[PATCH 1/2] tools: binman: main.py: add build-sandbox in sys.path
Adds build-sandbox in sys.path to look for libfdt, otherwise py_test can't use binman.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- tools/binman/main.py | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/binman/main.py b/tools/binman/main.py index 35944f314a..f62394043d 100755 --- a/tools/binman/main.py +++ b/tools/binman/main.py @@ -40,6 +40,7 @@ from patman import test_util # Bring in the libfdt module sys.path.insert(2, 'scripts/dtc/pylibfdt') sys.path.insert(2, os.path.join(srctree, 'scripts/dtc/pylibfdt')) +sys.path.insert(2, os.path.join(srctree, 'build-sandbox/scripts/dtc/pylibfdt')) sys.path.insert(2, os.path.join(srctree, 'build-sandbox_spl/scripts/dtc/pylibfdt'))
# When running under python-coverage on Ubuntu 16.04, the dist-packages
Adds /tmp/sandbox to sys.path to look for libfdt, otherwise ci is broken if a py_test uses binman.
diff --git a/tools/binman/main.py b/tools/binman/main.py index f62394043d..7d52482c0c 100755 --- a/tools/binman/main.py +++ b/tools/binman/main.py @@ -42,6 +42,7 @@ sys.path.insert(2, 'scripts/dtc/pylibfdt') sys.path.insert(2, os.path.join(srctree, 'scripts/dtc/pylibfdt')) sys.path.insert(2, os.path.join(srctree, 'build-sandbox/scripts/dtc/pylibfdt')) sys.path.insert(2, os.path.join(srctree, 'build-sandbox_spl/scripts/dtc/pylibfdt')) +sys.path.insert(2, os.path.join(srctree, '/tmp/sandbox/scripts/dtc/pylibfdt'))
# When running under python-coverage on Ubuntu 16.04, the dist-packages # directories are dropped from the python path. Add them in so that we can find
Hi Philippe,
On Thu, 27 Jan 2022 at 07:03, Philippe Reynes philippe.reynes@softathome.com wrote:
Which test uses /tmp/sandbox to build U-Boot? We might need to use --toolpath for this, or set PYTHONPATH in the caller?
2.17.1
Hi Simon,
Le 27/01/2022 à 16:06, Simon Glass a écrit :
Hi Philippe,
I have added a test that use binman in vboot (for global image signature, a header added before the image). This path should be added for the CI, otherwise tests "sandbox test.pyt " and "sandbox with clan test.py" fail.
2.17.1
Regards, Philippe
Hi Philippe,
On Thu, 27 Jan 2022 at 08:15, Philippe REYNES philippe.reynes@softathome.com wrote:
Hi Simon,
Hi Philippe,
But the tests should run in the board directory provided to pytest.
I will have to look at your test.
2.17.1
Regards, Philippe
-- This message and any attachments herein are confidential, intended solely for the addressees and are SoftAtHome’s ownership. Any unauthorized use or dissemination is prohibited. If you are not the intended addressee of this message, please cancel it immediately and inform the sender.
Is this supposed to be sent on the mailing list?
Hi Philippe
2.17.1
The build-sandbox_spl path should be enough though, shouldn't it? Have you not built that?
Philippe REYNES
Philippe Reynes
