[PATCH v5 0/1] x86: efi: Add a 64-bit coreboot payload
This series creates a new 64-bit 'coreboot64' build which can be launched from coreboot. It uses SPL to effect the jump to 64-bit mode.
This was done in an attempt to get the Ubuntu FirmwareTestSuite[1] working. Unfortunately the latest version shows a splash screen and hangs, perhaps due to some missing EFI support.
[1] https://wiki.ubuntu.com/FirmwareTestSuite
Changes in v5: - Rewrite commit message to explain what coreboot is
Simon Glass (1): x86: Add a 64-bit 'coreboot64' build
board/coreboot/coreboot/MAINTAINERS | 7 +++++ configs/coreboot64_defconfig | 48 +++++++++++++++++++++++++++++ doc/board/coreboot/coreboot.rst | 10 ++++++ 3 files changed, 65 insertions(+) create mode 100644 configs/coreboot64_defconfig
Coreboot is a first-stage bootloader mostly used on x86 devices as an alternative to UEFI. Coreboot runs in 32-bit mode.
U-Boot currently supports booting from coreboot as a second-stage bootloader, also in 32-bit mode. However it is useful to be able to run U-Boot in 64-bit mode. To do this we can have a 32-bit SPL which switches over the CPU and jumps to a 64-bit U-Boot proper.
Add a new 'coreboot64' board for running 64-bit U-Boot from coreboot. This uses binman to create an image with a 32-bit SPL and a 64-bit U-Boot.
This allows running 64-bit EFI images on x86, for example, without needing a native U-Boot port for a board.
diff --git a/board/coreboot/coreboot/MAINTAINERS b/board/coreboot/coreboot/MAINTAINERS index 188906b080..a05673bb0b 100644 --- a/board/coreboot/coreboot/MAINTAINERS +++ b/board/coreboot/coreboot/MAINTAINERS @@ -4,3 +4,10 @@ S: Maintained F: board/coreboot/coreboot/ F: include/configs/chromebook_link.h F: configs/coreboot_defconfig + +COREBOOT64 BOARD +M: Simon Glass sjg@chromium.org +S: Maintained +F: board/coreboot/coreboot/ +F: include/configs/chromebook_link.h +F: configs/coreboot64_defconfig diff --git a/configs/coreboot64_defconfig b/configs/coreboot64_defconfig new file mode 100644 index 0000000000..80353b8eb3 --- /dev/null +++ b/configs/coreboot64_defconfig @@ -0,0 +1,48 @@ +CONFIG_X86=y +CONFIG_SYS_TEXT_BASE=0x1120000 +CONFIG_ENV_SIZE=0x1000 +CONFIG_NR_DRAM_BANKS=8 +CONFIG_PRE_CON_BUF_ADDR=0x100000 +CONFIG_X86_RUN_64BIT=y +CONFIG_VENDOR_COREBOOT=y +CONFIG_TARGET_COREBOOT=y +CONFIG_SPL_TEXT_BASE=0x1110000 +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_SHOW_BOOT_PROGRESS=y +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="root=/dev/sdb3 init=/sbin/init rootwait ro" +CONFIG_PRE_CONSOLE_BUFFER=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_LAST_STAGE_INIT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_IDE=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y +CONFIG_CMD_SOUND=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_MAC_PARTITION=y +# CONFIG_SPL_MAC_PARTITION is not set +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="coreboot" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +# CONFIG_PCI_PNP is not set +CONFIG_SOUND=y +CONFIG_SOUND_I8254=y +CONFIG_CONSOLE_SCROLL_LINES=5 diff --git a/doc/board/coreboot/coreboot.rst b/doc/board/coreboot/coreboot.rst index fd974229eb..9c44c025a4 100644 --- a/doc/board/coreboot/coreboot.rst +++ b/doc/board/coreboot/coreboot.rst @@ -40,3 +40,13 @@ To enable video you must enable these options in coreboot: At present it seems that for Minnowboard Max, coreboot does not pass through the video information correctly (it always says the resolution is 0x0). This works correctly for link though. + +64-bit U-Boot +------------- + +In addition to the 32-bit 'coreboot' build there is a 'coreboot64' build. This +produces an image which can be booted from coreboot (32-bit). Internally it +works by using a 32-bit SPL binary to switch to 64-bit for running U-Boot. It +can be useful for running UEFI applications, for example. + +This has only been lightly tested.
Changes in v5:
Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
Changes in v5:
The coreboot firmware supports a lot of different boards. The board may have two SATA drives or may be using NVME drives instead. Why do we have this BOOTARGS line instead of using CONFIG_DISTRO_DEFAULTS=y?
Best regards
Heinrich
Hi Heinrich,
Changes in v5:
Convert coreboot BOOTARGS
Hi Heinrich,
On Sat, May 2, 2020 at 9:40 PM Bin Meng bmeng.cn@gmail.com wrote:
Hi Heinrich,
Changes in v5:
Sorry, hit send too soon.
Convert coreboot BOOTARGS to CONFIG_DISTRO_DEFAULTS makes sense.
Let's keep this series as it is.
Would you please come up with a patch to do distro boot for coreboot?
Regards, Bin
On 5/2/20 3:41 PM, Bin Meng wrote:
Hi Heinrich,
Hi Heinrich,
Changes in v5:
Regards, Bin
If the move to DISTRO_DEFAULTS is done in a follow-up patch, I am fine with the patch merged as is.
Best regards
Heinrich
Changes in v5:
applied to u-boot-x86, thanks!
Bin Meng
