[PATCH v2] net: phy: broadcom: add support for BCM54210E
It's Broadcom PHY simply described as single-port RGMII 10/100/1000BASE-T PHY. It requires disabling delay skew and GTXCLK bits.
BCM54210E support ported from Linux kernel commit 0fc9ae1076697 ("net: phy: broadcom: add support for BCM54210E") AUX/SHD/bcm54xx_config_clock_delay update ported from Linux 6.5-rc4 commit 28e219aea0b9e ("net: phy: broadcom: drop brcm_phy_setbits() and use phy_set_bits() instead")
Signed-off-by: Marek Vasut marex@denx.de --- Cc: Joe Hershberger joe.hershberger@ni.com Cc: Marek Vasut marex@denx.de Cc: Michal Simek michal.simek@amd.com Cc: Rafał Miłecki rafal@milecki.pl Cc: Ramon Fried rfried.dev@gmail.com Cc: Rasmus Villemoes rasmus.villemoes@prevas.dk --- V2: Add RGMII delay fix from up to Linux 6.5-rc4 per suggestion from Rafał --- drivers/net/phy/broadcom.c | 101 ++++++++++++++++++++++++++++++++++++- 1 file changed, 100 insertions(+), 1 deletion(-)
diff --git a/drivers/net/phy/broadcom.c b/drivers/net/phy/broadcom.c index 36c70da181a..82e3bbef7dd 100644 --- a/drivers/net/phy/broadcom.c +++ b/drivers/net/phy/broadcom.c @@ -30,10 +30,87 @@ #define MIIM_BCM54XX_EXP_SEL_ER 0x0f00 /* Expansion register select */
#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC 0x0007 -#define MIIM_BCM_AUXCNTL_ACTL_SMDSP_EN 0x0800 +#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC_WIRESPEED_EN 0x0010 +#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_EN 0x0080 +#define MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_SKEW_EN 0x0100 +#define MIIM_BCM_AUXCNTL_MISC_FORCE_AMDIX 0x0200 +#define MIIM_BCM_AUXCNTL_ACTL_SMDSP_EN 0x0800 +#define MIIM_BCM_AUXCNTL_MISC_WREN 0x8000
#define MIIM_BCM_CHANNEL_WIDTH 0x2000
+#define BCM54810_SHD_CLK_CTL 0x3 +#define BCM54810_SHD_CLK_CTL_GTXCLK_EN BIT(9) + +static int bcm54xx_auxctl_read(struct phy_device *phydev, u16 regnum) +{ + /* The register must be written to both the Shadow Register Select and + * the Shadow Read Register Selector + */ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, + MIIM_BCM54xx_AUXCNTL_ENCODE(regnum)); + return phy_read(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL); +} + +static int bcm54xx_auxctl_write(struct phy_device *phydev, u16 regnum, u16 val) +{ + return phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54xx_AUXCNTL, regnum | val); +} + +static int bcm_phy_read_shadow(struct phy_device *phydev, u16 shadow) +{ + phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_SHD, + MIIM_BCM54XX_SHD_VAL(shadow)); + return MIIM_BCM54XX_SHD_DATA(phy_read(phydev, MDIO_DEVAD_NONE, + MIIM_BCM54XX_SHD)); +} + +static int bcm_phy_write_shadow(struct phy_device *phydev, u16 shadow, u16 val) +{ + return phy_write(phydev, MDIO_DEVAD_NONE, MIIM_BCM54XX_SHD, + MIIM_BCM54XX_SHD_WR_ENCODE(shadow, val)); +} + +static int bcm54xx_config_clock_delay(struct phy_device *phydev) +{ + int rc, val; + + /* handling PHY's internal RX clock delay */ + val = bcm54xx_auxctl_read(phydev, MIIM_BCM_AUXCNTL_SHDWSEL_MISC); + val |= MIIM_BCM_AUXCNTL_MISC_WREN; + if (phydev->interface == PHY_INTERFACE_MODE_RGMII || + phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID) { + /* Disable RGMII RXC-RXD skew */ + val &= ~MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_SKEW_EN; + } + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID) { + /* Enable RGMII RXC-RXD skew */ + val |= MIIM_BCM_AUXCNTL_SHDWSEL_MISC_RGMII_SKEW_EN; + } + rc = bcm54xx_auxctl_write(phydev, MIIM_BCM_AUXCNTL_SHDWSEL_MISC, val); + if (rc < 0) + return rc; + + /* handling PHY's internal TX clock delay */ + val = bcm_phy_read_shadow(phydev, BCM54810_SHD_CLK_CTL); + if (phydev->interface == PHY_INTERFACE_MODE_RGMII || + phydev->interface == PHY_INTERFACE_MODE_RGMII_RXID) { + /* Disable internal TX clock delay */ + val &= ~BCM54810_SHD_CLK_CTL_GTXCLK_EN; + } + if (phydev->interface == PHY_INTERFACE_MODE_RGMII_ID || + phydev->interface == PHY_INTERFACE_MODE_RGMII_TXID) { + /* Enable internal TX clock delay */ + val |= BCM54810_SHD_CLK_CTL_GTXCLK_EN; + } + rc = bcm_phy_write_shadow(phydev, BCM54810_SHD_CLK_CTL, val); + if (rc < 0) + return rc; + + return 0; +} + static void bcm_phy_write_misc(struct phy_device *phydev, u16 reg, u16 chl, u16 value) { @@ -62,6 +139,18 @@ static int bcm5461_config(struct phy_device *phydev) return 0; }
+/* Broadcom BCM54210E */ +static int bcm54210e_config(struct phy_device *phydev) +{ + int ret; + + ret = bcm54xx_config_clock_delay(phydev); + if (ret < 0) + return ret; + + return bcm5461_config(phydev); +} + static int bcm54xx_parse_status(struct phy_device *phydev) { unsigned int mii_reg; @@ -311,6 +400,16 @@ static int bcm5482_startup(struct phy_device *phydev) return bcm54xx_parse_status(phydev); }
+U_BOOT_PHY_DRIVER(bcm54210e) = { + .name = "Broadcom BCM54210E", + .uid = 0x600d84a0, + .mask = 0xfffffff0, + .features = PHY_GBIT_FEATURES, + .config = &bcm54210e_config, + .startup = &bcm54xx_startup, + .shutdown = &genphy_shutdown, +}; + U_BOOT_PHY_DRIVER(bcm5461s) = { .name = "Broadcom BCM5461S", .uid = 0x2060c0,
Reviewed-by: Rafał Miłecki rafal@milecki.pl
Thanks for your help with this !
Signed-off-by: Marek Vasut marex@denx.de Reviewed-by: Rafał Miłecki rafal@milecki.pl
Rafał Miłecki
