[PATCH] i2c: t210: Add VI_I2C clock source support
Fix VI_I2C clock source type. Will be needed by VI_I2C driver. Also added use of INTERNAL_ID macro in two places, needed to keep the id returned to 8 bits.
Signed-off-by: Tom Warren twarren@nvidia.com --- arch/arm/mach-tegra/tegra210/clock.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-tegra/tegra210/clock.c b/arch/arm/mach-tegra/tegra210/clock.c index f1b25e2..00c65c2 100644 --- a/arch/arm/mach-tegra/tegra210/clock.c +++ b/arch/arm/mach-tegra/tegra210/clock.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * (C) Copyright 2013-2015 + * (C) Copyright 2013-2020 * NVIDIA Corporation <www.nvidia.com> */
@@ -333,7 +333,7 @@ static enum clock_type_id clock_periph_type[PERIPHC_COUNT] = { TYPE(PERIPHC_DMIC3, CLOCK_TYPE_NONE), TYPE(PERIPHC_APE, CLOCK_TYPE_NONE), TYPE(PERIPHC_QSPI, CLOCK_TYPE_PC01C00_C42C41TC40), - TYPE(PERIPHC_VI_I2C, CLOCK_TYPE_NONE), + TYPE(PERIPHC_VI_I2C, CLOCK_TYPE_PC2CC3M_T16), TYPE(PERIPHC_USB2_HSIC_TRK, CLOCK_TYPE_NONE), TYPE(PERIPHC_PEX_SATA_USB_RX_BYP, CLOCK_TYPE_NONE),
@@ -739,7 +739,7 @@ int get_periph_clock_info(enum periph_id periph_id, int *mux_bits, if (!clock_periph_id_isvalid(periph_id)) return -1;
- internal_id = periph_id_to_internal_id[periph_id]; + internal_id = INTERNAL_ID(periph_id_to_internal_id[periph_id]); if (!periphc_internal_id_isvalid(internal_id)) return -1;
@@ -765,7 +765,7 @@ enum clock_id get_periph_clock_id(enum periph_id periph_id, int source) if (!clock_periph_id_isvalid(periph_id)) return CLOCK_ID_NONE;
- internal_id = periph_id_to_internal_id[periph_id]; + internal_id = INTERNAL_ID(periph_id_to_internal_id[periph_id]); if (!periphc_internal_id_isvalid(internal_id)) return CLOCK_ID_NONE;
tomcwarren3959@gmail.com
