[u-boot][PATCH] mtd: nand: Fix SPL build after migration of CONFIG_SYS_NAND_SELF_INIT to Kconfig
This fixes the below build error if nand.c is included in an SPL build.
/work/u-boot/drivers/mtd/nand/raw/nand.c: In function ‘nand_init_chip’: /work/u-boot/drivers/mtd/nand/raw/nand.c:82:28: error: ‘nand_chip’ undeclared (first use in this function) 82 | struct nand_chip *nand = &nand_chip[i]; | ^~~~~~~~~ /work/u-boot/drivers/mtd/nand/raw/nand.c:82:28: note: each undeclared identifier is reported only once for each function it appears in /work/u-boot/drivers/mtd/nand/raw/nand.c:84:20: error: ‘base_address’ undeclared (first use in this function); did you mean ‘base_addr’? 84 | ulong base_addr = base_address[i]; | ^~~~~~~~~~~~ | base_addr
Fixes: 068c41f1cc77 ("Finish conversion CONFIG_SYS_NAND_SELF_INIT to Kconfig") Signed-off-by: Roger Quadros rogerq@kernel.org --- drivers/mtd/nand/raw/nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/raw/nand.c b/drivers/mtd/nand/raw/nand.c index 4b5560dd24..14bca12024 100644 --- a/drivers/mtd/nand/raw/nand.c +++ b/drivers/mtd/nand/raw/nand.c @@ -19,7 +19,7 @@ int nand_curr_device = -1;
static struct mtd_info *nand_info[CONFIG_SYS_MAX_NAND_DEVICE];
-#ifndef CONFIG_SYS_NAND_SELF_INIT +#if !CONFIG_IS_ENABLED(SYS_NAND_SELF_INIT) static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE]; static ulong base_address[CONFIG_SYS_MAX_NAND_DEVICE] = CONFIG_SYS_NAND_BASE_LIST; #endif
Hi
Reviewed-by: Michael Trimarchi michael@amarulasolutions.com
Hello Michael,
On 29/09/2022 09:08, Michael Nazzareno Trimarchi wrote:
Hi
Il mer 28 set 2022, 13:42 Roger Quadros <rogerq@kernel.org mailto:rogerq@kernel.org> ha scritto:
This fixes the below build error if nand.c is included in an SPL build. /work/u-boot/drivers/mtd/nand/raw/nand.c: In function ‘nand_init_chip’: /work/u-boot/drivers/mtd/nand/raw/nand.c:82:28: error: ‘nand_chip’ undeclared (first use in this function) 82 | struct nand_chip *nand = &nand_chip[i]; | ^~~~~~~~~ /work/u-boot/drivers/mtd/nand/raw/nand.c:82:28: note: each undeclared identifier is reported only once for each function it appears in /work/u-boot/drivers/mtd/nand/raw/nand.c:84:20: error: ‘base_address’ undeclared (first use in this function); did you mean ‘base_addr’? 84 | ulong base_addr = base_address[i]; | ^~~~~~~~~~~~ | base_addr Fixes: 068c41f1cc77 ("Finish conversion CONFIG_SYS_NAND_SELF_INIT to Kconfig") Signed-off-by: Roger Quadros <rogerq@kernel.org <mailto:rogerq@kernel.org>> --- drivers/mtd/nand/raw/nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) diff --git a/drivers/mtd/nand/raw/nand.c b/drivers/mtd/nand/raw/nand.c index 4b5560dd24..14bca12024 100644 --- a/drivers/mtd/nand/raw/nand.c +++ b/drivers/mtd/nand/raw/nand.c @@ -19,7 +19,7 @@ int nand_curr_device = -1; static struct mtd_info *nand_info[CONFIG_SYS_MAX_NAND_DEVICE]; -#ifndef CONFIG_SYS_NAND_SELF_INIT +#if !CONFIG_IS_ENABLED(SYS_NAND_SELF_INIT) static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE]; static ulong base_address[CONFIG_SYS_MAX_NAND_DEVICE] = CONFIG_SYS_NAND_BASE_LIST; #endif
Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com mailto:michael@amarulasolutions.com>
Thanks. Could you please fix your email client to use plain text format when responding on u-boot mailing list? ;)
-- 2.17.1
cheers, -roger
Hi
On Thu, Oct 6, 2022 at 3:29 PM Roger Quadros rogerq@kernel.org wrote:
Hello Michael,
Hi
Sorry, It's for no-obvious bad behavior to read from mobile phone, and forget about gmail
Michael
-- 2.17.1
cheers, -roger
Hi Roger,
#endif
2.17.1
Applied to nand-next, thanks!
Dario
Dario Binacchi
Roger Quadros
