[U-Boot] Getting started with SPL
*HI, *
*OS:* petalinux https://github.com/Xilinx/u-boot-xlnx/tree/master-next
*Board:* Xilinx z702 evaluation boardhttp://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC702-G.htm having ARM Cortex A9 and FPGA on the zc700 SoC
* Background:* I observed that first message on the console comes after 1 second. It is the message from u-boot. Why this was happening? Because I had to use a fsbl (first stage boot loader)http://blog.fakultaet-technik.de/development-with-zynq-part-3-build-boot-files/ for initialization of hardware. I suspected that it is this fsbl that is consuming 1 second initializing useless hardware which I will not use at all. in fact I am not going to use any fpga bitstream also.
So I am trying to boot my Linux image using uboot-SPL methodhttp://www.denx.de/en/pub/Documents/Presentations/EWC2012_Roeder_Zundel_Fastboot.pdf bypassing fsbl.
The main advantage I can get is perhaps fastest possible boot.
I found thishttps://github.com/Xilinx/u-boot-xlnx/blob/master/doc/README.SPL (README.SPL) document that explains how to work with SPL. However I have following question w.r.t to the this passage in the document:
The building of SPL images can be with: define CONFIG_SPL
Because SPL images normally have a different text base, one has to be configured by defining CONFIG_SPL_TEXT_BASE. The linker script has to be defined with CONFIG_SPL_LDSCRIPT.
Questions:
1- In which file I should define #define CONFIG_SPL and CONFIG_SPL_TEXT_BASE?
2-Where is the linker script? Do I need to define CONFIG_SPL_LDSCRIPT in the linker script ? Source code of SPL enabled u-boot for xilinx board I am using is thishttps://github.com/Xilinx/u-boot-xlnx/tree/master-next
This is the first time I am trying to play with SPL so kindly help me proceed.
Thanks and regards,
HB
Hi
On 04/30/2014 11:32 AM, Heshsham Abdul Basit wrote:
*HI, *
it is not OS - it is just xilinx u-boot repo. And petalinux is using this repo too.
- Background:* I observed that first message on the console comes after 1
In standard flow there is bootrom -> fsbl -> u-boot. I have never measured where we are spending time in boot.
yes. But also keep in your mind that depends on which boot device you are using. QSPI mode should be the fastest one.
Questions:
Just config file - you can just grep code and you will find out that it is in include/configs/ folder.
If you want to use private linker script then yes. There is also generic one.
yes. I have enabled it by default but for correct function you have to copy ps7_init.c/h files from your hardware design to be align with your hw design
Thanks, Michal
HI Michal.
Thanks for your answers. I have few related questions which I will ask separately.
Rgrds,
Heshsham
On 30/04/2014, Michal Simek monstr@monstr.eu wrote:
Hi
*HI, *
Questions:
Thanks, Michal
-- Michal Simek, Ing. (M.Eng), OpenPGP -> KeyID: FE3D1F91 w: www.monstr.eu p: +42-0-721842854 Maintainer of Linux kernel - Microblaze cpu - http://www.monstr.eu/fdt/ Maintainer of Linux kernel - Xilinx Zynq ARM architecture Microblaze U-BOOT custodian and responsible for u-boot arm zynq platform
Michal Simek
