[U-Boot] fw_printenv is not working
Hi, when i run fw_printenv , its not working..It shows:- fw_printenv: line 1: syntax error: "(" unexpected error... Let me tell you what i did... 1) i copy the u-boot source code from my colleague and copy in my hard disk. 2) After then i set the environment through commnads. the commands which i run are # make CROSS_COMPILE=arm-none-linux-gnueabi- ARCH=arm distclean # make CROSS_COMPILE=arm-none-linux-gnueabi- ARCH=arm omap3_evm_config # make CROSS_COMPILE=arm-none-linux-gnueabi- ARCH=arm 3) After then i go to /tools/env, where i configure the fw_env.config and then run make command. 4) After ruuning the command i got crc32.c and fw_printenv. 5)i copied the fw_printenv into the SD-Card and insert the card into the OMAP3EVM board. 6) after then when i use the command ./fw_printenv it throws the error fw_printenv: line 1: syntax error: "(" unexpected error.. Can u please help me what i have to do... I think i am doing something wrong...
Hi Mateer,
I am also facing the same issue. I am also getting the error: fw_printenv: line 1: syntax error: "(" unexpected whenever I give command fw_printenv. I am using OMAPL138 EVM board.
Can u please help me... How did you resolve this error for your board?? Thanks in advance... Nih_a
- i copy the u-boot source code from my colleague and copy in my hard
Dear Nih_a,
when replying to a mail, please make sure to maintain thread information, i. e. make sure to set appropriate In-reply-to: and References: headers.
I guess you did not read tools/env/README , or did you? Did you follow the instructions of setting HOSTCC= in the call to make ?
mateer
Mike Frysinger
Nih_a
