[U-Boot-Users] [Patch]
Hi Attached remade multicore patch to allow users to specify the core module fitted to their ARM supplied Integrator development board.
Please inform me of any defects found.
CHANGELOG: * Patch by Peter Pearse, 11 Apr 2005 - add core module targets for integratorap, integratorcp - add ARM946E cpu support - remap SSRAM memory to 0x00000000
Notes ----- a) Provides targets for all supported Core Modules - targets are of the form integrator<type>_CM<id>_config Examples make integratorap_CM946E_S make integratorcp_CM920T_config
b) Previous targets integegratorcp, integratorap retained.
c) Tested to build with MAKEALL arm
d) Tested to boot linux with - Integrator/CP CM920T - Integrator/CP CM926EJ-S - Versatile PB926EJ-S - both Integrator combinations boot in all three settings - Manually run U-Boot in ARM Boot Monitor - Auto boot U-Boot through ARM Boot Monitor - Auto boot direct into U-Boot
e) Patched against head at 11 Apr 2005
f) Replaces the patch submitted on 02 Feb 2005
------------------------ Peter.Pearse@arm.com -------------------------
It looks like this one is superseded by the second post of the same patch.
-- Regards, George
In message 89A528FE6DB0FA44877BB2F05B846718021F88C4@ZIPPY.Emea.Arm.com you wrote:
CHANGELOG:
- Patch by Peter Pearse, 11 Apr 2005
Most of this patch does not apply any more. Skipped. Please resubmit any parts that are still missing in the current code.
George G. Davis
Peter Pearse
