[U-Boot] [PATCH] Cleanup Whitelist entries
There are several items in the whitelist which don't appear to be used anywhere outside of the whitelist itself. These include:
CONFIG_IMX_NAND CONFIG_MXS_AUART CONFIG_MXS_AUART_BASE CONFIG_NORFLASH_PS32BIT CONFIG_QSPI CONFIG_REV3 CONFIG_SIMU CONFIG_STV0991 CONFIG_SYS_MEMORY_TOP CONFIG_SYS_SERIAL_BOOT CONFIG_SYS_TEXT_ADDR CONFIG_SYS_USBCTRL CONFIG_SYS_VIDEO
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 295681c..6f9baea 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1002,7 +1002,6 @@ CONFIG_IMAGE_FORMAT_LEGACY CONFIG_IMX CONFIG_IMX6_PWM_PER_CLK CONFIG_IMX_HDMI -CONFIG_IMX_NAND CONFIG_IMX_OTP CONFIG_IMX_VIDEO_SKIP CONFIG_IMX_WATCHDOG @@ -1403,8 +1402,6 @@ CONFIG_MXC_USB_FLAGS CONFIG_MXC_USB_PORT CONFIG_MXC_USB_PORTSC CONFIG_MXS -CONFIG_MXS_AUART -CONFIG_MXS_AUART_BASE CONFIG_MXS_GPIO CONFIG_MXS_OCOTP CONFIG_MX_CYCLIC @@ -1459,7 +1456,6 @@ CONFIG_NFS_TIMEOUT CONFIG_NOBQFMAN CONFIG_NON_SECURE CONFIG_NORBOOT -CONFIG_NORFLASH_PS32BIT CONFIG_NO_ETH CONFIG_NO_RELOCATION CONFIG_NO_WAIT @@ -1670,7 +1666,6 @@ CONFIG_QBMAN_CLK_DIV CONFIG_QE CONFIG_QEMU_MIPS CONFIG_QIXIS_I2C_ACCESS -CONFIG_QSPI CONFIG_QSPI_QUAD_SUPPORT CONFIG_QSPI_SEL_GPIO CONFIG_QUOTA @@ -1716,7 +1711,6 @@ CONFIG_RESET_VECTOR_ADDRESS CONFIG_RESTORE_FLASH CONFIG_RES_BLOCK_SIZE CONFIG_REV1 -CONFIG_REV3 CONFIG_REVISION_TAG CONFIG_RFSPART CONFIG_RIO @@ -1870,7 +1864,6 @@ CONFIG_SIEMENS_DRACO CONFIG_SIEMENS_MACH_TYPE CONFIG_SIEMENS_PXM2 CONFIG_SIEMENS_RUT -CONFIG_SIMU CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION CONFIG_SKIP_LOWLEVEL_INIT CONFIG_SKIP_LOWLEVEL_INIT_ONLY @@ -2083,7 +2076,6 @@ CONFIG_STRIDER_CPU CONFIG_STRIDER_CPU_DP CONFIG_STRIDER_FANS CONFIG_STUART -CONFIG_STV0991 CONFIG_STV0991_HZ CONFIG_STV0991_HZ_CLOCK CONFIG_ST_SMI @@ -3535,7 +3527,6 @@ CONFIG_SYS_MECR_VAL CONFIG_SYS_MEMAC_LITTLE_ENDIAN CONFIG_SYS_MEMORY_BASE CONFIG_SYS_MEMORY_SIZE -CONFIG_SYS_MEMORY_TOP CONFIG_SYS_MEMTEST_END CONFIG_SYS_MEMTEST_SCRATCH CONFIG_SYS_MEMTEST_START @@ -4314,7 +4305,6 @@ CONFIG_SYS_SDRC_TR_VAL2 CONFIG_SYS_SD_VOLTAGE CONFIG_SYS_SEC_MON_ADDR CONFIG_SYS_SEC_MON_OFFSET -CONFIG_SYS_SERIAL_BOOT CONFIG_SYS_SFP_ADDR CONFIG_SYS_SFP_OFFSET CONFIG_SYS_SGMII1_PHY_ADDR @@ -4403,7 +4393,6 @@ CONFIG_SYS_SUPPORT_64BIT_DATA CONFIG_SYS_SXCNFG_VAL CONFIG_SYS_TBIPA_VALUE CONFIG_SYS_TCLK -CONFIG_SYS_TEXT_ADDR CONFIG_SYS_TEXT_BASE_NOR CONFIG_SYS_TEXT_BASE_SPL CONFIG_SYS_TIMERBASE @@ -4496,7 +4485,6 @@ CONFIG_SYS_ULB_CLK CONFIG_SYS_UNIFY_CACHE CONFIG_SYS_UNSPEC_PHYID CONFIG_SYS_UNSPEC_STRID -CONFIG_SYS_USBCTRL CONFIG_SYS_USBD_BASE CONFIG_SYS_USB_EHCI_CPU_INIT CONFIG_SYS_USB_EHCI_REGS_BASE @@ -4545,7 +4533,6 @@ CONFIG_SYS_VCXK_RESET_DDR CONFIG_SYS_VCXK_RESET_PIN CONFIG_SYS_VCXK_RESET_PORT CONFIG_SYS_VGA_RAM_EN -CONFIG_SYS_VIDEO CONFIG_SYS_VIDEO_LOGO_MAX_SIZE CONFIG_SYS_VSC7385_BASE CONFIG_SYS_VSC7385_BASE_PHYS
This misses things that are set in CONFIG_SYS_EXTRA_OPTIONS and need to be converted first. Thanks!
Adam Ford
