[U-Boot] [PATCH][v4] armv8/ls2080ardb: Enable VID support
This patch enable VID support for ls2080ardb platform. It uses the common VID driver
Signed-off-by: Rai Harninder harninder.rai@nxp.com --- Changes in v4: - Fix implicit declaration warning for adjust_vdd() by including approriate header file
Changes in v3: - Call adjust_vdd() so that the voltage gets adjusted during u-boot boot up itself
Changes in v2 - Use CONFIG_FSL_LSCH3 instead of CONFIG_LAYERSCAPE since the latter is defined for other platforms as well - Modify patch description
.../include/asm/arch-fsl-layerscape/immap_lsch3.h | 4 ++++ board/freescale/common/vid.c | 15 ++++++++++++++- board/freescale/ls2080ardb/ls2080ardb.c | 9 +++++++++ include/configs/ls2080ardb.h | 16 ++++++++++++++++ 4 files changed, 43 insertions(+), 1 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 081519a..94258d2 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -154,6 +154,10 @@ struct ccsr_gur { u8 res_008[0x20-0x8]; u32 gpporcr1; /* General-purpose POR configuration */ u32 gpporcr2; /* General-purpose POR configuration 2 */ +#define FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT 25 +#define FSL_CHASSIS3_DCFG_FUSESR_VID_MASK 0x1F +#define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT 20 +#define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK 0x1F u32 dcfg_fusesr; /* Fuse status register */ u32 gpporcr3; u32 gpporcr4; diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index a6a132a..2f29795 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -10,6 +10,8 @@ #include <asm/io.h> #ifdef CONFIG_LS1043A #include <asm/arch/immap_lsch2.h> +#elif defined(CONFIG_FSL_LSCH3) +#include <asm/arch/immap_lsch3.h> #else #include <asm/immap_85xx.h> #endif @@ -285,7 +287,7 @@ static int set_voltage(int i2caddress, int vdd) int adjust_vdd(ulong vdd_override) { int re_enable = disable_interrupts(); -#ifdef CONFIG_LS1043A +#if defined(CONFIG_LS1043A) || defined(CONFIG_FSL_LSCH3) struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); #else ccsr_gur_t __iomem *gur = @@ -362,7 +364,11 @@ int adjust_vdd(ulong vdd_override) }
/* get the voltage ID from fuse status register */ +#ifdef CONFIG_FSL_LSCH3 + fusesr = in_le32(&gur->dcfg_fusesr); +#else fusesr = in_be32(&gur->dcfg_fusesr); +#endif /* * VID is used according to the table below * --------------------------------------- @@ -387,6 +393,13 @@ int adjust_vdd(ulong vdd_override) vid = (fusesr >> FSL_CHASSIS2_DCFG_FUSESR_VID_SHIFT) & FSL_CHASSIS2_DCFG_FUSESR_VID_MASK; } +#elif defined(CONFIG_FSL_LSCH3) + vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK; + if ((vid == 0) || (vid == FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK)) { + vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_VID_MASK; + } #else vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_ALTVID_SHIFT) & FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 12638df..9d3c680 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -21,6 +21,7 @@
#include "../common/qixis.h" #include "ls2080ardb_qixis.h" +#include "../common/vid.h"
#define PIN_MUX_SEL_SDHC 0x00 #define PIN_MUX_SEL_DSPI 0x0a @@ -122,6 +123,11 @@ int select_i2c_ch_pca9547(u8 ch) return 0; }
+int i2c_multiplexer_select_vid_channel(u8 channel) +{ + return select_i2c_ch_pca9547(channel); +} + int config_board_mux(int ctrl_type) { u8 reg5; @@ -188,6 +194,9 @@ int misc_init_r(void) if (hwconfig("sdhc")) config_board_mux(MUX_TYPE_SDHC);
+ if (adjust_vdd(0)) + printf("Warning: Adjusting core voltage failed.\n"); + return 0; }
diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 59a3f66..2a1e841 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -14,6 +14,22 @@
#define CONFIG_DISPLAY_BOARDINFO
+#define I2C_MUX_CH_VOL_MONITOR 0xa +#define I2C_VOL_MONITOR_ADDR 0x38 +#define CONFIG_VOL_MONITOR_IR36021_READ +#define CONFIG_VOL_MONITOR_IR36021_SET + +#define CONFIG_VID_FLS_ENV "ls2080ardb_vdd_mv" +#ifndef CONFIG_SPL_BUILD +#define CONFIG_VID +#endif +/* step the IR regulator in 5mV increments */ +#define IR_VDD_STEP_DOWN 5 +#define IR_VDD_STEP_UP 5 +/* The lowest and highest voltage allowed for LS2080ARDB */ +#define VDD_MV_MIN 819 +#define VDD_MV_MAX 1212 + #ifndef __ASSEMBLY__ unsigned long get_board_sys_clk(void); #endif
Changes in v4:
Changes in v3:
Changes in v2
Applied to u-boot-fsl-qoriq master. Awaiting upstream.
Thanks.
York
Rai Harninder
York Sun
