[PATCH 1/2 v2] lib/crypto: Enable more algorithms in cert verification
Right now the code explicitly limits us to sha1,256 hashes with RSA2048 encryption. But the limitation is artificial since U-Boot supports a wider range of algorithms.
The internal image_get_[checksum|crypto]_algo() functions expect an argument in the format of <checksum>,<crypto>. So let's remove the size checking and create the needed string on the fly in order to support more hash/signing combinations.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- changes since v1: - added patch [2/2] explicitly disabling sha1 - removed a TODO comment - added a print notifying wrt to image_get_(checksum|crypto)_algo usage lib/crypto/public_key.c | 35 ++++++++++++++++------------------- 1 file changed, 16 insertions(+), 19 deletions(-)
diff --git a/lib/crypto/public_key.c b/lib/crypto/public_key.c index df6033cdb499..3671ed138559 100644 --- a/lib/crypto/public_key.c +++ b/lib/crypto/public_key.c @@ -97,6 +97,7 @@ int public_key_verify_signature(const struct public_key *pkey, const struct public_key_signature *sig) { struct image_sign_info info; + char algo[256]; int ret;
pr_devel("==>%s()\n", __func__); @@ -108,30 +109,26 @@ int public_key_verify_signature(const struct public_key *pkey, return -EINVAL;
memset(&info, '\0', sizeof(info)); + memset(algo, 0, sizeof(algo)); info.padding = image_get_padding_algo("pkcs-1.5"); - /* - * Note: image_get_[checksum|crypto]_algo takes a string - * argument like "<checksum>,<crypto>" - * TODO: support other hash algorithms - */ - if (strcmp(sig->pkey_algo, "rsa") || (sig->s_size * 8) != 2048) { - pr_warn("Encryption is not RSA2048: %s%d\n", - sig->pkey_algo, sig->s_size * 8); - return -ENOPKG; - } - if (!strcmp(sig->hash_algo, "sha1")) { - info.checksum = image_get_checksum_algo("sha1,rsa2048"); - info.name = "sha1,rsa2048"; - } else if (!strcmp(sig->hash_algo, "sha256")) { - info.checksum = image_get_checksum_algo("sha256,rsa2048"); - info.name = "sha256,rsa2048"; - } else { - pr_warn("unknown msg digest algo: %s\n", sig->hash_algo); + if (strcmp(sig->pkey_algo, "rsa")) { + pr_err("Encryption is not RSA: %s\n", sig->pkey_algo); return -ENOPKG; } + ret = snprintf(algo, sizeof(algo), "%s,%s%d", sig->hash_algo, + sig->pkey_algo, sig->s_size * 8); + + if (ret >= sizeof(algo)) + return -EINVAL; + + info.checksum = image_get_checksum_algo((const char *)algo); + info.name = (const char *)algo; info.crypto = image_get_crypto_algo(info.name); - if (IS_ERR(info.checksum) || IS_ERR(info.crypto)) + if (!info.checksum || !info.crypto) { + pr_err("<%s> not supported on image_get_(checksum|crypto)_algo()\n", + algo); return -ENOPKG; + }
info.key = pkey->key; info.keylen = pkey->keylen;
Since SHA1 has know collisions disable it on EFI verification for variables and executables
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/efi_signature.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/lib/efi_loader/efi_signature.c b/lib/efi_loader/efi_signature.c index 6e3ee3c0c004..1903adc89ed0 100644 --- a/lib/efi_loader/efi_signature.c +++ b/lib/efi_loader/efi_signature.c @@ -476,6 +476,11 @@ bool efi_signature_verify(struct efi_image_regions *regs, if (ret < 0 || !signer) goto out;
+ if (!strcmp(signer->sig->hash_algo, "sha1")) { + pr_err("SHA1 support is disabled for EFI\n"); + goto out; + } + if (sinfo->blacklisted) goto out;
Heinrich
Replying to myself here but...
On Wed, 19 Jan 2022 at 13:54, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
goto out;
-- 2.30.2
This patch gets the job done, but rejects the sha1 cert signed images overall without checking db or dbx. Since I am planning to refactor the secure boot checking sequence a bit, it would make more sense for me to fix this in a less hacky way in upcoming patches. You can ofc pickup 1/2 whic is fixing an actual issue.
Cheers /Ilias
Ilias Apalodimas
