[PATCH v7 00/15] vpl: Introduce a verifying program loader
U-Boot provides a verified-boot feature based around FIT, but there is no standard way of implementing it for a board. At present the various required pieces must be built up separately, to produce a working implementation. In particular, there is no built-in support for selecting A/B boot or recovery mode.
This series introduces VPL, a verified program loader phase for U-Boot. Its purpose is to run the verified-boot process and decide which SPL binary should be run. It is critical that this decision happens before SPL runs, since SPL sets up SDRAM and we need to be able to update the SDRAM-init code in the field.
Adding VPL into the boot flow provides a standard way of implementing verified boot. This series includes the phase itself, some useful Kconfig options and a sandbox_vpl build for sandbox.
Most of the patches in this series are fixes and improvements to docs and various Kconfig conditions for SPL so can be applied separately if needed. The last four patches introduce VPL.
Changes in v7: - Add new patch with a default for TPL_TEXT_BASE - Add new patch to correct the conditions for SPL - Add new patch to correct condition for SEPARATE_BSS - Add new patch to avoid looking for an appended device tree - Renumber the tests - Update for the patman library rename - Add a few more options - Rebase to master - Update some options based on settings in master
Changes in v6: - Fix the missing SPDX tag on test/204... - Add docs for sandbox_vpl build - Drop TPL_HASH_SUPPORT patch since we only have SPL_HASH now
Changes in v5: - Rebase this patch on mainline (for GPIO and MISC Kconfig renames)
Changes in v4: - Add new patch to correct bloblist Kconfig dependencies - Add new patch to avoid building avb in SPL - Update spl_phase_prefix() for VPL - Tidy up some of the Makefile rules - Add options for blk, core, misc and tpl also - Add VPL_SIZE_LIMIT - Add a sandbox_vpl build - Update cover letter
Changes in v3: - Move VPL Kconfig options to a separate patch - Add full build support for VPL - Add a VPL size check (Kconfig option in next patch)
Changes in v2: - Add some more VPL Kconfig options
Simon Glass (15): doc: Convert SPL documentation to ReST doc: Expand SPL docs to explain the phase and config test: Tidy up test building with SPL bloblist: Correct Kconfig dependencies avb: Don't build in SPL Makefile: Simplify devicetree rules for SPL/TPL Makefile: Tidy up the TPL build rules Add a default for TPL_TEXT_BASE disk: Correct the conditions for SPL fdt: Correct condition for SEPARATE_BSS fdt: sandbox: Avoid looking for an appended device tree binman: Add VPL support Introduce Verifying Program Loader (VPL) vpl: Add Kconfig options for VPL sandbox: Add a build for VPL
Kconfig | 10 + Makefile | 28 ++- arch/sandbox/Kconfig | 8 + arch/sandbox/cpu/spl.c | 12 +- arch/sandbox/dts/sandbox.dtsi | 10 +- board/sandbox/MAINTAINERS | 7 + common/Kconfig | 71 +++++- common/Makefile | 2 +- common/spl/Kconfig | 235 ++++++++++++++++++- common/spl/spl.c | 25 +- configs/sandbox_vpl_defconfig | 251 +++++++++++++++++++++ disk/Makefile | 10 +- doc/arch/sandbox.rst | 13 ++ doc/develop/index.rst | 1 + doc/{README.SPL => develop/spl.rst} | 75 ++++-- drivers/Makefile | 2 + drivers/block/Kconfig | 12 + drivers/clk/Kconfig | 26 +++ drivers/core/Kconfig | 33 +++ drivers/core/Makefile | 2 +- drivers/gpio/Kconfig | 11 + drivers/i2c/Kconfig | 11 + drivers/misc/Kconfig | 28 +++ drivers/pinctrl/Kconfig | 18 +- drivers/rtc/Kconfig | 9 + drivers/serial/Kconfig | 20 ++ drivers/sysreset/Kconfig | 10 + drivers/timer/Kconfig | 10 + drivers/tpm/Kconfig | 30 +++ dts/Kconfig | 17 ++ include/bootstage.h | 2 + include/linux/kconfig.h | 3 + include/spl.h | 22 +- lib/Kconfig | 64 +++++- lib/fdtdec.c | 5 +- scripts/Kbuild.include | 4 + scripts/Makefile.autoconf | 12 + scripts/Makefile.build | 4 + scripts/Makefile.lib | 5 + scripts/Makefile.spl | 37 ++- tools/binman/etype/u_boot_vpl.py | 42 ++++ tools/binman/etype/u_boot_vpl_bss_pad.py | 44 ++++ tools/binman/etype/u_boot_vpl_dtb.py | 28 +++ tools/binman/etype/u_boot_vpl_expanded.py | 45 ++++ tools/binman/etype/u_boot_vpl_nodtb.py | 42 ++++ tools/binman/ftest.py | 109 +++++++-- tools/binman/state.py | 3 +- tools/binman/test/082_fdt_update_all.dts | 2 + tools/binman/test/225_u_boot_vpl.dts | 11 + tools/binman/test/226_u_boot_vpl_nodtb.dts | 13 ++ tools/binman/test/227_fdt_incl_vpl.dts | 13 ++ tools/binman/test/228_vpl_bss_pad.dts | 19 ++ 52 files changed, 1441 insertions(+), 85 deletions(-) create mode 100644 configs/sandbox_vpl_defconfig rename doc/{README.SPL => develop/spl.rst} (68%) create mode 100644 tools/binman/etype/u_boot_vpl.py create mode 100644 tools/binman/etype/u_boot_vpl_bss_pad.py create mode 100644 tools/binman/etype/u_boot_vpl_dtb.py create mode 100644 tools/binman/etype/u_boot_vpl_expanded.py create mode 100644 tools/binman/etype/u_boot_vpl_nodtb.py create mode 100644 tools/binman/test/225_u_boot_vpl.dts create mode 100644 tools/binman/test/226_u_boot_vpl_nodtb.dts create mode 100644 tools/binman/test/227_fdt_incl_vpl.dts create mode 100644 tools/binman/test/228_vpl_bss_pad.dts
Move this documentation over to .rst format.
(no changes since v1)
doc/develop/index.rst | 1 + doc/{README.SPL => develop/spl.rst} | 36 +++++++++++++++-------------- 2 files changed, 20 insertions(+), 17 deletions(-) rename doc/{README.SPL => develop/spl.rst} (86%)
diff --git a/doc/develop/index.rst b/doc/develop/index.rst index 93ebfa485f..a79dd9d4fb 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -23,6 +23,7 @@ Implementation menus printf smbios + spl uefi/index version
diff --git a/doc/README.SPL b/doc/develop/spl.rst similarity index 86% rename from doc/README.SPL rename to doc/develop/spl.rst index 011fd42537..4d6f394bed 100644 --- a/doc/README.SPL +++ b/doc/develop/spl.rst @@ -20,19 +20,19 @@ u-boot-spl.map. A config option named CONFIG_SPL_BUILD is enabled by Kconfig for SPL. Source files can therefore be compiled for SPL with different settings.
-For example: +For example::
-ifeq ($(CONFIG_SPL_BUILD),y) -obj-y += board_spl.o -else -obj-y += board.o -endif + ifeq ($(CONFIG_SPL_BUILD),y) + obj-y += board_spl.o + else + obj-y += board.o + endif
-obj-$(CONFIG_SPL_BUILD) += foo.o + obj-$(CONFIG_SPL_BUILD) += foo.o
-#ifdef CONFIG_SPL_BUILD - foo(); -#endif + #ifdef CONFIG_SPL_BUILD + foo(); + #endif
The building of SPL images can be enabled by CONFIG_SPL option in Kconfig. @@ -71,11 +71,13 @@ Device tree The U-Boot device tree is filtered by the fdtgrep tools during the build process to generate a much smaller device tree used in SPL (spl/u-boot-spl.dtb) with: + - the mandatory nodes (/alias, /chosen, /config) - the nodes with one pre-relocation property: 'u-boot,dm-pre-reloc' or 'u-boot,dm-spl'
fdtgrep is also used to remove: + - the properties defined in CONFIG_OF_SPL_REMOVE_PROPS - all the pre-relocation properties ('u-boot,dm-pre-reloc', 'u-boot,dm-spl' and 'u-boot,dm-tpl') @@ -98,14 +100,14 @@ stack usage at various points in run sequence of SPL. The -fstack-usage option to gcc will produce '.su' files (such as arch/arm/cpu/armv7/syslib.su) that will give stack usage information and cflow can construct program flow.
-Must have gcc 4.6 or later, which supports -fstack-usage +Must have gcc 4.6 or later, which supports -fstack-usage:
-1) Build normally -2) Perform the following shell command to generate a list of C files used in -SPL: -$ find spl -name '*.su' | sed -e 's:^spl/::' -e 's:[.]su$:.c:' > used-spl.list -3) Execute cflow: -$ cflow --main=board_init_r `cat used-spl.list` 2>&1 | $PAGER +#. Build normally +#. Perform the following shell command to generate a list of C files used in + SPL: +#. `find spl -name '*.su' | sed -e 's:^spl/::' -e 's:[.]su$:.c:' > used-spl.list` +#. Execute cflow: + `$ cflow --main=board_init_r $(cat used-spl.list) 2>&1 | $PAGER`
cflow will spit out a number of warnings as it does not parse the config files and picks functions based on #ifdef. Parsing the '.i'
Add a bit more information about how to use SPL.
doc/develop/spl.rst | 34 ++++++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/doc/develop/spl.rst b/doc/develop/spl.rst index 4d6f394bed..1059b2fb9c 100644 --- a/doc/develop/spl.rst +++ b/doc/develop/spl.rst @@ -66,6 +66,40 @@ CONFIG_SPL_SPI_LOAD (drivers/mtd/spi/spi_spl_load.o) CONFIG_SPL_RAM_DEVICE (common/spl/spl.c) CONFIG_SPL_WATCHDOG (drivers/watchdog/libwatchdog.o)
+Adding SPL-specific code +------------------------ + +To check whether a feature is enabled, use CONFIG_IS_ENABLED():: + + if (CONFIG_IS_ENABLED(CLK)) + ... + +This checks CONFIG_CLK for the main build, CONFIG_SPL_CLK for the SPL build, +CONFIG_TPL_CLK for the TPL build, etc. + +U-Boot Phases +------------- + +U-Boot boots through the following phases: + +TPL + Very early init, as tiny as possible. This loads SPL. + +SPL + Secondary program loader. Sets up SDRAM and loads U-Boot proper. It may also + load other firmware components. + +U-Boot + U-Boot proper, containing the command line and boot logic. + + +Checking the boot phase +----------------------- + +Use `spl_phase()` to find the current U-Boot phase, e.g. `PHASE_SPL`. You can +also find the previous and next phase and get the phase name. + + Device tree ----------- The U-Boot device tree is filtered by the fdtgrep tools during the build
We can in principle add tests to any SPL build, e.g. TPL or VPL. Update the build rules to handle this.
Makefile | 2 +- scripts/Makefile.spl | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index 66d9e78cc7..f597bc6866 100644 --- a/Makefile +++ b/Makefile @@ -839,7 +839,7 @@ libs-y += drivers/usb/ulpi/ ifdef CONFIG_POST libs-y += post/ endif -libs-$(CONFIG_UNIT_TEST) += test/ +libs-$(CONFIG_$(SPL_TPL_)UNIT_TEST) += test/ libs-$(CONFIG_UT_ENV) += test/env/ libs-$(CONFIG_UT_OPTEE) += test/optee/ libs-$(CONFIG_UT_OVERLAY) += test/overlay/ diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 83a95ee4aa..1f50fbf8c9 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -109,7 +109,7 @@ libs-y += dts/ libs-y += fs/ libs-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/ libs-$(CONFIG_SPL_NET) += net/ -libs-$(CONFIG_SPL_UNIT_TEST) += test/ +libs-$(CONFIG_$(SPL_TPL_)UNIT_TEST) += test/
head-y := $(addprefix $(obj)/,$(head-y)) libs-y := $(addprefix $(obj)/,$(libs-y))
This feature is not available in SPL unless common/ and lib/ are built. Update the Kconfig to avoid build errors.
(no changes since v4)
common/Kconfig | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 82cd864baf..d2b1b35225 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -721,7 +721,7 @@ config BLOBLIST
config SPL_BLOBLIST bool "Support for a bloblist in SPL" - depends on BLOBLIST + depends on BLOBLIST && SPL_LIBGENERIC_SUPPORT && SPL_LIBCOMMON_SUPPORT default y if SPL help This enables a bloblist in SPL. If this is the first part of U-Boot @@ -730,7 +730,7 @@ config SPL_BLOBLIST
config TPL_BLOBLIST bool "Support for a bloblist in TPL" - depends on BLOBLIST + depends on BLOBLIST && TPL_LIBGENERIC_SUPPORT && TPL_LIBCOMMON_SUPPORT default y if TPL help This enables a bloblist in TPL. The bloblist is set up in TPL and
This feature is not used in SPL at present. Update the Makefile to avoid it being built.
Changes in v4: - Add new patch to avoid building avb in SPL
common/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/Makefile b/common/Makefile index 3eff719601..2265b27b95 100644 --- a/common/Makefile +++ b/common/Makefile @@ -110,7 +110,7 @@ obj-y += s_record.o obj-$(CONFIG_CMD_LOADB) += xyzModem.o obj-$(CONFIG_$(SPL_TPL_)YMODEM_SUPPORT) += xyzModem.o
-obj-$(CONFIG_AVB_VERIFY) += avb_verify.o +obj-$(CONFIG_$(SPL_TPL_)AVB_VERIFY) += avb_verify.o obj-$(CONFIG_$(SPL_TPL_)STACKPROTECTOR) += stackprot.o obj-$(CONFIG_SCP03) += scp03.o
The current logic checks several options to decide whether SPL/TPL need the U-Boot devicetree to be built. In fact we can check OF_CONTROL, which is enabled in all cases that matter.
Makefile | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/Makefile b/Makefile index f597bc6866..9d026cc8ac 100644 --- a/Makefile +++ b/Makefile @@ -2087,9 +2087,7 @@ spl/u-boot-spl-dtb.bin: spl/u-boot-spl spl/u-boot-spl-dtb.hex: spl/u-boot-spl @:
-spl/u-boot-spl: tools prepare \ - $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_SPL_OF_PLATDATA),dts/dt.dtb) \ - $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_TPL_OF_PLATDATA),dts/dt.dtb) +spl/u-boot-spl: tools prepare $(if $(CONFIG_SPL_OF_CONTROL),dts/dt.dtb) $(Q)$(MAKE) obj=spl -f $(srctree)/scripts/Makefile.spl all
spl/sunxi-spl.bin: spl/u-boot-spl @@ -2104,8 +2102,7 @@ spl/u-boot-spl.sfp: spl/u-boot-spl spl/boot.bin: spl/u-boot-spl @:
-tpl/u-boot-tpl.bin: tools prepare \ - $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_SPL_OF_PLATDATA),dts/dt.dtb) +tpl/u-boot-tpl.bin: tools prepare $(if $(CONFIG_TPL_OF_CONTROL),dts/dt.dtb) $(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.spl all $(TPL_SIZE_CHECK)
These should follow the same pattern as SPL, for consistency. Fix them.
Makefile | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index 9d026cc8ac..f8c5fc2041 100644 --- a/Makefile +++ b/Makefile @@ -2102,10 +2102,13 @@ spl/u-boot-spl.sfp: spl/u-boot-spl spl/boot.bin: spl/u-boot-spl @:
-tpl/u-boot-tpl.bin: tools prepare $(if $(CONFIG_TPL_OF_CONTROL),dts/dt.dtb) - $(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.spl all +tpl/u-boot-tpl.bin: tpl/u-boot-tpl + @: $(TPL_SIZE_CHECK)
+tpl/u-boot-tpl: tools prepare $(if $(CONFIG_TPL_OF_CONTROL),dts/dt.dtb) + $(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.spl all + TAG_SUBDIRS := $(patsubst %,$(srctree)/%,$(u-boot-dirs) include)
FIND := find
If this value is not provided it causes a hang in the build. Add a default value to avoid this.
common/spl/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 9418d37b2e..b59215fe4f 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1412,6 +1412,7 @@ config TPL_POWER
config TPL_TEXT_BASE hex "Base address for the .text section of the TPL stage" + default 0 help The base address for the .text section of the TPL stage.
These filesystems may have different settings for SPL and TPL. Use the correct Makefile variable to handle this.
Changes in v7: - Add new patch to correct the conditions for SPL
disk/Makefile | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/disk/Makefile b/disk/Makefile index 6ce5a687b3..83f5af6069 100644 --- a/disk/Makefile +++ b/disk/Makefile @@ -6,8 +6,8 @@ #ccflags-y += -DET_DEBUG -DDEBUG
obj-$(CONFIG_PARTITIONS) += part.o -obj-$(CONFIG_$(SPL_)MAC_PARTITION) += part_mac.o -obj-$(CONFIG_$(SPL_)DOS_PARTITION) += part_dos.o -obj-$(CONFIG_$(SPL_)ISO_PARTITION) += part_iso.o -obj-$(CONFIG_$(SPL_)AMIGA_PARTITION) += part_amiga.o -obj-$(CONFIG_$(SPL_)EFI_PARTITION) += part_efi.o +obj-$(CONFIG_$(SPL_TPL_)MAC_PARTITION) += part_mac.o +obj-$(CONFIG_$(SPL_TPL_)DOS_PARTITION) += part_dos.o +obj-$(CONFIG_$(SPL_TPL_)ISO_PARTITION) += part_iso.o +obj-$(CONFIG_$(SPL_TPL_)AMIGA_PARTITION) += part_amiga.o +obj-$(CONFIG_$(SPL_TPL_)EFI_PARTITION) += part_efi.o
Hi Simon,
Changes in v7:
While none of CONFIG_TPL_xxx_PARTITION is defined, how do those rules work for TPL?
-Takahiro Akashi
-- 2.35.1.574.g5d30c73bfb-goog
On Thu, Apr 14, 2022 at 05:21:52PM +0900, AKASHI Takahiro wrote:
Hi Simon,
Changes in v7:
The makefile logic means that if the options are added then they would work as intended. With the options not being in Kconfig they'll simply never be evaluated to y.
Hi Simon,
Changes in v7:
Okay, so it is intentional. But I believe that the changes made around disk/ are not enough. For instance, in include/part.h, there still exist a couple of #ifdef CONFIG_PARTITIONS
So some functions are nullified even if SPL_PARTITIONS (and particular partition table types) is enabled.
I'm trying to fix some of issues when addressing the issue: https://lists.denx.de/pipermail/u-boot/2022-April/481258.html
-Takahiro Akashi
-- Tom
This may have different settings for SPL and TPL. Correct the condition.
Changes in v7: - Add new patch to correct condition for SEPARATE_BSS
lib/fdtdec.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 87aa677a4a..086f0c732a 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1227,7 +1227,7 @@ static void *fdt_find_separate(void)
#ifdef CONFIG_SPL_BUILD /* FDT is at end of BSS unless it is in a different memory region */ - if (IS_ENABLED(CONFIG_SPL_SEPARATE_BSS)) + if (CONFIG_IS_ENABLED(SEPARATE_BSS)) fdt_blob = (ulong *)&_image_binary_end; else fdt_blob = (ulong *)&__bss_end;
We don't use an appended tree for sandbox and the required symbols are not present. Add a condition to avoid a build error.
Changes in v7: - Add new patch to avoid looking for an appended device tree
lib/fdtdec.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 086f0c732a..0c0ec034ec 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -1225,6 +1225,9 @@ static void *fdt_find_separate(void) { void *fdt_blob = NULL;
+ if (IS_ENABLED(CONFIG_SANDBOX)) + return NULL; + #ifdef CONFIG_SPL_BUILD /* FDT is at end of BSS unless it is in a different memory region */ if (CONFIG_IS_ENABLED(SEPARATE_BSS))
Add support for U-Boot's Verifying Program Loader phase.
Changes in v7: - Renumber the tests - Update for the patman library rename
tools/binman/etype/u_boot_vpl.py | 42 ++++++++ tools/binman/etype/u_boot_vpl_bss_pad.py | 44 +++++++++ tools/binman/etype/u_boot_vpl_dtb.py | 28 ++++++ tools/binman/etype/u_boot_vpl_expanded.py | 45 +++++++++ tools/binman/etype/u_boot_vpl_nodtb.py | 42 ++++++++ tools/binman/ftest.py | 109 +++++++++++++++++---- tools/binman/state.py | 3 +- tools/binman/test/082_fdt_update_all.dts | 2 + tools/binman/test/225_u_boot_vpl.dts | 11 +++ tools/binman/test/226_u_boot_vpl_nodtb.dts | 13 +++ tools/binman/test/227_fdt_incl_vpl.dts | 13 +++ tools/binman/test/228_vpl_bss_pad.dts | 19 ++++ 12 files changed, 349 insertions(+), 22 deletions(-) create mode 100644 tools/binman/etype/u_boot_vpl.py create mode 100644 tools/binman/etype/u_boot_vpl_bss_pad.py create mode 100644 tools/binman/etype/u_boot_vpl_dtb.py create mode 100644 tools/binman/etype/u_boot_vpl_expanded.py create mode 100644 tools/binman/etype/u_boot_vpl_nodtb.py create mode 100644 tools/binman/test/225_u_boot_vpl.dts create mode 100644 tools/binman/test/226_u_boot_vpl_nodtb.dts create mode 100644 tools/binman/test/227_fdt_incl_vpl.dts create mode 100644 tools/binman/test/228_vpl_bss_pad.dts
diff --git a/tools/binman/etype/u_boot_vpl.py b/tools/binman/etype/u_boot_vpl.py new file mode 100644 index 0000000000..9daaca4f6f --- /dev/null +++ b/tools/binman/etype/u_boot_vpl.py @@ -0,0 +1,42 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for vpl/u-boot-vpl.bin +# + +from binman import elf +from binman.entry import Entry +from binman.etype.blob import Entry_blob + +class Entry_u_boot_vpl(Entry_blob): + """U-Boot VPL binary + + Properties / Entry arguments: + - filename: Filename of u-boot-vpl.bin (default 'vpl/u-boot-vpl.bin') + + This is the U-Boot VPL (Verifying Program Loader) binary. This is a small + binary which loads before SPL, typically into on-chip SRAM. It is + responsible for locating, loading and jumping to SPL, the next-stage + loader. Note that VPL is not relocatable so must be loaded to the correct + address in SRAM, or written to run from the correct address if direct + flash execution is possible (e.g. on x86 devices). + + SPL can access binman symbols at runtime. See: + + 'Access to binman entry offsets at run time (symbols)' + + in the binman README for more information. + + The ELF file 'vpl/u-boot-vpl' must also be available for this to work, since + binman uses that to look up symbols to write into the VPL binary. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.elf_fname = 'vpl/u-boot-vpl' + + def GetDefaultFilename(self): + return 'vpl/u-boot-vpl.bin' + + def WriteSymbols(self, section): + elf.LookupAndWriteSymbols(self.elf_fname, self, section.GetImage()) diff --git a/tools/binman/etype/u_boot_vpl_bss_pad.py b/tools/binman/etype/u_boot_vpl_bss_pad.py new file mode 100644 index 0000000000..b2ce2a3135 --- /dev/null +++ b/tools/binman/etype/u_boot_vpl_bss_pad.py @@ -0,0 +1,44 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2021 Google LLC +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for BSS padding for vpl/u-boot-vpl.bin. This padding +# can be added after the VPL binary to ensure that anything concatenated +# to it will appear to VPL to be at the end of BSS rather than the start. +# + +from binman import elf +from binman.entry import Entry +from binman.etype.blob import Entry_blob +from patman import tools + +class Entry_u_boot_vpl_bss_pad(Entry_blob): + """U-Boot VPL binary padded with a BSS region + + Properties / Entry arguments: + None + + This holds the padding added after the VPL binary to cover the BSS (Block + Started by Symbol) region. This region holds the various variables used by + VPL. It is set to 0 by VPL when it starts up. If you want to append data to + the VPL image (such as a device tree file), you must pad out the BSS region + to avoid the data overlapping with U-Boot variables. This entry is useful in + that case. It automatically pads out the entry size to cover both the code, + data and BSS. + + The contents of this entry will a certain number of zero bytes, determined + by __bss_size + + The ELF file 'vpl/u-boot-vpl' must also be available for this to work, since + binman uses that to look up the BSS address. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + + def ObtainContents(self): + fname = tools.get_input_filename('vpl/u-boot-vpl') + bss_size = elf.GetSymbolAddress(fname, '__bss_size') + if not bss_size: + self.Raise('Expected __bss_size symbol in vpl/u-boot-vpl') + self.SetContents(tools.get_bytes(0, bss_size)) + return True diff --git a/tools/binman/etype/u_boot_vpl_dtb.py b/tools/binman/etype/u_boot_vpl_dtb.py new file mode 100644 index 0000000000..f6253bf243 --- /dev/null +++ b/tools/binman/etype/u_boot_vpl_dtb.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for U-Boot device tree in VPL (Verifying Program Loader) +# + +from binman.entry import Entry +from binman.etype.blob_dtb import Entry_blob_dtb + +class Entry_u_boot_vpl_dtb(Entry_blob_dtb): + """U-Boot VPL device tree + + Properties / Entry arguments: + - filename: Filename of u-boot.dtb (default 'vpl/u-boot-vpl.dtb') + + This is the VPL device tree, containing configuration information for + VPL. VPL needs this to know what devices are present and which drivers + to activate. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + + def GetDefaultFilename(self): + return 'vpl/u-boot-vpl.dtb' + + def GetFdtEtype(self): + return 'u-boot-vpl-dtb' diff --git a/tools/binman/etype/u_boot_vpl_expanded.py b/tools/binman/etype/u_boot_vpl_expanded.py new file mode 100644 index 0000000000..92c64f0a65 --- /dev/null +++ b/tools/binman/etype/u_boot_vpl_expanded.py @@ -0,0 +1,45 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2021 Google LLC +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for expanded U-Boot VPL binary +# + +from patman import tout + +from binman import state +from binman.etype.blob_phase import Entry_blob_phase + +class Entry_u_boot_vpl_expanded(Entry_blob_phase): + """U-Boot VPL flat binary broken out into its component parts + + Properties / Entry arguments: + - vpl-dtb: Controls whether this entry is selected (set to 'y' or '1' to + select) + + This is a section containing the U-Boot binary, BSS padding if needed and a + devicetree. Using this entry type automatically creates this section, with + the following entries in it: + + u-boot-vpl-nodtb + u-boot-vpl-bss-pad + u-boot-dtb + + Having the devicetree separate allows binman to update it in the final + image, so that the entries positions are provided to the running U-Boot. + + This entry is selected based on the value of the 'vpl-dtb' entryarg. If + this is non-empty (and not 'n' or '0') then this expanded entry is selected. + """ + def __init__(self, section, etype, node): + bss_pad = state.GetEntryArgBool('vpl-bss-pad') + super().__init__(section, etype, node, 'u-boot-vpl', 'u-boot-vpl-dtb', + bss_pad) + + @classmethod + def UseExpanded(cls, node, etype, new_etype): + val = state.GetEntryArgBool('vpl-dtb') + tout.do_output(tout.INFO if val else tout.DETAIL, + "Node '%s': etype '%s': %s %sselected" % + (node.path, etype, new_etype, '' if val else 'not ')) + return val diff --git a/tools/binman/etype/u_boot_vpl_nodtb.py b/tools/binman/etype/u_boot_vpl_nodtb.py new file mode 100644 index 0000000000..25c966cf34 --- /dev/null +++ b/tools/binman/etype/u_boot_vpl_nodtb.py @@ -0,0 +1,42 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for 'u-boot-vpl-nodtb.bin' +# + +from binman import elf +from binman.entry import Entry +from binman.etype.blob import Entry_blob + +class Entry_u_boot_vpl_nodtb(Entry_blob): + """VPL binary without device tree appended + + Properties / Entry arguments: + - filename: Filename to include (default 'vpl/u-boot-vpl-nodtb.bin') + + This is the U-Boot VPL binary, It does not include a device tree blob at + the end of it so may not be able to work without it, assuming VPL needs + a device tree to operate on your platform. You can add a u_boot_vpl_dtb + entry after this one, or use a u_boot_vpl entry instead, which normally + expands to a section containing u-boot-vpl-dtb, u-boot-vpl-bss-pad and + u-boot-vpl-dtb + + VPL can access binman symbols at runtime. See: + + 'Access to binman entry offsets at run time (symbols)' + + in the binman README for more information. + + The ELF file 'vpl/u-boot-vpl' must also be available for this to work, since + binman uses that to look up symbols to write into the VPL binary. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.elf_fname = 'vpl/u-boot-vpl' + + def GetDefaultFilename(self): + return 'vpl/u-boot-vpl-nodtb.bin' + + def WriteSymbols(self, section): + elf.LookupAndWriteSymbols(self.elf_fname, self, section.GetImage()) diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 8f00db6945..ec1e1aac13 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -45,12 +45,14 @@ U_BOOT_DATA = b'1234' U_BOOT_IMG_DATA = b'img' U_BOOT_SPL_DATA = b'56780123456789abcdefghi' U_BOOT_TPL_DATA = b'tpl9876543210fedcbazyw' +U_BOOT_VPL_DATA = b'vpl76543210fedcbazywxyz_' BLOB_DATA = b'89' ME_DATA = b'0abcd' VGA_DATA = b'vga' U_BOOT_DTB_DATA = b'udtb' U_BOOT_SPL_DTB_DATA = b'spldtb' U_BOOT_TPL_DTB_DATA = b'tpldtb' +U_BOOT_VPL_DTB_DATA = b'vpldtb' X86_START16_DATA = b'start16' X86_START16_SPL_DATA = b'start16spl' X86_START16_TPL_DATA = b'start16tpl' @@ -61,6 +63,7 @@ PPC_MPC85XX_BR_DATA = b'ppcmpc85xxbr' U_BOOT_NODTB_DATA = b'nodtb with microcode pointer somewhere in here' U_BOOT_SPL_NODTB_DATA = b'splnodtb with microcode pointer somewhere in here' U_BOOT_TPL_NODTB_DATA = b'tplnodtb with microcode pointer somewhere in here' +U_BOOT_VPL_NODTB_DATA = b'vplnodtb' U_BOOT_EXP_DATA = U_BOOT_NODTB_DATA + U_BOOT_DTB_DATA U_BOOT_SPL_EXP_DATA = U_BOOT_SPL_NODTB_DATA + U_BOOT_SPL_DTB_DATA U_BOOT_TPL_EXP_DATA = U_BOOT_TPL_NODTB_DATA + U_BOOT_TPL_DTB_DATA @@ -136,6 +139,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('u-boot.img', U_BOOT_IMG_DATA) TestFunctional._MakeInputFile('spl/u-boot-spl.bin', U_BOOT_SPL_DATA) TestFunctional._MakeInputFile('tpl/u-boot-tpl.bin', U_BOOT_TPL_DATA) + TestFunctional._MakeInputFile('vpl/u-boot-vpl.bin', U_BOOT_VPL_DATA) TestFunctional._MakeInputFile('blobfile', BLOB_DATA) TestFunctional._MakeInputFile('me.bin', ME_DATA) TestFunctional._MakeInputFile('vga.bin', VGA_DATA) @@ -161,6 +165,8 @@ class TestFunctional(unittest.TestCase): U_BOOT_SPL_NODTB_DATA) TestFunctional._MakeInputFile('tpl/u-boot-tpl-nodtb.bin', U_BOOT_TPL_NODTB_DATA) + TestFunctional._MakeInputFile('vpl/u-boot-vpl-nodtb.bin', + U_BOOT_VPL_NODTB_DATA) TestFunctional._MakeInputFile('fsp.bin', FSP_DATA) TestFunctional._MakeInputFile('cmc.bin', CMC_DATA) TestFunctional._MakeInputFile('vbt.bin', VBT_DATA) @@ -279,6 +285,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('u-boot.dtb', U_BOOT_DTB_DATA) TestFunctional._MakeInputFile('spl/u-boot-spl.dtb', U_BOOT_SPL_DTB_DATA) TestFunctional._MakeInputFile('tpl/u-boot-tpl.dtb', U_BOOT_TPL_DTB_DATA) + TestFunctional._MakeInputFile('vpl/u-boot-vpl.dtb', U_BOOT_VPL_DTB_DATA)
def _RunBinman(self, *args, **kwargs): """Run binman using the command line @@ -414,8 +421,8 @@ class TestFunctional(unittest.TestCase): shutil.rmtree(tmpdir) return data
- def _GetDtbContentsForSplTpl(self, dtb_data, name): - """Create a version of the main DTB for SPL or SPL + def _GetDtbContentsForSpls(self, dtb_data, name): + """Create a version of the main DTB for SPL / TPL / VPL
For testing we don't actually have different versions of the DTB. With U-Boot we normally run fdtgrep to remove unwanted nodes, but for tests @@ -485,11 +492,11 @@ class TestFunctional(unittest.TestCase):
# For testing purposes, make a copy of the DT for SPL and TPL. Add # a node indicating which it is, so aid verification. - for name in ['spl', 'tpl']: + for name in ['spl', 'tpl', 'vpl']: dtb_fname = '%s/u-boot-%s.dtb' % (name, name) outfile = os.path.join(self._indir, dtb_fname) TestFunctional._MakeInputFile(dtb_fname, - self._GetDtbContentsForSplTpl(dtb_data, name)) + self._GetDtbContentsForSpls(dtb_data, name))
try: retcode = self._DoTestFile(fname, map=map, update_dtb=update_dtb, @@ -595,6 +602,16 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('tpl/u-boot-tpl', tools.read_file(cls.ElfTestFile(src_fname)))
+ @classmethod + def _SetupVplElf(cls, src_fname='bss_data'): + """Set up an ELF file with a '_dt_ucode_base_size' symbol + + Args: + Filename of ELF file to use as VPL + """ + TestFunctional._MakeInputFile('vpl/u-boot-vpl', + tools.read_file(cls.ElfTestFile(src_fname))) + @classmethod def _SetupDescriptor(cls): with open(cls.TestFile('descriptor.bin'), 'rb') as fd: @@ -1889,21 +1906,24 @@ class TestFunctional(unittest.TestCase): data = self._DoReadFileRealDtb('082_fdt_update_all.dts')
base_expected = { - 'section:image-pos': 0, - 'u-boot-tpl-dtb:size': 513, - 'u-boot-spl-dtb:size': 513, - 'u-boot-spl-dtb:offset': 493, - 'image-pos': 0, - 'section/u-boot-dtb:image-pos': 0, - 'u-boot-spl-dtb:image-pos': 493, - 'section/u-boot-dtb:size': 493, - 'u-boot-tpl-dtb:image-pos': 1006, - 'section/u-boot-dtb:offset': 0, - 'section:size': 493, 'offset': 0, + 'image-pos': 0, + 'size': 2320, 'section:offset': 0, - 'u-boot-tpl-dtb:offset': 1006, - 'size': 1519 + 'section:image-pos': 0, + 'section:size': 565, + 'section/u-boot-dtb:offset': 0, + 'section/u-boot-dtb:image-pos': 0, + 'section/u-boot-dtb:size': 565, + 'u-boot-spl-dtb:offset': 565, + 'u-boot-spl-dtb:image-pos': 565, + 'u-boot-spl-dtb:size': 585, + 'u-boot-tpl-dtb:offset': 1150, + 'u-boot-tpl-dtb:image-pos': 1150, + 'u-boot-tpl-dtb:size': 585, + 'u-boot-vpl-dtb:image-pos': 1735, + 'u-boot-vpl-dtb:offset': 1735, + 'u-boot-vpl-dtb:size': 585, }
# We expect three device-tree files in the output, one after the other. @@ -1911,11 +1931,12 @@ class TestFunctional(unittest.TestCase): # and 'tpl' in the TPL tree, to make sure they are distinct from the # main U-Boot tree. All three should have the same postions and offset. start = 0 - for item in ['', 'spl', 'tpl']: + self.maxDiff = None + for item in ['', 'spl', 'tpl', 'vpl']: dtb = fdt.Fdt.FromData(data[start:]) dtb.Scan() props = self._GetPropTree(dtb, BASE_DTB_PROPS + REPACK_DTB_PROPS + - ['spl', 'tpl']) + ['spl', 'tpl', 'vpl']) expected = dict(base_expected) if item: expected[item] = 0 @@ -1935,7 +1956,7 @@ class TestFunctional(unittest.TestCase): # over to the expected place. start = 0 for fname in ['u-boot.dtb.out', 'spl/u-boot-spl.dtb.out', - 'tpl/u-boot-tpl.dtb.out']: + 'tpl/u-boot-tpl.dtb.out', 'vpl/u-boot-vpl.dtb.out']: dtb = fdt.Fdt.FromData(data[start:]) size = dtb._fdt_obj.totalsize() pathname = tools.get_output_filename(os.path.split(fname)[1]) @@ -1943,7 +1964,7 @@ class TestFunctional(unittest.TestCase): name = os.path.split(fname)[0]
if name: - orig_indata = self._GetDtbContentsForSplTpl(dtb_data, name) + orig_indata = self._GetDtbContentsForSpls(dtb_data, name) else: orig_indata = dtb_data self.assertNotEqual(outdata, orig_indata, @@ -5321,6 +5342,52 @@ fdt fdtmap Extract the devicetree blob from the fdtmap self.assertIn("Node '/binman/fit': Unknown operation 'unknown'", str(exc.exception))
+ def testVpl(self): + """Test that an image with VPL and its device tree can be created""" + # ELF file with a '__bss_size' symbol + self._SetupVplElf() + data = self._DoReadFile('225_u_boot_vpl.dts') + self.assertEqual(U_BOOT_VPL_DATA + U_BOOT_VPL_DTB_DATA, data) + + def testVplNoDtb(self): + """Test that an image with vpl/u-boot-vpl-nodtb.bin can be created""" + self._SetupVplElf() + data = self._DoReadFile('226_u_boot_vpl_nodtb.dts') + self.assertEqual(U_BOOT_VPL_NODTB_DATA, + data[:len(U_BOOT_VPL_NODTB_DATA)]) + + def testExpandedVpl(self): + """Test that an expanded entry type is selected for TPL when needed""" + self._SetupVplElf() + + entry_args = { + 'vpl-bss-pad': 'y', + 'vpl-dtb': 'y', + } + self._DoReadFileDtb('227_fdt_incl_vpl.dts', use_expanded=True, + entry_args=entry_args) + image = control.images['image'] + entries = image.GetEntries() + self.assertEqual(1, len(entries)) + + # We only have u-boot-vpl, which be expanded + self.assertIn('u-boot-vpl', entries) + entry = entries['u-boot-vpl'] + self.assertEqual('u-boot-vpl-expanded', entry.etype) + subent = entry.GetEntries() + self.assertEqual(3, len(subent)) + self.assertIn('u-boot-vpl-nodtb', subent) + self.assertIn('u-boot-vpl-bss-pad', subent) + self.assertIn('u-boot-vpl-dtb', subent) + + def testVplBssPadMissing(self): + """Test that a missing symbol is detected""" + self._SetupVplElf('u_boot_ucode_ptr') + with self.assertRaises(ValueError) as e: + self._DoReadFile('228_vpl_bss_pad.dts') + self.assertIn('Expected __bss_size symbol in vpl/u-boot-vpl', + str(e.exception)) +
if __name__ == "__main__": unittest.main() diff --git a/tools/binman/state.py b/tools/binman/state.py index a302e1f00e..56e5bf8bc1 100644 --- a/tools/binman/state.py +++ b/tools/binman/state.py @@ -22,6 +22,7 @@ OUR_PATH = os.path.dirname(os.path.realpath(__file__)) DTB_TYPE_FNAME = { 'u-boot-spl-dtb': 'spl/u-boot-spl.dtb', 'u-boot-tpl-dtb': 'tpl/u-boot-tpl.dtb', + 'u-boot-vpl-dtb': 'vpl/u-boot-vpl.dtb', }
# Records the device-tree files known to binman, keyed by entry type (e.g. @@ -292,7 +293,7 @@ def GetAllFdts(): """Yield all device tree files being used by binman
Yields: - Device trees being used (U-Boot proper, SPL, TPL) + Device trees being used (U-Boot proper, SPL, TPL, VPL) """ if main_dtb: yield main_dtb diff --git a/tools/binman/test/082_fdt_update_all.dts b/tools/binman/test/082_fdt_update_all.dts index 284975cc28..1aea56989f 100644 --- a/tools/binman/test/082_fdt_update_all.dts +++ b/tools/binman/test/082_fdt_update_all.dts @@ -14,5 +14,7 @@ }; u-boot-tpl-dtb { }; + u-boot-vpl-dtb { + }; }; }; diff --git a/tools/binman/test/225_u_boot_vpl.dts b/tools/binman/test/225_u_boot_vpl.dts new file mode 100644 index 0000000000..a3a281a91e --- /dev/null +++ b/tools/binman/test/225_u_boot_vpl.dts @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + u-boot-vpl { + }; + u-boot-vpl-dtb { + }; + }; +}; diff --git a/tools/binman/test/226_u_boot_vpl_nodtb.dts b/tools/binman/test/226_u_boot_vpl_nodtb.dts new file mode 100644 index 0000000000..055016badd --- /dev/null +++ b/tools/binman/test/226_u_boot_vpl_nodtb.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-vpl-nodtb { + }; + }; +}; diff --git a/tools/binman/test/227_fdt_incl_vpl.dts b/tools/binman/test/227_fdt_incl_vpl.dts new file mode 100644 index 0000000000..435256fe31 --- /dev/null +++ b/tools/binman/test/227_fdt_incl_vpl.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-vpl { + }; + }; +}; diff --git a/tools/binman/test/228_vpl_bss_pad.dts b/tools/binman/test/228_vpl_bss_pad.dts new file mode 100644 index 0000000000..d308dcade1 --- /dev/null +++ b/tools/binman/test/228_vpl_bss_pad.dts @@ -0,0 +1,19 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-vpl { + }; + + u-boot-vpl-bss-pad { + }; + + u-boot { + }; + }; +};
Applied to u-boot-dm, thanks!
Add support for VPL, a new phase of U-Boot. This runs after TPL. It is responsible for selecting which SPL binary to run, based on a verified-boot process.
Changes in v4: - Update spl_phase_prefix() for VPL - Tidy up some of the Makefile rules
Makefile | 14 ++++++++++++++ common/spl/Kconfig | 15 ++++++++++++++- common/spl/spl.c | 25 ++++++++++++++++++++++--- doc/develop/spl.rst | 7 ++++++- drivers/Makefile | 2 ++ include/bootstage.h | 2 ++ include/linux/kconfig.h | 3 +++ include/spl.h | 22 +++++++++++++++++++--- scripts/Kbuild.include | 4 ++++ scripts/Makefile.autoconf | 12 ++++++++++++ scripts/Makefile.build | 4 ++++ scripts/Makefile.lib | 5 +++++ scripts/Makefile.spl | 35 ++++++++++++++++++++++++----------- 13 files changed, 131 insertions(+), 19 deletions(-)
diff --git a/Makefile b/Makefile index f8c5fc2041..ed1a352104 100644 --- a/Makefile +++ b/Makefile @@ -904,6 +904,12 @@ else TPL_SIZE_CHECK = endif
+ifneq ($(CONFIG_VPL_SIZE_LIMIT),0x0) +VPL_SIZE_CHECK = @$(call size_check,$@,$(CONFIG_VPL_SIZE_LIMIT)) +else +VPL_SIZE_CHECK = +endif + # Statically apply RELA-style relocations (currently arm64 only) # This is useful for arm64 where static relocation needs to be performed on # the raw binary, but certain simulators only accept an ELF file (but don't @@ -944,6 +950,7 @@ INPUTS-$(CONFIG_SPL_FRAMEWORK) += u-boot.img endif endif INPUTS-$(CONFIG_TPL) += tpl/u-boot-tpl.bin +INPUTS-$(CONFIG_VPL) += vpl/u-boot-vpl.bin
# Allow omitting the .dtb output if it is not normally used INPUTS-$(CONFIG_OF_SEPARATE) += $(if $(CONFIG_OF_OMIT_DTB),dts/dt.dtb,u-boot.dtb) @@ -2109,6 +2116,13 @@ tpl/u-boot-tpl.bin: tpl/u-boot-tpl tpl/u-boot-tpl: tools prepare $(if $(CONFIG_TPL_OF_CONTROL),dts/dt.dtb) $(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.spl all
+vpl/u-boot-vpl.bin: vpl/u-boot-vpl + @: + $(VPL_SIZE_CHECK) + +vpl/u-boot-vpl: tools prepare $(if $(CONFIG_TPL_OF_CONTROL),dts/dt.dtb) + $(Q)$(MAKE) obj=vpl -f $(srctree)/scripts/Makefile.spl all + TAG_SUBDIRS := $(patsubst %,$(srctree)/%,$(u-boot-dirs) include)
FIND := find diff --git a/common/spl/Kconfig b/common/spl/Kconfig index b59215fe4f..d3557468f8 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1,4 +1,4 @@ -menu "SPL / TPL" +menu "SPL / TPL / VPL"
config SUPPORT_SPL bool @@ -6,6 +6,9 @@ config SUPPORT_SPL config SUPPORT_TPL bool
+config SUPPORT_VPL + bool + config SPL_DFU_NO_RESET bool
@@ -302,6 +305,16 @@ config SPL_READ_ONLY writeable memory) of anything it wants to modify, such as device-private data.
+config TPL_SEPARATE_BSS + bool "BSS section is in a different memory region from text" + default y if SPL_SEPARATE_BSS + help + Some platforms need a large BSS region in TPL and can provide this + because RAM is already set up. In this case BSS can be moved to RAM. + This option should then be enabled so that the correct device tree + location is used. Normally we put the device tree at the end of BSS + but with this option enabled, it goes at _image_binary_end. + config SPL_BANNER_PRINT bool "Enable output of the SPL banner 'U-Boot SPL ...'" default y diff --git a/common/spl/spl.c b/common/spl/spl.c index b452d4feeb..34195fc1ad 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -60,6 +60,11 @@ binman_sym_declare(ulong, u_boot_spl, image_pos); binman_sym_declare(ulong, u_boot_spl, size); #endif
+#ifdef CONFIG_VPL +binman_sym_declare(ulong, vpl, image_pos); +binman_sym_declare(ulong, vpl, size); +#endif + /* Define board data structure */ static struct bd_info bdata __attribute__ ((section(".data")));
@@ -145,14 +150,22 @@ void spl_fixup_fdt(void *fdt_blob) #if CONFIG_IS_ENABLED(BINMAN_SYMBOLS) ulong spl_get_image_pos(void) { - return spl_phase() == PHASE_TPL ? +#ifdef CONFIG_VPL + if (spl_next_phase() == PHASE_VPL) + return binman_sym(ulong, u_boot_vpl, image_pos); +#endif + return spl_next_phase() == PHASE_SPL ? binman_sym(ulong, u_boot_spl, image_pos) : binman_sym(ulong, u_boot_any, image_pos); }
ulong spl_get_image_size(void) { - return spl_phase() == PHASE_TPL ? +#ifdef CONFIG_VPL + if (spl_next_phase() == PHASE_VPL) + return binman_sym(ulong, u_boot_vpl, size); +#endif + return spl_next_phase() == PHASE_SPL ? binman_sym(ulong, u_boot_spl, size) : binman_sym(ulong, u_boot_any, size); } @@ -160,7 +173,11 @@ ulong spl_get_image_size(void)
ulong spl_get_image_text_base(void) { - return spl_phase() == PHASE_TPL ? CONFIG_SPL_TEXT_BASE : +#ifdef CONFIG_VPL + if (spl_next_phase() == PHASE_VPL) + return CONFIG_VPL_TEXT_BASE; +#endif + return spl_next_phase() == PHASE_SPL ? CONFIG_SPL_TEXT_BASE : CONFIG_SYS_TEXT_BASE; }
@@ -465,6 +482,8 @@ static enum bootstage_id get_bootstage_id(bool start)
if (IS_ENABLED(CONFIG_TPL_BUILD) && phase == PHASE_TPL) return start ? BOOTSTAGE_ID_START_TPL : BOOTSTAGE_ID_END_TPL; + else if (IS_ENABLED(CONFIG_VPL_BUILD) && phase == PHASE_VPL) + return start ? BOOTSTAGE_ID_START_VPL : BOOTSTAGE_ID_END_VPL; else return start ? BOOTSTAGE_ID_START_SPL : BOOTSTAGE_ID_END_SPL; } diff --git a/doc/develop/spl.rst b/doc/develop/spl.rst index 1059b2fb9c..aec7b562fa 100644 --- a/doc/develop/spl.rst +++ b/doc/develop/spl.rst @@ -83,7 +83,12 @@ U-Boot Phases U-Boot boots through the following phases:
TPL - Very early init, as tiny as possible. This loads SPL. + Very early init, as tiny as possible. This loads SPL (or VPL if enabled). + +VPL + Optional verification step, which can select one of several SPL binaries, + if A/B verified boot is enabled. Implementation of the VPL logic is + work-in-progress. For now it just boots into SPL.
SPL Secondary program loader. Sets up SDRAM and loads U-Boot proper. It may also diff --git a/drivers/Makefile b/drivers/Makefile index 4e7cf28440..67c8af7442 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -38,6 +38,7 @@ obj-$(CONFIG_XEN) += xen/ obj-$(CONFIG_$(SPL_)FPGA) += fpga/
ifndef CONFIG_TPL_BUILD +ifndef CONFIG_VPL_BUILD ifdef CONFIG_SPL_BUILD
obj-$(CONFIG_SPL_CPU) += cpu/ @@ -60,6 +61,7 @@ obj-$(CONFIG_SPL_SATA) += ata/ scsi/ obj-$(CONFIG_HAVE_BLOCK_DEVICE) += block/ obj-$(CONFIG_SPL_THERMAL) += thermal/
+endif endif endif
diff --git a/include/bootstage.h b/include/bootstage.h index 99a334ad54..bca9438418 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -176,6 +176,8 @@ enum bootstage_id { BOOTSTAGE_ID_END_TPL, BOOTSTAGE_ID_START_SPL, BOOTSTAGE_ID_END_SPL, + BOOTSTAGE_ID_START_VPL, + BOOTSTAGE_ID_END_VPL, BOOTSTAGE_ID_START_UBOOT_F, BOOTSTAGE_ID_START_UBOOT_R, BOOTSTAGE_ID_USB_START, diff --git a/include/linux/kconfig.h b/include/linux/kconfig.h index d20da615b9..2bc704e110 100644 --- a/include/linux/kconfig.h +++ b/include/linux/kconfig.h @@ -38,6 +38,8 @@ #define _CONFIG_PREFIX TOOLS_ #elif defined(CONFIG_TPL_BUILD) #define _CONFIG_PREFIX TPL_ +#elif defined(CONFIG_VPL_BUILD) +#define _CONFIG_PREFIX VPL_ #elif defined(CONFIG_SPL_BUILD) #define _CONFIG_PREFIX SPL_ #else @@ -54,6 +56,7 @@ * CONFIG_FOO if CONFIG_SPL_BUILD is undefined, * CONFIG_SPL_FOO if CONFIG_SPL_BUILD is defined. * CONFIG_TPL_FOO if CONFIG_TPL_BUILD is defined. + * CONFIG_VPL_FOO if CONFIG_VPL_BUILD is defined. */ #define CONFIG_VAL(option) config_val(option)
diff --git a/include/spl.h b/include/spl.h index 8ceb3c0f09..f160d31046 100644 --- a/include/spl.h +++ b/include/spl.h @@ -61,6 +61,7 @@ static inline bool u_boot_first_phase(void) enum u_boot_phase { PHASE_NONE, /* Invalid phase, signifying before U-Boot */ PHASE_TPL, /* Running in TPL */ + PHASE_VPL, /* Running in VPL */ PHASE_SPL, /* Running in SPL */ PHASE_BOARD_F, /* Running in U-Boot before relocation */ PHASE_BOARD_R, /* Running in U-Boot after relocation */ @@ -113,7 +114,9 @@ static inline enum u_boot_phase spl_phase(void) { #ifdef CONFIG_TPL_BUILD return PHASE_TPL; -#elif CONFIG_SPL_BUILD +#elif defined(CONFIG_VPL_BUILD) + return PHASE_VPL; +#elif defined(CONFIG_SPL_BUILD) return PHASE_SPL; #else DECLARE_GLOBAL_DATA_PTR; @@ -135,10 +138,15 @@ static inline enum u_boot_phase spl_prev_phase(void) { #ifdef CONFIG_TPL_BUILD return PHASE_NONE; +#elif defined(CONFIG_VPL_BUILD) + return PHASE_TPL; /* VPL requires TPL */ #elif defined(CONFIG_SPL_BUILD) - return IS_ENABLED(CONFIG_TPL) ? PHASE_TPL : PHASE_NONE; + return IS_ENABLED(CONFIG_VPL) ? PHASE_VPL : + IS_ENABLED(CONFIG_TPL) ? PHASE_TPL : + PHASE_NONE; #else - return IS_ENABLED(CONFIG_SPL) ? PHASE_SPL : PHASE_NONE; + return IS_ENABLED(CONFIG_SPL) ? PHASE_SPL : + PHASE_NONE; #endif }
@@ -151,6 +159,8 @@ static inline enum u_boot_phase spl_prev_phase(void) static inline enum u_boot_phase spl_next_phase(void) { #ifdef CONFIG_TPL_BUILD + return IS_ENABLED(CONFIG_VPL) ? PHASE_VPL : PHASE_SPL; +#elif defined(CONFIG_VPL_BUILD) return PHASE_SPL; #else return PHASE_BOARD_F; @@ -167,6 +177,8 @@ static inline const char *spl_phase_name(enum u_boot_phase phase) switch (phase) { case PHASE_TPL: return "TPL"; + case PHASE_VPL: + return "VPL"; case PHASE_SPL: return "SPL"; case PHASE_BOARD_F: @@ -188,6 +200,8 @@ static inline const char *spl_phase_prefix(enum u_boot_phase phase) switch (phase) { case PHASE_TPL: return "tpl"; + case PHASE_VPL: + return "vpl"; case PHASE_SPL: return "spl"; case PHASE_BOARD_F: @@ -202,6 +216,8 @@ static inline const char *spl_phase_prefix(enum u_boot_phase phase) #ifdef CONFIG_SPL_BUILD # ifdef CONFIG_TPL_BUILD # define SPL_TPL_NAME "TPL" +# elif defined(CONFIG_VPL_BUILD) +# define SPL_TPL_NAME "VPL" # else # define SPL_TPL_NAME "SPL" # endif diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index 09506cb9a7..9c14310ad4 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -322,11 +322,15 @@ endif
ifdef CONFIG_SPL_BUILD SPL_ := SPL_ +ifeq ($(CONFIG_VPL_BUILD),y) +SPL_TPL_ := VPL_ +else ifeq ($(CONFIG_TPL_BUILD),y) SPL_TPL_ := TPL_ else SPL_TPL_ := SPL_ endif +endif else SPL_ := SPL_TPL_ := diff --git a/scripts/Makefile.autoconf b/scripts/Makefile.autoconf index 0b3ffa08bf..3fa4d50f1e 100644 --- a/scripts/Makefile.autoconf +++ b/scripts/Makefile.autoconf @@ -18,6 +18,10 @@ ifeq ($(shell grep -q '^CONFIG_TPL=y' include/config/auto.conf 2>/dev/null && ec __all: tpl/include/autoconf.mk endif
+ifeq ($(shell grep -q '^CONFIG_VPL=y' include/config/auto.conf 2>/dev/null && echo y),y) +__all: vpl/include/autoconf.mk +endif + include include/config/auto.conf
include scripts/Kbuild.include @@ -85,6 +89,10 @@ tpl/u-boot.cfg: include/config.h FORCE $(Q)mkdir -p $(dir $@) $(call cmd,u_boot_cfg,-DCONFIG_SPL_BUILD -DCONFIG_TPL_BUILD)
+vpl/u-boot.cfg: include/config.h FORCE + $(Q)mkdir -p $(dir $@) + $(call cmd,u_boot_cfg,-DCONFIG_SPL_BUILD -DCONFIG_VPL_BUILD) + include/autoconf.mk: u-boot.cfg $(call cmd,autoconf)
@@ -96,6 +104,10 @@ tpl/include/autoconf.mk: tpl/u-boot.cfg $(Q)mkdir -p $(dir $@) $(call cmd,autoconf)
+vpl/include/autoconf.mk: vpl/u-boot.cfg + $(Q)mkdir -p $(dir $@) + $(call cmd,autoconf) + # include/config.h # Prior to Kconfig, it was generated by mkconfig. Now it is created here. define filechk_config_h diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 5df8f61aa5..3b8c9d8c31 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -4,6 +4,9 @@ # ==========================================================================
# Modified for U-Boot +prefix := vpl +src := $(patsubst $(prefix)/%,%,$(obj)) +ifeq ($(obj),$(src)) prefix := tpl src := $(patsubst $(prefix)/%,%,$(obj)) ifeq ($(obj),$(src)) @@ -13,6 +16,7 @@ ifeq ($(obj),$(src)) prefix := . endif endif +endif
PHONY := __build __build: diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index c14da10de7..00acf2c57f 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -583,16 +583,21 @@ cmd_mkimage = $(objtree)/tools/mkimage $(MKIMAGEFLAGS_$(@F)) -d $< $@ \ # 'u-boot,dm-pre-reloc' property and thus are not needed by SPL. The second # pass removes various unused properties from the remaining nodes. # The output is typically a much smaller device tree file. +ifeq ($(CONFIG_VPL_BUILD),y) +fdtgrep_props := -b u-boot,dm-pre-reloc -b u-boot,dm-vpl +else ifeq ($(CONFIG_TPL_BUILD),y) fdtgrep_props := -b u-boot,dm-pre-reloc -b u-boot,dm-tpl else fdtgrep_props := -b u-boot,dm-pre-reloc -b u-boot,dm-spl endif +endif quiet_cmd_fdtgrep = FDTGREP $@ cmd_fdtgrep = $(objtree)/tools/fdtgrep $(fdtgrep_props) -RT $< \ -n /chosen -n /config -O dtb | \ $(objtree)/tools/fdtgrep -r -O dtb - -o $@ \ -P u-boot,dm-pre-reloc -P u-boot,dm-spl -P u-boot,dm-tpl \ + -P u-boot,dm-vpl \ $(addprefix -P ,$(subst $",,$(CONFIG_OF_SPL_REMOVE_PROPS)))
# fdt_rm_props diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 1f50fbf8c9..9798e7b120 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -27,8 +27,16 @@ UBOOTINCLUDE := -I$(obj)/include $(UBOOTINCLUDE) KBUILD_CPPFLAGS += -DCONFIG_SPL_BUILD ifeq ($(CONFIG_TPL_BUILD),y) KBUILD_CPPFLAGS += -DCONFIG_TPL_BUILD +else +ifeq ($(CONFIG_VPL_BUILD),y) +KBUILD_CPPFLAGS += -DCONFIG_VPL_BUILD +endif endif
+ifeq ($(CONFIG_VPL_BUILD),y) +SPL_BIN := u-boot-vpl +SPL_NAME := vpl +else ifeq ($(CONFIG_TPL_BUILD),y) SPL_BIN := u-boot-tpl SPL_NAME := tpl @@ -36,16 +44,21 @@ else SPL_BIN := u-boot-spl SPL_NAME := spl endif +endif
export SPL_NAME
ifdef CONFIG_SPL_BUILD SPL_ := SPL_ +ifeq ($(CONFIG_VPL_BUILD),y) +SPL_TPL_ := VPL_ +else ifeq ($(CONFIG_TPL_BUILD),y) SPL_TPL_ := TPL_ else SPL_TPL_ := SPL_ endif +endif else SPL_ := SPL_TPL_ := @@ -57,6 +70,9 @@ endif ifeq ($(obj)$(CONFIG_SUPPORT_TPL),tpl) $(error You cannot build TPL without enabling CONFIG_SUPPORT_TPL) endif +ifeq ($(obj)$(CONFIG_SUPPORT_VPL),vpl) +$(error You cannot build VPL without enabling CONFIG_SUPPORT_VPL) +endif
include $(srctree)/config.mk include $(srctree)/arch/$(ARCH)/Makefile @@ -90,17 +106,12 @@ libs-$(CONFIG_SPL_FRAMEWORK) += common/spl/ endif libs-y += common/init/
-# Special handling for a few options which support SPL/TPL -ifeq ($(CONFIG_TPL_BUILD),y) -libs-$(CONFIG_TPL_LIBCOMMON_SUPPORT) += boot/ common/ cmd/ env/ -libs-$(CONFIG_TPL_LIBGENERIC_SUPPORT) += lib/ -else -libs-$(CONFIG_SPL_LIBCOMMON_SUPPORT) += boot/ common/ cmd/ env/ -libs-$(CONFIG_SPL_LIBGENERIC_SUPPORT) += lib/ +# Special handling for a few options which support SPL/TPL/VPL +libs-$(CONFIG_$(SPL_TPL_)LIBCOMMON_SUPPORT) += boot/ common/ cmd/ env/ +libs-$(CONFIG_$(SPL_TPL_)LIBGENERIC_SUPPORT) += lib/ ifdef CONFIG_SPL_FRAMEWORK libs-$(CONFIG_PARTITIONS) += disk/ endif -endif
libs-y += drivers/ libs-$(CONFIG_SPL_USB_GADGET) += drivers/usb/dwc3/ @@ -182,7 +193,7 @@ LDPPFLAGS += \ sed -ne 's/GNU ld version ([0-9][0-9]*).([0-9][0-9]*).*/-DLD_MAJOR=\1 -DLD_MINOR=\2/p')
# Turn various CONFIG symbols into IMAGE symbols for easy reuse of -# the scripts between SPL and TPL. +# the scripts between SPL, TPL and VPL. ifneq ($(CONFIG_$(SPL_TPL_)MAX_SIZE),) LDPPFLAGS += -DIMAGE_MAX_SIZE=$(CONFIG_$(SPL_TPL_)MAX_SIZE) endif @@ -264,6 +275,7 @@ ifeq ($(CONFIG_SYS_SOC),"at91") INPUTS-y += $(obj)/boot.bin endif
+ifndef CONFIG_VPL_BUILD ifdef CONFIG_TPL_BUILD INPUTS-$(CONFIG_TPL_X86_16BIT_INIT) += $(obj)/u-boot-x86-start16-tpl.bin \ $(obj)/u-boot-x86-reset16-tpl.bin @@ -271,6 +283,7 @@ else INPUTS-$(CONFIG_SPL_X86_16BIT_INIT) += $(obj)/u-boot-x86-start16-spl.bin \ $(obj)/u-boot-x86-reset16-spl.bin endif +endif
INPUTS-$(CONFIG_ARCH_ZYNQ) += $(obj)/boot.bin INPUTS-$(CONFIG_ARCH_ZYNQMP) += $(obj)/boot.bin @@ -307,7 +320,7 @@ endif
ifneq ($(build_dtb),) $(obj)/$(SPL_BIN)-dtb.bin: $(obj)/$(SPL_BIN)-nodtb.bin \ - $(if $(CONFIG_SPL_SEPARATE_BSS),,$(obj)/$(SPL_BIN)-pad.bin) \ + $(if $(CONFIG_$(SPL_TPL_)SEPARATE_BSS),,$(obj)/$(SPL_BIN)-pad.bin) \ $(FINAL_DTB_CONTAINER) FORCE $(call if_changed,cat)
@@ -398,7 +411,7 @@ LDFLAGS_$(SPL_BIN) += $(call ld-option, --no-dynamic-linker)
LDFLAGS_$(SPL_BIN) += --build-id=none
-# Pick the best-match (i.e. SPL_TEXT_BASE for SPL, TPL_TEXT_BASE for TPL) +# Pick the best match (e.g. SPL_TEXT_BASE for SPL, TPL_TEXT_BASE for TPL) ifneq ($(CONFIG_$(SPL_TPL_)TEXT_BASE),) LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_$(SPL_TPL_)TEXT_BASE) endif
Add VPL versions of commonly used Kconfig options.
Changes in v7: - Add a few more options
Changes in v4: - Add options for blk, core, misc and tpl also - Add VPL_SIZE_LIMIT
Kconfig | 10 ++ common/Kconfig | 67 ++++++++++++ common/spl/Kconfig | 219 +++++++++++++++++++++++++++++++++++++++ drivers/block/Kconfig | 12 +++ drivers/clk/Kconfig | 26 +++++ drivers/core/Kconfig | 33 ++++++ drivers/core/Makefile | 2 +- drivers/gpio/Kconfig | 11 ++ drivers/i2c/Kconfig | 11 ++ drivers/misc/Kconfig | 28 +++++ drivers/pinctrl/Kconfig | 18 +++- drivers/rtc/Kconfig | 9 ++ drivers/serial/Kconfig | 20 ++++ drivers/sysreset/Kconfig | 10 ++ drivers/timer/Kconfig | 10 ++ drivers/tpm/Kconfig | 30 ++++++ dts/Kconfig | 17 +++ lib/Kconfig | 62 +++++++++++ 18 files changed, 592 insertions(+), 3 deletions(-)
diff --git a/Kconfig b/Kconfig index 9dd9ec7f6d..5e54d72a3b 100644 --- a/Kconfig +++ b/Kconfig @@ -279,6 +279,16 @@ config TPL_SYS_MALLOC_F_LEN particular needs this to operate, so that it can allocate the initial serial device and any others that are needed.
+config VPL_SYS_MALLOC_F_LEN + hex "Size of malloc() pool in VPL before relocation" + depends on SYS_MALLOC_F && VPL + default SYS_MALLOC_F_LEN + help + Before relocation, memory is very limited on many platforms. Still, + we can provide a small malloc() pool if needed. Driver model in + particular needs this to operate, so that it can allocate the + initial serial device and any others that are needed. + menuconfig EXPERT bool "Configure standard U-Boot features (expert users)" default y diff --git a/common/Kconfig b/common/Kconfig index d2b1b35225..e4a6520984 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -89,6 +89,15 @@ config TPL_LOGLEVEL int default LOGLEVEL
+config VPL_LOGLEVEL + int "loglevel for VPL" + default LOGLEVEL + help + All Messages with a loglevel smaller than the console loglevel will + be compiled in to VPL. See LOGLEVEL for a list of available log + levels. Setting this to a value above 4 may increase the code size + significantly. + config SILENT_CONSOLE bool "Support a silent console" help @@ -262,6 +271,15 @@ config LOG
if LOG
+config VPL_LOG + bool "Enable logging support in VPL" + depends on LOG + help + This enables support for logging of status and debug messages. These + can be displayed on the console, recorded in a memory buffer, or + discarded if not needed. Logging supports various categories and + levels of severity. + config LOG_MAX_LEVEL int "Maximum log level to record" default 6 @@ -431,6 +449,47 @@ config TPL_LOG_CONSOLE
endif
+config VPL_LOG + bool "Enable logging support in VPL" + depends on LOG + help + This enables support for logging of status and debug messages. These + can be displayed on the console, recorded in a memory buffer, or + discarded if not needed. Logging supports various categories and + levels of severity. + +if VPL_LOG + +config VPL_LOG_MAX_LEVEL + int "Maximum log level to record in VPL" + default 3 + help + This selects the maximum log level that will be recorded. Any value + higher than this will be ignored. If possible log statements below + this level will be discarded at build time. Levels: + + 0 - emergency + 1 - alert + 2 - critical + 3 - error + 4 - warning + 5 - note + 6 - info + 7 - debug + 8 - debug content + 9 - debug hardware I/O + +config VPL_LOG_CONSOLE + bool "Allow log output to the console in VPL" + default y + help + Enables a log driver which writes log records to the console. + Generally the console is the serial port or LCD display. Only the + log message is shown - other details like level, category, file and + line number are omitted. + +endif + config LOG_ERROR_RETURN bool "Log all functions which return an error" help @@ -736,6 +795,14 @@ config TPL_BLOBLIST This enables a bloblist in TPL. The bloblist is set up in TPL and passed to SPL and U-Boot proper.
+config VPL_BLOBLIST + bool "Support for a bloblist in VPL" + depends on BLOBLIST && VPL_LIBGENERIC_SUPPORT && VPL_LIBCOMMON_SUPPORT + default y if VPL + help + This enables a bloblist in VPL. The bloblist is set up in VPL and + passed to SPL and U-Boot proper. + if BLOBLIST
choice diff --git a/common/spl/Kconfig b/common/spl/Kconfig index d3557468f8..23426bc168 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -189,6 +189,13 @@ config SPL_BOARD_INIT spl_board_init() from board_init_r(). This function should be provided by the board.
+config VPL_BOARD_INIT + bool "Call board-specific initialization in VPL" + help + If this option is enabled, U-Boot will call the function + spl_board_init() from board_init_r(). This function should be + provided by the board. + config SPL_BOOTROM_SUPPORT bool "Support returning to the BOOTROM" help @@ -1631,6 +1638,218 @@ config TPL_YMODEM_SUPPORT
endif # TPL
+config VPL + bool + depends on SUPPORT_SPL + prompt "Enable VPL" + help + If you want to build VPL as well as the normal image, TPL and SPL, + say Y. + +if VPL + +config VPL_BANNER_PRINT + bool "Enable output of the VPL banner 'U-Boot VPL ...'" + depends on VPL + default y + help + If this option is enabled, VPL will print the banner with version + info. Disabling this option could be useful to reduce VPL boot time + (e.g. approx. 6 ms faster, when output on i.MX6 with 115200 baud). + +config VPL_BOARD_INIT + bool "Call board-specific initialization in VPL" + help + If this option is enabled, U-Boot will call the function + spl_board_init() from board_init_r(). This function should be + provided by the board. + +config VPL_CACHE + depends on CACHE + bool "Support cache drivers in VPL" + help + Enable support for cache drivers in VPL. + +config VPL_CRC32 + bool "Support CRC32 in VPL" + default y if VPL_ENV_SUPPORT || VPL_BLOBLIST + help + Enable this to support CRC32 in uImages or FIT images within VPL. + This is a 32-bit checksum value that can be used to verify images. + For FIT images, this is the least secure type of checksum, suitable + for detected accidental image corruption. For secure applications you + should consider SHA1 or SHA256. + +config VPL_DM_SPI + bool "Support SPI DM drivers in VPL" + help + Enable support for SPI DM drivers in VPL. + +config VPL_DM_SPI_FLASH + bool "Support SPI DM FLASH drivers in VPL" + help + Enable support for SPI DM flash drivers in VPL. + +config VPL_FRAMEWORK + bool "Support VPL based upon the common SPL framework" + default y + help + Enable the SPL framework under common/spl/ for VPL builds. + This framework supports MMC, NAND and YMODEM and other methods + loading of U-Boot's next stage. If unsure, say Y. + +config VPL_HANDOFF + bool "Pass hand-off information from VPL to SPL" + depends on HANDOFF && VPL_BLOBLIST + default y + help + This option enables VPL to write handoff information. This can be + used to pass information like the size of SDRAM from VPL to SPL. Also + VPL can receive information from TPL in the same place if that is + enabled. + +config VPL_LIBCOMMON_SUPPORT + bool "Support common libraries" + default y if SPL_LIBCOMMON_SUPPORT + help + Enable support for common U-Boot libraries within VPL. See + SPL_LIBCOMMON_SUPPORT for details. + +config VPL_LIBGENERIC_SUPPORT + bool "Support generic libraries" + default y if SPL_LIBGENERIC_SUPPORT + help + Enable support for generic U-Boot libraries within VPL. These + libraries include generic code to deal with device tree, hashing, + printf(), compression and the like. This option is enabled on many + boards. Enable this option to build the code in lib/ as part of a + VPL build. + +config VPL_DRIVERS_MISC + bool "Support misc drivers" + default y if TPL_DRIVERS_MISC + help + Enable miscellaneous drivers in VPL. These drivers perform various + tasks that don't fall nicely into other categories, Enable this + option to build the drivers in drivers/misc as part of a VPL + build, for those that support building in VPL (not all drivers do). + +config VPL_ENV_SUPPORT + bool "Support an environment" + help + Enable environment support in VPL. The U-Boot environment provides + a number of settings (essentially name/value pairs) which can + control many aspects of U-Boot's operation. Enabling this option will + make env_get() and env_set() available in VSPL. + +config VPL_GPIO + bool "Support GPIO in VPL" + default y if SPL_GPIO + help + Enable support for GPIOs (General-purpose Input/Output) in VPL. + GPIOs allow U-Boot to read the state of an input line (high or + low) and set the state of an output line. This can be used to + drive LEDs, control power to various system parts and read user + input. GPIOs can be useful in VPL to enable a 'sign-of-life' LED, + for example. Enable this option to build the drivers in + drivers/gpio as part of a VPL build. + +config VPL_HANDOFF + bool "Pass hand-off information from VPL to SPL and U-Boot proper" + depends on HANDOFF && VPL_BLOBLIST + default y + help + This option enables VPL to write handoff information. This can be + used to pass information like the size of SDRAM from VPL to U-Boot + proper. The information is also available to VPL if it is useful + there. + +config VPL_HASH + bool "Support hashing drivers in VPL" + depends on VPL + select SHA1 + select SHA256 + help + Enable hashing drivers in VPL. These drivers can be used to + accelerate secure boot processing in secure applications. Enable + this option to build system-specific drivers for hash acceleration + as part of a VPL build. + +config VPL_I2C_SUPPORT + bool "Support I2C in VPL" + default y if SPL_I2C_SUPPORT + help + Enable support for the I2C bus in VPL. Vee SPL_I2C_SUPPORT for + details. + +config VPL_PCH_SUPPORT + bool "Support PCH drivers" + default y if TPL_PCH_SUPPORT + help + Enable support for PCH (Platform Controller Hub) devices in VPL. + These are used to set up GPIOs and the SPI peripheral early in + boot. This enables the drivers in drivers/pch as part of a VPL + build. + +config VPL_PCI + bool "Support PCI drivers" + default y if SPL_PCI + help + Enable support for PCI in VPL. For platforms that need PCI to boot, + or must perform some init using PCI in VPL, this provides the + necessary driver support. This enables the drivers in drivers/pci + as part of a VPL build. + +config VPL_RTC + bool "Support RTC drivers" + help + Enable RTC (Real-time Clock) support in VPL. This includes support + for reading and setting the time. Some RTC devices also have some + non-volatile (battery-backed) memory which is accessible if + needed. This enables the drivers in drivers/rtc as part of a VPL + build. + +config VPL_SERIAL + bool "Support serial" + default y if TPL_SERIAL + select VPL_PRINTF + select VPL_STRTO + help + Enable support for serial in VPL. See SPL_SERIAL_SUPPORT for + details. + +config VPL_SIZE_LIMIT + hex "Maximum size of VPL image" + depends on VPL + default 0x0 + help + Specifies the maximum length of the U-Boot VPL image. + If this value is zero, it is ignored. + +config VPL_SPI + bool "Support SPI drivers" + help + Enable support for using SPI in VPL. See SPL_SPI_SUPPORT for + details. + +config VPL_SPI_FLASH_SUPPORT + bool "Support SPI flash drivers" + help + Enable support for using SPI flash in VPL, and loading U-Boot from + SPI flash. SPI flash (Serial Peripheral Bus flash) is named after + the SPI bus that is used to connect it to a system. It is a simple + but fast bidirectional 4-wire bus (clock, chip select and two data + lines). This enables the drivers in drivers/mtd/spi as part of a + VPL build. This normally requires VPL_SPI_SUPPORT. + +config VPL_TEXT_BASE + hex "VPL Text Base" + default 0x0 + help + The address in memory that VPL will be running from. + +endif # VPL + config SPL_AT91_MCK_BYPASS bool "Use external clock signal as a source of main clock for AT91 platforms" depends on ARCH_AT91 diff --git a/drivers/block/Kconfig b/drivers/block/Kconfig index c54b58110c..d6d1c6e32c 100644 --- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -39,6 +39,18 @@ config TPL_BLK be partitioned into several areas, called 'partitions' in U-Boot. A filesystem can be placed in each partition.
+config VPL_BLK + bool "Support block devices in VPL" + depends on VPL_DM && BLK + default y + help + Enable support for block devices, such as SCSI, MMC and USB + flash sticks. These provide a block-level interface which permits + reading, writing and (in some cases) erasing blocks. Block + devices often have a partition table which allows the device to + be partitioned into several areas, called 'partitions' in U-Boot. + A filesystem can be placed in each partition. + config BLOCK_CACHE bool "Use block device cache" depends on BLK diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 6dc271f71b..a62b81a123 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -30,6 +30,32 @@ config TPL_CLK setting up clocks within TPL, and allows the same drivers to be used as U-Boot proper.
+config VPL_CLK + bool "Enable clock support in VPL" + depends on CLK && VPL_DM + help + The clock subsystem adds a small amount of overhead to the image. + If this is acceptable and you have a need to use clock drivers in + SPL, enable this option. It might provide a cleaner interface to + setting up clocks within TPL, and allows the same drivers to be + used as U-Boot proper. + +config CLK_BCM6345 + bool "Clock controller driver for BCM6345" + depends on CLK && ARCH_BMIPS + default y + help + This clock driver adds support for enabling and disabling peripheral + clocks on BCM6345 SoCs. HW has no rate changing capabilities. + +config CLK_BOSTON + def_bool y if TARGET_BOSTON + depends on CLK + select REGMAP + select SYSCON + help + Enable this to support the clocks + config SPL_CLK_CCF bool "SPL Common Clock Framework [CCF] support " depends on SPL diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 8f7703c8b5..abf9858da5 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -35,6 +35,16 @@ config TPL_DM CONFIG_SPL_SYS_MALLOC_F_LEN for more details on how to enable it. Disable this for very small implementations.
+config VPL_DM + bool "Enable Driver Model for VPL" + depends on DM && VPL + default y if SPL_DM + help + Enable driver model in VPL. You will need to provide a + suitable malloc() implementation. If you are not using the + full malloc() enabled by CONFIG_SYS_SPL_MALLOC_START, + consider using CONFIG_SYS_MALLOC_SIMPLE. + config DM_WARN bool "Enable warnings in driver model" depends on DM @@ -111,6 +121,15 @@ config SPL_DM_SEQ_ALIAS numbered devices (e.g. serial0 = &serial0). This feature can be disabled if it is not required, to save code space in SPL.
+config VPL_DM_SEQ_ALIAS + bool "Support numbered aliases in device tree in VPL" + depends on VPL_DM + default y + help + Most boards will have a '/aliases' node containing the path to + numbered devices (e.g. serial0 = &serial0). This feature can be + disabled if it is not required, to save code space in VPL. + config SPL_DM_INLINE_OFNODE bool "Inline some ofnode functions which are seldom used in SPL" depends on SPL_DM @@ -282,6 +301,20 @@ config SPL_OF_TRANSLATE used for the address translation. This function is faster and smaller in size than fdt_translate_address().
+config VPL_OF_TRANSLATE + bool "Translate addresses using fdt_translate_address in SPL" + depends on SPL_DM && VPL_OF_CONTROL + help + If this option is enabled, the reg property will be translated + using the fdt_translate_address() function. This is necessary + on some platforms (e.g. MVEBU) using complex "ranges" + properties in many nodes. As this translation is not handled + correctly in the default simple_bus_translate() function. + + If this option is not enabled, simple_bus_translate() will be + used for the address translation. This function is faster and + smaller in size than fdt_translate_address(). + config TRANSLATION_OFFSET bool "Platforms specific translation offset" depends on DM && OF_CONTROL diff --git a/drivers/core/Makefile b/drivers/core/Makefile index 5edd4e4135..07a0886383 100644 --- a/drivers/core/Makefile +++ b/drivers/core/Makefile @@ -5,7 +5,7 @@ obj-y += device.o fdtaddr.o lists.o root.o uclass.o util.o obj-$(CONFIG_$(SPL_TPL_)ACPIGEN) += acpi.o obj-$(CONFIG_DEVRES) += devres.o -obj-$(CONFIG_$(SPL_)DM_DEVICE_REMOVE) += device-remove.o +obj-$(CONFIG_$(SPL_TPL_)DM_DEVICE_REMOVE) += device-remove.o obj-$(CONFIG_$(SPL_)SIMPLE_BUS) += simple-bus.o obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o obj-$(CONFIG_DM) += dump.o diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 8d0e47c67d..0f6f03cde9 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -48,6 +48,17 @@ config TPL_DM_GPIO particular GPIOs that they provide. The uclass interface is defined in include/asm-generic/gpio.h.
+config VPL_DM_GPIO + bool "Enable Driver Model for GPIO drivers in VPL" + depends on DM_GPIO && VPL_DM && VPL_GPIO + default y + help + Enable driver model for GPIO access in VPL. The standard GPIO + interface (gpio_get_value(), etc.) is then implemented by + the GPIO uclass. Drivers provide methods to query the + particular GPIOs that they provide. The uclass interface + is defined in include/asm-generic/gpio.h. + config GPIO_HOG bool "Enable GPIO hog support" depends on DM_GPIO diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 5482a4a470..d25c5736ef 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -47,6 +47,17 @@ config SPL_DM_I2C device (bus child) info is kept as parent platdata. The interface is defined in include/i2c.h.
+config VPL_DM_I2C + bool "Enable Driver Model for I2C drivers in VPL" + depends on VPL_DM && DM_I2C + default y + help + Enable driver model for I2C. The I2C uclass interface: probe, read, + write and speed, is implemented with the bus drivers operations, + which provide methods for bus setting and data transfer. Each chip + device (bus child) info is kept as parent platdata. The interface + is defined in include/i2c.h. + config SYS_I2C_LEGACY bool "Enable legacy I2C subsystem and drivers" depends on !DM_I2C diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 0ade3e32b0..bf83993a06 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -122,6 +122,16 @@ config TPL_CROS_EC control access to the battery and main PMIC depending on the device. You can use the 'crosec' command to access it.
+config VPL_CROS_EC + bool "Enable Chrome OS EC in VPL" + depends on VPL + help + Enable access to the Chrome OS EC in VPL. This is a separate + microcontroller typically available on a SPI bus on Chromebooks. It + provides access to the keyboard, some internal storage and may + control access to the battery and main PMIC depending on the + device. You can use the 'crosec' command to access it. + config CROS_EC_I2C bool "Enable Chrome OS EC I2C driver" depends on CROS_EC @@ -158,6 +168,15 @@ config TPL_CROS_EC_LPC through a legacy port interface, so on x86 machines the main function of the EC is power and thermal management.
+config VPL_CROS_EC_LPC + bool "Enable Chrome OS EC LPC driver in VPL" + depends on CROS_EC + help + Enable I2C access to the Chrome OS EC. This is used on x86 + Chromebooks such as link and falco. The keyboard is provided + through a legacy port interface, so on x86 machines the main + function of the EC is power and thermal management. + config CROS_EC_SANDBOX bool "Enable Chrome OS EC sandbox driver" depends on CROS_EC && SANDBOX @@ -185,6 +204,15 @@ config TPL_CROS_EC_SANDBOX EC flash read/write/erase support and a few other things. It is enough to perform a Chrome OS verified boot on sandbox.
+config VPL_CROS_EC_SANDBOX + bool "Enable Chrome OS EC sandbox driver in VPL" + depends on VPL_CROS_EC && SANDBOX + help + Enable a sandbox emulation of the Chrome OS EC in VPL. This supports + keyboard (use the -l flag to enable the LCD), verified boot context, + EC flash read/write/erase support and a few other things. It is + enough to perform a Chrome OS verified boot on sandbox. + config CROS_EC_SPI bool "Enable Chrome OS EC SPI driver" depends on CROS_EC diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 03946245c7..81fd7ee2e5 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -89,20 +89,34 @@ config TPL_PINCTRL This option is an TPL variant of the PINCTRL option. See the help of PINCTRL for details.
+config VPL_PINCTRL + bool "Support pin controllers in VPL" + depends on VPL && VPL_DM + help + This option is an VPL variant of the PINCTRL option. + See the help of PINCTRL for details. + config SPL_PINCTRL_FULL bool "Support full pin controllers in SPL" depends on SPL_PINCTRL && SPL_OF_CONTROL default n if TARGET_STM32F746_DISCO default y help - This option is an SPL-variant of the PINCTRL_FULL option. + This option is an SPL variant of the PINCTRL_FULL option. See the help of PINCTRL_FULL for details.
config TPL_PINCTRL_FULL bool "Support full pin controllers in TPL" depends on TPL_PINCTRL && TPL_OF_CONTROL help - This option is an TPL-variant of the PINCTRL_FULL option. + This option is a TPL variant of the PINCTRL_FULL option. + See the help of PINCTRL_FULL for details. + +config VPL_PINCTRL_FULL + bool "Support full pin controllers in VPL" + depends on VPL_PINCTRL && VPL_OF_CONTROL + help + This option is a VPL variant of the PINCTRL_FULL option. See the help of PINCTRL_FULL for details.
config SPL_PINCTRL_GENERIC diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index 71777cdd05..e4a589d8ec 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -32,6 +32,15 @@ config TPL_DM_RTC drivers to perform the actual functions. See rtc.h for a description of the API.
+config VPL_DM_RTC + bool "Enable Driver Model for RTC drivers in VPL" + depends on VPL_DM + help + Enable drver model for real-time-clock drivers. The RTC uclass + then provides the rtc_get()/rtc_set() interface, delegating to + drivers to perform the actual functions. See rtc.h for a + description of the API. + config RTC_ENABLE_32KHZ_OUTPUT bool "Enable RTC 32Khz output" help diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 345d1881f5..e55581ae2d 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -74,6 +74,16 @@ config TPL_SERIAL_PRESENT This option enables the full UART in TPL, so if is it disabled, the full UART driver will be omitted, thus saving space.
+config VPL_SERIAL_PRESENT + bool "Provide a serial driver in VPL" + depends on DM_SERIAL && VPL + default y + help + In very space-constrained devices even the full UART driver is too + large. In this case the debug UART can still be used in some cases. + This option enables the full UART in TPL, so if is it disabled, + the full UART driver will be omitted, thus saving space. + # Logic to allow us to use the imply keyword to set what the default port # should be. The default is otherwise 1. config CONS_INDEX_0 @@ -182,6 +192,16 @@ config TPL_DM_SERIAL implements serial_putc() etc. The uclass interface is defined in include/serial.h.
+config VPL_DM_SERIAL + bool "Enable Driver Model for serial drivers in VPL" + depends on DM_SERIAL + default y if VPL && DM_SERIAL + help + Enable driver model for serial in VPL. This replaces + drivers/serial/serial.c with the serial uclass, which + implements serial_putc() etc. The uclass interface is + defined in include/serial.h. + config DEBUG_UART bool "Enable an early debug UART for debugging" help diff --git a/drivers/sysreset/Kconfig b/drivers/sysreset/Kconfig index f6d60038b8..951ec0ea96 100644 --- a/drivers/sysreset/Kconfig +++ b/drivers/sysreset/Kconfig @@ -31,6 +31,16 @@ config TPL_SYSRESET to effect a reset. The uclass will try all available drivers when reset_walk() is called.
+config VPL_SYSRESET + bool "Enable support for system reset drivers in VPL mode" + depends on SYSRESET && VPL_DM + default y if TPL_SYSRESET + help + Enable system reset drivers which can be used to reset the CPU or + board. Each driver can provide a reset method which will be called + to effect a reset. The uclass will try all available drivers when + reset_walk() is called. + if SYSRESET
config SYSRESET_CMD_RESET diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 8913142654..47dfd9c559 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -27,6 +27,16 @@ config TPL_TIMER function. This enables the drivers in drivers/timer as part of an TPL build.
+config VPL_TIMER + bool "Enable driver model for timer drivers in VPL" + depends on TIMER && VPL + default y if TPL_TIMER + help + Enable support for timer drivers in VPL. These can be used to get + a timer value when in VPL, or perhaps for implementing a delay + function. This enables the drivers in drivers/timer as part of an + TPL build. + config TIMER_EARLY bool "Allow timer to be used early in U-Boot" depends on TIMER diff --git a/drivers/tpm/Kconfig b/drivers/tpm/Kconfig index 406ee8716e..eceff27d5f 100644 --- a/drivers/tpm/Kconfig +++ b/drivers/tpm/Kconfig @@ -137,6 +137,36 @@ config TPM2_CR50_I2C trust for a device, It operates like a TPM and can be used with verified boot. Cr50 is used on recent Chromebooks (since 2017).
+config SPL_TPM2_CR50_I2C + bool "Enable support for Google cr50 TPM" + depends on DM_I2C && SPL_TPM + help + Cr50 is an implementation of a TPM on Google's H1 security chip. + This uses the same open-source firmware as the Chromium OS EC. + While Cr50 has other features, its primary role is as the root of + trust for a device, It operates like a TPM and can be used with + verified boot. Cr50 is used on recent Chromebooks (since 2017). + +config TPL_TPM2_CR50_I2C + bool "Enable support for Google cr50 TPM" + depends on DM_I2C && TPL_TPM + help + Cr50 is an implementation of a TPM on Google's H1 security chip. + This uses the same open-source firmware as the Chromium OS EC. + While Cr50 has other features, its primary role is as the root of + trust for a device, It operates like a TPM and can be used with + verified boot. Cr50 is used on recent Chromebooks (since 2017). + +config VPL_TPM2_CR50_I2C + bool "Enable support for Google cr50 TPM" + depends on DM_I2C && VPL_TPM + help + Cr50 is an implementation of a TPM on Google's H1 security chip. + This uses the same open-source firmware as the Chromium OS EC. + While Cr50 has other features, its primary role is as the root of + trust for a device, It operates like a TPM and can be used with + verified boot. Cr50 is used on recent Chromebooks (since 2017). + config TPM2_TIS_SANDBOX bool "Enable sandbox TPMv2.x driver" depends on TPM_V2 && SANDBOX diff --git a/dts/Kconfig b/dts/Kconfig index b19912d10d..f1d05cc080 100644 --- a/dts/Kconfig +++ b/dts/Kconfig @@ -65,6 +65,15 @@ config TPL_OF_CONTROL which is not enough to support device tree. Enable this option to allow such boards to be supported by U-Boot TPL.
+config VPL_OF_CONTROL + bool "Enable run-time configuration via Device Tree in VPL" + depends on VPL && OF_CONTROL + default y if SPL_OF_CONTROL + help + Some boards use device tree in U-Boot but only have 4KB of SRAM + which is not enough to support device tree. Enable this option to + allow such boards to be supported by U-Boot VPL. + config OF_LIVE bool "Enable use of a live tree" depends on DM && OF_CONTROL @@ -523,4 +532,12 @@ config TPL_OF_PLATDATA_DRIVER_RT
endif
+config VPL_OF_REAL + def_bool y + help + Indicates that a real devicetree is available which can be accessed + at runtime. This means that dev_read_...() functions can be used to + read data from the devicetree for each device. This is true if + TPL_OF_CONTROL is enabled and not TPL_OF_PLATDATA + endmenu diff --git a/lib/Kconfig b/lib/Kconfig index 3c6fa99b1a..3d67f7f578 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -90,6 +90,11 @@ config TPL_PRINTF select TPL_SPRINTF select TPL_STRTO if !TPL_USE_TINY_PRINTF
+config VPL_PRINTF + bool + select VPL_SPRINTF + select VPL_STRTO if !VPL_USE_TINY_PRINTF + config SPRINTF bool default y @@ -100,6 +105,9 @@ config SPL_SPRINTF config TPL_SPRINTF bool
+config VPL_SPRINTF + bool + config SSCANF bool
@@ -113,6 +121,9 @@ config SPL_STRTO config TPL_STRTO bool
+config VPL_STRTO + bool + config IMAGE_SPARSE bool
@@ -165,6 +176,17 @@ config TPL_USE_TINY_PRINTF
The supported format specifiers are %c, %s, %u/%d and %x.
+config VPL_USE_TINY_PRINTF + bool "Enable tiny printf() version for VPL" + depends on VPL + help + This option enables a tiny, stripped down printf version. + This should only be used in space limited environments, + like SPL versions with hard memory limits. This version + reduces the code size by about 2.5KiB on armv7. + + The supported format specifiers are %c, %s, %u/%d and %x. + config PANIC_HANG bool "Do not reset the system on fatal error" help @@ -371,6 +393,17 @@ config TPL_TPM for the low-level TPM interface, but only one TPM is supported at a time by the TPM library.
+config VPL_TPM + bool "Trusted Platform Module (TPM) Support in VPL" + depends on VPL_DM + help + This enables support for TPMs which can be used to provide security + features for your board. The TPM can be connected via LPC or I2C + and a sandbox TPM is provided for testing purposes. Use the 'tpm' + command to interactive the TPM. Driver model support is provided + for the low-level TPM interface, but only one TPM is supported at + a time by the TPM library. + endmenu
menu "Android Verified Boot" @@ -625,6 +658,12 @@ config SPL_LZMA help This enables support for LZMA compression algorithm for SPL boot.
+config VPL_LZMA + bool "Enable LZMA decompression support for VPL build" + default y if LZMA + help + This enables support for LZMA compression algorithm for VPL boot. + config SPL_LZO bool "Enable LZO decompression support in SPL" help @@ -704,6 +743,7 @@ config OF_LIBFDT_OVERLAY
config SPL_OF_LIBFDT bool "Enable the FDT library for SPL" + depends on SPL_LIBGENERIC_SUPPORT default y if SPL_OF_CONTROL help This enables the FDT library (libfdt). It provides functions for @@ -725,6 +765,7 @@ config SPL_OF_LIBFDT_ASSUME_MASK
config TPL_OF_LIBFDT bool "Enable the FDT library for TPL" + depends on TPL_LIBGENERIC_SUPPORT default y if TPL_OF_CONTROL help This enables the FDT library (libfdt). It provides functions for @@ -744,6 +785,27 @@ config TPL_OF_LIBFDT_ASSUME_MASK 0xff means all assumptions are made and any invalid data may cause unsafe execution. See FDT_ASSUME_PERFECT, etc. in libfdt_internal.h
+config VPL_OF_LIBFDT + bool "Enable the FDT library for VPL" + default y if VPL_OF_CONTROL && !VPL_OF_PLATDATA + help + This enables the FDT library (libfdt). It provides functions for + accessing binary device tree images in memory, such as adding and + removing nodes and properties, scanning through the tree and finding + particular compatible nodes. The library operates on a flattened + version of the device tree. + +config VPL_OF_LIBFDT_ASSUME_MASK + hex "Mask of conditions to assume for libfdt" + depends on VPL_OF_LIBFDT || FIT + default 0xff + help + Use this to change the assumptions made by libfdt in SPL about the + device tree it is working with. A value of 0 means that no assumptions + are made, and libfdt is able to deal with malicious data. A value of + 0xff means all assumptions are made and any invalid data may cause + unsafe execution. See FDT_ASSUME_PERFECT, etc. in libfdt_internal.h + config FDT_FIXUP_PARTITIONS bool "overwrite MTD partitions in DTS through defined in 'mtdparts'" depends on OF_LIBFDT
Add an initial VPL build for sandbox. This includes the flow:
TPL (with of-platdata) -> VPL -> SPL -> U-Boot
To run it:
./tpl/u-boot-tpl -D
The -D is needed to get the default device tree, which includes the serial console info.
Add a Makefile check for OF_HOSTFILE which is the option that enables devicetree control on sandbox.
Changes in v7: - Rebase to master - Update some options based on settings in master
Changes in v6: - Add docs for sandbox_vpl build - Drop TPL_HASH_SUPPORT patch since we only have SPL_HASH now
Changes in v4: - Add a sandbox_vpl build - Update cover letter
arch/sandbox/Kconfig | 8 ++ arch/sandbox/cpu/spl.c | 12 +- arch/sandbox/dts/sandbox.dtsi | 10 +- board/sandbox/MAINTAINERS | 7 + configs/sandbox_vpl_defconfig | 251 ++++++++++++++++++++++++++++++++++ doc/arch/sandbox.rst | 13 ++ lib/Kconfig | 2 +- 7 files changed, 295 insertions(+), 8 deletions(-) create mode 100644 configs/sandbox_vpl_defconfig
diff --git a/arch/sandbox/Kconfig b/arch/sandbox/Kconfig index 477c51960d..5f55c7f28e 100644 --- a/arch/sandbox/Kconfig +++ b/arch/sandbox/Kconfig @@ -29,6 +29,14 @@ config SANDBOX_SPL bool "Enable SPL for sandbox" select SUPPORT_SPL
+config SANDBOX_TPL + bool "Enable TPL for sandbox" + select SUPPORT_TPL + +config SANDBOX_VPL + bool "Enable VPL for sandbox" + select SUPPORT_VPL + config SYS_CONFIG_NAME default "sandbox_spl" if SANDBOX_SPL default "sandbox" if !SANDBOX_SPL diff --git a/arch/sandbox/cpu/spl.c b/arch/sandbox/cpu/spl.c index 650bdb0a70..2f1c06903c 100644 --- a/arch/sandbox/cpu/spl.c +++ b/arch/sandbox/cpu/spl.c @@ -31,13 +31,21 @@ int sandbox_find_next_phase(char *fname, int maxlen, bool use_img) return 0; }
-/* SPL / TPL init function */ +/* SPL / TPL / VPL init function */ void board_init_f(ulong flag) { struct sandbox_state *state = state_get_current(); + int ret;
gd->arch.ram_buf = state->ram_buf; gd->ram_size = state->ram_size; + + ret = spl_early_init(); + if (ret) { + debug("spl_early_init() failed: %d\n", ret); + hang(); + } + preloader_console_init(); }
u32 spl_boot_device(void) @@ -74,8 +82,6 @@ void spl_board_init(void) { struct sandbox_state *state = state_get_current();
- preloader_console_init(); - if (state->run_unittests) { struct unit_test *tests = UNIT_TEST_ALL_START(); const int count = UNIT_TEST_ALL_COUNT(); diff --git a/arch/sandbox/dts/sandbox.dtsi b/arch/sandbox/dts/sandbox.dtsi index 66b813faad..e900d07846 100644 --- a/arch/sandbox/dts/sandbox.dtsi +++ b/arch/sandbox/dts/sandbox.dtsi @@ -246,7 +246,7 @@ };
spl-test { - u-boot,dm-pre-reloc; + u-boot,dm-spl; compatible = "sandbox,spl-test"; boolval; intval = <1>; @@ -260,7 +260,7 @@ };
spl-test2 { - u-boot,dm-pre-reloc; + u-boot,dm-spl; compatible = "sandbox,spl-test"; intval = <3>; intarray = <5>; @@ -272,14 +272,14 @@ };
spl-test3 { - u-boot,dm-pre-reloc; + u-boot,dm-spl; compatible = "sandbox,spl-test"; stringarray = "one"; maybe-empty-int = <1>; };
spl-test5 { - u-boot,dm-tpl; + u-boot,dm-vpl; compatible = "sandbox,spl-test"; stringarray = "tpl"; }; @@ -326,6 +326,8 @@ /* Needs to be available prior to relocation */ uart0: serial { u-boot,dm-spl; + u-boot,dm-tpl; + u-boot,dm-vpl; compatible = "sandbox,serial"; sandbox,text-colour = "cyan"; pinctrl-names = "default"; diff --git a/board/sandbox/MAINTAINERS b/board/sandbox/MAINTAINERS index d32561cd1d..9f5073bf28 100644 --- a/board/sandbox/MAINTAINERS +++ b/board/sandbox/MAINTAINERS @@ -33,3 +33,10 @@ S: Maintained F: board/sandbox/ F: include/configs/sandbox.h F: configs/sandbox_flattree_defconfig + +SANDBOX VPL BOARD +M: Simon Glass sjg@chromium.org +S: Maintained +F: board/sandbox/ +F: include/configs/sandbox_spl.h +F: configs/sandbox_vpl_defconfig diff --git a/configs/sandbox_vpl_defconfig b/configs/sandbox_vpl_defconfig new file mode 100644 index 0000000000..3c582aec58 --- /dev/null +++ b/configs/sandbox_vpl_defconfig @@ -0,0 +1,251 @@ +CONFIG_SYS_TEXT_BASE=0x200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SYS_MEMTEST_START=0x00100000 +CONFIG_SYS_MEMTEST_END=0x00101000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="sandbox" +CONFIG_SPL_SERIAL=y +CONFIG_TPL_LIBCOMMON_SUPPORT=y +CONFIG_TPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SPL=y +CONFIG_BOOTSTAGE_STASH_ADDR=0x0 +CONFIG_SANDBOX_SPL=y +CONFIG_SANDBOX_TPL=y +CONFIG_SANDBOX_VPL=y +CONFIG_DEBUG_UART=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x0 +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_BOOTSTAGE=y +CONFIG_BOOTSTAGE_REPORT=y +CONFIG_BOOTSTAGE_FDT=y +CONFIG_BOOTSTAGE_STASH=y +CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_CONSOLE_RECORD=y +CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_F=y +CONFIG_HANDOFF=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_TPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_I2C=y +CONFIG_SPL_RTC=y +CONFIG_TPL=y +CONFIG_TPL_DRIVERS_MISC=y +CONFIG_TPL_ENV_SUPPORT=y +CONFIG_TPL_I2C=y +CONFIG_TPL_RTC=y +CONFIG_TPL_SERIAL=y +CONFIG_VPL=y +CONFIG_VPL_ENV_SUPPORT=y +CONFIG_CMD_CPU=y +CONFIG_CMD_LICENSE=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_BOOTEFI_HELLO=y +# CONFIG_CMD_ELF is not set +CONFIG_CMD_ASKENV=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_ERASEENV=y +CONFIG_CMD_ENV_CALLBACK=y +CONFIG_CMD_ENV_FLAGS=y +CONFIG_CMD_NVEDIT_INFO=y +CONFIG_CMD_NVEDIT_LOAD=y +CONFIG_CMD_NVEDIT_SELECT=y +CONFIG_LOOPW=y +CONFIG_CMD_MD5SUM=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_MX_CYCLIC=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_DEMO=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_IDE=y +CONFIG_CMD_I2C=y +CONFIG_CMD_OSD=y +CONFIG_CMD_PCI=y +CONFIG_CMD_REMOTEPROC=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_BOOTP_DNS2=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_TFTPSRV=y +CONFIG_CMD_RARP=y +CONFIG_CMD_CDP=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_BMP=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_TIME=y +CONFIG_CMD_TIMER=y +CONFIG_CMD_SOUND=y +CONFIG_CMD_BOOTSTAGE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_TPM=y +CONFIG_CMD_TPM_TEST=y +CONFIG_CMD_CBFS=y +CONFIG_CMD_CRAMFS=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_MAC_PARTITION=y +CONFIG_AMIGA_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_TPL_OF_CONTROL=y +CONFIG_OF_HOSTFILE=y +CONFIG_TPL_OF_PLATDATA=y +CONFIG_TPL_OF_PLATDATA_INST=y +CONFIG_ENV_IS_NOWHERE=y +CONFIG_ENV_IS_IN_EXT4=y +CONFIG_ENV_EXT4_INTERFACE="host" +CONFIG_ENV_EXT4_DEVICE_AND_PART="0:0" +CONFIG_BOOTP_SEND_HOSTNAME=y +CONFIG_NETCONSOLE=y +CONFIG_IP_DEFRAG=y +CONFIG_SPL_DM=y +CONFIG_TPL_DM=y +CONFIG_DM_DMA=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SYSCON=y +CONFIG_SPL_SYSCON=y +CONFIG_DEVRES=y +CONFIG_DEBUG_DEVRES=y +# CONFIG_SPL_SIMPLE_BUS is not set +CONFIG_ADC=y +CONFIG_ADC_SANDBOX=y +CONFIG_SYS_SATA_MAX_DEVICE=2 +CONFIG_AXI=y +CONFIG_AXI_SANDBOX=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_TPL_CLK=y +CONFIG_CPU=y +CONFIG_DM_DEMO=y +CONFIG_DM_DEMO_SIMPLE=y +CONFIG_DM_DEMO_SHAPE=y +CONFIG_SPL_FIRMWARE=y +CONFIG_GPIO_HOG=y +CONFIG_PM8916_GPIO=y +CONFIG_SANDBOX_GPIO=y +CONFIG_I2C_CROS_EC_TUNNEL=y +CONFIG_I2C_CROS_EC_LDO=y +CONFIG_DM_I2C_GPIO=y +CONFIG_SYS_I2C_SANDBOX=y +CONFIG_I2C_MUX=y +CONFIG_I2C_ARB_GPIO_CHALLENGE=y +CONFIG_CROS_EC_KEYB=y +CONFIG_I8042_KEYB=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_DM_MAILBOX=y +CONFIG_SANDBOX_MBOX=y +CONFIG_MISC=y +CONFIG_TPL_MISC=y +CONFIG_CROS_EC=y +CONFIG_CROS_EC_I2C=y +CONFIG_CROS_EC_LPC=y +CONFIG_CROS_EC_SANDBOX=y +CONFIG_CROS_EC_SPI=y +CONFIG_P2SB=y +CONFIG_PWRSEQ=y +CONFIG_SPL_PWRSEQ=y +CONFIG_MMC_SANDBOX=y +CONFIG_SPI_FLASH_SANDBOX=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_DM_ETH=y +CONFIG_NVME=y +CONFIG_PCI=y +CONFIG_PCI_SANDBOX=y +CONFIG_PHY=y +CONFIG_PHY_SANDBOX=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y +CONFIG_PINCTRL_SANDBOX=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_ACT8846=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_PMIC_MAX77686=y +CONFIG_DM_PMIC_MC34708=y +CONFIG_PMIC_PM8916=y +CONFIG_PMIC_RK8XX=y +CONFIG_PMIC_S2MPS11=y +CONFIG_DM_PMIC_SANDBOX=y +CONFIG_PMIC_S5M8767=y +CONFIG_PMIC_TPS65090=y +CONFIG_DM_REGULATOR=y +CONFIG_REGULATOR_ACT8846=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_MAX77686=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_REGULATOR_S5M8767=y +CONFIG_DM_REGULATOR_SANDBOX=y +CONFIG_REGULATOR_TPS65090=y +CONFIG_DM_PWM=y +CONFIG_PWM_CROS_EC=y +CONFIG_PWM_SANDBOX=y +CONFIG_RAM=y +CONFIG_REMOTEPROC_SANDBOX=y +CONFIG_DM_RESET=y +CONFIG_SANDBOX_RESET=y +CONFIG_DM_RTC=y +CONFIG_SPL_DM_RTC=y +CONFIG_TPL_DM_RTC=y +CONFIG_SANDBOX_SERIAL=y +CONFIG_SOUND=y +CONFIG_SOUND_SANDBOX=y +CONFIG_SOC_DEVICE=y +CONFIG_SANDBOX_SPI=y +CONFIG_SPMI=y +CONFIG_SPMI_SANDBOX=y +CONFIG_SYSINFO=y +CONFIG_SYSINFO_SANDBOX=y +CONFIG_SYSINFO_GPIO=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_TPL_SYSRESET=y +CONFIG_TIMER=y +CONFIG_TIMER_EARLY=y +CONFIG_SANDBOX_TIMER=y +CONFIG_USB=y +CONFIG_USB_EMUL=y +CONFIG_USB_KEYBOARD=y +CONFIG_DM_VIDEO=y +CONFIG_CONSOLE_ROTATION=y +CONFIG_CONSOLE_TRUETYPE=y +CONFIG_CONSOLE_TRUETYPE_CANTORAONE=y +CONFIG_VIDEO_SANDBOX_SDL=y +CONFIG_OSD=y +CONFIG_SANDBOX_OSD=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_VIDEO_BMP_RLE8=y +CONFIG_FS_CBFS=y +CONFIG_FS_CRAMFS=y +# CONFIG_SPL_USE_TINY_PRINTF is not set +CONFIG_CMD_DHRYSTONE=y +CONFIG_RSA_VERIFY_WITH_PKEY=y +CONFIG_TPM=y +CONFIG_LZ4=y +CONFIG_ERRNO_STR=y +CONFIG_UNIT_TEST=y +CONFIG_SPL_UNIT_TEST=y +CONFIG_UT_TIME=y +CONFIG_UT_DM=y diff --git a/doc/arch/sandbox.rst b/doc/arch/sandbox.rst index f8804e1f41..e2e7147629 100644 --- a/doc/arch/sandbox.rst +++ b/doc/arch/sandbox.rst @@ -420,6 +420,19 @@ state_setprop() which does this automatically and avoids running out of space. See existing code for examples.
+VPL (Verifying Program Loader) +------------------------------ + +Sandbox provides an example build of vpl called `sandbox_vpl`. This can be run +using:: + + /path/to/sandbox_vpl/tpl/u-boot-tpl -D + +It starts up TPL (first-stage init), then VPL, then runs SPL and finally U-Boot +proper, following the normal flow for a verified boot. At present, no +verification is actually implemented. + + Debugging the init sequence ---------------------------
diff --git a/lib/Kconfig b/lib/Kconfig index 3d67f7f578..38743e6a1a 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -35,7 +35,7 @@ config BCH config BINMAN_FDT bool "Allow access to binman information in the device tree" depends on BINMAN && DM && OF_CONTROL - default y if OF_SEPARATE || OF_EMBED + default y if OF_SEPARATE || OF_EMBED || OF_HOSTFILE help This enables U-Boot to access information about binman entries, stored in the device tree in a binman node. Typical uses are to
AKASHI Takahiro
