[PATCH 0/3] sunxi: H6/H616: PRCM updates
During H616 boot0 blob and H6 boot0 sources analysis, I noticed that SPL doesn't set resistor calibration and PLL LDO on H6. Tests didn't show any observable difference, but nevertheless it's better to mimick boot0 behaviour.
In the process I also added names for few PRCM registers so it's clearer what code does.
Please take a look.
Best regards, Jernej
Jernej Skrabec (3): sunxi: prcm: Add a few registers sunxi: clock: H6/H616: Add resistor calibration sunxi: clock: H6: Adjust PLL LDO before clock setup
arch/arm/include/asm/arch-sunxi/prcm_sun50i.h | 10 ++++++++++ arch/arm/mach-sunxi/clock_sun50i_h6.c | 20 ++++++++++++++++--- arch/arm/mach-sunxi/dram_sun50i_h6.c | 8 +++++--- arch/arm/mach-sunxi/dram_sun50i_h616.c | 7 +++++-- 4 files changed, 37 insertions(+), 8 deletions(-)
H6 and H616 SPL code has a few writes to unknown PRCM registers. Now that we know what they are, let's replace magic offsets with proper register names.
Signed-off-by: Jernej Skrabec jernej.skrabec@gmail.com --- arch/arm/include/asm/arch-sunxi/prcm_sun50i.h | 10 ++++++++++ arch/arm/mach-sunxi/clock_sun50i_h6.c | 4 +++- arch/arm/mach-sunxi/dram_sun50i_h6.c | 8 +++++--- arch/arm/mach-sunxi/dram_sun50i_h616.c | 7 +++++-- 4 files changed, 23 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/prcm_sun50i.h b/arch/arm/include/asm/arch-sunxi/prcm_sun50i.h index 5f636e83845a..fd63d3aad839 100644 --- a/arch/arm/include/asm/arch-sunxi/prcm_sun50i.h +++ b/arch/arm/include/asm/arch-sunxi/prcm_sun50i.h @@ -37,8 +37,18 @@ struct sunxi_prcm_reg { u32 w1_gate_reset; /* 0x1ec */ u8 res10[0x1c]; /* 0x1f0 */ u32 rtc_gate_reset; /* 0x20c */ + u8 res11[0x34]; /* 0x210 */ + u32 pll_ldo_cfg; /* 0x244 */ + u8 res12[0x8]; /* 0x248 */ + u32 sys_pwroff_gating; /* 0x250 */ + u8 res13[0xbc]; /* 0x254 */ + u32 res_cal_ctrl; /* 0x310 */ + u32 ohms200; /* 0x314 */ + u32 ohms240; /* 0x318 */ + u32 res_cal_status; /* 0x31c */ }; check_member(sunxi_prcm_reg, rtc_gate_reset, 0x20c); +check_member(sunxi_prcm_reg, res_cal_status, 0x31c);
#define PRCM_TWI_GATE (1 << 0) #define PRCM_TWI_RESET (1 << 16) diff --git a/arch/arm/mach-sunxi/clock_sun50i_h6.c b/arch/arm/mach-sunxi/clock_sun50i_h6.c index a947463e0a53..e5846e6381ff 100644 --- a/arch/arm/mach-sunxi/clock_sun50i_h6.c +++ b/arch/arm/mach-sunxi/clock_sun50i_h6.c @@ -9,10 +9,12 @@ void clock_init_safe(void) { struct sunxi_ccm_reg *const ccm = (struct sunxi_ccm_reg *)SUNXI_CCM_BASE; + struct sunxi_prcm_reg *const prcm = + (struct sunxi_prcm_reg *)SUNXI_PRCM_BASE;
/* this seems to enable PLLs on H616 */ if (IS_ENABLED(CONFIG_MACH_SUN50I_H616)) - setbits_le32(SUNXI_PRCM_BASE + 0x250, 0x10); + setbits_le32(&prcm->sys_pwroff_gating, 0x10);
clock_set_pll1(408000000);
diff --git a/arch/arm/mach-sunxi/dram_sun50i_h6.c b/arch/arm/mach-sunxi/dram_sun50i_h6.c index d05375c90277..b332f3a3e4aa 100644 --- a/arch/arm/mach-sunxi/dram_sun50i_h6.c +++ b/arch/arm/mach-sunxi/dram_sun50i_h6.c @@ -12,6 +12,7 @@ #include <asm/arch/clock.h> #include <asm/arch/dram.h> #include <asm/arch/cpu.h> +#include <asm/arch/prcm.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/kconfig.h> @@ -665,6 +666,8 @@ unsigned long sunxi_dram_init(void) { struct sunxi_mctl_com_reg * const mctl_com = (struct sunxi_mctl_com_reg *)SUNXI_DRAM_COM_BASE; + struct sunxi_prcm_reg *const prcm = + (struct sunxi_prcm_reg *)SUNXI_PRCM_BASE; struct dram_para para = { .clk = CONFIG_DRAM_CLK, #ifdef CONFIG_SUNXI_DRAM_H6_LPDDR3 @@ -680,9 +683,8 @@ unsigned long sunxi_dram_init(void)
unsigned long size;
- /* RES_CAL_CTRL_REG in BSP U-boot*/ - setbits_le32(0x7010310, BIT(8)); - clrbits_le32(0x7010318, 0x3f); + setbits_le32(&prcm->res_cal_ctrl, BIT(8)); + clrbits_le32(&prcm->ohms240, 0x3f);
mctl_auto_detect_rank_width(¶); mctl_auto_detect_dram_size(¶); diff --git a/arch/arm/mach-sunxi/dram_sun50i_h616.c b/arch/arm/mach-sunxi/dram_sun50i_h616.c index 83e8abc2f8d8..454c845a0010 100644 --- a/arch/arm/mach-sunxi/dram_sun50i_h616.c +++ b/arch/arm/mach-sunxi/dram_sun50i_h616.c @@ -19,6 +19,7 @@ #include <asm/arch/clock.h> #include <asm/arch/dram.h> #include <asm/arch/cpu.h> +#include <asm/arch/prcm.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/kconfig.h> @@ -1001,14 +1002,16 @@ static unsigned long mctl_calc_size(struct dram_para *para)
unsigned long sunxi_dram_init(void) { + struct sunxi_prcm_reg *const prcm = + (struct sunxi_prcm_reg *)SUNXI_PRCM_BASE; struct dram_para para = { .clk = CONFIG_DRAM_CLK, .type = SUNXI_DRAM_TYPE_DDR3, }; unsigned long size;
Reviewed-by: Samuel Holland samuel@sholland.org
BSP boot0 executes resistor calibration before clocks are initialized. Let's do that.
Signed-off-by: Jernej Skrabec jernej.skrabec@gmail.com --- arch/arm/mach-sunxi/clock_sun50i_h6.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-sunxi/clock_sun50i_h6.c b/arch/arm/mach-sunxi/clock_sun50i_h6.c index e5846e6381ff..32119ad16555 100644 --- a/arch/arm/mach-sunxi/clock_sun50i_h6.c +++ b/arch/arm/mach-sunxi/clock_sun50i_h6.c @@ -12,9 +12,14 @@ void clock_init_safe(void) struct sunxi_prcm_reg *const prcm = (struct sunxi_prcm_reg *)SUNXI_PRCM_BASE;
- /* this seems to enable PLLs on H616 */ - if (IS_ENABLED(CONFIG_MACH_SUN50I_H616)) + if (IS_ENABLED(CONFIG_MACH_SUN50I_H616)) { + /* this seems to enable PLLs on H616 */ setbits_le32(&prcm->sys_pwroff_gating, 0x10); + setbits_le32(&prcm->res_cal_ctrl, 2); + } + + clrbits_le32(&prcm->res_cal_ctrl, 1); + setbits_le32(&prcm->res_cal_ctrl, 1);
BSP boot0 adjust PLL LDO regulator before clocks are initialized. Let's do that.
Signed-off-by: Jernej Skrabec jernej.skrabec@gmail.com --- arch/arm/mach-sunxi/clock_sun50i_h6.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/mach-sunxi/clock_sun50i_h6.c b/arch/arm/mach-sunxi/clock_sun50i_h6.c index 32119ad16555..7926394cf762 100644 --- a/arch/arm/mach-sunxi/clock_sun50i_h6.c +++ b/arch/arm/mach-sunxi/clock_sun50i_h6.c @@ -21,6 +21,13 @@ void clock_init_safe(void) clrbits_le32(&prcm->res_cal_ctrl, 1); setbits_le32(&prcm->res_cal_ctrl, 1);
+ if (IS_ENABLED(CONFIG_MACH_SUN50I_H6)) { + /* set key field for ldo enable */ + setbits_le32(&prcm->pll_ldo_cfg, 0xA7000000); + /* set PLL VDD LDO output to 1.14 V */ + setbits_le32(&prcm->pll_ldo_cfg, 0x60000); + } + clock_set_pll1(408000000);
writel(CCM_PLL6_DEFAULT, &ccm->pll6_cfg);
On Sun, 30 Jan 2022 15:27:12 +0100 Jernej Skrabec jernej.skrabec@gmail.com wrote:
Please take a look.
All merged into sunxi/master, which already landed in mainline.
Thanks! Andre
Andre Przywara
Jernej Skrabec
Samuel Holland
