[U-Boot] [PATCH] wandboard: Switch to SPL support
Currently we need to build one U-boot image for each of the wandboard variants: quad, dual-lite and solo.
By switching to SPL we can support all these variants with a single binary, which is very convenient.
Based on the work from Richard Hu.
Tested kernel booting on the three boards.
Signed-off-by: Richard Hu hakahu@gmail.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/Kconfig | 1 + board/wandboard/MAINTAINERS | 4 +- board/wandboard/Makefile | 2 +- board/wandboard/README | 22 +-- board/wandboard/spl.c | 317 +++++++++++++++++++++++++++++++++++++++ board/wandboard/wandboard.c | 176 ++++++++++++---------- configs/wandboard_defconfig | 6 + configs/wandboard_dl_defconfig | 3 - configs/wandboard_quad_defconfig | 3 - configs/wandboard_solo_defconfig | 3 - include/configs/wandboard.h | 27 ++-- 11 files changed, 448 insertions(+), 116 deletions(-) create mode 100644 board/wandboard/spl.c create mode 100644 configs/wandboard_defconfig delete mode 100644 configs/wandboard_dl_defconfig delete mode 100644 configs/wandboard_quad_defconfig delete mode 100644 configs/wandboard_solo_defconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 00be305..ca7448e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -493,6 +493,7 @@ config TARGET_UDOO config TARGET_WANDBOARD bool "Support wandboard" select CPU_V7 + select SUPPORT_SPL
config TARGET_WARP bool "Support WaRP" diff --git a/board/wandboard/MAINTAINERS b/board/wandboard/MAINTAINERS index b986980..0680517 100644 --- a/board/wandboard/MAINTAINERS +++ b/board/wandboard/MAINTAINERS @@ -3,6 +3,4 @@ M: Fabio Estevam fabio.estevam@freescale.com S: Maintained F: board/wandboard/ F: include/configs/wandboard.h -F: configs/wandboard_dl_defconfig -F: configs/wandboard_quad_defconfig -F: configs/wandboard_solo_defconfig +F: configs/wandboard_defconfig diff --git a/board/wandboard/Makefile b/board/wandboard/Makefile index 5b50eca..db9f4a6 100644 --- a/board/wandboard/Makefile +++ b/board/wandboard/Makefile @@ -4,4 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y := wandboard.o +obj-y := wandboard.o spl.o diff --git a/board/wandboard/README b/board/wandboard/README index 1f678e1..c6c0132 100644 --- a/board/wandboard/README +++ b/board/wandboard/README @@ -12,31 +12,25 @@ http://www.wandboard.org/ Building U-boot for Wandboard -----------------------------
-To build U-Boot for the Wandboard Dual Lite version: +To build U-Boot for the Wandboard:
-$ make wandboard_dl_config -$ make - -To build U-Boot for the Wandboard Solo version: - -$ make wandboard_solo_config -$ make - -To build U-Boot for the Wandboard Quad version: - -$ make wandboard_quad_config +$ make wandboard_config $ make
Flashing U-boot into the SD card --------------------------------
-- After the 'make' command completes, the generated 'u-boot.imx' binary must be +- After the 'make' command completes, the generated 'SPL' binary must be flashed into the SD card;
-$ sudo dd if=u-boot.imx of=/dev/mmcblk0 bs=512 seek=2; sync +$ sudo dd if=SPL of=/dev/mmcblk0 bs=1k seek=1; sync
(Note - the SD card node may vary, so adjust this as needed).
+- Flash the u-boot.img image into the SD card: + +sudo dd if=u-boot.img of=/dev/mmcblk0 bs=1k seek=69; sync + - Insert the SD card into the slot located in the bottom of the board (same side as the mx6 processor)
diff --git a/board/wandboard/spl.c b/board/wandboard/spl.c new file mode 100644 index 0000000..77afae7 --- /dev/null +++ b/board/wandboard/spl.c @@ -0,0 +1,317 @@ +/* + * Copyright (C) 2014 Wandboard + * Author: Tungyi Lin tungyilin1127@gmail.com + * Richard Hu hakahu@gmail.com + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/iomux.h> +#include <asm/arch/mx6-pins.h> +#include <asm/errno.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/video.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <asm/arch/crm_regs.h> +#include <asm/io.h> +#include <asm/arch/sys_proto.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +#if defined(CONFIG_SPL_BUILD) +#include <asm/arch/mx6-ddr.h> +/* + * Driving strength: + * 0x30 == 40 Ohm + * 0x28 == 48 Ohm + */ + +#define IMX6DQ_DRIVE_STRENGTH 0x30 +#define IMX6SDL_DRIVE_STRENGTH 0x28 + +/* configure MX6Q/DUAL mmdc DDR io registers */ +static struct mx6dq_iomux_ddr_regs mx6dq_ddr_ioregs = { + .dram_sdclk_0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdclk_1 = IMX6DQ_DRIVE_STRENGTH, + .dram_cas = IMX6DQ_DRIVE_STRENGTH, + .dram_ras = IMX6DQ_DRIVE_STRENGTH, + .dram_reset = IMX6DQ_DRIVE_STRENGTH, + .dram_sdcke0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdcke1 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdodt1 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs0 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs1 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs2 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs3 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs4 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs5 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs6 = IMX6DQ_DRIVE_STRENGTH, + .dram_sdqs7 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm0 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm1 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm2 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm3 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm4 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm5 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm6 = IMX6DQ_DRIVE_STRENGTH, + .dram_dqm7 = IMX6DQ_DRIVE_STRENGTH, +}; + +/* configure MX6Q/DUAL mmdc GRP io registers */ +static struct mx6dq_iomux_grp_regs mx6dq_grp_ioregs = { + .grp_ddr_type = 0x000c0000, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_addds = IMX6DQ_DRIVE_STRENGTH, + .grp_ctlds = IMX6DQ_DRIVE_STRENGTH, + .grp_ddrmode = 0x00020000, + .grp_b0ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b1ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b2ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b3ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b4ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b5ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b6ds = IMX6DQ_DRIVE_STRENGTH, + .grp_b7ds = IMX6DQ_DRIVE_STRENGTH, +}; + +/* configure MX6SOLO/DUALLITE mmdc DDR io registers */ +struct mx6sdl_iomux_ddr_regs mx6sdl_ddr_ioregs = { + .dram_sdclk_0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdclk_1 = IMX6SDL_DRIVE_STRENGTH, + .dram_cas = IMX6SDL_DRIVE_STRENGTH, + .dram_ras = IMX6SDL_DRIVE_STRENGTH, + .dram_reset = IMX6SDL_DRIVE_STRENGTH, + .dram_sdcke0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdcke1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdba2 = 0x00000000, + .dram_sdodt0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdodt1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs0 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs1 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs2 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs3 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs4 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs5 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs6 = IMX6SDL_DRIVE_STRENGTH, + .dram_sdqs7 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm0 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm1 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm2 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm3 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm4 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm5 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm6 = IMX6SDL_DRIVE_STRENGTH, + .dram_dqm7 = IMX6SDL_DRIVE_STRENGTH, +}; + +/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ +struct mx6sdl_iomux_grp_regs mx6sdl_grp_ioregs = { + .grp_ddr_type = 0x000c0000, + .grp_ddrmode_ctl = 0x00020000, + .grp_ddrpke = 0x00000000, + .grp_addds = IMX6SDL_DRIVE_STRENGTH, + .grp_ctlds = IMX6SDL_DRIVE_STRENGTH, + .grp_ddrmode = 0x00020000, + .grp_b0ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b1ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b2ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b3ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b4ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b5ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b6ds = IMX6SDL_DRIVE_STRENGTH, + .grp_b7ds = IMX6SDL_DRIVE_STRENGTH, +}; + +/* H5T04G63AFR-PB */ +static struct mx6_ddr3_cfg h5t04g63afr = { + .mem_speed = 1600, + .density = 4, + .width = 16, + .banks = 8, + .rowaddr = 15, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; + +/* H5TQ2G63DFR-H9 */ +static struct mx6_ddr3_cfg h5tq2g63dfr = { + .mem_speed = 1333, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1350, + .trcmin = 4950, + .trasmin = 3600, +}; + +static struct mx6_mmdc_calibration mx6q_2g_mmdc_calib = { + .p0_mpwldectrl0 = 0x001f001f, + .p0_mpwldectrl1 = 0x001f001f, + .p1_mpwldectrl0 = 0x001f001f, + .p1_mpwldectrl1 = 0x001f001f, + .p0_mpdgctrl0 = 0x4301030d, + .p0_mpdgctrl1 = 0x03020277, + .p1_mpdgctrl0 = 0x4300030a, + .p1_mpdgctrl1 = 0x02780248, + .p0_mprddlctl = 0x4536393b, + .p1_mprddlctl = 0x36353441, + .p0_mpwrdlctl = 0x41414743, + .p1_mpwrdlctl = 0x462f453f, +}; + +/* DDR 64bit 2GB */ +static struct mx6_ddr_sysinfo mem_q = { + .dsize = 2, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 1, + .rtt_wr = 0, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, +}; + +static struct mx6_mmdc_calibration mx6dl_1g_mmdc_calib = { + .p0_mpwldectrl0 = 0x001f001f, + .p0_mpwldectrl1 = 0x001f001f, + .p1_mpwldectrl0 = 0x001f001f, + .p1_mpwldectrl1 = 0x001f001f, + .p0_mpdgctrl0 = 0x420e020e, + .p0_mpdgctrl1 = 0x02000200, + .p1_mpdgctrl0 = 0x42020202, + .p1_mpdgctrl1 = 0x01720172, + .p0_mprddlctl = 0x494c4f4c, + .p1_mprddlctl = 0x4a4c4c49, + .p0_mpwrdlctl = 0x3f3f3133, + .p1_mpwrdlctl = 0x39373f2e, +}; + +static struct mx6_mmdc_calibration mx6s_512m_mmdc_calib = { + .p0_mpwldectrl0 = 0x0040003c, + .p0_mpwldectrl1 = 0x0032003e, + .p0_mpdgctrl0 = 0x42350231, + .p0_mpdgctrl1 = 0x021a0218, + .p0_mprddlctl = 0x4b4b4e49, + .p0_mpwrdlctl = 0x3f3f3035, +}; + +/* DDR 64bit 1GB */ +static struct mx6_ddr_sysinfo mem_dl = { + .dsize = 2, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 1, + .rtt_wr = 0, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, +}; + +/* DDR 32bit 512MB */ +static struct mx6_ddr_sysinfo mem_s = { + .dsize = 1, + .cs1_mirror = 0, + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, + .ncs = 1, + .bi_on = 1, + .rtt_nom = 1, + .rtt_wr = 0, + .ralat = 5, + .walat = 0, + .mif3_mode = 3, + .rst_to_cke = 0x23, + .sde_to_rst = 0x10, +}; + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static void gpr_init(void) +{ + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + + /* enable AXI cache for VDOA/VPU/IPU */ + writel(0xF00000CF, &iomux->gpr[4]); + /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ + writel(0x007F007F, &iomux->gpr[6]); + writel(0x007F007F, &iomux->gpr[7]); +} + +static void spl_dram_init(void) +{ + if (is_cpu_type(MXC_CPU_MX6SOLO)) { + mx6sdl_dram_iocfg(32, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); + mx6_dram_cfg(&mem_s, &mx6s_512m_mmdc_calib, &h5tq2g63dfr); + } else if (is_cpu_type(MXC_CPU_MX6DL)) { + mx6sdl_dram_iocfg(64, &mx6sdl_ddr_ioregs, &mx6sdl_grp_ioregs); + mx6_dram_cfg(&mem_dl, &mx6dl_1g_mmdc_calib, &h5tq2g63dfr); + } else if (is_cpu_type(MXC_CPU_MX6Q)) { + mx6dq_dram_iocfg(64, &mx6dq_ddr_ioregs, &mx6dq_grp_ioregs); + mx6_dram_cfg(&mem_q, &mx6q_2g_mmdc_calib, &h5t04g63afr); + } + + udelay(100); +} + +void board_init_f(ulong dummy) +{ + ccgr_init(); + + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + gpr_init(); + + /* iomux */ + board_early_init_f(); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + /* DDR initialization */ + spl_dram_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + /* load/boot image from boot device */ + board_init_r(NULL, 0); +} +#endif diff --git a/board/wandboard/wandboard.c b/board/wandboard/wandboard.c index 1075c65..90625ab 100644 --- a/board/wandboard/wandboard.c +++ b/board/wandboard/wandboard.c @@ -53,66 +53,66 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { - gd->ram_size = (phys_size_t)CONFIG_DDR_MB * 1024 * 1024; + gd->ram_size = imx_ddr_size();
return 0; }
static iomux_v3_cfg_t const uart1_pads[] = { - MX6_PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), - MX6_PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), + IOMUX_PADS(PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), };
static iomux_v3_cfg_t const usdhc1_pads[] = { - MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IOMUX_PADS(PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), /* Carrier MicroSD Card Detect */ - MX6_PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL)), };
static iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), /* SOM MicroSD Card Detect */ - MX6_PAD_EIM_DA9__GPIO3_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_EIM_DA9__GPIO3_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL)), };
static iomux_v3_cfg_t const enet_pads[] = { - MX6_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)), + IOMUX_PADS(PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), /* AR8031 PHY Reset */ - MX6_PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), + IOMUX_PADS(PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL)), };
static void setup_iomux_uart(void) { - imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); + SETUP_IOMUX_PADS(uart1_pads); }
static void setup_iomux_enet(void) { - imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + SETUP_IOMUX_PADS(enet_pads);
/* Reset AR8031 PHY */ gpio_direction_output(ETH_PHY_RESET, 0); @@ -156,15 +156,13 @@ int board_mmc_init(bd_t *bis) for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { switch (index) { case 0: - imx_iomux_v3_setup_multiple_pads( - usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); + SETUP_IOMUX_PADS(usdhc3_pads); usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); usdhc_cfg[0].max_bus_width = 4; gpio_direction_input(USDHC3_CD_GPIO); break; case 1: - imx_iomux_v3_setup_multiple_pads( - usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + SETUP_IOMUX_PADS(usdhc1_pads); usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); usdhc_cfg[1].max_bus_width = 4; gpio_direction_input(USDHC1_CD_GPIO); @@ -218,54 +216,66 @@ int board_phy_config(struct phy_device *phydev) }
#if defined(CONFIG_VIDEO_IPUV3) -struct i2c_pads_info i2c2_pad_info = { +struct i2c_pads_info mx6q_i2c2_pad_info = { .scl = { - .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL + .i2c_mode = MX6Q_PAD_KEY_COL3__I2C2_SCL | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gpio_mode = MX6_PAD_KEY_COL3__GPIO4_IO12 + .gpio_mode = MX6Q_PAD_KEY_COL3__GPIO4_IO12 | MUX_PAD_CTRL(I2C_PAD_CTRL), .gp = IMX_GPIO_NR(4, 12) }, .sda = { - .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA + .i2c_mode = MX6Q_PAD_KEY_ROW3__I2C2_SDA | MUX_PAD_CTRL(I2C_PAD_CTRL), - .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 + .gpio_mode = MX6Q_PAD_KEY_ROW3__GPIO4_IO13 + | MUX_PAD_CTRL(I2C_PAD_CTRL), + .gp = IMX_GPIO_NR(4, 13) + } +}; + +struct i2c_pads_info mx6dl_i2c2_pad_info = { + .scl = { + .i2c_mode = MX6DL_PAD_KEY_COL3__I2C2_SCL + | MUX_PAD_CTRL(I2C_PAD_CTRL), + .gpio_mode = MX6DL_PAD_KEY_COL3__GPIO4_IO12 + | MUX_PAD_CTRL(I2C_PAD_CTRL), + .gp = IMX_GPIO_NR(4, 12) + }, + .sda = { + .i2c_mode = MX6DL_PAD_KEY_ROW3__I2C2_SDA + | MUX_PAD_CTRL(I2C_PAD_CTRL), + .gpio_mode = MX6DL_PAD_KEY_ROW3__GPIO4_IO13 | MUX_PAD_CTRL(I2C_PAD_CTRL), .gp = IMX_GPIO_NR(4, 13) } };
static iomux_v3_cfg_t const fwadapt_7wvga_pads[] = { - MX6_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK, - MX6_PAD_DI0_PIN2__IPU1_DI0_PIN02, /* HSync */ - MX6_PAD_DI0_PIN3__IPU1_DI0_PIN03, /* VSync */ - MX6_PAD_DI0_PIN4__IPU1_DI0_PIN04 - | MUX_PAD_CTRL(PAD_CTL_DSE_120ohm), /* Contrast */ - MX6_PAD_DI0_PIN15__IPU1_DI0_PIN15, /* DISP0_DRDY */ - - MX6_PAD_DISP0_DAT0__IPU1_DISP0_DATA00, - MX6_PAD_DISP0_DAT1__IPU1_DISP0_DATA01, - MX6_PAD_DISP0_DAT2__IPU1_DISP0_DATA02, - MX6_PAD_DISP0_DAT3__IPU1_DISP0_DATA03, - MX6_PAD_DISP0_DAT4__IPU1_DISP0_DATA04, - MX6_PAD_DISP0_DAT5__IPU1_DISP0_DATA05, - MX6_PAD_DISP0_DAT6__IPU1_DISP0_DATA06, - MX6_PAD_DISP0_DAT7__IPU1_DISP0_DATA07, - MX6_PAD_DISP0_DAT8__IPU1_DISP0_DATA08, - MX6_PAD_DISP0_DAT9__IPU1_DISP0_DATA09, - MX6_PAD_DISP0_DAT10__IPU1_DISP0_DATA10, - MX6_PAD_DISP0_DAT11__IPU1_DISP0_DATA11, - MX6_PAD_DISP0_DAT12__IPU1_DISP0_DATA12, - MX6_PAD_DISP0_DAT13__IPU1_DISP0_DATA13, - MX6_PAD_DISP0_DAT14__IPU1_DISP0_DATA14, - MX6_PAD_DISP0_DAT15__IPU1_DISP0_DATA15, - MX6_PAD_DISP0_DAT16__IPU1_DISP0_DATA16, - MX6_PAD_DISP0_DAT17__IPU1_DISP0_DATA17, - - MX6_PAD_SD4_DAT2__GPIO2_IO10 - | MUX_PAD_CTRL(NO_PAD_CTRL), /* DISP0_BKLEN */ - MX6_PAD_SD4_DAT3__GPIO2_IO11 - | MUX_PAD_CTRL(NO_PAD_CTRL), /* DISP0_VDDEN */ + IOMUX_PADS(PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK), + IOMUX_PADS(PAD_DI0_PIN2__IPU1_DI0_PIN02), /* HSync */ + IOMUX_PADS(PAD_DI0_PIN3__IPU1_DI0_PIN03), /* VSync */ + IOMUX_PADS(PAD_DI0_PIN4__IPU1_DI0_PIN04 | MUX_PAD_CTRL(PAD_CTL_DSE_120ohm)), /* Contrast */ + IOMUX_PADS(PAD_DI0_PIN15__IPU1_DI0_PIN15), /* DISP0_DRDY */ + IOMUX_PADS(PAD_DISP0_DAT0__IPU1_DISP0_DATA00), + IOMUX_PADS(PAD_DISP0_DAT1__IPU1_DISP0_DATA01), + IOMUX_PADS(PAD_DISP0_DAT2__IPU1_DISP0_DATA02), + IOMUX_PADS(PAD_DISP0_DAT3__IPU1_DISP0_DATA03), + IOMUX_PADS(PAD_DISP0_DAT4__IPU1_DISP0_DATA04), + IOMUX_PADS(PAD_DISP0_DAT5__IPU1_DISP0_DATA05), + IOMUX_PADS(PAD_DISP0_DAT6__IPU1_DISP0_DATA06), + IOMUX_PADS(PAD_DISP0_DAT7__IPU1_DISP0_DATA07), + IOMUX_PADS(PAD_DISP0_DAT8__IPU1_DISP0_DATA08), + IOMUX_PADS(PAD_DISP0_DAT9__IPU1_DISP0_DATA09), + IOMUX_PADS(PAD_DISP0_DAT10__IPU1_DISP0_DATA10), + IOMUX_PADS(PAD_DISP0_DAT11__IPU1_DISP0_DATA11), + IOMUX_PADS(PAD_DISP0_DAT12__IPU1_DISP0_DATA12), + IOMUX_PADS(PAD_DISP0_DAT13__IPU1_DISP0_DATA13), + IOMUX_PADS(PAD_DISP0_DAT14__IPU1_DISP0_DATA14), + IOMUX_PADS(PAD_DISP0_DAT15__IPU1_DISP0_DATA15), + IOMUX_PADS(PAD_DISP0_DAT16__IPU1_DISP0_DATA16), + IOMUX_PADS(PAD_DISP0_DAT17__IPU1_DISP0_DATA17), + IOMUX_PADS(PAD_SD4_DAT2__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* DISP0_BKLEN */ + IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* DISP0_VDDEN */ };
static void do_enable_hdmi(struct display_info_t const *dev) @@ -281,9 +291,7 @@ static int detect_i2c(struct display_info_t const *dev)
static void enable_fwadapt_7wvga(struct display_info_t const *dev) { - imx_iomux_v3_setup_multiple_pads( - fwadapt_7wvga_pads, - ARRAY_SIZE(fwadapt_7wvga_pads)); + SETUP_IOMUX_PADS(fwadapt_7wvga_pads);
gpio_direction_output(IMX_GPIO_NR(2, 10), 1); gpio_direction_output(IMX_GPIO_NR(2, 11), 1); @@ -346,7 +354,7 @@ static void setup_display(void) writel(reg, &mxc_ccm->chsccdr);
/* Disable LCD backlight */ - imx_iomux_v3_setup_pad(MX6_PAD_DI0_PIN4__GPIO4_IO20); + SETUP_IOMUX_PAD(PAD_DI0_PIN4__GPIO4_IO20); gpio_direction_input(IMX_GPIO_NR(4, 20)); } #endif /* CONFIG_VIDEO_IPUV3 */ @@ -391,6 +399,12 @@ int board_late_init(void) add_board_boot_modes(board_boot_modes); #endif
+#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG + if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) + setenv("board_rev", "MX6Q"); + else + setenv("board_rev", "MX6DL"); +#endif return 0; }
@@ -399,7 +413,11 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c2_pad_info); + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c2_pad_info); + if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D)) + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6q_i2c2_pad_info); + else + setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &mx6dl_i2c2_pad_info);
return 0; } diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig new file mode 100644 index 0000000..1ccac5a --- /dev/null +++ b/configs/wandboard_defconfig @@ -0,0 +1,6 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +CONFIG_ARM=y +CONFIG_TARGET_WANDBOARD=y +CONFIG_DM=y +CONFIG_DM_THERMAL=y diff --git a/configs/wandboard_dl_defconfig b/configs/wandboard_dl_defconfig deleted file mode 100644 index 5a1f7f5..0000000 --- a/configs/wandboard_dl_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" -CONFIG_ARM=y -CONFIG_TARGET_WANDBOARD=y diff --git a/configs/wandboard_quad_defconfig b/configs/wandboard_quad_defconfig deleted file mode 100644 index d940848..0000000 --- a/configs/wandboard_quad_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" -CONFIG_ARM=y -CONFIG_TARGET_WANDBOARD=y diff --git a/configs/wandboard_solo_defconfig b/configs/wandboard_solo_defconfig deleted file mode 100644 index 66aa5d3..0000000 --- a/configs/wandboard_solo_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" -CONFIG_ARM=y -CONFIG_TARGET_WANDBOARD=y diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index b2c3614..7ce861e 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -14,6 +14,10 @@ #include <asm/imx-common/gpio.h> #include <linux/sizes.h>
+#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#include "imx6_spl.h" + #define CONFIG_MX6 #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO @@ -125,20 +129,15 @@ #define CONFIG_MXC_OCOTP #endif
-#if defined(CONFIG_MX6DL) || defined(CONFIG_MX6S) -#define CONFIG_DEFAULT_FDT_FILE "imx6dl-wandboard.dtb" -#elif defined(CONFIG_MX6Q) -#define CONFIG_DEFAULT_FDT_FILE "imx6q-wandboard.dtb" -#endif - +#define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG #define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \ "image=zImage\0" \ "console=ttymxc0\0" \ "splashpos=m,m\0" \ + "fdtfile=undefined\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ - "fdt_file=" CONFIG_DEFAULT_FDT_FILE "\0" \ "fdt_addr=0x18000000\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ @@ -192,7 +191,7 @@ "bootscript=echo Running bootscript from mmc ...; " \ "source\0" \ "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ - "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdtfile}\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ @@ -220,7 +219,7 @@ "fi; " \ "${get_cmd} ${image}; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ - "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "if ${get_cmd} ${fdt_addr} ${fdtfile}; then " \ "bootz ${loadaddr} - ${fdt_addr}; " \ "else " \ "if test ${boot_fdt} = try; then " \ @@ -231,9 +230,17 @@ "fi; " \ "else " \ "bootz; " \ - "fi;\0" + "fi;\0" \ + "findfdt="\ + "if test $board_rev = MX6Q ; then " \ + "setenv fdtfile imx6q-wandboard.dtb; fi; " \ + "if test $board_rev = MX6DL ; then " \ + "setenv fdtfile imx6dl-wandboard.dtb; fi; " \ + "if test $fdtfile = undefined; then " \ + "echo WARNING: Could not determine dtb to use; fi; \0" \
#define CONFIG_BOOTCOMMAND \ + "run findfdt; " \ "mmc dev ${mmcdev}; if mmc rescan; then " \ "if run loadbootscript; then " \ "run bootscript; " \
Tested kernel boot on wandboard quad and dual-lite variants.
Tested-by: Vagrant Cascadian vagrant@aikidev.net
- select SUPPORT_SPL
- Copyright (C) 2014 Wandboard
- Author: Tungyi Lin tungyilin1127@gmail.com
Richard Hu <hakahu@gmail.com>
- Driving strength:
- 0x30 == 40 Ohm
- 0x28 == 48 Ohm
- .dram_sdclk_0 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdclk_1 = IMX6DQ_DRIVE_STRENGTH,
- .dram_cas = IMX6DQ_DRIVE_STRENGTH,
- .dram_ras = IMX6DQ_DRIVE_STRENGTH,
- .dram_reset = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdcke0 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdcke1 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdba2 = 0x00000000,
- .dram_sdodt0 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdodt1 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdqs0 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdqs1 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdqs2 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdqs3 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdqs4 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdqs5 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdqs6 = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdqs7 = IMX6DQ_DRIVE_STRENGTH,
- .dram_dqm0 = IMX6DQ_DRIVE_STRENGTH,
- .dram_dqm1 = IMX6DQ_DRIVE_STRENGTH,
- .dram_dqm2 = IMX6DQ_DRIVE_STRENGTH,
- .dram_dqm3 = IMX6DQ_DRIVE_STRENGTH,
- .dram_dqm4 = IMX6DQ_DRIVE_STRENGTH,
- .dram_dqm5 = IMX6DQ_DRIVE_STRENGTH,
- .dram_dqm6 = IMX6DQ_DRIVE_STRENGTH,
- .dram_dqm7 = IMX6DQ_DRIVE_STRENGTH,
- .grp_ddr_type = 0x000c0000,
- .grp_ddrmode_ctl = 0x00020000,
- .grp_ddrpke = 0x00000000,
- .grp_addds = IMX6DQ_DRIVE_STRENGTH,
- .grp_ctlds = IMX6DQ_DRIVE_STRENGTH,
- .grp_ddrmode = 0x00020000,
- .grp_b0ds = IMX6DQ_DRIVE_STRENGTH,
- .grp_b1ds = IMX6DQ_DRIVE_STRENGTH,
- .grp_b2ds = IMX6DQ_DRIVE_STRENGTH,
- .grp_b3ds = IMX6DQ_DRIVE_STRENGTH,
- .grp_b4ds = IMX6DQ_DRIVE_STRENGTH,
- .grp_b5ds = IMX6DQ_DRIVE_STRENGTH,
- .grp_b6ds = IMX6DQ_DRIVE_STRENGTH,
- .grp_b7ds = IMX6DQ_DRIVE_STRENGTH,
- .dram_sdclk_0 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdclk_1 = IMX6SDL_DRIVE_STRENGTH,
- .dram_cas = IMX6SDL_DRIVE_STRENGTH,
- .dram_ras = IMX6SDL_DRIVE_STRENGTH,
- .dram_reset = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdcke0 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdcke1 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdodt0 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdodt1 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdqs0 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdqs1 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdqs2 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdqs3 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdqs4 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdqs5 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdqs6 = IMX6SDL_DRIVE_STRENGTH,
- .dram_sdqs7 = IMX6SDL_DRIVE_STRENGTH,
- .dram_dqm0 = IMX6SDL_DRIVE_STRENGTH,
- .dram_dqm1 = IMX6SDL_DRIVE_STRENGTH,
- .dram_dqm2 = IMX6SDL_DRIVE_STRENGTH,
- .dram_dqm3 = IMX6SDL_DRIVE_STRENGTH,
- .dram_dqm4 = IMX6SDL_DRIVE_STRENGTH,
- .dram_dqm5 = IMX6SDL_DRIVE_STRENGTH,
- .dram_dqm6 = IMX6SDL_DRIVE_STRENGTH,
- .dram_dqm7 = IMX6SDL_DRIVE_STRENGTH,
- .grp_addds = IMX6SDL_DRIVE_STRENGTH,
- .grp_ctlds = IMX6SDL_DRIVE_STRENGTH,
- .grp_b0ds = IMX6SDL_DRIVE_STRENGTH,
- .grp_b1ds = IMX6SDL_DRIVE_STRENGTH,
- .grp_b2ds = IMX6SDL_DRIVE_STRENGTH,
- .grp_b3ds = IMX6SDL_DRIVE_STRENGTH,
- .grp_b4ds = IMX6SDL_DRIVE_STRENGTH,
- .grp_b5ds = IMX6SDL_DRIVE_STRENGTH,
- .grp_b6ds = IMX6SDL_DRIVE_STRENGTH,
- .grp_b7ds = IMX6SDL_DRIVE_STRENGTH,
- .mem_speed = 1600,
- .density = 4,
- .width = 16,
- .banks = 8,
- .rowaddr = 15,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1375,
- .trcmin = 4875,
- .trasmin = 3500,
- .mem_speed = 1333,
- .density = 2,
- .width = 16,
- .banks = 8,
- .rowaddr = 14,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1350,
- .trcmin = 4950,
- .trasmin = 3600,
- .p0_mpwldectrl0 = 0x001f001f,
- .p0_mpwldectrl1 = 0x001f001f,
- .p1_mpwldectrl0 = 0x001f001f,
- .p1_mpwldectrl1 = 0x001f001f,
- .p0_mpdgctrl0 = 0x4301030d,
- .p0_mpdgctrl1 = 0x03020277,
- .p1_mpdgctrl0 = 0x4300030a,
- .p1_mpdgctrl1 = 0x02780248,
- .p0_mprddlctl = 0x4536393b,
- .p1_mprddlctl = 0x36353441,
- .p0_mpwrdlctl = 0x41414743,
- .p1_mpwrdlctl = 0x462f453f,
- .dsize = 2,
- .cs1_mirror = 0,
- /* config for full 4GB range so that get_mem_size() works */
- .cs_density = 32,
- .ncs = 1,
- .bi_on = 1,
- .rtt_nom = 1,
- .rtt_wr = 0,
- .ralat = 5,
- .walat = 0,
- .mif3_mode = 3,
- .rst_to_cke = 0x23,
- .sde_to_rst = 0x10,
- .p0_mpdgctrl0 = 0x420e020e,
- .p0_mpdgctrl1 = 0x02000200,
- .p1_mpdgctrl0 = 0x42020202,
- .p1_mpdgctrl1 = 0x01720172,
- .p0_mprddlctl = 0x494c4f4c,
- .p1_mprddlctl = 0x4a4c4c49,
- .p0_mpwrdlctl = 0x3f3f3133,
- .p1_mpwrdlctl = 0x39373f2e,
- .p0_mpwldectrl0 = 0x0040003c,
- .p0_mpwldectrl1 = 0x0032003e,
- .p0_mpdgctrl0 = 0x42350231,
- .p0_mpdgctrl1 = 0x021a0218,
- .p0_mprddlctl = 0x4b4b4e49,
- .p0_mpwrdlctl = 0x3f3f3035,
- .dsize = 2,
- .cs1_mirror = 0,
- .cs_density = 32,
- .ncs = 1,
- .bi_on = 1,
- .rtt_nom = 1,
- .rtt_wr = 0,
- .ralat = 5,
- .walat = 0,
- .mif3_mode = 3,
- .dsize = 1,
- .cs1_mirror = 0,
- .cs_density = 32,
- .ncs = 1,
- .bi_on = 1,
- .rtt_nom = 1,
- .rtt_wr = 0,
- .ralat = 5,
- .walat = 0,
- .mif3_mode = 3,
- struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- writel(0x00C03F3F, &ccm->CCGR0);
- writel(0x0030FC03, &ccm->CCGR1);
- writel(0x0FFFC000, &ccm->CCGR2);
- writel(0x3FF00000, &ccm->CCGR3);
- writel(0x00FFF300, &ccm->CCGR4);
- writel(0x0F0000C3, &ccm->CCGR5);
- writel(0x000003FF, &ccm->CCGR6);
- struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR;
- /* enable AXI cache for VDOA/VPU/IPU */
- writel(0xF00000CF, &iomux->gpr[4]);
- /* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */
- writel(0x007F007F, &iomux->gpr[6]);
- writel(0x007F007F, &iomux->gpr[7]);
- if (is_cpu_type(MXC_CPU_MX6SOLO)) {
- } else if (is_cpu_type(MXC_CPU_MX6DL)) {
- } else if (is_cpu_type(MXC_CPU_MX6Q)) {
- udelay(100);
- ccgr_init();
- /* setup AIPS and disable watchdog */
- arch_cpu_init();
- gpr_init();
- /* iomux */
- board_early_init_f();
- /* setup GP timer */
- timer_init();
- /* UART clocks enabled and gd valid - init serial console */
- preloader_console_init();
- /* DDR initialization */
- spl_dram_init();
- /* Clear the BSS. */
- memset(__bss_start, 0, __bss_end - __bss_start);
- /* load/boot image from boot device */
- board_init_r(NULL, 0);
- IOMUX_PADS(PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- IOMUX_PADS(PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD1_DAT0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD1_DAT1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD1_DAT2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD1_DAT3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), /* Carrier MicroSD Card Detect */
- IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | MUX_PAD_CTRL(NO_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), /* SOM MicroSD Card Detect */
- IOMUX_PADS(PAD_EIM_DA9__GPIO3_IO09 | MUX_PAD_CTRL(NO_PAD_CTRL)),
- IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TXC__RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TD0__RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TD1__RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TD2__RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TD3__RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RXC__RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RD0__RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RD1__RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RD2__RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RD3__RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL)),
- IOMUX_PADS(PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL)), /* AR8031 PHY Reset */
- IOMUX_PADS(PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL)),
- SETUP_IOMUX_PADS(uart1_pads);
case 1:SETUP_IOMUX_PADS(usdhc3_pads); usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); usdhc_cfg[0].max_bus_width = 4; gpio_direction_input(USDHC3_CD_GPIO); break;
.gp = IMX_GPIO_NR(4, 12) }, .sda = {.gpio_mode = MX6Q_PAD_KEY_COL3__GPIO4_IO12 | MUX_PAD_CTRL(I2C_PAD_CTRL),
- .scl = {
- .sda = {
.gp = IMX_GPIO_NR(4, 13) }.gpio_mode = MX6DL_PAD_KEY_ROW3__GPIO4_IO13 | MUX_PAD_CTRL(I2C_PAD_CTRL),
- IOMUX_PADS(PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK),
- IOMUX_PADS(PAD_DI0_PIN2__IPU1_DI0_PIN02), /* HSync */
- IOMUX_PADS(PAD_DI0_PIN3__IPU1_DI0_PIN03), /* VSync */
- IOMUX_PADS(PAD_DI0_PIN4__IPU1_DI0_PIN04 | MUX_PAD_CTRL(PAD_CTL_DSE_120ohm)), /* Contrast */
- IOMUX_PADS(PAD_DI0_PIN15__IPU1_DI0_PIN15), /* DISP0_DRDY */
- IOMUX_PADS(PAD_DISP0_DAT0__IPU1_DISP0_DATA00),
- IOMUX_PADS(PAD_DISP0_DAT1__IPU1_DISP0_DATA01),
- IOMUX_PADS(PAD_DISP0_DAT2__IPU1_DISP0_DATA02),
- IOMUX_PADS(PAD_DISP0_DAT3__IPU1_DISP0_DATA03),
- IOMUX_PADS(PAD_DISP0_DAT4__IPU1_DISP0_DATA04),
- IOMUX_PADS(PAD_DISP0_DAT5__IPU1_DISP0_DATA05),
- IOMUX_PADS(PAD_DISP0_DAT6__IPU1_DISP0_DATA06),
- IOMUX_PADS(PAD_DISP0_DAT7__IPU1_DISP0_DATA07),
- IOMUX_PADS(PAD_DISP0_DAT8__IPU1_DISP0_DATA08),
- IOMUX_PADS(PAD_DISP0_DAT9__IPU1_DISP0_DATA09),
- IOMUX_PADS(PAD_DISP0_DAT10__IPU1_DISP0_DATA10),
- IOMUX_PADS(PAD_DISP0_DAT11__IPU1_DISP0_DATA11),
- IOMUX_PADS(PAD_DISP0_DAT12__IPU1_DISP0_DATA12),
- IOMUX_PADS(PAD_DISP0_DAT13__IPU1_DISP0_DATA13),
- IOMUX_PADS(PAD_DISP0_DAT14__IPU1_DISP0_DATA14),
- IOMUX_PADS(PAD_DISP0_DAT15__IPU1_DISP0_DATA15),
- IOMUX_PADS(PAD_DISP0_DAT16__IPU1_DISP0_DATA16),
- IOMUX_PADS(PAD_DISP0_DAT17__IPU1_DISP0_DATA17),
- IOMUX_PADS(PAD_SD4_DAT2__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* DISP0_BKLEN */
- IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL)), /* DISP0_VDDEN */
fwadapt_7wvga_pads,
- SETUP_IOMUX_PAD(PAD_DI0_PIN4__GPIO4_IO20); gpio_direction_input(IMX_GPIO_NR(4, 20));
- if (is_cpu_type(MXC_CPU_MX6Q) || is_cpu_type(MXC_CPU_MX6D))
- else
+#endif return 0; }
else
- "fdtfile=undefined\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \
- "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdtfile}\0" \ "mmcboot=echo Booting from mmc ...; " \ "run mmcargs; " \ "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \
"fi;\0"
"fi;\0" \
- "findfdt="\
Hi Fabio,
- Driving strength:
- 0x30 == 40 Ohm
- 0x28 == 48 Ohm
- .density = 4,
- .width = 16,
- .banks = 8,
- .rowaddr = 15,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1375,
- .trcmin = 4875,
- .trasmin = 3500,
- .density = 2,
- .width = 16,
- .banks = 8,
- .rowaddr = 14,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1350,
- .trcmin = 4950,
- .trasmin = 3600,
- .dsize = 2,
- .cs1_mirror = 0,
- .cs_density = 32,
- .ncs = 1,
- .bi_on = 1,
- .rtt_nom = 1,
- .rtt_wr = 0,
- .ralat = 5,
- .walat = 0,
- .mif3_mode = 3,
- .dsize = 2,
- .cs1_mirror = 0,
- .cs_density = 32,
- .ncs = 1,
- .bi_on = 1,
- .rtt_nom = 1,
- .rtt_wr = 0,
- .ralat = 5,
- .walat = 0,
- .mif3_mode = 3,
- .dsize = 1,
- .cs1_mirror = 0,
- .cs_density = 32,
- .ncs = 1,
- .bi_on = 1,
- .rtt_nom = 1,
- .rtt_wr = 0,
- .ralat = 5,
- .walat = 0,
- .mif3_mode = 3,
- udelay(100);
- ccgr_init();
- arch_cpu_init();
- gpr_init();
- /* iomux */
- timer_init();
- spl_dram_init();
- .scl = {
- .sda = {
fwadapt_7wvga_pads,
- else
+#endif return 0; }
else
"fi;\0"
"fi;\0" \
- "findfdt="\
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Hi Stefano,
On Fri, May 15, 2015 at 9:42 AM, Stefano Babic sbabic@denx.de wrote:
Hi Fabio,
Could this one be applied, please?
I would like to send another patch that depends on this one.
Thanks,
Fabio Estevam
Hi Fabio,
My mistake - it was already planned to be merged. I'll apply it.
Regards, Stefano
Fabio Estevam
Stefano Babic
Vagrant Cascadian
