[U-Boot] [PATCH] mvsata: issue hard reset on initialization
Before the actual initialization do a hard reset of the SATA port and the connected device.
Signed-off-by: Michael Walle michael@walle.cc Cc: Prafulla Wadaskar prafulla@marvell.com --- drivers/block/mvsata_ide.c | 10 +++++++++- 1 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/drivers/block/mvsata_ide.c b/drivers/block/mvsata_ide.c index 3d6993a..ff880d5 100644 --- a/drivers/block/mvsata_ide.c +++ b/drivers/block/mvsata_ide.c @@ -33,7 +33,9 @@
/* SATA port registers */ struct mvsata_port_registers { - u32 reserved1[192]; + u32 reserved0[10]; + u32 edma_cmd; + u32 reserved1[181]; /* offset 0x300 : ATA Interface registers */ u32 sstatus; u32 serror; @@ -76,6 +78,7 @@ struct mvsata_port_registers { * and for SStatus DETection. */
+#define MVSATA_EDMA_CMD_ATA_RST 0x00000004 #define MVSATA_SCONTROL_DET_MASK 0x0000000F #define MVSATA_SCONTROL_DET_NONE 0x00000000 #define MVSATA_SCONTROL_DET_INIT 0x00000001 @@ -115,6 +118,11 @@ static int mvsata_ide_initialize_port(struct mvsata_port_registers *port) u32 status; u32 timeleft = 10000; /* wait at most 10 ms for SATA reset to complete */
+ /* Hard reset */ + writel(MVSATA_EDMA_CMD_ATA_RST, &port->edma_cmd); + udelay(25); + writel(0, &port->edma_cmd); + /* Set control IPM to 3 (no low power) and DET to 1 (initialize) */ control = readl(&port->scontrol); control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_INIT;
-----Original Message----- From: Michael Walle [mailto:michael@walle.cc] Sent: Monday, May 02, 2011 3:35 AM To: u-boot@lists.denx.de Cc: Michael Walle; Prafulla Wadaskar Subject: [PATCH] mvsata: issue hard reset on initialization
Copying Albert for his ack
Regards.. Prafulla . .
- u32 reserved0[10];
- u32 edma_cmd;
- u32 reserved1[181]; /* offset 0x300 : ATA Interface registers */ u32 sstatus; u32 serror;
- and for SStatus DETection.
- /* Hard reset */
- writel(MVSATA_EDMA_CMD_ATA_RST, &port->edma_cmd);
- udelay(25);
- writel(0, &port->edma_cmd);
- /* Set control IPM to 3 (no low power) and DET to 1 (initialize) */ control = readl(&port->scontrol); control = (control & ~MVSATA_SCONTROL_MASK) | MVSATA_PORT_INIT;
-- 1.7.2.3
Am Montag 02 Mai 2011, 10:37:41 schrieb Prafulla Wadaskar:
any news on this?
Hi Michael,
Sorry for the delay. Busy period for me I'm afraid.
any news on this?
What is the reason for issuing the hard reset? Is it in case the board was rebooted and we want the disk drives to return to a safe state?
Also, why 25?
Amicalement,
Hi Albert,
Am Dienstag 10 Mai 2011, 23:47:04 schrieben Sie:
Hi Michael,
no problem ;)
any news on this?
Right, if i reboot my linkstation (from linux) the ATA probing times out without the reset.
Also, the user manual states (FS_88F6180_9x_6281_OpenSource.pdf, Ch 7.6.9): Device hard reset (setting the <eAtaRst> field in the EDMA Command Register (Table 342 p. 506) and device initialization are required before any attempt to access the device.
Also, why 25?
I took that 25us from the original marvell uboot port (uboot 1.1.4 heavily modified by marvell, the gpl sources provided by buffalo) and from the linux sata_mv driver, both are using 25us.
Hi Michael,
Le 11/05/2011 00:13, Michael Walle a écrit :
Hi Albert,
Hi Michael,
no problem ;)
any news on this?
Also, the user manual states (FS_88F6180_9x_6281_OpenSource.pdf, Ch 7.6.9): Device hard reset (setting the<eAtaRst> field in the EDMA Command Register (Table 342 p. 506) and device initialization are required before any attempt to access the device.
Ok.
Also, why 25?
Can you just add a comment stating that the value was inspired by Marvell use rather than taken from the spec?
Amicalement,
Albert ARIBAUD
Michael Walle
Prafulla Wadaskar
