[U-Boot] [PATCH] defconfigs: Add a config for AM43xx High Security EVM with QSPI Boot support
On AM43xx HS devices, QSPI boot is XIP and we use a single stage bootloader. Add a defconfig for this.
Signed-off-by: Andrew F. Davis afd@ti.com --- MAINTAINERS | 1 + configs/am43xx_hs_evm_qspi_defconfig | 56 ++++++++++++++++++++++++++++++++++++ 2 files changed, 57 insertions(+) create mode 100644 configs/am43xx_hs_evm_qspi_defconfig
diff --git a/MAINTAINERS b/MAINTAINERS index 04acf2b89d..8cd01fb241 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -420,6 +420,7 @@ F: arch/arm/mach-omap2/sec-common.c F: arch/arm/mach-omap2/config_secure.mk F: configs/am335x_hs_evm_defconfig F: configs/am43xx_hs_evm_defconfig +F: configs/am43xx_hs_evm_qspi_defconfig F: configs/am57xx_hs_evm_defconfig F: configs/dra7xx_hs_evm_defconfig F: configs/k2hk_hs_evm_defconfig diff --git a/configs/am43xx_hs_evm_qspi_defconfig b/configs/am43xx_hs_evm_qspi_defconfig new file mode 100644 index 0000000000..634ac32377 --- /dev/null +++ b/configs/am43xx_hs_evm_qspi_defconfig @@ -0,0 +1,56 @@ +CONFIG_ARM=y +# CONFIG_SYS_THUMB_BUILD is not set +CONFIG_ARCH_OMAP2PLUS=y +CONFIG_TI_COMMON_CMD_OPTIONS=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_AM43XX=y +CONFIG_TI_SECURE_DEVICE=y +CONFIG_TI_SECURE_EMIF_REGION_START=0xbdb00000 +CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 +CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 +CONFIG_ISW_ENTRY_ADDR=0x300018e0 +CONFIG_DEFAULT_DEVICE_TREE="am43x-epos-evm" +CONFIG_FIT_IMAGE_POST_PROCESS=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1,SERIAL1,QSPI" +CONFIG_QSPI_BOOT=y +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_VERSION_VARIABLE=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MTDPARTS=y +CONFIG_ISO_PARTITION=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +# CONFIG_BLK is not set +CONFIG_DFU_MMC=y +CONFIG_DFU_RAM=y +CONFIG_DFU_SF=y +CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y +CONFIG_MMC_OMAP_HS=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_PHYLIB=y +CONFIG_PHY_GIGE=y +CONFIG_DM_SERIAL=y +CONFIG_SYS_NS16550=y +CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GADGET=y +CONFIG_USB_DWC3_OMAP=y +CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_G_DNL_MANUFACTURER="Texas Instruments" +CONFIG_G_DNL_VENDOR_NUM=0x0403 +CONFIG_G_DNL_PRODUCT_NUM=0xbd00
This has a bunch of warnings about CONFIG_SYS_NS16550_REG_SIZE and:
Where do we even use CONFIG_SERIAL1 ? Or CONFIG_QSPI? Finally, I think board/ti/am43xx/Kconfig needs to at least borrow the CONS_INDEX logic from board/ti/am335x/Kconfig, if not migrate it to drivers/serial/Kconfig and start depend'ing it in on TI parts. Thanks!
Andrew F. Davis
