00000030, + 0x020e076c, 0x00000030, + 0x020e0750, 0x00020000, + 0x020e04bc, 0x00000030, + 0x020e04c0, 0x00000030, + 0x020e04c4, 0x00000030, + 0x020e04c8, 0x00000030, + 0x020e0760, 0x00020000, + 0x020e0764, 0x00000030, + 0x020e0770, 0x00000030, + 0x020e0778, 0x00000030, + 0x020e077c, 0x00000030, + 0x020e0470, 0x00000030, + 0x020e0474, 0x00000030, + 0x020e0478, 0x00000030, + 0x020e047c, 0x00000030, + 0x021b001c, 0x00008000, + 0x021b0800, 0xA1390003, + 0x021b080c, 0x00350035, + 0x021b0810, 0x002A0032, + 0x021b083c, 0x02340234, + 0x021b0840, 0x02200220, + 0x021b0848, 0x4650504E, + 0x021b0850, 0x3A342E34, + 0x021b081c, 0x33333333, + 0x021b0820, 0x33333333, + 0x021b0824, 0x33333333, + 0x021b0828, 0x33333333, + 0x021b08b8, 0x00000800, + 0x021b0004, 0x0002002D, + 0x021b0008, 0x00333040, + 0x021b000c, 0x676B52F3, + 0x021b0010, 0xB66D8B63, + 0x021b0014, 0x01FF00DB, + 0x021b0018, 0x00011740, + 0x021b001c, 0x00008000, + 0x021b002c, 0x000026D2, + 0x021b0030, 0x006B1023, + 0x021b0040, 0x00000027, + 0x021b0000, 0x84190000, + 0x021b001c, 0x02008032, + 0x021b001c, 0x00008033, + 0x021b001c, 0x00048031, + 0x021b001c, 0x15208030, + 0x021b001c, 0x04008040, + 0x021b0020, 0x00007800, + 0x021b0818, 0x00022227, + 0x021b0004, 0x0002556D, + 0x021b0404, 0x00011006, + 0x021b001c, 0x00000000, + 0x020c4068, 0x00C03F3F, + 0x020c406c, 0x0030FC03, + 0x020c4070, 0x0FFFC000, + 0x020c4074, 0x3FF00000, + 0x020c4078, 0xFFFFF300, + 0x020c407c, 0x0F0000C3, + 0x020c4080, 0x000003FF, + 0x020e0010, 0xF00000CF, + 0x020e0018, 0x007F007F, + 0x020e001c, 0x007F007F, +}; + +static void ddr_init(int *table, int size) +{ + int i; + + for (i = 0; i < size / 2 ; i++) + writel(table[2 * i + 1], table[2 * i]); +} + +static void spl_dram_init(void) +{ + ddr_init(mx6ssielaff_dcd_table, ARRAY_SIZE(mx6ssielaff_dcd_table)); +} + +int board_spi_cs_gpio(unsigned int bus, unsigned int cs) +{ + return (bus == CONFIG_SF_DEFAULT_BUS && cs == CONFIG_SF_DEFAULT_CS) + ? SPI2_CS_GPIO : -1; +} + +static void setup_spi(void) +{ + imx_iomux_v3_setup_multiple_pads(ecspi2_pads, ARRAY_SIZE(ecspi2_pads)); + gpio_request(SPI2_CS_GPIO, "spi2_cs0"); + gpio_direction_output(SPI2_CS_GPIO, 1); + enable_spi_clk(true, 1); +} + +void board_init_f(ulong dummy) +{ + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + gpr_init(); + + /* IOMUX UART */ + imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* SPI */ + setup_spi(); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} + +void board_boot_order(u32 *spl_boot_list) +{ + u32 bootdev = spl_boot_device(); + + /* + * The default boot fuse settings use the SD card (MMC1) as primary + * boot device, but allow SPI NOR as a fallback boot device. + * We can't detect the fallback case and spl_boot_device() will return + * BOOT_DEVICE_MMC1 despite the actual boot device being SPI NOR. + * Therefore we try to load U-Boot proper vom SPI NOR after loading + * from MMC has failed. + */ + spl_boot_list[0] = bootdev; + + switch (bootdev) { + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + spl_boot_list[1] = BOOT_DEVICE_SPI; + break; + } +} diff --git a/configs/imx6dl_sielaff_defconfig b/configs/imx6dl_sielaff_defconfig new file mode 100644 index 00000000000..41574a41af1 --- /dev/null +++ b/configs/imx6dl_sielaff_defconfig @@ -0,0 +1,120 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_TEXT_BASE=0x17800000 +CONFIG_SYS_MALLOC_LEN=0x4000000 +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SOURCE_FILE="imx6dl-sielaff" +CONFIG_SF_DEFAULT_SPEED=20000000 +CONFIG_ENV_SIZE=0x10000 +CONFIG_ENV_OFFSET=0xF0000 +CONFIG_ENV_SECT_SIZE=0x10000 +CONFIG_MX6S=y +CONFIG_TARGET_MX6S_SIELAFF=y +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx6dl-sielaff" +CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_LTO=y +CONFIG_FIT=y +CONFIG_SPL_FIT_PRINT=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_SPI_BOOT=y +CONFIG_SPL_RAW_IMAGE_SUPPORT=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x8A +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x11400 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_SPL=y +CONFIG_CMD_SPL_WRITE_SIZE=0x20000 +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y +CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_WDT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nand0=nand0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=nand0:-@0x0(rootfs)" +CONFIG_CMD_UBI=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_BOUNCE_BUFFER=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x12000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=2 +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MXC=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_RAW_NAND=y +CONFIG_NAND_MXS=y +CONFIG_NAND_MXS_DT=y +CONFIG_SYS_NAND_ONFI_DETECTION=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PHYLIB=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ8XXX=y +CONFIG_DM_MDIO=y +CONFIG_FEC_MXC=y +CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y +CONFIG_MXC_UART=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_MXC_SPI=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_IMX_THERMAL=y +CONFIG_USB=y +CONFIG_SPL_USB_HOST=y +CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_GADGET=y +CONFIG_SPL_USB_GADGET=y +CONFIG_USB_GADGET_MANUFACTURER="FSL" +CONFIG_USB_GADGET_VENDOR_NUM=0x0525 +CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 +CONFIG_CI_UDC=y +CONFIG_SPL_USB_SDP_SUPPORT=y +CONFIG_IMX_WATCHDOG=y diff --git a/include/configs/imx6dl-sielaff.h b/include/configs/imx6dl-sielaff.h new file mode 100644 index 00000000000..df074135079 --- /dev/null +++ b/include/configs/imx6dl-sielaff.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ +#ifndef __MX6SSIELAFF_CONFIG_H +#define __MX6SSIELAFF_CONFIG_H + +#include <asm/arch/imx-regs.h> +#include <linux/sizes.h> +#include "mx6_common.h" + +#define CFG_MXC_UART_BASE UART2_BASE + +#define PHYS_SDRAM_SIZE SZ_512M +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR +#define CFG_SYS_SDRAM_BASE PHYS_SDRAM +#define CFG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CFG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CFG_SYS_FSL_ESDHC_ADDR USDHC3_BASE_ADDR +#define CFG_SYS_FSL_USDHC_NUM 1 + +#define CFG_SYS_NAND_BASE 0x40000000 + +#endif /* __MX6SSIELAFF_CONFIG_H */
Hi Frieder,
Changes in v2:
- Implement changes suggested by Fabio (Thanks!)
- Fix system reset and remove unneeded cpu_reset()
- Add 'static const' to nfc_pads[]
- Remove hostname from env
- Remove options to disable caches
- Enable watchdog and wdt command
- Enable LTO
I put this series in CI and it complained that there is no MAINTAINERS entry for this board:
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/784464
and there was also an issue with the documentation:
https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/784463
Please fix these two issues and submit v3.
On 15.02.24 13:27, Fabio Estevam wrote:
Hi Frieder,
Changes in v2:
- Enable LTO
Oops, right. Totally forgot about these two things. I just sent out a v3. Thanks!
Describe how to build and boot for the Sielaff i.MX6 Solo board.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- Changes in v2: * none --- doc/board/sielaff/imx6dl-sielaff.rst | 32 ++++++++++++++++++++++++++++ doc/board/sielaff/index.rst | 9 ++++++++ 2 files changed, 41 insertions(+) create mode 100644 doc/board/sielaff/imx6dl-sielaff.rst create mode 100644 doc/board/sielaff/index.rst
diff --git a/doc/board/sielaff/imx6dl-sielaff.rst b/doc/board/sielaff/imx6dl-sielaff.rst new file mode 100644 index 00000000000..24dd67ccaef --- /dev/null +++ b/doc/board/sielaff/imx6dl-sielaff.rst @@ -0,0 +1,32 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Sielaff i.MX6 Solo Board +======================== + +The Sielaff i.MX6 Solo board is a control and HMI board for vending +machines. + +Quick Start +----------- + +- Build U-Boot +- Boot + +Build U-Boot +^^^^^^^^^^^^ + +.. code-block:: bash + + $ make imx6dl_sielaff_defconfig + $ make CROSS_COMPILE=arm-none-linux-gnueabihf- + +Burn the flash.bin to SD card at an offset of 1 KiB: + +.. code-block:: bash + + $ dd if=flash.bin of=/dev/sd[x] bs=1K seek=1 conv=notrunc + +Boot +^^^^ + +Put the SD card in the slot on the board and apply power. diff --git a/doc/board/sielaff/index.rst b/doc/board/sielaff/index.rst new file mode 100644 index 00000000000..a8376484d88 --- /dev/null +++ b/doc/board/sielaff/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Sielaff +======= + +.. toctree:: + :maxdepth: 2 + + imx6dl-sielaff
Fabio Estevam
Frieder Schrempf
Frieder Schrempf
