[U-Boot-Users] ppc_4xx-ld: u-boot: Not enough room for program headers (allocated 2, need 3)
Hi , Thank you so much for answering my questions i mentioned several days ago. I'm porting u-boot-1.1.4 to Ebedded planet EP405(with ppc 405GPr processor) and it bases on a similar board CPCI4052 as you suggested. i did as follow #cd ../u-boot-1.1.3/board/esd #mkdir ep405 #cd cpci405 #cp * ../ep405 #cd ../ep405 # mv cpci405.c ep405.c #cd ../../../include/configs #cp CPCI4052.h ep405.h then add text content as follow to u-boot-1.1.3/Makefile ep_config: unconfig @./mkconfig $(@:_config=) ppc ppc4xx cpci405 esd @echo "BOARD_REVISION = $(@:_config=)" >>include/config.mk #cd ../u-boot-1.1.3 #make distclean #make ep405_config #make all then the error appears: ppc_4xx-ld: u-boot: Not enough room for program headers (allocated 2, need 3) ppc_4xx-ld: final link failed: Bad value would you please tell me why and how to handle it ? Thank u and best wishes !
In message c002eb610601022001u438ce46as@mail.gmail.com you wrote:
Thank you so much for answering my questions i mentioned several days =
Let's keep in mind that similar does not mean the same.
This is wrong. Don't do this. "board/esd" is for boards manufactured by esd electronics only, while the EP405 is by Embedded Planet. So far we don't have a vendor directory for EP, which means you have to place your code in board/
Wrong again, as you must provide your own board config file instead of using the cpci405 one.
Clean up above problems first, please.
Thank u! I just want to make a test before i modify content of files such as ep405.c . and i changed the directory as you said to board/ and modified the Makefile correctly. then , #make clean #make ep405_config #make all the error followed is : make[1]: Entering directory `/tmp/u-boot-1.1.4/board/ep405' make[1]: *** No rule to make target `../common/misc.c', needed by `.depend'. Stop.
so now, where will i check the rule and do some amendments and how to do?
I also confused by another problem: There has been a PlanetCore Boot Loader resides in flash memoery(in EP405),and there is no JTAG on the board. so if i erase the existed bootloader which is convinient for writing flash, it will be difficult for me to write my u-boot image to flash. so can i keep the existed bootloader and as it is now and use it to write u-boot in another region of the flash ? Then after booting from PlanetCore Boot Loader, i will be able to run u-boot and check if it has been correctly modified. if the answer is yes, what should i do during the procedure of modifying u-boot?
2006/1/3, Wolfgang Denk wd@denx.de:
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Things that try to look like things often do look more like things than things. Well-known fact. - Terry Pratchett, _Wyrd Sisters_
腾飞龙
