[U-Boot-Users] [PATCH] Updates for evb4510 (ARM7)
This patch is for the evb4510 target. The patch adds support for a timer interrupt and cleans up the config header file for passing boot arguments to linux.
u-boot/board/evb4510/evb4510.c ==============================
Removed code related to the non-interrupt method for timers.
u-boot/cpu/arm720t/interrupts.c ===============================
Added interrupt handling. Timer interrupt configuration.
u-boot/include/asm-arm/arch-arm720t/s3c4510b.h ==============================================
Added macros and constants related to interrupts
u-boot/include/configs/evb4510.h ================================
Changed boot args. Enabled CONFIG_CMDLINE_TAG, CONFIG_SETUP_MEMORY_TAGS and CONFIG_INITRD_TAG
u-boot/lib_arm/armlinux.c =========================
Copy the ramdisk to destination address for this target (similar to the B2 target).
Curt Brune
