[PATCH] board_r: use IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC) in board_init_r()
Drop CONFIG_NEEDS_MANUAL_RELOC ifdefs in board_init_r() and use IS_ENABLED() instead. Also, use the MANUAL_RELOC() macro to update the initcall pointers.
Signed-off-by: Ovidiu Panait ovidiu.panait@windriver.com ---
common/board_r.c | 13 +++++-------- 1 file changed, 5 insertions(+), 8 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index 93c9c2e50d..6f4aca2077 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -61,6 +61,7 @@ #include <wdt.h> #include <asm-generic/gpio.h> #include <efi_loader.h> +#include <relocate.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -810,19 +811,15 @@ void board_init_r(gd_t *new_gd, ulong dest_addr) if (CONFIG_IS_ENABLED(X86_64) && !IS_ENABLED(CONFIG_EFI_APP)) arch_setup_gd(new_gd);
-#ifdef CONFIG_NEEDS_MANUAL_RELOC - int i; -#endif - #if !defined(CONFIG_X86) && !defined(CONFIG_ARM) && !defined(CONFIG_ARM64) gd = new_gd; #endif gd->flags &= ~GD_FLG_LOG_READY;
-#ifdef CONFIG_NEEDS_MANUAL_RELOC - for (i = 0; i < ARRAY_SIZE(init_sequence_r); i++) - init_sequence_r[i] += gd->reloc_off; -#endif + if (IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC)) { + for (int i = 0; i < ARRAY_SIZE(init_sequence_r); i++) + MANUAL_RELOC(init_sequence_r[i]); + }
if (initcall_run_list(init_sequence_r)) hang();
Ovidiu Panait
