[PATCH v4 1/5] firmware: scmi: voltage regulator
Implement voltage regulators interfaced by the SCMI voltage domain protocol. The DT bindings are defined in the Linux kernel since SCMI voltage domain and regulators patches [1] and [2] integration in v5.11-rc7.
Link: [1] https://github.com/torvalds/linux/commit/0f80fcec08e9c50b8d2992cf26495673765... Link: [2] https://github.com/torvalds/linux/commit/2add5cacff3531e54c50b0832128299faa9... Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- Changes in v4: - define a device for SCMI voltage protocol that binds the SCMI regulators as suggested by Patrick. - removed Simon and Jaehoon tags since changes.
Changes in v3: - applied review tags
Changes in v2: - no change --- doc/device-tree-bindings/arm/arm,scmi.txt | 34 ++++ drivers/firmware/scmi/scmi_agent-uclass.c | 10 ++ drivers/power/regulator/Kconfig | 8 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/scmi_regulator.c | 195 ++++++++++++++++++++++ include/scmi_protocols.h | 113 +++++++++++++ 6 files changed, 361 insertions(+) create mode 100644 drivers/power/regulator/scmi_regulator.c
diff --git a/doc/device-tree-bindings/arm/arm,scmi.txt b/doc/device-tree-bindings/arm/arm,scmi.txt index 1f293ea24..a76124f4a 100644 --- a/doc/device-tree-bindings/arm/arm,scmi.txt +++ b/doc/device-tree-bindings/arm/arm,scmi.txt @@ -62,6 +62,20 @@ Required properties: - #power-domain-cells : Should be 1. Contains the device or the power domain ID value used by SCMI commands.
+Regulator bindings for the SCMI Regulator based on SCMI Message Protocol +------------------------------------------------------------ +An SCMI Regulator is permanently bound to a well defined SCMI Voltage Domain, +and should be always positioned as a root regulator. +It does not support any current operation. + +SCMI Regulators are grouped under a 'regulators' node which in turn is a child +of the SCMI Voltage protocol node inside the desired SCMI instance node. + +This binding uses the common regulator binding[6]. + +Required properties: + - reg : shall identify an existent SCMI Voltage Domain. + Sensor bindings for the sensors based on SCMI Message Protocol -------------------------------------------------------------- SCMI provides an API to access the various sensors on the SoC. @@ -105,6 +119,7 @@ Required sub-node properties: [3] Documentation/devicetree/bindings/thermal/thermal.txt [4] Documentation/devicetree/bindings/sram/sram.yaml [5] Documentation/devicetree/bindings/reset/reset.txt +[6] Documentation/devicetree/bindings/regulator/regulator.yaml
Example:
@@ -169,6 +184,25 @@ firmware { reg = <0x16>; #reset-cells = <1>; }; + + scmi_voltage: protocol@17 { + reg = <0x17>; + + regulators { + regulator_devX: regulator@0 { + reg = <0x0>; + regulator-max-microvolt = <3300000>; + }; + + regulator_devY: regulator@9 { + reg = <0x9>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <4200000>; + }; + + ... + }; + }; }; };
diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index 516e690ac..f13e46c36 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -79,6 +79,16 @@ static int scmi_bind_protocols(struct udevice *dev) if (IS_ENABLED(CONFIG_RESET_SCMI)) drv = DM_DRIVER_GET(scmi_reset_domain); break; + case SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN: + if (IS_ENABLED(CONFIG_DM_REGULATOR_SCMI)) { + node = ofnode_find_subnode(node, "regulators"); + if (!ofnode_valid(node)) { + dev_err(dev, "no regulators node\n"); + return -ENXIO; + } + drv = DM_DRIVER_GET(scmi_voltage_domain); + } + break; default: break; } diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index fbbea18c7..5d6180229 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -353,3 +353,11 @@ config DM_REGULATOR_TPS65941 TPS65941 series of PMICs have 5 single phase BUCKs that can also be configured in multi phase modes & 4 LDOs. The driver implements get/set api for value and enable. + +config DM_REGULATOR_SCMI + bool "Enable driver for SCMI voltage domain regulators" + depends on DM_REGULATOR + select SCMI_AGENT + help + Enable this option if you want to support regulators exposed through + the SCMI voltage domain protocol by a SCMI server. diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index 9d58112dc..b2f5972ea 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -30,3 +30,4 @@ obj-$(CONFIG_DM_REGULATOR_TPS65910) += tps65910_regulator.o obj-$(CONFIG_DM_REGULATOR_TPS62360) += tps62360_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_STPMIC1) += stpmic1.o obj-$(CONFIG_DM_REGULATOR_TPS65941) += tps65941_regulator.o +obj-$(CONFIG_DM_REGULATOR_SCMI) += scmi_regulator.o diff --git a/drivers/power/regulator/scmi_regulator.c b/drivers/power/regulator/scmi_regulator.c new file mode 100644 index 000000000..b3142bf4e --- /dev/null +++ b/drivers/power/regulator/scmi_regulator.c @@ -0,0 +1,195 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020-2021 Linaro Limited + */ +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <scmi_agent.h> +#include <scmi_protocols.h> +#include <asm/types.h> +#include <dm/device.h> +#include <dm/device_compat.h> +#include <dm/device-internal.h> +#include <linux/kernel.h> +#include <power/regulator.h> + +/** + * struct scmi_regulator_platdata - Platform data for a scmi voltage domain regulator + * @domain_id: ID representing the regulator for the related SCMI agent + */ +struct scmi_regulator_platdata { + u32 domain_id; +}; + +static int scmi_voltd_set_enable(struct udevice *dev, bool enable) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_config_set_in in = { + .domain_id = pdata->domain_id, + .config = enable ? SCMI_VOLTD_CONFIG_ON : SCMI_VOLTD_CONFIG_OFF, + }; + struct scmi_voltd_config_set_out out; + struct scmi_msg msg = SCMI_MSG_IN(SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + SCMI_VOLTAGE_DOMAIN_CONFIG_SET, + in, out); + int ret; + + ret = devm_scmi_process_msg(dev->parent->parent, &msg); + if (ret) + return ret; + + ret = scmi_to_linux_errno(out.status); + if (ret) + return ret; + + return ret; +} + +static int scmi_voltd_get_enable(struct udevice *dev) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_config_get_in in = { + .domain_id = pdata->domain_id, + }; + struct scmi_voltd_config_get_out out; + struct scmi_msg msg = SCMI_MSG_IN(SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + SCMI_VOLTAGE_DOMAIN_CONFIG_GET, + in, out); + int ret; + + ret = devm_scmi_process_msg(dev->parent->parent, &msg); + if (ret < 0) + return ret; + + ret = scmi_to_linux_errno(out.status); + if (ret < 0) + return ret; + + return out.config == SCMI_VOLTD_CONFIG_ON; +} + +static int scmi_voltd_set_voltage_level(struct udevice *dev, int uV) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_level_set_in in = { + .domain_id = pdata->domain_id, + .voltage_level = uV, + }; + struct scmi_voltd_level_set_out out; + struct scmi_msg msg = SCMI_MSG_IN(SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + SCMI_VOLTAGE_DOMAIN_LEVEL_SET, + in, out); + int ret; + + ret = devm_scmi_process_msg(dev->parent->parent, &msg); + if (ret < 0) + return ret; + + return scmi_to_linux_errno(out.status); +} + +static int scmi_voltd_get_voltage_level(struct udevice *dev) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_level_get_in in = { + .domain_id = pdata->domain_id, + }; + struct scmi_voltd_level_get_out out; + struct scmi_msg msg = SCMI_MSG_IN(SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + SCMI_VOLTAGE_DOMAIN_LEVEL_GET, + in, out); + int ret; + + ret = devm_scmi_process_msg(dev->parent->parent, &msg); + if (ret < 0) + return ret; + + ret = scmi_to_linux_errno(out.status); + if (ret < 0) + return ret; + + return out.voltage_level; +} + +static int scmi_regulator_of_to_plat(struct udevice *dev) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + fdt_addr_t reg; + + reg = dev_read_addr(dev); + if (reg == FDT_ADDR_T_NONE) + return -EINVAL; + + pdata->domain_id = (u32)reg; + + return 0; +} + +static int scmi_regulator_probe(struct udevice *dev) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_attr_in in = { 0 }; + struct scmi_voltd_attr_out out = { 0 }; + struct scmi_msg scmi_msg = { + .protocol_id = SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + .message_id = SCMI_VOLTAGE_DOMAIN_ATTRIBUTES, + .in_msg = (u8 *)&in, + .in_msg_sz = sizeof(in), + .out_msg = (u8 *)&out, + .out_msg_sz = sizeof(out), + }; + int ret; + + /* Check voltage domain is known from SCMI server */ + in.domain_id = pdata->domain_id; + + ret = devm_scmi_process_msg(dev->parent->parent, &scmi_msg); + if (ret) { + dev_err(dev, "Failed to query voltage domain %u: %d\n", + pdata->domain_id, ret); + return -ENXIO; + } + + return 0; +} + +static const struct dm_regulator_ops scmi_voltd_ops = { + .get_value = scmi_voltd_get_voltage_level, + .set_value = scmi_voltd_set_voltage_level, + .get_enable = scmi_voltd_get_enable, + .set_enable = scmi_voltd_set_enable, +}; + +U_BOOT_DRIVER(scmi_regulator) = { + .name = "scmi_regulator", + .id = UCLASS_REGULATOR, + .ops = &scmi_voltd_ops, + .probe = scmi_regulator_probe, + .of_to_plat = scmi_regulator_of_to_plat, + .plat_auto = sizeof(struct scmi_regulator_platdata), +}; + +static int scmi_regulator_bind(struct udevice *dev) +{ + struct driver *drv; + ofnode node; + int ret; + + drv = DM_DRIVER_GET(scmi_regulator); + + ofnode_for_each_subnode(node, dev_ofnode(dev)) { + ret = device_bind(dev, drv, ofnode_get_name(node), + NULL, node, NULL); + if (ret) + return ret; + } + + return 0; +} + +U_BOOT_DRIVER(scmi_voltage_domain) = { + .name = "scmi_voltage_domain", + .id = UCLASS_NOP, + .bind = scmi_regulator_bind, +}; diff --git a/include/scmi_protocols.h b/include/scmi_protocols.h index ccab97c96..2db71697e 100644 --- a/include/scmi_protocols.h +++ b/include/scmi_protocols.h @@ -23,6 +23,7 @@ enum scmi_std_protocol { SCMI_PROTOCOL_ID_CLOCK = 0x14, SCMI_PROTOCOL_ID_SENSOR = 0x15, SCMI_PROTOCOL_ID_RESET_DOMAIN = 0x16, + SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN = 0x17, };
enum scmi_status_code { @@ -176,4 +177,116 @@ struct scmi_rd_reset_out { s32 status; };
+/* + * SCMI Voltage Domain Protocol + */ + +enum scmi_voltage_domain_message_id { + SCMI_VOLTAGE_DOMAIN_ATTRIBUTES = 0x3, + SCMI_VOLTAGE_DOMAIN_CONFIG_SET = 0x5, + SCMI_VOLTAGE_DOMAIN_CONFIG_GET = 0x6, + SCMI_VOLTAGE_DOMAIN_LEVEL_SET = 0x7, + SCMI_VOLTAGE_DOMAIN_LEVEL_GET = 0x8, +}; + +#define SCMI_VOLTD_NAME_LEN 16 + +#define SCMI_VOLTD_CONFIG_MASK GENMASK(3, 0) +#define SCMI_VOLTD_CONFIG_OFF 0 +#define SCMI_VOLTD_CONFIG_ON 0x7 + +/** + * struct scmi_voltd_attr_in - Payload for VOLTAGE_DOMAIN_ATTRIBUTES message + * @domain_id: SCMI voltage domain ID + */ +struct scmi_voltd_attr_in { + u32 domain_id; +}; + +/** + * struct scmi_voltd_attr_out - Payload for VOLTAGE_DOMAIN_ATTRIBUTES response + * @status: SCMI command status + * @attributes: Retrieved attributes of the voltage domain + * @name: Voltage domain name + */ +struct scmi_voltd_attr_out { + s32 status; + u32 attributes; + char name[SCMI_VOLTD_NAME_LEN]; +}; + +/** + * struct scmi_voltd_config_set_in - Message payload for VOLTAGE_CONFIG_SET cmd + * @domain_id: SCMI voltage domain ID + * @config: Configuration data of the voltage domain + */ +struct scmi_voltd_config_set_in { + u32 domain_id; + u32 config; +}; + +/** + * struct scmi_voltd_config_set_out - Response for VOLTAGE_CONFIG_SET command + * @status: SCMI command status + */ +struct scmi_voltd_config_set_out { + s32 status; +}; + +/** + * struct scmi_voltd_config_get_in - Message payload for VOLTAGE_CONFIG_GET cmd + * @domain_id: SCMI voltage domain ID + */ +struct scmi_voltd_config_get_in { + u32 domain_id; +}; + +/** + * struct scmi_voltd_config_get_out - Response for VOLTAGE_CONFIG_GET command + * @status: SCMI command status + * @config: Configuration data of the voltage domain + */ +struct scmi_voltd_config_get_out { + s32 status; + u32 config; +}; + +/** + * struct scmi_voltd_level_set_in - Message payload for VOLTAGE_LEVEL_SET cmd + * @domain_id: SCMI voltage domain ID + * @flags: Parameter flags for configuring target level + * @voltage_level: Target voltage level in microvolts (uV) + */ +struct scmi_voltd_level_set_in { + u32 domain_id; + u32 flags; + s32 voltage_level; +}; + +/** + * struct scmi_voltd_level_set_out - Response for VOLTAGE_LEVEL_SET command + * @status: SCMI command status + */ +struct scmi_voltd_level_set_out { + s32 status; +}; + +/** + * struct scmi_voltd_level_get_in - Message payload for VOLTAGE_LEVEL_GET cmd + * @domain_id: SCMI voltage domain ID + */ +struct scmi_voltd_level_get_in { + u32 domain_id; +}; + +/** + * struct scmi_voltd_level_get_out - Response for VOLTAGE_LEVEL_GET command + * @status: SCMI command status + * @voltage_level: Voltage level in microvolts (uV) + */ +struct scmi_voltd_level_get_out { + s32 status; + s32 voltage_level; +}; + #endif /* _SCMI_PROTOCOLS_H */
Implement sandbox regulator devices for SCMI voltage domains and test them in DM scmi tests.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jaehoon Chung jh80.chung@samsung.com --- Changes in v4: - no change
Changes in v2: - don't test IS_ENABLED(CONFIG_DM_REGULATOR_SCMI) in test/dm/scmi.c, it's expected enabled when CONFIG_FIRMWARE_SCMI is enabled in sandbox. --- arch/sandbox/dts/test.dts | 23 +++ arch/sandbox/include/asm/scmi_test.h | 20 ++ configs/sandbox_defconfig | 1 + drivers/firmware/scmi/sandbox-scmi_agent.c | 203 ++++++++++++++++++- drivers/firmware/scmi/sandbox-scmi_devices.c | 25 ++- test/dm/scmi.c | 58 ++++++ 6 files changed, 327 insertions(+), 3 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index e95f4631b..14d6983e7 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -451,6 +451,27 @@ reg = <0x16>; #reset-cells = <1>; }; + + protocol@17 { + reg = <0x17>; + + regulators { + #address-cells = <1>; + #size-cells = <0>; + + regul0_scmi0: reg@0 { + reg = <0>; + regulator-name = "sandbox-voltd0"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <3300000>; + }; + regul1_scmi0: reg@1 { + reg = <0x1>; + regulator-name = "sandbox-voltd1"; + regulator-min-microvolt = <1800000>; + }; + }; + }; };
sandbox-scmi-agent@1 { @@ -1217,6 +1238,8 @@ compatible = "sandbox,scmi-devices"; clocks = <&clk_scmi0 7>, <&clk_scmi0 3>, <&clk_scmi1 1>; resets = <&reset_scmi0 3>; + regul0-supply = <®ul0_scmi0>; + regul1-supply = <®ul1_scmi0>; };
pinctrl { diff --git a/arch/sandbox/include/asm/scmi_test.h b/arch/sandbox/include/asm/scmi_test.h index 3e8b0068f..9b7031531 100644 --- a/arch/sandbox/include/asm/scmi_test.h +++ b/arch/sandbox/include/asm/scmi_test.h @@ -31,6 +31,18 @@ struct sandbox_scmi_reset { bool asserted; };
+/** + * struct sandbox_scmi_voltd - Simulated voltage regulator exposed by SCMI + * @id: Identifier of the voltage domain used in the SCMI protocol + * @enabled: Regulator state: true if on, false if off + * @voltage_uv: Regulator current voltage in microvoltd (uV) + */ +struct sandbox_scmi_voltd { + uint id; + bool enabled; + int voltage_uv; +}; + /** * struct sandbox_scmi_agent - Simulated SCMI service seen by SCMI agent * @idx: Identifier for the SCMI agent, its index @@ -38,6 +50,8 @@ struct sandbox_scmi_reset { * @clk_count: Simulated clocks array size * @clk: Simulated reset domains * @clk_count: Simulated reset domains array size + * @voltd: Simulated voltage domains (regulators) + * @voltd_count: Simulated voltage domains array size */ struct sandbox_scmi_agent { uint idx; @@ -45,6 +59,8 @@ struct sandbox_scmi_agent { size_t clk_count; struct sandbox_scmi_reset *reset; size_t reset_count; + struct sandbox_scmi_voltd *voltd; + size_t voltd_count; };
/** @@ -63,12 +79,16 @@ struct sandbox_scmi_service { * @clk_count: Number of clock devices probed * @reset: Array the reset controller devices * @reset_count: Number of reset controller devices probed + * @regul: Array regulator devices + * @regul_count: Number of regulator devices probed */ struct sandbox_scmi_devices { struct clk *clk; size_t clk_count; struct reset_ctl *reset; size_t reset_count; + struct udevice **regul; + size_t regul_count; };
#ifdef CONFIG_SCMI_FIRMWARE diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 0c7674efc..790158445 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -214,6 +214,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y CONFIG_REGULATOR_S5M8767=y CONFIG_DM_REGULATOR_SANDBOX=y +CONFIG_DM_REGULATOR_SCMI=y CONFIG_REGULATOR_TPS65090=y CONFIG_DM_PWM=y CONFIG_PWM_SANDBOX=y diff --git a/drivers/firmware/scmi/sandbox-scmi_agent.c b/drivers/firmware/scmi/sandbox-scmi_agent.c index 35de68c75..3eafc49bd 100644 --- a/drivers/firmware/scmi/sandbox-scmi_agent.c +++ b/drivers/firmware/scmi/sandbox-scmi_agent.c @@ -19,14 +19,15 @@ * SCMI protocols embedded in U-Boot. Currently: * - SCMI clock protocol: emulate 2 agents each exposing few clocks * - SCMI reset protocol: emulate 1 agents each exposing a reset + * - SCMI voltage domain protocol: emulate 1 agent exposing 2 regulators * - * Agent #0 simulates 2 clocks and 1 reset domain. + * Agent #0 simulates 2 clocks, 1 reset domain and 1 voltage domain. * See IDs in scmi0_clk[]/scmi0_reset[] and "sandbox-scmi-agent@0" in test.dts. * * Agent #1 simulates 1 clock. * See IDs in scmi1_clk[] and "sandbox-scmi-agent@1" in test.dts. * - * All clocks are default disabled and reset levels down. + * All clocks and regulators are default disabled and reset controller down. * * This Driver exports sandbox_scmi_service_ct() for the test sequence to * get the state of the simulated services (clock state, rate, ...) and @@ -45,6 +46,11 @@ static struct sandbox_scmi_reset scmi0_reset[] = { { .id = 3 }, };
+static struct sandbox_scmi_voltd scmi0_voltd[] = { + { .id = 0, .voltage_uv = 3300000 }, + { .id = 1, .voltage_uv = 1800000 }, +}; + static struct sandbox_scmi_clk scmi1_clk[] = { { .id = 1, .rate = 44 }, }; @@ -81,6 +87,13 @@ static void debug_print_agent_state(struct udevice *dev, char *str) agent->reset_count, agent->reset_count ? agent->reset[0].asserted : -1, agent->reset_count > 1 ? agent->reset[1].asserted : -1); + dev_dbg(dev, " scmi%u_voltd (%zu): %u/%d, %u/%d, ...\n", + agent->idx, + agent->voltd_count, + agent->voltd_count ? agent->voltd[0].enabled : -1, + agent->voltd_count ? agent->voltd[0].voltage_uv : -1, + agent->voltd_count ? agent->voltd[1].enabled : -1, + agent->voltd_count ? agent->voltd[1].voltage_uv : -1); };
static struct sandbox_scmi_clk *get_scmi_clk_state(uint agent_id, uint clock_id) @@ -123,6 +136,20 @@ static struct sandbox_scmi_reset *get_scmi_reset_state(uint agent_id, return NULL; }
+static struct sandbox_scmi_voltd *get_scmi_voltd_state(uint agent_id, + uint domain_id) +{ + size_t n; + + if (agent_id == 0) { + for (n = 0; n < ARRAY_SIZE(scmi0_voltd); n++) + if (scmi0_voltd[n].id == domain_id) + return scmi0_voltd + n; + } + + return NULL; +} + /* * Sandbox SCMI agent ops */ @@ -290,6 +317,160 @@ static int sandbox_scmi_rd_reset(struct udevice *dev, struct scmi_msg *msg) return 0; }
+static int sandbox_scmi_voltd_attribs(struct udevice *dev, struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_attr_in *in = NULL; + struct scmi_voltd_attr_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_attr_in *)msg->in_msg; + out = (struct scmi_voltd_attr_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else { + memset(out, 0, sizeof(*out)); + snprintf(out->name, sizeof(out->name), "regu%u", in->domain_id); + + out->status = SCMI_SUCCESS; + } + + return 0; +} + +static int sandbox_scmi_voltd_config_set(struct udevice *dev, + struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_config_set_in *in = NULL; + struct scmi_voltd_config_set_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_config_set_in *)msg->in_msg; + out = (struct scmi_voltd_config_set_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else if (in->config & ~SCMI_VOLTD_CONFIG_MASK) { + dev_err(dev, "Invalid config value 0x%x\n", in->config); + + out->status = SCMI_INVALID_PARAMETERS; + } else if (in->config != SCMI_VOLTD_CONFIG_ON && + in->config != SCMI_VOLTD_CONFIG_OFF) { + dev_err(dev, "Unexpected custom value 0x%x\n", in->config); + + out->status = SCMI_INVALID_PARAMETERS; + } else { + voltd_state->enabled = in->config == SCMI_VOLTD_CONFIG_ON; + out->status = SCMI_SUCCESS; + } + + return 0; +} + +static int sandbox_scmi_voltd_config_get(struct udevice *dev, + struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_config_get_in *in = NULL; + struct scmi_voltd_config_get_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_config_get_in *)msg->in_msg; + out = (struct scmi_voltd_config_get_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else { + if (voltd_state->enabled) + out->config = SCMI_VOLTD_CONFIG_ON; + else + out->config = SCMI_VOLTD_CONFIG_OFF; + + out->status = SCMI_SUCCESS; + } + + return 0; +} + +static int sandbox_scmi_voltd_level_set(struct udevice *dev, + struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_level_set_in *in = NULL; + struct scmi_voltd_level_set_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_level_set_in *)msg->in_msg; + out = (struct scmi_voltd_level_set_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else { + voltd_state->voltage_uv = in->voltage_level; + out->status = SCMI_SUCCESS; + } + + return 0; +} + +static int sandbox_scmi_voltd_level_get(struct udevice *dev, + struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_level_get_in *in = NULL; + struct scmi_voltd_level_get_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_level_get_in *)msg->in_msg; + out = (struct scmi_voltd_level_get_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else { + out->voltage_level = voltd_state->voltage_uv; + out->status = SCMI_SUCCESS; + } + + return 0; +} + static int sandbox_scmi_test_process_msg(struct udevice *dev, struct scmi_msg *msg) { @@ -316,6 +497,22 @@ static int sandbox_scmi_test_process_msg(struct udevice *dev, break; } break; + case SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN: + switch (msg->message_id) { + case SCMI_VOLTAGE_DOMAIN_ATTRIBUTES: + return sandbox_scmi_voltd_attribs(dev, msg); + case SCMI_VOLTAGE_DOMAIN_CONFIG_SET: + return sandbox_scmi_voltd_config_set(dev, msg); + case SCMI_VOLTAGE_DOMAIN_CONFIG_GET: + return sandbox_scmi_voltd_config_get(dev, msg); + case SCMI_VOLTAGE_DOMAIN_LEVEL_SET: + return sandbox_scmi_voltd_level_set(dev, msg); + case SCMI_VOLTAGE_DOMAIN_LEVEL_GET: + return sandbox_scmi_voltd_level_get(dev, msg); + default: + break; + } + break; case SCMI_PROTOCOL_ID_BASE: case SCMI_PROTOCOL_ID_POWER_DOMAIN: case SCMI_PROTOCOL_ID_SYSTEM: @@ -367,6 +564,8 @@ static int sandbox_scmi_test_probe(struct udevice *dev) .clk_count = ARRAY_SIZE(scmi0_clk), .reset = scmi0_reset, .reset_count = ARRAY_SIZE(scmi0_reset), + .voltd = scmi0_voltd, + .voltd_count = ARRAY_SIZE(scmi0_voltd), }; break; case '1': diff --git a/drivers/firmware/scmi/sandbox-scmi_devices.c b/drivers/firmware/scmi/sandbox-scmi_devices.c index 1a6fafbf5..aab5782fd 100644 --- a/drivers/firmware/scmi/sandbox-scmi_devices.c +++ b/drivers/firmware/scmi/sandbox-scmi_devices.c @@ -1,16 +1,18 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020, Linaro Limited + * Copyright (C) 2020-2021, Linaro Limited */
#include <common.h> #include <clk.h> #include <dm.h> +#include <log.h> #include <malloc.h> #include <reset.h> #include <asm/io.h> #include <asm/scmi_test.h> #include <dm/device_compat.h> +#include <power/regulator.h>
/* * Simulate to some extent a SCMI exchange. @@ -21,16 +23,19 @@
#define SCMI_TEST_DEVICES_CLK_COUNT 3 #define SCMI_TEST_DEVICES_RD_COUNT 1 +#define SCMI_TEST_DEVICES_VOLTD_COUNT 2
/* * struct sandbox_scmi_device_priv - Storage for device handles used by test * @clk: Array of clock instances used by tests * @reset_clt: Array of the reset controller instances used by tests + * @regulators: Array of regulator device references used by the tests * @devices: Resources exposed by sandbox_scmi_devices_ctx() */ struct sandbox_scmi_device_priv { struct clk clk[SCMI_TEST_DEVICES_CLK_COUNT]; struct reset_ctl reset_ctl[SCMI_TEST_DEVICES_RD_COUNT]; + struct udevice *regulators[SCMI_TEST_DEVICES_VOLTD_COUNT]; struct sandbox_scmi_devices devices; };
@@ -74,6 +79,8 @@ static int sandbox_scmi_devices_probe(struct udevice *dev) .clk_count = SCMI_TEST_DEVICES_CLK_COUNT, .reset = priv->reset_ctl, .reset_count = SCMI_TEST_DEVICES_RD_COUNT, + .regul = priv->regulators, + .regul_count = SCMI_TEST_DEVICES_VOLTD_COUNT, };
for (n = 0; n < SCMI_TEST_DEVICES_CLK_COUNT; n++) { @@ -92,8 +99,24 @@ static int sandbox_scmi_devices_probe(struct udevice *dev) } }
+ for (n = 0; n < SCMI_TEST_DEVICES_VOLTD_COUNT; n++) { + char name[32]; + + ret = snprintf(name, sizeof(name), "regul%zu-supply", n); + assert(ret >= 0 && ret < sizeof(name)); + + ret = device_get_supply_regulator(dev, name, + priv->devices.regul + n); + if (ret) { + dev_err(dev, "%s: Failed on voltd %zu\n", __func__, n); + goto err_regul; + } + } + return 0;
+err_regul: + n = SCMI_TEST_DEVICES_RD_COUNT; err_reset: for (; n > 0; n--) reset_free(priv->devices.reset + n - 1); diff --git a/test/dm/scmi.c b/test/dm/scmi.c index be60b44b3..792410338 100644 --- a/test/dm/scmi.c +++ b/test/dm/scmi.c @@ -20,6 +20,7 @@ #include <dm/device-internal.h> #include <dm/test.h> #include <linux/kconfig.h> +#include <power/regulator.h> #include <test/ut.h>
static int ut_assert_scmi_state_preprobe(struct unit_test_state *uts) @@ -47,6 +48,7 @@ static int ut_assert_scmi_state_postprobe(struct unit_test_state *uts, ut_asserteq(3, scmi_devices->clk_count); if (IS_ENABLED(CONFIG_RESET_SCMI)) ut_asserteq(1, scmi_devices->reset_count); + ut_asserteq(2, scmi_devices->regul_count);
/* State of the simulated SCMI server exposed */ scmi_ctx = sandbox_scmi_service_ctx(); @@ -58,6 +60,8 @@ static int ut_assert_scmi_state_postprobe(struct unit_test_state *uts, ut_assertnonnull(scmi_ctx->agent[0]->clk); ut_asserteq(1, scmi_ctx->agent[0]->reset_count); ut_assertnonnull(scmi_ctx->agent[0]->reset); + ut_asserteq(2, scmi_ctx->agent[0]->voltd_count); + ut_assertnonnull(scmi_ctx->agent[0]->voltd);
ut_assertnonnull(scmi_ctx->agent[1]); ut_assertnonnull(scmi_ctx->agent[1]->clk); @@ -201,3 +205,57 @@ static int dm_test_scmi_resets(struct unit_test_state *uts) }
DM_TEST(dm_test_scmi_resets, UT_TESTF_SCAN_FDT); + +static int dm_test_scmi_voltage_domains(struct unit_test_state *uts) +{ + struct sandbox_scmi_devices *scmi_devices; + struct sandbox_scmi_service *scmi_ctx; + struct sandbox_scmi_voltd *sandbox_voltd; + struct dm_regulator_uclass_plat *uc_pdata; + struct udevice *dev; + struct udevice *regul_dev; + + ut_assertok(load_sandbox_scmi_test_devices(uts, &dev)); + + scmi_devices = sandbox_scmi_devices_ctx(dev); + scmi_ctx = sandbox_scmi_service_ctx(); + + /* Set/Get an SCMI voltage domain level */ + sandbox_voltd = &scmi_ctx->agent[0]->voltd[0]; + regul_dev = scmi_devices->regul[0]; + ut_assert(regul_dev); + + uc_pdata = dev_get_uclass_plat(regul_dev); + ut_assert(uc_pdata); + + ut_assertok(regulator_set_value(regul_dev, uc_pdata->min_uV)); + ut_asserteq(sandbox_voltd->voltage_uv, uc_pdata->min_uV); + + ut_assert(regulator_get_value(regul_dev) == uc_pdata->min_uV); + + ut_assertok(regulator_set_value(regul_dev, uc_pdata->max_uV)); + ut_asserteq(sandbox_voltd->voltage_uv, uc_pdata->max_uV); + + ut_assert(regulator_get_value(regul_dev) == uc_pdata->max_uV); + + /* Enable/disable SCMI voltage domains */ + ut_assertok(regulator_set_enable(scmi_devices->regul[0], false)); + ut_assertok(regulator_set_enable(scmi_devices->regul[1], false)); + ut_assert(!scmi_ctx->agent[0]->voltd[0].enabled); + ut_assert(!scmi_ctx->agent[0]->voltd[1].enabled); + + ut_assertok(regulator_set_enable(scmi_devices->regul[0], true)); + ut_assert(scmi_ctx->agent[0]->voltd[0].enabled); + ut_assert(!scmi_ctx->agent[0]->voltd[1].enabled); + + ut_assertok(regulator_set_enable(scmi_devices->regul[1], true)); + ut_assert(scmi_ctx->agent[0]->voltd[0].enabled); + ut_assert(scmi_ctx->agent[0]->voltd[1].enabled); + + ut_assertok(regulator_set_enable(scmi_devices->regul[0], false)); + ut_assert(!scmi_ctx->agent[0]->voltd[0].enabled); + ut_assert(scmi_ctx->agent[0]->voltd[1].enabled); + + return release_sandbox_scmi_test_devices(uts, dev); +} +DM_TEST(dm_test_scmi_voltage_domains, UT_TESTF_SCAN_FDT);
Fix inline comments and empty line in scmi driver and test files.
Remove test on IS_ENABLED(CONFIG_*_SCMI) in test/dm/scmi.c since these configuration are expected enabled when CONFIG_FIRMWARE_SCMI is enabled in sandbox configuration.
Changes in v2: - discard adding tests on IS_ENABLED(CONFIG_*_SCMI) in test/dm/scmi.c for the reason stated in commit log. --- arch/sandbox/include/asm/scmi_test.h | 5 +++-- drivers/firmware/scmi/sandbox-scmi_agent.c | 4 ++-- test/dm/scmi.c | 15 ++------------- 3 files changed, 7 insertions(+), 17 deletions(-)
diff --git a/arch/sandbox/include/asm/scmi_test.h b/arch/sandbox/include/asm/scmi_test.h index 9b7031531..2930e686d 100644 --- a/arch/sandbox/include/asm/scmi_test.h +++ b/arch/sandbox/include/asm/scmi_test.h @@ -24,6 +24,7 @@ struct sandbox_scmi_clk {
/** * struct sandbox_scmi_reset - Simulated reset controller exposed by SCMI + * @id: Identifier of the reset controller used in the SCMI protocol * @asserted: Reset control state: true if asserted, false if desasserted */ struct sandbox_scmi_reset { @@ -48,8 +49,8 @@ struct sandbox_scmi_voltd { * @idx: Identifier for the SCMI agent, its index * @clk: Simulated clocks * @clk_count: Simulated clocks array size - * @clk: Simulated reset domains - * @clk_count: Simulated reset domains array size + * @reset: Simulated reset domains + * @reset_count: Simulated reset domains array size * @voltd: Simulated voltage domains (regulators) * @voltd_count: Simulated voltage domains array size */ diff --git a/drivers/firmware/scmi/sandbox-scmi_agent.c b/drivers/firmware/scmi/sandbox-scmi_agent.c index 3eafc49bd..56125a57b 100644 --- a/drivers/firmware/scmi/sandbox-scmi_agent.c +++ b/drivers/firmware/scmi/sandbox-scmi_agent.c @@ -18,7 +18,7 @@ * processing. It simulates few of the SCMI services for some of the * SCMI protocols embedded in U-Boot. Currently: * - SCMI clock protocol: emulate 2 agents each exposing few clocks - * - SCMI reset protocol: emulate 1 agents each exposing a reset + * - SCMI reset protocol: emulate 1 agent exposing a reset controller * - SCMI voltage domain protocol: emulate 1 agent exposing 2 regulators * * Agent #0 simulates 2 clocks, 1 reset domain and 1 voltage domain. @@ -29,7 +29,7 @@ * * All clocks and regulators are default disabled and reset controller down. * - * This Driver exports sandbox_scmi_service_ct() for the test sequence to + * This Driver exports sandbox_scmi_service_ctx() for the test sequence to * get the state of the simulated services (clock state, rate, ...) and * check back-end device state reflects the request send through the * various uclass devices, as clocks and reset controllers. diff --git a/test/dm/scmi.c b/test/dm/scmi.c index 792410338..2eaf06392 100644 --- a/test/dm/scmi.c +++ b/test/dm/scmi.c @@ -44,10 +44,8 @@ static int ut_assert_scmi_state_postprobe(struct unit_test_state *uts, scmi_devices = sandbox_scmi_devices_ctx(dev);
ut_assertnonnull(scmi_devices); - if (IS_ENABLED(CONFIG_CLK_SCMI)) - ut_asserteq(3, scmi_devices->clk_count); - if (IS_ENABLED(CONFIG_RESET_SCMI)) - ut_asserteq(1, scmi_devices->reset_count); + ut_asserteq(3, scmi_devices->clk_count); + ut_asserteq(1, scmi_devices->reset_count); ut_asserteq(2, scmi_devices->regul_count);
/* State of the simulated SCMI server exposed */ @@ -110,7 +108,6 @@ static int dm_test_scmi_sandbox_agent(struct unit_test_state *uts)
return ret; } - DM_TEST(dm_test_scmi_sandbox_agent, UT_TESTF_SCAN_FDT);
static int dm_test_scmi_clocks(struct unit_test_state *uts) @@ -121,9 +118,6 @@ static int dm_test_scmi_clocks(struct unit_test_state *uts) int ret_dev; int ret;
- if (!IS_ENABLED(CONFIG_CLK_SCMI)) - return 0; - ret = load_sandbox_scmi_test_devices(uts, &dev); if (ret) return ret; @@ -172,7 +166,6 @@ static int dm_test_scmi_clocks(struct unit_test_state *uts)
return release_sandbox_scmi_test_devices(uts, dev); } - DM_TEST(dm_test_scmi_clocks, UT_TESTF_SCAN_FDT);
static int dm_test_scmi_resets(struct unit_test_state *uts) @@ -182,9 +175,6 @@ static int dm_test_scmi_resets(struct unit_test_state *uts) struct udevice *dev = NULL; int ret;
- if (!IS_ENABLED(CONFIG_RESET_SCMI)) - return 0; - ret = load_sandbox_scmi_test_devices(uts, &dev); if (ret) return ret; @@ -203,7 +193,6 @@ static int dm_test_scmi_resets(struct unit_test_state *uts)
return release_sandbox_scmi_test_devices(uts, dev); } - DM_TEST(dm_test_scmi_resets, UT_TESTF_SCAN_FDT);
Add local variables agent0/agent1 to refer to SCMI sandbox context agent and ease readability of the test.
For consistency, rename regul_dev to regul0_dev and remove sandbox_voltd in dm_test_scmi_voltage_domains().
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- Changes in v4 - no change
Changes in v3 - new change added to the series, suggested from patch v2 review. --- test/dm/scmi.c | 100 +++++++++++++++++++++++++++---------------------- 1 file changed, 55 insertions(+), 45 deletions(-)
diff --git a/test/dm/scmi.c b/test/dm/scmi.c index 2eaf06392..c938e6d4f 100644 --- a/test/dm/scmi.c +++ b/test/dm/scmi.c @@ -39,6 +39,8 @@ static int ut_assert_scmi_state_postprobe(struct unit_test_state *uts, { struct sandbox_scmi_devices *scmi_devices; struct sandbox_scmi_service *scmi_ctx; + struct sandbox_scmi_agent *agent0; + struct sandbox_scmi_agent *agent1;
/* Device references to check context against test sequence */ scmi_devices = sandbox_scmi_devices_ctx(dev); @@ -50,20 +52,22 @@ static int ut_assert_scmi_state_postprobe(struct unit_test_state *uts,
/* State of the simulated SCMI server exposed */ scmi_ctx = sandbox_scmi_service_ctx(); + agent0 = scmi_ctx->agent[0]; + agent1 = scmi_ctx->agent[1];
ut_asserteq(2, scmi_ctx->agent_count);
- ut_assertnonnull(scmi_ctx->agent[0]); - ut_asserteq(2, scmi_ctx->agent[0]->clk_count); - ut_assertnonnull(scmi_ctx->agent[0]->clk); - ut_asserteq(1, scmi_ctx->agent[0]->reset_count); - ut_assertnonnull(scmi_ctx->agent[0]->reset); - ut_asserteq(2, scmi_ctx->agent[0]->voltd_count); - ut_assertnonnull(scmi_ctx->agent[0]->voltd); + ut_assertnonnull(agent0); + ut_asserteq(2, agent0->clk_count); + ut_assertnonnull(agent0->clk); + ut_asserteq(1, agent0->reset_count); + ut_assertnonnull(agent0->reset); + ut_asserteq(2, agent0->voltd_count); + ut_assertnonnull(agent0->voltd);
- ut_assertnonnull(scmi_ctx->agent[1]); - ut_assertnonnull(scmi_ctx->agent[1]->clk); - ut_asserteq(1, scmi_ctx->agent[1]->clk_count); + ut_assertnonnull(agent1); + ut_assertnonnull(agent1->clk); + ut_asserteq(1, agent1->clk_count);
return 0; } @@ -114,6 +118,8 @@ static int dm_test_scmi_clocks(struct unit_test_state *uts) { struct sandbox_scmi_devices *scmi_devices; struct sandbox_scmi_service *scmi_ctx; + struct sandbox_scmi_agent *agent0; + struct sandbox_scmi_agent *agent1; struct udevice *dev = NULL; int ret_dev; int ret; @@ -124,6 +130,8 @@ static int dm_test_scmi_clocks(struct unit_test_state *uts)
scmi_devices = sandbox_scmi_devices_ctx(dev); scmi_ctx = sandbox_scmi_service_ctx(); + agent0 = scmi_ctx->agent[0]; + agent1 = scmi_ctx->agent[1];
/* Test SCMI clocks rate manipulation */ ut_asserteq(1000, clk_get_rate(&scmi_devices->clk[0])); @@ -133,9 +141,9 @@ static int dm_test_scmi_clocks(struct unit_test_state *uts) ret_dev = clk_set_rate(&scmi_devices->clk[1], 1088); ut_assert(!ret_dev || ret_dev == 1088);
- ut_asserteq(1000, scmi_ctx->agent[0]->clk[0].rate); - ut_asserteq(1088, scmi_ctx->agent[0]->clk[1].rate); - ut_asserteq(44, scmi_ctx->agent[1]->clk[0].rate); + ut_asserteq(1000, agent0->clk[0].rate); + ut_asserteq(1088, agent0->clk[1].rate); + ut_asserteq(44, agent1->clk[0].rate);
ut_asserteq(1000, clk_get_rate(&scmi_devices->clk[0])); ut_asserteq(1088, clk_get_rate(&scmi_devices->clk[1])); @@ -146,23 +154,23 @@ static int dm_test_scmi_clocks(struct unit_test_state *uts) ut_assert(!ret_dev || ret_dev == 333);
/* Test SCMI clocks gating manipulation */ - ut_assert(!scmi_ctx->agent[0]->clk[0].enabled); - ut_assert(!scmi_ctx->agent[0]->clk[1].enabled); - ut_assert(!scmi_ctx->agent[1]->clk[0].enabled); + ut_assert(!agent0->clk[0].enabled); + ut_assert(!agent0->clk[1].enabled); + ut_assert(!agent1->clk[0].enabled);
ut_asserteq(0, clk_enable(&scmi_devices->clk[1])); ut_asserteq(0, clk_enable(&scmi_devices->clk[2]));
- ut_assert(!scmi_ctx->agent[0]->clk[0].enabled); - ut_assert(scmi_ctx->agent[0]->clk[1].enabled); - ut_assert(scmi_ctx->agent[1]->clk[0].enabled); + ut_assert(!agent0->clk[0].enabled); + ut_assert(agent0->clk[1].enabled); + ut_assert(agent1->clk[0].enabled);
ut_assertok(clk_disable(&scmi_devices->clk[1])); ut_assertok(clk_disable(&scmi_devices->clk[2]));
return release_sandbox_scmi_test_devices(uts, dev); } @@ -172,6 +180,7 @@ static int dm_test_scmi_resets(struct unit_test_state *uts) { struct sandbox_scmi_devices *scmi_devices; struct sandbox_scmi_service *scmi_ctx; + struct sandbox_scmi_agent *agent0; struct udevice *dev = NULL; int ret;
@@ -181,15 +190,16 @@ static int dm_test_scmi_resets(struct unit_test_state *uts)
/* Test SCMI resect controller manipulation */ - ut_assert(!scmi_ctx->agent[0]->reset[0].asserted) + ut_assert(!agent0->reset[0].asserted)
ut_assertok(reset_assert(&scmi_devices->reset[0])); - ut_assert(scmi_ctx->agent[0]->reset[0].asserted) + ut_assert(agent0->reset[0].asserted)
ut_assertok(reset_deassert(&scmi_devices->reset[0])); - ut_assert(!scmi_ctx->agent[0]->reset[0].asserted); + ut_assert(!agent0->reset[0].asserted);
return release_sandbox_scmi_test_devices(uts, dev); } @@ -199,51 +209,51 @@ static int dm_test_scmi_voltage_domains(struct unit_test_state *uts) { struct sandbox_scmi_devices *scmi_devices; struct sandbox_scmi_service *scmi_ctx; - struct sandbox_scmi_voltd *sandbox_voltd; + struct sandbox_scmi_agent *agent0; struct dm_regulator_uclass_plat *uc_pdata; struct udevice *dev; - struct udevice *regul_dev; + struct udevice *regul0_dev;
/* Set/Get an SCMI voltage domain level */ - sandbox_voltd = &scmi_ctx->agent[0]->voltd[0]; - regul_dev = scmi_devices->regul[0]; - ut_assert(regul_dev); + regul0_dev = scmi_devices->regul[0]; + ut_assert(regul0_dev);
- uc_pdata = dev_get_uclass_plat(regul_dev); + uc_pdata = dev_get_uclass_plat(regul0_dev); ut_assert(uc_pdata);
- ut_assertok(regulator_set_value(regul_dev, uc_pdata->min_uV)); - ut_asserteq(sandbox_voltd->voltage_uv, uc_pdata->min_uV); + ut_assertok(regulator_set_value(regul0_dev, uc_pdata->min_uV)); + ut_asserteq(agent0->voltd[0].voltage_uv, uc_pdata->min_uV);
- ut_assert(regulator_get_value(regul_dev) == uc_pdata->min_uV); + ut_assert(regulator_get_value(regul0_dev) == uc_pdata->min_uV);
- ut_assertok(regulator_set_value(regul_dev, uc_pdata->max_uV)); - ut_asserteq(sandbox_voltd->voltage_uv, uc_pdata->max_uV); + ut_assertok(regulator_set_value(regul0_dev, uc_pdata->max_uV)); + ut_asserteq(agent0->voltd[0].voltage_uv, uc_pdata->max_uV);
- ut_assert(regulator_get_value(regul_dev) == uc_pdata->max_uV); + ut_assert(regulator_get_value(regul0_dev) == uc_pdata->max_uV);
/* Enable/disable SCMI voltage domains */ ut_assertok(regulator_set_enable(scmi_devices->regul[0], false)); ut_assertok(regulator_set_enable(scmi_devices->regul[1], false)); - ut_assert(!scmi_ctx->agent[0]->voltd[0].enabled); - ut_assert(!scmi_ctx->agent[0]->voltd[1].enabled); + ut_assert(!agent0->voltd[0].enabled); + ut_assert(!agent0->voltd[1].enabled);
ut_assertok(regulator_set_enable(scmi_devices->regul[0], true)); - ut_assert(scmi_ctx->agent[0]->voltd[0].enabled); - ut_assert(!scmi_ctx->agent[0]->voltd[1].enabled); + ut_assert(agent0->voltd[0].enabled); + ut_assert(!agent0->voltd[1].enabled);
ut_assertok(regulator_set_enable(scmi_devices->regul[1], true)); - ut_assert(scmi_ctx->agent[0]->voltd[0].enabled); - ut_assert(scmi_ctx->agent[0]->voltd[1].enabled); + ut_assert(agent0->voltd[0].enabled); + ut_assert(agent0->voltd[1].enabled);
ut_assertok(regulator_set_enable(scmi_devices->regul[0], false)); - ut_assert(!scmi_ctx->agent[0]->voltd[0].enabled); - ut_assert(scmi_ctx->agent[0]->voltd[1].enabled); + ut_assert(!agent0->voltd[0].enabled); + ut_assert(agent0->voltd[1].enabled);
On Mon, 8 Mar 2021 at 14:38, Etienne Carriere etienne.carriere@linaro.org wrote:
Changes in v4
- no change
Changes in v3
Fix header file inclusion order in SCMI regulators driver.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- Changes in v4 - new change added to the series. --- drivers/firmware/scmi/scmi_agent-uclass.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index f13e46c36..91632588a 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -5,11 +5,10 @@
#include <common.h> #include <dm.h> -#include <dm/device_compat.h> #include <errno.h> #include <scmi_agent-uclass.h> #include <scmi_protocols.h> - +#include <dm/device_compat.h> #include <dm/device-internal.h> #include <linux/compat.h>
Changes in v4
Link: [1] https://protect2.fireeye.com/v1/url?k=4762535a-18f96b93-4763d815-0cc47a336fa... Link: [2] https://protect2.fireeye.com/v1/url?k=3da6e589-623ddd40-3da76ec6-0cc47a336fa... Signed-off-by: Etienne Carriere etienne.carriere@linaro.org
Best Regards, Jaehoon Chung
Changes in v4:
Changes in v3:
Changes in v2:
- no change
Example:
reg = <0x17>;
regulators {
reg = <0x0>;
reg = <0x9>;
return -ENXIO;
default: break; }break;
- bool "Enable driver for SCMI voltage domain regulators"
- depends on DM_REGULATOR
- select SCMI_AGENT
help
- Copyright (C) 2020-2021 Linaro Limited
- struct scmi_regulator_platdata - Platform data for a scmi voltage domain regulator
- @domain_id: ID representing the regulator for the related SCMI agent
- u32 domain_id;
- struct scmi_regulator_platdata *pdata = dev_get_plat(dev);
- struct scmi_voltd_config_set_in in = {
- struct scmi_voltd_config_set_out out;
- struct scmi_msg msg = SCMI_MSG_IN(SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN,
in, out);
- int ret;
- ret = devm_scmi_process_msg(dev->parent->parent, &msg);
- if (ret)
return ret;
- ret = scmi_to_linux_errno(out.status);
- if (ret)
return ret;
- return ret;
- struct scmi_voltd_config_get_in in = {
- struct scmi_voltd_config_get_out out;
in, out);
- int ret;
- if (ret < 0)
return ret;
- if (ret < 0)
return ret;
- return out.config == SCMI_VOLTD_CONFIG_ON;
- struct scmi_voltd_level_set_in in = {
- struct scmi_voltd_level_set_out out;
in, out);
- int ret;
- if (ret < 0)
return ret;
- return scmi_to_linux_errno(out.status);
- struct scmi_voltd_level_get_in in = {
- struct scmi_voltd_level_get_out out;
in, out);
- int ret;
- if (ret < 0)
return ret;
- if (ret < 0)
return ret;
- return out.voltage_level;
- fdt_addr_t reg;
- reg = dev_read_addr(dev);
- if (reg == FDT_ADDR_T_NONE)
return -EINVAL;
- pdata->domain_id = (u32)reg;
- struct scmi_voltd_attr_in in = { 0 };
- struct scmi_voltd_attr_out out = { 0 };
- struct scmi_msg scmi_msg = {
- int ret;
- /* Check voltage domain is known from SCMI server */
- in.domain_id = pdata->domain_id;
- ret = devm_scmi_process_msg(dev->parent->parent, &scmi_msg);
- if (ret) {
return -ENXIO;
- .get_value = scmi_voltd_get_voltage_level,
- .set_value = scmi_voltd_set_voltage_level,
- .get_enable = scmi_voltd_get_enable,
- .set_enable = scmi_voltd_set_enable,
- .name = "scmi_regulator",
- .id = UCLASS_REGULATOR,
- .ops = &scmi_voltd_ops,
- .probe = scmi_regulator_probe,
- .of_to_plat = scmi_regulator_of_to_plat,
- .plat_auto = sizeof(struct scmi_regulator_platdata),
- struct driver *drv;
- ofnode node;
- int ret;
- drv = DM_DRIVER_GET(scmi_regulator);
- ofnode_for_each_subnode(node, dev_ofnode(dev)) {
NULL, node, NULL);
if (ret)
return ret;
- .name = "scmi_voltage_domain",
- .id = UCLASS_NOP,
- .bind = scmi_regulator_bind,
- SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN = 0x17,
- SCMI Voltage Domain Protocol
- SCMI_VOLTAGE_DOMAIN_ATTRIBUTES = 0x3,
- SCMI_VOLTAGE_DOMAIN_CONFIG_SET = 0x5,
- SCMI_VOLTAGE_DOMAIN_CONFIG_GET = 0x6,
- SCMI_VOLTAGE_DOMAIN_LEVEL_SET = 0x7,
- SCMI_VOLTAGE_DOMAIN_LEVEL_GET = 0x8,
- struct scmi_voltd_attr_in - Payload for VOLTAGE_DOMAIN_ATTRIBUTES message
- @domain_id: SCMI voltage domain ID
- u32 domain_id;
- struct scmi_voltd_attr_out - Payload for VOLTAGE_DOMAIN_ATTRIBUTES response
- @status: SCMI command status
- @attributes: Retrieved attributes of the voltage domain
- @name: Voltage domain name
- s32 status;
- u32 attributes;
- char name[SCMI_VOLTD_NAME_LEN];
- struct scmi_voltd_config_set_in - Message payload for VOLTAGE_CONFIG_SET cmd
- @config: Configuration data of the voltage domain
- u32 domain_id;
- u32 config;
- struct scmi_voltd_config_set_out - Response for VOLTAGE_CONFIG_SET command
- s32 status;
- struct scmi_voltd_config_get_in - Message payload for VOLTAGE_CONFIG_GET cmd
- u32 domain_id;
- struct scmi_voltd_config_get_out - Response for VOLTAGE_CONFIG_GET command
- s32 status;
- u32 config;
- struct scmi_voltd_level_set_in - Message payload for VOLTAGE_LEVEL_SET cmd
- @flags: Parameter flags for configuring target level
- @voltage_level: Target voltage level in microvolts (uV)
- u32 domain_id;
- u32 flags;
- s32 voltage_level;
- struct scmi_voltd_level_set_out - Response for VOLTAGE_LEVEL_SET command
- s32 status;
- struct scmi_voltd_level_get_in - Message payload for VOLTAGE_LEVEL_GET cmd
- u32 domain_id;
- struct scmi_voltd_level_get_out - Response for VOLTAGE_LEVEL_GET command
- @voltage_level: Voltage level in microvolts (uV)
- s32 status;
Link: [1] https://github.com/torvalds/linux/commit/0f80fcec08e9c50b8d2992cf26495673765... Link: [2] https://github.com/torvalds/linux/commit/2add5cacff3531e54c50b0832128299faa9... Signed-off-by: Etienne Carriere etienne.carriere@linaro.org Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Etienne Carriere
Jaehoon Chung
