[U-Boot] [PATCH 1/1] efi_loader: error handling for `efidebug boot add`
In `efidebug boot add iPXE scsi 0:1 snp-arm64.efi --foo` a parameter is missing. Hence the command should not silently return as if everything were ok but should display the usage info.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/efidebug.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 5072a7b39bc..db96682c5a4 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -491,7 +491,7 @@ static int do_efi_boot_add(cmd_tbl_t *cmdtp, int flag,
id = (int)simple_strtoul(argv[1], &endp, 16); if (*endp != '\0' || id > 0xffff) - return CMD_RET_FAILURE; + return CMD_RET_USAGE;
sprintf(var_name, "Boot%04X", id); p = var_name16;
Reviewed-by: Alexander Graf agraf@csgraf.de
Alex
Alexander Graf
