[PATCH] arm: kirkwood: Enable bootstd for Sheevaplug board
Enable bootstd for Sheevaplug board. Remove JFFS2 support. See JFFS2 Vulnerability[1]. Enable LTO to keep board size within limit.
[1] https://lore.kernel.org/u-boot/20241114233005.GN3600562@bill-the-cat/T/#m2fc...
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
configs/sheevaplug_defconfig | 16 ++-------------- include/configs/sheevaplug.h | 20 +++++++++++++++----- 2 files changed, 17 insertions(+), 19 deletions(-)
diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 9ac40b9e57..a7f6c73ecb 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -16,16 +16,14 @@ CONFIG_ENV_OFFSET=0x80000 CONFIG_DEFAULT_DEVICE_TREE="marvell/kirkwood-sheevaplug" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_IDENT_STRING="\nMarvell-Sheevaplug" +CONFIG_LTO=y CONFIG_HAS_BOARD_SIZE_LIMIT=y CONFIG_BOARD_SIZE_LIMIT=524288 +CONFIG_BOOTSTD_FULL=y CONFIG_BOOTDELAY=3 -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="${x_bootcmd_kernel}; setenv bootargs ${x_bootargs} ${x_bootargs_root}; bootm 0x6400000;" CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_HUSH_PARSER=y CONFIG_SYS_MAXARGS=32 -CONFIG_CMD_BOOTZ=y # CONFIG_BOOTM_PLAN9 is not set # CONFIG_BOOTM_RTEMS is not set # CONFIG_BOOTM_VXWORKS is not set @@ -35,19 +33,10 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SATA=y CONFIG_CMD_USB=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_JFFS2=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:512K(uboot),512K(env),4M(kernel),-(rootfs)" CONFIG_CMD_UBI=y -CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y @@ -68,6 +57,5 @@ CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_LZMA=y CONFIG_BZIP2=y diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index 4e0b3c663c..c08d29892c 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -12,13 +12,23 @@
#include "mv-common.h"
+#define KERNEL_ADDR_R __stringify(0x800000) +#define FDT_ADDR_R __stringify(0x2c00000) +#define RAMDISK_ADDR_R __stringify(0x01100000) +#define SCRIPT_ADDR_R __stringify(0x200000) + +#define LOAD_ADDRESS_ENV_SETTINGS \ + "kernel_addr_r=" KERNEL_ADDR_R "\0" \ + "fdt_addr_r=" FDT_ADDR_R "\0" \ + "ramdisk_addr_r=" RAMDISK_ADDR_R "\0" \ + "scriptaddr=" SCRIPT_ADDR_R "\0" /* * Environment variables configurations */ -#define CFG_EXTRA_ENV_SETTINGS "x_bootargs=console" \ - "=ttyS0,115200 mtdparts=" CONFIG_MTDPARTS_DEFAULT \ - "x_bootcmd_kernel=nand read 0x6400000 0x100000 0x400000\0" \ - "x_bootcmd_usb=usb start\0" \ - "x_bootargs_root=root=/dev/mtdblock3 rw rootfstype=jffs2\0" +#define CFG_EXTRA_ENV_SETTINGS \ + LOAD_ADDRESS_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ + "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ + "console=ttyS0,115200\0"
#endif /* _CONFIG_SHEEVAPLUG_H */
Hi Tony,
Can I suggest that you move to a test-based environment, too?
- Environment variables configurations
2.39.5
REgards, Simon
Hi Simon,
On Wed, Nov 20, 2024 at 4:40 AM Simon Glass sjg@chromium.org wrote:
Hi Tony,
Did you mean a "text-based environment" as in board/<vendor>/<board>/<CONFIG_SYS_BOARD>.env ?
If yes, I have not tried it but my impression from my past reading is that we need to repeat the bootcmd (bootcmd=bootflow scan -lb) and other boot #define's in the .env file. In that case the include/confis/sheevaplug.h can be removed. I recall reading this conversation here in the ML from way past. It'll be easier to maintain and I'm all for it!
Is there a good example somewhere in the u-boot source tree? i.e. any other envs that could be useful for bootstd should be in there too.
All the best, Tony
2.39.5
REgards, Simon
Tony Dinh
