[PATCH] serial: Fix SIFIVE debug serial dependency
The commit 4cc24aeaf420 ("serial: Add missing Kconfig dependencies for debug consoles") has added incorrect dependency for SIFIVE debug uart which should depend on SIFIVE driver instead of PL01x.
drivers/serial/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 17d0e7362379..006cb5a50140 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -359,7 +359,7 @@ config DEBUG_UART_SANDBOX
config DEBUG_UART_SIFIVE bool "SiFive UART" - depends on PL01X_SERIAL + depends on SIFIVE_SERIAL help Select this to enable a debug UART using the serial_sifive driver. You will need to provide parameters to make this work. The driver will
Hi Michal,
Does that mean this should have a Fixes: tag?
Hi Simon,
On 10. 07. 20 2:35, Simon Glass wrote:
Hi Michal,
TBH I had it there but removed it because commit is pointing to it anyway. And also I am not aware about any stable process in place. Or is there any process around that people are looking for fixed tags and picking them to any u-boot stable tree?
Thanks, Michal
On Fri, 10 Jul 2020 at 00:21, Michal Simek michal.simek@xilinx.com wrote:
Hi Simon,
Hi Michal,
+Tom Rini who may know
Hi Simon,
Hi Michal,
We do fixes tags because it's good history.
Hi Simon,
Hi Michal,
ok. Thx. M
Michal Simek
