[U-Boot] [PULL u-boot] Please pull u-boot-amlogic-20191018
Hi Tom,
This PR adds more support for Amlogic G12A and derivatives SoCs based boards, by enabling HDMI/CVBS display support and 2 new boards, Khadas VIM3, and the SEI610 little brother of the already supported SEI510. Daniel also pushed a documentation update to explicit the available alternatives to the currently used blobs and tools to created a bootable binary.
The CI job is at https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic/pipelines/1012
Thanks, Neil
The following changes since commit a2fce50455c9831f36765e5813b0b5e98f55d70b:
Merge tag 'for-v2020.01' of https://gitlab.denx.de/u-boot/custodians/u-boot-ubi (2019-10-17 07:26:16 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic.git tags/u-boot-amlogic-20191018
for you to fetch changes up to be2ffa1656509cc974910224a87443868d7037d9:
configs: sei610: Add config file to fix userdata size (2019-10-18 14:54:37 +0200)
---------------------------------------------------------------- - document alternative libretech-cc installation methods, including upstream TF-A and opensource tools - add HDMI/CVBS display support for Amlogic G12A SoCs and SEI510 board - add support for Amlogic A311D based Khadas VIM3 - add support for Amlogic S905X3 based SEI610 board, targeting Android support like SEI510
---------------------------------------------------------------- Andreas Färber (4): arm: dts: Import and update DT for Khadas VIM3 configs: Add Khadas VIM3 defconfig arm: meson: Tidy SoC information output arm: meson: Recognize A311D SoC
Daniel Drake (1): board: amlogic: document alternative libretech-cc installation methods
Guillaume La Roque (2): configs: sei510: rework header and fix userdata size configs: sei610: Add config file to fix userdata size
Neil Armstrong (16): power: domain: meson-gx-pwrc: add G12A support clk: meson: g12a: add support for VPU/HDMI clocks video: meson: remove power domain get video: meson: sync with linux drm-misc tree video: meson: add compatible for Amlogic G12A arm: meson: board-g12a: Setup VPU in fdt ARM: dts: meson-g12a: add U-Boot specific DT for graphics configs: sei510: enable Video Display support ARM: meson: add SM1 SoC id mmc: meson-gx: add support for mmc-pwrseq-emmc clk: meson-sm1: add compatible ARM: dts: Import SEI610 DT from Linux 5.4-rc2 power: domain: add Amlogic Everything-Else power domain driver configs: sei510: enable everything-else power domain ARM: dts: meson-sm1: add U-Boot specific DT for graphics boards: amlogic: add SEI610 support
MAINTAINERS | 1 + arch/arm/dts/Makefile | 4 +- arch/arm/dts/meson-g12-common-u-boot.dtsi | 29 + arch/arm/dts/meson-g12-common.dtsi | 2435 ++++++++++++++++++++ arch/arm/dts/meson-g12a-sei510-u-boot.dtsi | 7 + arch/arm/dts/meson-g12a-u200-u-boot.dtsi | 7 + arch/arm/dts/meson-g12a.dtsi | 2422 +------------------ arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts | 16 + arch/arm/dts/meson-g12b-a311d.dtsi | 149 ++ arch/arm/dts/meson-g12b-khadas-vim3.dtsi | 189 ++ arch/arm/dts/meson-g12b-odroid-n2-u-boot.dtsi | 7 + arch/arm/dts/meson-g12b-odroid-n2.dts | 104 +- arch/arm/dts/meson-g12b-s922x.dtsi | 124 + arch/arm/dts/meson-g12b.dtsi | 39 +- arch/arm/dts/meson-khadas-vim3.dtsi | 360 +++ arch/arm/dts/meson-sm1-sei610-u-boot.dtsi | 7 + arch/arm/dts/meson-sm1-sei610.dts | 383 +++ arch/arm/dts/meson-sm1.dtsi | 147 ++ arch/arm/mach-meson/board-g12a.c | 5 + arch/arm/mach-meson/board-info.c | 5 +- board/amlogic/p212/README.libretech-cc | 41 +- board/amlogic/sei610/MAINTAINERS | 7 + board/amlogic/sei610/Makefile | 6 + board/amlogic/sei610/README | 119 + board/amlogic/sei610/sei610.c | 26 + board/amlogic/w400/MAINTAINERS | 1 + board/amlogic/w400/README.khadas-vim3 | 132 ++ configs/khadas-vim3_defconfig | 54 + configs/sei510_defconfig | 11 + configs/sei610_defconfig | 76 + drivers/clk/meson/g12a.c | 621 ++++- drivers/mmc/meson_gx_mmc.c | 51 + drivers/power/domain/Kconfig | 7 + drivers/power/domain/Makefile | 1 + drivers/power/domain/meson-ee-pwrc.c | 430 ++++ drivers/power/domain/meson-gx-pwrc-vpu.c | 155 +- drivers/video/meson/meson_dw_hdmi.c | 61 +- drivers/video/meson/meson_plane.c | 47 +- drivers/video/meson/meson_registers.h | 373 ++- drivers/video/meson/meson_vclk.c | 233 +- drivers/video/meson/meson_venc.c | 169 +- drivers/video/meson/meson_vpu.c | 11 +- drivers/video/meson/meson_vpu.h | 2 + drivers/video/meson/meson_vpu_init.c | 205 +- include/configs/meson64_android.h | 136 ++ include/configs/sei510.h | 113 +- include/configs/sei610.h | 31 + include/dt-bindings/clock/g12a-clkc.h | 6 + include/dt-bindings/power/meson-g12a-power.h | 13 + include/dt-bindings/power/meson-sm1-power.h | 18 + .../reset/amlogic,meson-g12a-audio-reset.h | 38 + 51 files changed, 6941 insertions(+), 2693 deletions(-) create mode 100644 arch/arm/dts/meson-g12-common-u-boot.dtsi create mode 100644 arch/arm/dts/meson-g12-common.dtsi create mode 100644 arch/arm/dts/meson-g12a-sei510-u-boot.dtsi create mode 100644 arch/arm/dts/meson-g12a-u200-u-boot.dtsi create mode 100644 arch/arm/dts/meson-g12b-a311d-khadas-vim3.dts create mode 100644 arch/arm/dts/meson-g12b-a311d.dtsi create mode 100644 arch/arm/dts/meson-g12b-khadas-vim3.dtsi create mode 100644 arch/arm/dts/meson-g12b-odroid-n2-u-boot.dtsi create mode 100644 arch/arm/dts/meson-g12b-s922x.dtsi create mode 100644 arch/arm/dts/meson-khadas-vim3.dtsi create mode 100644 arch/arm/dts/meson-sm1-sei610-u-boot.dtsi create mode 100644 arch/arm/dts/meson-sm1-sei610.dts create mode 100644 arch/arm/dts/meson-sm1.dtsi create mode 100644 board/amlogic/sei610/MAINTAINERS create mode 100644 board/amlogic/sei610/Makefile create mode 100644 board/amlogic/sei610/README create mode 100644 board/amlogic/sei610/sei610.c create mode 100644 board/amlogic/w400/README.khadas-vim3 create mode 100644 configs/khadas-vim3_defconfig create mode 100644 configs/sei610_defconfig create mode 100644 drivers/power/domain/meson-ee-pwrc.c create mode 100644 include/configs/meson64_android.h create mode 100644 include/configs/sei610.h create mode 100644 include/dt-bindings/power/meson-g12a-power.h create mode 100644 include/dt-bindings/power/meson-sm1-power.h create mode 100644 include/dt-bindings/reset/amlogic,meson-g12a-audio-reset.h
On Fri, Oct 18, 2019 at 04:58:06PM +0200, Neil Armstrong wrote:
Hi Tom,
Thanks, Neil
Neil Armstrong
