[PATCH 1/3] ARM: dts: uniphier: rename DT nodes to follow json-schema
Import the nodename changes I made in Linux for avoiding dt-schama warnings. This follows the $nodename patterns in the dt-schema.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/dts/uniphier-ld11.dtsi | 6 +++--- arch/arm/dts/uniphier-ld20.dtsi | 8 ++++---- arch/arm/dts/uniphier-ld4.dtsi | 10 +++++----- arch/arm/dts/uniphier-pro4.dtsi | 12 ++++++------ arch/arm/dts/uniphier-pro5.dtsi | 12 ++++++------ arch/arm/dts/uniphier-pxs2.dtsi | 10 +++++----- arch/arm/dts/uniphier-pxs3.dtsi | 8 ++++---- arch/arm/dts/uniphier-sld8.dtsi | 10 +++++----- 8 files changed, 38 insertions(+), 38 deletions(-)
diff --git a/arch/arm/dts/uniphier-ld11.dtsi b/arch/arm/dts/uniphier-ld11.dtsi index 337a3537ed28..b3d44e868956 100644 --- a/arch/arm/dts/uniphier-ld11.dtsi +++ b/arch/arm/dts/uniphier-ld11.dtsi @@ -433,7 +433,7 @@ }; };
- emmc: sdhc@5a000000 { + emmc: mmc@5a000000 { compatible = "socionext,uniphier-sd4hc", "cdns,sd4hc"; reg = <0x5a000000 0x400>; interrupts = <0 78 4>; @@ -566,7 +566,7 @@ }; };
- aidet: aidet@5fc20000 { + aidet: interrupt-controller@5fc20000 { compatible = "socionext,uniphier-ld11-aidet"; reg = <0x5fc20000 0x200>; interrupt-controller; @@ -621,7 +621,7 @@ }; };
- nand: nand@68000000 { + nand: nand-controller@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; reg-names = "nand_data", "denali_reg"; diff --git a/arch/arm/dts/uniphier-ld20.dtsi b/arch/arm/dts/uniphier-ld20.dtsi index 3721110b17a7..5a7bd3301dd7 100644 --- a/arch/arm/dts/uniphier-ld20.dtsi +++ b/arch/arm/dts/uniphier-ld20.dtsi @@ -559,7 +559,7 @@ }; };
- emmc: sdhc@5a000000 { + emmc: mmc@5a000000 { compatible = "socionext,uniphier-sd4hc", "cdns,sd4hc"; reg = <0x5a000000 0x400>; interrupts = <0 78 4>; @@ -578,7 +578,7 @@ cdns,phy-dll-delay-sdclk-hsmmc = <21>; };
- sd: sdhc@5a400000 { + sd: mmc@5a400000 { compatible = "socionext,uniphier-sd-v3.1.1"; status = "disabled"; reg = <0x5a400000 0x800>; @@ -664,7 +664,7 @@ }; };
- aidet: aidet@5fc20000 { + aidet: interrupt-controller@5fc20000 { compatible = "socionext,uniphier-ld20-aidet"; reg = <0x5fc20000 0x200>; interrupt-controller; @@ -944,7 +944,7 @@ socionext,syscon = <&soc_glue>; };
- nand: nand@68000000 { + nand: nand-controller@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; reg-names = "nand_data", "denali_reg"; diff --git a/arch/arm/dts/uniphier-ld4.dtsi b/arch/arm/dts/uniphier-ld4.dtsi index c2706cef0b8a..e40407a0dfa5 100644 --- a/arch/arm/dts/uniphier-ld4.dtsi +++ b/arch/arm/dts/uniphier-ld4.dtsi @@ -51,7 +51,7 @@ ranges; interrupt-parent = <&intc>;
- l2: l2-cache@500c0000 { + l2: cache-controller@500c0000 { compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; @@ -245,7 +245,7 @@ #dma-cells = <1>; };
- sd: sdhc@5a400000 { + sd: mmc@5a400000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a400000 0x200>; @@ -265,7 +265,7 @@ sd-uhs-sdr50; };
- emmc: sdhc@5a500000 { + emmc: mmc@5a500000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a500000 0x200>; @@ -375,7 +375,7 @@ interrupt-controller; };
- aidet: aidet@61830000 { + aidet: interrupt-controller@61830000 { compatible = "socionext,uniphier-ld4-aidet"; reg = <0x61830000 0x200>; interrupt-controller; @@ -398,7 +398,7 @@ }; };
- nand: nand@68000000 { + nand: nand-controller@68000000 { compatible = "socionext,uniphier-denali-nand-v5a"; status = "disabled"; reg-names = "nand_data", "denali_reg"; diff --git a/arch/arm/dts/uniphier-pro4.dtsi b/arch/arm/dts/uniphier-pro4.dtsi index d090fc7e2d8b..7e81260d33d3 100644 --- a/arch/arm/dts/uniphier-pro4.dtsi +++ b/arch/arm/dts/uniphier-pro4.dtsi @@ -59,7 +59,7 @@ ranges; interrupt-parent = <&intc>;
- l2: l2-cache@500c0000 { + l2: cache-controller@500c0000 { compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; @@ -279,7 +279,7 @@ #dma-cells = <1>; };
- sd: sdhc@5a400000 { + sd: mmc@5a400000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a400000 0x200>; @@ -299,7 +299,7 @@ sd-uhs-sdr50; };
- emmc: sdhc@5a500000 { + emmc: mmc@5a500000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a500000 0x200>; @@ -317,7 +317,7 @@ non-removable; };
- sd1: sdhc@5a600000 { + sd1: mmc@5a600000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a600000 0x200>; @@ -426,7 +426,7 @@ }; };
- aidet: aidet@5fc20000 { + aidet: interrupt-controller@5fc20000 { compatible = "socionext,uniphier-pro4-aidet"; reg = <0x5fc20000 0x200>; interrupt-controller; @@ -626,7 +626,7 @@ }; };
- nand: nand@68000000 { + nand: nand-controller@68000000 { compatible = "socionext,uniphier-denali-nand-v5a"; status = "disabled"; reg-names = "nand_data", "denali_reg"; diff --git a/arch/arm/dts/uniphier-pro5.dtsi b/arch/arm/dts/uniphier-pro5.dtsi index 9cad79d0860e..05828d785cec 100644 --- a/arch/arm/dts/uniphier-pro5.dtsi +++ b/arch/arm/dts/uniphier-pro5.dtsi @@ -131,7 +131,7 @@ ranges; interrupt-parent = <&intc>;
- l2: l2-cache@500c0000 { + l2: cache-controller@500c0000 { compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x8>, <0x506c0000 0x400>; @@ -144,7 +144,7 @@ next-level-cache = <&l3>; };
- l3: l3-cache@500c8000 { + l3: cache-controller@500c8000 { compatible = "socionext,uniphier-system-cache"; reg = <0x500c8000 0x2000>, <0x503c8100 0x8>, <0x506c8000 0x400>; @@ -408,7 +408,7 @@ }; };
- aidet: aidet@5fc20000 { + aidet: interrupt-controller@5fc20000 { compatible = "socionext,uniphier-pro5-aidet"; reg = <0x5fc20000 0x200>; interrupt-controller; @@ -489,7 +489,7 @@ }; };
- nand: nand@68000000 { + nand: nand-controller@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; reg-names = "nand_data", "denali_reg"; @@ -502,7 +502,7 @@ resets = <&sys_rst 2>; };
- emmc: sdhc@68400000 { + emmc: mmc@68400000 { compatible = "socionext,uniphier-sd-v3.1"; status = "disabled"; reg = <0x68400000 0x800>; @@ -518,7 +518,7 @@ non-removable; };
- sd: sdhc@68800000 { + sd: mmc@68800000 { compatible = "socionext,uniphier-sd-v3.1"; status = "disabled"; reg = <0x68800000 0x800>; diff --git a/arch/arm/dts/uniphier-pxs2.dtsi b/arch/arm/dts/uniphier-pxs2.dtsi index 4e11e85d8dd7..bf852c28005a 100644 --- a/arch/arm/dts/uniphier-pxs2.dtsi +++ b/arch/arm/dts/uniphier-pxs2.dtsi @@ -157,7 +157,7 @@ ranges; interrupt-parent = <&intc>;
- l2: l2-cache@500c0000 { + l2: cache-controller@500c0000 { compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x8>, <0x506c0000 0x400>; @@ -446,7 +446,7 @@ }; };
- emmc: sdhc@5a000000 { + emmc: mmc@5a000000 { compatible = "socionext,uniphier-sd-v3.1.1"; status = "disabled"; reg = <0x5a000000 0x800>; @@ -462,7 +462,7 @@ non-removable; };
- sd: sdhc@5a400000 { + sd: mmc@5a400000 { compatible = "socionext,uniphier-sd-v3.1.1"; status = "disabled"; reg = <0x5a400000 0x800>; @@ -508,7 +508,7 @@ }; };
- aidet: aidet@5fc20000 { + aidet: interrupt-controller@5fc20000 { compatible = "socionext,uniphier-pxs2-aidet"; reg = <0x5fc20000 0x200>; interrupt-controller; @@ -799,7 +799,7 @@ }; };
- nand: nand@68000000 { + nand: nand-controller@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; reg-names = "nand_data", "denali_reg"; diff --git a/arch/arm/dts/uniphier-pxs3.dtsi b/arch/arm/dts/uniphier-pxs3.dtsi index b1aff285c8b7..f830cef8941e 100644 --- a/arch/arm/dts/uniphier-pxs3.dtsi +++ b/arch/arm/dts/uniphier-pxs3.dtsi @@ -353,7 +353,7 @@ }; };
- emmc: sdhc@5a000000 { + emmc: mmc@5a000000 { compatible = "socionext,uniphier-sd4hc", "cdns,sd4hc"; reg = <0x5a000000 0x400>; interrupts = <0 78 4>; @@ -372,7 +372,7 @@ cdns,phy-dll-delay-sdclk-hsmmc = <21>; };
- sd: sdhc@5a400000 { + sd: mmc@5a400000 { compatible = "socionext,uniphier-sd-v3.1.1"; status = "disabled"; reg = <0x5a400000 0x800>; @@ -462,7 +462,7 @@ }; };
- aidet: aidet@5fc20000 { + aidet: interrupt-controller@5fc20000 { compatible = "socionext,uniphier-pxs3-aidet"; reg = <0x5fc20000 0x200>; interrupt-controller; @@ -821,7 +821,7 @@ socionext,syscon = <&soc_glue>; };
- nand: nand@68000000 { + nand: nand-controller@68000000 { compatible = "socionext,uniphier-denali-nand-v5b"; status = "disabled"; reg-names = "nand_data", "denali_reg"; diff --git a/arch/arm/dts/uniphier-sld8.dtsi b/arch/arm/dts/uniphier-sld8.dtsi index efce02768b6f..332a4da9d659 100644 --- a/arch/arm/dts/uniphier-sld8.dtsi +++ b/arch/arm/dts/uniphier-sld8.dtsi @@ -51,7 +51,7 @@ ranges; interrupt-parent = <&intc>;
- l2: l2-cache@500c0000 { + l2: cache-controller@500c0000 { compatible = "socionext,uniphier-system-cache"; reg = <0x500c0000 0x2000>, <0x503c0100 0x4>, <0x506c0000 0x400>; @@ -249,7 +249,7 @@ #dma-cells = <1>; };
- sd: sdhc@5a400000 { + sd: mmc@5a400000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a400000 0x200>; @@ -269,7 +269,7 @@ sd-uhs-sdr50; };
- emmc: sdhc@5a500000 { + emmc: mmc@5a500000 { compatible = "socionext,uniphier-sd-v2.91"; status = "disabled"; reg = <0x5a500000 0x200>; @@ -379,7 +379,7 @@ interrupt-controller; };
- aidet: aidet@61830000 { + aidet: interrupt-controller@61830000 { compatible = "socionext,uniphier-sld8-aidet"; reg = <0x61830000 0x200>; interrupt-controller; @@ -402,7 +402,7 @@ }; };
Import Linux commits:
37f3e0096f71 ("ARM: dts: uniphier: add reset-names to NAND controller node") e98d5023fe1f ("arm64: dts: uniphier: add reset-names to NAND controller node")
arch/arm/dts/uniphier-ld11.dtsi | 3 ++- arch/arm/dts/uniphier-ld20.dtsi | 3 ++- arch/arm/dts/uniphier-ld4.dtsi | 3 ++- arch/arm/dts/uniphier-pro4.dtsi | 3 ++- arch/arm/dts/uniphier-pro5.dtsi | 3 ++- arch/arm/dts/uniphier-pxs2.dtsi | 3 ++- arch/arm/dts/uniphier-pxs3.dtsi | 3 ++- arch/arm/dts/uniphier-sld8.dtsi | 3 ++- 8 files changed, 16 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/uniphier-ld11.dtsi b/arch/arm/dts/uniphier-ld11.dtsi index b3d44e868956..e0737ac7f06c 100644 --- a/arch/arm/dts/uniphier-ld11.dtsi +++ b/arch/arm/dts/uniphier-ld11.dtsi @@ -631,7 +631,8 @@ pinctrl-0 = <&pinctrl_nand>; clock-names = "nand", "nand_x", "ecc"; clocks = <&sys_clk 2>, <&sys_clk 3>, <&sys_clk 3>; - resets = <&sys_rst 2>; + reset-names = "nand", "reg"; + resets = <&sys_rst 2>, <&sys_rst 2>; }; }; }; diff --git a/arch/arm/dts/uniphier-ld20.dtsi b/arch/arm/dts/uniphier-ld20.dtsi index 5a7bd3301dd7..59e4191dfc39 100644 --- a/arch/arm/dts/uniphier-ld20.dtsi +++ b/arch/arm/dts/uniphier-ld20.dtsi @@ -954,7 +954,8 @@ pinctrl-0 = <&pinctrl_nand>; clock-names = "nand", "nand_x", "ecc"; clocks = <&sys_clk 2>, <&sys_clk 3>, <&sys_clk 3>; - resets = <&sys_rst 2>; + reset-names = "nand", "reg"; + resets = <&sys_rst 2>, <&sys_rst 2>; }; }; }; diff --git a/arch/arm/dts/uniphier-ld4.dtsi b/arch/arm/dts/uniphier-ld4.dtsi index e40407a0dfa5..1eebc7fa3bee 100644 --- a/arch/arm/dts/uniphier-ld4.dtsi +++ b/arch/arm/dts/uniphier-ld4.dtsi @@ -408,7 +408,8 @@ pinctrl-0 = <&pinctrl_nand2cs>; clock-names = "nand", "nand_x", "ecc"; clocks = <&sys_clk 2>, <&sys_clk 3>, <&sys_clk 3>; - resets = <&sys_rst 2>; + reset-names = "nand", "reg"; + resets = <&sys_rst 2>, <&sys_rst 2>; }; }; }; diff --git a/arch/arm/dts/uniphier-pro4.dtsi b/arch/arm/dts/uniphier-pro4.dtsi index 7e81260d33d3..d006b45f7a3d 100644 --- a/arch/arm/dts/uniphier-pro4.dtsi +++ b/arch/arm/dts/uniphier-pro4.dtsi @@ -636,7 +636,8 @@ pinctrl-0 = <&pinctrl_nand>; clock-names = "nand", "nand_x", "ecc"; clocks = <&sys_clk 2>, <&sys_clk 3>, <&sys_clk 3>; - resets = <&sys_rst 2>; + reset-names = "nand", "reg"; + resets = <&sys_rst 2>, <&sys_rst 2>; }; }; }; diff --git a/arch/arm/dts/uniphier-pro5.dtsi b/arch/arm/dts/uniphier-pro5.dtsi index 05828d785cec..ba7e224b38e6 100644 --- a/arch/arm/dts/uniphier-pro5.dtsi +++ b/arch/arm/dts/uniphier-pro5.dtsi @@ -499,7 +499,8 @@ pinctrl-0 = <&pinctrl_nand2cs>; clock-names = "nand", "nand_x", "ecc"; clocks = <&sys_clk 2>, <&sys_clk 3>, <&sys_clk 3>; - resets = <&sys_rst 2>; + reset-names = "nand", "reg"; + resets = <&sys_rst 2>, <&sys_rst 2>; };
emmc: mmc@68400000 { diff --git a/arch/arm/dts/uniphier-pxs2.dtsi b/arch/arm/dts/uniphier-pxs2.dtsi index bf852c28005a..8d968d368102 100644 --- a/arch/arm/dts/uniphier-pxs2.dtsi +++ b/arch/arm/dts/uniphier-pxs2.dtsi @@ -809,7 +809,8 @@ pinctrl-0 = <&pinctrl_nand2cs>; clock-names = "nand", "nand_x", "ecc"; clocks = <&sys_clk 2>, <&sys_clk 3>, <&sys_clk 3>; - resets = <&sys_rst 2>; + reset-names = "nand", "reg"; + resets = <&sys_rst 2>, <&sys_rst 2>; }; }; }; diff --git a/arch/arm/dts/uniphier-pxs3.dtsi b/arch/arm/dts/uniphier-pxs3.dtsi index f830cef8941e..ed079c171137 100644 --- a/arch/arm/dts/uniphier-pxs3.dtsi +++ b/arch/arm/dts/uniphier-pxs3.dtsi @@ -831,7 +831,8 @@ pinctrl-0 = <&pinctrl_nand>; clock-names = "nand", "nand_x", "ecc"; clocks = <&sys_clk 2>, <&sys_clk 3>, <&sys_clk 3>; - resets = <&sys_rst 2>; + reset-names = "nand", "reg"; + resets = <&sys_rst 2>, <&sys_rst 2>; }; }; }; diff --git a/arch/arm/dts/uniphier-sld8.dtsi b/arch/arm/dts/uniphier-sld8.dtsi index 332a4da9d659..393157eb14ed 100644 --- a/arch/arm/dts/uniphier-sld8.dtsi +++ b/arch/arm/dts/uniphier-sld8.dtsi @@ -412,7 +412,8 @@ pinctrl-0 = <&pinctrl_nand2cs>; clock-names = "nand", "nand_x", "ecc"; clocks = <&sys_clk 2>, <&sys_clk 3>, <&sys_clk 3>; - resets = <&sys_rst 2>; + reset-names = "nand", "reg"; + resets = <&sys_rst 2>, <&sys_rst 2>; }; }; };
On Fri, Feb 28, 2020 at 9:58 PM Masahiro Yamada yamada.masahiro@socionext.com wrote:
Applied to u-boot-uniphier.
resets = <&sys_rst 2>, <&sys_rst 2>; }; emmc: mmc@68400000 {
2.17.1
The compatible string "i2c-eeprom" is U-Boot own compatible, which has never been approved by the DT community. "u-boot,i2c-offset-len" is also a U-Boot own hack.
Linux adds "atmel,*" as generic compatibles, and U-Boot also followed it by commit d7e28918aa3f ("i2c_eeprom: Add reading support").
The U-Boot own hack is no longer needed. Just sync with Linux.
arch/arm/dts/uniphier-ld11-global.dts | 2 +- arch/arm/dts/uniphier-pro4-ace.dts | 3 +-- arch/arm/dts/uniphier-pro4-sanji.dts | 3 +-- arch/arm/dts/uniphier-pxs2-gentil.dts | 3 +-- arch/arm/dts/uniphier-ref-daughter.dtsi | 3 +-- 5 files changed, 5 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/uniphier-ld11-global.dts b/arch/arm/dts/uniphier-ld11-global.dts index 744b36e28a33..7968d524351b 100644 --- a/arch/arm/dts/uniphier-ld11-global.dts +++ b/arch/arm/dts/uniphier-ld11-global.dts @@ -132,7 +132,7 @@ };
eeprom@50 { - compatible = "st,24c64", "atmel,24c64", "i2c-eeprom"; + compatible = "st,24c64", "atmel,24c64"; reg = <0x50>; pagesize = <32>; }; diff --git a/arch/arm/dts/uniphier-pro4-ace.dts b/arch/arm/dts/uniphier-pro4-ace.dts index ce8ea7b79bbf..92cc48dd86d0 100644 --- a/arch/arm/dts/uniphier-pro4-ace.dts +++ b/arch/arm/dts/uniphier-pro4-ace.dts @@ -50,10 +50,9 @@ status = "okay";
eeprom@54 { - compatible = "st,24c64", "atmel,24c64", "i2c-eeprom"; + compatible = "st,24c64", "atmel,24c64"; reg = <0x54>; pagesize = <32>; - u-boot,i2c-offset-len = <2>; }; };
diff --git a/arch/arm/dts/uniphier-pro4-sanji.dts b/arch/arm/dts/uniphier-pro4-sanji.dts index 686dd3af7e95..3b68a7c605c2 100644 --- a/arch/arm/dts/uniphier-pro4-sanji.dts +++ b/arch/arm/dts/uniphier-pro4-sanji.dts @@ -45,10 +45,9 @@ status = "okay";
diff --git a/arch/arm/dts/uniphier-pxs2-gentil.dts b/arch/arm/dts/uniphier-pxs2-gentil.dts index b13d6277bf13..e27fd4f2a569 100644 --- a/arch/arm/dts/uniphier-pxs2-gentil.dts +++ b/arch/arm/dts/uniphier-pxs2-gentil.dts @@ -48,10 +48,9 @@ status = "okay";
diff --git a/arch/arm/dts/uniphier-ref-daughter.dtsi b/arch/arm/dts/uniphier-ref-daughter.dtsi index 9240a313b933..a11897669c26 100644 --- a/arch/arm/dts/uniphier-ref-daughter.dtsi +++ b/arch/arm/dts/uniphier-ref-daughter.dtsi @@ -7,9 +7,8 @@
&i2c0 { eeprom@50 { - compatible = "microchip,24lc128", "i2c-eeprom"; + compatible = "microchip,24lc128", "atmel,24c128"; reg = <0x50>; pagesize = <64>; - u-boot,i2c-offset-len = <2>; }; };
eeprom@50 {
eeprom@54 {
eeprom@54 {
eeprom@54 {
&i2c0 { eeprom@50 {
2.17.1
sd: sdhc@5a400000 {
sd: sdhc@5a400000 {
sd: sdhc@5a400000 {
sd: sdhc@68800000 {
sd: sdhc@5a400000 {
sd: sdhc@5a400000 {
sd: sdhc@5a400000 {
-- 2.17.1
Masahiro Yamada
