[U-Boot] [PATCH 0/3 v2] RFC: Dreamplug support
It compiles clean, and I've loaded it via JTAG and used it to dump the existing bootloader out of the SPI flash. I have _not_ used it to burn itself to the flash yet. I'm looking for comments before I try that. ;-)
Some concerns:
1.) does the 'make all' support need to be last? I've used rebase to edit patches and commits, but I've never reshuffled. Each patch compiles clean. FIXED in v2.
2.) The SPI flash chip is a Macronix MX25L1606, however it has the identical chip idcode to the MX25L1605. How is that properly handled? The 06 does have some new features [1].
3.) I added the board number [2], etc to asm/mach-types.h even though it says to not to. ;-) Is there a proper way to do it? If it's copied from the Linux kernel, it hasn't been updated in a while...
[1] http://www.macronix.com/QuickPlace/hq/PageLibrary4825740B00298A3B.nsf/h_Inde... [2] http://www.arm.linux.org.uk/developer/machines/list.php?id=3550
Changes from v1 to v2:
- resorted series to move 'make all' support last.
Jason Cooper (3): dreamplug: Initial support. dreamplug: switch from NAND flash to SPI flash. dreamplug: include in 'make all'
MAKEALL | 1 + arch/arm/include/asm/mach-types.h | 13 +++ board/Marvell/dreamplug/Makefile | 51 +++++++++++ board/Marvell/dreamplug/dreamplug.c | 153 ++++++++++++++++++++++++++++++++ board/Marvell/dreamplug/dreamplug.h | 39 ++++++++ board/Marvell/dreamplug/kwbimage.cfg | 160 ++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/dreamplug.h | 111 +++++++++++++++++++++++ 8 files changed, 529 insertions(+), 0 deletions(-) create mode 100644 board/Marvell/dreamplug/Makefile create mode 100644 board/Marvell/dreamplug/dreamplug.c create mode 100644 board/Marvell/dreamplug/dreamplug.h create mode 100644 board/Marvell/dreamplug/kwbimage.cfg create mode 100644 include/configs/dreamplug.h
Copied files from boards/Marvell/guruplug/ and did s/GURUPLUG/DREAMPLUG/g s/guruplug/dreamplug/g
Also, added MACH_TYPE_DREAMPLUG 3550 registered with at http://www.arm.linux.co.uk/developer/machines/
Signed-off-by: Jason Cooper u-boot@lakedaemon.net --- arch/arm/include/asm/mach-types.h | 13 +++ board/Marvell/dreamplug/Makefile | 51 +++++++++++ board/Marvell/dreamplug/dreamplug.c | 153 ++++++++++++++++++++++++++++++++ board/Marvell/dreamplug/dreamplug.h | 39 ++++++++ board/Marvell/dreamplug/kwbimage.cfg | 162 ++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/dreamplug.h | 111 +++++++++++++++++++++++ 7 files changed, 530 insertions(+), 0 deletions(-) create mode 100644 board/Marvell/dreamplug/Makefile create mode 100644 board/Marvell/dreamplug/dreamplug.c create mode 100644 board/Marvell/dreamplug/dreamplug.h create mode 100644 board/Marvell/dreamplug/kwbimage.cfg create mode 100644 include/configs/dreamplug.h
diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index a1fd03a..02baf58 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -3312,6 +3312,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_T5388P 3336 #define MACH_TYPE_DINGO 3337 #define MACH_TYPE_GOFLEXHOME 3338 +#define MACH_TYPE_DREAMPLUG 3550
#ifdef CONFIG_ARCH_EBSA110 # ifdef machine_arch_type @@ -42913,6 +42914,18 @@ extern unsigned int __machine_arch_type; # define machine_is_goflexhome() (0) #endif
+#ifdef CONFIG_MACH_DREAMPLUG +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_DREAMPLUG +# endif +# define machine_is_dreamplug() (machine_arch_type == MACH_TYPE_DREAMPLUG) +#else +# define machine_is_dreamplug() (0) +#endif + /* * These have not yet been registered */ diff --git a/board/Marvell/dreamplug/Makefile b/board/Marvell/dreamplug/Makefile new file mode 100644 index 0000000..b7e5270 --- /dev/null +++ b/board/Marvell/dreamplug/Makefile @@ -0,0 +1,51 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Siddarth Gore gores@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := dreamplug.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/Marvell/dreamplug/dreamplug.c b/board/Marvell/dreamplug/dreamplug.c new file mode 100644 index 0000000..32d82ba --- /dev/null +++ b/board/Marvell/dreamplug/dreamplug.c @@ -0,0 +1,153 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Siddarth Gore gores@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <miiphy.h> +#include <asm/arch/kirkwood.h> +#include <asm/arch/mpp.h> +#include "dreamplug.h" + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + /* + * default gpio configuration + * There are maximum 64 gpios controlled through 2 sets of registers + * the below configuration configures mainly initial LED status + */ + kw_config_gpio(DREAMPLUG_OE_VAL_LOW, + DREAMPLUG_OE_VAL_HIGH, + DREAMPLUG_OE_LOW, DREAMPLUG_OE_HIGH); + + /* Multi-Purpose Pins Functionality configuration */ + u32 kwmpp_config[] = { + MPP0_NF_IO2, + MPP1_NF_IO3, + MPP2_NF_IO4, + MPP3_NF_IO5, + MPP4_NF_IO6, + MPP5_NF_IO7, + MPP6_SYSRST_OUTn, + MPP7_GPO, /* GPIO_RST */ + MPP8_TW_SDA, + MPP9_TW_SCK, + MPP10_UART0_TXD, + MPP11_UART0_RXD, + MPP12_SD_CLK, + MPP13_SD_CMD, + MPP14_SD_D0, + MPP15_SD_D1, + MPP16_SD_D2, + MPP17_SD_D3, + MPP18_NF_IO0, + MPP19_NF_IO1, + MPP20_GE1_0, + MPP21_GE1_1, + MPP22_GE1_2, + MPP23_GE1_3, + MPP24_GE1_4, + MPP25_GE1_5, + MPP26_GE1_6, + MPP27_GE1_7, + MPP28_GE1_8, + MPP29_GE1_9, + MPP30_GE1_10, + MPP31_GE1_11, + MPP32_GE1_12, + MPP33_GE1_13, + MPP34_GE1_14, + MPP35_GE1_15, + MPP36_GPIO, + MPP37_GPIO, + MPP38_GPIO, + MPP39_GPIO, + MPP40_TDM_SPI_SCK, + MPP41_TDM_SPI_MISO, + MPP42_TDM_SPI_MOSI, + MPP43_GPIO, + MPP44_GPIO, + MPP45_GPIO, + MPP46_GPIO, /* M_RLED */ + MPP47_GPIO, /* M_GLED */ + MPP48_GPIO, /* B_RLED */ + MPP49_GPIO, /* B_GLED */ + 0 + }; + kirkwood_mpp_conf(kwmpp_config); + return 0; +} + +int board_init(void) +{ + /* + * arch number of board + */ + gd->bd->bi_arch_number = MACH_TYPE_DREAMPLUG; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = kw_sdram_bar(0) + 0x100; + + return 0; +} + +#ifdef CONFIG_RESET_PHY_R +void mv_phy_88e1121_init(char *name) +{ + u16 reg; + u16 devadr; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr)) { + printf("Err..%s could not read PHY dev address\n", + __FUNCTION__); + return; + } + + /* + * Enable RGMII delay on Tx and Rx for CPU port + * Ref: sec 4.7.2 of chip datasheet + */ + miiphy_write(name, devadr, MV88E1121_PGADR_REG, 2); + miiphy_read(name, devadr, MV88E1121_MAC_CTRL2_REG, ®); + reg |= (MV88E1121_RGMII_RXTM_CTRL | MV88E1121_RGMII_TXTM_CTRL); + miiphy_write(name, devadr, MV88E1121_MAC_CTRL2_REG, reg); + miiphy_write(name, devadr, MV88E1121_PGADR_REG, 0); + + /* reset the phy */ + miiphy_reset(name, devadr); + + printf("88E1121 Initialized on %s\n", name); +} + +void reset_phy(void) +{ + /* configure and initialize both PHY's */ + mv_phy_88e1121_init("egiga0"); + mv_phy_88e1121_init("egiga1"); +} +#endif /* CONFIG_RESET_PHY_R */ diff --git a/board/Marvell/dreamplug/dreamplug.h b/board/Marvell/dreamplug/dreamplug.h new file mode 100644 index 0000000..b597859 --- /dev/null +++ b/board/Marvell/dreamplug/dreamplug.h @@ -0,0 +1,39 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Siddarth Gore gores@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef __DREAMPLUG_H +#define __DREAMPLUG_H + +#define DREAMPLUG_OE_LOW (~(0)) +#define DREAMPLUG_OE_HIGH (~(0)) +#define DREAMPLUG_OE_VAL_LOW 0 +#define DREAMPLUG_OE_VAL_HIGH (0xf << 16) /* 4 LED Pins high */ + +/* PHY related */ +#define MV88E1121_MAC_CTRL2_REG 21 +#define MV88E1121_PGADR_REG 22 +#define MV88E1121_RGMII_TXTM_CTRL (1 << 4) +#define MV88E1121_RGMII_RXTM_CTRL (1 << 5) + +#endif /* __DREAMPLUG_H */ diff --git a/board/Marvell/dreamplug/kwbimage.cfg b/board/Marvell/dreamplug/kwbimage.cfg new file mode 100644 index 0000000..2afd927 --- /dev/null +++ b/board/Marvell/dreamplug/kwbimage.cfg @@ -0,0 +1,162 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Siddarth Gore gores@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM nand +NAND_ECC_MODE default +NAND_PAGE_SIZE 0x0800 + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +# Configure RGMII-0/1 interface pad voltage to 1.8V +DATA 0xFFD100e0 0x1b1b9b9b + +#Dram initalization for SINGLE x16 CL=5 @ 400MHz +DATA 0xFFD01400 0x43000c30 # DDR Configuration register +# bit13-0: 0xc30 (3120 DDR2 clks refresh rate) +# bit23-14: zero +# bit24: 1= enable exit self refresh mode on DDR access +# bit25: 1 required +# bit29-26: zero +# bit31-30: 01 + +DATA 0xFFD01404 0x37543000 # DDR Controller Control Low +# bit 4: 0=addr/cmd in smame cycle +# bit 5: 0=clk is driven during self refresh, we don't care for APX +# bit 6: 0=use recommended falling edge of clk for addr/cmd +# bit14: 0=input buffer always powered up +# bit18: 1=cpu lock transaction enabled +# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 +# bit27-24: 7= CL+2, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM +# bit30-28: 3 required +# bit31: 0=no additional STARTBURST delay + +DATA 0xFFD01408 0x22125451 # DDR Timing (Low) (active cycles value +1) +# bit3-0: TRAS lsbs +# bit7-4: TRCD +# bit11- 8: TRP +# bit15-12: TWR +# bit19-16: TWTR +# bit20: TRAS msb +# bit23-21: 0x0 +# bit27-24: TRRD +# bit31-28: TRTP + +DATA 0xFFD0140C 0x00000a33 # DDR Timing (High) +# bit6-0: TRFC +# bit8-7: TR2R +# bit10-9: TR2W +# bit12-11: TW2W +# bit31-13: zero required + +DATA 0xFFD01410 0x000000cc # DDR Address Control +# bit1-0: 01, Cs0width=x8 +# bit3-2: 10, Cs0size=1Gb +# bit5-4: 01, Cs1width=x8 +# bit7-6: 10, Cs1size=1Gb +# bit9-8: 00, Cs2width=nonexistent +# bit11-10: 00, Cs2size =nonexistent +# bit13-12: 00, Cs3width=nonexistent +# bit15-14: 00, Cs3size =nonexistent +# bit16: 0, Cs0AddrSel +# bit17: 0, Cs1AddrSel +# bit18: 0, Cs2AddrSel +# bit19: 0, Cs3AddrSel +# bit31-20: 0 required + +DATA 0xFFD01414 0x00000000 # DDR Open Pages Control +# bit0: 0, OpenPage enabled +# bit31-1: 0 required + +DATA 0xFFD01418 0x00000000 # DDR Operation +# bit3-0: 0x0, DDR cmd +# bit31-4: 0 required + +DATA 0xFFD0141C 0x00000C52 # DDR Mode +# bit2-0: 2, BurstLen=2 required +# bit3: 0, BurstType=0 required +# bit6-4: 4, CL=5 +# bit7: 0, TestMode=0 normal +# bit8: 0, DLL reset=0 normal +# bit11-9: 6, auto-precharge write recovery ???????????? +# bit12: 0, PD must be zero +# bit31-13: 0 required + +DATA 0xFFD01420 0x00000040 # DDR Extended Mode +# bit0: 0, DDR DLL enabled +# bit1: 0, DDR drive strenght normal +# bit2: 0, DDR ODT control lsd (disabled) +# bit5-3: 000, required +# bit6: 1, DDR ODT control msb, (disabled) +# bit9-7: 000, required +# bit10: 0, differential DQS enabled +# bit11: 0, required +# bit12: 0, DDR output buffer enabled +# bit31-13: 0 required + +DATA 0xFFD01424 0x0000F17F # DDR Controller Control High +# bit2-0: 111, required +# bit3 : 1 , MBUS Burst Chop disabled +# bit6-4: 111, required +# bit7 : 0 +# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz +# bit9 : 0 , no half clock cycle addition to dataout +# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals +# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh +# bit15-12: 1111 required +# bit31-16: 0 required + +DATA 0xFFD01428 0x00085520 # DDR2 ODT Read Timing (default values) +DATA 0xFFD0147C 0x00008552 # DDR2 ODT Write Timing (default values) + +DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 +DATA 0xFFD01504 0x0FFFFFF1 # CS[0]n Size +# bit0: 1, Window enabled +# bit1: 0, Write Protect disabled +# bit3-2: 00, CS0 hit selected +# bit23-4: ones, required +# bit31-24: 0x0F, Size (i.e. 256MB) + +DATA 0xFFD01508 0x10000000 # CS[1]n Base address to 256Mb +DATA 0xFFD0150C 0x0FFFFFF5 # CS[1]n Size 256Mb Window enabled for CS1 + +DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled +DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled + +DATA 0xFFD01494 0x00030000 # DDR ODT Control (Low) +DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) +# bit1-0: 00, ODT0 controlled by ODT Control (low) register above +# bit3-2: 01, ODT1 active NEVER! +# bit31-4: zero, required + +DATA 0xFFD0149C 0x0000E803 # CPU ODT Control +DATA 0xFFD01480 0x00000001 # DDR Initialization Control +#bit0=1, enable DDR init upon this register write + +# End of Header extension +DATA 0x0 0x0 diff --git a/boards.cfg b/boards.cfg index d2cacc8..a69ada6 100644 --- a/boards.cfg +++ b/boards.cfg @@ -110,6 +110,7 @@ suen3 arm arm926ejs km_arm keymile suen8 arm arm926ejs km_arm keymile kirkwood mgcoge3un arm arm926ejs km_arm keymile kirkwood guruplug arm arm926ejs - Marvell kirkwood +dreamplug arm arm926ejs - Marvell kirkwood mv88f6281gtw_ge arm arm926ejs - Marvell kirkwood openrd_base arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_BASE openrd_client arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_CLIENT diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h new file mode 100644 index 0000000..7b494cc --- /dev/null +++ b/include/configs/dreamplug.h @@ -0,0 +1,111 @@ +/* + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Siddarth Gore gores@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CONFIG_DREAMPLUG_H +#define _CONFIG_DREAMPLUG_H + +/* + * Version number information + */ +#define CONFIG_IDENT_STRING "\nMarvell-DreamPlug" + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_SHEEVA_88SV131 1 /* CPU Core subversion */ +#define CONFIG_KIRKWOOD 1 /* SOC Family Name */ +#define CONFIG_KW88F6281 1 /* SOC Name */ +#define CONFIG_MACH_DREAMPLUG /* Machine type */ +#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ + +/* + * Commands configuration + */ +#define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ +#include <config_cmd_default.h> +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ENV +#define CONFIG_CMD_FAT +#define CONFIG_CMD_NAND +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB +#define CONFIG_CMD_IDE + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" + +/* + * Environment variables configurations + */ +#ifdef CONFIG_CMD_NAND +#define CONFIG_ENV_IS_IN_NAND 1 +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K */ +#else +#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ +#endif +/* + * max 4k env size is enough, but in case of nand + * it has to be rounded to sector size + */ +#define CONFIG_ENV_SIZE 0x20000 /* 128k */ +#define CONFIG_ENV_ADDR 0x60000 +#define CONFIG_ENV_OFFSET 0x60000 /* env starts here */ + +/* + * Default environment variables + */ +#define CONFIG_BOOTCOMMAND "setenv ethact egiga0; " \ + "${x_bootcmd_ethernet}; setenv ethact egiga1; " \ + "${x_bootcmd_ethernet}; ${x_bootcmd_usb}; ${x_bootcmd_kernel}; "\ + "setenv bootargs ${x_bootargs} ${x_bootargs_root}; " \ + "bootm 0x6400000;" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "x_bootcmd_ethernet=ping 192.168.2.1\0" \ + "x_bootcmd_usb=usb start\0" \ + "x_bootcmd_kernel=nand read.e 0x6400000 0x100000 0x400000\0" \ + "x_bootargs=console=ttyS0,115200\0" \ + "x_bootargs_root=ubi.mtd=2 root=ubi0:rootfs rootfstype=ubifs\0" + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_MVGBE_PORTS {1, 1} /* enable both ports */ +#define CONFIG_PHY_BASE_ADR 0 +#endif /* CONFIG_CMD_NET */ + +/* + * SATA Driver configuration + */ +#ifdef CONFIG_MVSATA_IDE +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +#endif /*CONFIG_MVSATA_IDE*/ + +#define CONFIG_SYS_ALT_MEMTEST + +#endif /* _CONFIG_DREAMPLUG_H */
MPP._SPI_ configuration copied from boards/Marvell/mv88f6281gtw_ge/mv88f6281gtw_ge.c
Signed-off-by: Jason Cooper u-boot@lakedaemon.net --- board/Marvell/dreamplug/dreamplug.c | 18 +++++++++--------- board/Marvell/dreamplug/kwbimage.cfg | 4 +--- include/configs/dreamplug.h | 2 +- 3 files changed, 11 insertions(+), 13 deletions(-)
diff --git a/board/Marvell/dreamplug/dreamplug.c b/board/Marvell/dreamplug/dreamplug.c index 32d82ba..6442396 100644 --- a/board/Marvell/dreamplug/dreamplug.c +++ b/board/Marvell/dreamplug/dreamplug.c @@ -43,14 +43,14 @@ int board_early_init_f(void)
/* Multi-Purpose Pins Functionality configuration */ u32 kwmpp_config[] = { - MPP0_NF_IO2, - MPP1_NF_IO3, - MPP2_NF_IO4, - MPP3_NF_IO5, - MPP4_NF_IO6, - MPP5_NF_IO7, + MPP0_SPI_SCn, + MPP1_SPI_MOSI, + MPP2_SPI_SCK, + MPP3_SPI_MISO, + MPP4_GPIO, + MPP5_GPO, MPP6_SYSRST_OUTn, - MPP7_GPO, /* GPIO_RST */ + MPP7_SPI_SCn, MPP8_TW_SDA, MPP9_TW_SCK, MPP10_UART0_TXD, @@ -61,8 +61,8 @@ int board_early_init_f(void) MPP15_SD_D1, MPP16_SD_D2, MPP17_SD_D3, - MPP18_NF_IO0, - MPP19_NF_IO1, + MPP18_GPO, + MPP19_GPO, MPP20_GE1_0, MPP21_GE1_1, MPP22_GE1_2, diff --git a/board/Marvell/dreamplug/kwbimage.cfg b/board/Marvell/dreamplug/kwbimage.cfg index 2afd927..ae76b32 100644 --- a/board/Marvell/dreamplug/kwbimage.cfg +++ b/board/Marvell/dreamplug/kwbimage.cfg @@ -26,9 +26,7 @@ #
# Boot Media configurations -BOOT_FROM nand -NAND_ECC_MODE default -NAND_PAGE_SIZE 0x0800 +BOOT_FROM spi
# SOC registers configuration using bootrom header extension # Maximum KWBIMAGE_MAX_CONFIG configurations allowed diff --git a/include/configs/dreamplug.h b/include/configs/dreamplug.h index 7b494cc..bf477b2 100644 --- a/include/configs/dreamplug.h +++ b/include/configs/dreamplug.h @@ -47,7 +47,7 @@ #define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_FAT -#define CONFIG_CMD_NAND +#define CONFIG_CMD_SF #define CONFIG_CMD_PING #define CONFIG_CMD_USB #define CONFIG_CMD_IDE
-----Original Message----- From: u-boot@lakedaemon.net [mailto:u-boot@lakedaemon.net] Sent: Monday, June 06, 2011 6:04 PM To: u-boot@lists.denx.de Cc: Prafulla Wadaskar; Jason Cooper Subject: [PATCH 2/3 v2] dreamplug: switch from NAND flash to SPI flash.
No need for this, you can add these changes to your native patch since this is your first post
Regards.. Prafulla ..
Signed-off-by: Jason Cooper u-boot@lakedaemon.net --- MAKEALL | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/MAKEALL b/MAKEALL index d592374..35fc5b7 100755 --- a/MAKEALL +++ b/MAKEALL @@ -345,6 +345,7 @@ LIST_ARM9=" \ edb9315a \ edminiv2 \ guruplug \ + dreamplug \ imx27lite \ jadecpu \ lpd7a400 \
-----Original Message----- From: u-boot@lakedaemon.net [mailto:u-boot@lakedaemon.net] Sent: Monday, June 06, 2011 6:04 PM To: u-boot@lists.denx.de Cc: Prafulla Wadaskar; Jason Cooper Subject: [PATCH 3/3 v2] dreamplug: include in 'make all'
You can avoid 2/3, and 3/3 of your patch series and post a single patch series for this support.
Will do, thanks for taking a look.
Jason.
-----Original Message----- From: u-boot@lakedaemon.net [mailto:u-boot@lakedaemon.net] Sent: Monday, June 06, 2011 6:04 PM To: u-boot@lists.denx.de Cc: Prafulla Wadaskar; Jason Cooper Subject: [PATCH 0/3 v2] RFC: Dreamplug support
It compiles clean, and I've loaded it via JTAG and used it to dump the existing bootloader out of the SPI flash. I have _not_ used it to burn itself to the flash yet. I'm looking for comments before I try that. ;- )
Some concerns:
No, the proper way is- you should add board first to arm-linux, then the updated mach-types.h will be updated by arm maintainer on u-boot, then you can add your board support.
[1] http://www.macronix.com/QuickPlace/hq/PageLibrary4825740B00298A3B.nsf/h_ Index/5F41CDDCB837422C48257639003E5EC3/$File/AN055- Migrate_to_MX25L1606E_and_MX25L8006E-1.2.pdf [2] http://www.arm.linux.org.uk/developer/machines/list.php?id=3550
No patch for this file, follow process explained above.
You should update MAINTAINERS file too.
Regards.. Prafulla . .
Prafulla,
Thanks for the input! I assume the SPI flash implementation looked ok?
Ok, I'll starting working on the Linux side as well.
So, in the interim, I'll resubmit using the guruplug board id, then submit separate patch after the Linux support is accepted.
Ok, I'll add Dreamplug under Siddarth Gore.
Jason
Prafulla Wadaskar
