[U-Boot] [PATCH 1/5] 74xx_7xx: CPCI750: Add commandline editing/history
Signed-off-by: Stefan Roese sr@denx.de Cc: Reinhard Arlt reinhard.arlt@esd-electronics.com --- include/configs/CPCI750.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/include/configs/CPCI750.h b/include/configs/CPCI750.h index 8494faa..3b0b888 100644 --- a/include/configs/CPCI750.h +++ b/include/configs/CPCI750.h @@ -76,7 +76,8 @@
#define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
-#define CONFIG_AUTO_COMPLETE 1 +#define CONFIG_CMDLINE_EDITING /* add command line history */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */
/* Define which ETH port will be used for connecting the network */ #define CONFIG_SYS_ETH_PORT ETH_0
This command is used to load/boot an OS-image which is transferred from the CPCI host to the CPCI target/adapter.
Signed-off-by: Stefan Roese sr@denx.de Cc: Reinhard Arlt reinhard.arlt@esd-electronics.com --- board/esd/cpci750/cpci750.c | 76 +++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 76 insertions(+), 0 deletions(-)
diff --git a/board/esd/cpci750/cpci750.c b/board/esd/cpci750/cpci750.c index 4826633..3473504 100644 --- a/board/esd/cpci750/cpci750.c +++ b/board/esd/cpci750/cpci750.c @@ -122,6 +122,9 @@ static char show_config_tab[][15] = {{"PCI0DLL_2 "}, /* 31 */
extern flash_info_t flash_info[];
+extern int do_bootm (cmd_tbl_t *, int, int, char *[]); +extern int do_bootvx (cmd_tbl_t *, int, int, char *[]); + /* ------------------------------------------------------------------------- */
/* this is the current GT register space location */ @@ -538,6 +541,79 @@ int display_mem_map (void) return (0); }
+/* + * Command loadpci: wait for signal from host and boot image. + */ +int do_loadpci(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + volatile unsigned int *ptr; + int count = 0; + int count2 = 0; + int status; + char addr[16]; + char str[] = "\|/-"; + char *local_args[2]; + + /* + * Mark sync address + */ + ptr = 0; + ptr[0] = 0xffffffff; + ptr[1] = 0xffffffff; + puts("\nWaiting for image from pci host -"); + + /* + * Wait for host to write the start address + */ + while (*ptr == 0xffffffff) { + count++; + if (!(count % 100)) { + count2++; + putc(0x08); /* backspace */ + putc(str[count2 % 4]); + } + + /* Abort if ctrl-c was pressed */ + if (ctrlc()) { + puts("\nAbort\n"); + return 0; + } + + udelay(1000); + } + + sprintf(addr, "%08x", *ptr); + printf("\nBooting Image at addr 0x%s ...\n", addr); + setenv("loadaddr", addr); + + switch (ptr[1] == 0) { + case 0: + /* + * Boot image via bootm + */ + local_args[0] = argv[0]; + local_args[1] = NULL; + status = do_bootm (cmdtp, 0, 1, local_args); + break; + case 1: + /* + * Boot image via bootvx + */ + local_args[0] = argv[0]; + local_args[1] = NULL; + status = do_bootvx (cmdtp, 0, 1, local_args); + break; + } + + return 0; +} + +U_BOOT_CMD( + loadpci, 1, 1, do_loadpci, + "loadpci - Wait for pci-image and boot it\n", + NULL + ); + /* DRAM check routines copied from gw8260 */
#if defined (CONFIG_SYS_DRAM_TEST)
Hi Stefan,
doen't it make sense to use/extend the code from board/esd/common/cmd_loadpci.c in stead it copying this code? Even that code is running on 4xx only, it should be simple to modify it for cpci750. Adding support for bootvx should be simple also.
Matthias
- Command loadpci: wait for signal from host and boot image.
- volatile unsigned int *ptr;
- int count = 0;
- int count2 = 0;
- int status;
- char addr[16];
- char str[] = "\|/-";
- char *local_args[2];
* Mark sync address
- ptr = 0;
- ptr[0] = 0xffffffff;
- ptr[1] = 0xffffffff;
- puts("\nWaiting for image from pci host -");
- while (*ptr == 0xffffffff) {
count++;
count2++;
if (ctrlc()) {
puts("\nAbort\n");
udelay(1000);
- sprintf(addr, "%08x", *ptr);
- printf("\nBooting Image at addr 0x%s ...\n", addr);
- setenv("loadaddr", addr);
- switch (ptr[1] == 0) {
- case 0:
break;
- case 1:
break;
+U_BOOT_CMD(
- loadpci, 1, 1, do_loadpci,
- "loadpci - Wait for pci-image and boot it\n",
- NULL
Hi Matthias,
I thought about this too but didn't do it mainly because of those reasons:
a) As you already mentioned the current code in common is 4xx specific.
b) The parameters used to identify the image type are incompatible on both platforms. "1" is used for booting a script on 4xx and VxWorks on CPCI750.
c) I have no means of testing any changes in this code on 4xx and/or 750.
So if you still think this should be unified then I need your assistance here. You would need to help me testing those changes on both platforms. Please let me know if you can do this.
Thanks.
Best regards, Stefan
Hi Stefan,
please leave the code as is. It is already used in a project and so modifying the parameter type may no change.
On Friday 05 June 2009 05:39, Stefan Roese wrote:
Hi Matthias,
But easy to adapt :-)
Of course I can do such testing on 4xx hardware.
But let's shutdown this discussion.
Matthias
Dear Stefan Roese,
Applied to next, thanks.
Signed-off-by: Stefan Roese sr@denx.de Cc: Reinhard Arlt reinhard.arlt@esd-electronics.com --- board/esd/cpci750/cpci750.c | 11 +++++------ 1 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/board/esd/cpci750/cpci750.c b/board/esd/cpci750/cpci750.c index 3473504..69ae517 100644 --- a/board/esd/cpci750/cpci750.c +++ b/board/esd/cpci750/cpci750.c @@ -451,13 +451,12 @@ int misc_init_r ()
void after_reloc (ulong dest_addr, gd_t * gd) { + memoryMapDeviceSpace (BOOT_DEVICE, CONFIG_SYS_BOOT_SPACE, CONFIG_SYS_BOOT_SIZE);
- memoryMapDeviceSpace (BOOT_DEVICE, CONFIG_SYS_BOOT_SPACE, CONFIG_SYS_BOOT_SIZE); - - display_mem_map (); - /* now, jump to the main ppcboot board init code */ - board_init_r (gd, dest_addr); - /* NOTREACHED */ + display_mem_map (); + /* now, jump to the main ppcboot board init code */ + board_init_r (gd, dest_addr); + /* NOTREACHED */ }
Dear Stefan Roese,
The Marvell bridge 64360 supports serveral PCI functions, not only 0. This patch enables access to those functions.
Signed-off-by: Stefan Roese sr@denx.de Cc: Reinhard Arlt reinhard.arlt@esd-electronics.com --- board/esd/cpci750/cpci750.c | 16 +++++++++++----- board/esd/cpci750/pci.c | 14 +++++++++----- 2 files changed, 20 insertions(+), 10 deletions(-)
diff --git a/board/esd/cpci750/cpci750.c b/board/esd/cpci750/cpci750.c index 69ae517..18944ef 100644 --- a/board/esd/cpci750/cpci750.c +++ b/board/esd/cpci750/cpci750.c @@ -187,6 +187,7 @@ original ppcboot 1.1.6 source end */ static void gt_pci_config (void) { unsigned int stat; + unsigned int data; unsigned int val = 0x00fff864; /* DINK32: BusNum 23:16, DevNum 15:11, FuncNum 10:8, RegNum 7:2 */
/* In PCIX mode devices provide their own bus and device numbers. We query the Discovery II's @@ -254,10 +255,11 @@ static void gt_pci_config (void)
/*ronen update the pci internal registers base address.*/ #ifdef MAP_PCI - for (stat = 0; stat <= PCI_HOST1; stat++) - pciWriteConfigReg (stat, - PCI_INTERNAL_REGISTERS_MEMORY_MAPPED_BASE_ADDRESS, - SELF, CONFIG_SYS_GT_REGS); + for (stat = 0; stat <= PCI_HOST1; stat++) { + data = pciReadConfigReg(stat, PCI_INTERNAL_REGISTERS_MEMORY_MAPPED_BASE_ADDRESS, SELF); + data = (data & 0x0f) | CONFIG_SYS_GT_REGS; + pciWriteConfigReg (stat, PCI_INTERNAL_REGISTERS_MEMORY_MAPPED_BASE_ADDRESS, SELF, data); + } #endif
} @@ -451,9 +453,13 @@ int misc_init_r ()
void after_reloc (ulong dest_addr, gd_t * gd) { - memoryMapDeviceSpace (BOOT_DEVICE, CONFIG_SYS_BOOT_SPACE, CONFIG_SYS_BOOT_SIZE); + memoryMapDeviceSpace (BOOT_DEVICE, CONFIG_SYS_BOOT_SPACE, + CONFIG_SYS_BOOT_SIZE);
display_mem_map (); + GT_REG_WRITE (PCI_0BASE_ADDRESS_REGISTERS_ENABLE, 0xfffffdfe); + GT_REG_WRITE (PCI_1BASE_ADDRESS_REGISTERS_ENABLE, 0xfffffdfe); + /* now, jump to the main ppcboot board init code */ board_init_r (gd, dest_addr); /* NOTREACHED */ diff --git a/board/esd/cpci750/pci.c b/board/esd/cpci750/pci.c index bfc7e55..3b59b16 100644 --- a/board/esd/cpci750/pci.c +++ b/board/esd/cpci750/pci.c @@ -768,11 +768,12 @@ static int gt_read_config_dword (struct pci_controller *hose, int bus = PCI_BUS (dev);
if ((bus == local_buses[0]) || (bus == local_buses[1])) { - *value = pciReadConfigReg ((PCI_HOST) hose->cfg_addr, offset, + *value = pciReadConfigReg ((PCI_HOST) hose->cfg_addr, + offset | (PCI_FUNC(dev) << 8), PCI_DEV (dev)); } else { - *value = pciOverBridgeReadConfigReg ((PCI_HOST) hose-> - cfg_addr, offset, + *value = pciOverBridgeReadConfigReg ((PCI_HOST) hose->cfg_addr, + offset | (PCI_FUNC(dev) << 8), PCI_DEV (dev), bus); }
@@ -785,13 +786,16 @@ static int gt_write_config_dword (struct pci_controller *hose, int bus = PCI_BUS (dev);
if ((bus == local_buses[0]) || (bus == local_buses[1])) { - pciWriteConfigReg ((PCI_HOST) hose->cfg_addr, offset, + pciWriteConfigReg ((PCI_HOST) hose->cfg_addr, + offset | (PCI_FUNC(dev) << 8), PCI_DEV (dev), value); } else { pciOverBridgeWriteConfigReg ((PCI_HOST) hose->cfg_addr, - offset, PCI_DEV (dev), bus, + offset | (PCI_FUNC(dev) << 8), + PCI_DEV (dev), bus, value); } + return 0; }
Hi Stefan,
see one comment below.
- for (stat = 0; stat <= PCI_HOST1; stat++) {
Please break those long lines.
Matthias
The CPCI750 can be built as CPCI host or adapter/target board. This patch adds support for runtime detection of those variants.
Signed-off-by: Stefan Roese sr@denx.de Cc: Reinhard Arlt reinhard.arlt@esd-electronics.com --- board/esd/cpci750/cpci750.c | 9 ++++++++ board/esd/cpci750/ide.c | 4 ++- board/esd/cpci750/pci.c | 49 ++++++++++++++++++++++++++++++------------ include/configs/CPCI750.h | 2 + 4 files changed, 49 insertions(+), 15 deletions(-)
diff --git a/board/esd/cpci750/cpci750.c b/board/esd/cpci750/cpci750.c index 18944ef..1e76bc6 100644 --- a/board/esd/cpci750/cpci750.c +++ b/board/esd/cpci750/cpci750.c @@ -140,6 +140,15 @@ void board_prebootm_init (void); unsigned int INTERNAL_REG_BASE_ADDR = CONFIG_SYS_GT_REGS; int display_mem_map (void);
+/* + * Skip video initialization on slave variant. + * This function will overwrite the weak default in cfb_console.c + */ +int board_video_skip(void) +{ + return CPCI750_SLAVE_TEST; +} + /* ------------------------------------------------------------------------- */
/* diff --git a/board/esd/cpci750/ide.c b/board/esd/cpci750/ide.c index 9bdc523..638219f 100644 --- a/board/esd/cpci750/ide.c +++ b/board/esd/cpci750/ide.c @@ -39,6 +39,8 @@ int ide_preinit (void) int l;
status = 1; + if (CPCI750_SLAVE_TEST != 0) + return status; for (l = 0; l < CONFIG_SYS_IDE_MAXBUS; l++) { ide_bus_offset[l] = -ATA_STATUS; } @@ -57,7 +59,7 @@ int ide_preinit (void) ide_bus_offset[1] &= 0xfffffffe; ide_bus_offset[1] += CONFIG_SYS_PCI0_IO_SPACE; } - return (status); + return status; }
void ide_set_reset (int flag) { diff --git a/board/esd/cpci750/pci.c b/board/esd/cpci750/pci.c index 3b59b16..a2c1c50 100644 --- a/board/esd/cpci750/pci.c +++ b/board/esd/cpci750/pci.c @@ -795,7 +795,6 @@ static int gt_write_config_dword (struct pci_controller *hose, PCI_DEV (dev), bus, value); } - return 0; }
@@ -807,6 +806,9 @@ static void gt_setup_ide (struct pci_controller *hose, u32 bar_response, bar_value; int bar;
+ if (CPCI750_SLAVE_TEST != 0) + return; + for (bar = 0; bar < 6; bar++) { /*ronen different function for 3rd bank. */ unsigned int offset = @@ -833,6 +835,9 @@ static void gt_setup_cpcidvi (struct pci_controller *hose, { u32 bar_value, pci_response;
+ if (CPCI750_SLAVE_TEST != 0) + return; + pci_hose_read_config_dword (hose, dev, PCI_COMMAND, &pci_response); pci_hose_write_config_dword (hose, dev, PCI_BASE_ADDRESS_0, 0xffffffff); pci_hose_read_config_dword (hose, dev, PCI_BASE_ADDRESS_0, &pci_response); @@ -911,6 +916,7 @@ struct pci_controller pci1_hose = { void pci_init_board (void) { unsigned int command; + unsigned int slave; #ifdef CONFIG_PCI_PNP unsigned int bar; #endif @@ -922,6 +928,8 @@ void pci_init_board (void) gt_cpcidvi_rom.base = 0; #endif
+ slave = CPCI750_SLAVE_TEST; + pci0_hose.config_table = gt_config_table; pci1_hose.config_table = gt_config_table;
@@ -957,27 +965,40 @@ void pci_init_board (void) pci0_hose.cfg_addr = (unsigned int *) PCI_HOST0;
pci_register_hose (&pci0_hose); - pciArbiterEnable (PCI_HOST0); - pciParkingDisable (PCI_HOST0, 1, 1, 1, 1, 1, 1, 1); - command = pciReadConfigReg (PCI_HOST0, PCI_COMMAND, SELF); - command |= PCI_COMMAND_MASTER; - pciWriteConfigReg (PCI_HOST0, PCI_COMMAND, SELF, command); - command = pciReadConfigReg (PCI_HOST0, PCI_COMMAND, SELF); - command |= PCI_COMMAND_MEMORY; - pciWriteConfigReg (PCI_HOST0, PCI_COMMAND, SELF, command); + if (slave == 0) { + pciArbiterEnable (PCI_HOST0); + pciParkingDisable (PCI_HOST0, 1, 1, 1, 1, 1, 1, 1); + command = pciReadConfigReg (PCI_HOST0, PCI_COMMAND, SELF); + command |= PCI_COMMAND_MASTER; + pciWriteConfigReg (PCI_HOST0, PCI_COMMAND, SELF, command); + command = pciReadConfigReg (PCI_HOST0, PCI_COMMAND, SELF); + command |= PCI_COMMAND_MEMORY; + pciWriteConfigReg (PCI_HOST0, PCI_COMMAND, SELF, command);
#ifdef CONFIG_PCI_PNP - pciauto_config_init(&pci0_hose); - pciauto_region_allocate(pci0_hose.pci_io, 0x400, &bar); + pciauto_config_init(&pci0_hose); + pciauto_region_allocate(pci0_hose.pci_io, 0x400, &bar); #endif #ifdef CONFIG_PCI_SCAN_SHOW - printf("PCI: Bus Dev VenId DevId Class Int\n"); + printf("PCI: Bus Dev VenId DevId Class Int\n"); #endif - pci0_hose.last_busno = pci_hose_scan_bus (&pci0_hose, pci0_hose.first_busno); + pci0_hose.last_busno = pci_hose_scan_bus (&pci0_hose, + pci0_hose.first_busno);
#ifdef DEBUG - gt_pci_bus_mode_display (PCI_HOST1); + gt_pci_bus_mode_display (PCI_HOST1); #endif + } else { + pciArbiterDisable (PCI_HOST0); + pciParkingDisable (PCI_HOST0, 1, 1, 1, 1, 1, 1, 1); + command = pciReadConfigReg (PCI_HOST0, PCI_COMMAND, SELF); + command |= PCI_COMMAND_MASTER; + pciWriteConfigReg (PCI_HOST0, PCI_COMMAND, SELF, command); + command = pciReadConfigReg (PCI_HOST0, PCI_COMMAND, SELF); + command |= PCI_COMMAND_MEMORY; + pciWriteConfigReg (PCI_HOST0, PCI_COMMAND, SELF, command); + pci0_hose.last_busno = pci0_hose.first_busno; + } pci1_hose.first_busno = pci0_hose.last_busno + 1; pci1_hose.last_busno = 0xff; pci1_hose.current_busno = pci1_hose.first_busno; diff --git a/include/configs/CPCI750.h b/include/configs/CPCI750.h index 3b0b888..d516c3c 100644 --- a/include/configs/CPCI750.h +++ b/include/configs/CPCI750.h @@ -627,4 +627,6 @@
#define CONFIG_SYS_BOARD_ASM_INIT 1
+#define CPCI750_SLAVE_TEST (((in8(0xf0300000) & 0x80) == 0) ? 0 : 1) + #endif /* __CONFIG_H */
Dear Stefan Roese,
Dear Stefan Roese,
Applied to next. Thanks.
Matthias Fuchs
Matthias Fuchs
Stefan Roese
