[U-Boot] [PATCH][v2] armv8: fsl-layerscape: Add support of GPIO structure
Layerscape Gen2 SoC supports GPIO registers to control GPIO signals. Adding support of GPIO structure to access GPIO registers.t rebase --continue
Signed-off-by: Pratiyush Srivastava pratiyush.srivastava@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- Changes for v2: Incorporated York's comments - Removed CONFIG_SYS_GPIO1_ADDR as bool - Renamed CONFIG_SYS_GPIO1_ADDR
This structure is required while supporting ethernent in LS1012AFRDM.
arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index d684a07..f58be96 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -52,6 +52,11 @@ #define QSPI0_BASE_ADDR (CONFIG_SYS_IMMR + 0x00550000) #define DSPI1_BASE_ADDR (CONFIG_SYS_IMMR + 0x01100000)
+#define GPIO1_BASE_ADDR (CONFIG_SYS_IMMR + 0x300000) +#define GPIO2_BASE_ADDR (CONFIG_SYS_IMMR + 0x310000) +#define GPIO3_BASE_ADDR (CONFIG_SYS_IMMR + 0x320000) +#define GPIO4_BASE_ADDR (CONFIG_SYS_IMMR + 0x330000) + #define LPUART_BASE (CONFIG_SYS_IMMR + 0x01950000)
#define AHCI_BASE_ADDR (CONFIG_SYS_IMMR + 0x02200000) @@ -588,6 +593,16 @@ struct ccsr_cci400 { u8 res_e004[0x10000 - 0xe004]; };
+struct ccsr_gpio { + u32 gpdir; + u32 gpodr; + u32 gpdat; + u32 gpier; + u32 gpimr; + u32 gpicr; + u32 gpibe; +}; + /* MMU 500 */ #define SMMU_SCR0 (SMMU_BASE + 0x0) #define SMMU_SCR1 (SMMU_BASE + 0x4)
Prabhakar Kushwaha
