[PATCH v1 1/1] timer: npcm: Add driver for Nuvoton NPCM SoCs
This driver enables a periodic timer on NPCM SoCs and implements the get_count timer ops.
Signed-off-by: Stanley Chu yschu@nuvoton.com --- drivers/timer/Kconfig | 6 ++ drivers/timer/Makefile | 1 + drivers/timer/npcm-timer.c | 111 +++++++++++++++++++++++++++++++++++++ 3 files changed, 118 insertions(+) create mode 100644 drivers/timer/npcm-timer.c
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 8913142654..f22c46f44e 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -143,6 +143,12 @@ config NOMADIK_MTU_TIMER The MTU provides 4 decrementing free-running timers. At the moment, only the first timer is used by the driver.
+config NPCM_TIMER + bool "Nuvoton NPCM timer support" + depends on TIMER + help + Select this to enable a timer on Nuvoton NPCM SoCs. + config OMAP_TIMER bool "Omap timer support" depends on TIMER diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index e2bd530eb0..39bda1ea79 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -14,6 +14,7 @@ obj-$(CONFIG_CADENCE_TTC_TIMER) += cadence-ttc.o obj-$(CONFIG_DESIGNWARE_APB_TIMER) += dw-apb-timer.o obj-$(CONFIG_MPC83XX_TIMER) += mpc83xx_timer.o obj-$(CONFIG_NOMADIK_MTU_TIMER) += nomadik-mtu-timer.o +obj-$(CONFIG_NPCM_TIMER) += npcm-timer.o obj-$(CONFIG_OMAP_TIMER) += omap-timer.o obj-$(CONFIG_RENESAS_OSTM_TIMER) += ostm_timer.o obj-$(CONFIG_RISCV_TIMER) += riscv_timer.o diff --git a/drivers/timer/npcm-timer.c b/drivers/timer/npcm-timer.c new file mode 100644 index 0000000000..f7d95d4bfa --- /dev/null +++ b/drivers/timer/npcm-timer.c @@ -0,0 +1,111 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2022 Nuvoton Technology Corp. + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <timer.h> +#include <asm/io.h> + +#define NPCM_TIMER_CLOCK_RATE 1000000UL /* 1MHz timer */ +#define NPCM_TIMER_INPUT_RATE 25000000UL /* Rate of input clock */ +#define NPCM_TIMER_TDR_MASK GENMASK(23, 0) +#define NPCM_TIMER_MAX_VAL NPCM_TIMER_TDR_MASK /* max counter value */ + +/* Register offsets */ +#define TCR0 0x0 /* Timer Control and Status Register */ +#define TICR0 0x8 /* Timer Initial Count Register */ +#define TDR0 0x10 /* Timer Data Register */ + +/* TCR fields */ +#define TCR_MODE_PERIODIC BIT(27) +#define TCR_EN BIT(30) +#define TCR_PRESCALE_25 (25 - 1) + +/* + * 24-bits down-counting hw timer. + * last_count: last hw counter value. + * counter: the value to be returned for get_count ops. + */ +struct npcm_timer_priv { + void __iomem *base; + u32 last_count; + u64 counter; +}; + +static u64 npcm_timer_get_count(struct udevice *dev) +{ + struct npcm_timer_priv *priv = dev_get_priv(dev); + u32 val; + + /* The timer is couting down */ + val = readl(priv->base + TDR0) & NPCM_TIMER_TDR_MASK; + if (val <= priv->last_count) + priv->counter += priv->last_count - val; + else + priv->counter += priv->last_count + (NPCM_TIMER_MAX_VAL + 1 - val); + priv->last_count = val; + + return priv->counter; +} + +static int npcm_timer_probe(struct udevice *dev) +{ + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct npcm_timer_priv *priv = dev_get_priv(dev); + struct clk clk; + int ret; + + priv->base = dev_read_addr_ptr(dev); + if (!priv->base) + return -ENOENT; + priv->counter = 0; + priv->last_count = 0; + uc_priv->clock_rate = NPCM_TIMER_CLOCK_RATE; + + if (IS_ENABLED(CONFIG_ARCH_NPCM750)) { + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) + return ret; + + ret = clk_set_rate(&clk, NPCM_TIMER_INPUT_RATE); + if (ret < 0) + return ret; + } + + /* + * Configure timer and start + * periodic mode + * input clock freq = 25Mhz + * prescale = 25 + * timer clock rate = 25Mhz/25 + */ + writel(0, priv->base + TCR0); + writel(NPCM_TIMER_MAX_VAL, priv->base + TICR0); + writel(TCR_EN | TCR_MODE_PERIODIC | TCR_PRESCALE_25, + priv->base + TCR0); + + return 0; +} + +static const struct timer_ops npcm_timer_ops = { + .get_count = npcm_timer_get_count, +}; + +static const struct udevice_id npcm_timer_ids[] = { + { .compatible = "nuvoton,npcm845-timer" }, + { .compatible = "nuvoton,npcm750-timer" }, + {} +}; + +U_BOOT_DRIVER(npcm_timer) = { + .name = "npcm_timer", + .id = UCLASS_TIMER, + .of_match = npcm_timer_ids, + .priv_auto = sizeof(struct npcm_timer_priv), + .probe = npcm_timer_probe, + .ops = &npcm_timer_ops, + .flags = DM_FLAG_PRE_RELOC, +};
+config NPCM_TIMER
- bool "Nuvoton NPCM timer support"
- depends on TIMER
- help
- config OMAP_TIMER bool "Omap timer support" depends on TIMER
- Copyright (c) 2022 Nuvoton Technology Corp.
Should this be calculated by NPCM_TIMER_INPUT_RATE/NPCM_TIMER_CLOCK_RATE
Also thanks for including me I always love the attention, but I'm not sure why I have been CCed in many of you recent patches is there a reason for this?
Thank you, Jesse Taube
- 24-bits down-counting hw timer.
- last_count: last hw counter value.
- counter: the value to be returned for get_count ops.
- void __iomem *base;
- u32 last_count;
- u64 counter;
- struct npcm_timer_priv *priv = dev_get_priv(dev);
- u32 val;
- /* The timer is couting down */
- val = readl(priv->base + TDR0) & NPCM_TIMER_TDR_MASK;
- if (val <= priv->last_count)
- else
- priv->last_count = val;
- return priv->counter;
- struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- struct clk clk;
- int ret;
- priv->base = dev_read_addr_ptr(dev);
- if (!priv->base)
return -ENOENT;
- priv->counter = 0;
- priv->last_count = 0;
- uc_priv->clock_rate = NPCM_TIMER_CLOCK_RATE;
- if (IS_ENABLED(CONFIG_ARCH_NPCM750)) {
if (ret < 0)
return ret;
if (ret < 0)
return ret;
* periodic mode
* prescale = 25
- writel(0, priv->base + TCR0);
- writel(NPCM_TIMER_MAX_VAL, priv->base + TICR0);
- writel(TCR_EN | TCR_MODE_PERIODIC | TCR_PRESCALE_25,
priv->base + TCR0);
- .get_count = npcm_timer_get_count,
- { .compatible = "nuvoton,npcm845-timer" },
- { .compatible = "nuvoton,npcm750-timer" },
- .name = "npcm_timer",
- .id = UCLASS_TIMER,
- .of_match = npcm_timer_ids,
- .priv_auto = sizeof(struct npcm_timer_priv),
- .probe = npcm_timer_probe,
- .ops = &npcm_timer_ops,
- .flags = DM_FLAG_PRE_RELOC,
Jesse Taube
Stanley Chu
