[PATCH 1/2] spl: Kconfig: Replace CONFIG_SPL_NET_SUPPORT with CONFIG_SPL_NET
Replace CONFIG_SPL_NET_SUPPORT with CONFIG_SPL_NET to match CONFIG_NET so that CONFIG_$(SPL_)NET can be used to conditionally select build objects between SPL and U-Boot.
Signed-off-by: Nathan Rossi nathan@nathanrossi.com --- common/Makefile | 2 +- common/spl/Kconfig | 10 +++++----- configs/am335x_boneblack_vboot_defconfig | 2 +- configs/am335x_evm_defconfig | 2 +- configs/am335x_guardian_defconfig | 2 +- configs/am43xx_evm_defconfig | 2 +- configs/am43xx_hs_evm_defconfig | 2 +- configs/chromebook_link64_defconfig | 2 +- configs/chromebook_samus_tpl_defconfig | 2 +- configs/pcm051_rev1_defconfig | 2 +- configs/pcm051_rev3_defconfig | 2 +- configs/pengwyn_defconfig | 2 +- configs/qemu-x86_64_defconfig | 2 +- doc/SPL/README.am335x-network | 2 +- lib/tiny-printf.c | 4 ++-- scripts/Makefile.spl | 2 +- tools/buildman/README | 8 ++++---- 17 files changed, 25 insertions(+), 25 deletions(-)
diff --git a/common/Makefile b/common/Makefile index 5f62b8d0b1..9bb00dd66e 100644 --- a/common/Makefile +++ b/common/Makefile @@ -71,7 +71,7 @@ obj-$(CONFIG_SPL_HASH_SUPPORT) += hash.o obj-$(CONFIG_TPL_HASH_SUPPORT) += hash.o obj-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o obj-$(CONFIG_SPL_LOAD_FIT) += common_fit.o -obj-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o +obj-$(CONFIG_SPL_NET) += miiphyutil.o obj-$(CONFIG_$(SPL_TPL_)OF_LIBFDT) += fdt_support.o
ifdef CONFIG_SPL_USB_HOST_SUPPORT diff --git a/common/spl/Kconfig b/common/spl/Kconfig index b03a476b9f..abfc719c91 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -556,7 +556,7 @@ config SPL_ETH_SUPPORT drivers in SPL. This permits SPL to load U-Boot over an Ethernet link rather than from an on-board peripheral. Environment support is required since the network stack uses a number of environment - variables. See also SPL_NET_SUPPORT. + variables. See also SPL_NET.
config SPL_FS_EXT4 bool "Support EXT filesystems" @@ -847,7 +847,7 @@ config UBI_SPL_SILENCE_MSG
endif # if SPL_UBI
-config SPL_NET_SUPPORT +config SPL_NET bool "Support networking" help Enable support for network devices (such as Ethernet) in SPL. @@ -856,7 +856,7 @@ config SPL_NET_SUPPORT the network stack uses a number of environment variables. See also SPL_ETH_SUPPORT.
-if SPL_NET_SUPPORT +if SPL_NET config SPL_NET_VCI_STRING string "BOOTP Vendor Class Identifier string sent by SPL" help @@ -865,7 +865,7 @@ config SPL_NET_VCI_STRING of a client. This is often used in practice to allow for the DHCP server to specify different files to load depending on if the ROM, SPL or U-Boot itself makes the request -endif # if SPL_NET_SUPPORT +endif # if SPL_NET
config SPL_NO_CPU_SUPPORT bool "Drop CPU code in SPL" @@ -1152,7 +1152,7 @@ config SPL_USB_ETHER USB-connected Ethernet link (such as a USB Ethernet dongle) rather than from an onboard peripheral. Environment support is required since the network stack uses a number of environment variables. - See also SPL_NET_SUPPORT and SPL_ETH_SUPPORT. + See also SPL_NET and SPL_ETH_SUPPORT.
config SPL_DFU bool "Support DFU (Device Firmware Upgrade)" diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 9cea85413b..11f6656938 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -16,7 +16,7 @@ CONFIG_VERSION_VARIABLE=y CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_NET_VCI_STRING="AM33xx U-Boot SPL" CONFIG_SPL_OS_BOOT=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 335aa8cfa1..4a2bd2e3ce 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -17,7 +17,7 @@ CONFIG_SPL_ETH_SUPPORT=y # CONFIG_SPL_FS_EXT4 is not set CONFIG_SPL_MTD_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_NET_VCI_STRING="AM335x U-Boot SPL" CONFIG_SPL_OS_BOOT=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 13974f7c0f..0f84ccc955 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -24,7 +24,7 @@ CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MUSB_NEW_SUPPORT=y -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_NET_VCI_STRING="Guardian U-Boot SPL" CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 2e64879beb..55a19738c0 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -16,7 +16,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_MISC_INIT_R is not set CONFIG_VERSION_VARIABLE=y CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_NET_VCI_STRING="AM43xx U-Boot SPL" CONFIG_SPL_OS_BOOT=y CONFIG_SPL_USB_HOST_SUPPORT=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index 523ce00585..402771eed2 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -26,7 +26,7 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_NET_VCI_STRING="AM43xx U-Boot SPL" CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y diff --git a/configs/chromebook_link64_defconfig b/configs/chromebook_link64_defconfig index 5abd690b00..1b1b557922 100644 --- a/configs/chromebook_link64_defconfig +++ b/configs/chromebook_link64_defconfig @@ -30,7 +30,7 @@ CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CPU_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C_SUPPORT=y -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_PCI=y CONFIG_SPL_PCH_SUPPORT=y CONFIG_SPL_RTC_SUPPORT=y diff --git a/configs/chromebook_samus_tpl_defconfig b/configs/chromebook_samus_tpl_defconfig index cd1cc5ffa1..caa25c7ad5 100644 --- a/configs/chromebook_samus_tpl_defconfig +++ b/configs/chromebook_samus_tpl_defconfig @@ -31,7 +31,7 @@ CONFIG_BLOBLIST_SIZE=0x1000 CONFIG_BLOBLIST_ADDR=0xff7c0000 CONFIG_HANDOFF=y CONFIG_SPL_SEPARATE_BSS=y -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_PCI=y CONFIG_SPL_PCH_SUPPORT=y CONFIG_TPL_PCI=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index cbe6594837..d0262e639a 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -22,7 +22,7 @@ CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_NET_VCI_STRING="pcm051 U-Boot SPL" CONFIG_SPL_OS_BOOT=y CONFIG_SPL_POWER_SUPPORT=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 744c5827d1..b3e0b9a6a8 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -22,7 +22,7 @@ CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y # CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_NET_VCI_STRING="pcm051 U-Boot SPL" CONFIG_SPL_OS_BOOT=y CONFIG_SPL_POWER_SUPPORT=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index eadab3e860..e8e0bbf244 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -22,7 +22,7 @@ CONFIG_SPL_ETH_SUPPORT=y CONFIG_SPL_FS_EXT4=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_NET_VCI_STRING="AM335x U-Boot SPL" CONFIG_SPL_OS_BOOT=y CONFIG_SPL_POWER_SUPPORT=y diff --git a/configs/qemu-x86_64_defconfig b/configs/qemu-x86_64_defconfig index a37ec4d0d6..f71cc93118 100644 --- a/configs/qemu-x86_64_defconfig +++ b/configs/qemu-x86_64_defconfig @@ -30,7 +30,7 @@ CONFIG_LAST_STAGE_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_CPU_SUPPORT=y CONFIG_SPL_ENV_SUPPORT=y -CONFIG_SPL_NET_SUPPORT=y +CONFIG_SPL_NET=y CONFIG_SPL_PCI=y CONFIG_SPL_PCH_SUPPORT=y CONFIG_SPL_RTC_SUPPORT=y diff --git a/doc/SPL/README.am335x-network b/doc/SPL/README.am335x-network index e3cf93f8dc..05d1579a64 100644 --- a/doc/SPL/README.am335x-network +++ b/doc/SPL/README.am335x-network @@ -7,7 +7,7 @@ NAND and bricked (empty) board with only a network cable.
I. Building the required images 1. You have to enable generic SPL configuration options (see -doc/README.SPL) as well as CONFIG_SPL_NET_SUPPORT, +doc/README.SPL) as well as CONFIG_SPL_NET, CONFIG_ETH_SUPPORT, CONFIG_SPL_LIBGENERIC_SUPPORT and CONFIG_SPL_LIBCOMMON_SUPPORT in your board configuration file to build SPL with support for booting over the network. Also you have to enable diff --git a/lib/tiny-printf.c b/lib/tiny-printf.c index 1138c7012a..db0f23fd1f 100644 --- a/lib/tiny-printf.c +++ b/lib/tiny-printf.c @@ -47,7 +47,7 @@ static void div_out(struct printf_info *info, unsigned long *num, out_dgt(info, dgt); }
-#ifdef CONFIG_SPL_NET_SUPPORT +#ifdef CONFIG_SPL_NET static void string(struct printf_info *info, char *s) { char ch; @@ -177,7 +177,7 @@ static void __maybe_unused pointer(struct printf_info *info, const char *fmt, } break; #endif -#ifdef CONFIG_SPL_NET_SUPPORT +#ifdef CONFIG_SPL_NET case 'm': return mac_address_string(info, ptr, false); case 'M': diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 314b02ba07..768eaaf8f5 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -96,7 +96,7 @@ libs-$(CONFIG_SPL_USB_GADGET) += drivers/usb/cdns3/ libs-y += dts/ libs-y += fs/ libs-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/ -libs-$(CONFIG_SPL_NET_SUPPORT) += net/ +libs-$(CONFIG_SPL_NET) += net/
head-y := $(addprefix $(obj)/,$(head-y)) libs-y := $(addprefix $(obj)/,$(libs-y)) diff --git a/tools/buildman/README b/tools/buildman/README index c1ac0d0f58..3764344fa7 100644 --- a/tools/buildman/README +++ b/tools/buildman/README @@ -983,13 +983,13 @@ For example: ... 43: Convert CONFIG_SPL_USBETH_SUPPORT to Kconfig arm: - + u-boot.cfg: CONFIG_SPL_ENV_SUPPORT=1 CONFIG_SPL_NET_SUPPORT=1 + + u-boot.cfg: CONFIG_SPL_ENV_SUPPORT=1 CONFIG_SPL_NET=1 + u-boot-spl.cfg: CONFIG_SPL_MMC_SUPPORT=1 CONFIG_SPL_NAND_SUPPORT=1 - + all: CONFIG_SPL_ENV_SUPPORT=1 CONFIG_SPL_MMC_SUPPORT=1 CONFIG_SPL_NAND_SUPPORT=1 CONFIG_SPL_NET_SUPPORT=1 + + all: CONFIG_SPL_ENV_SUPPORT=1 CONFIG_SPL_MMC_SUPPORT=1 CONFIG_SPL_NAND_SUPPORT=1 CONFIG_SPL_NET=1 am335x_evm_usbspl : - + u-boot.cfg: CONFIG_SPL_ENV_SUPPORT=1 CONFIG_SPL_NET_SUPPORT=1 + + u-boot.cfg: CONFIG_SPL_ENV_SUPPORT=1 CONFIG_SPL_NET=1 + u-boot-spl.cfg: CONFIG_SPL_MMC_SUPPORT=1 CONFIG_SPL_NAND_SUPPORT=1 - + all: CONFIG_SPL_ENV_SUPPORT=1 CONFIG_SPL_MMC_SUPPORT=1 CONFIG_SPL_NAND_SUPPORT=1 CONFIG_SPL_NET_SUPPORT=1 + + all: CONFIG_SPL_ENV_SUPPORT=1 CONFIG_SPL_MMC_SUPPORT=1 CONFIG_SPL_NAND_SUPPORT=1 CONFIG_SPL_NET=1 44: Convert CONFIG_SPL_USB_HOST_SUPPORT to Kconfig ...
--- 2.24.1
Use CONFIG_$(SPL_)NET to conditionally select object files depending on the SPL or U-Boot specific configuration.
Signed-off-by: Nathan Rossi nathan@nathanrossi.com --- net/Makefile | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/net/Makefile b/net/Makefile index fef71b940a..8e45103168 100644 --- a/net/Makefile +++ b/net/Makefile @@ -5,20 +5,20 @@
#ccflags-y += -DDEBUG
-obj-$(CONFIG_NET) += arp.o +obj-$(CONFIG_$(SPL_)NET) += arp.o obj-$(CONFIG_CMD_BOOTP) += bootp.o obj-$(CONFIG_CMD_CDP) += cdp.o obj-$(CONFIG_CMD_DNS) += dns.o ifdef CONFIG_DM_ETH -obj-$(CONFIG_NET) += eth-uclass.o +obj-$(CONFIG_$(SPL_)NET) += eth-uclass.o else -obj-$(CONFIG_NET) += eth_legacy.o +obj-$(CONFIG_$(SPL_)NET) += eth_legacy.o endif obj-$(CONFIG_DM_MDIO) += mdio-uclass.o obj-$(CONFIG_DM_MDIO_MUX) += mdio-mux-uclass.o -obj-$(CONFIG_NET) += eth_common.o +obj-$(CONFIG_$(SPL_)NET) += eth_common.o obj-$(CONFIG_CMD_LINK_LOCAL) += link_local.o -obj-$(CONFIG_NET) += net.o +obj-$(CONFIG_$(SPL_)NET) += net.o obj-$(CONFIG_CMD_NFS) += nfs.o obj-$(CONFIG_CMD_PING) += ping.o obj-$(CONFIG_CMD_PCAP) += pcap.o --- 2.24.1
Nathan Rossi
