[U-Boot] [PATCH v2 1/2] rockchip: clk: rv1108: remove duplicate reset init
rockchip_reset_bind() already does the needed init for the reset registers, only referenced the wrong cru structure.
So we can get rid of the open-coded reset init and just fix the correct cru reference.
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com --- changes in v2: - drop the now unused old softreset_reg struct softresets are only used inside the softreset driver and have their own separate struct
arch/arm/include/asm/arch-rockchip/clock.h | 6 ------ drivers/clk/rockchip/clk_rv1108.c | 14 +------------- 2 files changed, 1 insertion(+), 19 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/clock.h b/arch/arm/include/asm/arch-rockchip/clock.h index 0eb19ca86f..1d5b3a07d0 100644 --- a/arch/arm/include/asm/arch-rockchip/clock.h +++ b/arch/arm/include/asm/arch-rockchip/clock.h @@ -43,12 +43,6 @@ struct sysreset_reg { unsigned int glb_srst_snd_value; };
-struct softreset_reg { - void __iomem *base; - unsigned int sf_reset_offset; - unsigned int sf_reset_num; -}; - /** * clk_get_divisor() - Calculate the required clock divisior * diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index 3ebb007fab..b1e8208d54 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -681,7 +681,6 @@ static int rv1108_clk_bind(struct udevice *dev) int ret; struct udevice *sys_child, *sf_child; struct sysreset_reg *priv; - struct softreset_reg *sf_priv;
/* The reset driver does not have a device node, so bind it here */ ret = device_bind_driver(dev, "rockchip_sysreset", "sysreset", @@ -698,22 +697,11 @@ static int rv1108_clk_bind(struct udevice *dev) }
#if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) - ret = offsetof(struct rk3368_cru, softrst_con[0]); + ret = offsetof(struct rv1108_cru, softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 13); if (ret) debug("Warning: software reset driver bind faile\n"); #endif - ret = device_bind_driver_to_node(dev, "rockchip_reset", "reset", - dev_ofnode(dev), &sf_child); - if (ret) { - debug("Warning: No rockchip reset driver: ret=%d\n", ret); - } else { - sf_priv = malloc(sizeof(struct softreset_reg)); - sf_priv->sf_reset_offset = offsetof(struct rv1108_cru, - softrst_con[0]); - sf_priv->sf_reset_num = 13; - sf_child->priv = sf_priv; - }
return 0; }
CONFIG_IS_ENABLED() needs the config name like used in Kconfig, so without the leading CONFIG_. The clock drivers all wrongly check for CONFIG_RESET_ROCKCHIP, fix that
Signed-off-by: Heiko Stuebner heiko.stuebner@theobroma-systems.com Reviewed-by: Kever Yang kever.yang@rock-chips.com --- drivers/clk/rockchip/clk_rk3036.c | 2 +- drivers/clk/rockchip/clk_rk3188.c | 2 +- drivers/clk/rockchip/clk_rk322x.c | 2 +- drivers/clk/rockchip/clk_rk3288.c | 2 +- drivers/clk/rockchip/clk_rk3328.c | 2 +- drivers/clk/rockchip/clk_rk3368.c | 2 +- drivers/clk/rockchip/clk_rk3399.c | 2 +- drivers/clk/rockchip/clk_rv1108.c | 2 +- 8 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk3036.c b/drivers/clk/rockchip/clk_rk3036.c index 9bf9cedaf8..6d5ae3d003 100644 --- a/drivers/clk/rockchip/clk_rk3036.c +++ b/drivers/clk/rockchip/clk_rk3036.c @@ -352,7 +352,7 @@ static int rk3036_clk_bind(struct udevice *dev) sys_child->priv = priv; }
-#if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) ret = offsetof(struct rk3036_cru, cru_softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 9); if (ret) diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index dda686cfb3..3ea9a81b32 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -590,7 +590,7 @@ static int rk3188_clk_bind(struct udevice *dev) sys_child->priv = priv; }
-#if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) ret = offsetof(struct rk3188_cru, cru_softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 9); if (ret) diff --git a/drivers/clk/rockchip/clk_rk322x.c b/drivers/clk/rockchip/clk_rk322x.c index f09730c91b..6e8a164d62 100644 --- a/drivers/clk/rockchip/clk_rk322x.c +++ b/drivers/clk/rockchip/clk_rk322x.c @@ -508,7 +508,7 @@ static int rk322x_clk_bind(struct udevice *dev) sys_child->priv = priv; }
-#if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) ret = offsetof(struct rk322x_cru, cru_softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 9); if (ret) diff --git a/drivers/clk/rockchip/clk_rk3288.c b/drivers/clk/rockchip/clk_rk3288.c index 0122381633..85d1b67e43 100644 --- a/drivers/clk/rockchip/clk_rk3288.c +++ b/drivers/clk/rockchip/clk_rk3288.c @@ -1015,7 +1015,7 @@ static int rk3288_clk_bind(struct udevice *dev) sys_child->priv = priv; }
-#if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) ret = offsetof(struct rk3288_cru, cru_softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 12); if (ret) diff --git a/drivers/clk/rockchip/clk_rk3328.c b/drivers/clk/rockchip/clk_rk3328.c index 4331048a87..e700a1bc25 100644 --- a/drivers/clk/rockchip/clk_rk3328.c +++ b/drivers/clk/rockchip/clk_rk3328.c @@ -791,7 +791,7 @@ static int rk3328_clk_bind(struct udevice *dev) sys_child->priv = priv; }
-#if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) ret = offsetof(struct rk3328_cru, softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 12); if (ret) diff --git a/drivers/clk/rockchip/clk_rk3368.c b/drivers/clk/rockchip/clk_rk3368.c index c1a867b2ed..b51d529ade 100644 --- a/drivers/clk/rockchip/clk_rk3368.c +++ b/drivers/clk/rockchip/clk_rk3368.c @@ -620,7 +620,7 @@ static int rk3368_clk_bind(struct udevice *dev) sys_child->priv = priv; }
-#if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) ret = offsetof(struct rk3368_cru, softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 15); if (ret) diff --git a/drivers/clk/rockchip/clk_rk3399.c b/drivers/clk/rockchip/clk_rk3399.c index a273bd1beb..9020a9f202 100644 --- a/drivers/clk/rockchip/clk_rk3399.c +++ b/drivers/clk/rockchip/clk_rk3399.c @@ -1195,7 +1195,7 @@ static int rk3399_clk_bind(struct udevice *dev) sys_child->priv = priv; }
-#if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) ret = offsetof(struct rk3399_cru, softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 21); if (ret) diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index b1e8208d54..6019bfc6ce 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -696,7 +696,7 @@ static int rv1108_clk_bind(struct udevice *dev) sys_child->priv = priv; }
-#if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) ret = offsetof(struct rv1108_cru, softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 13); if (ret)
Applied to u-boot-rockchip master.
Thanks, - Kever
Thanks, - Kever
changes in v2:
void __iomem *base;
- clk_get_divisor() - Calculate the required clock divisior
- ret = offsetof(struct rv1108_cru, softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 13); if (ret) debug("Warning: software reset driver bind faile\n"); #endif
if (ret) {
} else {
softrst_con[0]);
return 0; }
Thanks, - Kever
Thanks,
- Kever
changes in v2:
diff --git a/arch/arm/include/asm/arch-rockchip/clock.h b/arch/arm/include/asm/arch-rockchip/clock.h index 0eb19ca86f..1d5b3a07d0 100644 --- a/arch/arm/include/asm/arch-rockchip/clock.h +++ b/arch/arm/include/asm/arch-rockchip/clock.h @@ -43,12 +43,6 @@ struct sysreset_reg { unsigned int glb_srst_snd_value; }; -struct softreset_reg { - void __iomem *base; - unsigned int sf_reset_offset; - unsigned int sf_reset_num; -};
/** * clk_get_divisor() - Calculate the required clock divisior * diff --git a/drivers/clk/rockchip/clk_rv1108.c b/drivers/clk/rockchip/clk_rv1108.c index 3ebb007fab..b1e8208d54 100644 --- a/drivers/clk/rockchip/clk_rv1108.c +++ b/drivers/clk/rockchip/clk_rv1108.c @@ -681,7 +681,6 @@ static int rv1108_clk_bind(struct udevice *dev) int ret; struct udevice *sys_child, *sf_child; struct sysreset_reg *priv; - struct softreset_reg *sf_priv; /* The reset driver does not have a device node, so bind it here */ ret = device_bind_driver(dev, "rockchip_sysreset", "sysreset", @@ -698,22 +697,11 @@ static int rv1108_clk_bind(struct udevice *dev) } #if CONFIG_IS_ENABLED(CONFIG_RESET_ROCKCHIP) - ret = offsetof(struct rk3368_cru, softrst_con[0]); + ret = offsetof(struct rv1108_cru, softrst_con[0]); ret = rockchip_reset_bind(dev, ret, 13); if (ret) debug("Warning: software reset driver bind faile\n"); #endif - ret = device_bind_driver_to_node(dev, "rockchip_reset", "reset", - dev_ofnode(dev), &sf_child); - if (ret) { - debug("Warning: No rockchip reset driver: ret=%d\n", ret); - } else { - sf_priv = malloc(sizeof(struct softreset_reg)); - sf_priv->sf_reset_offset = offsetof(struct rv1108_cru, - softrst_con[0]); - sf_priv->sf_reset_num = 13; - sf_child->priv = sf_priv; - } return 0; }
Heiko Stuebner
Kever Yang
