[U-Boot] [PATCH] pinctrl: uniphier: set input-enable before pin-muxing
While IECTRL is disabled, input signals are pulled-down internally. If pin-muxing is set up first, glitch signals (Low to High transition) might be input to hardware blocks.
Bad case scenario: [1] The hardware block is already running before pinctrl is handled. (the reset is de-asserted by default or by a firmware, for example) [2] The pin-muxing is set up. The input signals to hardware block are pulled-down by the chip-internal biasing. [3] The pins are input-enabled. The signals from the board reach the hardware block.
Actually, one invalid character is input to the UART blocks for such SoCs as PH1-LD4, PH1-sLD8, where UART devices start to run at the power on reset.
To avoid such problems, pins should be input-enabled before muxing.
[ ported from Linux commit bac7f4c1bf5e7c6ccd5bb71edc015b26c77f7460 ]
Fixes: 5dc626f83619 ("pinctrl: uniphier: add UniPhier pinctrl core support") Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
drivers/pinctrl/uniphier/pinctrl-uniphier-core.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c index 37a920c..ffdccab 100644 --- a/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c +++ b/drivers/pinctrl/uniphier/pinctrl-uniphier-core.c @@ -74,6 +74,9 @@ static void uniphier_pinmux_set_one(struct udevice *dev, unsigned pin, unsigned reg, reg_end, shift, mask; u32 tmp;
+ /* some pins need input-enabling */ + uniphier_pinconf_input_enable(dev, pin); + reg = UNIPHIER_PINCTRL_PINMUX_BASE + pin * mux_bits / 32 * reg_stride; reg_end = reg + reg_stride; shift = pin * mux_bits % 32; @@ -94,9 +97,6 @@ static void uniphier_pinmux_set_one(struct udevice *dev, unsigned pin,
if (priv->socdata->load_pinctrl) writel(1, priv->base + UNIPHIER_PINCTRL_LOAD_PINMUX); - - /* some pins need input-enabling */ - uniphier_pinconf_input_enable(dev, pin); }
static int uniphier_pinmux_group_set(struct udevice *dev,
2016-03-04 15:56 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
