[U-Boot] [PATCH] dm: tpm: Drop CONFIG_DM_TPM
Now that all TPM drivers use driver model, we can drop the special driver model CONFIG option.
drivers/tpm/Kconfig | 15 +++------------ drivers/tpm/Makefile | 2 +- 2 files changed, 4 insertions(+), 13 deletions(-)
diff --git a/drivers/tpm/Kconfig b/drivers/tpm/Kconfig index 3ab652c..31b35f7 100644 --- a/drivers/tpm/Kconfig +++ b/drivers/tpm/Kconfig @@ -4,15 +4,6 @@
menu "TPM support"
-config DM_TPM - bool "Enable driver model for Trusted Platform Module drivers" - depends on DM && TPM - help - Enable driver model for TPMs. The TIS interface (tis_open(), - tis_sendrecv(), etc.) is then implemented by the TPM uclass. Note - that even with driver model only a single TPM is currently - supported, since the tpm library assumes this. - config TPM_TIS_SANDBOX bool "Enable sandbox TPM driver" depends on SANDBOX @@ -24,7 +15,7 @@ config TPM_TIS_SANDBOX
config TPM_ATMEL_TWI bool "Enable Atmel TWI TPM device driver" - depends on DM_TPM && DM_I2C + depends on TPM && DM_I2C help This driver supports an Atmel TPM device connected on the I2C bus. The usual tpm operations and the 'tpm' command can be used to talk @@ -33,7 +24,7 @@ config TPM_ATMEL_TWI
config TPM_TIS_INFINEON bool "Enable support for Infineon SLB9635/45 TPMs on I2C" - depends on DM_TPM && DM_I2C + depends on TPM && DM_I2C help This driver supports Infineon TPM devices connected on the I2C bus. The usual tpm operations and the 'tpm' command can be used to talk @@ -57,7 +48,7 @@ config TPM_TIS_I2C_BURST_LIMITATION_LEN
config TPM_TIS_LPC bool "Enable support for Infineon SLB9635/45 TPMs on LPC" - depends on DM_TPM && X86 + depends on TPM && X86 help This driver supports Infineon TPM devices connected on the I2C bus. The usual tpm operations and the 'tpm' command can be used to talk diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index 5748145..1d49e95 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -3,7 +3,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_DM_TPM) += tpm-uclass.o +obj-$(CONFIG_TPM) += tpm-uclass.o
obj-$(CONFIG_TPM_ATMEL_TWI) += tpm_atmel_twi.o obj-$(CONFIG_TPM_TIS_INFINEON) += tpm_tis_infineon.o
