[U-Boot] [PATCH 1/4] powerpc/83xx/km: update SDRAM parameters for km8321 boards
Measurements during HW basic test showed, that the SDRAM timing has to be optimized. This patch adapted these timings accordingly.
Signed-off-by: Marco Schmid marco.schmid@keymile.com Signed-off-by: Holger Brunck holger.brunck@keymile.com cc: Kim Phillips kim.phillips@freescale.com cc: Valentin Longchamp valentin.longchamp@keymile.com --- include/configs/km/km8321-common.h | 24 ++++++++++++++---------- 1 files changed, 14 insertions(+), 10 deletions(-)
diff --git a/include/configs/km/km8321-common.h b/include/configs/km/km8321-common.h index 902ae26..580b72f 100644 --- a/include/configs/km/km8321-common.h +++ b/include/configs/km/km8321-common.h @@ -70,7 +70,8 @@ #define CONFIG_SYS_DDR_CS0_BNDS 0x0000007f #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SDRAM_TYPE_DDR2 | \ SDRAM_CFG_32_BE | \ - SDRAM_CFG_SREN) + SDRAM_CFG_SREN | \ + SDRAM_CFG_HSE)
#define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #define CONFIG_SYS_DDR_CLK_CNTL (DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) @@ -82,7 +83,7 @@ CSCONFIG_ROW_BIT_13 | \ CSCONFIG_COL_BIT_10)
-#define CONFIG_SYS_DDR_MODE 0x47860252 +#define CONFIG_SYS_DDR_MODE 0x47860242 #define CONFIG_SYS_DDR_MODE2 0x8080c000
#define CONFIG_SYS_DDR_TIMING_0 ((2 << TIMING_CFG0_MRS_CYC_SHIFT) | \ @@ -94,20 +95,20 @@ (0 << TIMING_CFG0_WRT_SHIFT) | \ (0 << TIMING_CFG0_RWT_SHIFT))
-#define CONFIG_SYS_DDR_TIMING_1 ((TIMING_CFG1_CASLAT_50) | \ +#define CONFIG_SYS_DDR_TIMING_1 ((TIMING_CFG1_CASLAT_40) | \ (2 << TIMING_CFG1_WRTORD_SHIFT) | \ (2 << TIMING_CFG1_ACTTOACT_SHIFT) | \ - (2 << TIMING_CFG1_WRREC_SHIFT) | \ - (6 << TIMING_CFG1_REFREC_SHIFT) | \ - (2 << TIMING_CFG1_ACTTORW_SHIFT) | \ - (6 << TIMING_CFG1_ACTTOPRE_SHIFT) | \ - (2 << TIMING_CFG1_PRETOACT_SHIFT)) + (3 << TIMING_CFG1_WRREC_SHIFT) | \ + (7 << TIMING_CFG1_REFREC_SHIFT) | \ + (3 << TIMING_CFG1_ACTTORW_SHIFT) | \ + (7 << TIMING_CFG1_ACTTOPRE_SHIFT) | \ + (3 << TIMING_CFG1_PRETOACT_SHIFT))
#define CONFIG_SYS_DDR_TIMING_2 ((8 << TIMING_CFG2_FOUR_ACT_SHIFT) | \ (3 << TIMING_CFG2_CKE_PLS_SHIFT) | \ (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) | \ (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) | \ - (4 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) | \ + (3 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) | \ (0 << TIMING_CFG2_ADD_LAT_SHIFT) | \ (5 << TIMING_CFG2_CPO_SHIFT))
@@ -122,7 +123,10 @@ /* * Local Bus Configuration & Clock Setup */ -#define CONFIG_SYS_LCRR (LCRR_DBYP | LCRR_EADC_1 | LCRR_CLKDIV_2) +#define CONFIG_SYS_LCRR_DBYP 0x80000000 +#define CONFIG_SYS_LCRR_EADC 0x00010000 +#define CONFIG_SYS_LCRR_CLKDIV 0x00000002 + #define CONFIG_SYS_LBC_LBCR 0x00000000
CONFIG_SYS_LCRR is unused and CONFIG_SYS_LBC_LBCR is already defined in the common header file, so remove them.
Signed-off-by: Holger Brunck holger.brunck@keymile.com cc: Kim Phillips kim.phillips@freescale.com cc: Valentin Longchamp valentin.longchamp@keymile.com --- include/configs/tuda1.h | 6 ------ 1 files changed, 0 insertions(+), 6 deletions(-)
diff --git a/include/configs/tuda1.h b/include/configs/tuda1.h index 577bbd0..2581d8a 100644 --- a/include/configs/tuda1.h +++ b/include/configs/tuda1.h @@ -41,12 +41,6 @@ #define CONFIG_SYS_APP2_SIZE 256 /* Megabytes */
/* - * Local Bus Configuration & Clock Setup - */ -#define CONFIG_SYS_LCRR (LCRR_DBYP | LCRR_EADC_1 | LCRR_CLKDIV_2) -#define CONFIG_SYS_LBC_LBCR 0x00000000 - -/* * Init Local Bus Memory Controller: * * Bank Bus Machine PortSz Size Device
Hello Holger,
Acked-by: Heiko Schocher hs@denx.de
bye, Heiko
These boards are from a u-boot point of view identical. So collect the two headerfiles to one, to decrease maintenance.
Signed-off-by: Holger Brunck holger.brunck@keymile.com cc: Kim Phillips kim.phillips@freescale.com cc: Valentin Longchamp valentin.longchamp@keymile.com cc: Heiko Schocher hs@denx.de --- MAINTAINERS | 5 +- boards.cfg | 3 +- include/configs/tuxa1.h | 123 ---------------------------------- include/configs/{tuda1.h => tuxx1.h} | 23 +++--- 4 files changed, 16 insertions(+), 138 deletions(-) delete mode 100644 include/configs/tuxa1.h rename include/configs/{tuda1.h => tuxx1.h} (84%)
diff --git a/MAINTAINERS b/MAINTAINERS index a56ca10..f111226 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -436,11 +436,12 @@ Heiko Schocher hs@denx.de municse MPC5200 sc3 PPC405GP suvd3 MPC8321 - tuda1 MPC8321 - tuxa1 MPC8321 uc101 MPC5200 ve8313 MPC8313
+Holger Brunck holger.brunck@keymile.com + tuxx1 MPC8321 + Peter De Schrijver p2@mind.be
ML2 PPC4xx diff --git a/boards.cfg b/boards.cfg index 1e5b3e0..93577d1 100644 --- a/boards.cfg +++ b/boards.cfg @@ -590,8 +590,7 @@ MPC837XERDB powerpc mpc83xx mpc837xerdb freesca kmeter1 powerpc mpc83xx km83xx keymile kmsupx5 powerpc mpc83xx km83xx keymile suvd3 powerpc mpc83xx km83xx keymile -tuda1 powerpc mpc83xx km83xx keymile -tuxa1 powerpc mpc83xx km83xx keymile +tuxx1 powerpc mpc83xx km83xx keymile MERGERBOX powerpc mpc83xx mergerbox matrix_vision MVBLM7 powerpc mpc83xx mvblm7 matrix_vision SIMPC8313_LP powerpc mpc83xx simpc8313 sheldon - SIMPC8313:NAND_LP diff --git a/include/configs/tuxa1.h b/include/configs/tuxa1.h deleted file mode 100644 index 2d9af3f..0000000 --- a/include/configs/tuxa1.h +++ /dev/null @@ -1,123 +0,0 @@ -/* - * Copyright (C) 2006 Freescale Semiconductor, Inc. - * Dave Liu daveliu@freescale.com - * - * Copyright (C) 2007 Logic Product Development, Inc. - * Peter Barada peterb@logicpd.com - * - * Copyright (C) 2007 MontaVista Software, Inc. - * Anton Vorontsov avorontsov@ru.mvista.com - * - * (C) Copyright 2008 - * Heiko Schocher, DENX Software Engineering, hs@denx.de. - * - * (C) Copyright 2010 - * Yan Bin, Lukas Roggli, KEYMILE Ltd, lukas.roggli@keymile.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - */ -#define CONFIG_TUXA1 /* TUXA1 board specific */ -#define CONFIG_HOSTNAME tuxa1 -#define CONFIG_KM_BOARD_NAME "tuxa1" - -#define CONFIG_SYS_TEXT_BASE 0xF0000000 - -/* include common defines/options for all 8321 Keymile boards */ -#include "km/km8321-common.h" - -#define CONFIG_SYS_LPXF_BASE 0xA0000000 /* LPXF */ -#define CONFIG_SYS_LPXF_SIZE 256 /* Megabytes */ -#define CONFIG_SYS_PINC2_BASE 0xB0000000 /* PINC2 */ -#define CONFIG_SYS_PINC2_SIZE 256 /* Megabytes */ - -/* - * Init Local Bus Memory Controller: - * - * Bank Bus Machine PortSz Size Device - * ---- --- ------- ------ ----- ------ - * 2 Local GPCM 8 bit 256MB LPXF - * 3 Local GPCM 8 bit 256MB PINC2 - * - */ - -/* - * LPXF on the local bus CS2 - * Window base at flash base - * Window size: 256 MB - */ -#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LPXF_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_256MB) - -#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LPXF_BASE | \ - BR_PS_8 | \ - BR_MS_GPCM | \ - BR_V) - -#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_LPXF_SIZE) | \ - OR_GPCM_CSNT | \ - OR_GPCM_ACS_DIV4 | \ - OR_GPCM_SCY_2 | \ - OR_GPCM_TRLX_SET | \ - OR_GPCM_EHTR_CLEAR | \ - OR_GPCM_EAD) -/* - * PINC2 on the local bus CS3 - * Access window base at PINC2 base - * Window size: 256 MB - */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PINC2_BASE -#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_256MB) - -#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_PINC2_BASE | \ - BR_PS_8 | \ - BR_MS_GPCM | \ - BR_V) - -#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_PINC2_SIZE) | \ - OR_GPCM_CSNT | \ - OR_GPCM_ACS_DIV2 | \ - OR_GPCM_SCY_2 | \ - OR_GPCM_TRLX_SET | \ - OR_GPCM_EHTR_CLEAR) - -#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ - 0x0000c000 | \ - MxMR_WLFx_2X) - -/* - * MMU Setup - */ -/* LPXF: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ - BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_LPXF_BASE | BATU_BL_256M | \ - BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U - -/* PINC2: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_RW | \ - BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PINC2_BASE | BATU_BL_256M | \ - BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_RW | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U - -#define CONFIG_SYS_IBAT7L (0) -#define CONFIG_SYS_IBAT7U (0) -#define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L -#define CONFIG_SYS_DBAT7U CONFIG_SYS_IBAT7U - -#endif /* __CONFIG_H */ diff --git a/include/configs/tuda1.h b/include/configs/tuxx1.h similarity index 84% rename from include/configs/tuda1.h rename to include/configs/tuxx1.h index 2581d8a..b07f6b3 100644 --- a/include/configs/tuda1.h +++ b/include/configs/tuxx1.h @@ -13,6 +13,7 @@ * * (C) Copyright 2010-2011 * Lukas Roggli, KEYMILE Ltd, lukas.roggli@keymile.com + * Holger Brunck, Keymile GmbH, holger.bruncl@keymile.com * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -26,9 +27,9 @@ /* * High Level Configuration Options */ -#define CONFIG_TUDA1 /* TUDA1 board specific */ -#define CONFIG_HOSTNAME tuda1 -#define CONFIG_KM_BOARD_NAME "tuda1" +#define CONFIG_TUXXX /* TUXX1 board specific */ +#define CONFIG_HOSTNAME tuxx1 +#define CONFIG_KM_BOARD_NAME "tuxx1"
@@ -43,15 +44,15 @@ /* * Init Local Bus Memory Controller: * - * Bank Bus Machine PortSz Size Device - * ---- --- ------- ------ ----- ------ - * 2 Local GPCM 8 bit 256MB PAXG - * 3 Local GPCM 8 bit 256MB PINC3 + * Bank Bus Machine PortSz Size Device on TUDA1 TUXA1 + * ---- --- ------- ------ ----- --------------------- + * 2 Local GPCM 8 bit 256MB PAXG LPXF + * 3 Local GPCM 8 bit 256MB PINC3 PINC2 * */
/* - * PAXG on the local bus CS2 + * Configuration for C2 on the local bus */ /* Window base at flash base */ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_APP1_BASE @@ -71,7 +72,7 @@ OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD) /* - * PINC3 on the local bus CS3 + * Configuration for C3 on the local bus */ /* Access window base at PINC3 base */ #define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_APP2_BASE @@ -97,7 +98,7 @@ /* * MMU Setup */ -/* PAXG: icache cacheable, but dcache-inhibit and guarded */ +/* APP1: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | \ BATL_PP_RW | \ BATL_MEMCOHERENCE) @@ -112,7 +113,7 @@ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
-/* PINC3: icache cacheable, but dcache-inhibit and guarded */ +/* APP2: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | \ BATL_PP_RW | \ BATL_MEMCOHERENCE)
Hello Holger,
bye, Heiko
This board is similar to our tuxx1 target. But on this board there is only one application specific chip select configured.
Signed-off-by: Holger Brunck holger.brunck@keymile.com cc: Kim Phillips kim.phillips@freescale.com cc: Valentin Longchamp valentin.longchamp@keymile.com cc: Heiko Schocher hs@denx.de --- MAINTAINERS | 1 + boards.cfg | 1 + include/configs/tuxx1.h | 24 +++++++++++++++++++----- 3 files changed, 21 insertions(+), 5 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index f111226..f97bbf6 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -440,6 +440,7 @@ Heiko Schocher hs@denx.de ve8313 MPC8313
Holger Brunck holger.brunck@keymile.com + tuge1 MPC8321 tuxx1 MPC8321
Peter De Schrijver p2@mind.be diff --git a/boards.cfg b/boards.cfg index 93577d1..b108dd0 100644 --- a/boards.cfg +++ b/boards.cfg @@ -590,6 +590,7 @@ MPC837XERDB powerpc mpc83xx mpc837xerdb freesca kmeter1 powerpc mpc83xx km83xx keymile kmsupx5 powerpc mpc83xx km83xx keymile suvd3 powerpc mpc83xx km83xx keymile +tuge1 powerpc mpc83xx km83xx keymile - tuxx1:KM_DISABLE_APP2 tuxx1 powerpc mpc83xx km83xx keymile MERGERBOX powerpc mpc83xx mergerbox matrix_vision MVBLM7 powerpc mpc83xx mvblm7 matrix_vision diff --git a/include/configs/tuxx1.h b/include/configs/tuxx1.h index b07f6b3..f6d2b17 100644 --- a/include/configs/tuxx1.h +++ b/include/configs/tuxx1.h @@ -27,9 +27,13 @@ /* * High Level Configuration Options */ -#define CONFIG_TUXXX /* TUXX1 board specific */ +#define CONFIG_TUXXX /* TUXX1 board (tuxa1/tuda1) specific */ #define CONFIG_HOSTNAME tuxx1 +#ifdef CONFIG_KM_DISABLE_APP2 +#define CONFIG_KM_BOARD_NAME "tuge1" +#else #define CONFIG_KM_BOARD_NAME "tuxx1" +#endif
@@ -38,16 +42,18 @@
#define CONFIG_SYS_APP1_BASE 0xA0000000 /* PAXG */ #define CONFIG_SYS_APP1_SIZE 256 /* Megabytes */ +#ifndef CONFIG_KM_DISABLE_APP2 #define CONFIG_SYS_APP2_BASE 0xB0000000 /* PINC3 */ #define CONFIG_SYS_APP2_SIZE 256 /* Megabytes */ +#endif
/* * Init Local Bus Memory Controller: * - * Bank Bus Machine PortSz Size Device on TUDA1 TUXA1 - * ---- --- ------- ------ ----- --------------------- - * 2 Local GPCM 8 bit 256MB PAXG LPXF - * 3 Local GPCM 8 bit 256MB PINC3 PINC2 + * Bank Bus Machine PortSz Size Device on TUDA1 TUXA1 TUGE1 + * ---- --- ------- ------ ----- ---------------------------- + * 2 Local GPCM 8 bit 256MB PAXG LPXF PAXI + * 3 Local GPCM 8 bit 256MB PINC3 PINC2 unused * */
@@ -71,6 +77,7 @@ OR_GPCM_TRLX_SET | \ OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD) +#ifndef CONFIG_KM_DISABLE_APP2 /* * Configuration for C3 on the local bus */ @@ -94,6 +101,7 @@ #define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ MxMR_WLFx_2X) +#endif
/* * MMU Setup @@ -113,6 +121,11 @@ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
+#ifdef CONFIG_KM_DISABLE_APP2 +#define CONFIG_SYS_IBAT6L (0) +#define CONFIG_SYS_IBAT6U (0) +#define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L +#else /* APP2: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | \ BATL_PP_RW | \ @@ -125,6 +138,7 @@ BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) +#endif #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
Hello Holger,
bye, Heiko
Hello Holger,
bye, Heiko
On Wed, 14 Dec 2011 16:21:42 +0100 Holger Brunck holger.brunck@keymile.com wrote:
applied 1-4 out of 4 patches to mpc83xx.
Thanks,
Kim
Heiko Schocher
Holger Brunck
Kim Phillips
