I'm trying to run mainline u-boot on amlogic a96mini device but before I try to flash it does anybody have an idea if it will work on mainline. As I have limited number of devices and I know that after flashing I can brick the board so would like to ask if anybody have experience with this device and running mainline. Thanks and BR,
marek
I would strongly recommend making https://github.com/superna9999/linux/wiki/Amlogic-HDMI-Boot-Dongle as a back-up. While I have before managed to interrupt a re-flash cycle such that the DTB on-board is still there and so the binary portions of the firmware are happy it will then load U-Boot from SD card. I did not play with mainline however.
Hi Tom,
OK thanks for hint. IIRC this hdmi thingy tells FW from which media to boot and then I can compile u-boot and have boot it from SDcard? For me any amlogic u-boot is fine just need to be sure it will boot from emmc in final step then :). Thanks.
-- Tom
BR,
marek
On Mon, Dec 09, 2019 at 08:47:07AM +0100, Belisko Marek wrote:
Hi Tom,
Correct. The previous stages will check and then if it sees the magic continue to boot process from other media. This will prevent you from bricking the hardware :)
Belisko Marek
