[U-Boot] [PATCH v2 0/5] Fixes/Addition to use the USB Ethernet gadget with the DWC3 gadget controller
This series implements 2 fixes to be able to use USB Ethernet gadget with the dwc3 driver. It also adds new commands to bind/unbind a device to/from a driver and update the 'dm tree' command to make it easier to use those new commands. The bind/unbind commands can be used to bind the DWC3 USB gadget to the usb_ether driver from the command line instead of relying on platform code.
Changes in v2: - Make the bind/unbind command generic, not specific to usb device. - Update the API to be able to bind/unbind based on DTS node path - Add a Kconfig option to select the bind/unbind commands
Jean-Jacques Hiblot (5): usb: gadget: Add bcdDevice for the DWC3 USB Gadget Controller net: eth-uclass: Fix for DM USB ethernet support cmd: Add bind/unbind commands to bind a device to a driver from the command line drivers: uclass: Add dev_get_uclass_index() to get the uclass/index of a device dm: print the index of the device when dumping the dm tree
cmd/Kconfig | 9 ++ cmd/Makefile | 1 + cmd/bind.c | 256 ++++++++++++++++++++++++++++++++++++++ drivers/core/dump.c | 16 ++- drivers/core/uclass.c | 21 ++++ drivers/usb/gadget/gadget_chips.h | 2 + include/dm/uclass-internal.h | 11 ++ net/eth-uclass.c | 3 +- 8 files changed, 312 insertions(+), 7 deletions(-) create mode 100644 cmd/bind.c
Add an entry in usb_gadget_controller_number() for the DWC3 gadget controller. Without it, it is not possible to bind the USB Ethernet driver.
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com ---
Changes in v2: None
drivers/usb/gadget/gadget_chips.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/usb/gadget/gadget_chips.h b/drivers/usb/gadget/gadget_chips.h index f320708..9b0ad2e 100644 --- a/drivers/usb/gadget/gadget_chips.h +++ b/drivers/usb/gadget/gadget_chips.h @@ -214,5 +214,7 @@ static inline int usb_gadget_controller_number(struct usb_gadget *gadget) return 0x21; else if (gadget_is_fotg210(gadget)) return 0x22; + else if (gadget_is_dwc3(gadget)) + return 0x23; return -ENOENT; }
When a USB ethernet device is halted, the device driver is removed. When this happens the uclass private memory is freed and uclass_priv is set to NULL. This causes a data abort when uclass_priv->state is then set to ETH_STATE_PASSIVE.
Fix it by checking if uclass_priv is NULL before setting uclass_priv->state
Signed-off-by: Jean-Jacques Hiblot jjhiblot@ti.com Acked-by: Joe Hershberger joe.hershberger@ni.com ---
Changes in v2: None
net/eth-uclass.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/net/eth-uclass.c b/net/eth-uclass.c index e4b4922..3a5217a 100644 --- a/net/eth-uclass.c +++ b/net/eth-uclass.c @@ -312,7 +312,8 @@ void eth_halt(void)
eth_get_ops(current)->stop(current); priv = current->uclass_priv; - priv->state = ETH_STATE_PASSIVE; + if (priv) + priv->state = ETH_STATE_PASSIVE; }
int eth_is_active(struct udevice *dev)
In some cases it can be useful to be able to bind a device to a driver from the command line. The obvious example is for versatile devices such as USB gadget. Another use case is when the devices are not yet ready at startup and require some setup before the drivers are bound (ex: FPGA which bitsream is fetched from a mass storage or ethernet)
usage example:
bind usb_dev_generic 0 usb_ether unbind usb_dev_generic 0 usb_ether or unbind eth 1
bind /ocp/omap_dwc3@48380000/usb@48390000 usb_ether unbind /ocp/omap_dwc3@48380000/usb@48390000
cmd/Kconfig | 9 +++ cmd/Makefile | 1 + cmd/bind.c | 256 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 266 insertions(+) create mode 100644 cmd/bind.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 1eb55e5..d6bbfba 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -607,6 +607,15 @@ config CMD_ADC Shows ADC device info and permit printing one-shot analog converted data from a named Analog to Digital Converter.
+config CMD_BIND + bool "bind/unbind - Bind or unbind a device to/from a driver" + depends on DM + help + Bind or unbind a device to/from a driver from the command line. + This is useful in situations where a device may be handled by several + drivers. For example, this can be used to bind a UDC to the usb ether + gadget driver from the command line. + config CMD_CLK bool "clk - Show clock frequencies" help diff --git a/cmd/Makefile b/cmd/Makefile index e0088df..b12aca3 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -19,6 +19,7 @@ obj-$(CONFIG_SOURCE) += source.o obj-$(CONFIG_CMD_SOURCE) += source.o obj-$(CONFIG_CMD_BDI) += bdinfo.o obj-$(CONFIG_CMD_BEDBUG) += bedbug.o +obj-$(CONFIG_CMD_BIND) += bind.o obj-$(CONFIG_CMD_BINOP) += binop.o obj-$(CONFIG_CMD_BLOCK_CACHE) += blkcache.o obj-$(CONFIG_CMD_BMP) += bmp.o diff --git a/cmd/bind.c b/cmd/bind.c new file mode 100644 index 0000000..60d84d6 --- /dev/null +++ b/cmd/bind.c @@ -0,0 +1,256 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2018 JJ Hiblot jjhiblot@ti.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/device-internal.h> +#include <dm/lists.h> +#include <dm/uclass-internal.h> + +static int bind_by_class_index(const char *uclass, int index, + const char *drv_name) +{ + static enum uclass_id uclass_id; + struct udevice *dev; + struct udevice *parent; + int ret; + struct driver *drv; + + drv = lists_driver_lookup_name(drv_name); + if (!drv) { + printf("Cannot find driver '%s'\n", drv_name); + return -ENOENT; + } + + uclass_id = uclass_get_by_name(uclass); + if (uclass_id == UCLASS_INVALID) { + printf("%s is not a valid uclass\n", uclass); + return -EINVAL; + } + + ret = uclass_find_device(uclass_id, index, &parent); + if (!parent || ret) { + printf("Cannot find device %d of class %s\n", index, uclass); + return ret; + } + + ret = device_bind_with_driver_data(parent, drv, drv->name, 0, + ofnode_null(), &dev); + if (!dev || ret) { + printf("Unable to bind. err:%d\n", ret); + return ret; + } + + return 0; +} + +static int unbind_by_class_index(const char *uclass, int index) +{ + static enum uclass_id uclass_id; + struct udevice *dev; + int ret; + + uclass_id = uclass_get_by_name(uclass); + if (uclass_id == UCLASS_INVALID) { + printf("%s is not a valid uclass\n", uclass); + return -EINVAL; + } + + ret = uclass_find_device(uclass_id, index, &dev); + if (!dev || ret) { + printf("Cannot find device %d of class %s\n", index, uclass); + return ret; + } + + ret = device_unbind(dev); + if (ret) { + printf("Unable to unbind. err:%d\n", ret); + return ret; + } + + return 0; +} + +static int unbind_child_by_class_index(const char *uclass, int index, + const char *drv_name) +{ + static enum uclass_id uclass_id; + struct udevice *parent; + struct udevice *dev, *n; + int ret; + struct driver *drv; + + drv = lists_driver_lookup_name(drv_name); + if (!drv) { + printf("Cannot find driver '%s'\n", drv_name); + return -ENOENT; + } + + uclass_id = uclass_get_by_name(uclass); + if (uclass_id == UCLASS_INVALID) { + printf("%s is not a valid uclass\n", uclass); + return -EINVAL; + } + + ret = uclass_find_device(uclass_id, index, &parent); + if (!parent || ret) { + printf("Cannot find device %d of class %s\n", index, uclass); + return ret; + } + + list_for_each_entry_safe(dev, n, &parent->child_head, sibling_node) { + int rc; + + if (dev->driver != drv) + continue; + + rc = device_unbind(dev); + if (rc && !ret) { + printf("failed to unbind %s/%s\n", dev->name, + drv->name); + ret = rc; + } + } + + return ret; +} + +static int bind_by_node_path(const char *path, const char *drv_name) +{ + struct udevice *dev; + struct udevice *parent = NULL; + int ret; + int id; + ofnode ofnode; + struct driver *drv; + + drv = lists_driver_lookup_name(drv_name); + if (!drv) { + printf("%s is not a valid driver name\n", drv_name); + return -ENOENT; + } + + ofnode = ofnode_path(path); + if (!ofnode_valid(ofnode)) { + printf("%s is not a valid node path\n", path); + return -EINVAL; + } + + while (ofnode_valid(ofnode)) { + for (id = 0; id < UCLASS_COUNT; id++) { + if (!uclass_find_device_by_ofnode(id, ofnode, &parent)) + break; + } + if (parent) + break; + ofnode = ofnode_get_parent(ofnode); + } + + if (!parent) { + printf("Cannot find a parent device for node path %s\n", path); + return -ENODEV; + } + + ret = device_bind_with_driver_data(parent, drv, drv->name, 0, + ofnode_path(path), &dev); + if (!dev || ret) { + printf("Unable to bind. err:%d\n", ret); + return ret; + } + + return 0; +} + +static int unbind_by_node_path(const char *path) +{ + struct udevice *dev; + int ret; + int id; + ofnode ofnode; + + ofnode = ofnode_path(path); + if (!ofnode_valid(ofnode)) { + printf("%s is not a valid node path\n", path); + return -EINVAL; + } + + for (id = 0; id < UCLASS_COUNT; id++) { + if (uclass_find_device_by_ofnode(id, ofnode, &dev) == 0) + break; + } + + if (!dev) { + printf("Cannot find a device with path %s\n", path); + return -ENODEV; + } + + ret = device_unbind(dev); + if (ret) { + printf("Unable to unbind. err:%d\n", ret); + return ret; + } + + return 0; +} + +static int do_bind_unbind(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + int ret; + bool bind; + bool by_node; + + if (argc < 2) + return CMD_RET_USAGE; + + bind = (argv[0][0] == 'b'); + by_node = (argv[1][0] == '/'); + + if (by_node && bind) { + if (argc != 3) + return CMD_RET_USAGE; + ret = bind_by_node_path(argv[1], argv[2]); + } else if (by_node && !bind) { + if (argc != 2) + return CMD_RET_USAGE; + ret = unbind_by_node_path(argv[1]); + } else if (!by_node && bind) { + int index = (argc > 2) ? simple_strtoul(argv[2], NULL, 10) : 0; + + if (argc != 4) + return CMD_RET_USAGE; + ret = bind_by_class_index(argv[1], index, argv[3]); + } else if (!by_node && !bind) { + int index = (argc > 2) ? simple_strtoul(argv[2], NULL, 10) : 0; + + if (argc == 3) + ret = unbind_by_class_index(argv[1], index); + else if (argc == 4) + ret = unbind_child_by_class_index(argv[1], index, + argv[3]); + else + return CMD_RET_USAGE; + } + + if (ret) + return CMD_RET_FAILURE; + else + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD( + bind, 4, 0, do_bind_unbind, + "Bind a device to a driver", + "<node path> <driver>\n" + "bind <class> <index> <driver>\n" +); + +U_BOOT_CMD( + unbind, 4, 0, do_bind_unbind, + "Unbind a device from a driver", + "<node path>\n" + "unbind <class> <index>\n" + "unbind <class> <index> <driver>\n" +);
usage example:
Looks great!
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Hi Jean-Jacques,
usage example:
Changes in v2:
This looks good to me, with a few comments below. I think it is great to get this sort of functionality in U-Boot.
Please can you add a test which calls issues a few of these commands? You might find test_shell_basics.py useful as a starting point.
+config CMD_BIND
depends on DM
help
- Copyright (c) 2018 JJ Hiblot jjhiblot@ti.com
int ret;
struct driver *drv;
if (!drv) {
return -ENOENT;
return -EINVAL;
return ret;
if (!dev || ret) {
return ret;
int ret;
return -EINVAL;
if (!dev || ret) {
return ret;
if (ret) {
return ret;
int ret;
struct driver *drv;
if (!drv) {
return -ENOENT;
return -EINVAL;
return ret;
The above two blocks duplicate code in the function above. Can you put then in a separate function can call it here?
This feels like code that should be in drivers/core since it is messing with the internal lists and driver names. But I suppose for now we can keep it here. Let's see how things expand later.
int rc;
continue;
if (rc && !ret) {
drv->name);
ret = rc;
return ret;
int ret;
int id;
ofnode ofnode;
struct driver *drv;
if (!drv) {
return -ENOENT;
return -EINVAL;
break;
Can you create a function in drivers/core that finds an ofnode globally? I don't like having this logic here.
You could convert device_get_global_by_of_offset() to use an ofnode.
Remember that any printf() calls should be here, not in drivers/core.
if (parent)
break;
if (!parent) {
return -ENODEV;
if (!dev || ret) {
return ret;
int ret;
int id;
ofnode ofnode;
return -EINVAL;
break;
Same comment as above - move this logic to drivers/core
if (!dev) {
return -ENODEV;
if (ret) {
return ret;
int ret;
bool bind;
bool by_node;
if (argc < 2)
if (argc != 3)
if (argc != 2)
if (argc != 4)
if (argc == 3)
else if (argc == 4)
argv[3]);
else
if (ret)
else
+U_BOOT_CMD(
+U_BOOT_CMD(
"<node path>\n"
2.7.4
usage example:
Changes in v2:
+config CMD_BIND
- bool "bind/unbind - Bind or unbind a device to/from a driver"
- depends on DM
- help
- static enum uclass_id uclass_id;
- struct udevice *dev;
- struct udevice *parent;
- int ret;
- struct driver *drv;
- drv = lists_driver_lookup_name(drv_name);
- if (!drv) {
return -ENOENT;
- uclass_id = uclass_get_by_name(uclass);
- if (uclass_id == UCLASS_INVALID) {
return -EINVAL;
- ret = uclass_find_device(uclass_id, index, &parent);
- if (!parent || ret) {
return ret;
- ret = device_bind_with_driver_data(parent, drv, drv->name, 0,
- if (!dev || ret) {
return ret;
- int ret;
return -EINVAL;
- ret = uclass_find_device(uclass_id, index, &dev);
return ret;
- ret = device_unbind(dev);
- if (ret) {
return ret;
- struct udevice *dev, *n;
- int ret;
- if (!drv) {
return -ENOENT;
return -EINVAL;
return ret;
- list_for_each_entry_safe(dev, n, &parent->child_head, sibling_node) {
int rc;
continue;
if (rc && !ret) {
drv->name);
ret = rc;
- return ret;
- struct udevice *parent = NULL;
- int ret;
- int id;
- ofnode ofnode;
- if (!drv) {
return -ENOENT;
- ofnode = ofnode_path(path);
- if (!ofnode_valid(ofnode)) {
return -EINVAL;
- while (ofnode_valid(ofnode)) {
break;
if (parent)
break;
- if (!parent) {
return -ENODEV;
return ret;
- int ret;
- int id;
- ofnode ofnode;
return -EINVAL;
- for (id = 0; id < UCLASS_COUNT; id++) {
break;
- if (!dev) {
return -ENODEV;
- if (ret) {
return ret;
- int ret;
- bool bind;
- bool by_node;
- if (argc < 2)
- bind = (argv[0][0] == 'b');
- by_node = (argv[1][0] == '/');
- if (by_node && bind) {
if (argc != 3)
- } else if (by_node && !bind) {
if (argc != 2)
- } else if (!by_node && bind) {
if (argc != 4)
- } else if (!by_node && !bind) {
if (argc == 3)
else if (argc == 4)
argv[3]);
else
- if (ret)
- else
I am getting compilation warnings bout this ret handling.
cmd/bind.c: In function ‘do_bind_unbind’: cmd/bind.c:237:5: warning: ‘ret’ may be used uninitialized in this function [-Wmaybe-uninitialized] if (ret) ^
+U_BOOT_CMD(
- bind, 4, 0, do_bind_unbind,
- "Bind a device to a driver",
- "<node path> <driver>\n"
- "bind <class> <index> <driver>\n"
+U_BOOT_CMD(
- unbind, 4, 0, do_bind_unbind,
- "Unbind a device from a driver",
- "<node path>\n"
- "unbind <class> <index>\n"
- "unbind <class> <index> <driver>\n"
I have played with this series with zynq_gpio driver on zcu100. It can be only one instance of this driver but I can call bind multiple times and instance is listed with new index. Log below.
ZynqMP> dm tree Class index Probed Driver Name ----------------------------------------- root 0 [ + ] root_drive root_driver serial 0 [ ] arm_dcc |-- dcc simple_bus 0 [ ] generic_si |-- amba_apu@0 simple_bus 1 [ + ] generic_si |-- amba gpio 0 [ ] gpio_zynq | |-- gpio@ff0a0000 mmc 0 [ + ] arasan_sdh | |-- sdhci@ff160000 ... ZynqMP> bind /amba/gpio@ff0a0000 gpio_zynq EFI: Initializing UCLASS_EFI Calling zynq_gpio_bind ZynqMP> dm tree Class index Probed Driver Name ----------------------------------------- root 0 [ + ] root_drive root_driver serial 0 [ ] arm_dcc |-- dcc simple_bus 0 [ ] generic_si |-- amba_apu@0 simple_bus 1 [ + ] generic_si |-- amba gpio 0 [ ] gpio_zynq | |-- gpio@ff0a0000 gpio 1 [ ] gpio_zynq | | `-- gpio_zynq mmc 0 [ + ] arasan_sdh | |-- sdhci@ff160000 ... ZynqMP>
I can read dev->seq in probe and fail if dev->seq is not 0 but not sure if this should be checked in probe.
The second thing is that when I call unbind for probed device that it is failing because it hasn't been removed.
ZynqMP> dm tree Class index Probed Driver Name ----------------------------------------- root 0 [ + ] root_drive root_driver serial 0 [ ] arm_dcc |-- dcc simple_bus 0 [ ] generic_si |-- amba_apu@0 simple_bus 1 [ + ] generic_si |-- amba gpio 0 [ ] gpio_zynq | |-- gpio@ff0a0000 mmc 0 [ + ] arasan_sdh | |-- sdhci@ff160000 ... ZynqMP> gpio status 0 Calling zynq_gpio_ofdata_to_platdata Calling zynq_gpio_probe 0 ZynqMP> dm tree Class index Probed Driver Name ----------------------------------------- root 0 [ + ] root_drive root_driver serial 0 [ ] arm_dcc |-- dcc simple_bus 0 [ ] generic_si |-- amba_apu@0 simple_bus 1 [ + ] generic_si |-- amba gpio 0 [ + ] gpio_zynq | |-- gpio@ff0a0000 mmc 0 [ + ] arasan_sdh | |-- sdhci@ff160000 ... ZynqMP> unbind /amba/gpio@ff0a0000 EFI: Initializing UCLASS_EFI activated Unable to unbind. err:-22
That's why I am curious if this command enable to unbind device then there should be also an option to remove that device too.
More generic note. I have been taking information about structure from dm tree command and I would consider to move test/dm/cmd_dm.c to cmd folder and extend this file by these new functionality.
Thanks, Michal
Changes in v2: New
drivers/core/uclass.c | 21 +++++++++++++++++++++ include/dm/uclass-internal.h | 11 +++++++++++ 2 files changed, 32 insertions(+)
diff --git a/drivers/core/uclass.c b/drivers/core/uclass.c index 0085d3f..6efce20 100644 --- a/drivers/core/uclass.c +++ b/drivers/core/uclass.c @@ -171,6 +171,27 @@ enum uclass_id uclass_get_by_name(const char *name) return UCLASS_INVALID; }
+int dev_find_uclass_index(struct udevice *dev, struct uclass **ucp) +{ + struct udevice *iter; + struct uclass *uc = dev->uclass; + int i = 0; + + if (list_empty(&uc->dev_head)) + return -ENODEV; + + list_for_each_entry(iter, &uc->dev_head, uclass_node) { + if (iter == dev) { + if (ucp) + *ucp = uc; + return i; + } + i++; + } + + return -ENODEV; +} + int uclass_find_device(enum uclass_id id, int index, struct udevice **devp) { struct uclass *uc; diff --git a/include/dm/uclass-internal.h b/include/dm/uclass-internal.h index 7ba064b..30d5a4f 100644 --- a/include/dm/uclass-internal.h +++ b/include/dm/uclass-internal.h @@ -24,6 +24,17 @@ int uclass_get_device_tail(struct udevice *dev, int ret, struct udevice **devp);
/** + * dev_get_uclass_index() - Get uclass and index of device + * @dev: - in - Device that we want the uclass/index of + * @ucp: - out - A pointer to the uclass the device belongs to + * + * The device is not prepared for use - this is an internal function. + * + * @return the index of the device in the uclass list or -ENODEV if not found. + */ +int dev_get_uclass_index(struct udevice *dev, struct uclass **ucp); + +/** * uclass_find_device() - Return n-th child of uclass * @id: Id number of the uclass * @index: Position of the child in uclass's list
Hi Jean-Jacques,
Please add a commit message with motivation and purpose.
Also please add a test for this (e.g. in test/dm/core.c
Changes in v2: New
int i = 0;
return -ENODEV;
if (iter == dev) {
if (ucp)
*ucp = uc;
return i;
i++;
return -ENODEV;
- dev_get_uclass_index() - Get uclass and index of device
- @dev: - in - Device that we want the uclass/index of
- @ucp: - out - A pointer to the uclass the device belongs to
- The device is not prepared for use - this is an internal function.
- @return the index of the device in the uclass list or -ENODEV if not found.
find or get? It should be find, since it doesn't probe anything.
- uclass_find_device() - Return n-th child of uclass
- @id: Id number of the uclass
- @index: Position of the child in uclass's list
-- 2.7.4
Changes in v2: New
This function doesn't fit with description or even with declaration below.
Thanks, Michal
- struct udevice *iter;
- struct uclass *uc = dev->uclass;
- int i = 0;
- if (list_empty(&uc->dev_head))
return -ENODEV;
- list_for_each_entry(iter, &uc->dev_head, uclass_node) {
if (iter == dev) {
if (ucp)
*ucp = uc;
return i;
i++;
- return -ENODEV;
Command "dm tree" dumps the devices with class, driver, name information. Add the index of the device in the class too, because the information is useful for the bind/unbind commands.
Changes in v2: New
drivers/core/dump.c | 16 ++++++++++------ 1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/drivers/core/dump.c b/drivers/core/dump.c index 58820cd..d7cdb14 100644 --- a/drivers/core/dump.c +++ b/drivers/core/dump.c @@ -8,6 +8,7 @@ #include <mapmem.h> #include <dm/root.h> #include <dm/util.h> +#include <dm/uclass-internal.h>
static void show_devices(struct udevice *dev, int depth, int last_flag) { @@ -15,7 +16,8 @@ static void show_devices(struct udevice *dev, int depth, int last_flag) struct udevice *child;
/* print the first 11 characters to not break the tree-format. */ - printf(" %-10.10s [ %c ] %-10.10s ", dev->uclass->uc_drv->name, + printf(" %-10.10s %d [ %c ] %-10.10s ", dev->uclass->uc_drv->name, + dev_get_uclass_index(dev, NULL), dev->flags & DM_FLAG_ACTIVATED ? '+' : ' ', dev->driver->name);
for (i = depth; i >= 0; i--) { @@ -47,8 +49,8 @@ void dm_dump_all(void)
root = dm_root(); if (root) { - printf(" Class Probed Driver Name\n"); - printf("----------------------------------------\n"); + printf(" Class index Probed Driver Name\n"); + printf("-----------------------------------------\n"); show_devices(root, -1, 0); } } @@ -60,9 +62,9 @@ void dm_dump_all(void) * * @dev: Device to display */ -static void dm_display_line(struct udevice *dev) +static void dm_display_line(struct udevice *dev, int index) { - printf("- %c %s @ %08lx", + printf("%i %c %s @ %08lx", index, dev->flags & DM_FLAG_ACTIVATED ? '*' : ' ', dev->name, (ulong)map_to_sysmem(dev)); if (dev->seq != -1 || dev->req_seq != -1) @@ -78,6 +80,7 @@ void dm_dump_uclass(void)
for (id = 0; id < UCLASS_COUNT; id++) { struct udevice *dev; + int i = 0;
ret = uclass_get(id, &uc); if (ret) @@ -87,7 +90,8 @@ void dm_dump_uclass(void) if (list_empty(&uc->dev_head)) continue; list_for_each_entry(dev, &uc->dev_head, uclass_node) { - dm_display_line(dev); + dm_display_line(dev, i); + i++; } puts("\n"); }
Changes in v2: New
Jean-Jacques Hiblot
Joe Hershberger
Michal Simek
