[U-Boot] [PATCH v3 1/4]drivers: mmc: dwmmc: enable support for DT
This patch enables for device tree for dw-mmc driver. Driver have been fixed because it is used exynos5 and exynos4. Add, fdt compat id of exynos4 dwmmc.
Signed-off-by: Beomho Seo beomho.seo@samsung.com Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Piotr Wilczek p.wilczek@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- Changes for v3: - None.
drivers/mmc/exynos_dw_mmc.c | 21 +++++++++++++++++---- include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 3 files changed, 19 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index de8cdcc..b9d41d4 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -13,6 +13,7 @@ #include <asm/arch/dwmmc.h> #include <asm/arch/clk.h> #include <asm/arch/pinmux.h> +#include <asm/gpio.h>
#define DWMMC_MAX_CH_NUM 4 #define DWMMC_MAX_FREQ 52000000 @@ -82,6 +83,7 @@ int exynos_dwmci_add_port(int index, u32 regbase, int bus_width, u32 clksel) freq = 52000000; sclk = get_mmc_clk(index); div = DIV_ROUND_UP(sclk, freq); + div -= 1; /* set the clock divisor for mmc */ set_mmc_clk(index, div);
@@ -118,15 +120,21 @@ int exynos_dwmmc_init(const void *blob) { int index, bus_width; int node_list[DWMMC_MAX_CH_NUM]; - int err = 0, dev_id, flag, count, i; + int err = 0, dev_id, flag, count, i, compat_id; u32 clksel_val, base, timing[3];
+#ifdef CONFIG_EXYNOS4 + compat_id = COMPAT_SAMSUNG_EXYNOS4_DWMMC; +#else + compat_id = COMPAT_SAMSUNG_EXYNOS5_DWMMC; +#endif + count = fdtdec_find_aliases_for_id(blob, "mmc", - COMPAT_SAMSUNG_EXYNOS5_DWMMC, node_list, - DWMMC_MAX_CH_NUM); + compat_id, node_list, DWMMC_MAX_CH_NUM);
for (i = 0; i < count; i++) { int node = node_list[i]; + struct fdt_gpio_state pwr_gpio;
if (node <= 0) continue; @@ -145,6 +153,9 @@ int exynos_dwmmc_init(const void *blob) else flag = PINMUX_FLAG_NONE;
+ fdtdec_decode_gpio(blob, node, "pwr-gpios", &pwr_gpio); + if (fdt_gpio_isvalid(&pwr_gpio)) + gpio_direction_output(pwr_gpio.gpio, 1); /* config pinmux for each mmc channel */ err = exynos_pinmux_config(dev_id, flag); if (err) { @@ -152,7 +163,9 @@ int exynos_dwmmc_init(const void *blob) return err; }
- index = dev_id - PERIPH_ID_SDMMC0; + index = fdtdec_get_int(blob, node, "index", dev_id); + if (index == dev_id) + index = dev_id - PERIPH_ID_SDMMC0;
/* Get the base address from the device node */ base = fdtdec_get_addr(blob, node, "reg"); diff --git a/include/fdtdec.h b/include/fdtdec.h index 63027bd..15f50fe 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -83,6 +83,7 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS5_DWMMC, /* Exynos5 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ + COMPAT_SAMSUNG_EXYNOS4_DWMMC, /* Exynos4 DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index be04598..79179cf 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -56,6 +56,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS5_DWMMC, "samsung,exynos5250-dwmmc"), COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), + COMPAT(SAMSUNG_EXYNOS4_DWMMC, "samsung,exynos4412-dwmmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"),
Dear Beonho Seo,
Changes for v3:
- None.
- div -= 1;
why?
- int err = 0, dev_id, flag, count, i, compat_id; u32 clksel_val, base, timing[3];
- compat_id = COMPAT_SAMSUNG_EXYNOS4_DWMMC;
+#else
- compat_id = COMPAT_SAMSUNG_EXYNOS5_DWMMC;
NAK. please don't use ifdef.
- count = fdtdec_find_aliases_for_id(blob, "mmc",
DWMMC_MAX_CH_NUM);
please add blank line.
I can't understand why this routine is needed. Could you please explain?
- COMPAT_SAMSUNG_EXYNOS4_DWMMC, /* Exynos4 DWMMC controller */
Do we need to separate exynos4 dwmmc and exynos5 dwmmc?
Jaehoon, how you think?
- COMPAT(SAMSUNG_EXYNOS4_DWMMC, "samsung,exynos4412-dwmmc"), COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"),
Thanks, Minkyu Kang.
On 04/08/2014 11:53 AM, Minkyu Kang wrote:
Dear Beonho Seo,
Changes for v3:
- None.
- div -= 1;
why?
+#else
In my patch, this is used the below. + + if (cpu_is_exynos4()) + compat_id = COMPAT_SAMSUNG_EXYNOS4_DWMMC; + else if (cpu_is_exynos5()) + compat_id = COMPAT_SAMSUNG_EXYNOS5_DWMMC; + else + compat_id = COMPAT_UNKNOWN; +
DWMMC_MAX_CH_NUM);
It didn't need to separate.
Best Regards, Jaehoon Chung
Thanks, Minkyu Kang. _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Thank you for your advice.
Dear Beonho Seo,
Changes for v3:
- None.
- div -= 1;
why?
It need for set accurately required frequency. Above code prevent to set below the required frequency. For example above case, If sclk is 100 MHz and required frequency 50 MHz, Where div = 2. and then mmc clock set 33 MHz calculating. So It need div minus one.
+#else
OK. I will change it.
DWMMC_MAX_CH_NUM);
OK. I will add blank line.
SDMMC index(0, 1 ... 4) is need to get/set mmc clk. It is decided the difference between dev_id and PERIPH_ID_SDMMC0(=75). But If dev_id is PERIPH_ID_SDMMC4(=131), index is set inaccurately. So I add index property at device tree. and then parse it. If index property not exist, index is decided the difference between dev_id and PERIPH_ID_SDMMC0.
OK, I will change and test it.
Hi, Minkyu.
Dear Beonho Seo,
Changes for v3:
- None.
- div -= 1;
why?
It didn't consider how div value is set into CMU register. SCLK = (MOUT/(PRE_RATIO + 1))/(RATIO + 1). Finally, it didn't consider for plus one. Source clock is set to wrong value.
It needs to change other approach than using just "div -= 1".
If i understood something wrong, let me know, plz.
+#else
DWMMC_MAX_CH_NUM);
Beomho Seo
Jaehoon Chung
Minkyu Kang
