[PATCH v2 0/4] gpio: update gpio_get_status()
Currently, if pin's function is GPIOF_FUNC, only "func" if displayed without any other information. It would be interesting, if information is available, to indicate which pinmuxing's name is used.
Changes in v2: - add gpio test
Patrice Chotard (4): gpio: Allow to print pin's label even for pin with GPIOF_FUNC function gpio: Fix pin's status display for pin with GPIOF_UNUSED function pinctrl: pinctrl_stm32: Populate uc_priv->name[] with pinmux node's name gpio: sandbox: Add GPIOD_IS_AF for gpio configured in alternate function
drivers/gpio/gpio-uclass.c | 18 ++++++++++----- drivers/gpio/sandbox.c | 5 +++++ drivers/pinctrl/pinctrl_stm32.c | 8 +++++-- include/asm-generic/gpio.h | 1 + include/dt-bindings/gpio/sandbox-gpio.h | 3 +++ test/dm/gpio.c | 30 +++++++++++++++++++++++++ 6 files changed, 57 insertions(+), 8 deletions(-)
For example, for STM32 SoC's based platform, "gpio status" command output :
before Bank GPIOZ: GPIOZ0: unused : 0 [ ] GPIOZ1: unused : 0 [ ] GPIOZ2: unused : 0 [ ] GPIOZ3: unused : 0 [ ] GPIOZ4: func GPIOZ5: func GPIOZ6: unused : 0 [ ] GPIOZ7: unused : 0 [ ] GPIOZ8: unknown GPIOZ9: unknown GPIOZ10: unknown GPIOZ11: unknown GPIOZ12: unknown GPIOZ13: unknown GPIOZ14: unknown GPIOZ15: unknown
After Bank GPIOZ: GPIOZ0: unused : 0 [ ] GPIOZ1: unused : 0 [ ] GPIOZ2: unused : 0 [ ] GPIOZ3: unused : 0 [ ] GPIOZ4: func i2c4-0 GPIOZ5: func i2c4-0 GPIOZ6: unused : 0 [ ] GPIOZ7: unused : 0 [ ] GPIOZ8: unknown GPIOZ9: unknown GPIOZ10: unknown GPIOZ11: unknown GPIOZ12: unknown GPIOZ13: unknown GPIOZ14: unknown GPIOZ15: unknown
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
(no changes since v1)
drivers/gpio/gpio-uclass.c | 16 +++++++++++----- 1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index 0ed32b7217..d60e46159a 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -884,26 +884,31 @@ int gpio_get_status(struct udevice *dev, int offset, char *buf, int buffsize) const struct dm_gpio_ops *ops = gpio_get_ops(dev); struct gpio_dev_priv *priv; char *str = buf; + const char *label; int func; int ret; int len; + bool used;
BUILD_BUG_ON(GPIOF_COUNT != ARRAY_SIZE(gpio_function));
*buf = 0; priv = dev_get_uclass_priv(dev); - ret = gpio_get_raw_function(dev, offset, NULL); + ret = gpio_get_raw_function(dev, offset, &label); if (ret < 0) return ret; func = ret; len = snprintf(str, buffsize, "%s%d: %s", priv->bank_name ? priv->bank_name : "", offset, gpio_function[func]); - if (func == GPIOF_INPUT || func == GPIOF_OUTPUT || - func == GPIOF_UNUSED) { - const char *label; - bool used;
+ switch (func) { + case GPIOF_FUNC: + snprintf(str + len, buffsize - len, " %s", label ? label : ""); + break; + case GPIOF_INPUT: + case GPIOF_OUTPUT: + case GPIOF_UNUSED: ret = ops->get_value(dev, offset); if (ret < 0) return ret; @@ -913,6 +918,7 @@ int gpio_get_status(struct udevice *dev, int offset, char *buf, int buffsize) used ? 'x' : ' ', used ? " " : "", label ? label : ""); + break; }
Even pin with GPIOF_UNUSED function can have a label. The criteria to add or not a space character is linked to label not to the used/unused status.
drivers/gpio/gpio-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpio/gpio-uclass.c b/drivers/gpio/gpio-uclass.c index d60e46159a..a00880e446 100644 --- a/drivers/gpio/gpio-uclass.c +++ b/drivers/gpio/gpio-uclass.c @@ -916,7 +916,7 @@ int gpio_get_status(struct udevice *dev, int offset, char *buf, int buffsize) snprintf(str + len, buffsize - len, ": %d [%c]%s%s", ret, used ? 'x' : ' ', - used ? " " : "", + label ? " " : "", label ? label : ""); break; }
Populate uc_priv->name[] with pinmux node's name in order to indicate the pinmuxing's name in case GPIO is configured in alternate.
drivers/pinctrl/pinctrl_stm32.c | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index 990cd19286..b755fa42b4 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -257,10 +257,12 @@ static int stm32_pinctrl_probe(struct udevice *dev) return 0; }
-static int stm32_gpio_config(struct gpio_desc *desc, +static int stm32_gpio_config(ofnode node, + struct gpio_desc *desc, const struct stm32_gpio_ctl *ctl) { struct stm32_gpio_priv *priv = dev_get_priv(desc->dev); + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(desc->dev); struct stm32_gpio_regs *regs = priv->regs; struct stm32_pinctrl_priv *ctrl_priv; int ret; @@ -291,6 +293,8 @@ static int stm32_gpio_config(struct gpio_desc *desc, index = desc->offset; clrsetbits_le32(®s->otyper, OTYPE_MSK << index, ctl->otype << index);
+ uc_priv->name[desc->offset] = strdup(ofnode_get_name(node)); + hwspinlock_unlock(&ctrl_priv->hws);
return 0; @@ -385,7 +389,7 @@ static int stm32_pinctrl_config(ofnode node) if (rv) return rv; desc.offset = gpio_dsc.pin; - rv = stm32_gpio_config(&desc, &gpio_ctl); + rv = stm32_gpio_config(node, &desc, &gpio_ctl); log_debug("rv = %d\n\n", rv); if (rv) return rv;
This allows to test if a pin's label if displayed using gpio_get_status() when this pin is configured in alternate function.
drivers/gpio/sandbox.c | 5 +++++ include/asm-generic/gpio.h | 1 + include/dt-bindings/gpio/sandbox-gpio.h | 3 +++ test/dm/gpio.c | 30 +++++++++++++++++++++++++ 4 files changed, 39 insertions(+)
diff --git a/drivers/gpio/sandbox.c b/drivers/gpio/sandbox.c index 106b2a7b27..305f9a6ff6 100644 --- a/drivers/gpio/sandbox.c +++ b/drivers/gpio/sandbox.c @@ -196,6 +196,8 @@ static int sb_gpio_get_function(struct udevice *dev, unsigned offset) return GPIOF_OUTPUT; if (get_gpio_flag(dev, offset, GPIOD_IS_IN)) return GPIOF_INPUT; + if (get_gpio_flag(dev, offset, GPIOD_IS_AF)) + return GPIOF_FUNC;
return GPIOF_INPUT; /*GPIO is not configurated */ } @@ -219,6 +221,9 @@ static int sb_gpio_xlate(struct udevice *dev, struct gpio_desc *desc, if (args->args[1] & GPIO_OUT_ACTIVE) desc->flags |= GPIOD_IS_OUT_ACTIVE;
+ if (args->args[1] & GPIO_AF) + desc->flags |= GPIOD_IS_AF; + return 0; }
diff --git a/include/asm-generic/gpio.h b/include/asm-generic/gpio.h index 81f63f06f1..0fcf70983f 100644 --- a/include/asm-generic/gpio.h +++ b/include/asm-generic/gpio.h @@ -127,6 +127,7 @@ struct gpio_desc { #define GPIOD_OPEN_SOURCE BIT(6) /* GPIO is open source type */ #define GPIOD_PULL_UP BIT(7) /* GPIO has pull-up enabled */ #define GPIOD_PULL_DOWN BIT(8) /* GPIO has pull-down enabled */ +#define GPIOD_IS_AF BIT(9) /* GPIO is an alternate function */
/* Flags for updating the above */ #define GPIOD_MASK_DIR (GPIOD_IS_OUT | GPIOD_IS_IN | \ diff --git a/include/dt-bindings/gpio/sandbox-gpio.h b/include/dt-bindings/gpio/sandbox-gpio.h index e4bfdb3ce1..05f9836583 100644 --- a/include/dt-bindings/gpio/sandbox-gpio.h +++ b/include/dt-bindings/gpio/sandbox-gpio.h @@ -21,4 +21,7 @@ /* Bit 18 express GPIO output is active */ #define GPIO_OUT_ACTIVE 0x40000
+/* Bit 19 express GPIO set as alternate function */ +#define GPIO_AF 0x80000 + #endif diff --git a/test/dm/gpio.c b/test/dm/gpio.c index 33ae98701f..a8c35d4370 100644 --- a/test/dm/gpio.c +++ b/test/dm/gpio.c @@ -778,3 +778,33 @@ static int dm_test_gpio_get_values_as_int_base3(struct unit_test_state *uts) } DM_TEST(dm_test_gpio_get_values_as_int_base3, UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT); + +/* Check that gpio_get_status return the label of a GPIO configured as GPIOD_AF */ +static int dm_test_gpio_function(struct unit_test_state *uts) +{ + struct gpio_desc desc; + struct udevice *dev; + ulong flags; + unsigned int offset, gpio; + char buf[80]; + + ut_assertok(uclass_get_device(UCLASS_TEST_FDT, 0, &dev)); + ut_asserteq_str("a-test", dev->name); + + /* request gpio_b 5 */ + ut_assertok(gpio_request_by_name(dev, "test-gpios", 2, &desc, 0)); + /* update gpio_b 5 function to GPIO_AF */ + ut_assertok(dm_gpio_clrset_flags(&desc, GPIOD_IS_AF, GPIOD_IS_AF)); + ut_assertok(dm_gpio_get_flags(&desc, &flags)); + ut_asserteq(GPIOD_IS_AF, flags); + /* check using gpio_get_status that label is displayed for a pin with GPIO_AF function */ + ut_assertok(gpio_lookup_name("b5", &dev, &offset, &gpio)); + ut_assertok(gpio_get_status(dev, offset, buf, sizeof(buf))); + ut_asserteq_str("b5: func a-test.test-gpios2", buf); + + ut_assertok(dm_gpio_free(dev, &desc)); + + return 0; +} +DM_TEST(dm_test_gpio_function, + UT_TESTF_SCAN_PDATA | UT_TESTF_SCAN_FDT);
On Tue, 9 Aug 2022 at 01:14, Patrice Chotard patrice.chotard@foss.st.com wrote:
Patrice Chotard
