[PATCH] soc: soc_ti_k3: identify j7200 SR2.0 SoCs
Anytime a new revision of a chip is produced, Texas Instruments will increment the 4 bit VARIANT section of the CTRLMMR_WKUP_JTAGID register by one. Typically this will be decoded as SR1.0 -> SR2.0 ... however a few TI SoCs do not follow this convention.
Rather than defining a revision string array for each SoC, use a default revision string array for all TI SoCs that continue to follow the typical 1.0 -> 2.0 revision scheme.
Signed-off-by: Bryan Brattlof bb@ti.com --- drivers/soc/soc_ti_k3.c | 16 +++++----------- 1 file changed, 5 insertions(+), 11 deletions(-)
diff --git a/drivers/soc/soc_ti_k3.c b/drivers/soc/soc_ti_k3.c index 965728e8185a0..88bf153d9f6a6 100644 --- a/drivers/soc/soc_ti_k3.c +++ b/drivers/soc/soc_ti_k3.c @@ -60,8 +60,8 @@ static char *j721e_rev_string_map[] = { "1.0", "1.1", };
-static char *am65x_rev_string_map[] = { - "1.0", "2.0", +static char *typical_rev_string_map[] = { + "1.0", "2.0", "3.0", };
static const char *get_rev_string(u32 idreg) @@ -78,16 +78,10 @@ static const char *get_rev_string(u32 idreg) goto bail; return j721e_rev_string_map[rev];
- case AM65X: - if (rev > ARRAY_SIZE(am65x_rev_string_map)) - goto bail; - return am65x_rev_string_map[rev]; - - case AM64X: - case J7200: default: - if (!rev) - return "1.0"; + if (rev > ARRAY_SIZE(typical_rev_string_map)) + goto bail; + return typical_rev_string_map[rev]; };
bail:
Bryan Brattlof
