[GIT PULL] Please pull u-boot-amlogic-20230131
Hi Tom,
Sorry for the late PR, here's changes for next release: - Switch USB Gadget to DM ! Finally, the last legacy bit is now over - Add new boards: - Odroid Go Ultra, a portable console based on S922X - Odroid-N2L, a smaller version of the N2+
The PR also contains: - jethub j100: add rescue boot from microSD - move meson sm command to cmd/meson and add efusedump sub-command
The CI job is at https://source.denx.de/u-boot/custodians/u-boot-amlogic/pipelines/14947
Thanks, Neil
The following changes since commit 7b84c973b96775576dcff228d865e8570be26c82:
ns16650: Correct CONFIG_SYS_NS16550_MEM32 platforms (2023-01-09 11:30:49 -0500)
https://source.denx.de/u-boot/custodians/u-boot-amlogic.git tags/u-boot-amlogic-20230131
for you to fetch changes up to 8f5e9de121003bfd9a64a5b3a503c0fbd02af823:
ARM: meson: Add support for Odroid-N2L (2023-01-30 14:24:17 +0100)
---------------------------------------------------------------- - jethub j100: add rescue boot from microSD - move meson sm command to cmd/meson and add efusedump sub-command - switch dwc2 otg to DM for G12A, GXL & AXG - Add new boards: - Odroid Go Ultra - Odroid-N2L
---------------------------------------------------------------- Alexey Romanov (5): asm/arch-meson: add missing meson_sm_write_efuse signature arm/mach-meson: move smc commands in cmd/meson doc/usage: cmd: documentation for meson/sm command cmd/arm: meson: sm: introduce efusedump command doc/usage: cmd: sm: documentation efusedump cmd
Mattijs Korpershoek (2): usb: dwc3-meson-g12a: force mode on child add/removal ARM: meson: g12a: switch dwc2 otg to DM
Neil Armstrong (6): usb: dwc3-meson-gxl: force mode on child add/removal ARM: meson: switch AXG & GX dwc2 otg to DM ARM: dts: sync Amlogic ARM64 DT from v6.2-rc1 ARM: meson: add support for Odroid Go Ultra ARM: dts: Import Odroid-N2L support ARM: meson: Add support for Odroid-N2L
Viacheslav Bocharov (1): board: amlogic: jethub j100: add rescue boot from microSD
MAINTAINERS | 1 + arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-g12-common.dtsi | 167 +++-- arch/arm/dts/meson-g12a.dtsi | 5 + .../arm/dts/meson-g12b-odroid-go-ultra-u-boot.dtsi | 16 + arch/arm/dts/meson-g12b-odroid-go-ultra.dts | 722 +++++++++++++++++++++ arch/arm/dts/meson-g12b-odroid-n2.dtsi | 410 +----------- arch/arm/dts/meson-g12b-odroid-n2l-u-boot.dtsi | 7 + arch/arm/dts/meson-g12b-odroid-n2l.dts | 125 ++++ arch/arm/dts/meson-g12b-odroid.dtsi | 445 +++++++++++++ arch/arm/dts/meson-g12b.dtsi | 5 + arch/arm/dts/meson-sm1.dtsi | 52 +- arch/arm/include/asm/arch-meson/sm.h | 28 + arch/arm/mach-meson/board-axg.c | 129 ---- arch/arm/mach-meson/board-g12a.c | 127 ---- arch/arm/mach-meson/board-gx.c | 137 ---- arch/arm/mach-meson/sm.c | 144 ---- cmd/Kconfig | 7 + cmd/Makefile | 3 + cmd/meson/Makefile | 5 + cmd/meson/sm.c | 191 ++++++ configs/bananapi-m5_defconfig | 1 + configs/beelink-gsking-x_defconfig | 1 + configs/beelink-gtking_defconfig | 1 + configs/beelink-gtkingpro_defconfig | 1 + configs/jethub_j100_defconfig | 1 + configs/jethub_j80_defconfig | 1 + configs/khadas-vim2_defconfig | 1 + configs/khadas-vim3_android_ab_defconfig | 1 + configs/khadas-vim3_android_defconfig | 1 + configs/khadas-vim3_defconfig | 1 + configs/khadas-vim3l_android_ab_defconfig | 1 + configs/khadas-vim3l_android_defconfig | 1 + configs/khadas-vim3l_defconfig | 1 + configs/khadas-vim_defconfig | 1 + configs/libretech-ac_defconfig | 1 + configs/libretech-cc_defconfig | 1 + configs/libretech-s905d-pc_defconfig | 1 + configs/libretech-s912-pc_defconfig | 1 + configs/odroid-c4_defconfig | 1 + configs/odroid-go-ultra_defconfig | 70 ++ configs/odroid-hc4_defconfig | 1 + configs/odroid-n2_defconfig | 1 + configs/odroid-n2l_defconfig | 70 ++ configs/radxa-zero_defconfig | 1 + configs/s400_defconfig | 1 + configs/sei510_defconfig | 1 + configs/sei610_defconfig | 1 + configs/u200_defconfig | 1 + configs/wetek-core2_defconfig | 1 + doc/board/amlogic/index.rst | 6 +- doc/board/amlogic/odroid-go-ultra.rst | 34 + doc/board/amlogic/odroid-n2l.rst | 31 + doc/usage/cmd/sm.rst | 48 ++ doc/usage/index.rst | 1 + drivers/usb/dwc3/dwc3-meson-g12a.c | 18 + drivers/usb/dwc3/dwc3-meson-gxl.c | 18 + include/configs/jethub.h | 1 + 58 files changed, 2040 insertions(+), 1012 deletions(-) create mode 100644 arch/arm/dts/meson-g12b-odroid-go-ultra-u-boot.dtsi create mode 100644 arch/arm/dts/meson-g12b-odroid-go-ultra.dts create mode 100644 arch/arm/dts/meson-g12b-odroid-n2l-u-boot.dtsi create mode 100644 arch/arm/dts/meson-g12b-odroid-n2l.dts create mode 100644 arch/arm/dts/meson-g12b-odroid.dtsi create mode 100644 cmd/meson/Makefile create mode 100644 cmd/meson/sm.c create mode 100644 configs/odroid-go-ultra_defconfig create mode 100644 configs/odroid-n2l_defconfig create mode 100644 doc/board/amlogic/odroid-go-ultra.rst create mode 100644 doc/board/amlogic/odroid-n2l.rst create mode 100644 doc/usage/cmd/sm.rst
On Tue, Jan 31, 2023 at 09:48:09AM +0100, Neil Armstrong wrote:
Hi Tom,
- Add new boards:
Thanks, Neil
Neil Armstrong
