[U-Boot] [PATCH v2 0/3] ARM: at91: save mmc environment in a FAT file instead of some sectors
I sent these patches days ago with other patches which refactor SAMA5 common configuration files, see URL: http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/203128/focus=203182 Since the patches which refactor SAMA5 common configuration files is rejected. So this time I only send the patches which only convert the mmc environment to FAT file.
Josh Wu (3): ARM: at91: sama5d3_xplained: save environment in a FAT file in MMC card ARM: at91: sama5d3xek: save enviroment as a FAT file in MMC card ARM: at91: at91sam9x5: save environment to a FAT file in MMC card
include/configs/at91sam9x5ek.h | 11 ++++++----- include/configs/sama5d3_xplained.h | 10 ++++++---- include/configs/sama5d3xek.h | 10 ++++++---- 3 files changed, 18 insertions(+), 13 deletions(-)
This patch will save U-Boot environment as a file: uboot.env, in FAT partition instead of saving it in raw sector of MMC card.
This make us easier to manage the environment file.
Signed-off-by: Josh Wu josh.wu@atmel.com ---
include/configs/sama5d3_xplained.h | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index d5588b1..a697035 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -169,13 +169,15 @@ "bootz 0x22000000 - 0x21000000" #elif CONFIG_SYS_USE_MMC /* bootstrap + u-boot + env in sd card */ -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_ENV_OFFSET 0x2000 -#define CONFIG_ENV_SIZE 0x1000 +#define CONFIG_ENV_IS_IN_FAT +#define CONFIG_FAT_WRITE +#define FAT_ENV_INTERFACE "mmc" +#define FAT_ENV_FILE "uboot.env" +#define FAT_ENV_DEVICE_AND_PART "0" +#define CONFIG_ENV_SIZE 0x4000 #define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x21000000 at91-sama5d3_xplained.dtb; " \ "fatload mmc 0:1 0x22000000 zImage; " \ "bootz 0x22000000 - 0x21000000" -#define CONFIG_SYS_MMC_ENV_DEV 0 #else #define CONFIG_ENV_IS_NOWHERE #endif
Hi Josh,
After you remove the duplicated definition.
Acked-by: Bo Shen voice.shen@atmel.com
This has been defined in --->8--- #if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) #define CONFIG_CMD_FAT #define CONFIG_FAT_WRITE ---<8---
Best Regards, Bo Shen
On 1/19/2015 4:16 PM, Bo Shen wrote:
Hi Josh,
Thanks.
Okay, you are right. Will do.
Best Regards, Josh Wu
This patch will save U-Boot environment as a file: uboot.env, in FAT partition instead of in raw sector of MMC card.
include/configs/sama5d3xek.h | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index f2849d7..c29f25b 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -215,13 +215,15 @@ "bootm 0x22000000 - 0x21000000" #elif CONFIG_SYS_USE_MMC /* bootstrap + u-boot + env in sd card */ -#define CONFIG_ENV_IS_IN_MMC -#define CONFIG_ENV_OFFSET 0x2000 -#define CONFIG_ENV_SIZE 0x1000 +#define CONFIG_ENV_IS_IN_FAT +#define CONFIG_FAT_WRITE +#define FAT_ENV_INTERFACE "mmc" +#define FAT_ENV_FILE "uboot.env" +#define FAT_ENV_DEVICE_AND_PART "0" +#define CONFIG_ENV_SIZE 0x4000 #define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x21000000 dtb; " \ "fatload mmc 0:1 0x22000000 uImage; " \ "bootm 0x22000000 - 0x21000000" -#define CONFIG_SYS_MMC_ENV_DEV 0 #else #define CONFIG_ENV_IS_NOWHERE #endif
Hi Josh,
Ackey-by: Bo Shen voice.shen@atmel.com
Nitpick: Can you move in the following condition include? --->8--- #if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) #define CONFIG_CMD_FAT #endif ---8<---
On 1/19/2015 4:18 PM, Bo Shen wrote:
Hi Josh,
sure, it's doable. I'll fix it in next version.
include/configs/at91sam9x5ek.h | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index b1d4baa..6d8b71d 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -203,11 +203,12 @@ "bootm 0x22000000" #else /* CONFIG_SYS_USE_MMC */ /* bootstrap + u-boot + env + linux in mmc */ -#define CONFIG_ENV_IS_IN_MMC -/* For FAT system, most cases it should be in the reserved sector */ -#define CONFIG_ENV_OFFSET 0x2000 -#define CONFIG_ENV_SIZE 0x1000 -#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_IS_IN_FAT +#define CONFIG_FAT_WRITE +#define FAT_ENV_INTERFACE "mmc" +#define FAT_ENV_FILE "uboot.env" +#define FAT_ENV_DEVICE_AND_PART "0" +#define CONFIG_ENV_SIZE 0x4000 #endif
#ifdef CONFIG_SYS_USE_MMC
Hi Josh,
Sorry, I forgot to add following changes:
Changes in v2: - refined commit messages - fix a compile error for at91sam9x5 mmc env file.
Bo Shen
Josh Wu
