[U-Boot] U-boot env variables parsing
Hi!
I am doing env settings some thing like this,
ROOT1=/dev/mmcblk0p1 ROOT2=/dev/mmcblk0p2 ROOT=${ROOT1} bootargs1=console=ttyS0,115200n8 mem=256M noinitrd rw rootdelay=1 ${ROOT}
when I say 'setenv bootargs ${bootargs1}', ${ROOT} gets resolved to 'ROOT1', it does not get completely resolved to '/dev/mmcblk0p1'.
Is there something fundamentally wrong in setting the env variables this way?
What would be the right way to achieve this, as I want ROOT to be ${ROOT1} sometimes and ${ROOT2} some times?
regards
-Nitin
Get your preferred Email name! Now you can @ymail.com and @rocketmail.com. http://mail.promotions.yahoo.com/newdomains/aa/
Hi Nitin,
Hi!
There is nothing fundamentally wrong - it will simply not work ;) No, seriously, you want U-Boot to do two evaluation passes over bootargs, which we cannot do. In a regular shell this would be done by a separate "eval" or backtick round, but we lack this.
What we usually do is something like this (example taken from an arbitrary board):
nfsargs=setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off panic=1 addtty=setenv bootargs ${bootargs} console=tty0 console=${consdev},${baudrate} addfb=setenv bootargs ${bootargs} fbcon=map:5 video=fslfb:800x480-32@60 flash_nfs=run nfsargs addip addtty addfb;bootm ${kernel_addr} - ${fdt_addr}
When "run flash_nfs" is executed, little "scripts" are called and they assemble a full command line from different variables. So in this example, one could simply change ${kernel_addr} and "run flash_nfs" would boot the new kernel.
If you don't like such constructs, you can also get more funky and start using "if ... then .. else .." construct in the hush shell parser.
There is more than one way to do it ;)
Cheers Detlev
Hi Nitin,
Hi!
I recall impl. something like this for the old shell. It enabled me to do:
linuxip=ip=$(ipaddr)::$(gatewayip):$(netmask):$(hostname):$(linuxif):off tboot=setenv bootargs $(linuxroot) $(linuxip) $(extra);tftp 100000; bootm 100000
it was fairly simple to do but I don't think WD applied it since the old shell was obsolete
I guess it would not be hard to do the same for hush. If I fund the correct commit it looked like this for the old shell:
Index: main.c =================================================================== --- main.c (revision 15) +++ main.c (revision 16) @@ -463,9 +463,9 @@
-static void process_macros (const char *input, char *output) +static int process_macros (const char *input, char *output) { - char c, prev; + char c, prev, macro_processed =0; const char *varname_start; int inputcnt = strlen (input); int outputcnt = CFG_CBSIZE; @@ -540,6 +540,7 @@ } /* Look for another '$' */ state = 0; + macro_processed = 1; } break; } @@ -549,7 +550,7 @@
if (outputcnt) *output = 0; - + return macro_processed; #ifdef DEBUG_PARSER printf ("[PROCESS_MACROS] OUTPUT len %d: "%s"\n", strlen(output_start), output_start); @@ -580,6 +581,7 @@ char *token; /* start of token in cmdbuf */ char *sep; /* end of token (separator) in cmdbuf */ char finaltoken[CFG_CBSIZE]; + char tmptoken[CFG_CBSIZE]; char *str = cmdbuf; char *argv[CFG_MAXARGS + 1]; /* NULL terminated */ int argc; @@ -631,7 +633,11 @@ #endif
/* find macros in this token and replace them */ - process_macros (token, finaltoken); + if(process_macros (token, finaltoken)){ + strcpy(tmptoken,finaltoken); + while(process_macros (tmptoken, finaltoken)) + strcpy(tmptoken,finaltoken); + }
/* Extract arguments */ argc = parse_line (finaltoken, argv);
Jocke
Dear Joakim Tjernlund,
In message OFEBF95CA1.44E68372-ONC12576F8.0043F4F7-C12576F8.0044D7F5@transmode.se you wrote:
I don't think you ever posted this before. I cannot find any trace of such a patch - not in the public archives nor locally.
Hm... will this not make escaping impossible? Assume you want to pass
arg=${name}
to Linux. How would you escape this so it does NOT get expanded if you run process_macros() arbitrarily often?
Wolfgang Denk wd@denx.de wrote on 2010-04-01 14:47:45:
In message <OFEBF95CA1.44E68372-ONC12576F8.0043F4F7-C12576F8. 0044D7F5@transmode.se> you wrote:
shell was obsolete
I think I did, but this would have been late 2001 or 2002 I think :) Not 100% sure about the date since the old CVS log looks a bit fishy after the repo got converted to Subversion.
arg=${name}
Possibly, I never needed that though. One would probably need to add an escape char for that. Something like arg=${name}
Jocke
In message OF6D501B3A.40F7E6A2-ONC12576F8.00466BE2-C12576F8.00471566@transmode.se you wrote:
Ah... that was at PPCBoot times, then. Found it: Tue, 11 Sep 2001 15:29:26 +0200
AFAICT the patch was late for a release, but has not been formally rejected. Probably just got forgotten.
arg=${name}
Woudn't this then just cause another cycle through process_macros(), where it then gets substitured anyway? [Guess I gotta try this out.]
Wolfgang Denk wd@denx.de wrote on 2010-04-01 15:05:29:
In message <OF6D501B3A.40F7E6A2-ONC12576F8.00466BE2-C12576F8. 00471566@transmode.se> you wrote:
Wow, you got your archives in order :)
Ah, I must have misunderstood then.
arg=${name}
I am not sure what will happen, it was so man years ago. But I would guess that if you really want to pass arg=$(name) to the kernel you will probably need to do some adjustment.
Jocke
Hi Jocke,
arg=${name}
To me it looks like the new code would indeed do a "greedy" substitution only stopping when no more substitutions can be done. This is very un-unixy and thus not something I'd like to see as a default behaviour.
When we want to move in this direction, then we should implement something with finer control over the substitution rounds.
Cheers and happy easter all around Detlev
Detlev Zundel dzu@denx.de wrote on 2010-04-01 16:56:40:
Hi Jocke,
arg=${name}
Why not? What is gained by the current method?
Jocke
In message OF5552925C.8F998468-ONC12576F8.005E3247-C12576F8.005E9BF2@transmode.se you wrote:
We follow the principle of least surprise [1]; the command line interpeter in U-Boot should behave as similar to a (say, POSIX compatible) shell as possible. Restrictions and deviations are not intentional, but caused by the attempt to do with a minimal memory footprint.
Like Detlev I feel/fear that the suggested change will cause more annoyance due to unexpected behaviour that it will do good.
I also see little actual need for such an extension, as in all cases I've seen so far it has been possible to acchieve the goal without code changes by just minimal adjustments of the definitions. For example, your code:
could be rewritten from plain variable definitions into an equivalent command sequence, like that:
setenv setip 'setenv bootargs ${bootargs} ip=${ipaddr}::${gatewayip}:${netmask}:${hostname}:${linuxif}:off'
Do the same for "linuxroot" (=> setroot) and "extra" (=> setextra), and then use:
setenv tboot 'run setroot setip setextra;tftp 100000;bootm'
will do exactly what you want. Detlev quoted similar code earlier. This is what many, many existing boards use, and what we explain in great detail in the manual.
[1] http://en.wikipedia.org/wiki/Principle_of_least_surprise
Wolfgang Denk wd@denx.de wrote on 2010-04-01 20:27:47:
In message <OF5552925C.8F998468-ONC12576F8.005E3247-C12576F8. 005E9BF2@transmode.se> you wrote:
what bad do you think it might do? You mentioned the possibility to pass arg=$(name) literally(why would you do that?) Have you ever done that? Then one should be able to pass $(linuxip) too, which you can't.
setenv setip 'setenv bootargs ${bootargs} ip=${ipaddr}::${gatewayip}:$ {netmask}:${hostname}:${linuxif}:off'
While you can do that, it is ugly and clumsy(which was why I wrote the patch)
I want the shell to make things simpler/easier for me and the above isn't either.
Jocke
Hi Jocke,
Nope, I haven't, but if some linux commandline parameter needs such a construct, I surely do not want to change the U-Boot shell to be able to do it. The change you propose would make such a thing impossible.
Why do you think so?
=> run nfsargs addip addtty addfb => prin ipaddr ipaddr=192.168.160.43 => setenv bootargs ${bootargs} ${ipaddr} => bootm ${kernel_addr}
-bash-3.2# cat /proc/cmdline root=/dev/nfs rw nfsroot=192.168.1.1:/opt/eldk/ppc_6xx ip=192.168.160.43:192.168.1.1:192.168.83.201:255.255.0.0:pdm360ng:eth0:off panic=1 console=tty0 console=ttyPSC5,115200 fbcon=map:5 video=fslfb:800x480-32@60 ${ipaddr}
This is a personal preference. Personally I value the quoted principle of least surprise more. Moreover I much rather make all use cases possible and maybe use some extra characters for exotic ones rather than precluding a specific use case completely in order to save a few characters.
Cheers Detlev
Detlev Zundel dzu@denx.de wrote on 2010-04-08 12:00:05:
Hi Jocke,
Hi Detlev :)
Oh, so there is an escape char() after all. I got the impression that there wasn't one.
-bash-3.2# cat /proc/cmdline root=/dev/nfs rw nfsroot=192.168.1.1:/opt/eldk/ppc_6xx ip=192.168.160.43:192.168.1.1:192.168.83.201:255.255.0.0:pdm360ng:eth0:off panic=1 console=tty0 console=ttyPSC5,115200 fbcon=map:5 video=fslfb: 800x480-32@60 ${ipaddr}
Since an escape char appear to exist, one should be able to use it much like you did above so I don't think that any use case disappears. Instead the common usage becomes simpler and the so far artificial use case needs an extra escape char.
Jocke
Hi Jocke,
Hm. I have to admit that I did not actually try your code, but there is a loop in there until no further substitution takes place. It seems to me that this loop over process_macros thus does substitution _and_ uses up the escape characters.
So I fear that if in one iteration _some_ substitution takes place and the escape character is stripped in the same iteration _another_ round of substitution will be done and the escape character is gone. So in effect you will have to study the whole string in advance (plus all the substitutions it will see) to tell how many rounds the loop will take and how many escape characters will be needed.
Such a behaviour would be very odd in my eyes. On the other hand, this is only theory....
Cheers Detlev
Detlev Zundel dzu@denx.de wrote on 2010-04-08 18:06:40:
Hi Jocke,
Hi again :)
Possibly, I haven't tested that either but ...
... I don't think you or WD has changed your mind even it it worked the way we want it to so no point arguing over an impl. detail/bug when we don't agree on the big picture.
This "feature" isn't that important to me so I rest my case.
Jocke
Detlev Zundel
Joakim Tjernlund
Nitin Mahajan
