[PATCH v2] arm: spl: Use separate fault handlers instead of a single common one
It may be necessary to set breakpoints etc. on a specific fault handler in SPL. Add a Kconfig option to separate the different handlers into their own individual infinite loops.
Signed-off-by: Csókás Bence csokas.bence@prolan.hu ---
Notes: Changes in v2: * Change `depends`: add `&& !ARM64 && !CPU_V7M` * Remove `default n`
arch/arm/Kconfig | 9 +++++++++ arch/arm/lib/vectors.S | 18 ++++++++++++++++++ 2 files changed, 27 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 328e2ddc33..a6ddbad30c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -79,6 +79,15 @@ config SPL_SYS_NO_VECTOR_TABLE depends on SPL bool
+config SPL_USE_SEPARATE_FAULT_HANDLERS + bool "Use separate fault handlers instead of a single common one" + depends on !SPL_SYS_NO_VECTOR_TABLE && !ARM64 && !CPU_V7M + help + Instead of a common fault handler, generate a separate one for + undefined_instruction, software_interrupt, prefetch_abort etc. + This is for debugging purposes, when you want to set breakpoints + on them separately. + config LINUX_KERNEL_IMAGE_HEADER depends on ARM64 bool diff --git a/arch/arm/lib/vectors.S b/arch/arm/lib/vectors.S index 7cf7d1636f..a14bca6fb8 100644 --- a/arch/arm/lib/vectors.S +++ b/arch/arm/lib/vectors.S @@ -138,11 +138,29 @@ _fiq: .word fiq #if !CONFIG_IS_ENABLED(SYS_NO_VECTOR_TABLE) .align 5 undefined_instruction: +#if CONFIG_IS_ENABLED(USE_SEPARATE_FAULT_HANDLERS) + b undefined_instruction +#endif software_interrupt: +#if CONFIG_IS_ENABLED(USE_SEPARATE_FAULT_HANDLERS) + b software_interrupt +#endif prefetch_abort: +#if CONFIG_IS_ENABLED(USE_SEPARATE_FAULT_HANDLERS) + b prefetch_abort +#endif data_abort: +#if CONFIG_IS_ENABLED(USE_SEPARATE_FAULT_HANDLERS) + b data_abort +#endif not_used: +#if CONFIG_IS_ENABLED(USE_SEPARATE_FAULT_HANDLERS) + b not_used +#endif irq: +#if CONFIG_IS_ENABLED(USE_SEPARATE_FAULT_HANDLERS) + b irq +#endif fiq: 1: b 1b /* hang and never return */
Csókás Bence
