[U-Boot] [PATCH v2 0/6] moveconfig: A few more features
This adds a few more features to moveconfig that I have found useful:
- Allow 'config/' to appear before the defconfig name - Allow reading the defconfig list form stdin - Support for finding CONFIGs which imply those being moved, to reduce patch sizes
Ideally the tool would be able to optimise Kconfig settings to avoid large defconfig patches. The above features are in service of that goal, but we are still some way away from it.
Changes in v2: - Drop unrelated change of line continuation to brackets - Adjust hints to include Tom Rini's <(...) approach - Drop change of 'headers' to 'header' - Update cover letter to express future hopes
Simon Glass (6): moveconfig: Support providing a path to the defconfig files moveconfig: Allow reading the defconfig list from stdin moveconfig: Tidy up the documentation and add hints moveconfig: Add a constant for auto.conf moveconfig: Support building a simple config database moveconfig: Support looking for implied CONFIG options
tools/moveconfig.py | 368 +++++++++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 350 insertions(+), 18 deletions(-)
It is convenient to provide the full patch to the defconfig files in some situations, e.g. when the file was generated by a shell command (e.g. 'ls configs/zynq*').
Add support for this, and move the globbing code into a function with its own documentation.
tools/moveconfig.py | 21 +++++++++++++++++++-- 1 file changed, 19 insertions(+), 2 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 2f674375fd..bfc2295238 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -279,6 +279,24 @@ def get_make_cmd(): sys.exit('GNU Make not found') return ret[0].rstrip()
+def get_matched_defconfig(line): + """Get the defconfig files that match a pattern + + Args: + line: Path or filename to match, e.g. 'configs/snow_defconfig' or + 'k2*_defconfig'. If no directory is provided, 'configs/' is + prepended + + Returns: + a list of matching defconfig files + """ + dirname = os.path.dirname(line) + if dirname: + pattern = line + else: + pattern = os.path.join('configs', line) + return glob.glob(pattern) + glob.glob(pattern + '_defconfig') + def get_matched_defconfigs(defconfigs_file): """Get all the defconfig files that match the patterns in a file.""" defconfigs = [] @@ -286,8 +304,7 @@ def get_matched_defconfigs(defconfigs_file): line = line.strip() if not line: continue # skip blank lines silently - pattern = os.path.join('configs', line) - matched = glob.glob(pattern) + glob.glob(pattern + '_defconfig') + matched = get_matched_defconfig(line) if not matched: print >> sys.stderr, "warning: %s:%d: no defconfig matched '%s'" % \ (defconfigs_file, i + 1, line)
Applied to u-boot-dm, thanks!
Support passes in a defconfig filename of '-' to read the list from stdin instead of from a file.
Changes in v2: None
tools/moveconfig.py | 21 ++++++++++++++++++--- 1 file changed, 18 insertions(+), 3 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index bfc2295238..e48b474fd9 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -298,9 +298,22 @@ def get_matched_defconfig(line): return glob.glob(pattern) + glob.glob(pattern + '_defconfig')
def get_matched_defconfigs(defconfigs_file): - """Get all the defconfig files that match the patterns in a file.""" + """Get all the defconfig files that match the patterns in a file. + + Args: + defconfigs_file: File containing a list of defconfigs to process, or + '-' to read the list from stdin + + Returns: + A list of paths to defconfig files, with no duplicates + """ defconfigs = [] - for i, line in enumerate(open(defconfigs_file)): + if defconfigs_file == '-': + fd = sys.stdin + defconfigs_file = 'stdin' + else: + fd = open(defconfigs_file) + for i, line in enumerate(fd): line = line.strip() if not line: continue # skip blank lines silently @@ -1330,7 +1343,9 @@ def main(): parser.add_option('-C', '--commit', action='store_true', default=False, help='Create a git commit for the operation') parser.add_option('-d', '--defconfigs', type='string', - help='a file containing a list of defconfigs to move') + help='a file containing a list of defconfigs to move, ' + "one per line (for example 'snow_defconfig') " + "or '-' to read from stdin") parser.add_option('-n', '--dry-run', action='store_true', default=False, help='perform a trial run (show log with no changes)') parser.add_option('-e', '--exit-on-error', action='store_true',
Changes in v2: None
The newest clean-up features are not mentioned in the docs. Fix this and add a few hints for particular workflows that are hopefully helpful.
Changes in v2: - Adjust hints to include Tom Rini's <(...) approach - Drop change of 'headers' to 'header'
tools/moveconfig.py | 22 ++++++++++++++++++++-- 1 file changed, 20 insertions(+), 2 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index e48b474fd9..96463fe2e3 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -115,6 +115,23 @@ use your own. Instead of modifying the list directly, you can give them via environments.
+Tips and trips +-------------- + +To sync only X86 defconfigs: + + ./tools/moveconfig.py -s -d <(grep -l X86 configs/*) + +or: + + grep -l X86 configs/* | ./tools/moveconfig.py -s -d - + +To process CONFIG_CMD_FPGAD only for a subset of configs based on path match: + + ls configs/{hrcon*,iocon*,strider*} | \ + ./tools/moveconfig.py -Cy CONFIG_CMD_FPGAD -d - + + Available options -----------------
@@ -128,7 +145,7 @@ Available options
-d, --defconfigs Specify a file containing a list of defconfigs to move. The defconfig - files can be given with shell-style wildcards. + files can be given with shell-style wildcards. Use '-' to read from stdin.
-n, --dry-run Perform a trial run that does not make any changes. It is useful to @@ -169,7 +186,8 @@ Available options
-y, --yes Instead of prompting, automatically go ahead with all operations. This - includes cleaning up headers and CONFIG_SYS_EXTRA_OPTIONS. + includes cleaning up headers, CONFIG_SYS_EXTRA_OPTIONS, the config whitelist + and the README.
To see the complete list of supported options, run
This filename is used a few times. Move it to a constant before adding further uses.
Changes in v2: None
tools/moveconfig.py | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index 96463fe2e3..afab2644e7 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -263,6 +263,9 @@ COLOR_LIGHT_PURPLE = '1;35' COLOR_LIGHT_CYAN = '1;36' COLOR_WHITE = '1;37'
+AUTO_CONF_PATH = 'include/config/auto.conf' + + ### helper functions ### def get_devnull(): """Get the file object of '/dev/null' device.""" @@ -753,8 +756,7 @@ class KconfigParser: self.autoconf = os.path.join(build_dir, 'include', 'autoconf.mk') self.spl_autoconf = os.path.join(build_dir, 'spl', 'include', 'autoconf.mk') - self.config_autoconf = os.path.join(build_dir, 'include', 'config', - 'auto.conf') + self.config_autoconf = os.path.join(build_dir, AUTO_CONF_PATH) self.defconfig = os.path.join(build_dir, 'defconfig')
def get_cross_compile(self): @@ -1072,7 +1074,7 @@ class Slot: self.state = STATE_DEFCONFIG
def do_autoconf(self): - """Run 'make include/config/auto.conf'.""" + """Run 'make AUTO_CONF_PATH'."""
self.cross_compile = self.parser.get_cross_compile() if self.cross_compile is None: @@ -1085,7 +1087,7 @@ class Slot: if self.cross_compile: cmd.append('CROSS_COMPILE=%s' % self.cross_compile) cmd.append('KCONFIG_IGNORE_DUPLICATES=1') - cmd.append('include/config/auto.conf') + cmd.append(AUTO_CONF_PATH) self.ps = subprocess.Popen(cmd, stdout=self.devnull, stderr=subprocess.PIPE, cwd=self.current_src_dir)
Changes in v2: None
Add a -b option which scans all the defconfigs and builds a database of all the CONFIG options used by each. This is useful for querying later.
At present this only works with the separate -b option, which does not move any configs. It would be possible to adjust the script to build the database automatically when moving configs, but this might not be useful as the database does not change that often.
Changes in v2: None
tools/moveconfig.py | 81 ++++++++++++++++++++++++++++++++++++++++++++++++----- 1 file changed, 74 insertions(+), 7 deletions(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index afab2644e7..fab588f239 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -203,11 +203,13 @@ import glob import multiprocessing import optparse import os +import Queue import re import shutil import subprocess import sys import tempfile +import threading import time
SHOW_GNU_MAKE = 'scripts/show-gnu-make' @@ -264,6 +266,7 @@ COLOR_LIGHT_CYAN = '1;36' COLOR_WHITE = '1;37'
AUTO_CONF_PATH = 'include/config/auto.conf' +CONFIG_DATABASE = 'moveconfig.db'
### helper functions ### @@ -942,6 +945,34 @@ class KconfigParser:
return log
+ +class DatabaseThread(threading.Thread): + """This thread processes results from Slot threads. + + It collects the data in the master config directary. There is only one + result thread, and this helps to serialise the build output. + """ + def __init__(self, config_db, db_queue): + """Set up a new result thread + + Args: + builder: Builder which will be sent each result + """ + threading.Thread.__init__(self) + self.config_db = config_db + self.db_queue= db_queue + + def run(self): + """Called to start up the result thread. + + We collect the next result job and pass it on to the build. + """ + while True: + defconfig, configs = self.db_queue.get() + self.config_db[defconfig] = configs + self.db_queue.task_done() + + class Slot:
"""A slot to store a subprocess. @@ -951,7 +982,8 @@ class Slot: for faster processing. """
- def __init__(self, configs, options, progress, devnull, make_cmd, reference_src_dir): + def __init__(self, configs, options, progress, devnull, make_cmd, + reference_src_dir, db_queue): """Create a new process slot.
Arguments: @@ -962,6 +994,7 @@ class Slot: make_cmd: command name of GNU Make. reference_src_dir: Determine the true starting config state from this source tree. + db_queue: output queue to write config info for the database """ self.options = options self.progress = progress @@ -969,6 +1002,7 @@ class Slot: self.devnull = devnull self.make_cmd = (make_cmd, 'O=' + self.build_dir) self.reference_src_dir = reference_src_dir + self.db_queue = db_queue self.parser = KconfigParser(configs, options, self.build_dir) self.state = STATE_IDLE self.failed_boards = set() @@ -1044,6 +1078,8 @@ class Slot: if self.current_src_dir: self.current_src_dir = None self.do_defconfig() + elif self.options.build_db: + self.do_build_db() else: self.do_savedefconfig() elif self.state == STATE_SAVEDEFCONFIG: @@ -1093,6 +1129,17 @@ class Slot: cwd=self.current_src_dir) self.state = STATE_AUTOCONF
+ def do_build_db(self): + """Add the board to the database""" + configs = {} + with open(os.path.join(self.build_dir, AUTO_CONF_PATH)) as fd: + for line in fd.readlines(): + if line.startswith('CONFIG'): + config, value = line.split('=', 1) + configs[config] = value.rstrip() + self.db_queue.put([self.defconfig, configs]) + self.finish(True) + def do_savedefconfig(self): """Update the .config and run 'make savedefconfig'."""
@@ -1175,7 +1222,7 @@ class Slots:
"""Controller of the array of subprocess slots."""
- def __init__(self, configs, options, progress, reference_src_dir): + def __init__(self, configs, options, progress, reference_src_dir, db_queue): """Create a new slots controller.
Arguments: @@ -1184,6 +1231,7 @@ class Slots: progress: A progress indicator. reference_src_dir: Determine the true starting config state from this source tree. + db_queue: output queue to write config info for the database """ self.options = options self.slots = [] @@ -1191,7 +1239,7 @@ class Slots: make_cmd = get_make_cmd() for i in range(options.jobs): self.slots.append(Slot(configs, options, progress, devnull, - make_cmd, reference_src_dir)) + make_cmd, reference_src_dir, db_queue))
def add(self, defconfig): """Add a new subprocess if a vacant slot is found. @@ -1303,7 +1351,7 @@ class ReferenceSource:
return self.src_dir
-def move_config(configs, options): +def move_config(configs, options, db_queue): """Move config options to defconfig files.
Arguments: @@ -1313,6 +1361,8 @@ def move_config(configs, options): if len(configs) == 0: if options.force_sync: print 'No CONFIG is specified. You are probably syncing defconfigs.', + elif options.build_db: + print 'Building %s database' % CONFIG_DATABASE else: print 'Neither CONFIG nor --force-sync is specified. Nothing will happen.', else: @@ -1331,7 +1381,7 @@ def move_config(configs, options): defconfigs = get_all_defconfigs()
progress = Progress(len(defconfigs)) - slots = Slots(configs, options, progress, reference_src_dir) + slots = Slots(configs, options, progress, reference_src_dir, db_queue)
# Main loop to process defconfig files: # Add a new subprocess into a vacant slot. @@ -1358,6 +1408,8 @@ def main():
parser = optparse.OptionParser() # Add options here + parser.add_option('-b', '--build-db', action='store_true', default=False, + help='build a CONFIG database') parser.add_option('-c', '--color', action='store_true', default=False, help='display the log in color') parser.add_option('-C', '--commit', action='store_true', default=False, @@ -1390,7 +1442,7 @@ def main():
(options, configs) = parser.parse_args()
- if len(configs) == 0 and not options.force_sync: + if len(configs) == 0 and not any((options.force_sync, options.build_db)): parser.print_usage() sys.exit(1)
@@ -1400,10 +1452,17 @@ def main():
check_top_directory()
+ config_db = {} + db_queue = Queue.Queue() + t = DatabaseThread(config_db, db_queue) + t.setDaemon(True) + t.start() + if not options.cleanup_headers_only: check_clean_directory() update_cross_compile(options.color) - move_config(configs, options) + move_config(configs, options, db_queue) + db_queue.join()
if configs: cleanup_headers(configs, options) @@ -1423,5 +1482,13 @@ def main(): msg += '\n\nRsync all defconfig files using moveconfig.py' subprocess.call(['git', 'commit', '-s', '-m', msg])
+ if options.build_db: + with open(CONFIG_DATABASE, 'w') as fd: + for defconfig, configs in config_db.iteritems(): + print >>fd, '%s' % defconfig + for config in sorted(configs.keys()): + print >>fd, ' %s=%s' % (config, configs[config]) + print >>fd + if __name__ == '__main__': main()
Changes in v2: None
Some CONFIG options can be implied by others and this can help to reduce the size of the defconfig files. For example, CONFIG_X86 implies CONFIG_CMD_IRQ, so we can put 'imply CMD_IRQ' under 'config X86' and all x86 boards will have that option, avoiding adding CONFIG_CMD_IRQ to each of the x86 defconfig files.
Add a -i option which searches for such options.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Heiko Schocher hs@denx.de ---
Changes in v2: - Update cover letter to express future hopes
tools/moveconfig.py | 215 +++++++++++++++++++++++++++++++++++++++++++++++++++- 1 file changed, 214 insertions(+), 1 deletion(-)
diff --git a/tools/moveconfig.py b/tools/moveconfig.py index fab588f239..09c5a7e5cd 100755 --- a/tools/moveconfig.py +++ b/tools/moveconfig.py @@ -132,6 +132,69 @@ To process CONFIG_CMD_FPGAD only for a subset of configs based on path match: ./tools/moveconfig.py -Cy CONFIG_CMD_FPGAD -d -
+Finding implied CONFIGs +----------------------- + +Some CONFIG options can be implied by others and this can help to reduce +the size of the defconfig files. For example, CONFIG_X86 implies +CONFIG_CMD_IRQ, so we can put 'imply CMD_IRQ' under 'config X86' and +all x86 boards will have that option, avoiding adding CONFIG_CMD_IRQ to +each of the x86 defconfig files. + +This tool can help find such configs. To use it, first build a database: + + ./tools/moveconfig.py -b + +Then try to query it: + + ./tools/moveconfig.py -i CONFIG_CMD_IRQ + CONFIG_CMD_IRQ found in 311/2384 defconfigs + 44 : CONFIG_SYS_FSL_ERRATUM_IFC_A002769 + 41 : CONFIG_SYS_FSL_ERRATUM_A007075 + 31 : CONFIG_SYS_FSL_DDR_VER_44 + 28 : CONFIG_ARCH_P1010 + 28 : CONFIG_SYS_FSL_ERRATUM_P1010_A003549 + 28 : CONFIG_SYS_FSL_ERRATUM_SEC_A003571 + 28 : CONFIG_SYS_FSL_ERRATUM_IFC_A003399 + 25 : CONFIG_SYS_FSL_ERRATUM_A008044 + 22 : CONFIG_ARCH_P1020 + 21 : CONFIG_SYS_FSL_DDR_VER_46 + 20 : CONFIG_MAX_PIRQ_LINKS + 20 : CONFIG_HPET_ADDRESS + 20 : CONFIG_X86 + 20 : CONFIG_PCIE_ECAM_SIZE + 20 : CONFIG_IRQ_SLOT_COUNT + 20 : CONFIG_I8259_PIC + 20 : CONFIG_CPU_ADDR_BITS + 20 : CONFIG_RAMBASE + 20 : CONFIG_SYS_FSL_ERRATUM_A005871 + 20 : CONFIG_PCIE_ECAM_BASE + 20 : CONFIG_X86_TSC_TIMER + 20 : CONFIG_I8254_TIMER + 20 : CONFIG_CMD_GETTIME + 19 : CONFIG_SYS_FSL_ERRATUM_A005812 + 18 : CONFIG_X86_RUN_32BIT + 17 : CONFIG_CMD_CHIP_CONFIG + ... + +This shows a list of config options which might imply CONFIG_CMD_EEPROM along +with how many defconfigs they cover. From this you can see that CONFIG_X86 +implies CONFIG_CMD_EEPROM. Therefore, instead of adding CONFIG_CMD_EEPROM to +the defconfig of every x86 board, you could add a single imply line to the +Kconfig file: + + config X86 + bool "x86 architecture" + ... + imply CMD_EEPROM + +That will cover 20 defconfigs. Many of the options listed are not suitable as +they are not related. E.g. it would be odd for CONFIG_CMD_GETTIME to imply +CMD_EEPROM. + +Using this search you can reduce the size of moveconfig patches. + + Available options -----------------
@@ -195,6 +258,7 @@ To see the complete list of supported options, run
+import collections import copy import difflib import filecmp @@ -1400,6 +1464,148 @@ def move_config(configs, options, db_queue): slots.show_failed_boards() slots.show_suspicious_boards()
+def imply_config(config_list, find_superset=False): + """Find CONFIG options which imply those in the list + + Some CONFIG options can be implied by others and this can help to reduce + the size of the defconfig files. For example, CONFIG_X86 implies + CONFIG_CMD_IRQ, so we can put 'imply CMD_IRQ' under 'config X86' and + all x86 boards will have that option, avoiding adding CONFIG_CMD_IRQ to + each of the x86 defconfig files. + + This function uses the moveconfig database to find such options. It + displays a list of things that could possibly imply those in the list. + The algorithm ignores any that start with CONFIG_TARGET since these + typically refer to only a few defconfigs (often one). It also does not + display a config with less than 5 defconfigs. + + The algorithm works using sets. For each target config in config_list: + - Get the set 'defconfigs' which use that target config + - For each config (from a list of all configs): + - Get the set 'imply_defconfig' of defconfigs which use that config + - + - If imply_defconfigs contains anything not in defconfigs then + this config does not imply the target config + + Params: + config_list: List of CONFIG options to check (each a string) + find_superset: True to look for configs which are a superset of those + already found. So for example if CONFIG_EXYNOS5 implies an option, + but CONFIG_EXYNOS covers a larger set of defconfigs and also + implies that option, this will drop the former in favour of the + latter. In practice this option has not proved very used. + + Note the terminoloy: + config - a CONFIG_XXX options (a string, e.g. 'CONFIG_CMD_EEPROM') + defconfig - a defconfig file (a string, e.g. 'configs/snow_defconfig') + """ + # key is defconfig name, value is dict of (CONFIG_xxx, value) + config_db = {} + + # Holds a dict containing the set of defconfigs that contain each config + # key is config, value is set of defconfigs using that config + defconfig_db = collections.defaultdict(set) + + # Set of all config options we have seen + all_configs = set() + + # Set of all defconfigs we have seen + all_defconfigs = set() + + # Read in the database + configs = {} + with open(CONFIG_DATABASE) as fd: + for line in fd.readlines(): + line = line.rstrip() + if not line: # Separator between defconfigs + config_db[defconfig] = configs + all_defconfigs.add(defconfig) + configs = {} + elif line[0] == ' ': # CONFIG line + config, value = line.strip().split('=', 1) + configs[config] = value + defconfig_db[config].add(defconfig) + all_configs.add(config) + else: # New defconfig + defconfig = line + + # Work through each target config option in tern, independently + for config in config_list: + defconfigs = defconfig_db.get(config) + if not defconfigs: + print '%s not found in any defconfig' % config + continue + + # Get the set of defconfigs without this one (since a config cannot + # imply itself) + non_defconfigs = all_defconfigs - defconfigs + num_defconfigs = len(defconfigs) + print '%s found in %d/%d defconfigs' % (config, num_defconfigs, + len(all_configs)) + + # This will hold the results: key=config, value=defconfigs containing it + imply_configs = {} + rest_configs = all_configs - set([config]) + + # Look at every possible config, except the target one + for imply_config in rest_configs: + if 'CONFIG_TARGET' in imply_config: + continue + + # Find set of defconfigs that have this config + imply_defconfig = defconfig_db[imply_config] + + # Get the intersection of this with defconfigs containing the + # target config + common_defconfigs = imply_defconfig & defconfigs + + # Get the set of defconfigs containing this config which DO NOT + # also contain the taret config. If this set is non-empty it means + # that this config affects other defconfigs as well as (possibly) + # the ones affected by the target config. This means it implies + # things we don't want to imply. + not_common_defconfigs = imply_defconfig & non_defconfigs + if not_common_defconfigs: + continue + + # If there are common defconfigs, imply_config may be useful + if common_defconfigs: + skip = False + if find_superset: + for prev in imply_configs.keys(): + prev_count = len(imply_configs[prev]) + count = len(common_defconfigs) + if (prev_count > count and + (imply_configs[prev] & common_defconfigs == + common_defconfigs)): + # skip imply_config because prev is a superset + skip = True + break + elif count > prev_count: + # delete prev because imply_config is a superset + del imply_configs[prev] + if not skip: + imply_configs[imply_config] = common_defconfigs + + # Now we have a dict imply_configs of configs which imply each config + # The value of each dict item is the set of defconfigs containing that + # config. Rank them so that we print the configs that imply the largest + # number of defconfigs first. + ranked_configs = sorted(imply_configs, + key=lambda k: len(imply_configs[k]), reverse=True) + for config in ranked_configs: + num_common = len(imply_configs[config]) + + # Don't bother if there are less than 5 defconfigs affected. + if num_common < 5: + continue + missing = defconfigs - imply_configs[config] + missing_str = ', '.join(missing) if missing else 'all' + missing_str = '' + print ' %d : %-30s%s' % (num_common, config.ljust(30), + missing_str) + + def main(): try: cpu_count = multiprocessing.cpu_count() @@ -1418,6 +1624,8 @@ def main(): help='a file containing a list of defconfigs to move, ' "one per line (for example 'snow_defconfig') " "or '-' to read from stdin") + parser.add_option('-i', '--imply', action='store_true', default=False, + help='find options which imply others') parser.add_option('-n', '--dry-run', action='store_true', default=False, help='perform a trial run (show log with no changes)') parser.add_option('-e', '--exit-on-error', action='store_true', @@ -1442,7 +1650,8 @@ def main():
- if len(configs) == 0 and not any((options.force_sync, options.build_db)): + if len(configs) == 0 and not any((options.force_sync, options.build_db, + options.imply)): parser.print_usage() sys.exit(1)
@@ -1452,6 +1661,10 @@ def main():
+ if options.imply: + imply_config(configs) + return + config_db = {} db_queue = Queue.Queue() t = DatabaseThread(config_db, db_queue)
sjg@google.com
