[U-Boot] Accessing nested device tree nodes via phandle
Hi everybody,
I am working on reorganization of device trees for ARC boards in U-Boot in order to create a common device tree blob for both Linux and U-Boot.
And I've struggled with a kind of problem and need some help.
On AXS10x motherboard clocks for various peripherals are managed by one hardware block, so clock nodes in Linux device tree are grouped into one "clocks" node like this: ---------------------------------->8------------------------------------ clocks { i2cclk: i2cclk { compatible = "fixed-clock"; clock-frequency = <50000000>; #clock-cells = <0>; }; ... ... ... uartclk: uartclk { compatible = "fixed-clock"; clock-frequency = <33333333>; #clock-cells = <0>; }; }; ---------------------------------->8------------------------------------ And then some of them a referenced via phandle from other nodes, e.g. &uartclk is referenced from uart node.
When I try to create such hierarchy in U-Boot I find that uart driver is not able to get clock via phandle and corresponding uart doesn't work.
As I understand that is because children clocks nodes, i.e. "uartclk" in my case, never got bound as it's parent node "clocks" never got bound too. So when I add "compatible" and "u-boot,dm-pre-reloc" properties to "clocks" parent node everything works fine, e.g.: ---------------------------------->8------------------------------------ clocks { compatible = "simple-bus"; u-boot,dm-pre-reloc; uartclk: uartclk { compatible = "fixed-clock"; clock-frequency = <33333333>; #clock-cells = <0>; }; ... ... ... }; ---------------------------------->8------------------------------------
Please correct me if I wrongly interpret such behavior.
I wonder if it the only approach to implement Linux-like hierarchy for ARC? Or I am mistaken and in fact can use pure Linux device tree without adding properties, described above?
Thank you!
Hi Vlad,
On 20 December 2016 at 08:53, Vlad Zakharov Vladislav.Zakharov@synopsys.com wrote:
Hi everybody,
Yes you have it right. I'm not sure what linux is doing here - does it look for a node called 'clocks'? To my mind, U-Boot is the more correct.
Vlad Zakharov
