[U-Boot] [PATCH v2 00/10] rockchip: enable board_debug_uart_init for all soc
ALl rockchip soc use DEBUG UART, and need init the uart iomux in board_debug_uart_init(). Move the board_debug_uart_init() into soc file so that we can make all soc config in soc file and share a common board file later for all rockchip SoCs.
Verison 2 rebase on master with 'SYS_SOC name correction' patch set. This patchset has been test on: rk3036, rk3188, rk3229, rk3288, rk3328, rk3368, rk3399, rv1108
Kever Yang (10): rockchip: enable DEBUG_UART_BOARD_INIT by default rockchip; kylin-rk3036: enabl DEBUG UART rockchip: rk3036: add board_debug_uart_init() rockchip: rk3188: add board_debug_uart_init() rockchip: rk322x: move board_debug_uart_init() to rk322x.c rockchip: rk3288: use grf structure to access soc_con2 rockchip: rk3288: add board_debug_uart_init() rockchip: rk3368: move board_debug_uart_init() to rk3368.c rockchip: rk3399: use grf structure to access reg rockchip: rk3399: add board_debug_uart_init()
arch/arm/Kconfig | 1 + arch/arm/mach-rockchip/Kconfig | 4 -- arch/arm/mach-rockchip/rk3036-board-spl.c | 20 +-------- arch/arm/mach-rockchip/rk3036/Makefile | 1 + arch/arm/mach-rockchip/rk3036/rk3036.c | 39 ++++++++++++++++ arch/arm/mach-rockchip/rk3188-board-spl.c | 28 +----------- arch/arm/mach-rockchip/rk3188/Makefile | 1 + arch/arm/mach-rockchip/rk3188/rk3188.c | 36 +++++++++++++++ arch/arm/mach-rockchip/rk322x-board-spl.c | 44 +----------------- arch/arm/mach-rockchip/rk322x-board.c | 30 +------------ arch/arm/mach-rockchip/rk322x/Makefile | 2 +- arch/arm/mach-rockchip/rk322x/rk322x.c | 44 ++++++++++++++++++ arch/arm/mach-rockchip/rk3288-board-spl.c | 12 +---- arch/arm/mach-rockchip/rk3288-board-tpl.c | 16 +------ arch/arm/mach-rockchip/rk3288/rk3288.c | 19 +++++++- arch/arm/mach-rockchip/rk3368-board-spl.c | 8 ---- arch/arm/mach-rockchip/rk3368-board-tpl.c | 33 +------------- arch/arm/mach-rockchip/rk3368/rk3368.c | 31 +++++++++++++ arch/arm/mach-rockchip/rk3399-board-spl.c | 50 +-------------------- arch/arm/mach-rockchip/rk3399/rk3399.c | 55 ++++++++++++++++++++++- configs/kylin-rk3036_defconfig | 4 ++ 21 files changed, 240 insertions(+), 238 deletions(-) create mode 100644 arch/arm/mach-rockchip/rk3036/rk3036.c create mode 100644 arch/arm/mach-rockchip/rk3188/rk3188.c create mode 100644 arch/arm/mach-rockchip/rk322x/rk322x.c
All Rockchip SoCs use DEBUG_UART_BOARD_INIT to init per board UART IOMUX, enable it by default.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/Kconfig | 1 + arch/arm/mach-rockchip/Kconfig | 4 ---- 2 files changed, 1 insertion(+), 4 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f42eccef80..a5851aeeae 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1432,6 +1432,7 @@ config ARCH_ROCKCHIP select SYS_THUMB_BUILD if !ARM64 imply ADC imply CMD_DM + imply DEBUG_UART_BOARD_INIT imply DISTRO_DEFAULTS imply FAT_WRITE imply SARADC_ROCKCHIP diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 7e5a73f92c..17b3b9372d 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -34,7 +34,6 @@ config ROCKCHIP_RK3188 select SPL_RAM select SPL_DRIVERS_MISC_SUPPORT select SPL_ROCKCHIP_EARLYRETURN_TO_BROM - select DEBUG_UART_BOARD_INIT select BOARD_LATE_INIT select ROCKCHIP_BROM_HELPER help @@ -50,7 +49,6 @@ config ROCKCHIP_RK322X select SUPPORT_SPL select SPL select ROCKCHIP_BROM_HELPER - select DEBUG_UART_BOARD_INIT help The Rockchip RK3229 is a ARM-based SoC with a dual-core Cortex-A7 including NEON and GPU, Mali-400 graphics, several DDR3 options @@ -102,7 +100,6 @@ config ROCKCHIP_RK3368 imply SPL_SEPARATE_BSS imply SPL_SERIAL_SUPPORT imply TPL_SERIAL_SUPPORT - select DEBUG_UART_BOARD_INIT help The Rockchip RK3368 is a ARM-based SoC with a octa-core (organised into a big and little cluster with 4 cores each) Cortex-A53 including @@ -135,7 +132,6 @@ config ROCKCHIP_RK3399 select SPL_SEPARATE_BSS select SPL_SERIAL_SUPPORT select SPL_DRIVERS_MISC_SUPPORT - select DEBUG_UART_BOARD_INIT select BOARD_LATE_INIT select ROCKCHIP_BROM_HELPER help
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Enable debug uart for kylin board in defconfig.
configs/kylin-rk3036_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index d6d5abb2b6..fca3c238f7 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -7,7 +7,10 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_ROCKCHIP_RK3036=y CONFIG_TARGET_KYLIN_RK3036=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x0 +CONFIG_DEBUG_UART_BASE=0x20068000 +CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_STACK_R_ADDR=0x80000 +CONFIG_DEBUG_UART=y CONFIG_NR_DRAM_BANKS=1 # CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rk3036-kylin.dtb" @@ -44,6 +47,7 @@ CONFIG_SPI_FLASH=y CONFIG_PINCTRL=y CONFIG_DM_REGULATOR_FIXED=y # CONFIG_SPL_DM_SERIAL is not set +CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_DWC2=y
Use board_debug_uart_init() for UART iomux init instead of do it in board_init_f, and move the function to soc file so that we can find all the soc/board setting in soc file and use a common board file.
arch/arm/mach-rockchip/rk3036-board-spl.c | 20 +----------- arch/arm/mach-rockchip/rk3036/Makefile | 1 + arch/arm/mach-rockchip/rk3036/rk3036.c | 39 +++++++++++++++++++++++ 3 files changed, 41 insertions(+), 19 deletions(-) create mode 100644 arch/arm/mach-rockchip/rk3036/rk3036.c
diff --git a/arch/arm/mach-rockchip/rk3036-board-spl.c b/arch/arm/mach-rockchip/rk3036-board-spl.c index b897ffeae2..110d06dba5 100644 --- a/arch/arm/mach-rockchip/rk3036-board-spl.c +++ b/arch/arm/mach-rockchip/rk3036-board-spl.c @@ -7,30 +7,12 @@ #include <debug_uart.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> -#include <asm/arch-rockchip/grf_rk3036.h> -#include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/sdram_rk3036.h> #include <asm/arch-rockchip/timer.h> -#include <asm/arch-rockchip/uart.h> - -#define GRF_BASE 0x20008000 - -#define DEBUG_UART_BASE 0x20068000
void board_init_f(ulong dummy) { -#ifdef EARLY_DEBUG - struct rk3036_grf * const grf = (void *)GRF_BASE; - /* - * NOTE: sd card and debug uart use same iomux in rk3036, - * so if you enable uart, - * you can not boot from sdcard - */ - rk_clrsetreg(&grf->gpio1c_iomux, - GPIO1C3_MASK << GPIO1C3_SHIFT | - GPIO1C2_MASK << GPIO1C2_SHIFT, - GPIO1C3_UART2_SOUT << GPIO1C3_SHIFT | - GPIO1C2_UART2_SIN << GPIO1C2_SHIFT); +#ifdef CONFIG_DEBUG_UART debug_uart_init(); #endif rockchip_timer_init(); diff --git a/arch/arm/mach-rockchip/rk3036/Makefile b/arch/arm/mach-rockchip/rk3036/Makefile index 20d28f7c21..299fc50635 100644 --- a/arch/arm/mach-rockchip/rk3036/Makefile +++ b/arch/arm/mach-rockchip/rk3036/Makefile @@ -10,4 +10,5 @@ ifndef CONFIG_SPL_BUILD obj-y += syscon_rk3036.o endif
+obj-y += rk3036.o obj-y += sdram_rk3036.o diff --git a/arch/arm/mach-rockchip/rk3036/rk3036.c b/arch/arm/mach-rockchip/rk3036/rk3036.c new file mode 100644 index 0000000000..32426ac840 --- /dev/null +++ b/arch/arm/mach-rockchip/rk3036/rk3036.c @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + */ +#include <asm/io.h> +#include <asm/arch-rockchip/grf_rk3036.h> +#include <asm/arch-rockchip/hardware.h> + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ +#define GRF_BASE 0x20008000 + struct rk3036_grf * const grf = (void *)GRF_BASE; + enum { + GPIO1C3_SHIFT = 6, + GPIO1C3_MASK = 3 << GPIO1C3_SHIFT, + GPIO1C3_GPIO = 0, + GPIO1C3_MMC0_D1, + GPIO1C3_UART2_SOUT, + + GPIO1C2_SHIFT = 4, + GPIO1C2_MASK = 3 << GPIO1C2_SHIFT, + GPIO1C2_GPIO = 0, + GPIO1C2_MMC0_D0, + GPIO1C2_UART2_SIN, + }; + /* + * NOTE: sd card and debug uart use same iomux in rk3036, + * so if you enable uart, + * you can not boot from sdcard + */ + rk_clrsetreg(&grf->gpio1c_iomux, + GPIO1C3_MASK << GPIO1C3_SHIFT | + GPIO1C2_MASK << GPIO1C2_SHIFT, + GPIO1C3_UART2_SOUT << GPIO1C3_SHIFT | + GPIO1C2_UART2_SIN << GPIO1C2_SHIFT); +} +#endif +
- (C) Copyright 2019 Rockchip Electronics Co., Ltd
- enum {
GPIO1C3_SHIFT = 6,
GPIO1C3_GPIO = 0,
GPIO1C3_MMC0_D1,
GPIO1C3_UART2_SOUT,
GPIO1C2_SHIFT = 4,
GPIO1C2_GPIO = 0,
GPIO1C2_MMC0_D0,
GPIO1C2_UART2_SIN,
Would it be better to put this enum in the grf_rk3036.h header file as is done on the rk3288 to keep some consistency and have a central place where these defines are kept? Same for the other patches where the enums are defined in place.
+} +#endif
Hi Jack,
- enum {
GPIO1C3_SHIFT = 6,
GPIO1C3_GPIO = 0,
GPIO1C3_MMC0_D1,
GPIO1C3_UART2_SOUT,
GPIO1C2_SHIFT = 4,
GPIO1C2_GPIO = 0,
GPIO1C2_MMC0_D0,
GPIO1C2_UART2_SIN,
Thanks for your comment, but this kind of style is recommend by the maintainer, so maybe the rk3288 is the one need to update.
Thanks, - Kever
+} +#endif
arch/arm/mach-rockchip/rk3188-board-spl.c | 28 +----------------- arch/arm/mach-rockchip/rk3188/Makefile | 1 + arch/arm/mach-rockchip/rk3188/rk3188.c | 36 +++++++++++++++++++++++ 3 files changed, 38 insertions(+), 27 deletions(-) create mode 100644 arch/arm/mach-rockchip/rk3188/rk3188.c
diff --git a/arch/arm/mach-rockchip/rk3188-board-spl.c b/arch/arm/mach-rockchip/rk3188-board-spl.c index 230d69c4c1..77b9b36d35 100644 --- a/arch/arm/mach-rockchip/rk3188-board-spl.c +++ b/arch/arm/mach-rockchip/rk3188-board-spl.c @@ -93,38 +93,12 @@ static int setup_arm_clock(void) return ret; }
-void board_debug_uart_init(void) -{ - /* Enable early UART on the RK3188 */ -#define GRF_BASE 0x20008000 - struct rk3188_grf * const grf = (void *)GRF_BASE; - enum { - GPIO1B1_SHIFT = 2, - GPIO1B1_MASK = 3, - GPIO1B1_GPIO = 0, - GPIO1B1_UART2_SOUT, - - GPIO1B0_SHIFT = 0, - GPIO1B0_MASK = 3, - GPIO1B0_GPIO = 0, - GPIO1B0_UART2_SIN, - }; - - /* Enable early UART on the RK3188 */ - rk_clrsetreg(&grf->gpio1b_iomux, - GPIO1B1_MASK << GPIO1B1_SHIFT | - GPIO1B0_MASK << GPIO1B0_SHIFT, - GPIO1B1_UART2_SOUT << GPIO1B1_SHIFT | - GPIO1B0_UART2_SIN << GPIO1B0_SHIFT); -} - void board_init_f(ulong dummy) { struct udevice *dev; int ret;
-#define EARLY_UART -#ifdef EARLY_UART +#ifdef CONFIG_DEBUG_UART /* * Debug UART can be used from here if required: * diff --git a/arch/arm/mach-rockchip/rk3188/Makefile b/arch/arm/mach-rockchip/rk3188/Makefile index 7fa010405b..7dc123a3d2 100644 --- a/arch/arm/mach-rockchip/rk3188/Makefile +++ b/arch/arm/mach-rockchip/rk3188/Makefile @@ -6,5 +6,6 @@
ifndef CONFIG_TPL_BUILD obj-y += clk_rk3188.o +obj-y += rk3188.o obj-y += syscon_rk3188.o endif diff --git a/arch/arm/mach-rockchip/rk3188/rk3188.c b/arch/arm/mach-rockchip/rk3188/rk3188.c new file mode 100644 index 0000000000..933484e0df --- /dev/null +++ b/arch/arm/mach-rockchip/rk3188/rk3188.c @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch-rockchip/grf_rk3188.h> +#include <asm/arch-rockchip/hardware.h> + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ + /* Enable early UART on the RK3188 */ +#define GRF_BASE 0x20008000 + struct rk3188_grf * const grf = (void *)GRF_BASE; + enum { + GPIO1B1_SHIFT = 2, + GPIO1B1_MASK = 3, + GPIO1B1_GPIO = 0, + GPIO1B1_UART2_SOUT, + GPIO1B1_JTAG_TDO, + + GPIO1B0_SHIFT = 0, + GPIO1B0_MASK = 3, + GPIO1B0_GPIO = 0, + GPIO1B0_UART2_SIN, + GPIO1B0_JTAG_TDI, + }; + + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK << GPIO1B1_SHIFT | + GPIO1B0_MASK << GPIO1B0_SHIFT, + GPIO1B1_UART2_SOUT << GPIO1B1_SHIFT | + GPIO1B0_UART2_SIN << GPIO1B0_SHIFT); +} +#endif
Move the function to soc file so that we can find all the soc/board setting in soc file and use a common board file later for all rockchip SoCs.
arch/arm/mach-rockchip/rk322x-board-spl.c | 44 ++--------------------- arch/arm/mach-rockchip/rk322x-board.c | 30 +--------------- arch/arm/mach-rockchip/rk322x/Makefile | 2 +- arch/arm/mach-rockchip/rk322x/rk322x.c | 44 +++++++++++++++++++++++ 4 files changed, 48 insertions(+), 72 deletions(-) create mode 100644 arch/arm/mach-rockchip/rk322x/rk322x.c
diff --git a/arch/arm/mach-rockchip/rk322x-board-spl.c b/arch/arm/mach-rockchip/rk322x-board-spl.c index c50130c3b5..888310efbe 100644 --- a/arch/arm/mach-rockchip/rk322x-board-spl.c +++ b/arch/arm/mach-rockchip/rk322x-board-spl.c @@ -10,54 +10,13 @@ #include <spl.h> #include <asm/io.h> #include <asm/arch-rockchip/bootrom.h> -#include <asm/arch-rockchip/cru_rk322x.h> -#include <asm/arch-rockchip/grf_rk322x.h> #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/timer.h> -#include <asm/arch-rockchip/uart.h>
u32 spl_boot_device(void) { return BOOT_DEVICE_MMC1; } -#define GRF_BASE 0x11000000 -#define SGRF_BASE 0x10140000 - -#define DEBUG_UART_BASE 0x11030000 - -void board_debug_uart_init(void) -{ - static struct rk322x_grf * const grf = (void *)GRF_BASE; - enum { - GPIO1B2_SHIFT = 4, - GPIO1B2_MASK = 3 << GPIO1B2_SHIFT, - GPIO1B2_GPIO = 0, - GPIO1B2_UART1_SIN, - GPIO1B2_UART21_SIN, - - GPIO1B1_SHIFT = 2, - GPIO1B1_MASK = 3 << GPIO1B1_SHIFT, - GPIO1B1_GPIO = 0, - GPIO1B1_UART1_SOUT, - GPIO1B1_UART21_SOUT, - }; - enum { - CON_IOMUX_UART2SEL_SHIFT= 8, - CON_IOMUX_UART2SEL_MASK = 1 << CON_IOMUX_UART2SEL_SHIFT, - CON_IOMUX_UART2SEL_2 = 0, - CON_IOMUX_UART2SEL_21, - }; - - /* Enable early UART2 channel 1 on the RK322x */ - rk_clrsetreg(&grf->gpio1b_iomux, - GPIO1B1_MASK | GPIO1B2_MASK, - GPIO1B2_UART21_SIN << GPIO1B2_SHIFT | - GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT); - /* Set channel C as UART2 input */ - rk_clrsetreg(&grf->con_iomux, - CON_IOMUX_UART2SEL_MASK, - CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); -}
#define SGRF_DDR_CON0 0x10150000 void board_init_f(ulong dummy) @@ -65,6 +24,7 @@ void board_init_f(ulong dummy) struct udevice *dev; int ret;
+#ifdef CONFIG_DEBUG_UART /* * Debug UART can be used from here if required: * @@ -75,7 +35,7 @@ void board_init_f(ulong dummy) */ debug_uart_init(); printascii("SPL Init"); - +#endif ret = spl_early_init(); if (ret) { debug("spl_early_init() failed: %d\n", ret); diff --git a/arch/arm/mach-rockchip/rk322x-board.c b/arch/arm/mach-rockchip/rk322x-board.c index 9aad6bb0bc..d24f7c959d 100644 --- a/arch/arm/mach-rockchip/rk322x-board.c +++ b/arch/arm/mach-rockchip/rk322x-board.c @@ -11,7 +11,6 @@ #include <asm/arch-rockchip/boot_mode.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/periph.h> -#include <asm/arch-rockchip/grf_rk322x.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -32,34 +31,7 @@ int board_init(void) #include <asm/arch-rockchip/grf_rk322x.h> /* Enable early UART2 channel 1 on the RK322x */ #define GRF_BASE 0x11000000 - struct rk322x_grf * const grf = (void *)GRF_BASE; - enum { - GPIO1B2_SHIFT = 4, - GPIO1B2_MASK = 3 << GPIO1B2_SHIFT, - GPIO1B2_GPIO = 0, - GPIO1B2_UART21_SIN, - - GPIO1B1_SHIFT = 2, - GPIO1B1_MASK = 3 << GPIO1B1_SHIFT, - GPIO1B1_GPIO = 0, - GPIO1B1_UART1_SOUT, - GPIO1B1_UART21_SOUT, - }; - enum { - CON_IOMUX_UART2SEL_SHIFT= 8, - CON_IOMUX_UART2SEL_MASK = 1 << CON_IOMUX_UART2SEL_SHIFT, - CON_IOMUX_UART2SEL_2 = 0, - CON_IOMUX_UART2SEL_21, - }; - - rk_clrsetreg(&grf->gpio1b_iomux, - GPIO1B1_MASK | GPIO1B2_MASK, - GPIO1B2_UART21_SIN << GPIO1B2_SHIFT | - GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT); - /* Set channel C as UART2 input */ - rk_clrsetreg(&grf->con_iomux, - CON_IOMUX_UART2SEL_MASK, - CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); + static struct rk322x_grf * const grf = (void *)GRF_BASE;
/* * The integrated macphy is enabled by default, disable it diff --git a/arch/arm/mach-rockchip/rk322x/Makefile b/arch/arm/mach-rockchip/rk322x/Makefile index ecb3e8dfda..89b0fed692 100644 --- a/arch/arm/mach-rockchip/rk322x/Makefile +++ b/arch/arm/mach-rockchip/rk322x/Makefile @@ -4,6 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
- obj-y += clk_rk322x.o +obj-y += rk322x.o obj-y += syscon_rk322x.o diff --git a/arch/arm/mach-rockchip/rk322x/rk322x.c b/arch/arm/mach-rockchip/rk322x/rk322x.c new file mode 100644 index 0000000000..e5250bc784 --- /dev/null +++ b/arch/arm/mach-rockchip/rk322x/rk322x.c @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + */ +#include <asm/io.h> +#include <asm/arch-rockchip/grf_rk322x.h> +#include <asm/arch-rockchip/hardware.h> + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ +#define GRF_BASE 0x11000000 + static struct rk322x_grf * const grf = (void *)GRF_BASE; + enum { + GPIO1B2_SHIFT = 4, + GPIO1B2_MASK = 3 << GPIO1B2_SHIFT, + GPIO1B2_GPIO = 0, + GPIO1B2_UART1_SIN, + GPIO1B2_UART21_SIN, + + GPIO1B1_SHIFT = 2, + GPIO1B1_MASK = 3 << GPIO1B1_SHIFT, + GPIO1B1_GPIO = 0, + GPIO1B1_UART1_SOUT, + GPIO1B1_UART21_SOUT, + }; + enum { + CON_IOMUX_UART2SEL_SHIFT = 8, + CON_IOMUX_UART2SEL_MASK = 1 << CON_IOMUX_UART2SEL_SHIFT, + CON_IOMUX_UART2SEL_2 = 0, + CON_IOMUX_UART2SEL_21, + }; + + /* Enable early UART2 channel 1 on the RK322x */ + rk_clrsetreg(&grf->gpio1b_iomux, + GPIO1B1_MASK | GPIO1B2_MASK, + GPIO1B2_UART21_SIN << GPIO1B2_SHIFT | + GPIO1B1_UART21_SOUT << GPIO1B1_SHIFT); + /* Set channel C as UART2 input */ + rk_clrsetreg(&grf->con_iomux, + CON_IOMUX_UART2SEL_MASK, + CON_IOMUX_UART2SEL_21 << CON_IOMUX_UART2SEL_SHIFT); +} +#endif
Prefer to use structure to access register if we can.
arch/arm/mach-rockchip/rk3288/rk3288.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index af3a465cc3..987fae544c 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -4,15 +4,17 @@ */ #include <asm/io.h> #include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/grf_rk3288.h>
-#define GRF_SOC_CON2 0xff77024c +#define GRF_BASE 0xff770000
int arch_cpu_init(void) { /* We do some SoC one time setting here. */ + struct rk3288_grf * const grf = (void *)GRF_BASE;
/* Use rkpwm by default */ - rk_setreg(GRF_SOC_CON2, 1 << 0); + rk_setreg(&grf->soc_con2, 1 << 0);
return 0; }
Use board_debug_uart_init() for UART iomux init instead of do it in board_init_f, and move the function to soc file so that we can find all the soc/board setting in soc file and use a common board file for all rockchip SoCs later.
arch/arm/mach-rockchip/rk3288-board-spl.c | 12 ++---------- arch/arm/mach-rockchip/rk3288-board-tpl.c | 16 ++-------------- arch/arm/mach-rockchip/rk3288/rk3288.c | 13 +++++++++++++ 3 files changed, 17 insertions(+), 24 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3288-board-spl.c b/arch/arm/mach-rockchip/rk3288-board-spl.c index 937a99db53..d8d215db8a 100644 --- a/arch/arm/mach-rockchip/rk3288-board-spl.c +++ b/arch/arm/mach-rockchip/rk3288-board-spl.c @@ -109,16 +109,7 @@ void board_init_f(ulong dummy) struct udevice *dev; int ret;
- /* Example code showing how to enable the debug UART on RK3288 */ -#include <asm/arch-rockchip/grf_rk3288.h> - /* Enable early UART on the RK3288 */ -#define GRF_BASE 0xff770000 - struct rk3288_grf * const grf = (void *)GRF_BASE; - - rk_clrsetreg(&grf->gpio7ch_iomux, GPIO7C7_MASK << GPIO7C7_SHIFT | - GPIO7C6_MASK << GPIO7C6_SHIFT, - GPIO7C7_UART2DBG_SOUT << GPIO7C7_SHIFT | - GPIO7C6_UART2DBG_SIN << GPIO7C6_SHIFT); +#ifdef CONFIG_DEBUG_UART /* * Debug UART can be used from here if required: * @@ -129,6 +120,7 @@ void board_init_f(ulong dummy) */ debug_uart_init(); debug("\nspl:debug uart enabled in %s\n", __func__); +#endif ret = spl_early_init(); if (ret) { debug("spl_early_init() failed: %d\n", ret); diff --git a/arch/arm/mach-rockchip/rk3288-board-tpl.c b/arch/arm/mach-rockchip/rk3288-board-tpl.c index a430bb43ad..a9848067ba 100644 --- a/arch/arm/mach-rockchip/rk3288-board-tpl.c +++ b/arch/arm/mach-rockchip/rk3288-board-tpl.c @@ -10,28 +10,16 @@ #include <spl.h> #include <version.h> #include <asm/io.h> -#include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> -#include <asm/arch-rockchip/grf_rk3288.h> -#include <asm/arch-rockchip/periph.h> -#include <asm/arch-rockchip/pmu_rk3288.h> #include <asm/arch-rockchip/sys_proto.h> #include <asm/arch-rockchip/timer.h>
-#define GRF_BASE 0xff770000 void board_init_f(ulong dummy) { struct udevice *dev; int ret;
- /* Example code showing how to enable the debug UART on RK3288 */ - /* Enable early UART on the RK3288 */ - struct rk3288_grf * const grf = (void *)GRF_BASE; - - rk_clrsetreg(&grf->gpio7ch_iomux, GPIO7C7_MASK << GPIO7C7_SHIFT | - GPIO7C6_MASK << GPIO7C6_SHIFT, - GPIO7C7_UART2DBG_SOUT << GPIO7C7_SHIFT | - GPIO7C6_UART2DBG_SIN << GPIO7C6_SHIFT); +#ifdef CONFIG_DEBUG_UART /* * Debug UART can be used from here if required: * @@ -41,7 +29,7 @@ void board_init_f(ulong dummy) * printascii("string"); */ debug_uart_init(); - +#endif ret = spl_early_init(); if (ret) { debug("spl_early_init() failed: %d\n", ret); diff --git a/arch/arm/mach-rockchip/rk3288/rk3288.c b/arch/arm/mach-rockchip/rk3288/rk3288.c index 987fae544c..7941ca68a6 100644 --- a/arch/arm/mach-rockchip/rk3288/rk3288.c +++ b/arch/arm/mach-rockchip/rk3288/rk3288.c @@ -18,3 +18,16 @@ int arch_cpu_init(void)
return 0; } + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ + /* Enable early UART on the RK3288 */ + struct rk3288_grf * const grf = (void *)GRF_BASE; + + rk_clrsetreg(&grf->gpio7ch_iomux, GPIO7C7_MASK << GPIO7C7_SHIFT | + GPIO7C6_MASK << GPIO7C6_SHIFT, + GPIO7C7_UART2DBG_SOUT << GPIO7C7_SHIFT | + GPIO7C6_UART2DBG_SIN << GPIO7C6_SHIFT); +} +#endif
arch/arm/mach-rockchip/rk3368-board-spl.c | 8 ------ arch/arm/mach-rockchip/rk3368-board-tpl.c | 33 +---------------------- arch/arm/mach-rockchip/rk3368/rk3368.c | 31 +++++++++++++++++++++ 3 files changed, 32 insertions(+), 40 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3368-board-spl.c b/arch/arm/mach-rockchip/rk3368-board-spl.c index 9dea4ed994..b055ed4aee 100644 --- a/arch/arm/mach-rockchip/rk3368-board-spl.c +++ b/arch/arm/mach-rockchip/rk3368-board-spl.c @@ -9,17 +9,9 @@ #include <ram.h> #include <spl.h> #include <asm/io.h> -#include <asm/arch-rockchip/cru_rk3368.h> -#include <asm/arch-rockchip/grf_rk3368.h> -#include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/periph.h> -#include <asm/arch-rockchip/timer.h> #include <dm/pinctrl.h>
-void board_debug_uart_init(void) -{ -} - void board_init_f(ulong dummy) { struct udevice *pinctrl; diff --git a/arch/arm/mach-rockchip/rk3368-board-tpl.c b/arch/arm/mach-rockchip/rk3368-board-tpl.c index 373f009414..dc65a021c8 100644 --- a/arch/arm/mach-rockchip/rk3368-board-tpl.c +++ b/arch/arm/mach-rockchip/rk3368-board-tpl.c @@ -13,7 +13,6 @@ #include <asm/arch-rockchip/bootrom.h> #include <asm/arch-rockchip/clock.h> #include <asm/arch-rockchip/cru_rk3368.h> -#include <asm/arch-rockchip/grf_rk3368.h> #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/timer.h>
@@ -79,42 +78,12 @@ static void sgrf_init(void) rk_clrreg(&cru->softrst_con[4], DMA2_SRST_REQ); }
-void board_debug_uart_init(void) -{ - /* - * N.B.: This is called before the device-model has been - * initialised. For this reason, we can not access - * the GRF address range using the syscon API. - */ - struct rk3368_grf * const grf = - (struct rk3368_grf * const)0xff770000; - - enum { - GPIO2D1_MASK = GENMASK(3, 2), - GPIO2D1_GPIO = 0, - GPIO2D1_UART0_SOUT = (1 << 2), - - GPIO2D0_MASK = GENMASK(1, 0), - GPIO2D0_GPIO = 0, - GPIO2D0_UART0_SIN = (1 << 0), - }; - -#if defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff180000) - /* Enable early UART0 on the RK3368 */ - rk_clrsetreg(&grf->gpio2d_iomux, - GPIO2D0_MASK, GPIO2D0_UART0_SIN); - rk_clrsetreg(&grf->gpio2d_iomux, - GPIO2D1_MASK, GPIO2D1_UART0_SOUT); -#endif -} - void board_init_f(ulong dummy) { struct udevice *dev; int ret;
-#define EARLY_UART -#ifdef EARLY_UART +#ifdef CONFIG_DEBUG_UART /* * Debug UART can be used from here if required: * diff --git a/arch/arm/mach-rockchip/rk3368/rk3368.c b/arch/arm/mach-rockchip/rk3368/rk3368.c index 197f0c485a..1ed06c5352 100644 --- a/arch/arm/mach-rockchip/rk3368/rk3368.c +++ b/arch/arm/mach-rockchip/rk3368/rk3368.c @@ -96,3 +96,34 @@ int arch_early_init_r(void) return mcu_init(); } #endif + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ + /* + * N.B.: This is called before the device-model has been + * initialised. For this reason, we can not access + * the GRF address range using the syscon API. + */ +#if defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff180000) + struct rk3368_grf * const grf = + (struct rk3368_grf * const)0xff770000; + + enum { + GPIO2D1_MASK = GENMASK(3, 2), + GPIO2D1_GPIO = 0, + GPIO2D1_UART0_SOUT = (1 << 2), + + GPIO2D0_MASK = GENMASK(1, 0), + GPIO2D0_GPIO = 0, + GPIO2D0_UART0_SIN = (1 << 0), + }; + + /* Enable early UART0 on the RK3368 */ + rk_clrsetreg(&grf->gpio2d_iomux, + GPIO2D0_MASK, GPIO2D0_UART0_SIN); + rk_clrsetreg(&grf->gpio2d_iomux, + GPIO2D1_MASK, GPIO2D1_UART0_SOUT); +#endif +} +#endif
Kever Yang kever.yang@rock-chips.com 于2019年3月29日周五 上午9:12写道:
Tested-by: Andy Yan andy.yan@rock-chips.com
enum {
GPIO2D1_GPIO = 0,
GPIO2D0_GPIO = 0,
-#endif -}
enum {
GPIO2D1_GPIO = 0,
GPIO2D0_GPIO = 0,
+#endif +}
2.20.1
Signed-off-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Tested-by: Andy Yan andy.yan@rock-chips.com
Prefer to use structure to access register if we could.
arch/arm/mach-rockchip/rk3399/rk3399.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index 7567a4f584..b76ba4ed32 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -6,11 +6,13 @@ #include <common.h> #include <asm/armv8/mmu.h> #include <asm/io.h> +#include <asm/arch-rockchip/grf_rk3399.h> #include <asm/arch-rockchip/hardware.h>
#define GRF_EMMCCORE_CON11 0xff77f02c +#define GRF_BASE 0xff770000
static struct mm_region rk3399_mem_map[] = { { @@ -48,9 +50,10 @@ int dram_init_banksize(void) int arch_cpu_init(void) { /* We do some SoC one time setting here. */ + struct rk3399_grf_regs * const grf = (void *)GRF_BASE;
/* Emmc clock generator: disable the clock multipilier */ - rk_clrreg(GRF_EMMCCORE_CON11, 0x0ff); + rk_clrreg(&grf->emmccore_con[11], 0x0ff);
return 0; }
Kever Yang kever.yang@rock-chips.com 于2019年3月29日周五 上午9:13写道:
struct rk3399_grf_regs * const grf = (void *)GRF_BASE; /* Emmc clock generator: disable the clock multipilier */
rk_clrreg(&grf->emmccore_con[11], 0x0ff); return 0;
2.20.1
arch/arm/mach-rockchip/rk3399-board-spl.c | 50 +---------------------- arch/arm/mach-rockchip/rk3399/rk3399.c | 50 +++++++++++++++++++++++ 2 files changed, 51 insertions(+), 49 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399-board-spl.c b/arch/arm/mach-rockchip/rk3399-board-spl.c index 54a4b848a3..800ca80022 100644 --- a/arch/arm/mach-rockchip/rk3399-board-spl.c +++ b/arch/arm/mach-rockchip/rk3399-board-spl.c @@ -127,53 +127,6 @@ void secure_timer_init(void) writel(TIMER_EN | TIMER_FMODE, TIMER_CHN10_BASE + TIMER_CONTROL_REG); }
-void board_debug_uart_init(void) -{ -#define GRF_BASE 0xff770000 -#define GPIO0_BASE 0xff720000 -#define PMUGRF_BASE 0xff320000 - struct rk3399_grf_regs * const grf = (void *)GRF_BASE; -#ifdef CONFIG_TARGET_CHROMEBOOK_BOB - struct rk3399_pmugrf_regs * const pmugrf = (void *)PMUGRF_BASE; - struct rockchip_gpio_regs * const gpio = (void *)GPIO0_BASE; -#endif - -#if defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff180000) - /* Enable early UART0 on the RK3399 */ - rk_clrsetreg(&grf->gpio2c_iomux, - GRF_GPIO2C0_SEL_MASK, - GRF_UART0BT_SIN << GRF_GPIO2C0_SEL_SHIFT); - rk_clrsetreg(&grf->gpio2c_iomux, - GRF_GPIO2C1_SEL_MASK, - GRF_UART0BT_SOUT << GRF_GPIO2C1_SEL_SHIFT); -#else -# ifdef CONFIG_TARGET_CHROMEBOOK_BOB - rk_setreg(&grf->io_vsel, 1 << 0); - - /* - * Let's enable these power rails here, we are already running the SPI - * Flash based code. - */ - spl_gpio_output(gpio, GPIO(BANK_B, 2), 1); /* PP1500_EN */ - spl_gpio_set_pull(&pmugrf->gpio0_p, GPIO(BANK_B, 2), GPIO_PULL_NORMAL); - - spl_gpio_output(gpio, GPIO(BANK_B, 4), 1); /* PP3000_EN */ - spl_gpio_set_pull(&pmugrf->gpio0_p, GPIO(BANK_B, 4), GPIO_PULL_NORMAL); -#endif /* CONFIG_TARGET_CHROMEBOOK_BOB */ - - /* Enable early UART2 channel C on the RK3399 */ - rk_clrsetreg(&grf->gpio4c_iomux, - GRF_GPIO4C3_SEL_MASK, - GRF_UART2DGBC_SIN << GRF_GPIO4C3_SEL_SHIFT); - rk_clrsetreg(&grf->gpio4c_iomux, - GRF_GPIO4C4_SEL_MASK, - GRF_UART2DBGC_SOUT << GRF_GPIO4C4_SEL_SHIFT); - /* Set channel C as UART2 input */ - rk_clrsetreg(&grf->soc_con7, - GRF_UART_DBG_SEL_MASK, - GRF_UART_DBG_SEL_C << GRF_UART_DBG_SEL_SHIFT); -#endif -}
void board_init_f(ulong dummy) { @@ -183,8 +136,7 @@ void board_init_f(ulong dummy) struct rk3399_grf_regs *grf; int ret;
-#define EARLY_UART -#ifdef EARLY_UART +#ifdef CONFIG_DEBUG_UART debug_uart_init();
# ifdef CONFIG_TARGET_CHROMEBOOK_BOB diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index b76ba4ed32..238f79a216 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -57,3 +57,53 @@ int arch_cpu_init(void)
return 0; } + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ +#define GRF_BASE 0xff770000 +#define GPIO0_BASE 0xff720000 +#define PMUGRF_BASE 0xff320000 + struct rk3399_grf_regs * const grf = (void *)GRF_BASE; +#ifdef CONFIG_TARGET_CHROMEBOOK_BOB + struct rk3399_pmugrf_regs * const pmugrf = (void *)PMUGRF_BASE; + struct rockchip_gpio_regs * const gpio = (void *)GPIO0_BASE; +#endif + +#if defined(CONFIG_DEBUG_UART_BASE) && (CONFIG_DEBUG_UART_BASE == 0xff180000) + /* Enable early UART0 on the RK3399 */ + rk_clrsetreg(&grf->gpio2c_iomux, + GRF_GPIO2C0_SEL_MASK, + GRF_UART0BT_SIN << GRF_GPIO2C0_SEL_SHIFT); + rk_clrsetreg(&grf->gpio2c_iomux, + GRF_GPIO2C1_SEL_MASK, + GRF_UART0BT_SOUT << GRF_GPIO2C1_SEL_SHIFT); +#else +# ifdef CONFIG_TARGET_CHROMEBOOK_BOB + rk_setreg(&grf->io_vsel, 1 << 0); + + /* + * Let's enable these power rails here, we are already running the SPI + * Flash based code. + */ + spl_gpio_output(gpio, GPIO(BANK_B, 2), 1); /* PP1500_EN */ + spl_gpio_set_pull(&pmugrf->gpio0_p, GPIO(BANK_B, 2), GPIO_PULL_NORMAL); + + spl_gpio_output(gpio, GPIO(BANK_B, 4), 1); /* PP3000_EN */ + spl_gpio_set_pull(&pmugrf->gpio0_p, GPIO(BANK_B, 4), GPIO_PULL_NORMAL); +#endif /* CONFIG_TARGET_CHROMEBOOK_BOB */ + + /* Enable early UART2 channel C on the RK3399 */ + rk_clrsetreg(&grf->gpio4c_iomux, + GRF_GPIO4C3_SEL_MASK, + GRF_UART2DGBC_SIN << GRF_GPIO4C3_SEL_SHIFT); + rk_clrsetreg(&grf->gpio4c_iomux, + GRF_GPIO4C4_SEL_MASK, + GRF_UART2DBGC_SOUT << GRF_GPIO4C4_SEL_SHIFT); + /* Set channel C as UART2 input */ + rk_clrsetreg(&grf->soc_con7, + GRF_UART_DBG_SEL_MASK, + GRF_UART_DBG_SEL_C << GRF_UART_DBG_SEL_SHIFT); +#endif +} +#endif
-#endif
* Flash based code.
-#endif -}
return 0; }
* Flash based code.
I understand that it's just moving the whole function over, but if I understand correctly these are unrelated to the debug_uart_init that the commit mentions.
+#endif +} +#endif
Hi Jack,
-#endif
* Flash based code.
-#endif -}
return 0; }
* Flash based code.
Thanks for your comment, and I just move the whole function as-is, so I do not want to change the code before I understand it, and I'm not the one contribute this part.
Thanks, - Kever
+#endif +} +#endif
Andy Yan
Jack Mitchell
Kever Yang
Philipp Tomsich
