[U-Boot] [RFC PATCH] dm: ensure device names are unique
It is possible for HW to contain multiple instances of the same device. In this case, the name passed to device_bind() may not be unique across all devices within its uclass. One example is a system with multiple identical PCI Ethernet devices. Another might be a system with multiple identical I2C GPIO expanders, each connected to a separate I2C bus, yet using the same I2C address on that bus and hence having the same DT node name.
Enhance the code to detect this situation, and append a sequence number so the device name to ensure uniqueness.
Signed-off-by: Stephen Warren swarren@nvidia.com --- Some possible issues with this patch:
1) Doing this in bind() rather than probe() means dev->seq isn't available, so can't be used to generate the unique name. This process should be done during bind() rather than probe() though, since devices can be seen (e.g. by running "dm tree") before they're probed. Perhaps the uclass_resolve_seq() should be called by bind() not probe().
2) uclass_find_device_by_name() needs to look up the uclass pointer again even though device_bind() already knows it.
3) Iterating over the list to find the count of devices in the uclass is a bit annoying. Should the uclass maintain this count so it doesn't need to be re-calculated each time? --- drivers/core/device-remove.c | 4 ++++ drivers/core/device.c | 23 ++++++++++++++++++++++- include/dm/device.h | 3 +++ 3 files changed, 29 insertions(+), 1 deletion(-)
diff --git a/drivers/core/device-remove.c b/drivers/core/device-remove.c index e1714b2202b6..a2400989024a 100644 --- a/drivers/core/device-remove.c +++ b/drivers/core/device-remove.c @@ -112,6 +112,10 @@ int device_unbind(struct udevice *dev)
devres_release_all(dev);
+ if (dev->flags & DM_FLAG_ALLOC_NAME) { + free((char *)dev->name); + dev->name = NULL; + } free(dev);
return 0; diff --git a/drivers/core/device.c b/drivers/core/device.c index 269087a084cf..fcac0073c642 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -30,7 +30,7 @@ int device_bind(struct udevice *parent, const struct driver *drv, const char *name, void *platdata, int of_offset, struct udevice **devp) { - struct udevice *dev; + struct udevice *dev, *dev2; struct uclass *uc; int size, ret = 0;
@@ -62,6 +62,23 @@ int device_bind(struct udevice *parent, const struct driver *drv, dev->driver = drv; dev->uclass = uc;
+ if (!uclass_find_device_by_name(uc->uc_drv->id, dev->name, &dev2)) { + char *unique_name; + int count; + size = strlen(name) + 4 + 1; + unique_name = malloc(size); + if (!unique_name) { + ret = -ENOMEM; + goto fail_alloc1; + } + dev->flags |= DM_FLAG_ALLOC_NAME; + dev->name = unique_name; + count = 0; + list_for_each_entry(dev2, &uc->dev_head, uclass_node) + count++; + snprintf(unique_name, size, "%s.%d", name, count); + } + dev->seq = -1; dev->req_seq = -1; if (CONFIG_IS_ENABLED(OF_CONTROL) && CONFIG_IS_ENABLED(DM_SEQ_ALIAS)) { @@ -186,6 +203,10 @@ fail_alloc2: dev->platdata = NULL; } fail_alloc1: + if (dev->flags & DM_FLAG_ALLOC_NAME) { + free((char *)dev->name); + dev->name = NULL; + } devres_release_all(dev);
free(dev); diff --git a/include/dm/device.h b/include/dm/device.h index dad7591dfacb..976ba72a550c 100644 --- a/include/dm/device.h +++ b/include/dm/device.h @@ -41,6 +41,9 @@ struct driver_info; /* Device is bound */ #define DM_FLAG_BOUND (1 << 6)
+/* DM is responsible for allocating and freeing device name */ +#define DM_FLAG_ALLOC_NAME (1 << 7) + /** * struct udevice - An instance of a driver *
- Doing this in bind() rather than probe() means dev->seq isn't
- uclass_find_device_by_name() needs to look up the uclass pointer again
- Iterating over the list to find the count of devices in the uclass is a
4) This causes "ut dm autobind" to fail. I'll investigate that locally, but won't bother reposting until the questions above are considered.
- This causes "ut dm autobind" to fail. I'll investigate that locally,
It looks like that's because I need to add "gd->dm_root && " to the start of the following condition:
- if (!uclass_find_device_by_name(uc->uc_drv->id, dev->name, &dev2)) {
... otherwise, the uc_class_get/find() nested inside that end up creating a second root uclass.
I can fold that into v2, pending any other comments.
Makes sense.
We (Simon and I) had discussion about this when I first added support for eth devices. He convinced me the correct time for seq to be evaluated is at probe time. I can dig through the mail history for reasons if you're interested.
Maybe we could add a parameter to provide the pointer and if it's NULL, then it gets looked up. Might be a bit noisy change, though. Is that optimization very valuable?
These lists aren't long, right? It seems like the optimization to store the value is only helpful if the lists could be expected to be long, or the size is looked up many times.
dev->name = NULL;
} free(dev); return 0;
char *unique_name;
int count;
if (!unique_name) {
ret = -ENOMEM;
goto fail_alloc1;
count = 0;
count++;
dev->name = NULL;
} devres_release_all(dev); free(dev);
- struct udevice - An instance of a driver
-- 2.8.1
That might be interesting. Right now, about the only thing I see moving the evaluation from probe to bind would do is very marginally increase the amount of work done in bind, which potentially might be skipped if a particular Ethernet device was never probed. I would not expect this to make a noticeable difference, especially since IIRC when the network is first used, all the Ethernet devices are probed anyway, so this just moves work around?
I don't imagine there are too many uclasses, so it's probably not going to save too much time. Still, Simon has in the past objected to code that parses DT scanning the DT to find parent offsets, and this feels like exactly the same kind of thing. I'm not personally concerned about it; simply pointing it out in case anyone wanted that to be addressed.
Yes, I don't imagine this would be a particular issue in practice.
Hi Stephen,
There's a somewhat deep design issue there, but so far I feel that having the numbering resolved when a device is probed works best. It is very seldom useful until then. Device names don't really need to match there sequence number.
There are essentially no optimisations in driver model at present. So far the benefit hasn't shown itself. Perhaps it won't in a boot loader...
Hi Stephen,
I would rather that the caller handles this. But failing this perhaps a new function that does it? Is this for the Ethernet use case?
On 04/27/2016 10:50 PM, Simon Glass wrote:
Hi Stephen,
Signed-off-by: Stephen Warren <swarren@nvidia.com swarren@nvidia.com>
Wouldn't all callers of this function simply call the new function? I'm not aware of any case where the code to avoid duplicate names would not be desired.
I hit this for the Ethernet case, but I believe it applies to any type of device at all; see another possible trigger case in the commit description.
Hi Stephen,
Hi Stephen,
In
all
identical
number so
This does not happen with devices from the device tree. It only happens with auto-probed devices. Your I2C GPIO example is odd but I'd rather solve that by using the device tree node name.
I'd like to avoid putting things in the base code that we don't need early on in boot. How about a helper function for those subsystems that create devices outside the device tree system?
On 04/29/2016 07:23 AM, Simon Glass wrote:
Hi Stephen,
Hi Stephen,
In
all
identical
number so
DT itself imposes no such rule; node names must be unique only within their parent node but there's no restriction on identical node names appearing in different parts of the tree.
If U-Boot imposes that rule on DT, then there's no way in general that we can guarantee U-Boot will be able to use standard DTs (i.e. identical to those used by Linux or any other OS) for any platform; it'd be another change someone would need to make to transform a DT to be "U-Boot compatible", which rather reduces a potential benefit of DT for U-Boot; being able to just drop a DT in and have it work.
It would be possible for U-Boot to decouple its internal device name from the DT node name. In which case, your statement would work. However, I don't think that's the case at the moment, and in fact it's effectively what this patch is doing, although admittedly there are other ways of doing this.
Hi Stephen,
Hi Stephen,
Hi Stephen,
device. In
all
identical
identical
the
number so
U-Boot does not impose a rule. If you want duplicate device names you can have them. I think it is bad practice though.
Anyway I believe my point stands. Whereas users can edit the device tree and avoid conflicts they cannot do this with auto-probed devices. So for that case we should have a way of allocating a name before calling device_bind().
On 04/29/2016 10:28 AM, Simon Glass wrote:
Hi Stephen,
Hi Stephen,
Hi Stephen,
device. In
all
identical
identical
the
number so
OK. I'm just going to solve this by unplugging the second Ethernet card, or holding this patch locally for the case when I need to test the PCIe port.
Hi Stephen,
Hi Stephen,
Hi Stephen,
Hi Stephen,
On 26 April 2016 at 15:30, Stephen Warren wrote: > It is possible for HW to contain multiple instances of the same device. In > this case, the name passed to device_bind() may not be unique across all > devices within its uclass. One example is a system with multiple identical > PCI Ethernet devices. Another might be a system with multiple identical > I2C GPIO expanders, each connected to a separate I2C bus, yet using the > same I2C address on that bus and hence having the same DT node name. > > Enhance the code to detect this situation, and append a sequence number so > the device name to ensure uniqueness. > > Signed-off-by: Stephen Warren <swarren@nvidia.com swarren@nvidia.com>
Binding a device needs to be as cheap as possible. 99% of the time the name is fine, and we know the cases where it might not be. This is similar to the DM_UC_FLAG_SEQ_ALIAS - expensive functionality should be separated out so we don't require everyone to use it. It just creates bloat.
So please when contributing things to driver model (which is most welcome and appreciated) be a little more flexible. It should not take this much energy to explain the design principles and get a change to a patch.
Also see u-boot-dm/blkb-working which includes the allocation of device names. I need to resolve the comments and respin...
Joe Hershberger
Stephen Warren
