[U-Boot] Please pull u-boot-fsl-qoriq.git master
Tom,
This replace PR sent earlier today.
The following changes since commit 32fdf0e4d82bdca5d64d86330e461e59685f9959:
Prepare v2015.01-rc3 (2014-12-08 16:35:08 -0500)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to d0419f400af6f4bbe5c4ee5c97f6fbbdedec6cf3:
ARM: HYP/non-sec: Fix the ARCH Timer frequency setting for sun7i (2014-12-11 12:37:42 -0800)
---------------------------------------------------------------- Alison Wang (12): ls102xa: pblimage: Add pblimage tool support for LS102xA spl: Use u-boot.img instead of u-boot.bin arm: spl: Add I2C linker list in generic .lds kconfig: ls1021a: add SUPPORT_SPL ls102xa: qixis: Add CONFIG_QIXIS_I2C_ACCESS macro arm: ls102xa: Add SD boot support for LS1021AQDS board arm: ls102xa: Add SD boot support for LS1021ATWR board arm: ls1021a: Add CONFIG_DOS_PARTITION and CONFIG_CMD_FAT support arm: ls102xa: Fix SD/NAND/QSPI boot defination error for QE support arm: ls102xa: Add QSPI boot support for LS1021AQDS/TWR board arm: ls102xa: Add NAND boot support for LS1021AQDS board kconfig: ls102xa: Change the prompt messages
Chenhui Zhao (1): ls1021aqds: set the default I2C channel before DDR init
Jaiprakash Singh (1): driver/mtd: Fix IFC compilation warnings
Minghuan Lian (1): arm: ls102xa: Update PCIe dts node status
Nikhil Badola (3): drivers: usb: Make usb device-tree fixup code architecture independent drivers: usb: fsl: Add USB device-tree errata framework drivers: usb: fsl: Check USB Erratum A007792 applicability
Tang Yuantian (2): arm: ls102xa: fixed a bus frequency setting error fsl/sleep: updated the deep sleep framework for QorIQ platforms
Xiubo Li (7): ARM: HYP/non-sec: add the pen address BE mode support. ARM: HYP/non-sec: Fix the ARCH Timer frequency setting. ls1021a: adding a secondary core boot address and kick functions ls102xa: changing a few targets' configurations. ARM: ls102xa: allow all the peripheral access permission as R/W. ARM: ls102xa: Setting device's stream id for SMMUs. ARM: HYP/non-sec: Fix the ARCH Timer frequency setting for sun7i
Yao Yuan (1): ls1021aqds: add hwconfig setting to do pin mux
chenhui zhao (1): arm: ls102xa: clear EPU registers for deep sleep
Makefile | 11 +- arch/arm/Kconfig | 6 +- arch/arm/cpu/armv7/ls102xa/Makefile | 2 + arch/arm/cpu/armv7/ls102xa/cpu.c | 34 +++ arch/arm/cpu/armv7/ls102xa/fdt.c | 2 +- arch/arm/cpu/armv7/ls102xa/fsl_epu.c | 57 ++++ arch/arm/cpu/armv7/ls102xa/fsl_epu.h | 68 +++++ arch/arm/cpu/armv7/ls102xa/spl.c | 33 +++ arch/arm/cpu/armv7/nonsec_virt.S | 7 +- arch/arm/cpu/u-boot-spl.lds | 3 + arch/arm/include/asm/arch-ls102xa/config.h | 9 + arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 9 + .../include/asm/arch-ls102xa/ls102xa_stream_id.h | 17 ++ arch/arm/include/asm/arch-ls102xa/ns_access.h | 118 ++++++++ arch/arm/include/asm/arch-ls102xa/spl.h | 20 ++ arch/arm/include/asm/pcie_layerscape.h | 13 + arch/powerpc/cpu/mpc8xxx/fdt.c | 104 ------- board/freescale/common/Makefile | 10 + board/freescale/common/arm_sleep.c | 95 +++++++ board/freescale/common/ls102xa_stream_id.c | 18 ++ board/freescale/common/mpc85xx_sleep.c | 88 ++++++ board/freescale/common/ns_access.c | 30 +++ board/freescale/common/qixis.h | 7 + board/freescale/common/sleep.h | 21 ++ board/freescale/ls1021aqds/MAINTAINERS | 3 + board/freescale/ls1021aqds/ddr.c | 5 +- board/freescale/ls1021aqds/ls1021aqds.c | 283 ++++++++++++++++++-- board/freescale/ls1021aqds/ls102xa_pbi.cfg | 12 + board/freescale/ls1021aqds/ls102xa_rcw_nand.cfg | 7 + board/freescale/ls1021aqds/ls102xa_rcw_sd.cfg | 14 + board/freescale/ls1021atwr/MAINTAINERS | 2 + board/freescale/ls1021atwr/ls1021atwr.c | 151 +++++++++++ board/freescale/ls1021atwr/ls102xa_pbi.cfg | 12 + board/freescale/ls1021atwr/ls102xa_rcw_sd.cfg | 14 + configs/ls1021aqds_nand_defconfig | 4 + configs/ls1021aqds_qspi_defconfig | 3 + configs/ls1021aqds_sdcard_defconfig | 4 + configs/ls1021atwr_qspi_defconfig | 3 + configs/ls1021atwr_sdcard_defconfig | 4 + drivers/ddr/fsl/arm_ddr_gen3.c | 45 +++- drivers/ddr/fsl/fsl_ddr_gen4.c | 44 ++- drivers/ddr/fsl/mpc85xx_ddr_gen3.c | 67 ++--- drivers/mtd/nand/fsl_ifc_nand.c | 2 +- drivers/mtd/nand/fsl_ifc_spl.c | 10 + drivers/pci/Makefile | 1 + drivers/pci/pcie_layerscape.c | 51 ++++ drivers/usb/host/ehci-fsl.c | 186 +++++++++++++ include/configs/ls1021aqds.h | 175 +++++++++++- include/configs/ls1021atwr.h | 95 ++++++- include/configs/sun7i.h | 1 + include/fsl_ddr_sdram.h | 12 +- include/fsl_usb.h | 23 ++ tools/pblimage.c | 110 +++++--- 53 files changed, 1904 insertions(+), 221 deletions(-) create mode 100644 arch/arm/cpu/armv7/ls102xa/fsl_epu.c create mode 100644 arch/arm/cpu/armv7/ls102xa/fsl_epu.h create mode 100644 arch/arm/cpu/armv7/ls102xa/spl.c create mode 100644 arch/arm/include/asm/arch-ls102xa/ls102xa_stream_id.h create mode 100644 arch/arm/include/asm/arch-ls102xa/ns_access.h create mode 100644 arch/arm/include/asm/arch-ls102xa/spl.h create mode 100644 arch/arm/include/asm/pcie_layerscape.h create mode 100644 board/freescale/common/arm_sleep.c create mode 100644 board/freescale/common/ls102xa_stream_id.c create mode 100644 board/freescale/common/mpc85xx_sleep.c create mode 100644 board/freescale/common/ns_access.c create mode 100644 board/freescale/common/sleep.h create mode 100644 board/freescale/ls1021aqds/ls102xa_pbi.cfg create mode 100644 board/freescale/ls1021aqds/ls102xa_rcw_nand.cfg create mode 100644 board/freescale/ls1021aqds/ls102xa_rcw_sd.cfg create mode 100644 board/freescale/ls1021atwr/ls102xa_pbi.cfg create mode 100644 board/freescale/ls1021atwr/ls102xa_rcw_sd.cfg create mode 100644 configs/ls1021aqds_nand_defconfig create mode 100644 configs/ls1021aqds_qspi_defconfig create mode 100644 configs/ls1021aqds_sdcard_defconfig create mode 100644 configs/ls1021atwr_qspi_defconfig create mode 100644 configs/ls1021atwr_sdcard_defconfig create mode 100644 drivers/pci/pcie_layerscape.c
Thanks.
York
On Thu, Dec 11, 2014 at 12:41:00PM -0800, York Sun wrote:
Tom,
York Sun
